Hello All,
I'm trying to evaluate the AGC functionality on ADRV9002, As I set the Gain control configuration tab like below
I can see the AGC act correctly for a specific range of input power levels in the TES environment.
When I switch to MATLAB the AGC functionality does not work. Here is the applied parameters list:
First, I don't have the power overload threshold and power underload threshold parameters to set.
Secondly, if I load the profile on the transmitter side and transmit once, does the receiver configuration uses the profile? If yes, I applied the profile it does not work.
Thank you in advance.
Kind Regards
Arash
