AD7879 DAV Interrupt
Hello.
The AD7879-1 is connected using the I2C interface of the custom board.
Linux is running on the custom board.
Before installing the driver, i2c-tool is used to check the basic operation, and the initialization is performed as follows.
sudo i2cset -y 0 0x2c 0x02 0x0010 w
sudo i2cset -y 0 0x2c 0x02 0x40e3 w
sudo i2cset -y 0 0x2c 0x03 0xd0f0 w
sudo i2cset -y 0 0x2c 0x01 0x8dff w
After that, if you read the registers 0x08 to 0x0B, you can confirm that the value changes depending on the touch position of the touch panel.
sudo i2cget -y 0 0x2c 0x08 w
sudo i2cget -y 0 0x2c 0x09 w
sudo i2cget -y 0 0x2c 0x0a w
sudo i2cget -y 0 0x2c 0x0b w
However, the value of register 0x0A can always be read by 0x0000.
I have the following questions.
1.I recognize that the dav interrupt will be low when the adc conversion is completed by the above initialization. Is this correct?
2.I recognize that the dav interrupt becomes HIGH due to a timeout even if the adc conversion data is not read. Is this correct?
   In the case of the above setting value, since Register1:TMR is set to 0xFF, can we think that the timeout time is 9.44mS?
3.Is it correct that register 0x0A can always read 0x0000?
   Is it better to think that there is a hardware factor or a problem with the software initialization value?
Thanks.
Koji Okuda
