ADRV9002 Programming via libiio
Greetings;
I have been reviewing various documents/code, including:
TES Software generated output code
The SDK code
The Linux Driver (from the R2019_R2 release)
The ADRV9002-iiostream.c code.
I hae the following questions:
1) the ADRV9002-iiostream.c routine makes this call:
iio_channel_attr_write_longlong (chan, "TX1_LO_frequency", val);
- to change the TX1 Local Oscillator value.
- Can this also apply to the RX LO Frequency?? (our application is RX only, no TX)
- Is this call here, due to previously undocumented Driver setup that maybe "links" these LO's? (based upon the Users Guide documentation)
2. Can I assume that the ADRV9002 driver provided contains the TES generated code that was generated for the specific characteristics of the ZED board the ADRV9002 EVAL board?
- How does one modify/update the driver (via patches) regarding the "configuration structures" that the TES code outputs? (specifically for the REF clock input change we need to do).
3. Looking at the TES generated code, there is alot of setup/initialization for this part, w.r.t the "configuration structures", the loading of profiles, the loading of the onboard microcontroller and it's firmware. None of this seems to be present in the ADRV9002-iiostream.c code. Can I assume this is done by the driver?
- Is there a way to "override" the driver setup to re-initialize the device to this level of detail from user space once the driver has been loaded? (understanding that the part may need to be shutdown, reset, etc in order enforce this low-level re-initialization).
4. I reviewed the libiio call path for the iio_channel_attr_write_longlong() which, from user space, seems to resolve down to a write to SYSFS for the "local" setup. At the driver level, I believe will ultimately resolve to calling the correct sequence of lower level API calls in adrv9002_phy_lo_write() that will change the part's state as documented in the Users Guide in order to affect a change in the LO. Can this be confirmed? This is a follow up to question 1 about changing the RX LO. I understand this may be dependent upon the LO mux setup previously set by the driver via the "configuration structures".
I look foward to your reply.
Stephen Beckwith
  • - Can this also apply to the RX LO Frequency?? (our application is RX only, no TX)
    Yes. Note that this is also dependent on the LO mapping in the profile on what effect this really has.
    This is just an example but refer to my answer above.
    You are not expected to modify the driver code. You can update either devicetree, or configure the part through IIO attributes (including the profile).
    The re-initialization in TES is equivalent to changing a profile with the Linux driver.
    Yes. The driver uses the API from the adrv9001 SDK at the bottom.
    -Travis
  • Travis;
      Thank You so very much for your quick reply.  You just made my week!
    RE: LO setup - Yep, understand this
    RE: Changes - Oh, devicetree, yea, that would be the place.  When I started with Linux, it was "pre-devicetree" days, though the PPC's we were using at the time (different company) were just starting to arrive.  I'll check this out, thank you!  I'll research the profile setup (I seem to recall an answer/document that shows this being written via sysfs).
    RE: Confirmation - Thank You!!
    I'm sure I'll have some more questions on the programming, once we get our updated board back in-house after the Holidays.
    Happy Holidays to your and yours.
    Regards
    Stephen Beckwith
