Attempting to update adrv9009-zu11eg with adi_update_tools.sh fails with 'Unable to locate package libserialport-dev'
Product Number: adrv9009-zu11eg
Software Version: linaro 14.04, kernel 4.14.0-g8a57ede
Attempting to update adrv9009-zu11eg fails with 'Unable to locate package libserialport-dev'. Script output is:
root@analog:~/libserialport# sudo adi_update_tools.sh
2022-05-10 10:06:37 URL: github.com/analogdevicesinc 200 OK
 *** Updating linux_image_ADI-scripts BRANCH origin/m*ster ***
HEAD is now at ba69f07... adi_update_tools.sh: add 2021_R1 release
 *** Building linux_image_ADI-scripts ***
./adi_update_tools.sh has been updated, switching to new one
2022-05-10 10:06:38 URL: github.com/analogdevicesinc 200 OK
./adi_update_tools.sh script is the same, continuing
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libgtkdatabox-0.9.2-0-dev' instead of 'libgtkdatabox-dev'
Note, selecting 'libncurses5-dev' instead of 'ncurses-dev'
E: Unable to locate package libserialport-dev
Catastrophic error in prerequisite packages, please report error to:
https://ez.analog.com/community/linux-device-drivers/linux-software-drivers
I have tried installing libseriaport-dev without luck:
root@analog:~# sudo apt install libserialport-dev
and also building it myself (sigrok.org/wiki/Libserialport) but the output of the update script does not change!
Help would be appreciated!
  • It looks like you are on an old base image that cannot be upgraded. Please update to the latest: https://wiki.analog.com/resources/tools-software/linux-software/embedded_arm_images
    -Travis
  • Thanks for the reply. I have run the adi_update_boot.sh script, which appeared to complete successfully but running adi_update_tools.sh afterwards still fails as shown above.
    Output of running adi_update_boot.sh again:
    Verifying if ./adi_update_boot.sh is up to date...
    ./adi_update_boot.sh is up to date, continuing...
    Check latest available version...
    --2022-05-11 08:09:40--  swdownloads.analog.com/.../
    2019_r2/latest_boot.txt
    Resolving swdownloads.analog.com (swdownloads.analog.com)... 104.84.68.188
    Connecting to swdownloads.analog.com (swdownloads.analog.com)|104.84.68.188|:80.
    .. connected.
    HTTP request sent, awaiting response... 301 Moved Permanently
    Connecting to swdownloads.analog.com (swdownloads.analog.com)|104.84.68.188|:80... connected.
    Location: swdownloads.analog.com/.../latest_boot.txt [following]
    --2022-05-11 08:09:41--  swdownloads.analog.com/.../latest_boot.txt
    Connecting to swdownloads.analog.com (swdownloads.analog.com)|104.84.68.188|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 160 [text/plain]
    Saving to: ‘latest_boot.txt’
         0K                                                       100% 18.8M=0s
    2022-05-11 08:09:41 (18.8 MB/s) - ‘latest_boot.txt’ saved [160/160]
    Vim: Warning: Output is not to a terminal
    [?1cESC[24;1H"latest_boot.txt" [noeol][dos] 3L, 160C^M
    "latest_boot.txt" 3L, 159C written^MESC[?25hESC[?0c
    Latest version available: 2021_07_27
    Release: 2019_r2
    Current version detected: 2021_07_27
    Release: 2019_R2
    Already up to date!
  • E: Unable to locate package libserialport-dev
    "libserialport-dev" package is  not installed in Kuiper 2019_R2 (last released version).
    adi_update_tools.sh script can be run with parameters like: "dev", "2019_R1", "2019_R2" etc.
    Running it with no parameter will use a default value - which was already updated to next release version (see third line from log that says about 2021_R1). We are expecting to publish a prerelease image of 2021_R1 during next days.
    You can follow this wiki page to check whenever the new Kuiper version will be published and update to it.
    Until then you can run:
    adi_update_tools.sh 2019_R2
    that should work fine on a SD card with 2019_R2 image.
