ADRV9002 + ZCU102 Profile Load
I'm trying to load a profile that I've created in TES (0.20.0), using iio-scope (0.14).
We've gone the Petalinux build route using the 2019_R2 branch on a ZCU102 system.
When loading a profile through iio-scope, i'm getting this error for any json profile i try and load:
I am able to load profiles through sysfs however, but had a couple questions on this.
For the default profile that comes with the meta-adi recipes, it appears that RX1 and TX1 can both be in the ensm 'rf_enabled' state.
We've tested this through iio-scope, and it appears you can transmit and receive at the same time.
When i load a different profile, RX1/TX1 and RX2/TX2 all start in the 'primed' state, and only one of RX or TX of each pair can be enabled at a given time.
(i.e. if you have RX1 in the rf_enabled state, TX1 refuses to also go into the rf_enabled state and vice versa).
If you try and write this state through sysfs (using out_voltage0_ensm_mode for example), you get a write error stating: 'write error: Operation not permitted'.
Ultimately we're trying to override the default profile at boot and would like similar system behavior to what the default ADI profile seems to have.
~Seth
  • I'm trying to load a profile that I've created in TES (0.20.0), using iio-scope (0.14).
    The profile loading has changed a bit in the master branch of IIO-Scope. Can you try the latest artifact: iio-oscilloscope 1.0.641 - AppVeyor
    This is dependent on the profile itself. You can only transmit and receiver with a FDD (not TDD) profile.
    If you want to change the default boot profile you will need to change the profile built against:
    https://github.com/analogdevicesinc/linux/blob/2aa7ac113716f339ecfb57d5a9ea016d47cd7a46/drivers/iio/adc/navassa/adrv9002.c#L4650
    Located in the firmware folder: linux/Navassa_CMOS_profile.json at master · analogdevicesinc/linux (github.com)
    Otherwise add a profile load to your rc.local or similar init mechanism.
    -Travis
  • Thanks for responding so quick Travis!
    It looks like with the newer version of iio-scope, it is still failing to load a profile. Since we're able to do this through other means, its not a show stopper.
    This is good to know- we're trying to get a data sample rate of 51.2MSPS, and this only appears to be achievable through TDD: Configuration #4. For the 'Custom' configuration setup, it looks like the sample rate and its derivatives fall within the dead zones for the PLL's. Is it possible to get a 51.2MSPS data rate with FDD mode?
    Yup, this is the approach we've been taking- we're patching that particular file in the kernel and that mechanism appears to be working.
    Thanks again,
    ~Seth
  • For the 'Custom' configuration setup, it looks like the sample rate and its derivatives fall within the dead zones for the PLL's. Is it possible to get a 51.2MSPS data rate with FDD mode?
    Post this question in the ADRV9001-ADRV9007 support. They might know over there the limitation. They will ask you to post the TES GUI screenshots of what you are trying to do.
    -Travis
