Unable to ping Ethernet IP address AD9081/AD9082 Virtex UltraScale+ VCU118
Hello, I am trying to program UltraScale+ VCU118 Evaluation Kit with AD9081/1d9082 .
I downloaded the prebuilt image and bit file from the link below and programmed the VCU118 board with.
https://wiki.analog.com/resources/eval/user-guides/ad9081_fmca_ebz/quickstart/microblaze
  • The board successfully programed by Xilinx SDK 2019.1 xsdb with prebuilt bit file and Linux image strip file m=8, L=4.
  • The Kernel boot showed some failure (Please see the attached Kernel boot log for the full text):
    • xilinx_axienet 40c00000.ethernet: Failed to get clock: -2
    • ad9081 spi0.0: Failed to initialize: -21
    • ad9081: probe of spi0.0 failed with error -21
    • udhcpc: no lease, failing
    • I was able to login to the buildroot with username: root and pass: analog
Ramdisk addr 0x00000000,
Compiled-in FDT at 0x80510478
earlycon: uartlite_a0 at MMIO 0x40600000 (options '115200n8')
printk: bootconsole [uartlite_a0] enabled
cma: Reserved 512 MiB at 0x8e000000
Linux version 5.4.0-168125-g1d1209cdb0ce (michael@mhenneri-D06) (gcc version 7.3.1 20180425 (crosstool-NG 1.20.0)) #2837 Fri Mar 12 17:41:16 CET 2021
setup_memory: max_mapnr: 0x7ffff
setup_memory: min_low_pfn: 0x80000
setup_memory: max_low_pfn: 0xb0000
setup_memory: max_pfn: 0xfffff
Zone ranges:
  DMA      [mem 0x0000000080000000-0x00000000afffffff]
  Normal   empty
  HighMem  [mem 0x00000000b0000000-0x00000000ffffefff]
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x0000000080000000-0x00000000ffffefff]
Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffefff]
setup_cpuinfo: initialising cpu 0
setup_cpuinfo: Using full CPU PVR support
wt_msr_noirq
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists, mobility grouping on.  Total pages: 522751
Kernel command line: earlycon
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
mem auto-init: stack:off, heap alloc:off, heap free:off
Memory: 1538692K/2097148K available (5185K kernel code, 565K rwdata, 5152K rodata, 165K init, 154K bss, 34168K reserved, 524288K cma-reserved, 1310716K highmem)
Kernel virtual memory layout:
  * 0xfffea000..0xfffff000  : fixmap
  * 0xff800000..0xffc00000  : highmem PTEs
  * 0xff7ff000..0xff800000  : early ioremap
  * 0xb0000000..0xff7ff000  : vmalloc & ioremap
NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
irq-xilinx: mismatch in kind-of-intr param
irq-xilinx: /amba_pl/interrupt-controller@41200000: num_irq=16, sw_irq=0, edge=0xffff05f0
xilinx_timer_init: Timer base: 0xb0002000, Clocksource base: 0xb0002010
clocksource: xilinx_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
/amba_pl/timer@41c00000: irq=1, cpu_id 0
xilinx_timer_shutdown
xilinx_timer_set_periodic
Calibrating delay loop... 49.35 BogoMIPS (lpj=246784)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
devtmpfs: initialized
random: get_random_u32 called from bucket_table_alloc.isra.24+0x13c/0x170 with crng_init=0
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 16 (order: -4, 448 bytes, linear)
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic allocations
PCI: Probing PCI hardware
vgaarb: loaded
jesd204: created con: id=0, topo=0, link=0, /amba_pl/axi_quad_spi@44a70000/hmc7044@1 <-> /amba_pl/axi-adxcvr-tx@44b60000
jesd204: created con: id=1, topo=0, link=2, /amba_pl/axi_quad_spi@44a70000/hmc7044@1 <-> /amba_pl/axi-adxcvr-rx@44a60000
jesd204: created con: id=2, topo=0, link=0, /amba_pl/axi-adxcvr-tx@44b60000 <-> /amba_pl/axi-jesd204-tx@44b90000
jesd204: created con: id=3, topo=0, link=2, /amba_pl/axi-adxcvr-rx@44a60000 <-> /amba_pl/axi-jesd204-rx@44a90000
jesd204: created con: id=4, topo=0, link=0, /amba_pl/axi-jesd204-tx@44b90000 <-> /amba_pl/axi-ad9081-tx-hpc@44b10000
jesd204: created con: id=5, topo=0, link=2, /amba_pl/axi-jesd204-rx@44a90000 <-> /amba_pl/axi-ad9081-rx-hpc@44a10000
jesd204: created con: id=6, topo=0, link=2, /amba_pl/axi-ad9081-rx-hpc@44a10000 <-> /amba_pl/axi_quad_spi@44a70000/ad9081@0
jesd204: created con: id=7, topo=0, link=0, /amba_pl/axi-ad9081-tx-hpc@44b10000 <-> /amba_pl/axi_quad_spi@44a70000/ad9081@0
jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0: JESD204[2] transition uninitialized -> initialized
jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0: JESD204[0] transition uninitialized -> initialized
jesd204: found 8 devices and 1 topologies
clocksource: Switched to clocksource xilinx_clocksource
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 12288 bytes, linear)
TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
TCP bind hash table entries: 8192 (order: 5, 163840 bytes, linear)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 24576 bytes, linear)
UDP-Lite hash table entries: 512 (order: 2, 24576 bytes, linear)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
random: fast init done
workingset: timestamp_bits=30 max_order=19 bucket_order=0
Key type cifs.idmap registered
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler mq-deadline registered
io scheduler kyber registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
40600000.serial: ttyUL0 at MMIO 0x40600000 (irq = 5, base_baud = 0) is a uartlite
printk: console [ttyUL0] enabled
printk: bootconsole [uartlite_a0] disabled
uartlite 41400000.serial: IRQ index 0 not found
brd: module loaded
Xilinx SystemACE device driver, major=254
libphy: Fixed MDIO Bus: probed
xilinx_axienet 40c00000.ethernet: TX_CSUM 2
xilinx_axienet 40c00000.ethernet: RX_CSUM 2
xilinx_axienet 40c00000.ethernet (unnamed net_device) (uninitialized): Setting assumed host clock to 100000000
libphy: Xilinx Axi Ethernet MDIO: probed
i2c /dev entries driver
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
i2c i2c-0: Added multiplexed i2c bus 3
at24 4-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 4
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0075: registered 8 multiplexed busses for I2C switch pca9548
i2c i2c-0: Added multiplexed i2c bus 9
i2c i2c-0: Added multiplexed i2c bus 10
i2c i2c-0: Added multiplexed i2c bus 11
i2c i2c-0: Added multiplexed i2c bus 12
i2c i2c-0: Added multiplexed i2c bus 13
i2c i2c-0: Added multiplexed i2c bus 14
i2c i2c-0: Added multiplexed i2c bus 15
i2c i2c-0: Added multiplexed i2c bus 16
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
jesd204: /amba_pl/axi_quad_spi@44a70000/hmc7044@1,jesd204:0,parent=spi0.1: Using as SYSREF provider
axi_adxcvr 44a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using CPLL on GTY4 at 0x44A60000. Number of lanes: 4.
axi_adxcvr 44b60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using QPLL on GTY4 at 0x44B60000. Number of lanes: 4.
axi-jesd204-rx 44a90000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x44A90000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
axi-jesd204-tx 44b90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x44B90000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
axi_sysid 45000000.axi-sysid-0: AXI System ID core version (1.01.a) found
axi_sysid 45000000.axi-sysid-0: [ad9081_fmca_ebz] on [vcu118] git branch <(HEAD> git <e2a111d74bdcc055cc78409074346977a0f8452b> clean [2021-03-08 11:47:34] UTC
Key type encrypted registered
ad9081 spi0.0: some power supplies are not on.
ad9081 spi0.0: Boot did not reach expected spot in boot_pre_clock()
ad9081 spi0.0: PLL not locked, "pll_lock" in adi_ad9081_device_clk_pll_div_set(...), line346 in drivers/iio/adc/ad9081/adi_ad9081_device.c
Freeing unused kernel memory: 164K
This architecture does not have kernel memory protection.
Run /init as init process
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Saving random seed: random: dd: uninitialized urandom read (512 bytes read)
OK
Starting network: udhcpc: started, v1.31.1
net eth0: Promiscuous mode disabled.
xilinx_axienet 40c00000.ethernet eth0: Setting assumed host clock to 100000000
net eth0: Speed other than 10, 100
net eth0: or 1Gbps is not supported
xilinx_axienet 40c00000.ethernet eth0: Link is Down
udhcpc: sending discover
xilinx_axienet 40c00000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Starting dropbear sshd: random: dropbear: uninitialized urandom read (32 bytes read)
OK
Starting IIO Server Daemon
Welcome to Buildroot
buildroot login: random: crng init done
buildroot login: root
Password:
  • Only HMC7044 is available when I type:
    • # iio_info |grep iio:device
    • io:device0: hmc7044
        iio:device0: hmc7044
  • Jesd_status command found both Jesd204-RX and Jesd204-TX but link is disabled (Please see the Kernel boot log for the full text)
    • Link is disabled
    • SYSREF alignment error
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
xl(DEVICES) Found 2 JESD204 Link Layer peripheralsqqqqqqqqqqqqqqqqqqqqqqqqqqqqkx
xx        xx
xx(0): axi-jesd204-rx/44a90000.axi-jesd204-rx  [*]                            xx
xx(1): axi-jesd204-tx/44b90000.axi-jesd204-tx                                 xx
xmqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqjx
xl(STATUS)qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqkx
xxLink is                      disabled                                       xx
xxLink Status        xx
xxMeasured Link Clock (MHz)    374.995                                        xx
xxReported Link Clock (MHz)    750.000                                        xx
xxMeasured Device Clock (MHz)  749.994                                        xx
xxReported Device Clock (MHz)  750.000                                        xx
xxDesired Device Clock (MHz)   0.000                                          xx
xxLane rate (MHz)                                                             xx
xxLane rate / 40 (MHz)                                                        xx
xxLMFC rate (MHz)                                                             xx
xxSYSREF captured                                                             xx
xxSYSREF alignment error                                                      xx
xxSYNC~        xx
xl(LANE STATUS)qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqkx
xxLane#                             0      1      2      3      4      5      xt
xxErrors                            0      0      0      0      0      0      xj
  • I connected the ethernet cable directly to my PC. I set the static IP address on the PC and on the Xilinx board but I can’t ping its IP address.
# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:90:81
          inet addr:192.168.2.1  Bcast:192.168.2.255  Mask:255.255.255.0
          UP BROADCAST RUNNING  MTU:1500  Metric:1
          RX packets:13 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1079 (1.0 KiB)  TX bytes:1710 (1.6 KiB)
# ifconfig eth0 169.254.23.10
# ifconfig
          inet addr:169.254.23.10  Bcast:169.254.255.255  Mask:255.255.0.0
  • The Xilinx Ethernet IP address is unreachable. (Please see the prompt log)
C:\Users\babakki> ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection* 1:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
Ethernet adapter Ethernet:
   Link-local IPv6 Address . . . . . : fe80::4848:c8c7:5825:1773%15
   Autoconfiguration IPv4 Address. . : 169.254.23.115
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   Default Gateway . . . . . . . . . :
Wireless LAN adapter Local Area Connection* 11:
Wireless LAN adapter Local Area Connection* 12:
C:\Users\babakki>ping 169.254.23.10
Pinging 169.254.23.10 with 32 bytes of data:
Reply from 169.254.23.115: Destination host unreachable.
Ping statistics for 169.254.23.10:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
  • I tried  AD9081 and AD9082 with FMC connector on the Ultrascale+ board. In both cases the HMC light on the Analog board is red.
  • The Xilinx board VCU118 is new and I am sure no body used it before, Is there any switch or jumper that need to be changed for the ethernet?
I would appreciate your guidance and assistance with this matter.
  • Hello Babakki,
    I'd suggest rechecking the connections between the boards, because that might cause the initialization fail of the spi.
    For further support I will move this thread to the Linux community.
    Stanca
  • Hi Stanca, I connected the AD9081 board and Xilinx VCU118 by the FMC connectors same as Quick Start Guide page,
    AD9081 using FMC, VCU118 using FMC+.
    I connected the PC directly with ethernet cable to the Xilinx board. (no router)
  • Regarding the errors in your kernel log related to the ad9081
    Can you please check this?
    https://wiki.analog.com/resources/eval/user-guides/ad9081_fmca_ebz/quickstart/microblaze#board_setup
    Regarding the Ethernet issue - try to connect your board to an DHCP enabled network (router/switch)
    -Michael
  • Hi, I checked your link for the board setup. It looks correct. The capacitors C6D/C4D caps are in C5D/C3D position.
    The LEDs on the board:
    IRQB1: OFF
    IRQB0: ON (RED)
    HMC_STATUS: ON (RED)
    Other LEDs are ON (GREEN)
    I tried using another AD9081 board and I connected the ethernet cables for the PC and Xilinx board to a HDCP router. The IP address automatically been set as below for both the PC and the Xilinx board. But again when pinging, Destination host unreachable.
    On the Xilinx board (Tera Term):
    iio:device1: axi-ad9081-tx-hpc (buffer capable)
    iio:device2: axi-ad9081-rx-hpc (buffer capable)
    # ifconfig
    inet addr:192.168.1.3 Bcast:192.168.1.255 Mask:255.255.255.0
    RX packets:3 errors:0 dropped:0 overruns:0 frame:0
    TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:1240 (1.2 KiB) TX bytes:684 (684.0 B)
    On the PC (Prompt ):
    IPconfig
    IPv4 Address. . . . . . . . . . . : 192.168.1.2
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    ping 192.168.1.3
    Pinging 192.168.1.3 with 32 bytes of data:
    Reply from 192.168.1.2: Destination host unreachable.
    Ping statistics for 192.168.1.3:
  • The Kernel boot showed 1 failure (Please see the new attached Kernel boot log ):
    # Ramdisk addr 0x00000000,
    Linux version 5.4.0-168125-g1d1209cdb0ce (michael@mhenneri-D06) (gcc version 7.3.1 20180425 (crosstool-NG 1.20.0)) #2833 Fri Mar 12 17:39:59 CET 2021
    Zone ranges:
      Normal   empty
    wt_msr_noirq
    pcpu-alloc: [0] 0
    vgaarb: loaded
    brd: module loaded
    axi_adxcvr 44a60000.axi-adxcvr-rx: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance
    axi_adxcvr 44a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using QPLL on GTY4 at 0x44A60000. Number of lanes: 8.
    axi_adxcvr 44b60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using QPLL on GTY4 at 0x44B60000. Number of lanes: 8.
    axi-jesd204-rx 44a90000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x44A90000. Encoder 8b10b, width 4/4, lanes 8, jesd204-fsm.
    axi-jesd204-tx 44b90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x44B90000. Encoder 8b10b, width 4/4, lanes 8, jesd204-fsm.
    axi_sysid 45000000.axi-sysid-0: [ad9081_fmca_ebz] on [vcu118] git branch <(HEAD> git <e2a111d74bdcc055cc78409074346977a0f8452b> clean [2021-03-08 10:45:53] UTC
    ad9081 spi0.0: AD9081 Rev. 2 Grade 10 (API 1.1.0) probed
    iio_dmaengine_buffer_alloc:226 width 0 (DMA width >= 256-bits ?)
    cf_axi_dds 44b10000.axi-ad9081-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x44B10000 mapped to 0x(ptrval), probed DDS AD9081
    cf_axi_adc 44a10000.axi-ad9081-rx-hpc: ADI AIM (10.01.b) at 0x44A10000 mapped to 0x(ptrval), probed ADC AD9081 as MASTER
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition initialized -> probed
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition initialized -> probed
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition probed -> idle
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition probed -> idle
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition idle -> device_init
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition idle -> device_init
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition device_init -> link_init
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition device_init -> link_init
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition link_init -> link_supported
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition link_init -> link_supported
    hmc7044 spi0.1: hmc7044_jesd204_link_pre_setup: Link2 forcing continuous SYSREF mode
    hmc7044 spi0.1: hmc7044_jesd204_link_pre_setup: Link0 forcing continuous SYSREF mode
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition link_supported -> link_pre_setup
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition link_supported -> link_pre_setup
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition link_setup -> opt_setup_stage1
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition link_setup -> opt_setup_stage1
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition clocks_enable -> link_enable
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition clocks_enable -> link_enable
    ad9081 spi0.0: JESD RX (JTX) Link2 in DATA, SYNC deasserted, PLL locked, PHASE established, MODE valid
    ad9081 spi0.0: JESD TX (JRX) Link0 0xFF lanes in DATA
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition link_enable -> link_running
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition link_enable -> link_running
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[2] transition link_running -> opt_post_running_stage
    jesd204: /amba_pl/axi_quad_spi@44a70000/ad9081@0,jesd204:1,parent=spi0.0: JESD204[0] transition link_running -> opt_post_running_stage
    Starting klogd: OK
    Running sysctl: OK
    OK
    udhcpc: sending select for 192.168.1.3
    udhcpc: lease of 192.168.1.3 obtained, lease time 86400
    deleting routers
    adding dns 192.168.1.1
    OK
    Password:
