ZC706 ADRV9371 devmem Command not found
Software Version: Raspbian Kuiper GNU/ Linux 10 buster
I am working with the ZC706 and ADRV9371 Evaluation Boards to test hardware.
For part of the testing, I would like to use devmem to read some of the AXI registers and memory directly.
The error I get when trying to use the "devmem" or "devmem2" command is:
"-bash: devmem: command not found"
I also tried both:
"apt-get install devmem"
and
"apt install devmem"
but get the error:
"E: Unable to locate package devmem"
Troubleshooting steps tried so far:
(Please bear with me if this isn't useful. I don't have much experience with Linux yet.)
Checking internet on the eval board's kernel:
"apt-get update" on the eval board seems to run correctly.
Remade the kernel:
1) I cloned the latest https://github.com/analogdevicesinc/linux
2) From "Building the Zynq Linux kernel and devicetrees from source" used "make zynq_xcomm_adv7511_defconfig"
3) Then, using "make menuconfig" made sure that "Filter access to /dev/mem/" is not selected. (Linux/arm 5.10.0 Kernel Configuration)
4) Build the kernel with "make -j5 UIMAGE_LOADADDR=0x8000 uImage"
5) The kernel is successfully remade and uImage file created, placed into SD card's boot.
6) I can see the eval board start and operate normally but still cannot use devmem.
I can see the devmem directory at "/linux/include/config/arch/has/" and devmem.h under "/linux/include/config" so it seems to be part of the kernel.
Is there something else I should try to get this command working?
Thanks!
