ADRV9364-z7020 evaluation board custom device tree
The user encountered issues building a Linux image for the ADRV9364-z7020 evaluation board using Petalinux v2021.1 with a custom device tree. The build failed during the `do_configure` task due to the `KERNEL_DTB_PATH` being set to `${WORKDIR}`, causing a recursive copy error. The solution involved removing `system-top.dts` from `SRC_URI_append` and setting `KERNEL_DTB_PATH` to the correct path of `system-top.dts`. However, the user then faced another error due to the missing `system-conf.dtsi` file, which should be generated during the `petalinux-build` process.
Dear all,
I have an ADRV9364-z7020 evaluation board and I'm trying to build without success a Linux image by using a customized device-tree through Petalinux v2021.1.
After following the steps described in this Link about how to add a custom devicetree not supported by meta-adi, once executing the petalinux-build it crashes while performing the run.do_configure.2933 for our custom devicetree. I leave below the build.log and also the log.do_configure.2933 for further information you may need in order to give me some hints about which may be the cause for the not correctly compiling.
You will also notice that there are so many files copied to path '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/*' that they already exist. I'm wondering if this is also normal or may be related to the not correctly configuration of our custom devicetree.
build.log file:
[INFO] Sourcing buildtools
[INFO] Building project
[INFO] Sourcing build environment
SDK environment now set up; additionally you may now run devtool to perform development tasks.
Run devtool --help for further details.
### Shell environment set up for builds. ###
You can now run 'bitbake <target>'
Common targets are:
    core-image-minimal
    core-image-full-cmdline
    core-image-sato
    core-image-weston
    meta-toolchain
    meta-ide-support
You can also run generated qemu images with a command like 'runqemu qemux86'.
Other commonly useful commands are:
 - 'devtool' and 'recipetool' handle common recipe tasks
 - 'bitbake-layers' handles common layer tasks
 - 'oe-pkgdata-util' handles common target package tasks
[INFO] Generating workspace directory
NOTE: Starting bitbake server...
NOTE: Started PRServer with DBfile: /home/agonga/petalinux/rita/build/cache/prserv.sqlite3, IP: 127.0.0.1, PORT: 34421, PID: 2422
INFO: Specified workspace already set up, leaving as-is
NOTE: Started PRServer with DBfile: /home/agonga/petalinux/rita/build/cache/prserv.sqlite3, IP: 127.0.0.1, PORT: 45011, PID: 2507
NOTE: Resolving any missing task queue dependencies
Sstate summary: Wanted 258 Found 115 Missed 143 Current 1463 (44% match, 91% complete)
NOTE: Executing Tasks
NOTE: Running setscene task 1675 of 1723 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/base-files/base-files_3.0.14.bb:do_package_write_rpm_setscene)
NOTE: Running noexec task 1 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/timezone/tzcode-default.bb:do_rm_work_all)
NOTE: recipe base-files-3.0.14-r89: task do_package_write_rpm_setscene: Started
NOTE: recipe base-files-3.0.14-r89: task do_package_write_rpm_setscene: Succeeded
NOTE: Setscene tasks completed
NOTE: Running noexec task 2 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/cwautomacros/cwautomacros_20110201.bb:do_rm_work_all)
NOTE: Running noexec task 160 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/glibc/cross-localedef-native_2.32.bb:do_rm_work_all)
NOTE: Running noexec task 942 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/fribidi/fribidi_1.0.10.bb:do_rm_work_all)
NOTE: Running noexec task 1417 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/tcp-wrappers/tcp-wrappers_7.6.bb:do_rm_work_all)
NOTE: Running noexec task 1490 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/libcroco/libcroco_0.6.13.bb:do_rm_work_all)
NOTE: Running noexec task 1749 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/atk/atk_2.36.0.bb:do_rm_work_all)
NOTE: Running noexec task 2644 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/dbus/dbus_1.12.20.bb:do_rm_work_all)
NOTE: Running noexec task 3012 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxft_2.3.3.bb:do_rm_work_all)
NOTE: Running noexec task 3013 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxrandr_1.5.2.bb:do_rm_work_all)
NOTE: Running noexec task 3162 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxcomposite_0.4.5.bb:do_rm_work_all)
NOTE: Running noexec task 3163 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxdamage_1.1.5.bb:do_rm_work_all)
NOTE: Running noexec task 3164 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxi_1.7.10.bb:do_rm_work_all)
NOTE: Running noexec task 3165 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxcursor_1.2.0.bb:do_rm_work_all)
NOTE: Running noexec task 3231 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/harfbuzz/harfbuzz_2.7.2.bb:do_rm_work_all)
NOTE: Running task 3413 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/meta-openembedded/meta-oe/recipes-support/libiio/libiio_git.bb:do_install)
NOTE: Running task 3455 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_configure)
NOTE: Running noexec task 3467 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxi_1.7.10.bb:do_build)
NOTE: Running noexec task 3468 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxtst_1.2.3.bb:do_rm_work_all)
NOTE: Running noexec task 3480 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/glibc/cross-localedef-native_2.32.bb:do_build)
NOTE: Running noexec task 3537 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/tcp-wrappers/tcp-wrappers_7.6.bb:do_build)
NOTE: Running noexec task 3595 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/dbus/dbus_1.12.20.bb:do_build)
NOTE: Running noexec task 3607 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/atk/atk_2.36.0.bb:do_build)
NOTE: Running noexec task 3619 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxft_2.3.3.bb:do_build)
NOTE: Running noexec task 3631 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/harfbuzz/harfbuzz_2.7.2.bb:do_build)
NOTE: Running noexec task 3643 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/fribidi/fribidi_1.0.10.bb:do_build)
NOTE: Running noexec task 3644 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/pango/pango_1.46.2.bb:do_rm_work_all)
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_install: Started
NOTE: Running noexec task 3656 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/pango/pango_1.46.2.bb:do_build)
NOTE: Running noexec task 3703 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/timezone/tzcode-default.bb:do_build)
NOTE: recipe device-tree-xilinx-v2021.1+gitAUTOINC+252758eb1f-r0: task do_configure: Started
NOTE: Running noexec task 3770 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxtst_1.2.3.bb:do_build)
NOTE: Running noexec task 3771 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/atk/at-spi2-core_2.36.1.bb:do_rm_work_all)
NOTE: Running noexec task 3783 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/atk/at-spi2-core_2.36.1.bb:do_build)
NOTE: Running noexec task 3784 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/atk/at-spi2-atk_2.34.2.bb:do_rm_work_all)
NOTE: Running noexec task 3796 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxcomposite_0.4.5.bb:do_build)
NOTE: Running noexec task 3808 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxdamage_1.1.5.bb:do_build)
NOTE: Running noexec task 3820 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxcursor_1.2.0.bb:do_build)
NOTE: Running noexec task 3832 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/xorg-lib/libxrandr_1.5.2.bb:do_build)
NOTE: Running noexec task 3844 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/atk/at-spi2-atk_2.34.2.bb:do_build)
NOTE: Running noexec task 3845 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-gnome/gtk+/gtk+3_3.24.22.bb:do_rm_work_all)
NOTE: Running noexec task 3857 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-gnome/gtk+/gtk+3_3.24.22.bb:do_build)
NOTE: Running noexec task 3869 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/cwautomacros/cwautomacros_20110201.bb:do_build)
NOTE: Running noexec task 4135 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/libcroco/libcroco_0.6.13.bb:do_build)
NOTE: Running noexec task 4136 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-gnome/librsvg/librsvg_2.40.21.bb:do_rm_work_all)
NOTE: Running task 4152 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/pango/pango_1.46.2.bb:do_rm_work)
NOTE: Running task 4154 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/cantarell-fonts/cantarell-fonts_git.bb:do_rm_work)
NOTE: recipe cantarell-fonts-0.0.25-r0: task do_rm_work: Started
NOTE: recipe pango-1.46.2-r0: task do_rm_work: Started
NOTE: recipe cantarell-fonts-0.0.25-r0: task do_rm_work: Succeeded
NOTE: Running task 4165 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-gnome/librsvg/librsvg_2.40.21.bb:do_rm_work)
NOTE: recipe pango-1.46.2-r0: task do_rm_work: Succeeded
NOTE: Running task 4180 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-graphics/ttf-fonts/liberation-fonts_2.00.1.bb:do_rm_work)
NOTE: recipe liberation-fonts-1_2.00.1-r0: task do_rm_work: Started
NOTE: recipe liberation-fonts-1_2.00.1-r0: task do_rm_work: Succeeded
NOTE: Running task 4196 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-gnome/gtk+/gtk+3_3.24.22.bb:do_rm_work)
NOTE: recipe librsvg-default-2.40.21-r0: task do_rm_work: Started
NOTE: recipe librsvg-default-2.40.21-r0: task do_rm_work: Succeeded
NOTE: Running noexec task 4197 of 5284 (virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-gnome/librsvg/librsvg_2.40.21.bb:do_build)
NOTE: Running task 4199 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-gnome/gnome/adwaita-icon-theme_3.36.1.bb:do_rm_work)
NOTE: recipe gtk+3-3.24.22-r0: task do_rm_work: Started
NOTE: recipe adwaita-icon-theme-3.36.1-r0: task do_rm_work: Started
NOTE: recipe gtk+3-3.24.22-r0: task do_rm_work: Succeeded
NOTE: Running task 4215 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-connectivity/avahi/avahi_0.8.bb:do_rm_work)
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_install: Succeeded
NOTE: Running task 4216 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/meta-openembedded/meta-oe/recipes-support/libiio/libiio_git.bb:do_package)
NOTE: recipe adwaita-icon-theme-3.36.1-r0: task do_rm_work: Succeeded
NOTE: Running task 4217 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/meta-openembedded/meta-oe/recipes-support/libiio/libiio_git.bb:do_populate_sysroot)
NOTE: recipe avahi-0.8-r0: task do_rm_work: Started
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_populate_sysroot: Started
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_package: Started
NOTE: recipe avahi-0.8-r0: task do_rm_work: Succeeded
NOTE: Running task 4219 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-connectivity/libnss-mdns/libnss-mdns_0.14.1.bb:do_rm_work)
NOTE: recipe libnss-mdns-0.14.1-r0: task do_rm_work: Started
NOTE: recipe libnss-mdns-0.14.1-r0: task do_rm_work: Succeeded
NOTE: Running task 4234 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-support/rng-tools/rng-tools_6.10.bb:do_rm_work)
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_populate_sysroot: Succeeded
NOTE: Running task 4250 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-connectivity/openssh/openssh_8.3p1.bb:do_rm_work)
NOTE: recipe rng-tools-6.10-r0: task do_rm_work: Started
NOTE: recipe rng-tools-6.10-r0: task do_rm_work: Succeeded
NOTE: Running task 4252 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/sudo/sudo_1.9.3.bb:do_rm_work)
NOTE: recipe openssh-8.3p1-r0: task do_rm_work: Started
NOTE: recipe sudo-1.9.3-r0: task do_rm_work: Started
NOTE: recipe openssh-8.3p1-r0: task do_rm_work: Succeeded
NOTE: Running task 4268 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/busybox/busybox_1.32.0.bb:do_rm_work)
NOTE: recipe sudo-1.9.3-r0: task do_rm_work: Succeeded
NOTE: Running task 4270 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/zip/zip_3.0.bb:do_rm_work)
NOTE: recipe zip-3.0-r2: task do_rm_work: Started
NOTE: recipe busybox-1.32.0-r0: task do_rm_work: Started
NOTE: recipe zip-3.0-r2: task do_rm_work: Succeeded
NOTE: Running noexec task 4271 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/zip/zip_3.0.bb:do_rm_work_all)
NOTE: Running noexec task 4272 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/zip/zip_3.0.bb:do_build)
NOTE: Running task 4273 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_fetch)
NOTE: recipe busybox-1.32.0-r0: task do_rm_work: Succeeded
NOTE: Running task 4288 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/init-ifupdown/init-ifupdown_1.0.bb:do_rm_work)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_fetch: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_fetch: Succeeded
NOTE: Running task 4289 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_prepare_recipe_sysroot)
NOTE: recipe init-ifupdown-1.0-r7: task do_rm_work: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_prepare_recipe_sysroot: Started
NOTE: recipe init-ifupdown-1.0-r7: task do_rm_work: Succeeded
NOTE: Running noexec task 4290 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/init-ifupdown/init-ifupdown_1.0.bb:do_rm_work_all)
NOTE: Running noexec task 4291 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/init-ifupdown/init-ifupdown_1.0.bb:do_build)
NOTE: Running task 4292 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_unpack)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_prepare_recipe_sysroot: Succeeded
NOTE: Running task 4307 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb:do_rm_work)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_unpack: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_unpack: Succeeded
NOTE: Running task 4308 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_patch)
NOTE: recipe modutils-initscripts-1.0-r7: task do_rm_work: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_patch: Started
NOTE: recipe modutils-initscripts-1.0-r7: task do_rm_work: Succeeded
NOTE: Running noexec task 4309 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb:do_rm_work_all)
NOTE: Running noexec task 4310 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb:do_build)
NOTE: Running task 4325 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-kernel/dtc/dtc_1.6.0.bb:do_rm_work)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_patch: Succeeded
NOTE: Running task 4328 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_configure)
NOTE: recipe dtc-1.6.0-r0: task do_rm_work: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_configure: Started
NOTE: recipe dtc-1.6.0-r0: task do_rm_work: Succeeded
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_configure: Succeeded
NOTE: Running task 4329 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_compile)
NOTE: Running task 4345 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/packagegroups/packagegroup-core-ssh-dropbear.bb:do_rm_work)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_compile: Started
NOTE: recipe packagegroup-core-ssh-dropbear-1.0-r1: task do_rm_work: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_compile: Succeeded
NOTE: Running task 4347 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/dropbear/dropbear_2020.80.bb:do_rm_work)
NOTE: recipe packagegroup-core-ssh-dropbear-1.0-r1: task do_rm_work: Succeeded
NOTE: Running task 4348 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_install)
NOTE: recipe dropbear-2020.80-r0: task do_rm_work: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_install: Started
NOTE: recipe dropbear-2020.80-r0: task do_rm_work: Succeeded
NOTE: Running task 4375 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_rm_work)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_install: Succeeded
NOTE: Running task 4376 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_package)
NOTE: recipe qemuwrapper-cross-1.0-r0: task do_rm_work: Started
NOTE: recipe qemuwrapper-cross-1.0-r0: task do_rm_work: Succeeded
NOTE: Running noexec task 4377 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_rm_work_all)
NOTE: Running noexec task 4378 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_build)
NOTE: Running task 4380 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_fetch)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_package: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_fetch: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_package: Succeeded
NOTE: Running task 4381 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_packagedata)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_packagedata: Started
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_package: Succeeded
NOTE: Running task 4382 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/meta-openembedded/meta-oe/recipes-support/libiio/libiio_git.bb:do_packagedata)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_packagedata: Succeeded
NOTE: Running task 4383 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_package_qa)
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_packagedata: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_package_qa: Started
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_packagedata: Succeeded
NOTE: Running task 4384 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/meta-openembedded/meta-oe/recipes-support/libiio/libiio_git.bb:do_package_qa)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_package_qa: Succeeded
NOTE: Running task 4386 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_package_write_rpm)
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_package_qa: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_package_write_rpm: Started
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_package_write_rpm: Succeeded
NOTE: Running task 4387 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_rm_work)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_rm_work: Started
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_package_qa: Succeeded
NOTE: Running task 4388 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/meta-openembedded/meta-oe/recipes-support/libiio/libiio_git.bb:do_package_write_rpm)
NOTE: recipe sysvinit-inittab-2.88dsf-r10: task do_rm_work: Succeeded
NOTE: Running noexec task 4389 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_rm_work_all)
NOTE: Running noexec task 4390 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_build)
NOTE: Running task 4392 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-core/sysvinit/sysvinit_2.97.bb:do_rm_work)
NOTE: recipe sysvinit-2.97-r0: task do_rm_work: Started
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_package_write_rpm: Started
NOTE: recipe sysvinit-2.97-r0: task do_rm_work: Succeeded
NOTE: Running task 4393 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/libad9361-iio/libad9361-iio_0.2.bb:do_fetch)
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_fetch: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_fetch: Succeeded
NOTE: Running task 4394 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_prepare_recipe_sysroot)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_prepare_recipe_sysroot: Started
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_package_write_rpm: Succeeded
NOTE: Running task 4395 of 5284 (/home/agonga/petalinux/rita/components/yocto/layers/meta-openembedded/meta-oe/recipes-support/libiio/libiio_git.bb:do_rm_work)
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_rm_work: Started
NOTE: recipe libiio-0.23+gitAUTOINC+fcf42460bd-r0: task do_rm_work: Succeeded
NOTE: Running task 4396 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_unpack)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_prepare_recipe_sysroot: Succeeded
NOTE: Running task 4397 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/fru-tools/fru-tools_0.8.1.5.bb:do_fetch)
NOTE: recipe fru-tools-0.8.1.5+gitAUTOINC+957cb9b2d4-r0: task do_fetch: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_unpack: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_unpack: Succeeded
NOTE: Running task 4398 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_patch)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_patch: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_patch: Succeeded
NOTE: Running task 4399 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_populate_lic)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_populate_lic: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_populate_lic: Succeeded
NOTE: Running task 4400 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_deploy_source_date_epoch)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_deploy_source_date_epoch: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_deploy_source_date_epoch: Succeeded
NOTE: Running task 4401 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_generate_toolchain_file)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_generate_toolchain_file: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_generate_toolchain_file: Succeeded
NOTE: Running task 4402 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_configure)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_configure: Started
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_fetch: Succeeded
NOTE: Running task 4403 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/libad9361-iio/libad9361-iio_0.2.bb:do_prepare_recipe_sysroot)
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_prepare_recipe_sysroot: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_configure: Succeeded
NOTE: Running task 4404 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_compile)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_compile: Started
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_compile: Succeeded
NOTE: Running task 4405 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_install)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_install: Started
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_prepare_recipe_sysroot: Succeeded
NOTE: Running task 4406 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/libad9361-iio/libad9361-iio_0.2.bb:do_unpack)
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_unpack: Started
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_unpack: Succeeded
NOTE: Running task 4407 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/libad9361-iio/libad9361-iio_0.2.bb:do_patch)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_install: Succeeded
NOTE: Running task 4408 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_package)
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_patch: Started
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_patch: Succeeded
NOTE: Running task 4409 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/libad9361-iio/libad9361-iio_0.2.bb:do_populate_lic)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_package: Started
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_populate_lic: Started
NOTE: recipe fru-tools-0.8.1.5+gitAUTOINC+957cb9b2d4-r0: task do_fetch: Succeeded
NOTE: Running task 4410 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-xilinx/recipes-support/adrv9009-zu11eg-fan-control-daemon/adrv9009-zu11eg-fan-control_dev.bb:do_populate_sysroot)
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_populate_lic: Succeeded
NOTE: Running task 4411 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/fru-tools/fru-tools_0.8.1.5.bb:do_prepare_recipe_sysroot)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_populate_sysroot: Started
NOTE: recipe fru-tools-0.8.1.5+gitAUTOINC+957cb9b2d4-r0: task do_prepare_recipe_sysroot: Started
NOTE: recipe fru-tools-0.8.1.5+gitAUTOINC+957cb9b2d4-r0: task do_prepare_recipe_sysroot: Succeeded
NOTE: Running task 4412 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/libad9361-iio/libad9361-iio_0.2.bb:do_deploy_source_date_epoch)
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_deploy_source_date_epoch: Started
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_deploy_source_date_epoch: Succeeded
NOTE: Running task 4413 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/libad9361-iio/libad9361-iio_0.2.bb:do_generate_toolchain_file)
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_populate_sysroot: Succeeded
NOTE: Running task 4414 of 5284 (/home/agonga/petalinux/meta-adi/meta-adi-core/recipes-core/fru-tools/fru-tools_0.8.1.5.bb:do_unpack)
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_generate_toolchain_file: Started
ERROR: device-tree-xilinx-v2021.1+gitAUTOINC+252758eb1f-r0 do_configure: Execution of '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/temp/run.do_configure.2933' failed with exit code 1:
MISC_ARG is  -hdf_type xsa -yamlconf /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/device-tree.yaml
APP_ARG is  -app "device-tree"
Using xsct from: /home/agonga/petalinux/tools/xsct//bin/xsct
cmd is: xsct -sdx -nodisp /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/dtgen.tcl -ws /home/agonga/petalinux/rita/project-spec/configs/../../components/plnx_workspace/device-tree -pname device-tree -rp /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/git -processor_ip ps7_cortexa9 -hdf /home/agonga/petalinux/rita/build/tmp/deploy/images/zynq-generic/Xilinx-zynq-generic.xsa -arch 32   -app "device-tree"  -hdf_type xsa -yamlconf /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/device-tree.yaml
INFO: [Hsi 55-2053] elapsed time for repository (/home/agonga/petalinux/tools/xsct/data/embeddedsw) loading 0 seconds
WARNING: Clock pin "clk" of IP block "AD9361_SDR_axi_ad9361" is not connected to any of the pl_clk"
zocl:false
ext_platform:
WARNING: RITA_axi_dma_0 connected ip is NULL for the pin M_AXIS_MM2S
WARNING: ps7_i2c_0: No reset found
WARNING: ps7_i2c_1: No reset found
hsi::generate_target: Time (s): cpu = 00:00:07 ; elapsed = 00:00:08 . Memory (MB): peak = 2001.848 ; gain = 0.000 ; free physical = 7954 ; free virtual = 12011
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//base-hsi.tcl' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/base-hsi.tcl' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//build' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/build' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//deploy-source-date-epoch' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/deploy-source-date-epoch' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//device-tree.yaml' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/device-tree.yaml' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//dtgen.tcl' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/dtgen.tcl' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//git' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/git' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//license-destdir' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/license-destdir' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-system-top-custom.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-system-top-custom.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-adrv9361-z7035-bob-cmos.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-adrv9361-z7035-bob-cmos.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-adrv9361-z7035-bob.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-adrv9361-z7035-bob.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-adrv9361-z7035-fmc.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-adrv9361-z7035-fmc.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-adrv9364-z7020-bob-cmos.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-adrv9364-z7020-bob-cmos.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-adrv9364-z7020-bob.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-adrv9364-z7020-bob.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc702-adv7511-ad9361-fmcomms5.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc702-adv7511-ad9361-fmcomms5.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc702-adv7511.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc702-adv7511.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad6676-fmc.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad6676-fmc.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad9081.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad9081.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad9172-fmc-ebz.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad9172-fmc-ebz.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad9265-fmc-125ebz.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad9265-fmc-125ebz.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad9361-fmcomms2-3.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad9361-fmcomms2-3.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad9361-fmcomms5.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad9361-fmcomms5.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad9434-fmc-500ebz.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad9434-fmc-500ebz.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad9625-fmcadc2.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad9625-fmcadc2.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-ad9739a-fmc.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-ad9739a-fmc.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-adrv9008-1-jesd204-fsm.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-adrv9008-1-jesd204-fsm.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-adrv9008-2-jesd204-fsm.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-adrv9008-2-jesd204-fsm.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-adrv9009.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-adrv9009.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-adrv9371.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-adrv9371.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-adrv9375-jesd204-fsm.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-adrv9375-jesd204-fsm.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-fmcdaq2.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-fmcdaq2.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-fmcdaq3-revC.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-fmcdaq3-revC.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-fmcjesdadc1.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-fmcjesdadc1.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zc706-adv7511-fmcomms11.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zc706-adv7511-fmcomms11.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zed-adv7511-ad9361-fmcomms2-3.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zed-adv7511-ad9361-fmcomms2-3.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zed-adv7511-ad9467-fmc-250ebz.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zed-adv7511-ad9467-fmc-250ebz.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zed-adv7511-adrv9002.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zed-adv7511-adrv9002.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zed-adv7511-adrv9002-rx2tx2.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zed-adv7511-adrv9002-rx2tx2.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zed-adv7511.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zed-adv7511.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//pl-delete-nodes-zynq-zed-imageon.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/pl-delete-nodes-zynq-zed-imageon.dtsi' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//recipe-sysroot' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/recipe-sysroot' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//recipe-sysroot-default' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/recipe-sysroot-default' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//source-date-epoch' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/source-date-epoch' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//sstate-install-deploy_source_date_epoch' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/sstate-install-deploy_source_date_epoch' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//sstate-install-populate_lic' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/sstate-install-populate_lic' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//system-top-custom.dts' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/system-top-custom.dts' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//temp' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/temp' are the same file
cp: '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//zynq-7000-qspi-dummy.dtsi' and '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/zynq-7000-qspi-dummy.dtsi' are the same file
WARNING: /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/temp/run.do_configure.2933:195 exit 1 from 'cp -rf "/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0//"* "/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/"'
WARNING: Backtrace (BB generated script):
	#1: do_configure, /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/temp/run.do_configure.2933, line 195
	#2: main, /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/temp/run.do_configure.2933, line 281
Backtrace (metadata-relative locations):
	#1: do_configure, /home/agonga/petalinux/rita/components/yocto/layers/meta-xilinx-tools/classes/xsctbase.bbclass, line 74
ERROR: Logfile of failure stored in: /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/temp/log.do_configure.2933
NOTE: recipe device-tree-xilinx-v2021.1+gitAUTOINC+252758eb1f-r0: task do_configure: Failed
ERROR: Task (/home/agonga/petalinux/rita/components/yocto/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_configure) failed with exit code '1'
NOTE: recipe libad9361-iio-0.2+gitAUTOINC+fd44358e9c-r0: task do_generate_toolchain_file: Succeeded
NOTE: recipe fru-tools-0.8.1.5+gitAUTOINC+957cb9b2d4-r0: task do_unpack: Started
NOTE: recipe fru-tools-0.8.1.5+gitAUTOINC+957cb9b2d4-r0: task do_unpack: Succeeded
NOTE: recipe adrv9009-zu11eg-fan-control-dev+gitAUTOINC+e00aed0221-r0: task do_package: Succeeded
NOTE: Tasks Summary: Attempted 4415 tasks of which 4301 didn't need to be rerun and 1 failed.
ERROR: Failed to build project. Check the /home/agonga/petalinux/rita/build/build.log file for more details...
log.do_configure.2933 file:
DEBUG: Executing python function extend_recipe_sysroot
NOTE: Direct dependencies are ['virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/meta-openembedded/meta-python/recipes-devtools/python/python3-pyyaml_5.3.1.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/dtc/python3-dtc_1.5.1.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/python/python3_3.8.5.bb:do_populate_sysroot', '/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-kernel/dtc/dtc_1.6.0.bb:do_populate_sysroot', '/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/binutils/binutils-cross_2.35.1.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-bsp/u-boot/u-boot-tools_2020.07.bb:do_populate_sysroot', '/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/bison/bison_3.7.2.bb:do_populate_sysroot', '/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/gcc/gcc-cross_10.2.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/bc/bc_1.07.1.bb:do_populate_sysroot', '/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-kernel/kmod/kmod-native_git.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot', 'virtual:native:/home/agonga/petalinux/rita/components/yocto/layers/core/meta/recipes-extended/xz/xz_5.2.5.bb:do_populate_sysroot']
NOTE: Installed into sysroot: []
NOTE: Skipping as already exists in sysroot: ['python3-pyyaml-default', 'python3-dtc-default', 'pseudo-default', 'python3-default', 'kern-tools-default', 'dtc-default', 'binutils-cross-arm', 'u-boot-tools-default', 'quilt-default', 'bison-default', 'gcc-cross-arm', 'bc-default', 'kmod-default', 'patch-default', 'xz-default', 'libyaml-default', 'python3-setuptools-default', 'python3-cython-default', 'flex-default', 'swig-default', 'gdbm-default', 'zlib-default', 'libffi-default', 'pkgconfig-default', 'autoconf-default', 'automake-default', 'ncurses-default', 'libnsl2-default', 'gnu-config-default', 'libtirpc-default', 'readline-default', 'libtool-default', 'sqlite3-default', 'util-linux-default', 'openssl-default', 'bzip2-default', 'texinfo-dummy-default', 'gettext-minimal-default', 'libmpc-default', 'linux-libc-headers', 'mpfr-default', 'gmp-default', 'gtk-doc-default', 'attr-default', 'unzip-default', 'm4-default', 'libpcre-default', 'libpcre2-default', 'libcap-ng-default']
DEBUG: Python function extend_recipe_sysroot finished
DEBUG: Executing shell function do_configure
zocl:false
ext_platform:
ERROR: Execution of '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/temp/run.do_configure.2933' failed with exit code 1:
zocl:false
ext_platform:
Kind regards,
Amadeu.
  • Hi Amadeu,
    That looks odd. Does that happen on the first build? It seems something really wrong is going on... Are you setting any special variable or just KERNEL_DTB?  The only way I see this happening is because of this line if DTS_INCLUDE_PATH expands to "." so that it will give the current directory which might be WORKDIR. Are you sure you have all the environment correctly set up? Are you using bash as your default shell? Whats the result of "ls -la /bin/sh"?
    - Nuno Sá
  • Hello Nuno,
    The first build went good and I had been able to generate the pl.dtsi file.
    Once I got the pl.dtsi, I have created the pl-delete-nodes-${KERNEL_DTB}.dtsi file, and appended it to the device-tree.bbappend file together with my device-tree file.
    Finally, I've set to the petalinuxbsp.conf file the name of my device-tree and tried to build the project.
    In order to ensure that all the environmental requirements for Petalinux are installed, I've executed the script from this Link.
    Am I missing something?
    Amadeu.
    Can you paste your petalinuxbsp.conf  and device-tree.bbappend? Also, it would be good to make sure you are really using bash. What's the output of `ls -la /bin/sh`?
    I never used that script so I'm not sure about it. When I source the petalinux settings it normally checks the env for packages. I would assume that it also checks the current shell.
    - Nuno Sá
  • Hello Nuno,
    I leave you below my petalinuxbsp.conf and device-tree.bbappend files.
    #User Configuration
    #OE_TERMINAL = 'tmux'
    KERNEL_DTB="system-top"
    FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
    SRC_URI_append = " \
    	file://pl-delete-nodes-system-top.dtsi \
    	file://system-top.dts \
    # If the project being added is supported by ADI (with no custom changes), the devicetree should be present in the kernel sources. Hence, there's no need to redefine KERNEL_DTB_PATH
    KERNEL_DTB_PATH = "${WORKDIR}"
    # The following variable can be defined in case the new devicetree has no dependencies on the kernel sources (eg: by including a devicetree that is to be found there). If set to "n", it will prevent the device-tree recipe from copying all the kernel's devicetrees into ${WORKDIR}...
    USE_KERNEL_SOURCES = "n"
    The output of `ls -la /bin/sh` is: '/bin/sh -> bash'.
    Once I've got my first Petalinux build, I copied all the generated files from : '<pth-to-project>/components/plnx_workspace/device_tree' path to '<pth-to-project>/project-spec/meta-user/recipes-bsp/device-tree/files' but I'm wondering if this is the correct way to proceed or not.
    Amadeu.
  • Once I've got my first Petalinux build, I copied all the generated files from : '<pth-to-project>/components/plnx_workspace/device_tree' path to '<pth-to-project>/project-spec/meta-user/recipes-bsp/device-tree/files' but I'm wondering if this is the correct way to proceed or not.
    You should not need to do that...
    Hmm, I think I know what's happening:
    That is the problematic line... It will trigger the following command "cp -rf "${WORKDIR}/"* "${WORKDIR}/" which is obviously not nice. I need to add a safeguard here to make the copy only when KERNEL_DTB_PATH  != WORKDIR. If you are comfortable doing that, that's something you can add to the do_configure method. However that means changing meta-adi which is not great (better wait for a fix from the project).
    Alternatively, what you can do is to remove "file://system-top.dts" from you SRC_URI appends and change KERNEL_DTB_PATH to the real path, in your filesystem, of system-top.dts.
    Just to make it clear, this is indeed a bug in meta-adi. Thanks for the report!
    - Nuno Sá
  • Thanks Nuno for your fast reply, after removing system-top.dts from SRC_URI append and including it to the KERNEL_DTB_PATH, the compiling error from before was solved.
    Unfortunately, I'm facing another compiling error. The error comes from this line due to the fact that it is not able to find the file system-conf.dtsi. I've tried to comment this line and build again petalinux but it crashes also due to the fact that system-conf.dtsi is not find. (See log below)
    From what I've seen in Petalinux Reference Guide (page 146), after executing petalinux-config, petalinux should generate among different *.dtsi files the system-conf.dtsi, all of them located in path: '<plnx-proj-root>/components/plnx_workspace/device-tree/device-tree/'.
    Even though in my case, after saving the petalinux-config, the system-conf.dtsi file is not generated while the others are correctly generated. I guess that's the reason why my project crashes. The only file being modified after the petalinux-config is the config file located at '<plnx-proj-root>/project-spec/configs'.
    Maybe I'm missing some required package for petalinux?
    agonga@amadeugonga:~/petalinux/rita$ petalinux-build
    INFO: bitbake petalinux-image-minimal
    NOTE: Started PRServer with DBfile: /home/agonga/petalinux/rita/build/cache/prserv.sqlite3, IP: 127.0.0.1, PORT: 43921, PID: 228896
    Loading cache: 100% |#######################################################################################################################################################################| Time: 0:00:02
    Loaded 5099 entries from dependency cache.
    Parsing recipes: 100% |#####################################################################################################################################################################| Time: 0:00:03
    Parsing of 3475 .bb files complete (3464 cached, 11 parsed). 5110 targets, 259 skipped, 0 masked, 0 errors.
    Initialising tasks: 100% |##################################################################################################################################################################| Time: 0:00:13
    Checking sstate mirror object availability: 100% |##########################################################################################################################################| Time: 0:00:32
    Sstate summary: Wanted 195 Found 13 Missed 182 Current 1526 (6% match, 89% complete)
    ERROR: device-tree-xilinx-v2021.1+gitAUTOINC+252758eb1f-r0 do_compile: Error executing a python function in exec_python_func() autogenerated:
    The stack trace of python calls that resulted in this exception/failure was:
    File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
         0001:
     *** 0002:devicetree_do_compile(d)
         0003:
    File: '/home/agonga/petalinux/rita/components/yocto/layers/core/meta/classes/devicetree.bbclass', lineno: 131, function: devicetree_do_compile
         0127:            if not(os.path.isfile(dtspath)) or not(dts.endswith(".dts") or devicetree_source_is_overlay(dtspath)):
         0128:                continue # skip non-.dts files and non-overlay files
         0129:        except:
         0130:            continue # skip if can't determine if overlay
     *** 0131:        devicetree_compile(dtspath, includes, d)
         0132:}
         0133:
         0134:devicetree_do_install() {
         0135:    for DTB_FILE in `ls *.dtb *.dtbo`; do
    File: '/home/agonga/petalinux/rita/components/yocto/layers/core/meta/classes/devicetree.bbclass', lineno: 119, function: devicetree_compile
         0115:        dtcargs += ["-i", i]
         0116:    dtcargs += ["-o", "{0}.{1}".format(dtname, "dtbo" if isoverlay else "dtb")]
         0117:    dtcargs += ["-I", "dts", "-O", "dtb", "{0}.pp".format(dts)]
         0118:    bb.note("Running {0}".format(" ".join(dtcargs)))
     *** 0119:    subprocess.run(dtcargs, check = True, stdout=subprocess.PIPE, stderr=subprocess.STDOUT)
         0120:
         0121:python devicetree_do_compile() {
         0122:    includes = expand_includes("DT_INCLUDE", d)
         0123:    listpath = d.getVar("DT_FILES_PATH")
    File: '/home/agonga/petalinux/components/yocto/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.8/subprocess.py', lineno: 512, function: run
         0508:            # We don't call process.wait() as .__exit__ does that for us.
         0509:            raise
         0510:        retcode = process.poll()
         0511:        if check and retcode:
     *** 0512:            raise CalledProcessError(retcode, process.args,
         0513:                                     output=stdout, stderr=stderr)
         0514:    return CompletedProcess(process.args, retcode, stdout, stderr)
         0515:
         0516:
    Exception: subprocess.CalledProcessError: Command '['dtc', '-@', '-p', '0x1000', '-@', '-i', '/home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0', '-i', '/home/agonga/petalinux/rita/build/tmp/work-shared/zynq-generic/kernel-source/scripts/dtc/include-prefixes', '-i', '/home/agonga/petalinux/rita/project-spec/configs/../../components/plnx_workspace/device-tree/device-tree', '-o', 'system-top.dtb', '-I', 'dts', '-O', 'dtb', 'system-top.dts.pp']' returned non-zero exit status 1.
    Subprocess output:
    FATAL ERROR: Couldn't open "system-conf.dtsi": No such file or directory
    ERROR: Logfile of failure stored in: /home/agonga/petalinux/rita/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/device-tree/xilinx-v2021.1+gitAUTOINC+252758eb1f-r0/temp/log.do_compile.230791
    ERROR: Task (/home/agonga/petalinux/rita/components/yocto/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_compile) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 3652 tasks of which 3650 didn't need to be rerun and 1 failed.
    Summary: 1 task failed:
    Summary: There was 1 ERROR message shown, returning a non-zero exit code.
    Amadeu
  • UPDATE: In the last reply I was referring about system-conf.dtsi file being generated by petalinux-config but that's not true. This file is generated once executing petalinux-build.
    I've been able to see that when executing petalinux-build in a "raw" project (i.e. first build) the system-conf.dtsi file is correctly generated. Even though, when including the path of my device-tree in KERNEL_DTB_PATH and appending only SRC_URI_append = " \file://pl-delete-nodes-system-top.dtsi", the petalinux-build crashes due to the fact that system-conf.dtsi file is not generated.
    Any information why is this happening?
    Amadeu.
    That is true... IIRC, it is created during the do_configure task...
    What is strange here is that I would expect the meta-adi do_configure task to fail if the file is not there. This line should not work...
    Are you in any ways further appending the do_configure task?
    Maybe it's worth to just try a clean, fresh build (if not done already) to make sure your build is not in a complete crazy state already...
    As a sidenote, I did saw the system-conf.dtsi file not being generated when migrating to petalinux 2021. The reason can be seen in this commit message.
    - Nuno Sá
  • Finally, I had been able to successfully compile my Petalinux project.
    The reason why I was not able to generate the system-conf.dtsi file was due to the fact that I was not appending in the device-tree.bbappend file the do_configure task that is generated by default.
    I leave below as example my device-tree.bbappend file for further help.
    FILESEXTRAPATHS_prepend := "${THISDIR}/files:${SYSCONFIG_PATH}:"
    SRC_URI_append = " file://config \
    	file://system-user.dtsi \
    python () {
        if d.getVar("CONFIG_DISABLE"):
            d.setVarFlag("do_configure", "noexec", "1")
    export PETALINUX
    do_configure_append () {
    	script="${PETALINUX}/etc/hsm/scripts/petalinux_hsm_bridge.tcl"
    	data=${PETALINUX}/etc/hsm/data/
    	eval xsct -sdx -nodisp ${script} -c ${WORKDIR}/config \
    	-hdf ${DT_FILES_PATH}/hardware_description.${HDF_EXT} -repo ${S} \
    	-data ${data} -sw ${DT_FILES_PATH} -o ${DT_FILES_PATH} -a "soc_mapping"
    KERNEL_DTB_PATH="/home/agonga/petalinux/RITA/project-spec/meta-user/recipes-bsp/device-tree/files"
    USE_KERNEL_SOURCES="n"
    Kind regards,
    Amadeu.
  • This is surely odd. I would say that you do not have to re-implement that as it's done already in meta-user. AFAIK, you're not forced to append any task in you .bbappend file. Anyways, if this works for you :)
    I still might try something similar on my end just to see if I need to update something in the DOCS...
    - Nuno Sá
