Hi All
I recently found out that a change broke my jesd link to the ad9173.
I think it is due to a change in the device tree.
The tx_dma got removed and it seems that now the link does not get initialized:
root@analog:~# grep "" /sys/bus/platform/devices/*jesd*/status /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:Link is enabled /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:Measured Link Clock: 250.002 MHz /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:Reported Link Clock: 250.000 MHz /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:Lane rate: 10000.000 MHz /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:Lane rate / 40: 250.000 MHz /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:LMFC rate: 31.250 MHz /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:SYNC~: deasserted /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:Link status: CGS /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:SYSREF captured: No /sys/bus/platform/devices/84a90000.axi-jesd204-tx/status:SYSREF alignment error: No
Device tree was changed to:
/dts-v1/; / { fpga_axi: fpga-axi@0 { interrupt-parent = <&gic>; compatible = "simple-bus"; #address-cells = <0x1>; #size-cells = <0x1>; ranges = <0 0 0 0xffffffff>; /* tx_dma: tx-dmac@9c420000 { #dma-cells = <1>; compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c420000 0x10000>; interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>; adi,channels { #size-cells = <0>; #address-cells = <1>; dma-channel@0 { reg = <0>; adi,source-bus-width = <128>; adi,source-bus-type = <0>; adi,destination-bus-width = <256>; adi,destination-bus-type = <1>; adi,cyclic; }; }; }; */ axi_ad9173_core: axi-ad9173-hpc@84a04000 { compatible = "adi,axi-ad9172-1.0"; reg = <0x84a04000 0x10000>; // dmas = <&tx_dma 0>; // dma-names = "tx"; spibus-connected = <&dac0_ad9173>; // adi,axi-pl-fifo-enable; }; axi_ad9173_jesd: axi-jesd204-tx@84a90000 { compatible = "adi,axi-jesd204-tx-1.0"; reg = <0x84a90000 0x4000>; interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&axi_ad9173_adxcvr 1>, <&axi_ad9173_adxcvr 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; adi,octets-per-frame = <1>; adi,frames-per-multiframe = <32>; adi,converter-resolution = <16>; adi,bits-per-sample = <16>; adi,converters-per-device = <4>; #clock-cells = <0>; clock-output-names = "jesd_dac_lane_clk"; }; axi_ad9173_adxcvr: axi-adxcvr-tx@84a60000 { compatible = "adi,axi-adxcvr-1.0"; reg = <0x84a60000 0x1000>; clocks = <<c6952 8>; clock-names = "conv"; adi,sys-clk-select = <XCVR_QPLL>; adi,out-clk-select = <XCVR_REFCLK_DIV2>; // XCVR_REFCLK adi,use-lpm-enable; #clock-cells = <1>; clock-output-names = "dac_gt_clk", "tx_out_clk"; };
I see no evidence of what's wrong with the TX part
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.0-gef6f1e5007c2-dirty (badc0ded@LAPTOP-KU6CGS3H) (gcc version 7.2.0 (GCC)) #274 SMP Tue Jan 10 09:56:55 CET 2023 [ 0.000000] Machine model: Enclustra XU8 SOM [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 256 MiB at 0x000000006fc00000 [ 0.000000] On node 0 totalpages: 524032 [ 0.000000] DMA32 zone: 7165 pages used for memmap [ 0.000000] DMA32 zone: 0 pages reserved [ 0.000000] DMA32 zone: 524032 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x414 with crng_init=0 [ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s51864 r8192 d30056 u90112 [ 0.000000] pcpu-alloc: s51864 r8192 d30056 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516867 [ 0.000000] Kernel command line: console=ttyPS0,115200 rw earlyprintk rootwait root=/dev/mmcblk1p2 [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Memory: 1774848K/2096128K available (13372K kernel code, 1506K rwdata, 10692K rodata, 896K init, 343K bss, 59136K reserved, 262144K cma-reserved) [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x7b0074340, max_idle_ns: 440795202884 ns [ 0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255543ns [ 0.000246] Console: colour dummy device 80x25 [ 0.000265] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332) [ 0.000273] pid_max: default: 32768 minimum: 301 [ 0.000374] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000384] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.001068] ASID allocator initialised with 32768 entries [ 0.001118] rcu: Hierarchical SRCU implementation. [ 0.001419] EFI services will not be available. [ 0.001496] smp: Bringing up secondary CPUs ... [ 0.001773] Detected VIPT I-cache on CPU1 [ 0.001801] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.001860] smp: Brought up 1 node, 2 CPUs [ 0.001868] SMP: Total of 2 processors activated. [ 0.001873] CPU features: detected: 32-bit EL0 Support [ 0.003323] CPU: All CPU(s) started at EL2 [ 0.003334] alternatives: patching kernel code [ 0.004210] devtmpfs: initialized [ 0.009197] Registered cp15_barrier emulation handler [ 0.009205] Registered setend emulation handler [ 0.009309] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.009322] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.014231] xor: measuring software checksum speed [ 0.052026] 8regs : 2303.000 MB/sec [ 0.092055] 8regs_prefetch: 2053.000 MB/sec [ 0.132083] 32regs : 2830.000 MB/sec [ 0.172112] 32regs_prefetch: 2379.000 MB/sec [ 0.172117] xor: using function: 32regs (2830.000 MB/sec) [ 0.172126] pinctrl core: initialized pinctrl subsystem [ 0.172733] NET: Registered protocol family 16 [ 0.172990] audit: initializing netlink subsys (disabled) [ 0.173437] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 0.173445] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.173898] audit: type=2000 audit(0.172:1): state=initialized audit_enabled=0 res=1 [ 0.174577] DMA: preallocated 256 KiB pool for atomic allocations [ 0.194722] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.260412] raid6: int64x1 gen() 393 MB/s [ 0.328301] raid6: int64x1 xor() 444 MB/s [ 0.396396] raid6: int64x2 gen() 679 MB/s [ 0.464425] raid6: int64x2 xor() 602 MB/s [ 0.532479] raid6: int64x4 gen() 1036 MB/s [ 0.600541] raid6: int64x4 xor() 742 MB/s [ 0.668596] raid6: int64x8 gen() 979 MB/s [ 0.736627] raid6: int64x8 xor() 745 MB/s [ 0.804657] raid6: neonx1 gen() 723 MB/s [ 0.872737] raid6: neonx1 xor() 851 MB/s [ 0.940792] raid6: neonx2 gen() 1159 MB/s [ 1.008816] raid6: neonx2 xor() 1203 MB/s [ 1.076898] raid6: neonx4 gen() 1504 MB/s [ 1.144922] raid6: neonx4 xor() 1438 MB/s [ 1.212974] raid6: neonx8 gen() 1645 MB/s [ 1.281023] raid6: neonx8 xor() 1525 MB/s [ 1.281027] raid6: using algorithm neonx8 gen() 1645 MB/s [ 1.281031] raid6: .... xor() 1525 MB/s, rmw enabled [ 1.281035] raid6: using neon recovery algorithm [ 1.281916] SCSI subsystem initialized [ 1.281951] libata version 3.00 loaded. [ 1.282080] usbcore: registered new interface driver usbfs [ 1.282111] usbcore: registered new interface driver hub [ 1.282141] usbcore: registered new device driver usb [ 1.282296] media: Linux media interface: v0.10 [ 1.282320] videodev: Linux video capture interface: v2.00 [ 1.282367] pps_core: LinuxPPS API ver. 1 registered [ 1.282372] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.282385] PTP clock support registered [ 1.282408] EDAC MC: Ver: 3.0.0 [ 1.284260] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver. [ 1.284648] jesd204: created con: id=0, topo=1, link=0, /fpga-axi@0/axi-adxcvr-rx-3@84bc0000 <-> /fpga-axi@0/axi-jesd204-rx-3@84aac000 [ 1.284659] jesd204: created con: id=1, topo=1, link=0, /fpga-axi@0/axi-adxcvr-rx-2@84b80000 <-> /fpga-axi@0/axi-jesd204-rx-2@84aa8000 [ 1.284670] jesd204: created con: id=2, topo=1, link=0, /fpga-axi@0/axi-adxcvr-rx-1@84b40000 <-> /fpga-axi@0/axi-jesd204-rx-1@84aa4000 [ 1.284680] jesd204: created con: id=3, topo=1, link=0, /fpga-axi@0/axi-adxcvr-rx-0@84b00000 <-> /fpga-axi@0/axi-jesd204-rx-0@84aa0000 [ 1.284690] jesd204: created con: id=4, topo=1, link=0, /fpga-axi@0/axi-jesd204-rx-3@84aac000 <-> /fpga-axi@0/axi-ad9680-hpc-3@84a1c000 [ 1.284700] jesd204: created con: id=5, topo=1, link=0, /fpga-axi@0/axi-jesd204-rx-2@84aa8000 <-> /fpga-axi@0/axi-ad9680-hpc-2@84a18000 [ 1.284710] jesd204: created con: id=6, topo=1, link=0, /fpga-axi@0/axi-jesd204-rx-1@84aa4000 <-> /fpga-axi@0/axi-ad9680-hpc-1@84a14000 [ 1.284720] jesd204: created con: id=7, topo=1, link=0, /fpga-axi@0/axi-jesd204-rx-0@84aa0000 <-> /fpga-axi@0/axi-ad9680-hpc-0@84a10000 [ 1.284731] jesd204: created con: id=8, topo=1, link=0, /fpga-axi@0/axi-ad9680-hpc-3@84a1c000 <-> /amba/spi@ff050000/ad9680@4 [ 1.284741] jesd204: created con: id=9, topo=1, link=0, /fpga-axi@0/axi-ad9680-hpc-2@84a18000 <-> /amba/spi@ff050000/ad9680@3 [ 1.284751] jesd204: created con: id=10, topo=1, link=0, /fpga-axi@0/axi-ad9680-hpc-1@84a14000 <-> /amba/spi@ff050000/ad9680@2 [ 1.284761] jesd204: created con: id=11, topo=1, link=0, /fpga-axi@0/axi-ad9680-hpc-0@84a10000 <-> /amba/spi@ff050000/ad9680@1 [ 1.284776] jesd204: /amba/spi@ff050000/ad9680@4: JESD204[0] transition uninitialized -> initialized [ 1.284784] jesd204: /amba/spi@ff050000/ad9680@3: JESD204[0] transition uninitialized -> initialized [ 1.284792] jesd204: /amba/spi@ff050000/ad9680@2: JESD204[0] transition uninitialized -> initialized [ 1.284800] jesd204: /amba/spi@ff050000/ad9680@1: JESD204[0] transition uninitialized -> initialized [ 1.284805] jesd204: found 16 devices and 4 topologies [ 1.284841] FPGA manager framework [ 1.285015] Advanced Linux Sound Architecture Driver Initialized. [ 1.285279] Bluetooth: Core ver 2.22 [ 1.285302] NET: Registered protocol family 31 [ 1.285306] Bluetooth: HCI device and connection manager initialized [ 1.285314] Bluetooth: HCI socket layer initialized [ 1.285320] Bluetooth: L2CAP socket layer initialized [ 1.285340] Bluetooth: SCO socket layer initialized [ 1.285730] clocksource: Switched to clocksource arch_sys_counter [ 1.285799] VFS: Disk quotas dquot_6.6.0 [ 1.285839] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.290157] NET: Registered protocol family 2 [ 1.290493] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes) [ 1.290519] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 1.290623] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 1.290820] TCP: Hash tables configured (established 16384 bind 16384) [ 1.290875] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 1.290915] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 1.291018] NET: Registered protocol family 1 [ 1.291288] RPC: Registered named UNIX socket transport module. [ 1.291293] RPC: Registered udp transport module. [ 1.291297] RPC: Registered tcp transport module. [ 1.291300] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.291558] PCI: CLS 0 bytes, default 64 [ 1.291928] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 1.292032] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 1.292771] Initialise system trusted keyrings [ 1.292890] workingset: timestamp_bits=62 max_order=19 bucket_order=0 [ 1.293503] NFS: Registering the id_resolver key type [ 1.293515] Key type id_resolver registered [ 1.293519] Key type id_legacy registered [ 1.293528] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.293544] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 2.369241] NET: Registered protocol family 38 [ 2.426282] Key type asymmetric registered [ 2.426288] Asymmetric key parser 'x509' registered [ 2.426322] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.426328] io scheduler noop registered [ 2.426332] io scheduler deadline registered [ 2.426362] io scheduler cfq registered (default) [ 2.426367] io scheduler mq-deadline registered [ 2.426372] io scheduler kyber registered [ 2.454892] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 2.458586] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 2.462762] brd: module loaded [ 2.466428] loop: module loaded [ 2.466605] Registered mathworks_ip class [ 2.467376] mtdoops: mtd device (mtddev=name/number) must be supplied [ 2.468747] libphy: Fixed MDIO Bus: probed [ 2.469951] tun: Universal TUN/TAP device driver, 1.6 [ 2.471095] CAN device driver interface [ 2.472041] usbcore: registered new interface driver asix [ 2.472074] usbcore: registered new interface driver ax88179_178a [ 2.472101] usbcore: registered new interface driver cdc_ether [ 2.472131] usbcore: registered new interface driver net1080 [ 2.472157] usbcore: registered new interface driver cdc_subset [ 2.472183] usbcore: registered new interface driver zaurus [ 2.472218] usbcore: registered new interface driver cdc_ncm [ 2.475415] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.475423] ehci-pci: EHCI PCI platform driver [ 2.475690] usbcore: registered new interface driver uas [ 2.475723] usbcore: registered new interface driver usb-storage [ 2.475780] usbcore: registered new interface driver usbserial_generic [ 2.475800] usbserial: USB Serial support registered for generic [ 2.475823] usbcore: registered new interface driver ftdi_sio [ 2.475841] usbserial: USB Serial support registered for FTDI USB Serial Device [ 2.475865] usbcore: registered new interface driver upd78f0730 [ 2.475884] usbserial: USB Serial support registered for upd78f0730 [ 2.478355] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0 [ 2.478435] i2c /dev entries driver [ 2.480432] usbcore: registered new interface driver uvcvideo [ 2.480437] USB Video Class driver (1.1.1) [ 2.482618] Bluetooth: HCI UART driver ver 2.3 [ 2.482628] Bluetooth: HCI UART protocol H4 registered [ 2.482632] Bluetooth: HCI UART protocol BCSP registered [ 2.482658] Bluetooth: HCI UART protocol LL registered [ 2.482663] Bluetooth: HCI UART protocol ATH3K registered [ 2.482681] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 2.482733] Bluetooth: HCI UART protocol Intel registered [ 2.482751] Bluetooth: HCI UART protocol QCA registered [ 2.482790] usbcore: registered new interface driver bcm203x [ 2.482817] usbcore: registered new interface driver bpa10x [ 2.482845] usbcore: registered new interface driver bfusb [ 2.482875] usbcore: registered new interface driver btusb [ 2.482879] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 2.482923] usbcore: registered new interface driver ath3k [ 2.483250] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT) [ 2.483411] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED) [ 2.483572] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT) [ 2.484000] sdhci: Secure Digital Host Controller Interface driver [ 2.484004] sdhci: Copyright(c) Pierre Ossman [ 2.484008] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.484768] ledtrig-cpu: registered to indicate activity on CPUs [ 2.484819] zynqmp_firmware_probe Platform Management API v1.1 [ 2.484825] zynqmp_firmware_probe Trustzone version v1.0 [ 2.487572] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized [ 2.509701] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22 [ 2.510844] alg: No test for xilinx-zynqmp-aes (zynqmp-aes) [ 2.510865] zynqmp_aes zynqmp_aes: AES Successfully Registered [ 2.511063] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384) [ 2.511227] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa) [ 2.511434] usbcore: registered new interface driver usbhid [ 2.511438] usbhid: USB HID core driver [ 2.521346] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.00.a) found [ 2.521533] axi_sysid 85000000.axi-sysid-0: system ID header version mismatch. Expected 1, Reported 0 [ 2.521546] axi_sysid: probe of 85000000.axi-sysid-0 failed with error -14 [ 2.521852] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered [ 2.523008] usbcore: registered new interface driver snd-usb-audio [ 2.524784] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 2.525139] Initializing XFRM netlink socket [ 2.525209] NET: Registered protocol family 10 [ 2.525583] Segment Routing with IPv6 [ 2.525666] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.526045] NET: Registered protocol family 17 [ 2.526058] NET: Registered protocol family 15 [ 2.526075] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 2.526643] can: controller area network core (rev 20170425 abi 9) [ 2.526675] NET: Registered protocol family 29 [ 2.526681] can: raw protocol (rev 20170425) [ 2.526685] can: broadcast manager protocol (rev 20170425 t) [ 2.526692] can: netlink gateway (rev 20170425) max_hops=1 [ 2.526775] Bluetooth: RFCOMM TTY layer initialized [ 2.526783] Bluetooth: RFCOMM socket layer initialized [ 2.526795] Bluetooth: RFCOMM ver 1.11 [ 2.526803] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.526807] Bluetooth: BNEP filters: protocol multicast [ 2.526813] Bluetooth: BNEP socket layer initialized [ 2.526818] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.526823] Bluetooth: HIDP socket layer initialized [ 2.526920] 9pnet: Installing 9P2000 support [ 2.526931] NET: Registered protocol family 36 [ 2.526947] Key type dns_resolver registered [ 2.527344] registered taskstats version 1 [ 2.527349] Loading compiled-in X.509 certificates [ 2.527655] Btrfs loaded, crc32c=crc32c-generic [ 2.533905] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 33, base_baud = 6249999) is a xuartps [ 4.016542] console [ttyPS0] enabled [ 4.020530] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 34, base_baud = 6249999) is a xuartps [ 4.030157] of-fpga-region fpga-full: FPGA Region probed [ 4.036776] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success [ 4.043873] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success [ 4.050973] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success [ 4.058077] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success [ 4.065173] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success [ 4.072275] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success [ 4.079375] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success [ 4.086477] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success [ 4.093712] zynqmp_pll_disable() clock disable failed for rpll_int, ret = -13 [ 4.101701] HMC703: Start Probing [ 4.101711] HMC703: Devicetree Parsing... [ 4.105637] HMC703: Finished Probing [ 4.110262] pe4312 spi1.3: spi1.3 supply vcc not found, using dummy regulator [ 4.120982] pe4312 spi1.3: Linked as a consumer to regulator.0 [ 4.137632] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.170145] ad9208 spi2.1: ad9680 PLL LOCKED [ 4.174436] ad9208 spi2.1: ad9680 Rev. 5 Grade 8 (API 1.0.1) probed [ 4.186915] random: fast init done [ 4.190320] ad9208 spi2.2: Unrecognized CHIP_ID 0xF000 [ 4.215347] ad9208 spi2.3: ad9680 PLL LOCKED [ 4.219638] ad9208 spi2.3: ad9680 Rev. 5 Grade 8 (API 1.0.1) probed [ 4.232163] ad9208 spi2.4: Unrecognized CHIP_ID 0xF000 [ 4.239334] m25p80 spi0.0: non-uniform erase sector maps are not supported yet. [ 4.246818] m25p80 spi0.0: s25fl512s (65536 Kbytes) [ 4.251711] 6 fixed-partitions partitions found on MTD device spi0.0 [ 4.258054] Creating 6 MTD partitions on "spi0.0": [ 4.262840] 0x000000000000-0x000000700000 : "qspi-bootimage" [ 4.268950] 0x000000700000-0x000000c00000 : "qspi-kernel" [ 4.274745] 0x000000c00000-0x000000c80000 : "qspi-device-tree" [ 4.280969] 0x000000c80000-0x000000d00000 : "qspi-bootargs" [ 4.286942] 0x000000d00000-0x000000d40000 : "qspi-bootscript" [ 4.293078] 0x000000d40000-0x000004000000 : "qspi-rootfs" [ 4.299676] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp_pinconf_cfg_set failed: pin 26 param 1 value 0 [ 4.310444] macb ff0b0000.ethernet: Not enabling partial store and forward [ 4.317851] libphy: MACB_mii_bus: probed [ 4.394922] Micrel KSZ9031 Gigabit PHY ff0b0000.ethernet-ffffffff:03: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=ff0b0000.ethernet-ffffffff:03, irq=POLL) [ 4.410738] macb ff0b0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 20 (20:b0:f7:06:42:6c) [ 4.420876] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM [ 4.427396] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM [ 4.433880] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM [ 4.440362] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM [ 4.447770] dwc3-of-simple ff9d0000.usb0: dwc3_simple_set_phydata: Can't find usb3-phy [ 4.456511] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 22 [ 4.494803] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA 64-bit [ 4.537737] mmc1: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit [ 4.572182] cf_axi_adc 84a10000.axi-ad9680-hpc-0: ADI AIM (10.01.b) at 0x84A10000 mapped to 0x(____ptrval____), probed ADC AD9680 as MASTER [ 4.606293] cf_axi_adc 84a18000.axi-ad9680-hpc-2: ADI AIM (10.01.b) at 0x84A18000 mapped to 0x(____ptrval____), probed ADC AD9680 as MASTER [ 4.619518] axi_adxcvr 84b00000.axi-adxcvr-rx-0: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 4.638703] axi_adxcvr 84b00000.axi-adxcvr-rx-0: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B00000. Number of lanes: 2. [ 4.650385] axi_adxcvr 84b40000.axi-adxcvr-rx-1: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 4.667247] axi_adxcvr 84b40000.axi-adxcvr-rx-1: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B40000. Number of lanes: 2. [ 4.678922] axi_adxcvr 84b80000.axi-adxcvr-rx-2: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 4.695456] axi_adxcvr 84b80000.axi-adxcvr-rx-2: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B80000. Number of lanes: 2. [ 4.707111] axi_adxcvr 84bc0000.axi-adxcvr-rx-3: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 4.723944] axi_adxcvr 84bc0000.axi-adxcvr-rx-3: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84BC0000. Number of lanes: 2. [ 4.735974] axi_adxcvr 84a60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using QPLL on GTH4 at 0x84A60000. Number of lanes: 8. [ 4.749639] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.765112] mmc0: new HS200 MMC card at address 0001 [ 4.770511] mmcblk0: mmc0:0001 IB2916 14.6 GiB [ 4.775394] mmcblk0boot0: mmc0:0001 IB2916 partition 1 4.00 MiB [ 4.781661] mmcblk0boot1: mmc0:0001 IB2916 partition 2 4.00 MiB [ 4.787680] mmcblk0rpmb: mmc0:0001 IB2916 partition 3 4.00 MiB, chardev (242:0) [ 4.795942] mmcblk0: p1 [ 4.799586] ad9172 spi2.0: AD916x DAC Chip ID: 4 [ 4.804206] ad9172 spi2.0: AD916x DAC Product ID: 9173 [ 4.809338] ad9172 spi2.0: AD916x DAC Product Grade: 0 [ 4.814467] ad9172 spi2.0: AD916x DAC Product Revision: 2 [ 4.819857] ad9172 spi2.0: AD916x Revision: 1.1.1 [ 4.824553] ad9172 spi2.0: PLL Input rate 187500000 [ 4.937826] ad9172 spi2.0: PLL lock status 0, DLL lock status: 1 [ 5.127746] mmc1: new high speed SDHC card at address 0001 [ 5.133669] mmcblk1: mmc1:0001 0016G 15.2 GiB [ 5.139022] mmcblk1: p1 p2 p3 [ 5.161787] ad9172 spi2.0: Serdes PLL Locked (stat: 3) [ 5.273998] ad9172 spi2.0: code_grp_sync: f [ 5.278177] ad9172 spi2.0: frame_sync_stat: 0 [ 5.282524] ad9172 spi2.0: good_checksum_stat: 0 [ 5.287132] ad9172 spi2.0: init_lane_sync_stat: 0 [ 5.291828] ad9172 spi2.0: 4 lanes @ 10000000 kBps [ 5.296872] ad9172 spi2.0: code_grp_sync: f [ 5.301049] ad9172 spi2.0: frame_sync_stat: 0 [ 5.305395] ad9172 spi2.0: good_checksum_stat: 0 [ 5.310004] ad9172 spi2.0: init_lane_sync_stat: 0 [ 5.314700] ad9172 spi2.0: 4 lanes @ 10000000 kBps [ 5.320051] ad9172 spi2.0: Probed. [ 5.341900] cf_axi_dds 84a04000.axi-ad9173-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DDS AD917x [ 5.358666] rtc_zynqmp ffa60000.rtc: setting system clock to 2023-01-16 07:56:32 UTC (1673855792) [ 5.367531] of_cfs_init [ 5.369984] of_cfs_init: OK [ 5.372912] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.510784] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.518176] ALSA device list: [ 5.521131] No soundcards found. [ 5.524912] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 5.533520] cfg80211: failed to load regulatory.db [ 5.854126] EXT4-fs (mmcblk1p2): recovery complete [ 5.863746] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 5.871855] VFS: Mounted root (ext4 filesystem) on device 179:26. [ 5.883246] devtmpfs: mounted [ 5.886386] Freeing unused kernel memory: 896K [ 5.890852] Run /sbin/init as init process [ 6.653762] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition initialized -> probed [ 6.664382] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition probed -> idle [ 6.674384] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition idle -> device_init [ 6.684818] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition device_init -> link_init [ 6.695685] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_init -> link_supported [ 6.706811] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_supported -> link_pre_setup [ 6.718370] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 6.718444] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 6.730015] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 6.751663] systemd[1]: Detected architecture arm64. [ 6.763014] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 6.763055] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> link_setup [ 6.791002] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_setup -> opt_setup_stage1 [ 6.802385] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 6.814299] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 6.830536] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 6.842608] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 6.855475] systemd[1]: Set hostname to <analog>. [ 6.855763] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition initialized -> probed [ 6.870791] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition probed -> idle [ 6.880788] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition idle -> device_init [ 6.891230] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition device_init -> link_init [ 6.902103] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_init -> link_supported [ 6.913262] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_supported -> link_pre_setup [ 6.924871] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 6.936547] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 6.948291] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 6.960072] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> link_setup [ 6.971378] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_setup -> opt_setup_stage1 [ 6.982770] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 6.994689] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 7.006604] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 7.018522] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 7.032739] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 7.032755] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition clocks_enable -> link_enable [ 7.032763] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_enable -> link_running [ 7.032770] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_running -> opt_post_running_stage [ 7.033834] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 7.033848] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition clocks_enable -> link_enable [ 7.033855] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_enable -> link_running [ 7.033862] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_running -> opt_post_running_stage [ 7.271671] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 7.288802] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 7.459729] systemd[1]: /etc/systemd/system/tof-server.service:1: Assignment outside of section. Ignoring. [ 7.469434] systemd[1]: /etc/systemd/system/tof-server.service:2: Assignment outside of section. Ignoring. [ 7.658091] random: systemd: uninitialized urandom read (16 bytes read) [ 7.671131] random: systemd: uninitialized urandom read (16 bytes read) [ 7.678321] systemd[1]: Created slice system-getty.slice. [ 7.701814] random: systemd: uninitialized urandom read (16 bytes read) [ 7.708457] systemd[1]: Reached target Swap. [ 7.722085] systemd[1]: Listening on fsck to fsckd communication Socket. [ 9.344947] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 9.429805] systemd-journald[2151]: Received request to flush runtime journal from PID 1 [ 11.218782] random: crng init done [ 11.218788] random: 7 urandom warning(s) missed due to ratelimiting [ 15.157830] pps pps0: new PPS source ptp0 [ 15.157842] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered. [ 15.157981] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 19.230365] macb ff0b0000.ethernet eth0: link up (1000/Full) [ 19.230391] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 20.820708] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
I think I need to change the device tree to use jesd204-fsm to get this part working again due to the "broken" tx_dma link.
I tried the following changes (and variations of this change):
axi_ad9173_core: axi-ad9173-hpc@84a04000 { /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9173_jesd 0 1>; }; axi_ad9173_jesd: axi-jesd204-tx@84a90000 { /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9173_adxcvr 0 1>; }; axi_ad9173_adxcvr: axi-adxcvr-tx@84a60000 { /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <<c6952 0 1>; }; dac0_ad9173: ad9173@0 { /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <1>; /* This is the TOP device */ jesd204-link-ids = <0>; jesd204-inputs = <&axi_ad9173_core 0 1>; jesd204-ignore-errors; }; ltc6952: ltc6952@4 { jesd204-device; #jesd204-cells = <2>; };
New device trees look like:
/dts-v1/; #include "zynqmp.dtsi" #include "zynqmp-clk-ccf.dtsi" #include "zynq-enclustra-qspi64-parts.dtsi" #include <dt-bindings/input/input.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/pinctrl/pinctrl-zynqmp.h> #include <dt-bindings/phy/phy.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/jesd204/adxcvr.h> #include <dt-bindings/iio/adc/adi,ad9208.h> / { fpga_axi: fpga-axi@0 { interrupt-parent = <&gic>; compatible = "simple-bus"; #address-cells = <0x1>; #size-cells = <0x1>; ranges = <0 0 0 0xffffffff>; rx_dma0: dma@9c400000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c400000 0x1000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>; adi,channels { #size-cells = <0>; #address-cells = <1>; dma-channel@0 { reg = <0>; adi,source-bus-width = <64>; adi,source-bus-type = <2>; adi,destination-bus-width = <64>; adi,destination-bus-type = <0>; }; }; }; rx_dma1: dma@9c404000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c404000 0x1000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 91 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>; adi,channels { #size-cells = <0>; #address-cells = <1>; dma-channel@0 { reg = <0>; adi,source-bus-width = <64>; adi,source-bus-type = <2>; adi,destination-bus-width = <64>; adi,destination-bus-type = <0>; }; }; }; rx_dma2: dma@9c408000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c408000 0x1000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 93 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>; adi,channels { #size-cells = <0>; #address-cells = <1>; dma-channel@0 { reg = <0>; adi,source-bus-width = <64>; adi,source-bus-type = <2>; adi,destination-bus-width = <64>; adi,destination-bus-type = <0>; }; }; }; rx_dma3: dma@9c40c000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c40c000 0x1000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 95 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>; adi,channels { #size-cells = <0>; #address-cells = <1>; dma-channel@0 { reg = <0>; adi,source-bus-width = <64>; adi,source-bus-type = <2>; adi,destination-bus-width = <64>; adi,destination-bus-type = <0>; }; }; }; /* tx_dma: tx-dmac@9c420000 { #dma-cells = <1>; compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c420000 0x10000>; interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>; adi,channels { #size-cells = <0>; #address-cells = <1>; dma-channel@0 { reg = <0>; adi,source-bus-width = <128>; adi,source-bus-type = <0>; adi,destination-bus-width = <256>; adi,destination-bus-type = <1>; adi,cyclic; }; }; }; */ axi_ad9173_core: axi-ad9173-hpc@84a04000 { compatible = "adi,axi-ad9172-1.0"; reg = <0x84a04000 0x10000>; // dmas = <&tx_dma 0>; // dma-names = "tx"; spibus-connected = <&dac0_ad9173>; // adi,axi-pl-fifo-enable; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9173_jesd 0 1>; }; axi_ad9173_jesd: axi-jesd204-tx@84a90000 { compatible = "adi,axi-jesd204-tx-1.0"; reg = <0x84a90000 0x4000>; interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&axi_ad9173_adxcvr 1>, <&axi_ad9173_adxcvr 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; adi,octets-per-frame = <1>; adi,frames-per-multiframe = <32>; adi,converter-resolution = <16>; adi,bits-per-sample = <16>; adi,converters-per-device = <4>; #clock-cells = <0>; clock-output-names = "jesd_dac_lane_clk"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9173_adxcvr 0 1>; }; axi_ad9680_core0: axi-ad9680-hpc-0@84a10000 { compatible = "adi,axi-ad9680-1.0"; reg = <0x84a10000 0x2000>; dmas = <&rx_dma0 0>; dma-names = "rx"; spibus-connected = <&adc0_ad9680>; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9680_jesd0 1 0>; }; axi_ad9680_core1: axi-ad9680-hpc-1@84a14000 { compatible = "adi,axi-ad9680-1.0"; reg = <0x84a14000 0x2000>; dmas = <&rx_dma1 0>; dma-names = "rx"; spibus-connected = <&adc1_ad9680>; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9680_jesd1 1 0>; }; axi_ad9680_core2: axi-ad9680-hpc-2@84a18000 { compatible = "adi,axi-ad9680-1.0"; reg = <0x84a18000 0x2000>; dmas = <&rx_dma2 0>; dma-names = "rx"; spibus-connected = <&adc2_ad9680>; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9680_jesd2 1 0>; }; axi_ad9680_core3: axi-ad9680-hpc-3@84a1c000 { compatible = "adi,axi-ad9680-1.0"; reg = <0x84a1c000 0x2000>; dmas = <&rx_dma3 0>; dma-names = "rx"; spibus-connected = <&adc3_ad9680>; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9680_jesd3 1 0>; }; axi_ad9680_jesd0: axi-jesd204-rx-0@84aa0000 { compatible = "adi,axi-jesd204-rx-1.0"; reg = <0x84aa0000 0x4000>; interrupts = <0 107 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&axi_ad9680_adxcvr0 1>, <&axi_ad9680_adxcvr0 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; #clock-cells = <0>; clock-output-names = "jesd_adc_lane_clk0"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9680_adxcvr0 1 0>; }; axi_ad9680_jesd1: axi-jesd204-rx-1@84aa4000 { compatible = "adi,axi-jesd204-rx-1.0"; reg = <0x84aa4000 0x4000>; interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&axi_ad9680_adxcvr1 1>, <&axi_ad9680_adxcvr1 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; adi,octets-per-frame = <4>; adi,frames-per-multiframe = <32>; #clock-cells = <0>; clock-output-names = "jesd_adc_lane_clk1"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9680_adxcvr1 1 0>; }; axi_ad9680_jesd2: axi-jesd204-rx-2@84aa8000 { compatible = "adi,axi-jesd204-rx-1.0"; reg = <0x84aa8000 0x4000>; interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&axi_ad9680_adxcvr2 1>, <&axi_ad9680_adxcvr2 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; adi,octets-per-frame = <4>; adi,frames-per-multiframe = <32>; #clock-cells = <0>; clock-output-names = "jesd_adc_lane_clk2"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9680_adxcvr2 1 0>; }; axi_ad9680_jesd3: axi-jesd204-rx-3@84aac000 { compatible = "adi,axi-jesd204-rx-1.0"; reg = <0x84aac000 0x4000>; interrupts = <0 96 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&axi_ad9680_adxcvr3 1>, <&axi_ad9680_adxcvr3 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; adi,octets-per-frame = <4>; adi,frames-per-multiframe = <32>; #clock-cells = <0>; clock-output-names = "jesd_adc_lane_clk3"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9680_adxcvr3 1 0>; }; axi_ad9680_adxcvr0: axi-adxcvr-rx-0@84b00000{ compatible = "adi,axi-adxcvr-1.0"; reg = <0x84B00000 0x1000>; clocks = <<c6952 7>; clock-names = "conv"; #clock-cells = <1>; clock-output-names = "adc_gt_clk0", "rx_out_clk0"; adi,sys-clk-select = <XCVR_QPLL>; //XCVR_CPLL adi,out-clk-select = <XCVR_REFCLK_DIV2>; adi,use-lpm-enable; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; adi,jesd204-fsm-delayed-start-ms = <2000>; }; axi_ad9680_adxcvr1: axi-adxcvr-rx-1@84b40000{ compatible = "adi,axi-adxcvr-1.0"; reg = <0x84B40000 0x1000>; clocks = <<c6952 7>; clock-names = "conv"; #clock-cells = <1>; clock-output-names = "adc_gt_clk1", "rx_out_clk1"; adi,sys-clk-select = <XCVR_QPLL>; //XCVR_CPLL adi,out-clk-select = <XCVR_REFCLK_DIV2>; adi,use-lpm-enable; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; adi,jesd204-fsm-delayed-start-ms = <2000>; }; axi_ad9680_adxcvr2: axi-adxcvr-rx-2@84b80000{ compatible = "adi,axi-adxcvr-1.0"; reg = <0x84B80000 0x1000>; clocks = <<c6952 7>; clock-names = "conv"; #clock-cells = <1>; clock-output-names = "adc_gt_clk2", "rx_out_clk2"; adi,sys-clk-select = <XCVR_QPLL>; //XCVR_CPLL adi,out-clk-select = <XCVR_REFCLK_DIV2>; adi,use-lpm-enable; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; adi,jesd204-fsm-delayed-start-ms = <2000>; }; axi_ad9680_adxcvr3: axi-adxcvr-rx-3@84bc0000{ compatible = "adi,axi-adxcvr-1.0"; reg = <0x84BC0000 0x1000>; clocks = <<c6952 7>; clock-names = "conv"; #clock-cells = <1>; clock-output-names = "adc_gt_clk3", "rx_out_clk3"; adi,sys-clk-select = <XCVR_QPLL>; //XCVR_CPLL adi,out-clk-select = <XCVR_REFCLK_DIV2>; adi,use-lpm-enable; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; adi,jesd204-fsm-delayed-start-ms = <2000>; }; axi_ad9173_adxcvr: axi-adxcvr-tx@84a60000 { compatible = "adi,axi-adxcvr-1.0"; reg = <0x84a60000 0x1000>; clocks = <<c6952 8>; clock-names = "conv"; adi,sys-clk-select = <XCVR_QPLL>; adi,out-clk-select = <XCVR_REFCLK_DIV2>; // XCVR_REFCLK adi,use-lpm-enable; #clock-cells = <1>; clock-output-names = "dac_gt_clk", "tx_out_clk"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <<c6952 0 1>; }; }; }; #if SPI_ENABLED &spi0 { is-decoded-cs = <1>; num-cs = <8>; status = "okay"; ltc6952: ltc6952@4 { compatible = "adi,ltc6952"; reg = <4>; #address-cells = <1>; #size-cells = <0>; spi-max-frequency = <10000>; clock-output-names = "ltc6952_out0", "ltc6952_out1", "ltc6952_out2", "ltc6952_out3", "ltc6952_out4", "ltc6952_out5", "ltc6952_out6", "ltc6952_out7", "ltc6952_out8", "ltc6952_out9", "ltc6952_out10"; #clock-cells = <1>; adi,vco-frequency-hz = <1000000000>; adi,ref-frequency-hz = <100000000>; adi,charge-pump-microamp = <8020>; jesd204-device; #jesd204-cells = <2>; ltc6952_c0: channel@0 { reg = <0>; adi,extended-name = "DAC_SYSREF"; adi,divider = <128>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c1: channel@1 { reg = <1>; adi,extended-name = "CLK_ADC4"; adi,divider = <2>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c2: channel@2 { reg = <2>; adi,extended-name = "CLK_ADC3"; adi,divider = <2>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c3: channel@3 { reg = <3>; adi,extended-name = "CLK_ADC2"; adi,divider = <2>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c4: channel@4 { reg = <4>; adi,extended-name = "CLK_ADC1"; adi,divider = <2>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c5: channel@5 { reg = <5>; adi,extended-name = "FPGA_SYSREF"; adi,divider = <128>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c6: channel@6 { reg = <6>; adi,extended-name = "SYSREF_ADC_1-4"; adi,divider = <128>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c7: channel@7 { reg = <7>; adi,extended-name = "RefCLK_ADC"; adi,divider = <2>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c8: channel@8 { reg = <8>; adi,extended-name = "RefCLK_DAC"; adi,divider = <2>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c9: channel@9 { reg = <9>; adi,extended-name = "AUX_CLKout"; adi,divider = <10>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; ltc6952_c10: channel@10 { reg = <10>; adi,extended-name = "CLKout"; adi,divider = <2>; adi,digital-delay = <100>; adi,analog-delay = <0>; }; }; }; &spi1 { is-decoded-cs = <1>; num-cs = <8>; status = "okay"; dac0_ad9173: ad9173@0 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,ad9173"; reg = <0>; spi-max-frequency = <1000000>; clocks = <&axi_ad9173_jesd>, <<c6952 0>, <<c6952 0>; //mult12clk clock-names = "jesd_dac_clk", "dac_clk", "dac_sysref"; adi,dac-rate-khz = <12000000>; adi,jesd-link-mode = <8>; adi,jesd-dual-link-mode = <1>; adi,jesd-subclass = <0>; adi,dac-interpolation = <12>; adi,channel-interpolation = <1>; adi,clock-output-divider = <1>; adi,syncoutb-signal-type-lvds-enable; adi,logic-lanes-mapping = [00 01 02 03 04 05 06 07]; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <1>; /* This is the TOP device */ jesd204-link-ids = <0>; jesd204-inputs = <&axi_ad9173_core 0 1>; jesd204-ignore-errors; }; adc0_ad9680: ad9680@1 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,ad9680"; reg = <1>; spi-max-frequency = <1000000>; clocks = <&axi_ad9680_jesd0>, <<c6952 4>, <<c6952 5>; clock-names = "jesd_adc_clk", "adc_clk", "adc_sysref"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <1>; /* This is the TOP device */ jesd204-link-ids = <0>; jesd204-inputs = <&axi_ad9680_core0 1 0>; jesd204-ignore-errors; adi,logic-lanes-mapping = [00 02 01 03]; //adi,powerdown-pin-enable; adi,powerdown-mode = <AD9208_PDN_MODE_POWERDOWN>; adi,sampling-frequency = /bits/ 64 <500000000>; //adi,input-clock-divider-ratio = <2>; adi,sysref-lmfc-offset = <0>; adi,sysref-pos-window-skew = <0>; adi,sysref-neg-window-skew = <0>; adi,sysref-mode = <AD9208_SYSREF_CONT>; adi,sysref-nshot-ignore-count = <0>; /* JESD204 parameters */ adi,converters-per-device = <4>; /* JESD204 (M) vorher 2 */ adi,lanes-per-device = <2>; /* JESD204 (L) */ adi,octets-per-frame = <4>; /* JESD204 (F) vorher 2*/ adi,frames-per-multiframe = <32>; /* JESD204 (K) */ adi,converter-resolution = <14>; /* JESD204 (N) */ adi,bits-per-sample = <16>; /* JESD204 (N') */ adi,control-bits-per-sample = <2>; /* JESD204 (CS) */ adi,subclass = <1>; /* JESD204 (SUBCLASSV) */ /* DDC setup */ adi,ddc-channel-number = <AD9208_2_DDC_MODE >; //<AD9208_FULL_BANDWIDTH_MODE>; adi,ddc-mixer-real-enable; ad9208_ddc0: channel-0@0 { reg = <0>; adi,decimation = <2>; adi,nco-mode-select = <AD9208_NCO_MODE_ZIF>; adi,nco-channel-carrier-frequency-hz = /bits/ 64 <50000000>; adi,nco-channel-phase-offset = /bits/ 64 <0>; }; ad9208_ddc1: channel-1@1 { reg = <1>; adi,decimation = <2>; adi,nco-mode-select = <AD9208_NCO_MODE_ZIF>; adi,nco-channel-carrier-frequency-hz = /bits/ 64 <50000000>; adi,nco-channel-phase-offset = /bits/ 64 <0>; }; }; adc1_ad9680: ad9680@2 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,ad9680"; reg = <2>; spi-max-frequency = <1000000>; clocks = <&axi_ad9680_jesd1>, <<c6952 3>, <<c6952 5>; clock-names = "jesd_adc_clk", "adc_clk", "adc_sysref"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <1>; /* This is the TOP device */ jesd204-link-ids = <0>; jesd204-inputs = <&axi_ad9680_core1 1 0>; jesd204-ignore-errors; adi,logic-lanes-mapping = [00 02 01 03]; //adi,powerdown-pin-enable; adi,powerdown-mode = <AD9208_PDN_MODE_POWERDOWN>; adi,sampling-frequency = /bits/ 64 <500000000>; //adi,input-clock-divider-ratio = <2>; adi,sysref-lmfc-offset = <0>; adi,sysref-pos-window-skew = <0>; adi,sysref-neg-window-skew = <0>; adi,sysref-mode = <AD9208_SYSREF_CONT>; adi,sysref-nshot-ignore-count = <0>; /* JESD204 parameters */ adi,converters-per-device = <4>; /* JESD204 (M) vorher 2 */ adi,lanes-per-device = <2>; /* JESD204 (L) */ adi,octets-per-frame = <4>; /* JESD204 (F) vorher 2 */ adi,frames-per-multiframe = <32>; /* JESD204 (K) */ adi,converter-resolution = <14>; /* JESD204 (N) */ adi,bits-per-sample = <16>; /* JESD204 (N') */ adi,control-bits-per-sample = <2>; /* JESD204 (CS) */ adi,subclass = <1>; /* JESD204 (SUBCLASSV) */ /* DDC setup */ adi,ddc-channel-number = <AD9208_2_DDC_MODE >; //<AD9208_FULL_BANDWIDTH_MODE>; adi,ddc-mixer-real-enable; ad9208_ddc2: channel-2@0 { reg = <0>; adi,decimation = <2>; adi,nco-mode-select = <AD9208_NCO_MODE_ZIF>; adi,nco-channel-carrier-frequency-hz = /bits/ 64 <50000000>; adi,nco-channel-phase-offset = /bits/ 64 <0>; }; ad9208_ddc3: channel-3@1 { reg = <1>; adi,decimation = <2>; adi,nco-mode-select = <AD9208_NCO_MODE_ZIF>; adi,nco-channel-carrier-frequency-hz = /bits/ 64 <50000000>; adi,nco-channel-phase-offset = /bits/ 64 <0>; }; }; adc2_ad9680: ad9680@3 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,ad9680"; reg = <3>; spi-max-frequency = <1000000>; clocks = <&axi_ad9680_jesd2>, <<c6952 2>, <<c6952 5>; clock-names = "jesd_adc_clk", "adc_clk", "adc_sysref"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <1>; /* This is the TOP device */ jesd204-link-ids = <0>; jesd204-inputs = <&axi_ad9680_core2 1 0>; jesd204-ignore-errors; adi,logic-lanes-mapping = [00 02 01 03]; //adi,powerdown-pin-enable; adi,powerdown-mode = <AD9208_PDN_MODE_POWERDOWN>; adi,sampling-frequency = /bits/ 64 <500000000>; //adi,input-clock-divider-ratio = <2>; adi,sysref-lmfc-offset = <0>; adi,sysref-pos-window-skew = <0>; adi,sysref-neg-window-skew = <0>; adi,sysref-mode = <AD9208_SYSREF_CONT>; adi,sysref-nshot-ignore-count = <0>; /* JESD204 parameters */ adi,converters-per-device = <4>; /* JESD204 (M) vorher 2 */ adi,lanes-per-device = <2>; /* JESD204 (L) */ adi,octets-per-frame = <4>; /* JESD204 (F) vorher 2 */ adi,frames-per-multiframe = <32>; /* JESD204 (K) */ adi,converter-resolution = <14>; /* JESD204 (N) */ adi,bits-per-sample = <16>; /* JESD204 (N') */ adi,control-bits-per-sample = <2>; /* JESD204 (CS) */ adi,subclass = <1>; /* JESD204 (SUBCLASSV) */ /* DDC setup */ adi,ddc-channel-number = <AD9208_2_DDC_MODE >; //<AD9208_FULL_BANDWIDTH_MODE>; adi,ddc-mixer-real-enable; ad9208_ddc4: channel-4@0 { reg = <0>; adi,decimation = <2>; adi,nco-mode-select = <AD9208_NCO_MODE_ZIF>; adi,nco-channel-carrier-frequency-hz = /bits/ 64 <50000000>; adi,nco-channel-phase-offset = /bits/ 64 <0>; }; ad9208_ddc5: channel-5@1 { reg = <1>; adi,decimation = <2>; adi,nco-mode-select = <AD9208_NCO_MODE_ZIF>; adi,nco-channel-carrier-frequency-hz = /bits/ 64 <50000000>; adi,nco-channel-phase-offset = /bits/ 64 <0>; }; }; adc3_ad9680: ad9680@4 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,ad9680"; reg = <4>; spi-max-frequency = <1000000>; clocks = <&axi_ad9680_jesd3>, <<c6952 1>, <<c6952 5>; clock-names = "jesd_adc_clk", "adc_clk", "adc_sysref"; /* jesd204-fsm support */ jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <1>; /* This is the TOP device */ jesd204-link-ids = <0>; jesd204-inputs = <&axi_ad9680_core3 1 0>; jesd204-ignore-errors; adi,logic-lanes-mapping = [00 02 01 03]; //adi,powerdown-pin-enable; adi,powerdown-mode = <AD9208_PDN_MODE_POWERDOWN>; adi,sampling-frequency = /bits/ 64 <500000000>; //adi,input-clock-divider-ratio = <2>; adi,sysref-lmfc-offset = <0>; adi,sysref-pos-window-skew = <0>; adi,sysref-neg-window-skew = <0>; adi,sysref-mode = <AD9208_SYSREF_CONT>; adi,sysref-nshot-ignore-count = <0>; /* JESD204 parameters */ adi,converters-per-device = <4>; /* JESD204 (M) vorher 2 */ adi,lanes-per-device = <2>; /* JESD204 (L) */ adi,octets-per-frame = <4>; /* JESD204 (F) vorher 2 */ adi,frames-per-multiframe = <32>; /* JESD204 (K) */ adi,converter-resolution = <14>; /* JESD204 (N) */ adi,bits-per-sample = <16>; /* JESD204 (N') */ adi,control-bits-per-sample = <2>; /* JESD204 (CS) */ adi,subclass = <1>; /* JESD204 (SUBCLASSV) */ /* DDC setup */ adi,ddc-channel-number = <AD9208_2_DDC_MODE >; //<AD9208_FULL_BANDWIDTH_MODE>; adi,ddc-mixer-real-enable; ad9208_ddc6: channel-6@0 { reg = <0>; adi,decimation = <2>; adi,nco-mode-select = <AD9208_NCO_MODE_ZIF>; adi,nco-channel-carrier-frequency-hz = /bits/ 64 <50000000>; adi,nco-channel-phase-offset = /bits/ 64 <0>; }; ad9208_ddc7: channel-7@1 { reg = <1>; adi,decimation = <2>; adi,nco-mode-select = <AD9208_NCO_MODE_ZIF>; adi,nco-channel-carrier-frequency-hz = /bits/ 64 <50000000>; adi,nco-channel-phase-offset = /bits/ 64 <0>; }; }; };
But without getting it to work.
It either breaks jesd204-fsm completely
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.0-gef6f1e5007c2-dirty (badc0ded@LAPTOP-KU6CGS3H) (gcc version 7.2.0 (GCC)) #274 SMP Tue Jan 10 09:56:55 CET 2023 [ 0.000000] Machine model: Enclustra XU8 SOM [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 256 MiB at 0x000000006fc00000 [ 0.000000] On node 0 totalpages: 524032 [ 0.000000] DMA32 zone: 7165 pages used for memmap [ 0.000000] DMA32 zone: 0 pages reserved [ 0.000000] DMA32 zone: 524032 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x414 with crng_init=0 [ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s51864 r8192 d30056 u90112 [ 0.000000] pcpu-alloc: s51864 r8192 d30056 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516867 [ 0.000000] Kernel command line: console=ttyPS0,115200 rw earlyprintk rootwait root=/dev/mmcblk1p2 [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Memory: 1774844K/2096128K available (13372K kernel code, 1506K rwdata, 10692K rodata, 896K init, 343K bss, 59140K reserved, 262144K cma-reserved) [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x7b0074340, max_idle_ns: 440795202884 ns [ 0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255543ns [ 0.000261] Console: colour dummy device 80x25 [ 0.000280] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332) [ 0.000289] pid_max: default: 32768 minimum: 301 [ 0.000390] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000400] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.001088] ASID allocator initialised with 32768 entries [ 0.001138] rcu: Hierarchical SRCU implementation. [ 0.001451] EFI services will not be available. [ 0.001529] smp: Bringing up secondary CPUs ... [ 0.001804] Detected VIPT I-cache on CPU1 [ 0.001833] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.001891] smp: Brought up 1 node, 2 CPUs [ 0.001899] SMP: Total of 2 processors activated. [ 0.001905] CPU features: detected: 32-bit EL0 Support [ 0.003355] CPU: All CPU(s) started at EL2 [ 0.003365] alternatives: patching kernel code [ 0.004241] devtmpfs: initialized [ 0.009263] Registered cp15_barrier emulation handler [ 0.009271] Registered setend emulation handler [ 0.009375] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.009388] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.014296] xor: measuring software checksum speed [ 0.052020] 8regs : 2303.000 MB/sec [ 0.092049] 8regs_prefetch: 2053.000 MB/sec [ 0.132076] 32regs : 2830.000 MB/sec [ 0.172105] 32regs_prefetch: 2379.000 MB/sec [ 0.172110] xor: using function: 32regs (2830.000 MB/sec) [ 0.172120] pinctrl core: initialized pinctrl subsystem [ 0.172732] NET: Registered protocol family 16 [ 0.172987] audit: initializing netlink subsys (disabled) [ 0.173437] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 0.173444] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.173895] audit: type=2000 audit(0.172:1): state=initialized audit_enabled=0 res=1 [ 0.174575] DMA: preallocated 256 KiB pool for atomic allocations [ 0.194938] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.260297] raid6: int64x1 gen() 392 MB/s [ 0.328315] raid6: int64x1 xor() 445 MB/s [ 0.396395] raid6: int64x2 gen() 679 MB/s [ 0.464405] raid6: int64x2 xor() 601 MB/s [ 0.532470] raid6: int64x4 gen() 1036 MB/s [ 0.600533] raid6: int64x4 xor() 742 MB/s [ 0.668583] raid6: int64x8 gen() 979 MB/s [ 0.736629] raid6: int64x8 xor() 745 MB/s [ 0.804719] raid6: neonx1 gen() 724 MB/s [ 0.872722] raid6: neonx1 xor() 851 MB/s [ 0.940777] raid6: neonx2 gen() 1159 MB/s [ 1.008831] raid6: neonx2 xor() 1203 MB/s [ 1.076862] raid6: neonx4 gen() 1505 MB/s [ 1.144918] raid6: neonx4 xor() 1439 MB/s [ 1.212978] raid6: neonx8 gen() 1645 MB/s [ 1.281015] raid6: neonx8 xor() 1525 MB/s [ 1.281019] raid6: using algorithm neonx8 gen() 1645 MB/s [ 1.281023] raid6: .... xor() 1525 MB/s, rmw enabled [ 1.281027] raid6: using neon recovery algorithm [ 1.281933] SCSI subsystem initialized [ 1.281967] libata version 3.00 loaded. [ 1.282097] usbcore: registered new interface driver usbfs [ 1.282128] usbcore: registered new interface driver hub [ 1.282160] usbcore: registered new device driver usb [ 1.282320] media: Linux media interface: v0.10 [ 1.282344] videodev: Linux video capture interface: v2.00 [ 1.282395] pps_core: LinuxPPS API ver. 1 registered [ 1.282399] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.282412] PTP clock support registered [ 1.282436] EDAC MC: Ver: 3.0.0 [ 1.284290] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver. [ 1.284698] OF: /fpga-axi@0/axi-adxcvr-tx@84a60000: could not get #jesd204-cells for /amba/spi@ff040000/ltc6952@4 [ 1.284714] jesd204: framework error: -22 [ 1.284747] FPGA manager framework [ 1.284908] Advanced Linux Sound Architecture Driver Initialized. [ 1.285163] Bluetooth: Core ver 2.22 [ 1.285185] NET: Registered protocol family 31 [ 1.285190] Bluetooth: HCI device and connection manager initialized [ 1.285198] Bluetooth: HCI socket layer initialized [ 1.285204] Bluetooth: L2CAP socket layer initialized [ 1.285225] Bluetooth: SCO socket layer initialized [ 1.285749] clocksource: Switched to clocksource arch_sys_counter [ 1.285820] VFS: Disk quotas dquot_6.6.0 [ 1.285860] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.290764] NET: Registered protocol family 2 [ 1.291101] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes) [ 1.291126] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 1.291231] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 1.291425] TCP: Hash tables configured (established 16384 bind 16384) [ 1.291480] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 1.291520] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 1.291624] NET: Registered protocol family 1 [ 1.291882] RPC: Registered named UNIX socket transport module. [ 1.291887] RPC: Registered udp transport module. [ 1.291891] RPC: Registered tcp transport module. [ 1.291894] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.292155] PCI: CLS 0 bytes, default 64 [ 1.292504] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 1.292606] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 1.293374] Initialise system trusted keyrings [ 1.293452] workingset: timestamp_bits=62 max_order=19 bucket_order=0 [ 1.294673] NFS: Registering the id_resolver key type [ 1.294685] Key type id_resolver registered [ 1.294690] Key type id_legacy registered [ 1.294699] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.294715] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 2.370187] NET: Registered protocol family 38 [ 2.427534] Key type asymmetric registered [ 2.427540] Asymmetric key parser 'x509' registered [ 2.427572] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.427578] io scheduler noop registered [ 2.427583] io scheduler deadline registered [ 2.427603] io scheduler cfq registered (default) [ 2.427608] io scheduler mq-deadline registered [ 2.427612] io scheduler kyber registered [ 2.457339] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 2.461338] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 2.465354] brd: module loaded [ 2.469057] loop: module loaded [ 2.469244] Registered mathworks_ip class [ 2.470104] mtdoops: mtd device (mtddev=name/number) must be supplied [ 2.471460] libphy: Fixed MDIO Bus: probed [ 2.472564] tun: Universal TUN/TAP device driver, 1.6 [ 2.476589] CAN device driver interface [ 2.477610] usbcore: registered new interface driver asix [ 2.477639] usbcore: registered new interface driver ax88179_178a [ 2.477664] usbcore: registered new interface driver cdc_ether [ 2.477688] usbcore: registered new interface driver net1080 [ 2.477712] usbcore: registered new interface driver cdc_subset [ 2.477769] usbcore: registered new interface driver zaurus [ 2.477807] usbcore: registered new interface driver cdc_ncm [ 2.479080] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.479086] ehci-pci: EHCI PCI platform driver [ 2.479383] usbcore: registered new interface driver uas [ 2.479417] usbcore: registered new interface driver usb-storage [ 2.479480] usbcore: registered new interface driver usbserial_generic [ 2.479500] usbserial: USB Serial support registered for generic [ 2.479523] usbcore: registered new interface driver ftdi_sio [ 2.479543] usbserial: USB Serial support registered for FTDI USB Serial Device [ 2.479566] usbcore: registered new interface driver upd78f0730 [ 2.479585] usbserial: USB Serial support registered for upd78f0730 [ 2.481329] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0 [ 2.481396] i2c /dev entries driver [ 2.483492] usbcore: registered new interface driver uvcvideo [ 2.483497] USB Video Class driver (1.1.1) [ 2.485134] Bluetooth: HCI UART driver ver 2.3 [ 2.485143] Bluetooth: HCI UART protocol H4 registered [ 2.485147] Bluetooth: HCI UART protocol BCSP registered [ 2.485173] Bluetooth: HCI UART protocol LL registered [ 2.485178] Bluetooth: HCI UART protocol ATH3K registered [ 2.485197] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 2.485245] Bluetooth: HCI UART protocol Intel registered [ 2.485265] Bluetooth: HCI UART protocol QCA registered [ 2.485307] usbcore: registered new interface driver bcm203x [ 2.485337] usbcore: registered new interface driver bpa10x [ 2.485367] usbcore: registered new interface driver bfusb [ 2.485398] usbcore: registered new interface driver btusb [ 2.485403] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 2.485450] usbcore: registered new interface driver ath3k [ 2.485829] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT) [ 2.486001] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED) [ 2.486172] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT) [ 2.486641] sdhci: Secure Digital Host Controller Interface driver [ 2.486645] sdhci: Copyright(c) Pierre Ossman [ 2.486649] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.487294] ledtrig-cpu: registered to indicate activity on CPUs [ 2.487344] zynqmp_firmware_probe Platform Management API v1.1 [ 2.487350] zynqmp_firmware_probe Trustzone version v1.0 [ 2.490116] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized [ 2.512390] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22 [ 2.513766] alg: No test for xilinx-zynqmp-aes (zynqmp-aes) [ 2.513797] zynqmp_aes zynqmp_aes: AES Successfully Registered [ 2.514076] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384) [ 2.514297] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa) [ 2.514510] usbcore: registered new interface driver usbhid [ 2.514515] usbhid: USB HID core driver [ 2.521996] cf_axi_dds 84a04000.axi-ad9173-hpc: Device has no configuration node [ 2.524815] axi_adxcvr 84b00000.axi-adxcvr-rx-0: Device has no configuration node [ 2.524853] axi_adxcvr 84b40000.axi-adxcvr-rx-1: Device has no configuration node [ 2.524881] axi_adxcvr 84b80000.axi-adxcvr-rx-2: Device has no configuration node [ 2.524909] axi_adxcvr 84bc0000.axi-adxcvr-rx-3: Device has no configuration node [ 2.524936] axi_adxcvr 84a60000.axi-adxcvr-tx: Device has no configuration node [ 2.525046] axi-jesd204-rx 84aa0000.axi-jesd204-rx-0: Device has no configuration node [ 2.525075] axi-jesd204-rx 84aa4000.axi-jesd204-rx-1: Device has no configuration node [ 2.525102] axi-jesd204-rx 84aa8000.axi-jesd204-rx-2: Device has no configuration node [ 2.525130] axi-jesd204-rx 84aac000.axi-jesd204-rx-3: Device has no configuration node [ 2.525241] axi-jesd204-tx 84a90000.axi-jesd204-tx: Device has no configuration node [ 2.525817] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.00.a) found [ 2.526001] axi_sysid 85000000.axi-sysid-0: system ID header version mismatch. Expected 1, Reported 0 [ 2.526014] axi_sysid: probe of 85000000.axi-sysid-0 failed with error -14 [ 2.526304] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered [ 2.527977] usbcore: registered new interface driver snd-usb-audio [ 2.529798] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 2.531169] Initializing XFRM netlink socket [ 2.531239] NET: Registered protocol family 10 [ 2.531584] Segment Routing with IPv6 [ 2.531668] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.531999] NET: Registered protocol family 17 [ 2.532011] NET: Registered protocol family 15 [ 2.532026] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 2.532530] can: controller area network core (rev 20170425 abi 9) [ 2.532560] NET: Registered protocol family 29 [ 2.532566] can: raw protocol (rev 20170425) [ 2.532570] can: broadcast manager protocol (rev 20170425 t) [ 2.532577] can: netlink gateway (rev 20170425) max_hops=1 [ 2.532695] Bluetooth: RFCOMM TTY layer initialized [ 2.532702] Bluetooth: RFCOMM socket layer initialized [ 2.532716] Bluetooth: RFCOMM ver 1.11 [ 2.532724] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.532728] Bluetooth: BNEP filters: protocol multicast [ 2.532734] Bluetooth: BNEP socket layer initialized [ 2.532739] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.532744] Bluetooth: HIDP socket layer initialized [ 2.532853] 9pnet: Installing 9P2000 support [ 2.532864] NET: Registered protocol family 36 [ 2.532880] Key type dns_resolver registered [ 2.533391] registered taskstats version 1 [ 2.533396] Loading compiled-in X.509 certificates [ 2.533772] Btrfs loaded, crc32c=crc32c-generic [ 2.539882] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 33, base_baud = 6249999) is a xuartps [ 3.936673] console [ttyPS0] enabled [ 3.940654] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 34, base_baud = 6249999) is a xuartps [ 3.950252] of-fpga-region fpga-full: FPGA Region probed [ 3.956912] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success [ 3.964016] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success [ 3.971114] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success [ 3.978216] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success [ 3.985313] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success [ 3.992414] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success [ 3.999514] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success [ 4.006619] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success [ 4.013880] zynqmp_pll_disable() clock disable failed for rpll_int, ret = -13 [ 4.022025] HMC703: Start Probing [ 4.022034] HMC703: Devicetree Parsing... [ 4.025950] HMC703: Finished Probing [ 4.030576] pe4312 spi1.3: spi1.3 supply vcc not found, using dummy regulator [ 4.041304] pe4312 spi1.3: Linked as a consumer to regulator.0 [ 4.058065] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.070990] ad9208 spi2.1: Device has no configuration node [ 4.076770] ad9208 spi2.2: Device has no configuration node [ 4.082551] ad9208 spi2.3: Device has no configuration node [ 4.088331] ad9208 spi2.4: Device has no configuration node [ 4.095969] m25p80 spi0.0: non-uniform erase sector maps are not supported yet. [ 4.103472] m25p80 spi0.0: s25fl512s (65536 Kbytes) [ 4.108376] 6 fixed-partitions partitions found on MTD device spi0.0 [ 4.114729] Creating 6 MTD partitions on "spi0.0": [ 4.119511] 0x000000000000-0x000000700000 : "qspi-bootimage" [ 4.125687] 0x000000700000-0x000000c00000 : "qspi-kernel" [ 4.131469] 0x000000c00000-0x000000c80000 : "qspi-device-tree" [ 4.137685] 0x000000c80000-0x000000d00000 : "qspi-bootargs" [ 4.143642] 0x000000d00000-0x000000d40000 : "qspi-bootscript" [ 4.149771] 0x000000d40000-0x000004000000 : "qspi-rootfs" [ 4.156356] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp_pinconf_cfg_set failed: pin 26 param 1 value 0 [ 4.167119] macb ff0b0000.ethernet: Not enabling partial store and forward [ 4.174511] libphy: MACB_mii_bus: probed [ 4.250933] Micrel KSZ9031 Gigabit PHY ff0b0000.ethernet-ffffffff:03: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=ff0b0000.ethernet-ffffffff:03, irq=POLL) [ 4.266749] macb ff0b0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 20 (20:b0:f7:06:42:6c) [ 4.276890] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM [ 4.283412] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM [ 4.289910] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM [ 4.296399] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM [ 4.303818] dwc3-of-simple ff9d0000.usb0: dwc3_simple_set_phydata: Can't find usb3-phy [ 4.312584] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 22 [ 4.350312] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA 64-bit [ 4.394308] mmc1: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit [ 4.408831] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.422617] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.437727] rtc_zynqmp ffa60000.rtc: setting system clock to 2023-01-16 16:22:53 UTC (1673886173) [ 4.446598] of_cfs_init [ 4.449048] of_cfs_init: OK [ 4.451985] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 4.463032] random: fast init done [ 4.466556] mmc0: new HS200 MMC card at address 0001 [ 4.471971] mmcblk0: mmc0:0001 IB2916 14.6 GiB [ 4.476854] mmcblk0boot0: mmc0:0001 IB2916 partition 1 4.00 MiB [ 4.483128] mmcblk0boot1: mmc0:0001 IB2916 partition 2 4.00 MiB [ 4.489134] mmcblk0rpmb: mmc0:0001 IB2916 partition 3 4.00 MiB, chardev (242:0) [ 4.497642] mmcblk0: p1 [ 4.502535] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.596431] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.603856] ALSA device list: [ 4.606819] No soundcards found. [ 4.610553] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 4.619174] cfg80211: failed to load regulatory.db [ 4.624880] Waiting for root device /dev/mmcblk1p2... [ 4.799777] mmc1: new high speed SDHC card at address 0001 [ 4.805730] mmcblk1: mmc1:0001 0016G 15.2 GiB [ 4.811104] mmcblk1: p1 p2 p3 [ 4.815930] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 5.063093] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 5.071194] VFS: Mounted root (ext4 filesystem) on device 179:26. [ 5.139743] devtmpfs: mounted [ 5.142889] Freeing unused kernel memory: 896K [ 5.147353] Run /sbin/init as init process [ 7.040731] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 7.062421] systemd[1]: Detected architecture arm64. [ 7.086463] systemd[1]: Set hostname to <analog>. [ 7.366304] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 7.383385] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 7.553843] systemd[1]: /etc/systemd/system/tof-server.service:1: Assignment outside of section. Ignoring. [ 7.563527] systemd[1]: /etc/systemd/system/tof-server.service:2: Assignment outside of section. Ignoring. [ 7.741683] random: systemd: uninitialized urandom read (16 bytes read) [ 7.754715] random: systemd: uninitialized urandom read (16 bytes read) [ 7.761511] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.785818] random: systemd: uninitialized urandom read (16 bytes read) [ 7.792982] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 7.814123] systemd[1]: Listening on udev Control Socket. [ 9.548070] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 9.646661] systemd-journald[2104]: Received request to flush runtime journal from PID 1 [ 15.359338] pps pps0: new PPS source ptp0 [ 15.359350] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered. [ 15.359495] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 15.537635] random: crng init done [ 15.537642] random: 7 urandom warning(s) missed due to ratelimiting [ 16.740606] Adding 102396k swap on /var/swap. Priority:-2 extents:4 across:10111164k SS [ 19.461782] macb ff0b0000.ethernet eth0: link up (1000/Full) [ 19.461810] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 31.435000] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
Or does not break completely but RX also do not work anymore...
[ 2.482336] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.482342] ehci-pci: EHCI PCI platform driver [ 2.482600] usbcore: registered new interface driver uas [ 2.482633] usbcore: registered new interface driver usb-storage [ 2.482691] usbcore: registered new interface driver usbserial_generic [ 2.482714] usbserial: USB Serial support registered for generic [ 2.482736] usbcore: registered new interface driver ftdi_sio [ 2.482755] usbserial: USB Serial support registered for FTDI USB Serial Device [ 2.482778] usbcore: registered new interface driver upd78f0730 [ 2.482799] usbserial: USB Serial support registered for upd78f0730 [ 2.485315] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0 [ 2.485397] i2c /dev entries driver [ 2.487364] usbcore: registered new interface driver uvcvideo [ 2.487368] USB Video Class driver (1.1.1) [ 2.491177] Bluetooth: HCI UART driver ver 2.3 [ 2.491188] Bluetooth: HCI UART protocol H4 registered [ 2.491193] Bluetooth: HCI UART protocol BCSP registered [ 2.491228] Bluetooth: HCI UART protocol LL registered [ 2.491232] Bluetooth: HCI UART protocol ATH3K registered [ 2.491251] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 2.491346] Bluetooth: HCI UART protocol Intel registered [ 2.491365] Bluetooth: HCI UART protocol QCA registered [ 2.491410] usbcore: registered new interface driver bcm203x [ 2.491439] usbcore: registered new interface driver bpa10x [ 2.491468] usbcore: registered new interface driver bfusb [ 2.491499] usbcore: registered new interface driver btusb [ 2.491504] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 2.491548] usbcore: registered new interface driver ath3k [ 2.491920] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT) [ 2.492115] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED) [ 2.492285] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT) [ 2.492744] sdhci: Secure Digital Host Controller Interface driver [ 2.492749] sdhci: Copyright(c) Pierre Ossman [ 2.492752] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.493111] ledtrig-cpu: registered to indicate activity on CPUs [ 2.493161] zynqmp_firmware_probe Platform Management API v1.1 [ 2.493167] zynqmp_firmware_probe Trustzone version v1.0 [ 2.495903] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized [ 2.518150] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22 [ 2.518694] alg: No test for xilinx-zynqmp-aes (zynqmp-aes) [ 2.518710] zynqmp_aes zynqmp_aes: AES Successfully Registered [ 2.518882] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384) [ 2.519035] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa) [ 2.519250] usbcore: registered new interface driver usbhid [ 2.519254] usbhid: USB HID core driver [ 2.531414] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.00.a) found [ 2.531601] axi_sysid 85000000.axi-sysid-0: system ID header version mismatch. Expected 1, Reported 0 [ 2.531613] axi_sysid: probe of 85000000.axi-sysid-0 failed with error -14 [ 2.531884] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered [ 2.532947] usbcore: registered new interface driver snd-usb-audio [ 2.534741] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 2.536148] Initializing XFRM netlink socket [ 2.536219] NET: Registered protocol family 10 [ 2.536554] Segment Routing with IPv6 [ 2.536639] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.536971] NET: Registered protocol family 17 [ 2.536983] NET: Registered protocol family 15 [ 2.536998] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 2.537447] can: controller area network core (rev 20170425 abi 9) [ 2.537475] NET: Registered protocol family 29 [ 2.537481] can: raw protocol (rev 20170425) [ 2.537486] can: broadcast manager protocol (rev 20170425 t) [ 2.537492] can: netlink gateway (rev 20170425) max_hops=1 [ 2.537552] Bluetooth: RFCOMM TTY layer initialized [ 2.537560] Bluetooth: RFCOMM socket layer initialized [ 2.537575] Bluetooth: RFCOMM ver 1.11 [ 2.537583] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.537586] Bluetooth: BNEP filters: protocol multicast [ 2.537593] Bluetooth: BNEP socket layer initialized [ 2.537597] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.537603] Bluetooth: HIDP socket layer initialized [ 2.537704] 9pnet: Installing 9P2000 support [ 2.537715] NET: Registered protocol family 36 [ 2.537731] Key type dns_resolver registered [ 2.538420] registered taskstats version 1 [ 2.538424] Loading compiled-in X.509 certificates [ 2.538761] Btrfs loaded, crc32c=crc32c-generic [ 2.544868] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 33, base_baud = 6249999) is a xuartps [ 4.073562] console [ttyPS0] enabled [ 4.077538] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 34, base_baud = 6249999) is a xuartps [ 4.087119] of-fpga-region fpga-full: FPGA Region probed [ 4.093770] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success [ 4.100869] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success [ 4.107969] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success [ 4.115062] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success [ 4.122170] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success [ 4.129268] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success [ 4.136371] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success [ 4.143467] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success [ 4.150708] zynqmp_pll_disable() clock disable failed for rpll_int, ret = -13 [ 4.158768] HMC703: Start Probing [ 4.158778] HMC703: Devicetree Parsing... [ 4.162725] HMC703: Finished Probing [ 4.167346] pe4312 spi1.3: spi1.3 supply vcc not found, using dummy regulator [ 4.178075] pe4312 spi1.3: Linked as a consumer to regulator.0 [ 4.195165] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.227667] ad9208 spi2.1: ad9680 PLL LOCKED [ 4.231958] ad9208 spi2.1: ad9680 Rev. 5 Grade 8 (API 1.0.1) probed [ 4.244446] random: fast init done [ 4.247851] ad9208 spi2.2: Unrecognized CHIP_ID 0xF000 [ 4.272887] ad9208 spi2.3: ad9680 PLL LOCKED [ 4.277179] ad9208 spi2.3: ad9680 Rev. 5 Grade 8 (API 1.0.1) probed [ 4.289710] ad9208 spi2.4: Unrecognized CHIP_ID 0xF000 [ 4.296989] m25p80 spi0.0: non-uniform erase sector maps are not supported yet. [ 4.304485] m25p80 spi0.0: s25fl512s (65536 Kbytes) [ 4.309381] 6 fixed-partitions partitions found on MTD device spi0.0 [ 4.315725] Creating 6 MTD partitions on "spi0.0": [ 4.320511] 0x000000000000-0x000000700000 : "qspi-bootimage" [ 4.326610] 0x000000700000-0x000000c00000 : "qspi-kernel" [ 4.332395] 0x000000c00000-0x000000c80000 : "qspi-device-tree" [ 4.338600] 0x000000c80000-0x000000d00000 : "qspi-bootargs" [ 4.344554] 0x000000d00000-0x000000d40000 : "qspi-bootscript" [ 4.350666] 0x000000d40000-0x000004000000 : "qspi-rootfs" [ 4.357269] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp_pinconf_cfg_set failed: pin 26 param 1 value 0 [ 4.368036] macb ff0b0000.ethernet: Not enabling partial store and forward [ 4.375436] libphy: MACB_mii_bus: probed [ 4.451135] Micrel KSZ9031 Gigabit PHY ff0b0000.ethernet-ffffffff:03: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=ff0b0000.ethernet-ffffffff:03, irq=POLL) [ 4.466951] macb ff0b0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 20 (20:b0:f7:06:42:6c) [ 4.477081] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM [ 4.483607] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM [ 4.490092] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM [ 4.496573] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM [ 4.503994] dwc3-of-simple ff9d0000.usb0: dwc3_simple_set_phydata: Can't find usb3-phy [ 4.512738] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 22 [ 4.550510] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA 64-bit [ 4.595708] mmc1: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit [ 4.630230] cf_axi_adc 84a10000.axi-ad9680-hpc-0: ADI AIM (10.01.b) at 0x84A10000 mapped to 0x(____ptrval____), probed ADC AD9680 as MASTER [ 4.664340] cf_axi_adc 84a18000.axi-ad9680-hpc-2: ADI AIM (10.01.b) at 0x84A18000 mapped to 0x(____ptrval____), probed ADC AD9680 as MASTER [ 4.677713] axi_adxcvr 84b00000.axi-adxcvr-rx-0: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 4.696880] axi_adxcvr 84b00000.axi-adxcvr-rx-0: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B00000. Number of lanes: 2. [ 4.708576] axi_adxcvr 84b40000.axi-adxcvr-rx-1: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 4.725481] axi_adxcvr 84b40000.axi-adxcvr-rx-1: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B40000. Number of lanes: 2. [ 4.737157] axi_adxcvr 84b80000.axi-adxcvr-rx-2: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 4.753722] axi_adxcvr 84b80000.axi-adxcvr-rx-2: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B80000. Number of lanes: 2. [ 4.765392] axi_adxcvr 84bc0000.axi-adxcvr-rx-3: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 4.782259] axi_adxcvr 84bc0000.axi-adxcvr-rx-3: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84BC0000. Number of lanes: 2. [ 4.794383] jesd204: /fpga-axi@0/axi-adxcvr-tx@84a60000,jesd204:20,parent=84a60000.axi-adxcvr-tx: Device isn't a top-device, nor does it belong to topology with top-device [ 4.809825] axi_adxcvr: probe of 84a60000.axi-adxcvr-tx failed with error -14 [ 4.819589] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.833836] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 4.849451] rtc_zynqmp ffa60000.rtc: setting system clock to 2023-01-16 17:47:20 UTC (1673891240) [ 4.858329] of_cfs_init [ 4.860775] of_cfs_init: OK [ 4.863710] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 4.874237] mmc0: new HS200 MMC card at address 0001 [ 4.879656] mmcblk0: mmc0:0001 IB2916 14.6 GiB [ 4.884526] mmcblk0boot0: mmc0:0001 IB2916 partition 1 4.00 MiB [ 4.890786] mmcblk0boot1: mmc0:0001 IB2916 partition 2 4.00 MiB [ 4.896818] mmcblk0rpmb: mmc0:0001 IB2916 partition 3 4.00 MiB, chardev (242:0) [ 4.905370] mmcblk0: p1 [ 4.909991] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 5.002565] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.009975] ALSA device list: [ 5.012935] No soundcards found. [ 5.016693] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 5.025299] cfg80211: failed to load regulatory.db [ 5.030251] Waiting for root device /dev/mmcblk1p2... [ 5.198124] mmc1: new high speed SDHC card at address 0001 [ 5.204065] mmcblk1: mmc1:0001 0016G 15.2 GiB [ 5.209430] mmcblk1: p1 p2 p3 [ 5.213914] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 5.459453] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 5.467552] VFS: Mounted root (ext4 filesystem) on device 179:26. [ 5.538387] devtmpfs: mounted [ 5.541544] Freeing unused kernel memory: 896K [ 5.546007] Run /sbin/init as init process [ 6.717971] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition initialized -> probed [ 6.728577] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition probed -> idle [ 6.738575] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition idle -> device_init [ 6.749008] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition device_init -> link_init [ 6.759879] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_init -> link_supported [ 6.771002] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_supported -> link_pre_setup [ 6.782567] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 6.794212] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 6.805952] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 6.817716] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> link_setup [ 6.829021] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_setup -> opt_setup_stage1 [ 6.840411] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 6.852320] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 6.864228] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 6.876135] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 6.991488] axi_adxcvr 84b00000.axi-adxcvr-rx-0: QPLL RX: Not ready defer probe [ 7.102099] axi_adxcvr 84b00000.axi-adxcvr-rx-0: QPLL RX: Not ready defer probe [ 7.109428] axi-jesd204-rx 84aa0000.axi-jesd204-rx-0: axi_jesd204_rx_jesd204_clks_enable: Link0 enable lane clock failed (-517) [ 7.120900] jesd204: /fpga-axi@0/axi-jesd204-rx-0@84aa0000,jesd204:12,parent=84aa0000.axi-jesd204-rx-0: JESD204[0] got error from cb: -517 [ 7.133328] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: Rolling back from 'opt_setup_stage5', got error -517 [ 7.144760] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition initialized -> probed [ 7.155374] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition probed -> idle [ 7.165376] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition idle -> device_init [ 7.175810] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition device_init -> link_init [ 7.186681] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_init -> link_supported [ 7.197813] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_supported -> link_pre_setup [ 7.209374] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 7.221023] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 7.232759] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 7.244527] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> link_setup [ 7.255832] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_setup -> opt_setup_stage1 [ 7.267219] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 7.279128] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 7.291038] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 7.291046] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 7.342499] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 7.364145] systemd[1]: Detected architecture arm64. [ 7.418148] axi_adxcvr 84b80000.axi-adxcvr-rx-2: QPLL RX: Not ready defer probe [ 7.528897] axi_adxcvr 84b80000.axi-adxcvr-rx-2: QPLL RX: Not ready defer probe [ 7.536217] axi-jesd204-rx 84aa8000.axi-jesd204-rx-2: axi_jesd204_rx_jesd204_clks_enable: Link0 enable lane clock failed (-517) [ 7.538672] systemd[1]: Set hostname to <analog>. [ 7.547688] jesd204: /fpga-axi@0/axi-jesd204-rx-2@84aa8000,jesd204:14,parent=84aa8000.axi-jesd204-rx-2: JESD204[0] got error from cb: -517 [ 7.547694] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: Rolling back from 'opt_setup_stage5', got error -517 [ 7.576331] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 7.588006] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clocks_enable -> opt_setup_stage5 [ 7.599676] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4 [ 7.611610] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3 [ 7.623548] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2 [ 7.635476] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1 [ 7.647413] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> link_setup [ 7.658829] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_setup -> clk_sync_stage3 [ 7.670161] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2 [ 7.681933] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1 [ 7.693694] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> link_pre_setup [ 7.705368] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_pre_setup -> link_supported [ 7.716940] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_supported -> link_init [ 7.728086] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_init -> device_init [ 7.738985] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition device_init -> idle [ 7.749445] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition idle -> idle [ 7.759295] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition idle -> device_init [ 7.769755] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition device_init -> link_init [ 7.780632] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_init -> link_supported [ 7.791778] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_supported -> link_pre_setup [ 7.803360] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 7.815017] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 7.826765] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 7.838521] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> link_setup [ 7.849834] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_setup -> opt_setup_stage1 [ 7.861250] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 7.873196] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 7.885131] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 7.897069] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 7.930581] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 7.947619] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 8.012387] axi_adxcvr 84b00000.axi-adxcvr-rx-0: QPLL RX: Not ready defer probe [ 8.117948] systemd[1]: /etc/systemd/system/tof-server.service:1: Assignment outside of section. Ignoring. [ 8.122992] axi_adxcvr 84b00000.axi-adxcvr-rx-0: QPLL RX: Not ready defer probe [ 8.127629] systemd[1]: /etc/systemd/system/tof-server.service:2: Assignment outside of section. Ignoring. [ 8.134909] axi-jesd204-rx 84aa0000.axi-jesd204-rx-0: axi_jesd204_rx_jesd204_clks_enable: Link0 enable lane clock failed (-517) [ 8.156015] jesd204: /fpga-axi@0/axi-jesd204-rx-0@84aa0000,jesd204:12,parent=84aa0000.axi-jesd204-rx-0: JESD204[0] got error from cb: -517 [ 8.168445] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: Rolling back from 'opt_setup_stage5', got error -517 [ 8.180103] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 8.191759] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clocks_enable -> opt_setup_stage5 [ 8.203409] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4 [ 8.215316] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3 [ 8.227225] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2 [ 8.239135] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1 [ 8.251044] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> link_setup [ 8.262436] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_setup -> clk_sync_stage3 [ 8.273734] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2 [ 8.285473] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1 [ 8.297205] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> link_pre_setup [ 8.308859] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_pre_setup -> link_supported [ 8.313053] random: systemd: uninitialized urandom read (16 bytes read) [ 8.320427] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_supported -> link_init [ 8.333445] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 8.338158] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_init -> device_init [ 8.349744] random: systemd: uninitialized urandom read (16 bytes read) [ 8.360559] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition device_init -> idle [ 8.360569] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition idle -> idle [ 8.367215] systemd[1]: Reached target Swap. [ 8.377601] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition idle -> device_init [ 8.402106] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition device_init -> link_init [ 8.402117] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_init -> link_supported [ 8.424089] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_supported -> link_pre_setup [ 8.435651] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 8.447378] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 8.460581] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 8.475355] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> link_setup [ 8.486812] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_setup -> opt_setup_stage1 [ 8.486922] random: systemd: uninitialized urandom read (16 bytes read) [ 8.498199] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 8.498207] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 8.505200] systemd[1]: Listening on Journal Socket. [ 8.516714] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 8.516722] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 8.660705] axi_adxcvr 84b80000.axi-adxcvr-rx-2: QPLL RX: Not ready defer probe [ 8.771296] axi_adxcvr 84b80000.axi-adxcvr-rx-2: QPLL RX: Not ready defer probe [ 8.778604] axi-jesd204-rx 84aa8000.axi-jesd204-rx-2: axi_jesd204_rx_jesd204_clks_enable: Link0 enable lane clock failed (-517) [ 8.790079] jesd204: /fpga-axi@0/axi-jesd204-rx-2@84aa8000,jesd204:14,parent=84aa8000.axi-jesd204-rx-2: JESD204[0] got error from cb: -517 [ 8.790086] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: Rolling back from 'opt_setup_stage5', got error -517 [ 8.813986] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 8.831210] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clocks_enable -> opt_setup_stage5 [ 8.843099] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4 [ 8.855003] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3 [ 8.866911] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2 [ 8.878821] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1 [ 8.890732] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> link_setup [ 8.890739] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_setup -> clk_sync_stage3 [ 8.913411] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2 [ 8.925145] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1 [ 8.936966] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> link_pre_setup [ 8.950249] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_pre_setup -> link_supported [ 8.966664] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_supported -> link_init [ 8.977961] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_init -> device_init [ 8.988825] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition device_init -> idle [ 8.988834] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition idle -> idle [ 9.009073] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition idle -> device_init [ 9.019500] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition device_init -> link_init [ 9.031923] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_init -> link_supported [ 9.047727] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_supported -> link_pre_setup [ 9.059452] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 9.071093] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 9.082835] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 9.082852] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> link_setup [ 9.105867] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_setup -> opt_setup_stage1 [ 9.117260] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 9.129948] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 9.141854] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 9.158605] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 9.274133] axi_adxcvr 84b00000.axi-adxcvr-rx-0: QPLL RX: Not ready defer probe [ 9.384742] axi_adxcvr 84b00000.axi-adxcvr-rx-0: QPLL RX: Not ready defer probe [ 9.392891] axi-jesd204-rx 84aa0000.axi-jesd204-rx-0: axi_jesd204_rx_jesd204_clks_enable: Link0 enable lane clock failed (-517) [ 9.404367] jesd204: /fpga-axi@0/axi-jesd204-rx-0@84aa0000,jesd204:12,parent=84aa0000.axi-jesd204-rx-0: JESD204[0] got error from cb: -517 [ 9.416796] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: Rolling back from 'opt_setup_stage5', got error -517 [ 9.428366] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 9.440026] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clocks_enable -> opt_setup_stage5 [ 9.451687] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4 [ 9.463591] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3 [ 9.475502] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2 [ 9.488188] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1 [ 9.500094] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> link_setup [ 9.516322] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_setup -> clk_sync_stage3 [ 9.527807] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2 [ 9.539552] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1 [ 9.551298] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> link_pre_setup [ 9.551306] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_pre_setup -> link_supported [ 9.574497] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_supported -> link_init [ 9.585629] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_init -> device_init [ 9.585636] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition device_init -> idle [ 9.606919] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition idle -> idle [ 9.617513] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition idle -> device_init [ 9.632280] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition device_init -> link_init [ 9.643313] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_init -> link_supported [ 9.654454] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_supported -> link_pre_setup [ 9.666014] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 9.666022] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 9.666029] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 9.666047] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> link_setup [ 9.666054] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_setup -> opt_setup_stage1 [ 9.666061] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 9.666068] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 9.666075] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 9.666082] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 9.769533] axi_adxcvr 84b80000.axi-adxcvr-rx-2: QPLL RX: Not ready defer probe [ 9.888538] axi_adxcvr 84b80000.axi-adxcvr-rx-2: QPLL RX: Not ready defer probe [ 9.895879] axi-jesd204-rx 84aa8000.axi-jesd204-rx-2: axi_jesd204_rx_jesd204_clks_enable: Link0 enable lane clock failed (-517) [ 9.907351] jesd204: /fpga-axi@0/axi-jesd204-rx-2@84aa8000,jesd204:14,parent=84aa8000.axi-jesd204-rx-2: JESD204[0] got error from cb: -517 [ 9.919785] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: Rolling back from 'opt_setup_stage5', got error -517 [ 9.931261] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 9.942932] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clocks_enable -> opt_setup_stage5 [ 9.942941] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4 [ 9.942949] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3 [ 9.942956] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2 [ 9.942963] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1 [ 9.942971] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> link_setup [ 9.942978] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_setup -> clk_sync_stage3 [ 9.942985] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2 [ 9.942992] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1 [ 9.942999] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> link_pre_setup [ 9.943006] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_pre_setup -> link_supported [ 9.943013] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_supported -> link_init [ 9.943023] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_init -> device_init [ 9.943030] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition device_init -> idle [ 9.943038] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition idle -> idle [ 9.943045] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition idle -> device_init [ 9.943053] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition device_init -> link_init [ 9.943062] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_init -> link_supported [ 9.943069] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_supported -> link_pre_setup [ 9.943076] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 9.943082] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 9.943089] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 9.943103] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> link_setup [ 9.943110] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_setup -> opt_setup_stage1 [ 9.943117] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 9.943124] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 9.943131] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 9.943137] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 10.046562] axi_adxcvr 84b00000.axi-adxcvr-rx-0: QPLL RX: Not ready defer probe [ 10.150012] axi_adxcvr 84b00000.axi-adxcvr-rx-0: QPLL RX: Not ready defer probe [ 10.150057] axi-jesd204-rx 84aa0000.axi-jesd204-rx-0: axi_jesd204_rx_jesd204_clks_enable: Link0 enable lane clock failed (-517) [ 10.150068] jesd204: /fpga-axi@0/axi-jesd204-rx-0@84aa0000,jesd204:12,parent=84aa0000.axi-jesd204-rx-0: JESD204[0] got error from cb: -517 [ 10.150076] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: Rolling back from 'opt_setup_stage5', got error -517 [ 10.152243] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 10.152257] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clocks_enable -> opt_setup_stage5 [ 10.152264] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4 [ 10.152272] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3 [ 10.152279] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2 [ 10.152287] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1 [ 10.152295] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> link_setup [ 10.152302] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_setup -> clk_sync_stage3 [ 10.152309] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2 [ 10.152316] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1 [ 10.152323] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> link_pre_setup [ 10.152331] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_pre_setup -> link_supported [ 10.152338] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_supported -> link_init [ 10.152348] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_init -> device_init [ 10.152355] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition device_init -> idle [ 10.152363] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition idle -> idle [ 10.152370] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition idle -> device_init [ 10.152378] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition device_init -> link_init [ 10.152388] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_init -> link_supported [ 10.152395] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_supported -> link_pre_setup [ 10.152402] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 10.152409] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 10.152416] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 10.152430] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> link_setup [ 10.152437] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_setup -> opt_setup_stage1 [ 10.152445] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 10.152452] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 10.152459] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 10.152465] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 10.255915] axi_adxcvr 84b80000.axi-adxcvr-rx-2: QPLL RX: Not ready defer probe [ 10.359361] axi_adxcvr 84b80000.axi-adxcvr-rx-2: QPLL RX: Not ready defer probe [ 10.359401] axi-jesd204-rx 84aa8000.axi-jesd204-rx-2: axi_jesd204_rx_jesd204_clks_enable: Link0 enable lane clock failed (-517) [ 10.359411] jesd204: /fpga-axi@0/axi-jesd204-rx-2@84aa8000,jesd204:14,parent=84aa8000.axi-jesd204-rx-2: JESD204[0] got error from cb: -517 [ 10.359420] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: Rolling back from 'opt_setup_stage5', got error -517 [ 10.359581] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 10.359594] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clocks_enable -> opt_setup_stage5 [ 10.359601] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4 [ 10.359609] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3 [ 10.359616] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2 [ 10.359622] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1 [ 10.359630] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> link_setup [ 10.359637] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_setup -> clk_sync_stage3 [ 10.359644] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2 [ 10.359651] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1 [ 10.359658] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> link_pre_setup [ 10.359665] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_pre_setup -> link_supported [ 10.359672] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_supported -> link_init [ 10.359682] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition link_init -> device_init [ 10.359689] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: JESD204[0] transition device_init -> idle [ 10.359695] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:2,parent=spi2.1: FSM completed with error -517 [ 10.360330] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 10.360339] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clocks_enable -> opt_setup_stage5 [ 10.360347] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4 [ 10.360354] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3 [ 10.360361] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2 [ 10.360368] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1 [ 10.360375] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> link_setup [ 10.360382] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_setup -> clk_sync_stage3 [ 10.360388] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2 [ 10.360395] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1 [ 10.360402] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> link_pre_setup [ 10.360409] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_pre_setup -> link_supported [ 10.360416] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_supported -> link_init [ 10.360425] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition link_init -> device_init [ 10.360432] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: JESD204[0] transition device_init -> idle [ 10.360437] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:4,parent=spi2.3: FSM completed with error -517 [ 12.486447] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 12.565914] systemd-journald[2180]: Received request to flush runtime journal from PID 1 [ 17.827483] random: crng init done [ 17.827492] random: 7 urandom warning(s) missed due to ratelimiting [ 18.194043] pps pps0: new PPS source ptp0 [ 18.194055] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered. [ 18.194199] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 19.629456] Adding 102396k swap on /var/swap. Priority:-2 extents:4 across:10111164k SS [ 22.270617] macb ff0b0000.ethernet eth0: link up (1000/Full) [ 22.270642] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 34.388411] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
For reference with the tx_dma still in place:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.0-g14345162ffb4-dirty (cyril@p1) (gcc version 7.2.0 (GCC)) #138 SMP Wed May 4 09:33:50 CEST 2022 [ 0.000000] Machine model: Enclustra XU8 SOM [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 256 MiB at 0x000000006fc00000 [ 0.000000] On node 0 totalpages: 524032 [ 0.000000] DMA32 zone: 7165 pages used for memmap [ 0.000000] DMA32 zone: 0 pages reserved [ 0.000000] DMA32 zone: 524032 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x414 with crng_init=0 [ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s51864 r8192 d30056 u90112 [ 0.000000] pcpu-alloc: s51864 r8192 d30056 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516867 [ 0.000000] Kernel command line: console=ttyPS0,115200 rw earlyprintk rootwait root=/dev/mmcblk1p2 [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Memory: 1774652K/2096128K available (13372K kernel code, 1500K rwdata, 10688K rodata, 896K init, 344K bss, 59332K reserved, 262144K cma-reserved) [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns [ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns [ 0.000279] Console: colour dummy device 80x25 [ 0.000299] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960) [ 0.000307] pid_max: default: 32768 minimum: 301 [ 0.000415] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000425] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.001113] ASID allocator initialised with 32768 entries [ 0.001165] rcu: Hierarchical SRCU implementation. [ 0.001486] EFI services will not be available. [ 0.001602] smp: Bringing up secondary CPUs ... [ 0.001873] Detected VIPT I-cache on CPU1 [ 0.001903] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 1.024546] CPU2: failed to come online [ 1.024555] CPU2: failed in unknown state : 0x0 [ 2.049164] CPU3: failed to come online [ 2.049169] CPU3: failed in unknown state : 0x0 [ 2.049205] smp: Brought up 1 node, 2 CPUs [ 2.049210] SMP: Total of 2 processors activated. [ 2.049216] CPU features: detected: 32-bit EL0 Support [ 2.050659] CPU: All CPU(s) started at EL2 [ 2.050670] alternatives: patching kernel code [ 2.051518] devtmpfs: initialized [ 2.057217] Registered cp15_barrier emulation handler [ 2.057226] Registered setend emulation handler [ 2.057348] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 2.057360] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 2.062240] xor: measuring software checksum speed [ 2.101247] 8regs : 2302.000 MB/sec [ 2.141276] 8regs_prefetch: 2052.000 MB/sec [ 2.181306] 32regs : 2830.000 MB/sec [ 2.221337] 32regs_prefetch: 2379.000 MB/sec [ 2.221341] xor: using function: 32regs (2830.000 MB/sec) [ 2.221352] pinctrl core: initialized pinctrl subsystem [ 2.221951] NET: Registered protocol family 16 [ 2.222207] audit: initializing netlink subsys (disabled) [ 2.222269] audit: type=2000 audit(2.220:1): state=initialized audit_enabled=0 res=1 [ 2.222656] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 2.222663] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.223783] DMA: preallocated 256 KiB pool for atomic allocations [ 2.245002] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 2.309555] raid6: int64x1 gen() 392 MB/s [ 2.377617] raid6: int64x1 xor() 445 MB/s [ 2.445672] raid6: int64x2 gen() 679 MB/s [ 2.513675] raid6: int64x2 xor() 602 MB/s [ 2.581720] raid6: int64x4 gen() 1036 MB/s [ 2.649763] raid6: int64x4 xor() 741 MB/s [ 2.717852] raid6: int64x8 gen() 979 MB/s [ 2.785887] raid6: int64x8 xor() 745 MB/s [ 2.854001] raid6: neonx1 gen() 724 MB/s [ 2.921984] raid6: neonx1 xor() 852 MB/s [ 2.990060] raid6: neonx2 gen() 1159 MB/s [ 3.058094] raid6: neonx2 xor() 1203 MB/s [ 3.126139] raid6: neonx4 gen() 1503 MB/s [ 3.194184] raid6: neonx4 xor() 1438 MB/s [ 3.262257] raid6: neonx8 gen() 1645 MB/s [ 3.330305] raid6: neonx8 xor() 1525 MB/s [ 3.330309] raid6: using algorithm neonx8 gen() 1645 MB/s [ 3.330313] raid6: .... xor() 1525 MB/s, rmw enabled [ 3.330317] raid6: using neon recovery algorithm [ 3.331224] SCSI subsystem initialized [ 3.331259] libata version 3.00 loaded. [ 3.331383] usbcore: registered new interface driver usbfs [ 3.331413] usbcore: registered new interface driver hub [ 3.331453] usbcore: registered new device driver usb [ 3.331618] media: Linux media interface: v0.10 [ 3.331641] videodev: Linux video capture interface: v2.00 [ 3.331695] pps_core: LinuxPPS API ver. 1 registered [ 3.331699] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 3.331712] PTP clock support registered [ 3.331733] EDAC MC: Ver: 3.0.0 [ 3.333188] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver. [ 3.333605] jesd204: created con: id=0, topo=1, link=0, /fpga-axi@0/axi-adxcvr-rx-3@84bc0000 <-> /fpga-axi@0/axi-jesd204-rx-3@84aac000 [ 3.333617] jesd204: created con: id=1, topo=1, link=0, /fpga-axi@0/axi-adxcvr-rx-2@84b80000 <-> /fpga-axi@0/axi-jesd204-rx-2@84aa8000 [ 3.333627] jesd204: created con: id=2, topo=1, link=0, /fpga-axi@0/axi-adxcvr-rx-1@84b40000 <-> /fpga-axi@0/axi-jesd204-rx-1@84aa4000 [ 3.333639] jesd204: created con: id=3, topo=1, link=0, /fpga-axi@0/axi-adxcvr-rx-0@84b00000 <-> /fpga-axi@0/axi-jesd204-rx-0@84aa0000 [ 3.333649] jesd204: created con: id=4, topo=1, link=0, /fpga-axi@0/axi-jesd204-rx-3@84aac000 <-> /fpga-axi@0/axi-ad9680-hpc-3@84a1c000 [ 3.333659] jesd204: created con: id=5, topo=1, link=0, /fpga-axi@0/axi-jesd204-rx-2@84aa8000 <-> /fpga-axi@0/axi-ad9680-hpc-2@84a18000 [ 3.333669] jesd204: created con: id=6, topo=1, link=0, /fpga-axi@0/axi-jesd204-rx-1@84aa4000 <-> /fpga-axi@0/axi-ad9680-hpc-1@84a14000 [ 3.333678] jesd204: created con: id=7, topo=1, link=0, /fpga-axi@0/axi-jesd204-rx-0@84aa0000 <-> /fpga-axi@0/axi-ad9680-hpc-0@84a10000 [ 3.333689] jesd204: created con: id=8, topo=1, link=0, /fpga-axi@0/axi-ad9680-hpc-3@84a1c000 <-> /amba/spi@ff050000/ad9680@4 [ 3.333699] jesd204: created con: id=9, topo=1, link=0, /fpga-axi@0/axi-ad9680-hpc-2@84a18000 <-> /amba/spi@ff050000/ad9680@3 [ 3.333709] jesd204: created con: id=10, topo=1, link=0, /fpga-axi@0/axi-ad9680-hpc-1@84a14000 <-> /amba/spi@ff050000/ad9680@2 [ 3.333719] jesd204: created con: id=11, topo=1, link=0, /fpga-axi@0/axi-ad9680-hpc-0@84a10000 <-> /amba/spi@ff050000/ad9680@1 [ 3.333733] jesd204: /amba/spi@ff050000/ad9680@4: JESD204[0] transition uninitialized -> initialized [ 3.333741] jesd204: /amba/spi@ff050000/ad9680@3: JESD204[0] transition uninitialized -> initialized [ 3.333749] jesd204: /amba/spi@ff050000/ad9680@2: JESD204[0] transition uninitialized -> initialized [ 3.333756] jesd204: /amba/spi@ff050000/ad9680@1: JESD204[0] transition uninitialized -> initialized [ 3.333760] jesd204: found 16 devices and 4 topologies [ 3.333795] FPGA manager framework [ 3.333989] Advanced Linux Sound Architecture Driver Initialized. [ 3.334262] Bluetooth: Core ver 2.22 [ 3.334285] NET: Registered protocol family 31 [ 3.334289] Bluetooth: HCI device and connection manager initialized [ 3.334297] Bluetooth: HCI socket layer initialized [ 3.334304] Bluetooth: L2CAP socket layer initialized [ 3.334325] Bluetooth: SCO socket layer initialized [ 3.334818] clocksource: Switched to clocksource arch_sys_counter [ 3.334892] VFS: Disk quotas dquot_6.6.0 [ 3.334937] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.342480] NET: Registered protocol family 2 [ 3.342985] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes) [ 3.343012] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 3.343118] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 3.343309] TCP: Hash tables configured (established 16384 bind 16384) [ 3.343370] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 3.343410] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 3.343526] NET: Registered protocol family 1 [ 3.343770] RPC: Registered named UNIX socket transport module. [ 3.343774] RPC: Registered udp transport module. [ 3.343778] RPC: Registered tcp transport module. [ 3.343782] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.344079] PCI: CLS 0 bytes, default 64 [ 3.344443] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 3.344568] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 3.345417] Initialise system trusted keyrings [ 3.345936] workingset: timestamp_bits=62 max_order=19 bucket_order=0 [ 3.346583] NFS: Registering the id_resolver key type [ 3.346599] Key type id_resolver registered [ 3.346603] Key type id_legacy registered [ 3.346612] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 3.346628] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 4.422450] NET: Registered protocol family 38 [ 4.480188] Key type asymmetric registered [ 4.480194] Asymmetric key parser 'x509' registered [ 4.480229] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 4.480236] io scheduler noop registered [ 4.480240] io scheduler deadline registered [ 4.480264] io scheduler cfq registered (default) [ 4.480269] io scheduler mq-deadline registered [ 4.480273] io scheduler kyber registered [ 4.508904] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 4.512982] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 4.517069] brd: module loaded [ 4.521017] loop: module loaded [ 4.521199] Registered mathworks_ip class [ 4.522071] mtdoops: mtd device (mtddev=name/number) must be supplied [ 4.523532] libphy: Fixed MDIO Bus: probed [ 4.524682] tun: Universal TUN/TAP device driver, 1.6 [ 4.526896] CAN device driver interface [ 4.528049] xilinx_axienet 80101000.ethernet: missing/invalid xlnx,addrwidth property, using default [ 4.528695] xilinx_axienet 80201000.ethernet: missing/invalid xlnx,addrwidth property, using default [ 4.528885] usbcore: registered new interface driver asix [ 4.528926] usbcore: registered new interface driver ax88179_178a [ 4.528954] usbcore: registered new interface driver cdc_ether [ 4.528978] usbcore: registered new interface driver net1080 [ 4.529005] usbcore: registered new interface driver cdc_subset [ 4.529029] usbcore: registered new interface driver zaurus [ 4.529064] usbcore: registered new interface driver cdc_ncm [ 4.529873] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.529878] ehci-pci: EHCI PCI platform driver [ 4.530197] usbcore: registered new interface driver uas [ 4.530232] usbcore: registered new interface driver usb-storage [ 4.530292] usbcore: registered new interface driver usbserial_generic [ 4.530314] usbserial: USB Serial support registered for generic [ 4.530337] usbcore: registered new interface driver ftdi_sio [ 4.530357] usbserial: USB Serial support registered for FTDI USB Serial Device [ 4.530380] usbcore: registered new interface driver upd78f0730 [ 4.530400] usbserial: USB Serial support registered for upd78f0730 [ 4.532260] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0 [ 4.532331] i2c /dev entries driver [ 4.534512] usbcore: registered new interface driver uvcvideo [ 4.534517] USB Video Class driver (1.1.1) [ 4.536183] Bluetooth: HCI UART driver ver 2.3 [ 4.536192] Bluetooth: HCI UART protocol H4 registered [ 4.536197] Bluetooth: HCI UART protocol BCSP registered [ 4.536222] Bluetooth: HCI UART protocol LL registered [ 4.536226] Bluetooth: HCI UART protocol ATH3K registered [ 4.536245] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 4.536292] Bluetooth: HCI UART protocol Intel registered [ 4.536311] Bluetooth: HCI UART protocol QCA registered [ 4.536350] usbcore: registered new interface driver bcm203x [ 4.536381] usbcore: registered new interface driver bpa10x [ 4.536411] usbcore: registered new interface driver bfusb [ 4.536440] usbcore: registered new interface driver btusb [ 4.536445] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 4.536491] usbcore: registered new interface driver ath3k [ 4.536846] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT) [ 4.537027] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED) [ 4.537210] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT) [ 4.537691] sdhci: Secure Digital Host Controller Interface driver [ 4.537696] sdhci: Copyright(c) Pierre Ossman [ 4.537699] sdhci-pltfm: SDHCI platform and OF driver helper [ 4.539298] ledtrig-cpu: registered to indicate activity on CPUs [ 4.539369] zynqmp_firmware_probe Platform Management API v1.1 [ 4.539375] zynqmp_firmware_probe Trustzone version v1.0 [ 4.542133] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized [ 4.564556] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22 [ 4.565522] alg: No test for xilinx-zynqmp-aes (zynqmp-aes) [ 4.565541] zynqmp_aes zynqmp_aes: AES Successfully Registered [ 4.565742] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384) [ 4.565902] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa) [ 4.566120] usbcore: registered new interface driver usbhid [ 4.566124] usbhid: USB HID core driver [ 4.576431] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.00.a) found [ 4.576618] axi_sysid 85000000.axi-sysid-0: system ID header version mismatch. Expected 1, Reported 0 [ 4.576630] axi_sysid: probe of 85000000.axi-sysid-0 failed with error -14 [ 4.576915] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered [ 4.578236] usbcore: registered new interface driver snd-usb-audio [ 4.580198] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 4.582584] Initializing XFRM netlink socket [ 4.582658] NET: Registered protocol family 10 [ 4.583400] Segment Routing with IPv6 [ 4.583489] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 4.583832] NET: Registered protocol family 17 [ 4.583844] NET: Registered protocol family 15 [ 4.583860] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 4.584331] can: controller area network core (rev 20170425 abi 9) [ 4.584361] NET: Registered protocol family 29 [ 4.584366] can: raw protocol (rev 20170425) [ 4.584371] can: broadcast manager protocol (rev 20170425 t) [ 4.584378] can: netlink gateway (rev 20170425) max_hops=1 [ 4.584449] Bluetooth: RFCOMM TTY layer initialized [ 4.584457] Bluetooth: RFCOMM socket layer initialized [ 4.584472] Bluetooth: RFCOMM ver 1.11 [ 4.584480] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 4.584484] Bluetooth: BNEP filters: protocol multicast [ 4.584490] Bluetooth: BNEP socket layer initialized [ 4.584494] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 4.584500] Bluetooth: HIDP socket layer initialized [ 4.584606] 9pnet: Installing 9P2000 support [ 4.584617] NET: Registered protocol family 36 [ 4.584632] Key type dns_resolver registered [ 4.585145] registered taskstats version 1 [ 4.585149] Loading compiled-in X.509 certificates [ 4.585480] Btrfs loaded, crc32c=crc32c-generic [ 4.591638] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 35, base_baud = 6249999) is a xuartps [ 6.109201] console [ttyPS0] enabled [ 6.113394] of-fpga-region fpga-full: FPGA Region probed [ 6.120307] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success [ 6.127419] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success [ 6.134524] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success [ 6.141623] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success [ 6.148725] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success [ 6.155831] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success [ 6.162941] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success [ 6.170044] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success [ 6.177292] zynqmp_pll_disable() clock disable failed for rpll_int, ret = -13 [ 6.195143] HMC703: Start Probing [ 6.195153] HMC703: Devicetree Parsing... [ 6.199028] HMC703: Finished Probing [ 6.203670] pe4312 spi1.3: spi1.3 supply vcc not found, using dummy regulator [ 6.214394] pe4312 spi1.3: Linked as a consumer to regulator.0 [ 6.221086] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 6.252885] ad9208 spi2.1: ad9680 PLL LOCKED [ 6.257176] ad9208 spi2.1: ad9680 Rev. 5 Grade 8 (API 1.0.1) probed [ 6.269704] ad9208 spi2.2: Unrecognized CHIP_ID 0xF000 [ 6.281544] random: fast init done [ 6.297621] ad9208 spi2.3: ad9680 PLL LOCKED [ 6.301917] ad9208 spi2.3: ad9680 Rev. 5 Grade 8 (API 1.0.1) probed [ 6.314486] ad9208 spi2.4: Unrecognized CHIP_ID 0xF000 [ 6.320648] m25p80 spi0.0: non-uniform erase sector maps are not supported yet. [ 6.327989] m25p80 spi0.0: s25fl512s (65536 Kbytes) [ 6.332891] 6 fixed-partitions partitions found on MTD device spi0.0 [ 6.339233] Creating 6 MTD partitions on "spi0.0": [ 6.344019] 0x000000000000-0x000000700000 : "qspi-bootimage" [ 6.350130] 0x000000700000-0x000000c00000 : "qspi-kernel" [ 6.355924] 0x000000c00000-0x000000c80000 : "qspi-device-tree" [ 6.362149] 0x000000c80000-0x000000d00000 : "qspi-bootargs" [ 6.368116] 0x000000d00000-0x000000d40000 : "qspi-bootscript" [ 6.374255] 0x000000d40000-0x000004000000 : "qspi-rootfs" [ 6.380865] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp_pinconf_cfg_set failed: pin 26 param 1 value 0 [ 6.391627] macb ff0b0000.ethernet: Not enabling partial store and forward [ 6.399039] libphy: MACB_mii_bus: probed [ 6.475982] Micrel KSZ9031 Gigabit PHY ff0b0000.ethernet-ffffffff:03: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=ff0b0000.ethernet-ffffffff:03, irq=POLL) [ 6.491801] macb ff0b0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 21 (20:b0:f7:06:42:6c) [ 6.501830] zynqmp_gpd_attach_dev() domain7 request failed for node 32: -13 [ 6.508796] macb ff0e0000.ethernet: failed to add to PM domain domain7: -13 [ 6.515759] macb: probe of ff0e0000.ethernet failed with error -13 [ 6.522399] xilinx_axienet 80101000.ethernet: missing/invalid xlnx,addrwidth property, using default [ 6.531571] xilinx_axienet 80101000.ethernet: couldn't find phy i/f [ 6.538391] xilinx_axienet 80201000.ethernet: missing/invalid xlnx,addrwidth property, using default [ 6.547553] xilinx_axienet 80201000.ethernet: couldn't find phy i/f [ 6.554515] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM [ 6.561049] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM [ 6.567537] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM [ 6.574029] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM [ 6.581464] dwc3-of-simple ff9d0000.usb0: dwc3_simple_set_phydata: Can't find usb3-phy [ 6.590470] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 24 [ 6.626798] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA 64-bit [ 6.671858] mmc1: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit [ 6.707417] cf_axi_adc 84a10000.axi-ad9680-hpc-0: ADI AIM (10.01.b) at 0x84A10000 mapped to 0x(____ptrval____), probed ADC AD9680 as MASTER [ 6.740959] cf_axi_adc 84a18000.axi-ad9680-hpc-2: ADI AIM (10.01.b) at 0x84A18000 mapped to 0x(____ptrval____), probed ADC AD9680 as MASTER [ 6.754258] axi_adxcvr 84b00000.axi-adxcvr-rx-0: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 6.770973] axi_adxcvr 84b00000.axi-adxcvr-rx-0: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B00000. Number of lanes: 2. [ 6.782662] axi_adxcvr 84b40000.axi-adxcvr-rx-1: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 6.799516] axi_adxcvr 84b40000.axi-adxcvr-rx-1: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B40000. Number of lanes: 2. [ 6.811199] axi_adxcvr 84b80000.axi-adxcvr-rx-2: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 6.827734] axi_adxcvr 84b80000.axi-adxcvr-rx-2: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84B80000. Number of lanes: 2. [ 6.839405] axi_adxcvr 84bc0000.axi-adxcvr-rx-3: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance [ 6.856291] axi_adxcvr 84bc0000.axi-adxcvr-rx-3: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84BC0000. Number of lanes: 2. [ 6.868366] axi_adxcvr 84a60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using QPLL on GTH4 at 0x84A60000. Number of lanes: 8. [ 6.882261] AD9173: channel-interpolation=1 dac-interpolation=12 jesd-subclass=0 jesd-dual-link-mode=1 jesd-link-mode=8 dac-rate-khz=12000000 [ 6.896718] mmc0: new HS200 MMC card at address 0001 [ 6.902133] mmcblk0: mmc0:0001 IB2916 14.6 GiB [ 6.907027] mmcblk0boot0: mmc0:0001 IB2916 partition 1 4.00 MiB [ 6.913295] mmcblk0boot1: mmc0:0001 IB2916 partition 2 4.00 MiB [ 6.919338] mmcblk0rpmb: mmc0:0001 IB2916 partition 3 4.00 MiB, chardev (242:0) [ 6.927705] mmcblk0: p1 [ 6.931478] ad9172 spi2.0: AD916x DAC Chip ID: 4 [ 6.936093] ad9172 spi2.0: AD916x DAC Product ID: 9173 [ 6.941226] ad9172 spi2.0: AD916x DAC Product Grade: 0 [ 6.946356] ad9172 spi2.0: AD916x DAC Product Revision: 2 [ 6.951747] ad9172 spi2.0: AD916x Revision: 1.1.1 [ 6.956444] ad9172 spi2.0: PLL Input rate 187500000 [ 7.066886] ad9172 spi2.0: PLL lock status 0, DLL lock status: 1 [ 7.265890] mmc1: new high speed SDHC card at address 0001 [ 7.271822] mmcblk1: mmc1:0001 0016G 15.2 GiB [ 7.277171] mmcblk1: p1 p2 p3 [ 7.282849] ad9172 spi2.0: Serdes PLL Locked (stat: 3) [ 7.395060] ad9172 spi2.0: code_grp_sync: f [ 7.399240] ad9172 spi2.0: frame_sync_stat: f [ 7.403588] ad9172 spi2.0: good_checksum_stat: f [ 7.408197] ad9172 spi2.0: init_lane_sync_stat: f [ 7.412893] ad9172 spi2.0: 4 lanes @ 10000000 kBps [ 7.417937] ad9172 spi2.0: code_grp_sync: f [ 7.422114] ad9172 spi2.0: frame_sync_stat: f [ 7.426461] ad9172 spi2.0: good_checksum_stat: f [ 7.431070] ad9172 spi2.0: init_lane_sync_stat: f [ 7.435767] ad9172 spi2.0: 4 lanes @ 10000000 kBps [ 7.441112] ad9172 spi2.0: Probed. [ 7.463249] cf_axi_dds 84a04000.axi-ad9173-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DDS AD917x [ 7.480126] rtc_zynqmp ffa60000.rtc: setting system clock to 2023-01-16 18:12:28 UTC (1673892748) [ 7.488993] of_cfs_init [ 7.491454] of_cfs_init: OK [ 7.494393] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 7.632426] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 7.639838] ALSA device list: [ 7.642797] No soundcards found. [ 7.646514] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 7.655119] cfg80211: failed to load regulatory.db [ 7.744692] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 7.752794] VFS: Mounted root (ext4 filesystem) on device 179:26. [ 7.878750] devtmpfs: mounted [ 7.881916] Freeing unused kernel memory: 896K [ 7.886375] Run /sbin/init as init process [ 8.798816] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition initialized -> probed [ 8.809429] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition probed -> idle [ 8.819427] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition idle -> device_init [ 8.829860] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition device_init -> link_init [ 8.840737] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_init -> link_supported [ 8.851866] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_supported -> link_pre_setup [ 8.863429] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 8.875080] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 8.886815] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 8.898583] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition clk_sync_stage3 -> link_setup [ 8.909881] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_setup -> opt_setup_stage1 [ 8.921269] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 8.933183] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 8.945091] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 8.956999] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 8.969941] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition initialized -> probed [ 8.980555] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition probed -> idle [ 8.990554] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition idle -> device_init [ 9.000985] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition device_init -> link_init [ 9.011856] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_init -> link_supported [ 9.022985] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_supported -> link_pre_setup [ 9.034545] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_pre_setup -> clk_sync_stage1 [ 9.046195] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2 [ 9.057932] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3 [ 9.069691] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition clk_sync_stage3 -> link_setup [ 9.080991] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_setup -> opt_setup_stage1 [ 9.092378] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2 [ 9.104287] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3 [ 9.116198] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4 [ 9.128108] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5 [ 9.141122] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 9.152778] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition clocks_enable -> link_enable [ 9.163995] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_enable -> link_running [ 9.175124] jesd204: /amba/spi@ff050000/ad9680@1,jesd204:0,parent=spi2.1: JESD204[0] transition link_running -> opt_post_running_stage [ 9.187306] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition opt_setup_stage5 -> clocks_enable [ 9.198957] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition clocks_enable -> link_enable [ 9.210169] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_enable -> link_running [ 9.221295] jesd204: /amba/spi@ff050000/ad9680@3,jesd204:2,parent=spi2.3: JESD204[0] transition link_running -> opt_post_running_stage [ 9.883007] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 9.904667] systemd[1]: Detected architecture arm64. [ 9.927451] systemd[1]: Set hostname to <analog>. [ 10.187606] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 10.204686] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 10.378136] systemd[1]: /etc/systemd/system/tof-server.service:1: Assignment outside of section. Ignoring. [ 10.387814] systemd[1]: /etc/systemd/system/tof-server.service:2: Assignment outside of section. Ignoring. [ 10.565954] random: systemd: uninitialized urandom read (16 bytes read) [ 10.578948] random: systemd: uninitialized urandom read (16 bytes read) [ 10.585944] systemd[1]: Listening on fsck to fsckd communication Socket. [ 10.606885] random: systemd: uninitialized urandom read (16 bytes read) [ 10.614054] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 10.635062] systemd[1]: Created slice system-getty.slice. [ 11.511678] random: crng init done [ 11.511683] random: 7 urandom warning(s) missed due to ratelimiting [ 11.662312] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 11.742437] systemd-journald[2201]: Received request to flush runtime journal from PID 1 [ 17.459372] pps pps0: new PPS source ptp0 [ 17.459384] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered. [ 17.459541] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 18.805099] Adding 102396k swap on /var/swap. Priority:-2 extents:4 across:10111164k SS [ 20.815729] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 20.822824] xilinx_axienet 80101000.ethernet eth1: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration [ 21.147672] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready [ 21.158171] xilinx_axienet 80201000.ethernet eth2: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration [ 21.535436] macb ff0b0000.ethernet eth0: link up (1000/Full) [ 21.535463] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 33.584719] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
I don't know if I'm turning the right knobs to get the link working again or what to do next...
Please Help
Best Regards,
Philipp
