rf_port_select does not work
Product Number: iiolib
Good morning
for this
ret = iio_channel_attr_write(phy_chn_rx, "rf_port_select", rxcfg.rfport);
I get a -22
Other settings for the rx channel work
The
 phy_chn_rx = iio_device_find_channel(phydev, "voltage0", false );
gives the channel for rx. This one works.
Additionally is of value to assign settings to altvoltage0 or altvoltage1 for the PLUTO?
It seems they are not available ...
Thank You
Pietro
  • On the Pluto, only the A Balanced inputs are used.
    Therefore the other settings are locked - please see here:
    https://github.com/analogdevicesinc/linux/blob/master/arch/arm/boot/dts/zynq-pluto-sdr.dtsi#L248
    You should be able to control the RX/TX LOs using altvoltage0 or altvoltage1.
    When you iio_device_find_channel() you need to make sure that you look for an output channel...
    -Michael
  • Hi
    Thank You for the assistance. I will follow the indication.
    I have further questions.
    I want to reread the attribute.
    A list of what happens:
    1. iio_channel_attr_read( phy_chn_tx, "rf_port_select", (char*)txcfg.rfport, 10 )  -> -10014
    2. iio_channel_attr_read_longlong( phy_chn_tx, "rf_bandwidth", &txcfg.bw_hz ); -> -22
    3. iio_channel_attr_read_longlong( phy_chn_tx, "sampling_frequency", &txcfg.fs_hz ); -> 0
    4. iio_channel_attr_read_double(   phy_chn_tx, "hardwaregain", &txcfg.gain_db ); -> 0 but gain = 2600000
    5. iio_channel_attr_read_longlong( phy_chn_tx, "frequency", &txcfg.lo_hz); -> -2
    6. iio_channel_attr_read(          phy_chn_rx, "rf_port_select", (char*)rxcfg.rfport, 10 ); -> -5
    7. iio_channel_attr_read_longlong( phy_chn_rx, "rf_bandwidth", &rxcfg.bw_hz ); -> -10053
    8. iio_channel_attr_read_longlong( phy_chn_rx, "sampling_frequency", &rxcfg.fs_hz ); -> -10053
    9. iio_channel_attr_read_double(   phy_chn_rx, "hardwaregain", &rxcfg.gain_db ); -> -10053
    10. iio_channel_attr_read_longlong( phy_chn_rx, "frequency", &rxcfg.lo_hz); -> -2
    The attributes were written previously with return code 0.
    I suppose I should reread the same values. What happens?
    Where are the return codes ?
    Thank You
    Pietro
  • Attribute values written may have different read values if the value is not possible. If you want to get the return code look at the doc for each function you call: http://analogdevicesinc.github.io/libiio/v0.24/libiio/index.html
    -Travis
  • Hi Travis
    Thank You
    I suppose if the value is different simply I get the value but not the error.
    Can You tell me which file to open for reading the error codes?
    Thank You
    Pietro
  • Hi
    I just tested the iio_strerror()
    For all of the codes I have Unlnown error..
    Just help
    Than You
    Pietro
  • Can you provide the specific libiio function and error code?
    -Travis
  • Good morning Travis,
    It seems there is no way to attach  files.
    I dump here the source. Sorry it is long..
    The setup of the pluto is here. The calls to the IIO_LIB are prepended with a IIO_lib_itf.
    I use wxSidgets and the DLL functions are loaded in a data stracture.
    // ctx = IIO_lib_itf.iio_create_default_context();
    ctx = IIO_lib_itf.iio_create_network_context("pluto.local");
    if (ctx == NULL)
    char buf[1024];
    char str[1400];
    wxString String;
    IIO_lib_itf.iio_strerror(errno, buf, sizeof(buf));
    sprintf( str, "Failed creating IIO context: %s", buf);
    ListBox->AppendString(wxString(str));
    return;
    else
    ListBox->AppendString( " IIO context created" );
    scan_ctx = IIO_lib_itf.iio_create_scan_context( NULL, 0 );
    if (scan_ctx) {
    int info_count = IIO_lib_itf.iio_scan_context_get_info_list( scan_ctx, &info );
    if (info_count > 0) {
    char *buf = (char *)IIO_lib_itf.iio_context_info_get_description( info[ 0 ] );
    sprintf(str, "* Found %s", buf);
    ListBox->AppendString( wxString( str ) );
    IIO_lib_itf.iio_context_info_list_free(info);
    IIO_lib_itf.iio_scan_context_destroy( scan_ctx );
    scan_ctx = NULL;
    ListBox->AppendString("* Acquiring devices\n");
    device_count = IIO_lib_itf.iio_context_get_devices_count( ctx );
    if (!device_count) {
    ListBox->AppendString( "No supported PLUTOSDR devices found");
    return;
    sprintf(str, "* Context has %d device(s).\n", device_count );
    ListBox->AppendString( wxString(str) );
    ListBox->AppendString("* Acquiring TX device");
    tx = IIO_lib_itf.iio_context_find_device( ctx, "cf-ad9361-dds-core-lpc" );
    if (tx == NULL) {
    char buf[ 1024 ];
    IIO_lib_itf.iio_strerror(errno, buf, sizeof( buf ) );
    sprintf( str, "Error opening PLUTOSDR TX device: %s", buf );
    return;
    else
    ListBox->AppendString( wxString( "PLUTOSDR TX device open" ) );
    IIO_lib_itf.iio_device_set_kernel_buffers_count(tx, 8);
    phydev = IIO_lib_itf.iio_context_find_device(ctx, "ad9361-phy");
    if ( phydev != NULL )
    phy_chn_tx = IIO_lib_itf.iio_device_find_channel(phydev, "voltage0", true);
    if (phy_chn_tx == NULL)
    ListBox->AppendString(wxString("voltage0 channel for TX NOT found"));
    return;
    else
    ListBox->AppendString( wxString( "ad9361-phy dev for TX NOT found" ) );
    return;
    ssize_t ret;
    ret = IIO_lib_itf.iio_channel_attr_write(phy_chn_tx, "rf_port_select", txcfg.rfport );
    if( ret < 0 )
    ListBox->AppendString( wxString( "rf_port_select attribute for TX NOT written" ) );
    return;
    ret = IIO_lib_itf.iio_channel_attr_write_longlong(phy_chn_tx, "rf_bandwidth", txcfg.bw_hz );
    if (ret < 0)
    ListBox->AppendString( wxString("rf_bandwidth attribute for TX NOT written"));
    return;
    ret = IIO_lib_itf.iio_channel_attr_write_longlong( phy_chn_tx, "sampling_frequency", txcfg.fs_hz );
    if (ret < 0)
    ListBox->AppendString( wxString("sampling_frequency attribute for TX NOT written"));
    return;
    ret = IIO_lib_itf.iio_channel_attr_write_double( phy_chn_tx, "hardwaregain", txcfg.gain_db );
    if (ret < 0)
    ListBox->AppendString( wxString( "hardwaregain attribute for TX NOT written" ) );
    return;
    phy_chn_rx = IIO_lib_itf.iio_device_find_channel(phydev, "voltage0", false );
    if (phy_chn_rx == NULL)
    ListBox->AppendString( wxString( "voltage0 channel for RX NOT found"));
    return;
    ret = IIO_lib_itf.iio_channel_attr_write(phy_chn_rx, "rf_port_select", rxcfg.rfport);
    if (ret < 0)
    ListBox->AppendString(wxString("rf_port_select attribute for RX NOT written"));
    return;
    ret = IIO_lib_itf.iio_channel_attr_write_longlong(phy_chn_rx, "rf_bandwidth", rxcfg.bw_hz);
    if (ret < 0)
    ListBox->AppendString( wxString( "rf_bandwidth attribute for RX NOT written" ) );
    return;
    ret = IIO_lib_itf.iio_channel_attr_write_longlong(phy_chn_rx, "sampling_frequency", rxcfg.fs_hz );
    if (ret < 0)
    ListBox->AppendString(wxString( "sampling_frequency attribute for RX NOT written" ) );
    return;
    ret = IIO_lib_itf.iio_channel_attr_write_double( phy_chn_rx, "hardwaregain", rxcfg.gain_db );
    if (ret < 0)
    ListBox->AppendString(wxString("hardwaregain attribute for RX NOT written"));
    return;
    ret = IIO_lib_itf.iio_channel_attr_write_bool(
    IIO_lib_itf.iio_device_find_channel(phydev, "altvoltage0", true)
    , "powerdown", true ); // Turn OFF RX LO
    if (ret < 0)
    ListBox->AppendString( wxString("powerdown attribute on avoltage0 NOT written") );
    return;
    IIO_lib_itf.iio_device_find_channel(phydev, "altvoltage1", true)
    , "frequency", txcfg.lo_hz ); // Set TX LO frequency
    if (ret < 0)
    ListBox->AppendString(wxString("frequency attribute on avoltage1 NOT written"));
    return;
    ListBox->AppendString( "* Initializing streaming channels" );
    tx0_i = IIO_lib_itf.iio_device_find_channel(tx, "voltage0", true);
    if (!tx0_i)
    ListBox->AppendString(wxString("Tx0_i buffer NOT found"));
    return;ReadAllPlutoSettings
    // tx0_i = IIO_lib_itf.iio_device_find_channel(tx, "altvoltage0", true);
    tx0_q = IIO_lib_itf.iio_device_find_channel(tx, "voltage1", true);
    if (!tx0_q)
    ListBox->AppendString(wxString("Tx0_q buffer NOT found"));
    return;
    // tx0_q = IIO_lib_itf.iio_device_find_channel(tx, "altvoltage1", true);
    ListBox->AppendString( "* Enabling IIO streaming channels\n" );
    IIO_lib_itf.iio_channel_enable(tx0_i);
    IIO_lib_itf.iio_channel_enable(tx0_q);
    int iret = AD9361_lib_itf.ad9361_set_bb_rate(IIO_lib_itf.iio_context_find_device(ctx, "ad9361-phy"), txcfg.fs_hz);
    if ( iret < 0 )
    ListBox->AppendString( wxString( "ad9361-phy bb rate NOT written" ) );
    return;
    ListBox->AppendString( "* Creating TX buffer" );
    tx_buffer = IIO_lib_itf.iio_device_create_buffer( tx, NUM_SAMPLES, false );
    if ( !tx_buffer ) {
    ListBox->AppendString( "Could not create TX buffer." );
    return;
    // ntx = 0;
    iret = IIO_lib_itf.iio_channel_attr_write_bool(
    IIO_lib_itf.iio_device_find_channel( IIO_lib_itf.iio_context_find_device(ctx, "ad9361-phy"), "altvoltage1", true )
    , "powerdown", false); // Turn ON TX LO
    if (iret < 0)
    ListBox->AppendString(wxString("altvoltage1 powerdown NOT written"));
    return;
    ptx_buffer = (short*)IIO_lib_itf.iio_buffer_start(tx_buffer);
    ListBox->AppendString("* Transmit starts...\n");
    PlutoInitDone = true;
    ListBox->AppendString(" ");
    ReadAllPlutoSettings( &txcfg, &rxcfg );
    //////     The ReadAllPlutoSettings(...) reread all of the settings. It is here  ///////////
    void CPlutoDlg::ReadAllPlutoSettings( struct stream_cfg * p_txcfg, struct stream_cfg * p_rxcfg )
    // IIO_lib_itf.iio_device_find_channel( phydev, "voltage0", true);
    char buf[200];
    ssize_t sz = IIO_lib_itf.iio_channel_attr_read( phy_chn_tx, "rf_port_select", (char*)txcfg.rfport, 10 );
    if (sz != 1)
    IIO_lib_itf.iio_strerror( sz, buf, 200 );
    ListBox->AppendString(wxString( buf ));
    // ListBox->AppendString(wxString("rf port TX not correctly read "));
    sz = IIO_lib_itf.iio_channel_attr_read_longlong( phy_chn_tx, "rf_bandwidth", &txcfg.bw_hz );
    if (sz != 0)
    IIO_lib_itf.iio_strerror(sz, buf, 200);
    ListBox->AppendString(wxString(buf));
    // ListBox->AppendString( wxString( "rf_bandwidth TX not correctly read " ) );
    sz = IIO_lib_itf.iio_channel_attr_read_longlong( phy_chn_tx, "sampling_frequency", &txcfg.fs_hz );
    if (sz != 0)
    // ListBox->AppendString( wxString( "sampling_frequency TX not correctly read " ) );
    sz = IIO_lib_itf.iio_channel_attr_read_double( phy_chn_tx, "hardwaregain", &txcfg.gain_db );
    if (sz != 0)
    // ListBox->AppendString(wxString("hardwaregain TX not correctly read "));
    sz = IIO_lib_itf.iio_channel_attr_read_longlong( phy_chn_tx, "frequency", &txcfg.lo_hz);
    if (sz != 0)
    // ListBox->AppendString(wxString("frequency TX not correctly read "));
    sz = IIO_lib_itf.iio_channel_attr_read( phy_chn_rx, "rf_port_select", (char*)rxcfg.rfport, 10 );
    if (sz != 1)
    // ListBox->AppendString(wxString("rf port RX not correctly read "));
    sz = IIO_lib_itf.iio_channel_attr_read_longlong( phy_chn_rx, "rf_bandwidth", &rxcfg.bw_hz );
    if (sz != 1)
    // ListBox->AppendString(wxString("rf_bandwidth RX not correctly read "));
    sz = IIO_lib_itf.iio_channel_attr_read_longlong( phy_chn_rx, "sampling_frequency", &rxcfg.fs_hz );
    if (sz != 1)
    // ListBox->AppendString(wxString("sampling_frequency RX not correctly read "));
    sz = IIO_lib_itf.iio_channel_attr_read_double( phy_chn_rx, "hardwaregain", &rxcfg.gain_db );
    if (sz != 1)
    // ListBox->AppendString(wxString("hardwaregain RX not correctly read "));
    sz = IIO_lib_itf.iio_channel_attr_read_longlong( phy_chn_rx, "frequency", &rxcfg.lo_hz);
    if (sz != 1)
    // ListBox->AppendString(wxString("frequency RX not correctly read "));
    Not one of the readout is correct,
    Thank You
    Pietro
  • Can you provide a simple example in just C?
    -Travis
  • Hi Travis
    The initialization appears correct ..
    The readout is totally out of order.
    printf("* Initializing streaming channels\n");
    tx0_i = iio_device_find_channel(tx, "voltage0", true);
    if (!tx0_i)
    tx0_i = iio_device_find_channel(tx, "altvoltage0", true);
    tx0_q = iio_device_find_channel(tx, "voltage1", true);
    if (!tx0_q)
    tx0_q = iio_device_find_channel(tx, "altvoltage1", true);
    // Up to here it is correct
    // Now I want to read and nothing works
    struct stream_cfg txcfg_read;
    txcfg_read.rfport = " ";
    txcfg_read.bw_hz = 0;
    txcfg_read.fs_hz = 0;
    txcfg_read.gain_db = 0;
    sz = iio_channel_attr_read(tx0_i, "rf_port_select", (char*)txcfg_read.rfport, 10);
    int err2 = iio_channel_attr_read_longlong(tx0_i, "rf_bandwidth", &txcfg_read.bw_hz);
    err2 = iio_channel_attr_read_longlong(tx0_i, "sampling_frequency", &txcfg_read.fs_hz);
    err2 = iio_channel_attr_read_double(tx0_i, "hardwaregain", &txcfg_read.gain_db);
    Thank     You
    Pietro
  • It looks like you reading channels from the wrong device.
    For Pluto there are 3 relevant IIO devices...
    Can you start with the iio_info command?
