unable to build kernel image or devicetree due to errors
Product Number: adrv9371
Software Version: 2018r2
I have been trying to build the kernel as per the instruction given in the following link wiki.analog.com/.../zynq. I use the ubuntu app available at the windows store to build the kernel and the devicetree, and hence I am not able to use the Xilinx toolchain as it doesn't recognise the path outside the ubuntu directory. Hence I tried the method with the linaro toolchain and upon using the make uimage instruction, I get the following error
make: /root/sd1/analog/linux/gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi-gcc: No such file or directory
I tried downloading the linaro toolchain using the following command
wget releases.linaro.org/.../gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz
tar -xvf gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz
but it downloads a .tar.xz file and i don't know how to extract it. I tried the winrar to extract it but it shows the following error
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\libexec\gcc\arm-linux-gnueabi\5.5.0\liblto_plugin.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\libexec\gcc\arm-linux-gnueabi\5.5.0\liblto_plugin.so.0
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libm.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libnss_hesiod.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libnss_compat.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libcidn.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libnss_files.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libanl.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libthread_db.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libutil.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libnss_dns.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libnsl.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libBrokenLocale.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libnss_db.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\librt.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libnss_nisplus.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libresolv.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libnss_nis.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libdl.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\usr\lib\libcrypt.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libresolv.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\ld-linux.so.3
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libnss_nis.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libssp.so.0
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\librt.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libgomp.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libnss_compat.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libnss_files.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libanl.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libatomic.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libnss_hesiod.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\debug\libstdc++.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\debug\libstdc++.so.6
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libcrypt.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libgomp-plugin-host_nonshm.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libstdc++.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libasan.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libitm.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libatomic.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libc.so.6
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libcidn.so.1
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libutil.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libubsan.so.0
Incorrect function.
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libnsl.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libthread_db.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libgfortran.so.3
Incorrect function.
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libasan.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libBrokenLocale.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libnss_nisplus.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libdl.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libm.so.6
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libpthread.so.0
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libstdc++.so.6
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libnss_dns.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\libc\lib\libnss_db.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libssp.so.0
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libgomp.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libatomic.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\debug\libstdc++.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\debug\libstdc++.so.6
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libgomp-plugin-host_nonshm.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libstdc++.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libasan.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libitm.so.1
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libatomic.so.1
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libubsan.so.0
Incorrect function.
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libgfortran.so.3
Incorrect function.
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libasan.so.2
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\arm-linux-gnueabi\lib\libstdc++.so.6
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\lib\libcc1.so.0
Incorrect function.
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\lib\gcc\arm-linux-gnueabi\5.5.0\plugin\libcc1plugin.so
Incorrect function.
! \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz: Cannot create symbolic link \\wsl.localhost\Ubuntu\root\sd1\analog\linux\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi\lib\gcc\arm-linux-gnueabi\5.5.0\plugin\libcc1plugin.so.0
Incorrect function.
what i'm doing wrong?
