KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
ADRV9009
Recommended for New Designs
The ADRV9009 is a highly integrated, radio frequency (RF), agile transceiver offering dual transmitters and receivers, integrated synthesizers, and digital...
Datasheet
ADRV9009 on Analog.com
Hi ADI community,
I want to use ZCU102 + ADRV9009 platform for my application. For that, I followed the ADI wiki instructions to download Image Linux on SD card and boot it from ZCU102.
This is my setup :
- 32 Go SD Card
- ADI Image Linux: 2019_R1 (22 June 2020)
- ZCU102 rev 1.1 + ADRV9009.
- IIO OSCILLOSCOPE v1.15
Linux is booted correctly. But when I want to use IIO OSCILLOSCOPE, I have something like this :
When I check iio_attr -d command, I found this :
iio_device3 to iio:device6 are missing (axi-adrv9009-rx-hpc, axi-adrv9009-tx-hpc, adrv9009-phy, axi-adrv9009-rx-obs-hpc).
I've used this version (2019_R1) image Linux in the past and never had this issue before.
Do you have any idea where this comes from? Could be a hardware problem?
I updated the Linux image to KUIPER Linux using the 28 July 2021 version. I booted successfully the Linux. When I check the IIO device, I find this
all IIO devices, but when I used IIO Oscilloscope, I have some errors
I appreciate any feedback from you
Best
Can you provide the log from dmesg on the board?
-Travis
Hi Travis
Of course, This is the boot log from ADI Image Linux where the IIO device are missing
Xilinx Zynq MP First Stage Boot Loader Release 2018.3 Dec 5 2019 - 01:53:44 NOTICE: ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000 NOTICE: BL31: Secure code at 0x0 NOTICE: BL31: Non secure code at 0x8000000 NOTICE: BL31: v1.5(release):xilinx-v2018.3 NOTICE: BL31: Built : 15:00:47, Mar 18 2019 PMUFW: v1.1 U-Boot 2018.01 (Jun 29 2018 - 13:20:51 +0200) Xilinx ZynqMP ZCU102 rev1.0 I2C: ready DRAM: 4 GiB EL Level: EL2 Chip ID: zu9eg MMC: sdhci@ff170000: 0 (SD) *** Warning - bad CRC, using default environment In: serial@ff000000 Out: serial@ff000000 Err: serial@ff000000 Bootmode: LVL_SHFT_SD_MODE1 Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id Warning: ethernet@ff0e0000 (eth0) using random MAC address - 8e:9e:31:f3:28:c6 eth0: ethernet@ff0e0000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Device: sdhci@ff170000 Manufacturer ID: 3 OEM: 5344 Name: SM16G Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 14.8 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes reading uEnv.txt 392 bytes read in 11 ms (34.2 KiB/s) Loaded environment from uEnv.txt Importing environment from SD ... Running uenvcmd ... Copying Linux from SD to RAM... ** No boot file defined ** reading system.dtb 60427 bytes read in 30 ms (1.9 MiB/s) reading Image 16361984 bytes read in 1089 ms (14.3 MiB/s) ## Flattened Device Tree blob at 04000000 Booting using the fdt blob at 0x4000000 Loading Device Tree to 000000000ffee000, end 000000000ffffc0a ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.0-g8a57ede (jenkins@romlxbuild1.adlk.analog.com) (gcc version 7.3.1 20180314 (Linaro GCC 7.3-2018.04-rc3)) #653 SMP Mon Feb 3 16:44:50 GMT 2020 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0 [ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8') [ 0.000000] bootconsole [cdns0] enabled [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 256 MiB at 0x0000000070000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] random: fast init done [ 0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff55000 s45080 r8192 d32744 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240 [ 0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait cpuidle.off=1 root=/dev/mmcblk0p2 rw rootwait [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB [mem 0x6bfff000-0x6ffff000] (64MB) mapped at [ffffffc06bfff000-ffffffc06fffefff] [ 0.000000] Memory: 3783788K/4194304K available (10236K kernel code, 746K rwdata, 4448K rodata, 512K init, 2154K bss, 148372K reserved, 262144K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008a80000 ( 10240 KB) [ 0.000000] .rodata : 0xffffff8008a80000 - 0xffffff8008ee0000 ( 4480 KB) [ 0.000000] .init : 0xffffff8008ee0000 - 0xffffff8008f60000 ( 512 KB) [ 0.000000] .data : 0xffffff8008f60000 - 0xffffff800901aa00 ( 747 KB) [ 0.000000] .bss : 0xffffff800901aa00 - 0xffffff8009235530 ( 2155 KB) [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB) [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB) [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum) [ 0.000000] 0xffffffbf00000000 - 0xffffffbf1dc00000 ( 476 MB actual) [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc880000000 ( 34816 MB) [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU event tracing is enabled. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns [ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns [ 0.008333] Console: colour dummy device 80x25 [ 0.012389] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960) [ 0.022756] pid_max: default: 32768 minimum: 301 [ 0.027438] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.034012] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.041662] ASID allocator initialised with 65536 entries [ 0.046503] Hierarchical SRCU implementation. [ 0.051167] EFI services will not be available. [ 0.055312] zynqmp_plat_init Platform Management API v1.1 [ 0.060648] zynqmp_plat_init Trustzone version v1.0 [ 0.065580] smp: Bringing up secondary CPUs ... [ 0.070229] Detected VIPT I-cache on CPU1 [ 0.070258] CPU1: Booted secondary processor [410fd034] [ 0.070528] Detected VIPT I-cache on CPU2 [ 0.070546] CPU2: Booted secondary processor [410fd034] [ 0.070799] Detected VIPT I-cache on CPU3 [ 0.070816] CPU3: Booted secondary processor [410fd034] [ 0.070858] smp: Brought up 1 node, 4 CPUs [ 0.101565] SMP: Total of 4 processors activated. [ 0.106237] CPU features: detected feature: 32-bit EL0 Support [ 0.112036] CPU: All CPU(s) started at EL2 [ 0.116108] alternatives: patching kernel code [ 0.121248] devtmpfs: initialized [ 0.130082] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.134171] futex hash table entries: 1024 (order: 5, 131072 bytes) [ 0.145839] xor: measuring software checksum speed [ 0.184467] 8regs : 2303.000 MB/sec [ 0.224496] 8regs_prefetch: 2052.000 MB/sec [ 0.264529] 32regs : 2831.000 MB/sec [ 0.304559] 32regs_prefetch: 2456.000 MB/sec [ 0.304588] xor: using function: 32regs (2831.000 MB/sec) [ 0.308964] pinctrl core: initialized pinctrl subsystem [ 0.314561] NET: Registered protocol family 16 [ 0.319742] vdso: 2 pages (1 code @ ffffff8008a86000, 1 data @ ffffff8008f64000) [ 0.325868] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.333051] DMA: preallocated 256 KiB pool for atomic allocations [ 0.360767] zynqmp-pinctrl pinctrl: zynqmp pinctrl initialized [ 0.361770] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed [ 0.368610] ARM CCI_400_r1 PMU driver probed [ 0.379956] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.450312] raid6: int64x1 gen() 457 MB/s [ 0.518287] raid6: int64x1 xor() 443 MB/s [ 0.586391] raid6: int64x2 gen() 689 MB/s [ 0.654391] raid6: int64x2 xor() 605 MB/s [ 0.722440] raid6: int64x4 gen() 1043 MB/s [ 0.790469] raid6: int64x4 xor() 765 MB/s [ 0.858530] raid6: int64x8 gen() 982 MB/s [ 0.926570] raid6: int64x8 xor() 751 MB/s [ 0.994665] raid6: neonx1 gen() 726 MB/s [ 1.062680] raid6: neonx1 xor() 851 MB/s [ 1.130705] raid6: neonx2 gen() 1168 MB/s [ 1.198756] raid6: neonx2 xor() 1207 MB/s [ 1.266801] raid6: neonx4 gen() 1504 MB/s [ 1.334864] raid6: neonx4 xor() 1441 MB/s [ 1.402927] raid6: neonx8 gen() 1665 MB/s [ 1.470952] raid6: neonx8 xor() 1533 MB/s [ 1.470979] raid6: using algorithm neonx8 gen() 1665 MB/s [ 1.474949] raid6: .... xor() 1533 MB/s, rmw enabled [ 1.479880] raid6: using neon recovery algorithm [ 1.485900] SCSI subsystem initialized [ 1.488345] usbcore: registered new interface driver usbfs [ 1.493667] usbcore: registered new interface driver hub [ 1.498945] usbcore: registered new device driver usb [ 1.503985] media: Linux media interface: v0.10 [ 1.508446] Linux video capture interface: v2.00 [ 1.513045] pps_core: LinuxPPS API ver. 1 registered [ 1.517945] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.527037] PTP clock support registered [ 1.531148] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver. [ 1.537886] FPGA manager framework [ 1.541224] fpga-region fpga-full: FPGA Region probed [ 1.546235] Advanced Linux Sound Architecture Driver Initialized. [ 1.552441] Bluetooth: Core ver 2.22 [ 1.555761] NET: Registered protocol family 31 [ 1.560162] Bluetooth: HCI device and connection manager initialized [ 1.566479] Bluetooth: HCI socket layer initialized [ 1.571322] Bluetooth: L2CAP socket layer initialized [ 1.576353] Bluetooth: SCO socket layer initialized [ 1.581776] clocksource: Switched to clocksource arch_sys_counter [ 1.587314] VFS: Disk quotas dquot_6.6.0 [ 1.591173] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.601822] NET: Registered protocol family 2 [ 1.602564] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 1.609675] TCP bind hash table entries: 32768 (order: 7, 524288 bytes) [ 1.616452] TCP: Hash tables configured (established 32768 bind 32768) [ 1.622596] UDP hash table entries: 2048 (order: 4, 65536 bytes) [ 1.628572] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes) [ 1.635057] NET: Registered protocol family 1 [ 1.639408] RPC: Registered named UNIX socket transport module. [ 1.645116] RPC: Registered udp transport module. [ 1.649784] RPC: Registered tcp transport module. [ 1.654456] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.661369] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 1.668102] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 1.676324] audit: initializing netlink subsys (disabled) [ 1.681076] audit: type=2000 audit(1.627:1): state=initialized audit_enabled=0 res=1 [ 1.681375] workingset: timestamp_bits=62 max_order=20 bucket_order=0 [ 1.695701] NFS: Registering the id_resolver key type [ 1.700146] Key type id_resolver registered [ 1.704285] Key type id_legacy registered [ 1.708268] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.714937] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 1.745855] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 1.747596] io scheduler noop registered [ 1.751496] io scheduler deadline registered [ 1.755754] io scheduler cfq registered (default) [ 1.760404] io scheduler mq-deadline registered [ 1.764901] io scheduler kyber registered [ 1.769464] nwl-pcie fd0e0000.pcie: Link is DOWN [ 1.773512] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges: [ 1.779102] OF: PCI: MEM 0xe0000000..0xefffffff -> 0xe0000000 [ 1.784975] OF: PCI: MEM 0x600000000..0x7ffffffff -> 0x600000000 [ 1.791238] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00 [ 1.797261] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.802708] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff] [ 1.809541] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref] [ 1.817233] pci 0000:00:00.0: PCI bridge to [bus 01-0c] [ 1.824415] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed [ 1.828750] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success [ 1.835563] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success [ 1.842484] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success [ 1.849400] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success [ 1.856318] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success [ 1.863242] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success [ 1.870163] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success [ 1.877084] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success [ 1.908588] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.912282] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 1.919339] brd: module loaded [ 1.922644] loop: module loaded [ 1.923424] ahci-ceva fd0c0000.ahci: couldn't get PHY in node ahci: -517 [ 1.928316] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.936018] m25p80 spi0.0: SPI-NOR-UniqueID 10440088170200180c001700c5b7ac0ae4 [ 1.941754] m25p80 spi0.0: found n25q512a, expected m25p80 [ 1.947344] m25p80 spi0.0: n25q512a (131072 Kbytes) [ 1.952069] 4 ofpart partitions found on MTD device spi0.0 [ 1.957487] Creating 4 MTD partitions on "spi0.0": [ 1.962248] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot" [ 1.968443] 0x000000100000-0x000000600000 : "qspi-linux" [ 1.973604] 0x000000600000-0x000000620000 : "qspi-device-tree" [ 1.979458] 0x000000620000-0x000000c00000 : "qspi-rootfs" [ 1.985639] libphy: Fixed MDIO Bus: probed [ 1.989407] tun: Universal TUN/TAP device driver, 1.6 [ 1.993601] CAN device driver interface [ 1.999370] macb ff0e0000.ethernet: Not enabling partial store and forward [ 2.004497] libphy: MACB_mii_bus: probed [ 2.008497] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 23 (8e:9e:31:f3:28:c6) [ 2.017793] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL) [ 2.031407] usbcore: registered new interface driver asix [ 2.036166] usbcore: registered new interface driver ax88179_178a [ 2.042200] usbcore: registered new interface driver cdc_ether [ 2.047995] usbcore: registered new interface driver net1080 [ 2.053619] usbcore: registered new interface driver cdc_subset [ 2.059503] usbcore: registered new interface driver zaurus [ 2.065047] usbcore: registered new interface driver cdc_ncm [ 2.070889] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM [ 2.078418] usbcore: registered new interface driver uas [ 2.082176] usbcore: registered new interface driver usb-storage [ 2.088593] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0 [ 2.095349] i2c /dev entries driver [ 2.099722] IR NEC protocol handler initialized [ 2.103256] IR RC5(x/sz) protocol handler initialized [ 2.108271] IR RC6 protocol handler initialized [ 2.112769] IR JVC protocol handler initialized [ 2.117269] IR Sony protocol handler initialized [ 2.121852] IR SANYO protocol handler initialized [ 2.126523] IR Sharp protocol handler initialized [ 2.131195] IR MCE Keyboard/mouse protocol handler initialized [ 2.136993] IR XMP protocol handler initialized [ 2.142249] usbcore: registered new interface driver uvcvideo [ 2.147201] USB Video Class driver (1.1.1) [ 2.151854] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff80092a5000 with timeout 60s [ 2.160368] Bluetooth: HCI UART driver ver 2.3 [ 2.164592] Bluetooth: HCI UART protocol H4 registered [ 2.169696] Bluetooth: HCI UART protocol BCSP registered [ 2.174970] Bluetooth: HCI UART protocol ATH3K registered [ 2.180333] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 2.186598] Bluetooth: HCI UART protocol Intel registered [ 2.191925] Bluetooth: HCI UART protocol QCA registered [ 2.197144] usbcore: registered new interface driver bcm203x [ 2.202765] usbcore: registered new interface driver bpa10x [ 2.208300] usbcore: registered new interface driver bfusb [ 2.213750] usbcore: registered new interface driver btusb [ 2.219176] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 2.224840] usbcore: registered new interface driver ath3k [ 2.230729] CPUidle arm: Failed to register cpuidle driver [ 2.235845] sdhci: Secure Digital Host Controller Interface driver [ 2.241841] sdhci: Copyright(c) Pierre Ossman [ 2.246165] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.253008] ledtrig-cpu: registered to indicate activity on CPUs [ 2.257893] usbcore: registered new interface driver usbhid [ 2.263295] usbhid: USB HID core driver [ 2.270575] ad9528 spi1.0: spi1.0 supply vcc not found, using dummy regulator [ 2.297354] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using GTH4 at 0x84A60000 mapped to 0xffffff80092c5000. Number of lanes: 2. [ 2.306238] axi_adxcvr 84a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using GTH4 at 0x84A50000 mapped to 0xffffff80092cd000. Number of lanes: 2. [ 2.318384] axi_adxcvr 84a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using GTH4 at 0x84A80000 mapped to 0xffffff80092d5000. Number of lanes: 4. [ 2.332417] axi_sysid 85000000.axi-sysid-0: [adrv9009] on [zcu102] git <2e4ac278eb09c13471e381459b0da790ebad8373> clean [2019-12-05 00:50:41] UTC [ 2.344232] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered [ 2.351088] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 2.358009] Netfilter messages via NETLINK v0.30. [ 2.362626] ip_tables: (C) 2000-2006 Netfilter Core Team [ 2.367912] Initializing XFRM netlink socket [ 2.372082] NET: Registered protocol family 10 [ 2.376835] Segment Routing with IPv6 [ 2.380112] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 2.385551] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.391616] NET: Registered protocol family 17 [ 2.395741] NET: Registered protocol family 15 [ 2.400153] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 2.413033] Ebtables v2.0 registered [ 2.416655] can: controller area network core (rev 20170425 abi 9) [ 2.422755] NET: Registered protocol family 29 [ 2.427141] can: raw protocol (rev 20170425) [ 2.431373] can: broadcast manager protocol (rev 20170425 t) [ 2.436998] can: netlink gateway (rev 20170425) max_hops=1 [ 2.442495] Bluetooth: RFCOMM TTY layer initialized [ 2.447295] Bluetooth: RFCOMM socket layer initialized [ 2.452400] Bluetooth: RFCOMM ver 1.11 [ 2.456117] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.461390] Bluetooth: BNEP filters: protocol multicast [ 2.466586] Bluetooth: BNEP socket layer initialized [ 2.471513] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.477397] Bluetooth: HIDP socket layer initialized [ 2.482427] 9pnet: Installing 9P2000 support [ 2.486578] Key type dns_resolver registered [ 2.491247] registered taskstats version 1 [ 2.495176] Btrfs loaded, crc32c=crc32c-generic 2.513916] console [ttyPS0] enabled0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps [ 2.513916] console [ttyPS0] enabled [ 2.517494] bootconsole [cdns0] disabled [ 2.517494] bootconsole [cdns0] disabled [ 2.525484] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps [ 2.539496] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes [ 2.547656] PLL: shutdown [ 2.551983] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div1, ret = -13 [ 2.560522] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed [ 2.571193] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed [ 2.579235] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed [ 2.587593] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok [ 2.600030] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok [ 2.612660] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed [ 2.622825] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000 [ 2.629811] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.636416] [drm] No driver support for vblank timestamp query. [ 2.642375] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008b32030) [ 2.681103] [drm] Cannot find any crtc or sizes [ 2.685806] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0 [ 2.693900] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed [ 2.702845] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes [ 2.710726] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode [ 2.719681] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst [ 2.730017] scsi host0: ahci-ceva [ 2.733493] scsi host1: ahci-ceva [ 2.736907] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37 [ 2.744817] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37 [ 2.754511] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes [ 2.762600] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 2.768092] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 2.775973] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010810 [ 2.784688] xhci-hcd xhci-hcd.0.auto: irq 52, io mem 0xfe200000 [ 2.790708] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.797497] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.804714] usb usb1: Product: xHCI Host Controller [ 2.809583] usb usb1: Manufacturer: Linux 4.14.0-g8a57ede xhci-hcd [ 2.815755] usb usb1: SerialNumber: xhci-hcd.0.auto [ 2.820896] hub 1-0:1.0: USB hub found [ 2.824657] hub 1-0:1.0: 1 port detected [ 2.828743] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 2.834230] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 2.841993] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 2.848773] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.855984] usb usb2: Product: xHCI Host Controller [ 2.860853] usb usb2: Manufacturer: Linux 4.14.0-g8a57ede xhci-hcd [ 2.867027] usb usb2: SerialNumber: xhci-hcd.0.auto [ 2.872130] hub 2-0:1.0: USB hub found [ 2.875891] hub 2-0:1.0: 1 port detected [ 2.880867] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator [ 2.891078] GPIO line 496 (sel0) hogged as output/low [ 2.896456] GPIO line 497 (sel1) hogged as output/high [ 2.901917] GPIO line 498 (sel2) hogged as output/high [ 2.907377] GPIO line 499 (sel3) hogged as output/high [ 2.912606] pca953x 0-0020: interrupt support not compiled in [ 2.918449] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator [ 2.928374] pca953x 0-0021: interrupt support not compiled in [ 2.934909] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.941676] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.948454] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.955224] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.961993] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.968759] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.975525] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.982300] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.989066] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm) [ 2.995839] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm) [ 3.002220] i2c i2c-0: Added multiplexed i2c bus 3 [ 3.007610] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm) [ 3.014387] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm) [ 3.021161] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm) [ 3.027933] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm) [ 3.034705] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm) [ 3.041473] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 3.048241] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm) [ 3.055015] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm) [ 3.061397] i2c i2c-0: Added multiplexed i2c bus 4 [ 3.067974] ata1: SATA link down (SStatus 0 SControl 330) [ 3.073392] ata2: SATA link down (SStatus 0 SControl 330) [ 3.107970] i2c i2c-0: Added multiplexed i2c bus 5 [ 3.112878] i2c i2c-0: Added multiplexed i2c bus 6 [ 3.117663] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544 [ 3.124994] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 25 [ 3.132564] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write [ 3.139287] i2c i2c-1: Added multiplexed i2c bus 7 [ 3.144270] i2c i2c-1: Added multiplexed i2c bus 8 [ 3.151127] si570 9-005d: registered, current frequency 300000000 Hz [ 3.157501] i2c i2c-1: Added multiplexed i2c bus 9 [ 3.176256] si570 10-005d: registered, current frequency 148500000 Hz [ 3.182719] i2c i2c-1: Added multiplexed i2c bus 10 [ 3.187791] i2c i2c-1: Added multiplexed i2c bus 11 [ 3.192781] i2c i2c-1: Added multiplexed i2c bus 12 [ 3.197780] i2c i2c-1: Added multiplexed i2c bus 13 [ 3.202764] i2c i2c-1: Added multiplexed i2c bus 14 [ 3.207640] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548 [ 3.215514] i2c i2c-1: Added multiplexed i2c bus 15 [ 3.221626] at24 16-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write [ 3.228352] i2c i2c-1: Added multiplexed i2c bus 16 [ 3.233344] i2c i2c-1: Added multiplexed i2c bus 17 [ 3.238335] i2c i2c-1: Added multiplexed i2c bus 18 [ 3.243325] i2c i2c-1: Added multiplexed i2c bus 19 [ 3.248325] i2c i2c-1: Added multiplexed i2c bus 20 [ 3.253317] i2c i2c-1: Added multiplexed i2c bus 21 [ 3.258310] i2c i2c-1: Added multiplexed i2c bus 22 [ 3.263187] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548 [ 3.270773] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 26 [ 3.321787] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit [ 3.335739] adrv9009 spi1.1: adrv9009_probe : enter [ 3.343498] adrv9009 spi1.1: ADIHAL_resetHw at index [ 3.388172] mmc0: new SDHC card at address aaaa [ 3.392864] mmcblk0: mmc0:aaaa SM16G 14.8 GiB [ 3.400371] mmcblk0: p1 p2 p3 [ 3.841539] random: crng init done [ 10.832758] axi_adxcvr 84a60000.axi-adxcvr-rx: RX Error: 0 [ 10.838250] adrv9009 spi1.1: jesd_rx_clk enable failed (-5) [ 10.843839] ------------[ cut here ]------------ [ 10.848450] WARNING: CPU: 2 PID: 437 at drivers/clk/clk.c:622 clk_core_disable+0x78/0x80 [ 10.856523] Modules linked in: [ 10.859566] CPU: 2 PID: 437 Comm: kworker/2:1 Not tainted 4.14.0-g8a57ede #653 [ 10.866775] Hardware name: ZynqMP ZCU102 Rev1.0 (DT) [ 10.871729] Workqueue: events deferred_probe_work_func [ 10.876855] task: ffffffc87b392e00 task.stack: ffffff8009be0000 [ 10.882759] PC is at clk_core_disable+0x78/0x80 [ 10.887273] LR is at clk_core_disable_lock+0x20/0x38 [ 10.892220] pc : [<ffffff80084a3220>] lr : [<ffffff80084a3248>] pstate: 800000c5 [ 10.899598] sp : ffffff8009be3ab0 [ 10.902897] x29: ffffff8009be3ab0 x28: ffffffc87a5b0a86 [ 10.908192] x27: 00000000000e5def x26: 0000000000000007 [ 10.913487] x25: 0000000000000003 x24: 0000000000000004 [ 10.918782] x23: 0000000000000004 x22: ffffffc87a5b3848 [ 10.924078] x21: 00000000fffffffb x20: ffffffc87ae1ff00 [ 10.929373] x19: 0000000000000040 x18: 0000000000000010 [ 10.934668] x17: 0000000000000007 x16: ffffff8008a88630 [ 10.939964] x15: ffffffffffffffff x14: ffffff8089022927 [ 10.945259] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0 [ 10.950555] x11: 0000000005f5e0ff x10: 0000000000000006 [ 10.955850] x9 : 00000000ffffffd0 x8 : 616e65206b6c635f [ 10.961145] x7 : 78725f6473656a20 x6 : 0000000000000190 [ 10.966440] x5 : 0000000000000064 x4 : 0000000000000000 [ 10.971736] x3 : 0000000000000000 x2 : 00000000005b005a [ 10.977031] x1 : 0000000000000000 x0 : ffffffc87ae1ff00 [ 10.982327] Call trace: [ 10.984759] Exception stack(0xffffff8009be3970 to 0xffffff8009be3ab0) [ 10.991183] 3960: ffffffc87ae1ff00 0000000000000000 [ 10.998996] 3980: 00000000005b005a 0000000000000000 0000000000000000 0000000000000064 [ 11.006809] 39a0: 0000000000000190 78725f6473656a20 616e65206b6c635f 00000000ffffffd0 [ 11.014622] 39c0: 0000000000000006 0000000005f5e0ff ffffff80084ef8e0 ffffff8008f68aa0 [ 11.022434] 39e0: ffffff8089022927 ffffffffffffffff ffffff8008a88630 0000000000000007 [ 11.030247] 3a00: 0000000000000010 0000000000000040 ffffffc87ae1ff00 00000000fffffffb [ 11.038060] 3a20: ffffffc87a5b3848 0000000000000004 0000000000000004 0000000000000003 [ 11.045873] 3a40: 0000000000000007 00000000000e5def ffffffc87a5b0a86 ffffff8009be3ab0 [ 11.053686] 3a60: ffffff80084a3248 ffffff8009be3ab0 ffffff80084a3220 00000000800000c5 [ 11.061499] 3a80: ffffff8009be3a90 ffffff800854b05c ffffffffffffffff ffffff80087a2b44 [ 11.069310] 3aa0: ffffff8009be3ab0 ffffff80084a3220 [ 11.074173] [<ffffff80084a3220>] clk_core_disable+0x78/0x80 [ 11.079728] [<ffffff80084a3248>] clk_core_disable_lock+0x20/0x38 [ 11.085718] [<ffffff80084a327c>] clk_disable+0x1c/0x28 [ 11.090841] [<ffffff80087a1f70>] adrv9009_setup+0x478/0x11f0 [ 11.096491] [<ffffff80087a56d4>] adrv9009_probe+0x29ec/0x2f30 [ 11.102222] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8 [ 11.107525] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8 [ 11.113515] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0 [ 11.119591] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98 [ 11.125147] [<ffffff800854f238>] __device_attach+0xc0/0x130 [ 11.130702] [<ffffff800854f840>] device_initial_probe+0x10/0x18 [ 11.136605] [<ffffff800854e720>] bus_probe_device+0x90/0x98 [ 11.142161] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148 [ 11.148500] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338 [ 11.154236] [<ffffff80080b1dc0>] worker_thread+0x248/0x488 [ 11.159705] [<ffffff80080b7754>] kthread+0x12c/0x130 [ 11.164654] [<ffffff8008084a60>] ret_from_fork+0x10/0x18 [ 11.169947] ---[ end trace 31b837b9ae426653 ]--- [ 11.174587] ------------[ cut here ]------------ [ 11.179195] WARNING: CPU: 2 PID: 437 at drivers/clk/clk.c:504 clk_core_unprepare+0x80/0x90 [ 11.187446] Modules linked in: [ 11.190488] CPU: 2 PID: 437 Comm: kworker/2:1 Tainted: G W 4.14.0-g8a57ede #653 [ 11.198906] Hardware name: ZynqMP ZCU102 Rev1.0 (DT) [ 11.203856] Workqueue: events deferred_probe_work_func [ 11.208985] task: ffffffc87b392e00 task.stack: ffffff8009be0000 [ 11.214889] PC is at clk_core_unprepare+0x80/0x90 [ 11.219576] LR is at clk_unprepare+0x28/0x40 [ 11.223829] pc : [<ffffff80084a3108>] lr : [<ffffff80084a3a38>] pstate: 60000045 [ 11.231207] sp : ffffff8009be3ac0 [ 11.234506] x29: ffffff8009be3ac0 x28: ffffffc87a5b0a86 [ 11.239801] x27: 00000000000e5def x26: 0000000000000007 [ 11.245096] x25: 0000000000000003 x24: 0000000000000004 [ 11.250392] x23: 0000000000000004 x22: ffffffc87a5b3848 [ 11.255687] x21: 00000000fffffffb x20: ffffffc87a9b8680 [ 11.260983] x19: ffffffc87ae1ff00 x18: 0000000000000010 [ 11.266278] x17: 0000000000000007 x16: ffffff8008a88630 [ 11.271573] x15: ffffffffffffffff x14: ffffff8089022927 [ 11.276868] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0 [ 11.282164] x11: 0000000005f5e0ff x10: 0000000000000006 [ 11.287459] x9 : 00000000ffffffd0 x8 : 616e65206b6c635f [ 11.292754] x7 : 78725f6473656a20 x6 : 0000000000000190 [ 11.298050] x5 : 0000000000000000 x4 : ffffffc87b392e00 [ 11.303345] x3 : 0000000000000000 x2 : ffffffc87b392e00 [ 11.308640] x1 : 0000000000000000 x0 : ffffffc87ae1ff00 [ 11.313935] Call trace: [ 11.316368] Exception stack(0xffffff8009be3980 to 0xffffff8009be3ac0) [ 11.322793] 3980: ffffffc87ae1ff00 0000000000000000 ffffffc87b392e00 0000000000000000 [ 11.330605] 39a0: ffffffc87b392e00 0000000000000000 0000000000000190 78725f6473656a20 [ 11.338418] 39c0: 616e65206b6c635f 00000000ffffffd0 0000000000000006 0000000005f5e0ff [ 11.346231] 39e0: ffffff80084ef8e0 ffffff8008f68aa0 ffffff8089022927 ffffffffffffffff [ 11.354044] 3a00: ffffff8008a88630 0000000000000007 0000000000000010 ffffffc87ae1ff00 [ 11.361856] 3a20: ffffffc87a9b8680 00000000fffffffb ffffffc87a5b3848 0000000000000004 [ 11.369669] 3a40: 0000000000000004 0000000000000003 0000000000000007 00000000000e5def [ 11.377482] 3a60: ffffffc87a5b0a86 ffffff8009be3ac0 ffffff80084a3a38 ffffff8009be3ac0 [ 11.385295] 3a80: ffffff80084a3108 0000000060000045 ffffffffffffffff ffffff80087a2b44 [ 11.393108] 3aa0: ffffffffffffffff ffffff80084a3220 ffffff8009be3ac0 ffffff80084a3108 [ 11.400920] [<ffffff80084a3108>] clk_core_unprepare+0x80/0x90 [ 11.406650] [<ffffff80084a3a38>] clk_unprepare+0x28/0x40 [ 11.411945] [<ffffff80087a1f78>] adrv9009_setup+0x480/0x11f0 [ 11.417587] [<ffffff80087a56d4>] adrv9009_probe+0x29ec/0x2f30 [ 11.423317] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8 [ 11.428613] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8 [ 11.434602] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0 [ 11.440679] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98 [ 11.446235] [<ffffff800854f238>] __device_attach+0xc0/0x130 [ 11.451790] [<ffffff800854f840>] device_initial_probe+0x10/0x18 [ 11.457693] [<ffffff800854e720>] bus_probe_device+0x90/0x98 [ 11.463249] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148 [ 11.469586] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338 [ 11.475315] [<ffffff80080b1dc0>] worker_thread+0x248/0x488 [ 11.480784] [<ffffff80080b7754>] kthread+0x12c/0x130 [ 11.485732] [<ffffff8008084a60>] ret_from_fork+0x10/0x18 [ 11.491026] ---[ end trace 31b837b9ae426654 ]--- [ 11.495730] adrv9009 spi1.1: ADIHAL_resetHw at index [ 18.982628] axi_adxcvr 84a60000.axi-adxcvr-rx: RX Error: 0 [ 18.988115] adrv9009 spi1.1: jesd_rx_clk enable failed (-5) [ 18.993702] ------------[ cut here ]------------ [ 18.998305] WARNING: CPU: 2 PID: 437 at drivers/clk/clk.c:622 clk_core_disable+0x78/0x80 [ 19.006382] Modules linked in: [ 19.009423] CPU: 2 PID: 437 Comm: kworker/2:1 Tainted: G W 4.14.0-g8a57ede #653 [ 19.017841] Hardware name: ZynqMP ZCU102 Rev1.0 (DT) [ 19.022792] Workqueue: events deferred_probe_work_func [ 19.027920] task: ffffffc87b392e00 task.stack: ffffff8009be0000 [ 19.033825] PC is at clk_core_disable+0x78/0x80 [ 19.038339] LR is at clk_core_disable_lock+0x20/0x38 [ 19.043286] pc : [<ffffff80084a3220>] lr : [<ffffff80084a3248>] pstate: 800000c5 [ 19.050663] sp : ffffff8009be3ab0 [ 19.053962] x29: ffffff8009be3ab0 x28: ffffffc87a5b0a86 [ 19.059258] x27: 00000000000e5def x26: 0000000000000007 [ 19.064553] x25: 0000000000000003 x24: 0000000000000004 [ 19.069848] x23: 0000000000000004 x22: ffffffc87a5b3848 [ 19.075143] x21: 00000000fffffffb x20: ffffffc87ae1ff00 [ 19.080439] x19: 0000000000000040 x18: 0000000000000010 [ 19.085734] x17: 0000000000000007 x16: ffffff8008a88630 [ 19.091030] x15: ffffffffffffffff x14: ffffff8089022927 [ 19.096325] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0 [ 19.101620] x11: 0000000005f5e0ff x10: 0000000000000006 [ 19.106915] x9 : 00000000ffffffd0 x8 : 282064656c696166 [ 19.112211] x7 : 20656c62616e6520 x6 : 0000000000000203 [ 19.117506] x5 : 0000000000000064 x4 : 0000000000000000 [ 19.122801] x3 : 0000000000000000 x2 : 00000000005d005c [ 19.128097] x1 : 0000000000000000 x0 : ffffffc87ae1ff00 [ 19.133392] Call trace: [ 19.135824] Exception stack(0xffffff8009be3970 to 0xffffff8009be3ab0) [ 19.142248] 3960: ffffffc87ae1ff00 0000000000000000 [ 19.150061] 3980: 00000000005d005c 0000000000000000 0000000000000000 0000000000000064 [ 19.157874] 39a0: 0000000000000203 20656c62616e6520 282064656c696166 00000000ffffffd0 [ 19.165687] 39c0: 0000000000000006 0000000005f5e0ff ffffff80084ef8e0 ffffff8008f68aa0 [ 19.173500] 39e0: ffffff8089022927 ffffffffffffffff ffffff8008a88630 0000000000000007 [ 19.181313] 3a00: 0000000000000010 0000000000000040 ffffffc87ae1ff00 00000000fffffffb [ 19.189125] 3a20: ffffffc87a5b3848 0000000000000004 0000000000000004 0000000000000003 [ 19.196938] 3a40: 0000000000000007 00000000000e5def ffffffc87a5b0a86 ffffff8009be3ab0 [ 19.204751] 3a60: ffffff80084a3248 ffffff8009be3ab0 ffffff80084a3220 00000000800000c5 [ 19.212564] 3a80: ffffff8009be3a90 ffffff800854b05c ffffffffffffffff ffffff80087a2b44 [ 19.220376] 3aa0: ffffff8009be3ab0 ffffff80084a3220 [ 19.225238] [<ffffff80084a3220>] clk_core_disable+0x78/0x80 [ 19.230794] [<ffffff80084a3248>] clk_core_disable_lock+0x20/0x38 [ 19.236783] [<ffffff80084a327c>] clk_disable+0x1c/0x28 [ 19.241905] [<ffffff80087a1f70>] adrv9009_setup+0x478/0x11f0 [ 19.247547] [<ffffff80087a596c>] adrv9009_probe+0x2c84/0x2f30 [ 19.253278] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8 [ 19.258573] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8 [ 19.264563] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0 [ 19.270639] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98 [ 19.276195] [<ffffff800854f238>] __device_attach+0xc0/0x130 [ 19.281751] [<ffffff800854f840>] device_initial_probe+0x10/0x18 [ 19.287653] [<ffffff800854e720>] bus_probe_device+0x90/0x98 [ 19.293209] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148 [ 19.299547] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338 [ 19.305276] [<ffffff80080b1dc0>] worker_thread+0x248/0x488 [ 19.310744] [<ffffff80080b7754>] kthread+0x12c/0x130 [ 19.315693] [<ffffff8008084a60>] ret_from_fork+0x10/0x18 [ 19.320986] ---[ end trace 31b837b9ae426655 ]--- [ 19.325621] ------------[ cut here ]------------ [ 19.330226] WARNING: CPU: 2 PID: 437 at drivers/clk/clk.c:504 clk_core_unprepare+0x80/0x90 [ 19.338477] Modules linked in: [ 19.341518] CPU: 2 PID: 437 Comm: kworker/2:1 Tainted: G W 4.14.0-g8a57ede #653 [ 19.349936] Hardware name: ZynqMP ZCU102 Rev1.0 (DT) [ 19.354887] Workqueue: events deferred_probe_work_func [ 19.360015] task: ffffffc87b392e00 task.stack: ffffff8009be0000 [ 19.365920] PC is at clk_core_unprepare+0x80/0x90 [ 19.370607] LR is at clk_unprepare+0x28/0x40 [ 19.374860] pc : [<ffffff80084a3108>] lr : [<ffffff80084a3a38>] pstate: 60000045 [ 19.382238] sp : ffffff8009be3ac0 [ 19.385537] x29: ffffff8009be3ac0 x28: ffffffc87a5b0a86 [ 19.390832] x27: 00000000000e5def x26: 0000000000000007 [ 19.396127] x25: 0000000000000003 x24: 0000000000000004 [ 19.401422] x23: 0000000000000004 x22: ffffffc87a5b3848 [ 19.406718] x21: 00000000fffffffb x20: ffffffc87a9b8680 [ 19.412013] x19: ffffffc87ae1ff00 x18: 0000000000000010 [ 19.417308] x17: 0000000000000007 x16: ffffff8008a88630 [ 19.422604] x15: ffffffffffffffff x14: ffffff8089022927 [ 19.427899] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0 [ 19.433194] x11: 0000000005f5e0ff x10: 0000000000000006 [ 19.438490] x9 : 00000000ffffffd0 x8 : 282064656c696166 [ 19.443785] x7 : 20656c62616e6520 x6 : 0000000000000203 [ 19.449080] x5 : 0000000000000000 x4 : ffffffc87b392e00 [ 19.454376] x3 : 0000000000000000 x2 : ffffffc87b392e00 [ 19.459671] x1 : 0000000000000000 x0 : ffffffc87ae1ff00 [ 19.464966] Call trace: [ 19.467398] Exception stack(0xffffff8009be3980 to 0xffffff8009be3ac0) [ 19.473823] 3980: ffffffc87ae1ff00 0000000000000000 ffffffc87b392e00 0000000000000000 [ 19.481636] 39a0: ffffffc87b392e00 0000000000000000 0000000000000203 20656c62616e6520 [ 19.489449] 39c0: 282064656c696166 00000000ffffffd0 0000000000000006 0000000005f5e0ff [ 19.497262] 39e0: ffffff80084ef8e0 ffffff8008f68aa0 ffffff8089022927 ffffffffffffffff [ 19.505074] 3a00: ffffff8008a88630 0000000000000007 0000000000000010 ffffffc87ae1ff00 [ 19.512887] 3a20: ffffffc87a9b8680 00000000fffffffb ffffffc87a5b3848 0000000000000004 [ 19.520700] 3a40: 0000000000000004 0000000000000003 0000000000000007 00000000000e5def [ 19.528513] 3a60: ffffffc87a5b0a86 ffffff8009be3ac0 ffffff80084a3a38 ffffff8009be3ac0 [ 19.536325] 3a80: ffffff80084a3108 0000000060000045 ffffffffffffffff ffffff80087a2b44 [ 19.544138] 3aa0: ffffffffffffffff ffffff80084a3220 ffffff8009be3ac0 ffffff80084a3108 [ 19.551951] [<ffffff80084a3108>] clk_core_unprepare+0x80/0x90 [ 19.557680] [<ffffff80084a3a38>] clk_unprepare+0x28/0x40 [ 19.562975] [<ffffff80087a1f78>] adrv9009_setup+0x480/0x11f0 [ 19.568618] [<ffffff80087a596c>] adrv9009_probe+0x2c84/0x2f30 [ 19.574348] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8 [ 19.579643] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8 [ 19.585633] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0 [ 19.591709] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98 [ 19.597265] [<ffffff800854f238>] __device_attach+0xc0/0x130 [ 19.602821] [<ffffff800854f840>] device_initial_probe+0x10/0x18 [ 19.608724] [<ffffff800854e720>] bus_probe_device+0x90/0x98 [ 19.614280] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148 [ 19.620617] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338 [ 19.626346] [<ffffff80080b1dc0>] worker_thread+0x248/0x488 [ 19.631814] [<ffffff80080b7754>] kthread+0x12c/0x130 [ 19.636763] [<ffffff8008084a60>] ret_from_fork+0x10/0x18 [ 19.642056] ---[ end trace 31b837b9ae426656 ]--- [ 19.646699] adrv9009: probe of spi1.1 failed with error -5 [ 19.653932] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 19.660879] rtc_zynqmp ffa60000.rtc: setting system clock to 2022-12-22 00:00:10 UTC (1671667210) [ 19.669984] PLL: shutdown [ 19.672599] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13 [ 19.680659] ALSA device list: [ 19.683619] #0: DisplayPort monitor [ 22.643373] EXT4-fs (mmcblk0p2): recovery complete [ 22.649387] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 22.657498] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 22.666093] devtmpfs: mounted [ 22.669157] Freeing unused kernel memory: 512K Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory * Setting up X socket directories... [ OK ] * STARTDISTCC is set to false in /etc/default/distcc * /usr/bin/distccd not starting * Starting IIO Daemon iiod [ OK ] Last login: Wed Dec 21 22:26:36 UTC 2022 on ttyPS0 Welcome to Linaro 14.04 (GNU/Linux 4.14.0-g8a57ede aarch64) * Documentation: https://wiki.analog.com/ https://ez.analog.com/ New release '16.04.7 LTS' available. Run 'do-release-upgrade' to upgrade to it. root@analog:~#
This is not from 2021-R1. Can you provide the stack trace from that board? And restart IIO-Scope and try to connect?
-Travis
I provide the log of the ADI Image Linux (last one dated July 28, 2021).
I restart IIO-Scope and I still have the same problem.
Release 2019.1 Jul 27 2021 - 12:54:49
NOTICE: BL31: v2.0(release):xilinx-v2019.2
NOTICE: BL31: Built : 10:19:24, Jan 13 2020
PMUFW: v1.1
U-Boot 2018.01-21436-gbba91bc203 (Jan 13 2020 - 10:50:58 +0200) Xilinx ZynqMP ZCU102 rev1.0, Build: jenkins-development-build_uboot-1
I2C: ready
DRAM: 4 GiB
EL Level: EL2
Chip ID: zu9eg
In: serial@ff000000
Warning: ethernet@ff0e0000 (eth0) using random MAC address - 8a:ec:71:f4:84:0b
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
reading uEnv.txt
407 bytes read in 16 ms (24.4 KiB/s)
Running uenvcmd ...
reading system.dtb
59759 bytes read in 27 ms (2.1 MiB/s)
reading Image
29540864 bytes read in 1967 ms (14.3 MiB/s)
Loading Device Tree to 000000000ffee000, end 000000000ffff96e ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.0-g17f4223 (jenkins@romlxbuild1.adlk.analog.com) (gcc version 8.2.0 (GCC)) #1849 SMP Tue Jul 27 13:12:14 IST 2021
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
[ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52504 r8192 d29416 u90112
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait clk_ignore_unused cpuidle.off=1 root=/dev/mmcblk0p2 rw rootwait
[ 0.000000] software IO TLB: mapped [mem 0x6bfff000-0x6ffff000] (64MB)
[ 0.000000] Memory: 3772480K/4194304K available (12860K kernel code, 1520K rwdata, 13580K rodata, 832K init, 330K bss, 159680K reserved, 262144K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.008266] Console: colour dummy device 80x25
[ 0.012392] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[ 0.027449] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.034011] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.041788] ASID allocator initialised with 32768 entries
[ 0.046508] rcu: Hierarchical SRCU implementation.
[ 0.051553] EFI services will not be available.
[ 0.055828] smp: Bringing up secondary CPUs ...
[ 0.060485] Detected VIPT I-cache on CPU1
[ 0.060514] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.060822] Detected VIPT I-cache on CPU2
[ 0.060841] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.061125] Detected VIPT I-cache on CPU3
[ 0.061145] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.061188] smp: Brought up 1 node, 4 CPUs
[ 0.095681] SMP: Total of 4 processors activated.
[ 0.100355] CPU features: detected: 32-bit EL0 Support
[ 0.106780] CPU: All CPU(s) started at EL2
[ 0.109534] alternatives: patching kernel code
[ 0.114842] devtmpfs: initialized
[ 0.123494] Registered cp15_barrier emulation handler
[ 0.123543] Registered setend emulation handler
[ 0.127516] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.137103] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.148790] xor: measuring software checksum speed
[ 0.187305] 8regs : 2375.000 MB/sec
[ 0.227334] 8regs_prefetch: 2052.000 MB/sec
[ 0.267365] 32regs : 2724.000 MB/sec
[ 0.307394] 32regs_prefetch: 2308.000 MB/sec
[ 0.307435] xor: using function: 32regs (2724.000 MB/sec)
[ 0.311743] pinctrl core: initialized pinctrl subsystem
[ 0.317542] NET: Registered protocol family 16
[ 0.321742] audit: initializing netlink subsys (disabled)
[ 0.326767] audit: type=2000 audit(0.272:1): state=initialized audit_enabled=0 res=1
[ 0.334403] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.334410] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.349175] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.368875] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.437074] raid6: int64x1 gen() 444 MB/s
[ 0.505177] raid6: int64x1 xor() 452 MB/s
[ 0.573228] raid6: int64x2 gen() 679 MB/s
[ 0.641210] raid6: int64x2 xor() 599 MB/s
[ 0.709250] raid6: int64x4 gen() 980 MB/s
[ 0.777304] raid6: int64x4 xor() 737 MB/s
[ 0.845366] raid6: int64x8 gen() 1162 MB/s
[ 0.913402] raid6: int64x8 xor() 759 MB/s
[ 0.981489] raid6: neonx1 gen() 736 MB/s
[ 1.049489] raid6: neonx1 xor() 880 MB/s
[ 1.117540] raid6: neonx2 gen() 1129 MB/s
[ 1.185569] raid6: neonx2 xor() 1173 MB/s
[ 1.253649] raid6: neonx4 gen() 1479 MB/s
[ 1.321656] raid6: neonx4 xor() 1418 MB/s
[ 1.389726] raid6: neonx8 gen() 1551 MB/s
[ 1.457761] raid6: neonx8 xor() 1459 MB/s
[ 1.457799] raid6: using algorithm neonx8 gen() 1551 MB/s
[ 1.461757] raid6: .... xor() 1459 MB/s, rmw enabled
[ 1.466690] raid6: using neon recovery algorithm
[ 1.472069] SCSI subsystem initialized
[ 1.475161] usbcore: registered new interface driver usbfs
[ 1.480474] usbcore: registered new interface driver hub
[ 1.485758] usbcore: registered new device driver usb
[ 1.490908] media: Linux media interface: v0.10
[ 1.495260] videodev: Linux video capture interface: v2.00
[ 1.500733] pps_core: LinuxPPS API ver. 1 registered
[ 1.505617] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.514711] PTP clock support registered
[ 1.518610] EDAC MC: Ver: 3.0.0
[ 1.522119] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[ 1.529474] jesd204: created con: id=0, topo=0, link=0, /amba/spi@ff040000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-tx@84a80000
[ 1.540143] jesd204: created con: id=1, topo=0, link=2, /amba/spi@ff040000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-rx-os@84a50000
[ 1.551562] jesd204: created con: id=2, topo=0, link=1, /amba/spi@ff040000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-rx@84a60000
[ 1.562719] jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcvr-rx-os@84a50000 <-> /fpga-axi@0/axi-jesd204-rx-os@84ab0000
[ 1.574916] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-adxcvr-tx@84a80000 <-> /fpga-axi@0/axi-jesd204-tx@84a90000
[ 1.586594] jesd204: created con: id=5, topo=0, link=1, /fpga-axi@0/axi-adxcvr-rx@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84aa0000
[ 1.598273] jesd204: created con: id=6, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@84a90000 <-> /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000
[ 1.610489] jesd204: created con: id=7, topo=0, link=1, /fpga-axi@0/axi-jesd204-rx@84aa0000 <-> /amba/spi@ff040000/adrv9009-phy@1
[ 1.622070] jesd204: created con: id=8, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx-os@84ab0000 <-> /amba/spi@ff040000/adrv9009-phy@1
[ 1.633923] jesd204: created con: id=9, topo=0, link=0, /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000 <-> /amba/spi@ff040000/adrv9009-phy@1
[ 1.645950] jesd204: /amba/spi@ff040000/adrv9009-phy@1: JESD204[0] transition uninitialized -> initialized
[ 1.655537] jesd204: /amba/spi@ff040000/adrv9009-phy@1: JESD204[1] transition uninitialized -> initialized
[ 1.665139] jesd204: /amba/spi@ff040000/adrv9009-phy@1: JESD204[2] transition uninitialized -> initialized
[ 1.674741] jesd204: found 9 devices and 1 topologies
[ 1.679793] FPGA manager framework
[ 1.683309] Advanced Linux Sound Architecture Driver Initialized.
[ 1.689464] Bluetooth: Core ver 2.22
[ 1.692751] NET: Registered protocol family 31
[ 1.697148] Bluetooth: HCI device and connection manager initialized
[ 1.703465] Bluetooth: HCI socket layer initialized
[ 1.708307] Bluetooth: L2CAP socket layer initialized
[ 1.713339] Bluetooth: SCO socket layer initialized
[ 1.718726] clocksource: Switched to clocksource arch_sys_counter
[ 1.724328] VFS: Disk quotas dquot_6.6.0
[ 1.728159] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.739229] NET: Registered protocol family 2
[ 1.739603] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 1.747119] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.754445] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.761221] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.767375] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.773348] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.779825] NET: Registered protocol family 1
[ 1.784491] RPC: Registered named UNIX socket transport module.
[ 1.789890] RPC: Registered udp transport module.
[ 1.794559] RPC: Registered tcp transport module.
[ 1.799237] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.806434] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.812871] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.821299] Initialise system trusted keyrings
[ 1.824903] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 1.831931] NFS: Registering the id_resolver key type
[ 1.836310] Key type id_resolver registered
[ 1.840408] Key type id_legacy registered
[ 1.844392] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.851060] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 2.940004] NET: Registered protocol family 38
[ 3.001178] Key type asymmetric registered
[ 3.001216] Asymmetric key parser 'x509' registered
[ 3.004521] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 3.011841] io scheduler noop registered
[ 3.015731] io scheduler deadline registered
[ 3.019987] io scheduler cfq registered (default)
[ 3.024642] io scheduler mq-deadline registered
[ 3.029140] io scheduler kyber registered
[ 3.061479] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 3.066179] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 3.072717] brd: module loaded
[ 3.076609] loop: module loaded
[ 3.076835] Registered mathworks_ip class
[ 3.079336] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 3.086346] libphy: Fixed MDIO Bus: probed
[ 3.090011] tun: Universal TUN/TAP device driver, 1.6
[ 3.093981] CAN device driver interface
[ 3.098774] usbcore: registered new interface driver asix
[ 3.103080] usbcore: registered new interface driver ax88179_178a
[ 3.109106] usbcore: registered new interface driver cdc_ether
[ 3.114902] usbcore: registered new interface driver net1080
[ 3.120524] usbcore: registered new interface driver cdc_subset
[ 3.126406] usbcore: registered new interface driver zaurus
[ 3.131954] usbcore: registered new interface driver cdc_ncm
[ 3.138360] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.144034] ehci-pci: EHCI PCI platform driver
[ 3.148748] usbcore: registered new interface driver uas
[ 3.153752] usbcore: registered new interface driver usb-storage
[ 3.159751] usbcore: registered new interface driver usbserial_generic
[ 3.166197] usbserial: USB Serial support registered for generic
[ 3.172168] usbcore: registered new interface driver ftdi_sio
[ 3.177874] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.185144] usbcore: registered new interface driver upd78f0730
[ 3.191023] usbserial: USB Serial support registered for upd78f0730
[ 3.198771] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 3.204486] i2c /dev entries driver
[ 3.210087] usbcore: registered new interface driver uvcvideo
[ 3.213587] USB Video Class driver (1.1.1)
[ 3.219116] Bluetooth: HCI UART driver ver 2.3
[ 3.222058] Bluetooth: HCI UART protocol H4 registered
[ 3.227173] Bluetooth: HCI UART protocol BCSP registered
[ 3.232469] Bluetooth: HCI UART protocol LL registered
[ 3.237548] Bluetooth: HCI UART protocol ATH3K registered
[ 3.242927] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.249182] Bluetooth: HCI UART protocol Intel registered
[ 3.254522] Bluetooth: HCI UART protocol QCA registered
[ 3.259733] usbcore: registered new interface driver bcm203x
[ 3.265347] usbcore: registered new interface driver bpa10x
[ 3.270881] usbcore: registered new interface driver bfusb
[ 3.276331] usbcore: registered new interface driver btusb
[ 3.281754] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 3.287422] usbcore: registered new interface driver ath3k
[ 3.292958] EDAC MC: ECC not enabled
[ 3.296648] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 3.308832] CPUidle arm: Failed to register cpuidle driver
[ 3.314125] sdhci: Secure Digital Host Controller Interface driver
[ 3.320076] sdhci: Copyright(c) Pierre Ossman
[ 3.324402] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.330440] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.336038] zynqmp_firmware_probe Platform Management API v1.1
[ 3.341792] zynqmp_firmware_probe Trustzone version v1.0
[ 3.349864] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[ 3.377352] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[ 3.380077] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 3.385272] zynqmp_aes zynqmp_aes: AES Successfully Registered
[ 3.385272]
[ 3.392724] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 3.398829] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 3.404489] usbcore: registered new interface driver usbhid
[ 3.409728] usbhid: USB HID core driver
[ 3.422148] axi_sysid 85000000.axi-sysid-0: [adrv9009] on [zcu102] git <43c6ae1ca9faf268f30c7ef489f1428fc30a8b23> clean [2021-06-09 20:28:07] UTC
[ 3.429872] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 3.436474] usbcore: registered new interface driver snd-usb-audio
[ 3.444012] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 3.449961] Initializing XFRM netlink socket
[ 3.453899] NET: Registered protocol family 10
[ 3.458617] Segment Routing with IPv6
[ 3.461971] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.468105] NET: Registered protocol family 17
[ 3.472176] NET: Registered protocol family 15
[ 3.476592] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.489916] can: controller area network core (rev 20170425 abi 9)
[ 3.495646] NET: Registered protocol family 29
[ 3.500025] can: raw protocol (rev 20170425)
[ 3.504261] can: broadcast manager protocol (rev 20170425 t)
[ 3.509886] can: netlink gateway (rev 20170425) max_hops=1
[ 3.515423] Bluetooth: RFCOMM TTY layer initialized
[ 3.520185] Bluetooth: RFCOMM socket layer initialized
[ 3.525294] Bluetooth: RFCOMM ver 1.11
[ 3.529007] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.534279] Bluetooth: BNEP filters: protocol multicast
[ 3.539473] Bluetooth: BNEP socket layer initialized
[ 3.544401] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.550285] Bluetooth: HIDP socket layer initialized
[ 3.555318] 9pnet: Installing 9P2000 support
[ 3.559462] NET: Registered protocol family 36
[ 3.563881] Key type dns_resolver registered
[ 3.568649] registered taskstats version 1
[ 3.572174] Loading compiled-in X.509 certificates
[ 3.577269] Btrfs loaded, crc32c=crc32c-generic
[ 3.587956] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps
[ 3.597755] console [ttyPS0] enabled
[ 3.601355] bootconsole [cdns0] disabled
[ 3.609431] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps
[ 3.622811] of-fpga-region fpga-full: FPGA Region probed
[ 3.628653] nwl-pcie fd0e0000.pcie: Link is DOWN
[ 3.633295] nwl-pcie fd0e0000.pcie: host bridge /amba/pcie@fd0e0000 ranges:
[ 3.640266] nwl-pcie fd0e0000.pcie: MEM 0xe0000000..0xefffffff -> 0xe0000000
[ 3.647486] nwl-pcie fd0e0000.pcie: MEM 0x600000000..0x7ffffffff -> 0x600000000
[ 3.655071] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[ 3.661244] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.666727] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[ 3.673596] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[ 3.685781] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[ 3.692937] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[ 3.699527] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 3.706640] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 3.713747] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 3.720858] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 3.727964] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 3.735070] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 3.742176] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 3.749289] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 3.756532] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[ 3.767971] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div1, ret = -13
[ 3.776648] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[ 3.787436] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[ 3.795534] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[ 3.804018] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 3.816460] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 3.829153] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[ 3.839343] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[ 3.846375] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.852987] [drm] No driver support for vblank timestamp query.
[ 3.858971] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008dd2e70)
[ 3.999105] random: fast init done
[ 10.761878] random: crng init done
[ 12.078778] [drm] Cannot find any crtc or sizes
[ 12.083551] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[ 12.091654] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[ 12.100673] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[ 12.108558] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 12.117513] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 12.127969] scsi host0: ahci-ceva
[ 12.131536] scsi host1: ahci-ceva
[ 12.134989] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[ 12.142902] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[ 12.151841] ad9528 spi1.0: spi1.0 supply vcc not found, using dummy regulator
[ 12.159007] ad9528 spi1.0: Linked as a consumer to regulator.0
[ 12.188037] jesd204: /amba/spi@ff040000/ad9528-1@0,jesd204:0,parent=spi1.0: Using as SYSREF provider
[ 12.197509] adrv9009 spi1.1: adrv9009_probe : enter
[ 12.208259] m25p80 spi0.0: SPI-NOR-UniqueID 10440088170200180c001700c5b7ac0ae4
[ 12.215484] m25p80 spi0.0: found n25q512a, expected m25p80
[ 12.221235] m25p80 spi0.0: n25q512a (131072 Kbytes)
[ 12.226127] 4 fixed-partitions partitions found on MTD device spi0.0
[ 12.232476] Creating 4 MTD partitions on "spi0.0":
[ 12.237261] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[ 12.243468] 0x000000100000-0x000000600000 : "qspi-linux"
[ 12.249177] 0x000000600000-0x000000620000 : "qspi-device-tree"
[ 12.255393] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[ 12.263341] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 12.270725] libphy: MACB_mii_bus: probed
[ 12.274710] mdio_bus ff0e0000.ethernet-ffffffff: MDIO device at address 21 is missing.
[ 12.284904] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[ 12.297951] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 22 (8a:ec:71:f4:84:0b)
[ 12.308103] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 12.314657] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 12.321171] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 12.327670] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 12.335524] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[ 12.341371] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[ 12.349627] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 12.355117] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 12.363102] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[ 12.372514] xhci-hcd xhci-hcd.0.auto: irq 52, io mem 0xfe200000
[ 12.378642] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 12.386908] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.394124] usb usb1: Product: xHCI Host Controller
[ 12.398993] usb usb1: Manufacturer: Linux 4.19.0-g17f4223 xhci-hcd
[ 12.405166] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 12.410320] hub 1-0:1.0: USB hub found
[ 12.414094] hub 1-0:1.0: 1 port detected
[ 12.418201] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 12.423690] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 12.431346] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 12.438068] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 12.446327] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.453546] usb usb2: Product: xHCI Host Controller
[ 12.458413] usb usb2: Manufacturer: Linux 4.19.0-g17f4223 xhci-hcd
[ 12.464586] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 12.467885] ata2: SATA link down (SStatus 0 SControl 330)
[ 12.469698] hub 2-0:1.0: USB hub found
[ 12.474867] ata1: SATA link down (SStatus 0 SControl 330)
[ 12.478595] hub 2-0:1.0: 1 port detected
[ 12.489174] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[ 12.496432] pca953x 0-0020: Linked as a consumer to regulator.0
[ 12.503226] GPIO line 496 (sel0) hogged as output/low
[ 12.508605] GPIO line 497 (sel1) hogged as output/high
[ 12.514068] GPIO line 498 (sel2) hogged as output/high
[ 12.519541] GPIO line 499 (sel3) hogged as output/high
[ 12.524884] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator
[ 12.532123] pca953x 0-0021: Linked as a consumer to regulator.0
[ 12.539565] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.546378] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.553188] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.560014] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.566833] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.573657] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.580473] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.587293] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.594105] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.600917] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.607328] i2c i2c-0: Added multiplexed i2c bus 3
[ 12.612799] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[ 12.619615] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.626436] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.633250] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.640074] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.646903] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.653714] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.660533] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 12.666934] i2c i2c-0: Added multiplexed i2c bus 4
[ 12.706556] i2c i2c-0: Added multiplexed i2c bus 5
[ 12.711524] i2c i2c-0: Added multiplexed i2c bus 6
[ 12.716310] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[ 12.723662] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 24
[ 12.731524] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 12.738275] i2c i2c-1: Added multiplexed i2c bus 7
[ 12.743405] i2c i2c-1: Added multiplexed i2c bus 8
[ 12.750317] si570 9-005d: registered, current frequency 300000000 Hz
[ 12.756713] i2c i2c-1: Added multiplexed i2c bus 9
[ 12.775530] si570 10-005d: registered, current frequency 148500000 Hz
[ 12.782019] i2c i2c-1: Added multiplexed i2c bus 10
[ 12.787118] si5324 11-0069: si5328 probed
[ 12.850808] si5324 11-0069: si5328 probe successful
[ 12.855730] i2c i2c-1: Added multiplexed i2c bus 11
[ 12.860774] i2c i2c-1: Added multiplexed i2c bus 12
[ 12.865810] i2c i2c-1: Added multiplexed i2c bus 13
[ 12.870864] i2c i2c-1: Added multiplexed i2c bus 14
[ 12.875743] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[ 12.883711] i2c i2c-1: Added multiplexed i2c bus 15
[ 12.889999] at24 16-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 12.896744] i2c i2c-1: Added multiplexed i2c bus 16
[ 12.901792] i2c i2c-1: Added multiplexed i2c bus 17
[ 12.906844] i2c i2c-1: Added multiplexed i2c bus 18
[ 12.911889] i2c i2c-1: Added multiplexed i2c bus 19
[ 12.916937] i2c i2c-1: Added multiplexed i2c bus 20
[ 12.921983] i2c i2c-1: Added multiplexed i2c bus 21
[ 12.927028] i2c i2c-1: Added multiplexed i2c bus 22
[ 12.931908] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[ 12.939520] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 25
[ 12.945917] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[ 12.985763] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[ 13.020088] cf_axi_adc 84a00000.axi-adrv9009-rx-hpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0x000000003c9597c5, probed ADC ADRV9009 as MASTER
[ 13.051133] cf_axi_dds 84a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x0000000091daaf2c, probed DDS AD9371
[ 13.067525] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 2.
[ 13.080897] axi_adxcvr 84a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using CPLL on GTH4 at 0x84A50000. Number of lanes: 2.
[ 13.093183] axi_adxcvr 84a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using QPLL on GTH4 at 0x84A80000. Number of lanes: 4.
[ 13.107819] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition initialized -> probed
[ 13.118952] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition initialized -> probed
[ 13.130072] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition initialized -> probed
[ 13.141198] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition probed -> idle
[ 13.151716] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition probed -> idle
[ 13.162234] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition probed -> idle
[ 13.172752] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition idle -> device_init
[ 13.183702] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition idle -> device_init
[ 13.194648] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition idle -> device_init
[ 13.205601] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition device_init -> link_init
[ 13.216984] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition device_init -> link_init
[ 13.228364] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition device_init -> link_init
[ 13.239756] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition link_init -> link_supported
[ 13.251404] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition link_init -> link_supported
[ 13.263044] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition link_init -> link_supported
[ 13.274892] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition link_supported -> link_pre_setup
[ 13.286977] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition link_supported -> link_pre_setup
[ 13.299055] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition link_supported -> link_pre_setup
[ 13.311134] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition link_pre_setup -> clk_sync_stage1
[ 13.323299] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition link_pre_setup -> clk_sync_stage1
[ 13.335461] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition link_pre_setup -> clk_sync_stage1
[ 13.347627] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
[ 13.359882] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
[ 13.372129] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
[ 13.384383] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
[ 13.396635] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
[ 13.408883] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
[ 13.523232] axi_adxcvr 84a80000.axi-adxcvr-tx: QPLL TX Error: 0
[ 13.631212] axi_adxcvr 84a80000.axi-adxcvr-tx: QPLL TX Error: 0
[ 13.637136] axi-jesd204-tx 84a90000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_setup: Link0 enable lane clock failed (-5)
[ 13.648173] jesd204: /fpga-axi@0/axi-jesd204-tx@84a90000,jesd204:4,parent=84a90000.axi-jesd204-tx: JESD204[0] got error from cb: -5
[ 13.659987] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: Rolling back from 'clk_sync_stage3', got error -5
[ 13.671631] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition clk_sync_stage3 -> link_setup
[ 13.683451] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition clk_sync_stage3 -> link_setup
[ 13.695265] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition clk_sync_stage3 -> link_setup
[ 13.707084] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition link_setup -> clk_sync_stage3
[ 13.718903] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition link_setup -> clk_sync_stage3
[ 13.730720] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition link_setup -> clk_sync_stage3
[ 13.742536] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
[ 13.754791] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition clk_sync_stage3 -> clk_sync_stage2
[ 13.767038] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
[ 13.779291] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
[ 13.791545] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
[ 13.803793] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
[ 13.816044] adrv9009 spi1.1: ADIHAL_resetHw
[ 13.821275] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
[ 13.833444] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
[ 13.845611] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
[ 13.857792] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition link_pre_setup -> link_supported
[ 13.869874] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition link_pre_setup -> link_supported
[ 13.881957] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition link_pre_setup -> link_supported
[ 13.894038] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition link_supported -> link_init
[ 13.905682] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition link_supported -> link_init
[ 13.917323] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition link_supported -> link_init
[ 13.928972] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition link_init -> device_init
[ 13.940354] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition link_init -> device_init
[ 13.951734] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition link_init -> device_init
[ 13.963118] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[0] transition device_init -> idle
[ 13.974070] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[1] transition device_init -> idle
[ 13.985016] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: JESD204[2] transition device_init -> idle
[ 13.995963] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: FSM completed with error -5
[ 14.008210] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 14.015438] rtc_zynqmp ffa60000.rtc: setting system clock to 2022-12-22 01:40:15 UTC (1671673215)
[ 14.024311] of_cfs_init
[ 14.026770] of_cfs_init: OK
[ 14.029722] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 14.093060] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 14.100076] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 14.109804] mmcblk0: p1 p2 p3
[ 14.168914] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 14.175444] clk: Not disabling unused clocks
[ 14.179713] ALSA device list:
[ 14.182670] #0: DisplayPort monitor
[ 14.186647] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 14.195252] cfg80211: failed to load regulatory.db
[ 14.594861] EXT4-fs (mmcblk0p2): recovery complete
[ 14.606146] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 14.614260] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 14.620304] devtmpfs: mounted
[ 14.623446] Freeing unused kernel memory: 832K
[ 14.627924] Run /sbin/init as init process
[ 14.955293] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 14.977041] systemd[1]: Detected architecture arm64.
Welcome to Kuiper GNU/Linux 10 (buster)!
[ 14.995425] systemd[1]: Set hostname to <analog>.
[ 15.170712] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 15.187770] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 15.316118] systemd[1]: /etc/systemd/system/tof-server.service:1: Assignment outside of section. Ignoring.
[ 15.325809] systemd[1]: /etc/systemd/system/tof-server.service:2: Assignment outside of section. Ignoring.
[ 15.498886] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ 15.523059] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 15.542915] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Reached target Swap.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Reached target Slices.
[ OK ] Listening on Journal Socket.
Starting Load Kernel Modules...
Mounting Kernel Debug File System...
Mounting Huge Pages File System...
Starting udev Coldplug all Devices...
Starting Journal Service...
Mounting POSIX Message Queue File System...
[ OK ] Created slice system-serial\x2dgetty.slice.
Mounting RPC Pipe File System...
[ OK ] Created slice system-getty.slice.
Starting Set the console keyboard layout...
Starting Restore / save the current clock...
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Journal Service.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted RPC Pipe File System.
[ OK ] Started Restore / save the current clock.
Starting Remount Root and Kernel File Systems...
Starting Apply Kernel Variables...
Mounting Kernel Configuration File System...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Set the console keyboard layout.
[ OK ] Started Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage...
Starting Load/Save Random Seed...
Starting Create System Users...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Load/Save Random Seed.
Starting Helper to synchronize boot up for ifupdown...
[ OK ] Started Create System Users.
[ OK ] Started Helper to synchronize boot up for ifupdown.
Starting Create Static Device Nodes in /dev...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Starting udev Kernel Device Manager...
[ OK ] Started udev Kernel Device Manager.
Starting Show Plymouth Boot Screen...
[ OK ] Started Show Plymouth Boot Screen.
[ OK ] Started Forward Password R…s to Plymouth Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Found device /dev/ttyPS0.
[ OK ] Found device /dev/disk/by-partuuid/004ba301-01.
[ OK ] Found device /dev/ttyS0.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting File System Check…isk/by-partuuid/004ba301-01...
[ OK ] Started File System Check Daemon to report status.
[ OK ] Started File System Check …/disk/by-partuuid/004ba301-01.
Mounting /boot...
[ OK ] Mounted /boot.
[ OK ] Reached target Local File Systems.
Starting Set console font and keymap...
Starting Tell Plymouth To Write Out Runtime Data...
Starting Create Volatile Files and Directories...
Starting Raise network interfaces...
Starting Preprocess NFS configuration...
[ OK ] Started Set console font and keymap.
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Preprocess NFS configuration.
[ OK ] Reached target NFS client services.
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Raise network interfaces.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Daily man-db regeneration.
[ OK ] Listening on triggerhappy.socket.
[ OK ] Listening on GPS (Global P…ioning System) Daemon Sockets.
[ OK ] Listening on CUPS Scheduler.
[ OK ] Started Daily rotation of log files.
[ OK ] Started CUPS Scheduler.
[ OK ] Reached target Paths.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting LSB: Switch to on…nless shift key is pressed)...
Starting System Logging Service...
[ OK ] Started D-Bus System Message Bus.
Starting Login Service...
Starting Check for Raspberry Pi EEPROM updates...
Starting Modem Manager...
Starting dphys-swapfile - …unt, and delete a swap file...
[ OK ] Started Manage Sound Card State (restore and store).
Starting Save/Restore Sound Card State...
[ OK ] Started tof-server.service.
Starting Disk Manager...
Starting rng-tools.service...
[ OK ] Started Regular background program processing daemon.
Starting triggerhappy global hotkey daemon...
Starting WPA supplicant...
Starting dhcpcd on all interfaces...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Save/Restore Sound Card State.
[FAILED] Failed to start rng-tools.service.
See 'systemctl status rng-tools.service' for details.
[ OK ] Reached target Sound Card.
[ OK ] Started Login Service.
[ OK ] Started triggerhappy global hotkey daemon.
[ OK ] Started System Logging Service.
[FAILED] Failed to start Check for Raspberry Pi EEPROM updates.
See 'systemctl status rpi-eeprom-update.service' for details.
[ OK ] Started dhcpcd on all interfaces.
[ OK ] Started WPA supplicant.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Make remote CUPS printers available locally.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server...
[ OK ] Reached target Network is Online.
Starting Internet superserver...
[ OK ] Started IIO Daemon.
Starting /etc/rc.local Compatibility...
Starting HTTP based time synchronization tool...
Starting Permit User Sessions...
[ OK ] Started dphys-swapfile - s…mount, and delete a swap file.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Permit User Sessions.
Starting Light Display Manager...
Starting Hold until boot process finishes up...
Starting Authorization Manager...
[ OK ] Started Internet superserver.
[ OK ] Started HTTP based time synchronization tool.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Authorization Manager.
Raspbian GNU/Linux 10 analog ttyPS0
analog login: root (automatic login)
Last login: Thu Dec 22 01:38:39 GMT 2022 on ttyPS0
Linux analog 4.19.0-g17f4223 #1849 SMP Tue Jul 27 13:12:14 IST 2021 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@analog:~#
The iio_info shows this
root@analog:/sys/bus/iio/devices/iio:device2# iio_info
Library version: 0.21 (git tag: fb64aca)
Compiled with backends: local xml ip usb
IIO context created with local backend.
Backend version: 0.21 (git tag: fb64aca)
Backend description string: Linux analog 4.19.0-g17f4223 #1849 SMP Tue Jul 27 13:12:14 IST 2021 aarch64
IIO context has 2 attributes:
local,kernel: 4.19.0-g17f4223
uri: local:
IIO context has 8 devices:
iio:device0: ams
30 channels found:
voltage6: vccpsintfpddr (input)
2 channel-specific attributes found:
attr 0: raw value: 18508
attr 1: scale value: 0.045776367
voltage14: vccpsio2 (input)
attr 0: raw value: 19476
attr 1: scale value: 0.091552734
voltage16: psmgtravtt (input)
attr 0: raw value: 39663
voltage23: vccplintlp (input)
attr 0: raw value: 18582
voltage0: vcc_pspll0 (input)
attr 0: raw value: 26027
voltage22: vccbram (input)
attr 0: raw value: 18580
voltage26: vccams (input)
attr 0: raw value: 39195
attr 1: scale value: 0.015258789
voltage8: vccpsintfp (input)
attr 0: raw value: 18576
temp1: remote_temp (input)
3 channel-specific attributes found:
attr 0: offset value: -36058
attr 1: raw value: 39750
attr 2: scale value: 7.771514892
voltage9: vccpsaux (input)
attr 0: raw value: 39748
voltage25: vccplaux (input)
attr 0: raw value: 39796
voltage18: vccint (input)
attr 0: raw value: 18496
voltage15: psmgtravcc (input)
attr 0: raw value: 18514
temp0: ps_temp (input)
attr 1: raw value: 40140
voltage2: vccint (input)
voltage5: vcc_psddrpll (input)
attr 0: raw value: 39554
voltage21: vccvrefn (input)
attr 0: raw value: 5
voltage7: vccpsintlp (input)
attr 0: raw value: 18549
voltage11: vccpsio3 (input)
attr 0: raw value: 19639
temp2: pl_temp (input)
attr 1: raw value: 39648
voltage13: vccpsio1 (input)
attr 0: raw value: 19507
voltage3: vccbram (input)
attr 0: raw value: 18586
voltage4: vccaux (input)
attr 0: raw value: 39303
voltage12: vccpsio0 (input)
attr 0: raw value: 19503
voltage10: vccpsddr (input)
attr 0: raw value: 26047
voltage24: vccplintfp (input)
attr 0: raw value: 18544
voltage1: vcc_psbatt (input)
attr 0: raw value: 31195
voltage19: vccaux (input)
attr 0: raw value: 39261
voltage17: vccams (input)
attr 0: raw value: 39672
voltage20: vccvrefp (input)
attr 0: raw value: 27307
1 device-specific attributes found:
attr 0: sampling_frequency ERROR: Invalid argument (22)
No trigger on this device
iio:device1: ad9528-1
4 channels found:
altvoltage3: FMC_SYSREF (output)
attr 0: frequency value: 7680000
attr 1: phase value: 0.000000
attr 2: raw value: 1
altvoltage1: FMC_CLK (output)
attr 0: frequency value: 245760000
altvoltage12: DEV_SYSREF (output)
altvoltage13: DEV_CLK (output)
9 device-specific attributes found:
attr 0: pll1_feedback_clk_present value: 1
attr 1: pll1_locked value: 0
attr 2: pll1_reference_clk_a_present value: 1
attr 3: pll1_reference_clk_ab_missing value: 0
attr 4: pll1_reference_clk_b_present value: 0
attr 5: pll2_feedback_clk_present value: 1
attr 6: pll2_locked value: 1
attr 7: sync_dividers ERROR: Permission denied (13)
attr 8: vcxo_clk_present value: 1
1 debug attributes found:
debug attr 0: direct_reg_access value: 0x18
iio:device2: adrv9009-phy
25 channels found:
altvoltage1: (output)
1 channel-specific attributes found:
attr 0: AUX_OBS_RX_LO_frequency ERROR: Device or resource busy (16)
voltage9: (output)
4 channel-specific attributes found:
attr 0: offset ERROR: Device or resource busy (16)
attr 1: raw ERROR: Device or resource busy (16)
attr 2: sampling_frequency ERROR: Device or resource busy (16)
attr 3: scale ERROR: Device or resource busy (16)
voltage8: (output)
voltage3: (input)
7 channel-specific attributes found:
attr 0: hardwaregain ERROR: Device or resource busy (16)
attr 1: powerdown ERROR: Device or resource busy (16)
attr 2: quadrature_tracking_en ERROR: Device or resource busy (16)
attr 3: rf_bandwidth ERROR: Device or resource busy (16)
attr 4: rf_port_select value: OBS_TX_LO
attr 5: rf_port_select_available value: OBS_TX_LO OBS_AUX_LO
attr 6: sampling_frequency ERROR: Device or resource busy (16)
voltage2: (output)
voltage1: (output)
8 channel-specific attributes found:
attr 0: atten_control_pin_mode_en ERROR: Device or resource busy (16)
attr 1: hardwaregain ERROR: Device or resource busy (16)
attr 2: lo_leakage_tracking_en ERROR: Device or resource busy (16)
attr 3: pa_protection_en ERROR: Device or resource busy (16)
attr 4: powerdown ERROR: Device or resource busy (16)
attr 5: quadrature_tracking_en ERROR: Device or resource busy (16)
attr 6: rf_bandwidth ERROR: Device or resource busy (16)
attr 7: sampling_frequency ERROR: Device or resource busy (16)
voltage0: (output)
altvoltage0: TRX_LO (output)
attr 0: frequency ERROR: Device or resource busy (16)
attr 1: frequency_hopping_mode ERROR: Device or resource busy (16)
attr 2: frequency_hopping_mode_enable ERROR: Device or resource busy (16)
voltage2: (input)
voltage5: (input)
attr 2: scale ERROR: Device or resource busy (16)
voltage6: (input)
voltage12: (output)
attr 0: raw ERROR: Device or resource busy (16)
attr 1: sampling_frequency ERROR: Device or resource busy (16)
voltage6: (output)
voltage13: (output)
voltage4: (input)
voltage5: (output)
voltage1: (input)
10 channel-specific attributes found:
attr 0: gain_control_mode value: manual
attr 1: gain_control_mode_available value: manual slow_attack
attr 2: gain_control_pin_mode_en ERROR: Device or resource busy (16)
attr 3: hardwaregain ERROR: Device or resource busy (16)
attr 4: hd2_tracking_en ERROR: Device or resource busy (16)
attr 5: powerdown ERROR: Device or resource busy (16)
attr 6: quadrature_tracking_en ERROR: Device or resource busy (16)
attr 7: rf_bandwidth ERROR: Device or resource busy (16)
attr 8: rssi ERROR: Device or resource busy (16)
attr 9: sampling_frequency ERROR: Device or resource busy (16)
voltage3: (output)
voltage10: (output)
voltage7: (input)
voltage0: (input)
voltage4: (output)
voltage11: (output)
voltage7: (output)
temp0: (input)
attr 0: input ERROR: Device or resource busy (16)
17 device-specific attributes found:
attr 0: calibrate ERROR: Input/output error (5)
attr 1: calibrate_fhm_en value: 0
attr 2: calibrate_rx_phase_correction_en value: 0
attr 3: calibrate_rx_qec_en value: 0
attr 4: calibrate_tx_lol_en value: 0
attr 5: calibrate_tx_lol_ext_en value: 0
attr 6: calibrate_tx_qec_en value: 0
attr 7: ensm_mode value: radio_off
attr 8: ensm_mode_available value: radio_on radio_off
attr 9: gain_table_config ERROR: Permission denied (13)
attr 10: jesd204_fsm_ctrl value: 0
attr 11: jesd204_fsm_error value: -5
attr 12: jesd204_fsm_paused value: 0
attr 13: jesd204_fsm_resume ERROR: Permission denied (13)
attr 14: jesd204_fsm_state value: idle
attr 15: multichip_sync ERROR: Permission denied (13)
attr 16: profile_config value: TB
306 debug attributes found:
debug attr 0: gpio3v3 value: 0
debug attr 1: bist_tone value: 0
debug attr 2: bist_framer_b_loopback value: 0
debug attr 3: bist_framer_a_loopback value: 0
debug attr 4: bist_framer_b_prbs value: 0
debug attr 5: bist_framer_a_prbs value: 0
debug attr 6: initialize value: 0
debug attr 7: adi,aux-pll-lo-frequency_hz value: 2500000000
debug attr 8: adi,trx-pll-lo-frequency_hz value: 2400000000
debug attr 9: adi,dig-clocks-rf-pll-phase-sync-mode value: 0
debug attr 10: adi,dig-clocks-rf-pll-use-external-lo value: 0
debug attr 11: adi,dig-clocks-clk-pll-hs-div value: 1
debug attr 12: adi,dig-clocks-clk-pll-vco-freq_khz value: 9830400
debug attr 13: adi,dig-clocks-device-clock_khz value: 245760
debug attr 14: adi,tx-settings-dis-tx-data-if-pll-unlock value: 0
debug attr 15: adi,tx-settings-tx2-atten_md-b value: 10000
debug attr 16: adi,tx-settings-tx1-atten_md-b value: 10000
debug attr 17: adi,tx-settings-tx-atten-step-size value: 0
debug attr 18: adi,tx-settings-tx-channels value: 3
debug attr 19: adi,tx-settings-deframer-sel value: 0
debug attr 20: adi,tx-profile-tx-bbf3d-bcorner_khz value: 113000
debug attr 21: adi,tx-profile-tx-dac3d-bcorner_khz value: 225000
debug attr 22: adi,tx-profile-rf-bandwidth_hz value: 225000000
debug attr 23: adi,tx-profile-primary-sig-bandwidth_hz value: 100000000
debug attr 24: adi,tx-profile-tx-input-rate_khz value: 245760
debug attr 25: adi,tx-profile-tx-int5-interpolation value: 1
debug attr 26: adi,tx-profile-thb3-interpolation value: 2
debug attr 27: adi,tx-profile-thb2-interpolation value: 2
debug attr 28: adi,tx-profile-thb1-interpolation value: 2
debug attr 29: adi,tx-profile-tx-fir-interpolation value: 1
debug attr 30: adi,tx-profile-dac-div value: 1
debug attr 31: adi,tx-profile-tx-fir-num-fir-coefs value: 40
debug attr 32: adi,tx-profile-tx-fir-gain_db value: 6
debug attr 33: adi,obs-settings-obs-rx-lo-source value: 0
debug attr 34: adi,obs-settings-obs-rx-channels-enable value: 3
debug attr 35: adi,obs-settings-framer-sel value: 1
debug attr 36: adi,orx-gain-control-orx2-min-gain-index value: 195
debug attr 37: adi,orx-gain-control-orx2-max-gain-index value: 255
debug attr 38: adi,orx-gain-control-orx1-min-gain-index value: 195
debug attr 39: adi,orx-gain-control-orx1-max-gain-index value: 255
debug attr 40: adi,orx-gain-control-orx2-gain-index value: 255
debug attr 41: adi,orx-gain-control-orx1-gain-index value: 255
debug attr 42: adi,orx-gain-control-gain-mode value: 0
debug attr 43: adi,orx-profile-orx-ddc-mode value: 0
debug attr 44: adi,orx-profile-rx-bbf3d-bcorner_khz value: 225000
debug attr 45: adi,orx-profile-rf-bandwidth_hz value: 200000000
debug attr 46: adi,orx-profile-orx-output-rate_khz value: 245760
debug attr 47: adi,orx-profile-rhb1-decimation value: 2
debug attr 48: adi,orx-profile-rx-dec5-decimation value: 4
debug attr 49: adi,orx-profile-rx-fir-decimation value: 1
debug attr 50: adi,orx-profile-rx-fir-num-fir-coefs value: 24
debug attr 51: adi,orx-profile-rx-fir-gain_db value: 6
debug attr 52: adi,rx-settings-rx-channels value: 3
debug attr 53: adi,rx-settings-framer-sel value: 0
debug attr 54: adi,rx-gain-control-rx2-min-gain-index value: 195
debug attr 55: adi,rx-gain-control-rx2-max-gain-index value: 255
debug attr 56: adi,rx-gain-control-rx1-min-gain-index value: 195
debug attr 57: adi,rx-gain-control-rx1-max-gain-index value: 255
debug attr 58: adi,rx-gain-control-rx2-gain-index value: 255
debug attr 59: adi,rx-gain-control-rx1-gain-index value: 255
debug attr 60: adi,rx-gain-control-gain-mode value: 0
debug attr 61: adi,rx-nco-shifter-band-bnco2-freq_khz value: 0
debug attr 62: adi,rx-nco-shifter-band-bnco1-freq_khz value: 0
debug attr 63: adi,rx-nco-shifter-band-binput-center-freq_khz value: 0
debug attr 64: adi,rx-nco-shifter-band-binput-band-width_khz value: 0
debug attr 65: adi,rx-nco-shifter-band-a-nco2-freq_khz value: 0
debug attr 66: adi,rx-nco-shifter-band-a-nco1-freq_khz value: 0
debug attr 67: adi,rx-nco-shifter-band-a-input-center-freq_khz value: 0
debug attr 68: adi,rx-nco-shifter-band-a-input-band-width_khz value: 0
debug attr 69: adi,rx-profile-rx-ddc-mode value: 0
debug attr 70: adi,rx-profile-rx-bbf3d-bcorner_khz value: 200000
debug attr 71: adi,rx-profile-rf-bandwidth_hz value: 200000000
debug attr 72: adi,rx-profile-rx-output-rate_khz value: 245760
debug attr 73: adi,rx-profile-rhb1-decimation value: 1
debug attr 74: adi,rx-profile-rx-dec5-decimation value: 4
debug attr 75: adi,rx-profile-rx-fir-decimation value: 2
debug attr 76: adi,rx-profile-rx-fir-num-fir-coefs value: 48
debug attr 77: adi,rx-profile-rx-fir-gain_db value: 250
debug attr 78: adi,tx-pa-protection-tx2-peak-threshold value: 140
debug attr 79: adi,tx-pa-protection-tx1-peak-threshold value: 140
debug attr 80: adi,tx-pa-protection-peak-count value: 4
debug attr 81: adi,tx-pa-protection-tx2-power-threshold value: 4096
debug attr 82: adi,tx-pa-protection-tx1-power-threshold value: 4096
debug attr 83: adi,tx-pa-protection-tx-atten-step value: 2
debug attr 84: adi,tx-pa-protection-avg-duration value: 3
debug attr 85: adi,tx2-atten-ctrl-pin-enable value: 0
debug attr 86: adi,tx2-atten-ctrl-pin-tx-atten-dec-pin value: 7
debug attr 87: adi,tx2-atten-ctrl-pin-tx-atten-inc-pin value: 6
debug attr 88: adi,tx2-atten-ctrl-pin-step-size value: 0
debug attr 89: adi,tx1-atten-ctrl-pin-enable value: 0
debug attr 90: adi,tx1-atten-ctrl-pin-tx-atten-dec-pin value: 5
debug attr 91: adi,tx1-atten-ctrl-pin-tx-atten-inc-pin value: 4
debug attr 92: adi,tx1-atten-ctrl-pin-step-size value: 0
debug attr 93: adi,rx2-gain-ctrl-pin-enable value: 0
debug attr 94: adi,rx2-gain-ctrl-pin-rx-gain-dec-pin value: 4
debug attr 95: adi,rx2-gain-ctrl-pin-rx-gain-inc-pin value: 3
debug attr 96: adi,rx2-gain-ctrl-pin-dec-step value: 1
debug attr 97: adi,rx2-gain-ctrl-pin-inc-step value: 1
debug attr 98: adi,rx1-gain-ctrl-pin-enable value: 0
debug attr 99: adi,rx1-gain-ctrl-pin-rx-gain-dec-pin value: 1
debug attr 100: adi,rx1-gain-ctrl-pin-rx-gain-inc-pin value: 0
debug attr 101: adi,rx1-gain-ctrl-pin-dec-step value: 1
debug attr 102: adi,rx1-gain-ctrl-pin-inc-step value: 1
debug attr 103: adi,fhm-mode-fhm-init-frequency_hz value: 2450000000
debug attr 104: adi,fhm-mode-fhm-exit-mode value: 1
debug attr 105: adi,fhm-mode-fhm-trigger-mode value: 0
debug attr 106: adi,fhm-mode-enable-mcs-sync value: 0
debug attr 107: adi,fhm-mode-fhm-enable value: 0
debug attr 108: adi,fhm-config-fhm-max-freq_mhz value: 2500
debug attr 109: adi,fhm-config-fhm-min-freq_mhz value: 2400
debug attr 110: adi,fhm-config-fhm-gpio-pin value: 0
debug attr 111: adi,orx-lo-cfg-gpio-select value: 19
debug attr 112: adi,orx-lo-cfg-disable-aux-pll-relocking value: 0
debug attr 113: adi,gpio3v3-output-level-mask value: 0
debug attr 114: adi,gpio3v3-output-enable-mask value: 0
debug attr 115: adi,gpio3v3-source-control value: 0
debug attr 116: adi,arm-gpio-config-en-tx-tracking-cals-enable value: 0
debug attr 117: adi,arm-gpio-config-en-tx-tracking-cals-polarity value: 0
debug attr 118: adi,arm-gpio-config-en-tx-tracking-cals-gpio-pin-sel value: 0
debug attr 119: adi,arm-gpio-config-orx2-tx-sel1-pin-enable value: 0
debug attr 120: adi,arm-gpio-config-orx2-tx-sel1-pin-polarity value: 0
debug attr 121: adi,arm-gpio-config-orx2-tx-sel1-pin-gpio-pin-sel value: 0
debug attr 122: adi,arm-gpio-config-orx2-tx-sel0-pin-enable value: 0
debug attr 123: adi,arm-gpio-config-orx2-tx-sel0-pin-polarity value: 0
debug attr 124: adi,arm-gpio-config-orx2-tx-sel0-pin-gpio-pin-sel value: 0
debug attr 125: adi,arm-gpio-config-orx1-tx-sel1-pin-enable value: 0
debug attr 126: adi,arm-gpio-config-orx1-tx-sel1-pin-polarity value: 0
debug attr 127: adi,arm-gpio-config-orx1-tx-sel1-pin-gpio-pin-sel value: 0
debug attr 128: adi,arm-gpio-config-orx1-tx-sel0-pin-enable value: 0
debug attr 129: adi,arm-gpio-config-orx1-tx-sel0-pin-polarity value: 0
debug attr 130: adi,arm-gpio-config-orx1-tx-sel0-pin-gpio-pin-sel value: 0
debug attr 131: adi,jesd204-sysref-lvds-pn-invert value: 0
debug attr 132: adi,jesd204-sysref-lvds-mode value: 1
debug attr 133: adi,jesd204-des-eq-setting value: 1
debug attr 134: adi,jesd204-des-invert-lane-polarity value: 0
debug attr 135: adi,jesd204-ser-invert-lane-polarity value: 0
debug attr 136: adi,jesd204-ser-pre-emphasis value: 1
debug attr 137: adi,jesd204-ser-amplitude value: 15
debug attr 138: adi,jesd204-deframer-b-enable-manual-lane-xbar value: 0
debug attr 139: adi,jesd204-deframer-b-syncb-out-cmos-drive-level value: 0
debug attr 140: adi,jesd204-deframer-b-syncb-out-cmos-slew-rate value: 0
debug attr 141: adi,jesd204-deframer-b-syncb-out-lvds-pn-invert value: 0
debug attr 142: adi,jesd204-deframer-b-syncb-out-lvds-mode value: 1
debug attr 143: adi,jesd204-deframer-b-np value: 16
debug attr 144: adi,jesd204-deframer-b-syncb-out-select value: 0
debug attr 145: adi,jesd204-deframer-b-new-sysref-on-relink value: 0
debug attr 146: adi,jesd204-deframer-b-lmfc-offset value: 0
debug attr 147: adi,jesd204-deframer-b-deserializer-lane-crossbar value: 228
debug attr 148: adi,jesd204-deframer-b-deserializer-lanes-enabled value: 0
debug attr 149: adi,jesd204-deframer-b-external-sysref value: 1
debug attr 150: adi,jesd204-deframer-b-scramble value: 1
debug attr 151: adi,jesd204-deframer-b-k value: 32
debug attr 152: adi,jesd204-deframer-b-m value: 0
debug attr 153: adi,jesd204-deframer-b-lane0-id value: 0
debug attr 154: adi,jesd204-deframer-b-device-id value: 0
debug attr 155: adi,jesd204-deframer-b-bank-id value: 0
debug attr 156: adi,jesd204-deframer-a-enable-manual-lane-xbar value: 0
debug attr 157: adi,jesd204-deframer-a-syncb-out-cmos-drive-level value: 0
debug attr 158: adi,jesd204-deframer-a-syncb-out-cmos-slew-rate value: 0
debug attr 159: adi,jesd204-deframer-a-syncb-out-lvds-pn-invert value: 0
debug attr 160: adi,jesd204-deframer-a-syncb-out-lvds-mode value: 1
debug attr 161: adi,jesd204-deframer-a-np value: 16
debug attr 162: adi,jesd204-deframer-a-syncb-out-select value: 0
debug attr 163: adi,jesd204-deframer-a-new-sysref-on-relink value: 0
debug attr 164: adi,jesd204-deframer-a-lmfc-offset value: 17
debug attr 165: adi,jesd204-deframer-a-deserializer-lane-crossbar value: 228
debug attr 166: adi,jesd204-deframer-a-deserializer-lanes-enabled value: 15
debug attr 167: adi,jesd204-deframer-a-external-sysref value: 1
debug attr 168: adi,jesd204-deframer-a-scramble value: 1
debug attr 169: adi,jesd204-deframer-a-k value: 32
debug attr 170: adi,jesd204-deframer-a-m value: 4
debug attr 171: adi,jesd204-deframer-a-lane0-id value: 0
debug attr 172: adi,jesd204-deframer-a-device-id value: 0
debug attr 173: adi,jesd204-deframer-a-bank-id value: 0
debug attr 174: adi,jesd204-framer-b-enable-manual-lane-xbar value: 0
debug attr 175: adi,jesd204-framer-b-syncb-in-lvds-pn-invert value: 0
debug attr 176: adi,jesd204-framer-b-syncb-in-lvds-mode value: 1
debug attr 177: adi,jesd204-framer-b-over-sample value: 0
debug attr 178: adi,jesd204-framer-b-syncb-in-select value: 1
debug attr 179: adi,jesd204-framer-b-new-sysref-on-relink value: 0
debug attr 180: adi,jesd204-framer-b-lmfc-offset value: 31
debug attr 181: adi,jesd204-framer-b-serializer-lane-crossbar value: 228
debug attr 182: adi,jesd204-framer-b-serializer-lanes-enabled value: 12
debug attr 183: adi,jesd204-framer-b-external-sysref value: 1
debug attr 184: adi,jesd204-framer-b-scramble value: 1
debug attr 185: adi,jesd204-framer-b-np value: 16
debug attr 186: adi,jesd204-framer-b-f value: 4
debug attr 187: adi,jesd204-framer-b-k value: 32
debug attr 188: adi,jesd204-framer-b-m value: 4
debug attr 189: adi,jesd204-framer-b-lane0-id value: 0
debug attr 190: adi,jesd204-framer-b-device-id value: 0
debug attr 191: adi,jesd204-framer-b-bank-id value: 0
debug attr 192: adi,jesd204-framer-a-enable-manual-lane-xbar value: 0
debug attr 193: adi,jesd204-framer-a-syncb-in-lvds-pn-invert value: 0
debug attr 194: adi,jesd204-framer-a-syncb-in-lvds-mode value: 1
debug attr 195: adi,jesd204-framer-a-over-sample value: 0
debug attr 196: adi,jesd204-framer-a-syncb-in-select value: 0
debug attr 197: adi,jesd204-framer-a-new-sysref-on-relink value: 0
debug attr 198: adi,jesd204-framer-a-lmfc-offset value: 31
debug attr 199: adi,jesd204-framer-a-serializer-lane-crossbar value: 228
debug attr 200: adi,jesd204-framer-a-serializer-lanes-enabled value: 3
debug attr 201: adi,jesd204-framer-a-external-sysref value: 1
debug attr 202: adi,jesd204-framer-a-scramble value: 1
debug attr 203: adi,jesd204-framer-a-np value: 16
debug attr 204: adi,jesd204-framer-a-f value: 4
debug attr 205: adi,jesd204-framer-a-k value: 32
debug attr 206: adi,jesd204-framer-a-m value: 4
debug attr 207: adi,jesd204-framer-a-lane0-id value: 0
debug attr 208: adi,jesd204-framer-a-device-id value: 0
debug attr 209: adi,jesd204-framer-a-bank-id value: 1
debug attr 210: adi,aux-dac-values11 value: 0
debug attr 211: adi,aux-dac-values10 value: 0
debug attr 212: adi,aux-dac-values9 value: 0
debug attr 213: adi,aux-dac-resolution9 value: 0
debug attr 214: adi,aux-dac-vref9 value: 3
debug attr 215: adi,aux-dac-values8 value: 0
debug attr 216: adi,aux-dac-resolution8 value: 0
debug attr 217: adi,aux-dac-vref8 value: 3
debug attr 218: adi,aux-dac-values7 value: 0
debug attr 219: adi,aux-dac-resolution7 value: 0
debug attr 220: adi,aux-dac-vref7 value: 3
debug attr 221: adi,aux-dac-values6 value: 0
debug attr 222: adi,aux-dac-resolution6 value: 0
debug attr 223: adi,aux-dac-vref6 value: 3
debug attr 224: adi,aux-dac-values5 value: 0
debug attr 225: adi,aux-dac-resolution5 value: 0
debug attr 226: adi,aux-dac-vref5 value: 3
debug attr 227: adi,aux-dac-values4 value: 0
debug attr 228: adi,aux-dac-resolution4 value: 0
debug attr 229: adi,aux-dac-vref4 value: 3
debug attr 230: adi,aux-dac-values3 value: 0
debug attr 231: adi,aux-dac-resolution3 value: 0
debug attr 232: adi,aux-dac-vref3 value: 3
debug attr 233: adi,aux-dac-values2 value: 0
debug attr 234: adi,aux-dac-resolution2 value: 0
debug attr 235: adi,aux-dac-vref2 value: 3
debug attr 236: adi,aux-dac-values1 value: 0
debug attr 237: adi,aux-dac-resolution1 value: 0
debug attr 238: adi,aux-dac-vref1 value: 3
debug attr 239: adi,aux-dac-values0 value: 0
debug attr 240: adi,aux-dac-resolution0 value: 0
debug attr 241: adi,aux-dac-vref0 value: 3
debug attr 242: adi,aux-dac-enables value: 0
debug attr 243: adi,rxagc-agc-enable-fast-recovery-loop value: 0
debug attr 244: adi,rxagc-ip3-peak-exceeded-cnt value: 4
debug attr 245: adi,rxagc-ip3-over-range-thresh-index value: 246
debug attr 246: adi,rxagc-ip3-over-range-thresh value: 31
debug attr 247: adi,rxagc-agc-enable-ip3-optimization-thresh value: 0
debug attr 248: adi,rxagc-agc-enable-sync-pulse-for-gain-counter value: 0
debug attr 249: adi,rxagc-agc-reset-on-rxon value: 0
debug attr 250: adi,rxagc-agc-peak-thresh-gain-control-mode value: 1
debug attr 251: adi,rxagc-agc-change-gain-if-thresh-high value: 1
debug attr 252: adi,rxagc-agc-low-thresh-prevent-gain value: 0
debug attr 253: adi,rxagc-agc-slow-loop-settling-delay value: 16
debug attr 254: adi,rxagc-agc-rx2-attack-delay value: 10
debug attr 255: adi,rxagc-agc-rx1-attack-delay value: 10
debug attr 256: adi,rxagc-agc-gain-update-counter_us value: 250
debug attr 257: adi,rxagc-agc-rx2-min-gain-index value: 195
debug attr 258: adi,rxagc-agc-rx2-max-gain-index value: 255
debug attr 259: adi,rxagc-agc-rx1-min-gain-index value: 195
debug attr 260: adi,rxagc-agc-rx1-max-gain-index value: 255
debug attr 261: adi,rxagc-agc-peak-wait-time value: 4
debug attr 262: adi,rxagc-power-power-log-shift value: 0
debug attr 263: adi,rxagc-power-upper1-power-thresh value: 0
debug attr 264: adi,rxagc-power-upper0-power-thresh value: 2
debug attr 265: adi,rxagc-power-rx2-tdd-power-meas-delay value: 1
debug attr 266: adi,rxagc-power-rx2-tdd-power-meas-duration value: 5
debug attr 267: adi,rxagc-power-rx1-tdd-power-meas-delay value: 1
debug attr 268: adi,rxagc-power-rx1-tdd-power-meas-duration value: 5
debug attr 269: adi,rxagc-power-power-measurement-duration value: 5
debug attr 270: adi,rxagc-power-under-range-low-power-gain-step-recovery value: 4
debug attr 271: adi,rxagc-power-under-range-high-power-gain-step-recovery value: 4
debug attr 272: adi,rxagc-power-under-range-low-power-thresh value: 2
debug attr 273: adi,rxagc-power-under-range-high-power-thresh value: 9
debug attr 274: adi,rxagc-power-power-use-bbdc2 value: 0
debug attr 275: adi,rxagc-power-power-use-rfir-out value: 1
debug attr 276: adi,rxagc-power-power-enable-measurement value: 1
debug attr 277: adi,rxagc-peak-hb2-thresh-config value: 3
debug attr 278: adi,rxagc-peak-hb2-ovrg-sel value: 0
debug attr 279: adi,rxagc-peak-hb2-overload-power-mode value: 1
debug attr 280: adi,rxagc-peak-hb2-gain-step-attack value: 4
debug attr 281: adi,rxagc-peak-hb2-gain-step-mid-recovery value: 8
debug attr 282: adi,rxagc-peak-hb2-gain-step-low-recovery value: 4
debug attr 283: adi,rxagc-peak-hb2-gain-step-high-recovery value: 2
debug attr 284: adi,rxagc-peak-hb2-lower-thresh-peak-exceeded-cnt value: 3
debug attr 285: adi,rxagc-peak-hb2-upper-thresh-peak-exceeded-cnt value: 6
debug attr 286: adi,rxagc-peak-hb2-under-range-high-thresh value: 128
debug attr 287: adi,rxagc-peak-hb2-under-range-mid-thresh value: 90
debug attr 288: adi,rxagc-peak-hb2-under-range-low-thresh value: 45
debug attr 289: adi,rxagc-peak-hb2-high-thresh value: 181
debug attr 290: adi,rxagc-peak-hb2-overload-thresh-cnt value: 4
debug attr 291: adi,rxagc-peak-hb2-overload-duration-cnt value: 1
debug attr 292: adi,rxagc-peak-enable-hb2-overload value: 1
debug attr 293: adi,rxagc-peak-apd-gain-step-recovery value: 2
debug attr 294: adi,rxagc-peak-apd-gain-step-attack value: 4
debug attr 295: adi,rxagc-peak-apd-lower-thresh-peak-exceeded-cnt value: 3
debug attr 296: adi,rxagc-peak-apd-upper-thresh-peak-exceeded-cnt value: 6
debug attr 297: adi,rxagc-peak-apd-low-gain-mode-low-thresh value: 19
debug attr 298: adi,rxagc-peak-apd-low-thresh value: 23
debug attr 299: adi,rxagc-peak-apd-low-gain-mode-high-thresh value: 36
debug attr 300: adi,rxagc-peak-apd-high-thresh value: 39
debug attr 301: adi,rxagc-peak-agc-under-range-high-interval value: 4
debug attr 302: adi,rxagc-peak-agc-under-range-mid-interval value: 2
debug attr 303: adi,rxagc-peak-agc-under-range-low-interval_ns value: 205
debug attr 304: adi,default-initial-calibrations-mask value: 9362927
debug attr 305: direct_reg_access value: 0x0
iio:device3: ad7291
9 channels found:
temp0: (input)
attr 0: mean_raw value: 110
attr 1: raw value: 110
attr 2: scale value: 250
voltage1: (input)
attr 0: raw value: 2105
attr 1: scale value: 0.610351562
voltage5: (input)
attr 0: raw value: 2911
voltage2: (input)
attr 0: raw value: 1477
voltage6: (input)
attr 0: raw value: 1253
voltage3: (input)
attr 0: raw value: 2722
voltage7: (input)
attr 0: raw value: 2151
voltage0: (input)
attr 0: raw value: 2808
voltage4: (input)
attr 0: raw value: 2954
iio:device4: axi-adrv9009-rx-hpc (buffer capable)
4 channels found:
voltage0_i: (input, index: 0, format: le:S16/16>>0)
5 channel-specific attributes found:
attr 0: calibbias value: 0
attr 1: calibphase value: 0.000000
attr 2: calibscale value: 0.000000
attr 3: sampling_frequency value: 245760000
attr 4: sampling_frequency_available value: 245760000 30720000
voltage0_q: (input, index: 1, format: le:S16/16>>0)
voltage1_i: (input, index: 2, format: le:S16/16>>0)
voltage1_q: (input, index: 3, format: le:S16/16>>0)
3 buffer-specific attributes found:
attr 0: data_available value: 0
attr 1: length_align_bytes value: 16
attr 2: watermark value: 2048
2 debug attributes found:
debug attr 0: pseudorandom_err_check value: CH0 : PN9 : In Sync : OK
CH1 : PN9 : In Sync : OK
CH2 : PN9 : In Sync : OK
CH3 : PN9 : In Sync : OK
debug attr 1: direct_reg_access value: 0x0
iio:device5: axi-adrv9009-rx-obs-hpc (buffer capable)
2 channels found:
attr 0: sampling_frequency value: 245760000
debug attr 0: direct_reg_access value: 0xA0162
iio:device6: axi-adrv9009-tx-hpc (buffer capable)
12 channels found:
voltage0: (output, index: 0, format: le:S16/16>>0)
attr 0: calibphase value: 0.000000
attr 1: calibscale value: 0.000000
attr 2: sampling_frequency value: 245760000
attr 3: sampling_frequency_available value: 245760000 30720000
voltage1: (output, index: 1, format: le:S16/16>>0)
voltage2: (output, index: 2, format: le:S16/16>>0)
voltage3: (output, index: 3, format: le:S16/16>>0)
altvoltage3: TX1_Q_F2 (output)
attr 0: frequency value: 40001860
attr 4: scale value: 0.250000
altvoltage5: TX2_I_F2 (output)
attr 1: phase value: 90000
altvoltage2: TX1_Q_F1 (output)
altvoltage1: TX1_I_F2 (output)
altvoltage7: TX2_Q_F2 (output)
altvoltage4: TX2_I_F1 (output)
altvoltage0: TX1_I_F1 (output)
altvoltage6: TX2_Q_F1 (output)
debug attr 0: pl_ddr_fifo_enable value: 0
debug attr 1: direct_reg_access value: 0x90162
iio_sysfs_trigger:
0 channels found:
2 device-specific attributes found:
attr 0: add_trigger ERROR: Permission denied (13)
attr 1: remove_trigger ERROR: Permission denied (13)
No trigger on this devicetravisfcollins any thoughts ?
The JESD links have errors:
Have you modified your board in any way or changed the standard SD card files?
-Travis
Hi Travis,
Thank you for your reply
I didn't touch anything. I already use these Image Linux on another Platforms, and it was working perfectly.
The last week, I received from my colleagues a ZCU102 board and ADRV9009. They are not new. But I don't know if they are damaged or not.
The command jesd_status shows this
Could be a hardware problem on ZCU102 ? ADRV9009 ?
Best
Can you take a picture of your ADRV9009 board? Something seems off.
-Travis
Of course
That looks fine.
I'll need our FSM expert to take a look at this error.
-Travis
