Can someone please tell me the proper method to modify ADI generated device tree nodes within PetaLinux?
I am trying to build a BSP with support for the AD9986 (which uses the same driver as the 9081). I am using zynqmp-zcu102-rev10-ad9081-m8-l4 for KERNEL_DTB and I can see the nodes populated for a 9081. I have tried to put my modifications in system-user.dtsi to remove/modify the generated nodes, however it seems meta-adi-xilinx gets generated after my layer changes. So the end result is I don't see any changes.
The layer readme (Link) talks about adding new (I assume non ADI nodes), but isn't clear on how to modify existing ones.
I was able to make some changes by editing meta-adi-xilinx/recipies-bsp/device-tree/device-tree.bbappend but I would rather not have to edit that layer.
Is there a better way to do this?
