adau7118 on raspberry pi with 4 channel tdm
Hallo,
I need to run 4-channel microphones on the CM4 module.
I am trying to do this starting with the raspberry 3 on the Analog Devices kernel rpi-5.10y and when I use the default adau7118 simple overlay it works for two mics in i2s mode on my custom i2c board.
The default adau7118 overlay:
// SPDX-License-Identifier: GPL-2.0
/dts-v1/;
/plugin/;
	compatible = "brcm,bcm2835";
	fragment@0 {
		target = <&i2s>;
		__overlay__ {
			status = "okay";
	fragment@1 {
		target = <&i2c1>;
		__overlay__ {
			#address-cells = <1>;
			#size-cells = <0>;
			status = "okay";
			adau7118_codec: adau7118-codec@14 {
				reg = <0x14>;
				#sound-dai-cells = <0>;
				compatible = "adi,adau7118";
				status = "okay";
	fragment@2 {
		target = <&sound>;
		sound_overlay: __overlay__ {
			compatible = "simple-audio-card";
			simple-audio-card,format = "i2s";
			simple-audio-card,name = "adau7118";
			simple-audio-card,bitclock-slave = <&dailink0_slave>;
			simple-audio-card,frame-slave = <&dailink0_slave>;
			simple-audio-card,widgets =
				"Microphone", "Microphone Jack";
			simple-audio-card,routing =
				"PDM_DAT0", "Microphone Jack";
			status = "okay";
			simple-audio-card,cpu {
				/* so that bclk is 64x FS */
				dai-tdm-slot-num = <2>;
				dai-tdm-slot-width = <32>;
				sound-dai = <&i2s>;
			dailink0_slave: simple-audio-card,codec {
				sound-dai = <&adau7118_codec>;
	__overrides__ {
		card-name = <&sound_overlay>,"simple-audio-card,name";
Is it possible to run this driver in tdm 4 channel mode by changing this overlay?
I'm not sure, but the default raspberry pi kernel probably doesn't support a device like tdm, but can Analog Devices kernel fix the problem?
Jakub
