ADRV9002 tuning failed error
Category: Choose a category
I'm using ADRV9002 with my custom board. I try to implement Petalinux for my ZYNQ MPSoC. During the boot stage, I get an error which is;
[ 28.092301] adrv9002 spi3.0: Interface tuning failed: -5
[ 28.098932] cf_axi_adc: probe of 84a00000.axi-adrv9002-rx-lpc failed with error -5
After boot, I couldn't find ADRV9002 device on iio:devices. What could be the reason for that? I want to use only RX1/TX1 for ADRV9002. On HDL reference design, I disabled RX2/TX2 signals from IP Core.
    How is you devicetree looking like? Did you only specify rx0 and tx0 as adi,channels? By the way, what compatible string did you use?
    Dragos
    I'm trying to enable only RX1 and TX1. I want to disable RX2 and TX2. For this, I changed .json file. For RX, I changed .rxInitChannelMast to "129". For TX, I set "4". Should I change another configuration to disable RX2 and TX2?
    The proper way to do this is to generate a new profile (+stream) via TES with the second channel disabled... You then have two options:
    1) You compile this new profile together with the kernel (as we do right now) and make it the default one. Look at these commits for examples:
    https://github.com/analogdevicesinc/linux/commit/87ed5de3d6a8c14a5707782b2a4e80065f11f5b6
    https://github.com/analogdevicesinc/linux/commit/a2351866d1f3a6d249173bb71a65994cb8f73292
    You can just overwrite the existing ones so that the filename is the same and you do not have to change the driver.
    2) You compile the driver as a module and place your new profiles in /sys/firmware. This was never tested but it should work. If it doesn't then I need to fix it.
    - Nuno Sá
  • In your proposed profile on github, "rxInitChannelMask" is 83 but it is 65 in our profile where TX1 and RX1 is just enable. Where does this difference come from? And does it cause such problem defined above?
    Regards
  • Mine is 83 because the default profile we are using has both RX1/RX2 enabled... You should use TES to create a profile which disables RX2/TX2. Manually editing the files is asking for problems.
    - Nuno Sá
  •  I disabled RX2/TX2 channels, in TES and "rxInitChannelMask" is 65. We're getting same error, it happens sometimes. Is there any advice for us?
  • Sorry for the late reply... You can try to compile the kernel with debug enabled. Set the line
    "#define DEBUG"
    in the beginning of the adrv9002.c and adrv9002_conv.c files and then paste here the bootup messages. It should tell used if the tuning is failing for RX or TX
    - Nuno Sá
  • [   25.682023] Test Point register address : 1028
    [   25.686460] pn error in c:0, reg: 02
    [   25.695589] Test Point register address : 1028
    [   25.700026] pn error in c:0, reg: 02
    [   25.709090] Test Point register address : 1028
    [   25.713521] pn error in c:0, reg: 02
    [   25.722655] Test Point register address : 1028
    [   25.727090] pn error in c:0, reg: 02
    [   25.736217] Test Point register address : 1028
    [   25.740657] pn error in c:0, reg: 02
    [   25.749787] Test Point register address : 1028
    [   25.754224] pn error in c:0, reg: 02
    [   25.763290] Test Point register address : 1028
    [   25.767731] pn error in c:0, reg: 02
    [   25.776862] Test Point register address : 1028
    [   25.781297] pn error in c:0, reg: 02
    [   25.790426] Test Point register address : 1028
    [   25.794865] pn error in c:0, reg: 02
    [   25.804002] Test Point register address : 1028
    [   25.808439] pn error in c:0, reg: 02
    [   25.817579] Test Point register address : 1028
    [   25.822014] pn error in c:0, reg: 02
    [   25.831146] Test Point register address : 1028
    [   25.835582] pn error in c:0, reg: 02
    [   25.844711] Test Point register address : 1028
    [   25.849149] pn error in c:0, reg: 02
    [   25.858279] Test Point register address : 1028
    [   25.862714] pn error in c:0, reg: 02
    [   25.871847] Test Point register address : 1028
    [   25.876282] pn error in c:0, reg: 02
    [   25.885412] Test Point register address : 1028
    [   25.889851] pn error in c:0, reg: 02
    [   25.898978] Test Point register address : 1028
    [   25.903415] pn error in c:0, reg: 02
    [   25.912541] Test Point register address : 1028
    [   25.916978] pn error in c:0, reg: 02
    [   25.926160] Test Point register address : 1028
    [   25.930593] pn error in c:0, reg: 02
    [   25.939745] Test Point register address : 1028
    [   25.944177] pn error in c:0, reg: 02
    [   25.953324] Test Point register address : 1028
    [   25.957761] pn error in c:0, reg: 02
    [   25.966827] Test Point register address : 1028
    [   25.971260] pn error in c:0, reg: 02
    [   25.980408] Test Point register address : 1028
    [   25.984843] pn error in c:0, reg: 02
    [   25.993990] Test Point register address : 1028
    [   25.998426] pn error in c:0, reg: 02
    [   26.007571] Test Point register address : 1028
    [   26.012010] pn error in c:0, reg: 02
    [   26.021139] Test Point register address : 1028
    [   26.025581] pn error in c:0, reg: 02
    [   26.034723] Test Point register address : 1028
    [   26.039162] pn error in c:0, reg: 02
    [   26.048308] Test Point register address : 1028
    [   26.052747] pn error in c:0, reg: 02
    [   26.061892] Test Point register address : 1028
    [   26.066333] pn error in c:0, reg: 02
    [   26.075480] Test Point register address : 1028
    [   26.079915] pn error in c:0, reg: 02
    [   26.089060] Test Point register address : 1028
    [   26.093499] pn error in c:0, reg: 02
    [   26.102641] Test Point register address : 1028
    [   26.107076] pn error in c:0, reg: 02
    [   26.116216] Test Point register address : 1028
    [   26.120650] pn error in c:0, reg: 02
    [   26.129778] Test Point register address : 1028
    [   26.134220] pn error in c:0, reg: 02
    [   26.143363] Test Point register address : 1028
    [   26.147801] pn error in c:0, reg: 02
    [   26.156927] Test Point register address : 1028
    [   26.161359] pn error in c:0, reg: 02
    [   26.170424] Test Point register address : 1028
    [   26.174856] pn error in c:0, reg: 02
    [   26.184004] Test Point register address : 1028
    [   26.188441] pn error in c:0, reg: 02
    [   26.197585] Test Point register address : 1028
    [   26.202017] pn error in c:0, reg: 02
    [   26.211166] Test Point register address : 1028
    [   26.215600] pn error in c:0, reg: 02
    [   26.224746] Test Point register address : 1028
    [   26.229184] pn error in c:0, reg: 02
    [   26.238327] Test Point register address : 1028
    [   26.242764] pn error in c:0, reg: 02
    [   26.251905] Test Point register address : 1028
    [   26.256345] pn error in c:0, reg: 02
    [   26.265489] Test Point register address : 1028
    [   26.269929] pn error in c:0, reg: 02
    [   26.279072] Test Point register address : 1028
    [   26.283505] pn error in c:0, reg: 02
    [   26.292650] Test Point register address : 1028
    [   26.297089] pn error in c:0, reg: 02
    [   26.306233] Test Point register address : 1028
    [   26.310673] pn error in c:0, reg: 02
    [   26.319817] Test Point register address : 1028
    [   26.324257] pn error in c:0, reg: 02
    [   26.333401] Test Point register address : 1028
    [   26.337842] pn error in c:0, reg: 02
    [   26.346973] Test Point register address : 1028
    [   26.351411] pn error in c:0, reg: 02
    [   26.360551] Test Point register address : 1028
    [   26.364982] pn error in c:0, reg: 02
    [   26.374049] Test Point register address : 1028
    [   26.378480] pn error in c:0, reg: 02
    [   26.387630] Test Point register address : 1028
    [   26.392066] pn error in c:0, reg: 02
    [   26.401211] Test Point register address : 1028
    [   26.405649] pn error in c:0, reg: 02
    [   26.414793] Test Point register address : 1028
    [   26.419225] pn error in c:0, reg: 02
    [   26.428369] Test Point register address : 1028
    [   26.432809] pn error in c:0, reg: 02
    [   26.441935] Test Point register address : 1028
    [   26.446366] pn error in c:0, reg: 02
    [   26.455495] Test Point register address : 1028
    [   26.459933] pn error in c:0, reg: 02
    [   26.469079] Test Point register address : 1028
    [   26.473519] pn error in c:0, reg: 02
    [   26.482668] Test Point register address : 1028
    [   26.487102] pn error in c:0, reg: 02
    [   26.496250] Test Point register address : 1028
    [   26.500686] pn error in c:0, reg: 02
    [   26.509832] Test Point register address : 1028
    [   26.514270] pn error in c:0, reg: 02
    [   26.523416] Test Point register address : 1028
    [   26.527854] pn error in c:0, reg: 02
    [   26.537000] Test Point register address : 1028
    [   26.541439] pn error in c:0, reg: 02
    [   26.545006] SAMPL CLK: 15360000 tuning: RX1
    [   26.549179]   0:1:2:3:4:5:6:7
    [   26.552156] 0:# # # # # # # #
    [   26.555211] 1:# # # # # # # #
    [   26.558262] 2:# # # # # # # #
    [   26.561325] 3:# # # # # # # #
    [   26.564379] 4:# # # # # # # #
    [   26.567433] 5:# # # # # # # #
    [   26.570483] 6:# # # # # # # #
    [   26.573544] 7:# # # # # # # #
    [   26.576737] Test Point 11 return function return 0
    [   26.576739] Test Point 12 max_cnt function 0
    [   26.581526] Test Point 4 adrv9002_axi_intf_tune function return -5
    [   26.585788] adrv9002 spi0.0: Interface tuning failed: -5
    [   26.598509] cf_axi_adc: probe of 84a00000.axi-adrv9002-rx-lpc failed with error -5
    Hi Nuno,
    I have uploaded a basic txt file containing the error. We are still getting it. We will appreciate any help we can get.
    Can you share the profile you're using so I can give it a try on my end? It would also be nice to have the complete debug information (the one printed in adrv9002.c - you need to define DEBUG as I said in the previous reply)... Still not sure but this might be some issue in your custom hdl.
    You mean, it does not always happen? How frequent does it happen?
    - Nuno Sá
      "clocks": {
        "deviceClock_kHz": 38400,
        "clkPllVcoFreq_daHz": 884736000,
        "clkPllHsDiv": 0,
        "clkPllMode": 0,
        "clk1105Div": 2,
        "armClkDiv": 6,
        "armPowerSavingClkDiv": 2,
        "refClockOutEnable": true,
        "auxPllPower": 2,
        "clkPllPower": 2,
        "padRefClkDrv": 0,
        "extLo1OutFreq_kHz": 0,
        "extLo2OutFreq_kHz": 0,
        "rfPll1LoMode": 0,
        "rfPll2LoMode": 0,
        "ext1LoType": 0,
        "ext2LoType": 0,
        "rx1RfInputSel": 0,
        "rx2RfInputSel": 0,
        "extLo1Divider": 2,
        "extLo2Divider": 2,
        "rfPllPhaseSyncMode": 0,
        "rx1LoSelect": 2,
        "rx2LoSelect": 2,
        "tx1LoSelect": 1,
        "tx2LoSelect": 1,
        "rx1LoDivMode": 0,
        "rx2LoDivMode": 0,
        "tx1LoDivMode": 0,
        "tx2LoDivMode": 0,
        "loGen1Select": 1,
        "loGen2Select": 1
      "rx": {
        "rxInitChannelMask": 129,
        "rxChannelCfg": [ {
            "profile": {
              "primarySigBandwidth_Hz": 10000000,
              "rxOutputRate_Hz": 61440000,
              "rxInterfaceSampleRate_Hz": 61440000,
              "rxOffsetLo_kHz": 0,
              "rxNcoEnable": false,
              "outputSignaling": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 20000000,
              "lpAdcCorner": 0,
              "adcClk_kHz": 1105920,
              "rxCorner3dB_kHz": 10000,
              "rxCorner3dBLp_kHz": 10000,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 1,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "gainTableType": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "scicBlk23DivFactor": 1,
                  "scicBlk23LowRippleEn": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 1,
                  "decBy2Hb3Blk17p1En": 0,
                  "decBy2Hb4Blk17p2En": 0,
                  "decBy2Hb5Blk19p1En": 0,
                  "decBy2Hb6Blk19p2En": 0
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 1,
                  "hbMux": 4,
                  "isGainCompEnabled": 0,
                  "gainComp9GainI": [ 16384, 16384, 16384, 16384, 16384, 16384 ],
                  "gainComp9GainQ": [ 0, 0, 0, 0, 0, 0 ]
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                    "dpInFifoTestDataSel": 0
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                    "rxWbNbCompPFirInMuxSel": 0,
                    "rxWbNbCompPFirEn": 1
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "lnaConfig": {
                "externalLnaPresent": false,
                "gpioSourceSel": 0,
                "externalLnaPinSel": 0,
                "settlingDelay": 0,
                "numberLnaGainSteps": 0,
                "lnaGainSteps_mdB": [ 0, 0, 0, 0 ],
                "lnaDigitalGainDelay": 0,
                "minGainIndex": 0
              "rxSsiConfig": {
                "ssiType": 2,
                "ssiDataFormatSel": 4,
                "numLaneSel": 1,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "lvdsIBitInversion": false,
                "lvdsQBitInversion": false,
                "lvdsStrobeBitInversion": false,
                "lvdsUseLsbIn12bitMode": 0,
                "lvdsRxClkInversionEn": false,
                "cmosDdrPosClkEn": false,
                "cmosClkInversionEn": false,
                "ddrEn": true,
                "rxMaskStrobeEn": false
            "profile": {
              "filterOrder": 1,
              "filterOrderLp": 1,
              "lpAdcCorner": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 2,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "gainTableType": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 1,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 1,
                  "hbMux": 4,
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 2,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "lnaConfig": {
                "gpioSourceSel": 0,
                "settlingDelay": 0,
                "minGainIndex": 0
              "rxSsiConfig": {
                "ssiType": 2,
                "numLaneSel": 1,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "ddrEn": true,
            "profile": {
              "primarySigBandwidth_Hz": 12500,
              "rxOutputRate_Hz": 0,
              "rxInterfaceSampleRate_Hz": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "rxCorner3dB_kHz": 0,
              "rxCorner3dBLp_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "gainTableType": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "scicBlk23DivFactor": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                    "rxWbNbCompPFirEn": 0
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "lnaConfig": {
                "gpioSourceSel": 0,
                "settlingDelay": 0,
                "minGainIndex": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "ssiDataFormatSel": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "ddrEn": true,
            "profile": {
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "gainTableType": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "lnaConfig": {
                "gpioSourceSel": 0,
                "settlingDelay": 0,
                "minGainIndex": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "ddrEn": true,
            "profile": {
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 50000000,
              "lpAdcCorner": 0,
              "rxCorner3dB_kHz": 100000,
              "rxCorner3dBLp_kHz": 100000,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 64,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "gainTableType": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 1,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 1,
                  "hbMux": 2,
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 1,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "lnaConfig": {
                "gpioSourceSel": 0,
                "settlingDelay": 0,
                "minGainIndex": 0
              "rxSsiConfig": {
                "ssiType": 2,
                "numLaneSel": 1,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "ddrEn": true,
            "profile": {
              "filterOrder": 1,
              "filterOrderLp": 1,
              "lpAdcCorner": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 128,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "gainTableType": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 1,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 1,
                  "hbMux": 2,
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 3,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "lnaConfig": {
                "gpioSourceSel": 0,
                "settlingDelay": 0,
                "minGainIndex": 0
              "rxSsiConfig": {
                "ssiType": 2,
                "numLaneSel": 1,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "ddrEn": true,
            "profile": {
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "gainTableType": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "lnaConfig": {
                "gpioSourceSel": 0,
                "settlingDelay": 0,
                "minGainIndex": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "ddrEn": true,
            "profile": {
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "gainTableType": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "lnaConfig": {
                "gpioSourceSel": 0,
                "settlingDelay": 0,
                "minGainIndex": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "ddrEn": true,
      "tx": {
        "txInitChannelMask": 4,
        "txProfile": [ {
            "txInputRate_Hz": 61440000,
            "txInterfaceSampleRate_Hz": 61440000,
            "txOffsetLo_kHz": 0,
            "validDataDelay": 0,
            "txBbf3dBCorner_kHz": 50000,
            "txPdBiasCurrent": 1,
            "txPdGainEnable": 0,
            "txPrePdRealPole_kHz": 1000000,
            "txPostPdRealPole_kHz": 530000,
            "txBbfPower": 2,
            "txExtLoopBackType": 0,
            "txExtLoopBackForInitCal": 0,
            "txPeakLoopBackPower": 0,
            "frequencyDeviation_Hz": 0,
            "txDpProfile": {
              "txPreProc": {
                "txPreProcSymbol0": 0,
                "txPreProcSymbol1": 0,
                "txPreProcSymbol2": 0,
                "txPreProcSymbol3": 0,
                "txPreProcSymMapDivFactor": 1,
                "txPreProcMode": 1,
                "txPreProcWbNbPfirIBankSel": 0,
                "txPreProcWbNbPfirQBankSel": 1
              "txWbIntTop": {
                "txInterpBy2Blk30En": 0,
                "txInterpBy2Blk28En": 0,
                "txInterpBy2Blk26En": 0,
                "txInterpBy2Blk24En": 0,
                "txInterpBy2Blk22En": 0,
                "txWbLpfBlk22p1En": 0
              "txNbIntTop": {
                "txInterpBy2Blk20En": 0,
                "txInterpBy2Blk18En": 0,
                "txInterpBy2Blk16En": 0,
                "txInterpBy2Blk14En": 0,
                "txInterpBy2Blk12En": 0,
                "txInterpBy3Blk10En": 0,
                "txInterpBy2Blk8En": 0,
                "txScicBlk32En": 0,
                "txScicBlk32DivFactor": 1
              "txIntTop": {
                "interpBy3Blk44p1En": 1,
                "sinc3Blk44En": 0,
                "sinc2Blk42En": 0,
                "interpBy3Blk40En": 1,
                "interpBy2Blk38En": 0,
                "interpBy2Blk36En": 0
              "txIntTopFreqDevMap": {
                "rrc2Frac": 0,
                "mpll": 0,
                "nchLsw": 0,
                "nchMsb": 0,
                "freqDevMapEn": 0,
                "txRoundEn": 1
              "txIqdmDuc": {
                "iqdmDucMode": 0,
                "iqdmDev": 0,
                "iqdmDevOffset": 0,
                "iqdmScalar": 0,
                "iqdmThreshold": 0,
                "iqdmNco": {
                  "freq": 0,
                  "sampleFreq": 61440000,
                  "phase": 0,
                  "realOut": 0
            "txSsiConfig": {
              "ssiType": 2,
              "numLaneSel": 1,
              "strobeType": 0,
              "lsbFirst": 0,
              "qFirst": 0,
              "txRefClockPin": 1,
              "ddrEn": true,
            "txBbfPower": 2,
            "txDpProfile": {
              "txPreProc": {
                "txPreProcMode": 1,
                "txPreProcWbNbPfirIBankSel": 2,
                "txPreProcWbNbPfirQBankSel": 3
              "txWbIntTop": {
              "txNbIntTop": {
                "txScicBlk32En": 0,
              "txIntTop": {
                "sinc3Blk44En": 0,
                "sinc2Blk42En": 0,
                "rrc2Frac": 0,
                "mpll": 0,
                "nchLsw": 0,
                "nchMsb": 0,
                "freqDevMapEn": 0,
                "txRoundEn": 1
              "txIqdmDuc": {
                "iqdmDucMode": 0,
                "iqdmDev": 0,
                "iqdmDevOffset": 0,
                "iqdmScalar": 0,
                "iqdmThreshold": 0,
                "iqdmNco": {
                  "freq": 0,
                  "phase": 0,
                  "realOut": 0
            "txSsiConfig": {
              "ssiType": 2,
              "numLaneSel": 1,
              "strobeType": 0,
              "lsbFirst": 0,
              "qFirst": 0,
              "txRefClockPin": 1,
              "ddrEn": true,
      "sysConfig": {
        "duplexMode": 1,
        "fhModeOn": 0,
        "numDynamicProfiles": 1,
        "mcsMode": 0,
        "mcsInterfaceType": 0,
        "adcTypeMonitor": 1,
        "pllLockTime_us": 750,
        "pllPhaseSyncWait_us": 0,
        "pllModulus": {
          "modulus": [ 8388593, 8388593, 8388593, 8388593, 8388593 ],
          "dmModulus": [ 8388593, 8388593 ]
        "warmBootEnable": false
      "pfirBuffer": {
        "pfirRxWbNbChFilterCoeff_A": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
          "coefficients": [ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0  ]
        "pfirRxWbNbChFilterCoeff_B": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
        "pfirRxWbNbChFilterCoeff_C": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
        "pfirRxWbNbChFilterCoeff_D": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
        "pfirTxWbNbPulShpCoeff_A": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
          "coefficients": [ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0  ]
        "pfirTxWbNbPulShpCoeff_B": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
        "pfirTxWbNbPulShpCoeff_C": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
        "pfirTxWbNbPulShpCoeff_D": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
        "pfirRxNbPulShp": [ {
            "numCoeff": 128,
            "symmetricSel": 0,
            "taps": 128,
            "gainSel": 2,
            "numCoeff": 128,
            "symmetricSel": 0,
            "taps": 128,
            "gainSel": 2,
        "pfirRxMagLowTiaLowSRHp": [ {
            "numCoeff": 21,
            "coefficients": [ -125, 482, -310, -914, 612, 2168, -861, -5306, -1145, 11988, 19587, 11988, -1145, -5306, -861, 2168, 612, -914, -310, 482, -125  ]
            "numCoeff": 21,
        "pfirRxMagLowTiaHighSRHp": [ {
            "numCoeff": 21,
            "coefficients": [ -940, -178, 1792, 2565, -566, -5836, -7722, -2815, 6471, 14694, 17836, 14694, 6471, -2815, -7722, -5836, -566, 2565, 1792, -178, -940  ]
            "numCoeff": 21,
        "pfirRxMagHighTiaHighSRHp": [ {
            "numCoeff": 21,
            "coefficients": [ 41, -241, 750, -1559, 2236, -1920, -262, 4378, -8850, 8452, 26718, 8452, -8850, 4378, -262, -1920, 2236, -1559, 750, -241, 41  ]
            "numCoeff": 21,
        "pfirRxMagLowTiaLowSRLp": [ {
            "numCoeff": 21,
            "coefficients": [ -125, 482, -310, -914, 612, 2167, -860, -5304, -1144, 11987, 19584, 11987, -1144, -5304, -860, 2167, 612, -914, -310, 482, -125  ]
            "numCoeff": 21,
        "pfirRxMagLowTiaHighSRLp": [ {
            "numCoeff": 21,
            "coefficients": [ -960, -177, 1876, 2631, -710, -6092, -7709, -2400, 6813, 14477, 17273, 14477, 6813, -2400, -7709, -6092, -710, 2631, 1876, -177, -960  ]
            "numCoeff": 21,
        "pfirRxMagHighTiaHighSRLp": [ {
            "numCoeff": 21,
            "coefficients": [ 41, -237, 739, -1536, 2208, -1908, -229, 4283, -8730, 8455, 26600, 8455, -8730, 4283, -229, -1908, 2208, -1536, 739, -237, 41  ]
            "numCoeff": 21,
        "pfirTxMagComp1": {
          "numCoeff": 21,
          "coefficients": [ 69, -384, 1125, -2089, 2300, -165, -5248, 12368, -13473, 4864, 34039, 4864, -13473, 12368, -5248, -165, 2300, -2089, 1125, -384, 69  ]
        "pfirTxMagComp2": {
          "numCoeff": 21,
        "pfirTxMagCompNb": [ {
            "numCoeff": 13,
            "coefficients": [ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ]
            "numCoeff": 13,
        "pfirRxMagCompNb": [ {
            "numCoeff": 13,
            "numCoeff": 13,
    Hi Nuno,
    Here is the .json file we have generated using TES. We have added <#define DEBUG> but there is no additional info in the Kernel messages. Is there any other debug media we can use?
    It happens like 8 of the 10 times of the power-up sequence. 2 of the 10 times approximately it calibrates LVDS lines.
