Hi
I'm trying to set up an ADV7282 Video Decoder with a iMX8M Mini Board. For that, I have enabled building of the ADV7180 driver in the Kernel (CONFIG_VIDEO_ADV7180=m) and changed the device tree for the ADV7282 Video Decoder.
My Device Tree:
&csi1_bridge { fsl,mipi-mode; status = "okay"; port { csi1_ep: endpoint { remote-endpoint = <&csi1_mipi_ep>; }; }; }; &i2c2 { clock-frequency = <100000>; pinctrl-names = "default", "gpio"; pinctrl-0 = <&pinctrl_i2c2>; pinctrl-1 = <&pinctrl_i2c2_gpio>; scl-gpios = <&gpio5 16 GPIO_ACTIVE_HIGH>; sda-gpios = <&gpio5 17 GPIO_ACTIVE_HIGH>; status = "okay"; adv728x_mipi1: adv728x_mipi1@21 { status = "okay"; compatible = "adi,adv7282-m"; /* compatible = "adv,adv7180";*/ reg = <0x21>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_csi1>; clocks = <&clk IMX8MM_CLK_CLKO1>; clock-names = "csi_mclk"; /* Disabled CLKO2, since VAR-SOM-MX8M-MINI camera expansion board uses * its own oscillator. Enable CLK02 if your design requires it */ #if 0 assigned-clocks = <&clk IMX8MM_CLK_CLKO1>; assigned-clock-parents = <&clk IMX8MM_CLK_24M>; assigned-clock-rates = <24000000>; #endif csi_id = <0>; /* pwn-gpios = <&gpio5 12 GPIO_ACTIVE_HIGH>; rst-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; */ mclk = <24000000>; mclk_source = <0>; cvbs = <1>; port { adv728x_mipi1_ep: endpoint { remote-endpoint = <&mipi1_sensor_ep>; }; }; }; }; &mipi_csi_1 { #address-cells = <1>; #size-cells = <0>; status = "okay"; port { mipi1_sensor_ep: endpoint@1 { remote-endpoint = <&adv728x_mipi1_ep>; data-lanes = <1>; csis-hs-settle = <13>; csis-clk-settle = <2>; /*csis-wclk;*/ }; csi1_mipi_ep: endpoint@2 { remote-endpoint = <&csi1_ep>; }; }; };
I have also added the following snippet to mipi_csis_formats in github.com/.../mxc_mipi_csi.c
, { .code = MEDIA_BUS_FMT_UYVY8_2X8, .fmt_reg = MIPI_CSIS_ISPCFG_DOUBLE_CMPNT | MIPI_CSIS_ISPCFG_FMT_YCBCR422_8BIT, .data_alignment = 16, }
It is initialized correctly
# dmesg | grep adv [ 5.663585] adv7180 1-0021: chip found @ 0x21 (30a30000.i2c) [ 5.793635] mxc_mipi-csi 32e30000.mipi_csi: Registered sensor subdevice: adv7180 1-0021
But capturing doesn't work. It doesn't get any data to capture.
# gst-launch-1.0 v4l2src device=/dev/video0 norm=PAL ! jpegenc ! avimux ! filesink location=mjpeg.avi Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Setting pipeline to PLAYING ... New clock: GstSystemClock
