How to build the petalinux image,which is similar as pre-built image including all adrv9009 driver?
The pre-built image works well on my ZCU102 board & adrv9009.But ,I want to add my custom IP into block design.
So as my understand,I have to add corresponding drivers into kernel.
My question is ——how to add adrv9009 drivers into petalinux image(I have to use petalinux because of my custom IP core)?
Is there any tutorial?
https://wiki.analog.com/resources/tools-software/linux-build/generic/petalinux
this link shows that the image don't include adrv9009 driver ,i.e jesd204b ……
Thanks very much!!!
Parents
  • +1
    on Sep 8, 2021 11:02 AM
    You have several options, of which I recommend two, depending on whether you want to version control the solution or not. Before I give you the solution, I must mention that petalinux (as well as yocto) downloads the sources from a predefined git repository (for petalinux this would be the xilinx repos) with the commit tag specific to the version number of petalinux.
    For example you are using petalinux 2020.1 and want to change the kernel configuration. When building the project, petalinux will fetch the sources from github.com/.../xilinx-v2020.1 ; notice the xilinx-v2020.1 tagged commit in the link.
    Solution 1. (not version controlled in petalinux)
    You can override the fetch source location of the kernel either to a git repository or a local copy on your PC. This is documented Here in the "Configure the ZCU102 PetaLinux Project" section, with the example being the Xilinx git repo, but you can change it to what ever you desire.
    This change to the repo location will be stored in the petalinux project, even if you version control it, but beware because you will no longer be on the Xilinx maintained kernel repo and it might break some petalinux compatibility if you are not on a similar kernel source composition as the default Xilinx git tag. Also this puts the burden on you to make sure that the new repo is properly maintained.
    Solution 2.(version controlled in petalinux)
    For this you need to clone the Xilinx kernel repo on the appropriate tag and make the changes that you require to it. After this you need to create a patch with your changes; this can be done using format-patch from within git. You then need to add the patch to the petalinux project, similar to this.
    Any patch that you add to the project, this way, will be applied after the do_fetch process for the kernel sources is done. This way you will have the option document and version control all the changes you are making to the default kernel sources within your petalinux project while the main kernel repository is maintained by Xilinx.
    Hope this helps.
    -Ciprian
  • Oh,another question——
    Now,I have built a petalinux image which includes all adrv9009 drivers,and it can transfer RF signal as ADI pre-built image.
    But,I notices that this image don't include iio-device:ad7291 and iio-device:axi-adrv9009-rx-obs-hpc.There are two logs (ADI pre-built image & my petalinux image 's iio_info )
    ADI_r1_iio_info.txt
    Library version: 0.21 (git tag: 565bf68)
    Compiled with backends: local xml ip
    IIO context created with local backend.
    Backend version: 0.21 (git tag: 565bf68)
    Backend description string: Linux analog 4.14.0-g8a57ede #653 SMP Mon Feb 3 16:44:50 GMT 2020 aarch64
    IIO context has 3 attributes:
    	hdl_system_id: [adv7511] on [zed] git <2e4ac278eb09c13471e381459b0da790ebad8373> clean [2019-12-05 01:36:48] UTC
    	local,kernel: 4.14.0-g8a57ede
    	uri: local:
    IIO context has 8 devices:
    	iio:device0: ams
    		30 channels found:
    			temp1: remote_temp (input)
    			3 channel-specific attributes found:
    				attr  0: offset value: -36058
    				attr  1: raw value: 40790
    				attr  2: scale value: 7.771514892
    			voltage14: vccpsio2 (input)
    			2 channel-specific attributes found:
    				attr  0: raw value: 19511
    				attr  1: scale value: 0.091552734
    			voltage0: vcc_pspll0 (input)
    				attr  0: raw value: 26237
    				attr  1: scale value: 0.045776367
    			voltage11: vccpsio3 (input)
    				attr  0: raw value: 19806
    			voltage1: vcc_psbatt (input)
    				attr  0: raw value: 30234
    			voltage15: psmgtravcc (input)
    				attr  0: raw value: 18525
    			voltage18: vccint (input)
    				attr  0: raw value: 18538
    			voltage7: vccpsintlp (input)
    				attr  0: raw value: 18465
    			voltage2: vccint (input)
    				attr  0: raw value: 18561
    			temp0: ps_temp (input)
    				attr  1: raw value: 40932
    			voltage16: psmgtravtt (input)
    				attr  0: raw value: 39468
    			voltage12: vccpsio0 (input)
    				attr  0: raw value: 19524
    			voltage6: vccpsintfpddr (input)
    				attr  0: raw value: 18362
    			voltage21: vccvrefn (input)
    				attr  0: raw value: 0
    				attr  1: scale value: 0.015258789
    			voltage23: vccplintlp (input)
    				attr  0: raw value: 18422
    			voltage8: vccpsintfp (input)
    				attr  0: raw value: 18364
    			voltage4: vccaux (input)
    				attr  0: raw value: 39233
    			voltage25: vccplaux (input)
    				attr  0: raw value: 39608
    			voltage5: vcc_psddrpll (input)
    				attr  0: raw value: 39738
    			voltage9: vccpsaux (input)
    				attr  0: raw value: 39584
    			voltage19: vccaux (input)
    				attr  0: raw value: 39208
    			voltage22: vccbram (input)
    				attr  0: raw value: 18582
    			voltage20: vccvrefp (input)
    				attr  0: raw value: 27310
    			voltage10: vccpsddr (input)
    				attr  0: raw value: 25747
    			voltage13: vccpsio1 (input)
    				attr  0: raw value: 19533
    			temp2: pl_temp (input)
    				attr  1: raw value: 40914
    			voltage3: vccbram (input)
    				attr  0: raw value: 18550
    			voltage24: vccplintfp (input)
    				attr  0: raw value: 18536
    			voltage17: vccams (input)
    			voltage26: vccams (input)
    				attr  0: raw value: 39214
    		1 device-specific attributes found:
    				attr  0: sampling_frequency ERROR: Invalid argument (-22)
    		No trigger on this device
    	iio:device1: ad9528-1
    		4 channels found:
    			altvoltage12: DEV_SYSREF (output)
    				attr  0: frequency value: 120000
    				attr  1: phase value: 0.000000
    				attr  2: raw value: 1
    			altvoltage1: FMC_CLK (output)
    				attr  0: frequency value: 245760000
    			altvoltage13: DEV_CLK (output)
    			altvoltage3: FMC_SYSREF (output)
    		9 device-specific attributes found:
    				attr  0: pll1_feedback_clk_present value: 1
    				attr  1: pll1_locked value: 0
    				attr  2: pll1_reference_clk_a_present value: 0
    				attr  3: pll1_reference_clk_ab_missing value: 1
    				attr  4: pll1_reference_clk_b_present value: 0
    				attr  5: pll2_feedback_clk_present value: 1
    				attr  6: pll2_locked value: 1
    				attr  7: sync_dividers ERROR: Input/output error (-5)
    				attr  8: vcxo_clk_present value: 1
    		1 debug attributes found:
    				debug attr  0: direct_reg_access value: 0x18
    	iio:device2: ad7291
    		9 channels found:
    			voltage6:  (input)
    				attr  0: raw value: 889
    				attr  1: scale value: 0.610351562
    			temp0:  (input)
    				attr  0: mean_raw value: 152
    				attr  1: raw value: 152
    				attr  2: scale value: 250
    			voltage3:  (input)
    				attr  0: raw value: 2728
    			voltage7:  (input)
    				attr  0: raw value: 2135
    			voltage0:  (input)
    				attr  0: raw value: 2792
    			voltage4:  (input)
    				attr  0: raw value: 2960
    			voltage1:  (input)
    				attr  0: raw value: 2100
    			voltage5:  (input)
    				attr  0: raw value: 2941
    			voltage2:  (input)
    				attr  0: raw value: 1477
    	iio:device3: adrv9009-phy
    		25 channels found:
    			voltage1:  (input)
    			10 channel-specific attributes found:
    				attr  0: gain_control_mode value: manual
    				attr  1: gain_control_mode_available value: manual slow_attack
    				attr  2: gain_control_pin_mode_en value: 0
    				attr  3: hardwaregain value: 30.000000 dB
    				attr  4: hd2_tracking_en value: 0
    				attr  5: powerdown value: 0
    				attr  6: quadrature_tracking_en value: 0
    				attr  7: rf_bandwidth value: 200000000
    				attr  8: rssi value: 44.250 dB
    				attr  9: sampling_frequency value: 245760000
    			voltage3:  (input)
    			7 channel-specific attributes found:
    				attr  0: hardwaregain ERROR: Protocol error (-71)
    				attr  1: powerdown value: 1
    				attr  2: quadrature_tracking_en value: 0
    				attr  3: rf_bandwidth value: 200000000
    				attr  4: rf_port_select value: OBS_TX_LO
    				attr  5: rf_port_select_available value: OBS_TX_LO OBS_AUX_LO
    				attr  6: sampling_frequency value: 245760000
    			voltage1:  (output)
    			8 channel-specific attributes found:
    				attr  0: atten_control_pin_mode_en value: 0
    				attr  1: hardwaregain value: -10.000000 dB
    				attr  2: lo_leakage_tracking_en value: 0
    				attr  3: pa_protection_en value: 0
    				attr  4: powerdown value: 0
    				attr  5: quadrature_tracking_en value: 0
    				attr  6: rf_bandwidth value: 225000000
    				attr  7: sampling_frequency value: 245760000
    			voltage6:  (input)
    				attr  0: offset value: 45
    				attr  1: raw value: 970
    				attr  2: scale value: 0.775194
    			voltage8:  (output)
    			4 channel-specific attributes found:
    				attr  0: offset value: 2726
    				attr  1: raw value: 0
    				attr  2: sampling_frequency value: 245760000
    				attr  3: scale value: 0.782954
    			voltage5:  (output)
    			voltage0:  (input)
    				attr  8: rssi value: 2.250 dB
    			voltage2:  (input)
    			voltage9:  (output)
    			voltage4:  (input)
    				attr  1: raw value: 39
    			voltage12:  (output)
    				attr  1: sampling_frequency value: 245760000
    				attr  2: scale value: 0.805861
    			altvoltage0: TRX_LO (output)
    				attr  0: frequency value: 2400000000
    				attr  1: frequency_hopping_mode value: 2400000000
    				attr  2: frequency_hopping_mode_enable value: 0
    			voltage4:  (output)
    			voltage10:  (output)
    			voltage13:  (output)
    			voltage3:  (output)
    			voltage7:  (input)
    				attr  1: raw value: 1061
    			voltage2:  (output)
    			voltage6:  (output)
    			temp0:  (input)
    			1 channel-specific attributes found:
    				attr  0: input value: 72000
    			voltage0:  (output)
    			altvoltage1:  (output)
    				attr  0: AUX_OBS_RX_LO_frequency value: 2430000000
    			voltage11:  (output)
    			voltage7:  (output)
    			voltage5:  (input)
    				attr  1: raw value: 1013
    		12 device-specific attributes found:
    				attr  0: calibrate ERROR: Input/output error (-5)
    				attr  1: calibrate_frm_en value: 0
    				attr  2: calibrate_rx_phase_correction_en value: 0
    				attr  3: calibrate_rx_qec_en value: 0
    				attr  4: calibrate_tx_lol_en value: 0
    				attr  5: calibrate_tx_lol_ext_en value: 0
    				attr  6: calibrate_tx_qec_en value: 0
    				attr  7: ensm_mode value: radio_on
    				attr  8: ensm_mode_available value: radio_on radio_off
    				attr  9: gain_table_config ERROR: Permission denied (-13)
    				attr 10: multichip_sync ERROR: Input/output error (-5)
    				attr 11: profile_config value: TB
    		306 debug attributes found:
    				debug attr  0: gpio3v3 value: 0
    				debug attr  1: bist_tone value: 0
    				debug attr  2: bist_framer_b_loopback value: 0
    				debug attr  3: bist_framer_a_loopback value: 0
    				debug attr  4: bist_framer_b_prbs value: 0
    				debug attr  5: bist_framer_a_prbs value: 0
    				debug attr  6: initialize value: 0
    				debug attr  7: adi,aux-pll-lo-frequency_hz value: 2500000000
    				debug attr  8: adi,trx-pll-lo-frequency_hz value: 2400000000
    				debug attr  9: adi,dig-clocks-rf-pll-phase-sync-mode value: 0
    				debug attr 10: adi,dig-clocks-rf-pll-use-external-lo value: 0
    				debug attr 11: adi,dig-clocks-clk-pll-hs-div value: 1
    				debug attr 12: adi,dig-clocks-clk-pll-vco-freq_khz value: 9830400
    				debug attr 13: adi,dig-clocks-device-clock_khz value: 245760
    				debug attr 14: adi,tx-settings-dis-tx-data-if-pll-unlock value: 0
    				debug attr 15: adi,tx-settings-tx2-atten_md-b value: 10000
    				debug attr 16: adi,tx-settings-tx1-atten_md-b value: 10000
    				debug attr 17: adi,tx-settings-tx-atten-step-size value: 0
    				debug attr 18: adi,tx-settings-tx-channels value: 3
    				debug attr 19: adi,tx-settings-deframer-sel value: 0
    				debug attr 20: adi,tx-profile-tx-bbf3d-bcorner_khz value: 113000
    				debug attr 21: adi,tx-profile-tx-dac3d-bcorner_khz value: 225000
    				debug attr 22: adi,tx-profile-rf-bandwidth_hz value: 225000000
    				debug attr 23: adi,tx-profile-primary-sig-bandwidth_hz value: 100000000
    				debug attr 24: adi,tx-profile-tx-input-rate_khz value: 245760
    				debug attr 25: adi,tx-profile-tx-int5-interpolation value: 1
    				debug attr 26: adi,tx-profile-thb3-interpolation value: 2
    				debug attr 27: adi,tx-profile-thb2-interpolation value: 2
    				debug attr 28: adi,tx-profile-thb1-interpolation value: 2
    				debug attr 29: adi,tx-profile-tx-fir-interpolation value: 1
    				debug attr 30: adi,tx-profile-dac-div value: 1
    				debug attr 31: adi,tx-profile-tx-fir-num-fir-coefs value: 40
    				debug attr 32: adi,tx-profile-tx-fir-gain_db value: 6
    				debug attr 33: adi,obs-settings-obs-rx-lo-source value: 0
    				debug attr 34: adi,obs-settings-obs-rx-channels-enable value: 3
    				debug attr 35: adi,obs-settings-framer-sel value: 1
    				debug attr 36: adi,orx-gain-control-orx2-min-gain-index value: 195
    				debug attr 37: adi,orx-gain-control-orx2-max-gain-index value: 255
    				debug attr 38: adi,orx-gain-control-orx1-min-gain-index value: 195
    				debug attr 39: adi,orx-gain-control-orx1-max-gain-index value: 255
    				debug attr 40: adi,orx-gain-control-orx2-gain-index value: 255
    				debug attr 41: adi,orx-gain-control-orx1-gain-index value: 255
    				debug attr 42: adi,orx-gain-control-gain-mode value: 0
    				debug attr 43: adi,orx-profile-orx-ddc-mode value: 0
    				debug attr 44: adi,orx-profile-rx-bbf3d-bcorner_khz value: 225000
    				debug attr 45: adi,orx-profile-rf-bandwidth_hz value: 200000000
    				debug attr 46: adi,orx-profile-orx-output-rate_khz value: 245760
    				debug attr 47: adi,orx-profile-rhb1-decimation value: 2
    				debug attr 48: adi,orx-profile-rx-dec5-decimation value: 4
    				debug attr 49: adi,orx-profile-rx-fir-decimation value: 1
    				debug attr 50: adi,orx-profile-rx-fir-num-fir-coefs value: 24
    				debug attr 51: adi,orx-profile-rx-fir-gain_db value: 6
    				debug attr 52: adi,rx-settings-rx-channels value: 3
    				debug attr 53: adi,rx-settings-framer-sel value: 0
    				debug attr 54: adi,rx-gain-control-rx2-min-gain-index value: 195
    				debug attr 55: adi,rx-gain-control-rx2-max-gain-index value: 255
    				debug attr 56: adi,rx-gain-control-rx1-min-gain-index value: 195
    				debug attr 57: adi,rx-gain-control-rx1-max-gain-index value: 255
    				debug attr 58: adi,rx-gain-control-rx2-gain-index value: 255
    				debug attr 59: adi,rx-gain-control-rx1-gain-index value: 255
    				debug attr 60: adi,rx-gain-control-gain-mode value: 0
    				debug attr 61: adi,rx-nco-shifter-band-bnco2-freq_khz value: 0
    				debug attr 62: adi,rx-nco-shifter-band-bnco1-freq_khz value: 0
    				debug attr 63: adi,rx-nco-shifter-band-binput-center-freq_khz value: 0
    				debug attr 64: adi,rx-nco-shifter-band-binput-band-width_khz value: 0
    				debug attr 65: adi,rx-nco-shifter-band-a-nco2-freq_khz value: 0
    				debug attr 66: adi,rx-nco-shifter-band-a-nco1-freq_khz value: 0
    				debug attr 67: adi,rx-nco-shifter-band-a-input-center-freq_khz value: 0
    				debug attr 68: adi,rx-nco-shifter-band-a-input-band-width_khz value: 0
    				debug attr 69: adi,rx-profile-rx-ddc-mode value: 0
    				debug attr 70: adi,rx-profile-rx-bbf3d-bcorner_khz value: 200000
    				debug attr 71: adi,rx-profile-rf-bandwidth_hz value: 200000000
    				debug attr 72: adi,rx-profile-rx-output-rate_khz value: 245760
    				debug attr 73: adi,rx-profile-rhb1-decimation value: 1
    				debug attr 74: adi,rx-profile-rx-dec5-decimation value: 4
    				debug attr 75: adi,rx-profile-rx-fir-decimation value: 2
    				debug attr 76: adi,rx-profile-rx-fir-num-fir-coefs value: 48
    				debug attr 77: adi,rx-profile-rx-fir-gain_db value: 250
    				debug attr 78: adi,tx-pa-protection-tx2-peak-threshold value: 140
    				debug attr 79: adi,tx-pa-protection-tx1-peak-threshold value: 140
    				debug attr 80: adi,tx-pa-protection-peak-count value: 4
    				debug attr 81: adi,tx-pa-protection-tx2-power-threshold value: 4096
    				debug attr 82: adi,tx-pa-protection-tx1-power-threshold value: 4096
    				debug attr 83: adi,tx-pa-protection-tx-atten-step value: 2
    				debug attr 84: adi,tx-pa-protection-avg-duration value: 3
    				debug attr 85: adi,tx2-atten-ctrl-pin-enable value: 0
    				debug attr 86: adi,tx2-atten-ctrl-pin-tx-atten-dec-pin value: 7
    				debug attr 87: adi,tx2-atten-ctrl-pin-tx-atten-inc-pin value: 6
    				debug attr 88: adi,tx2-atten-ctrl-pin-step-size value: 0
    				debug attr 89: adi,tx1-atten-ctrl-pin-enable value: 0
    				debug attr 90: adi,tx1-atten-ctrl-pin-tx-atten-dec-pin value: 5
    				debug attr 91: adi,tx1-atten-ctrl-pin-tx-atten-inc-pin value: 4
    				debug attr 92: adi,tx1-atten-ctrl-pin-step-size value: 0
    				debug attr 93: adi,rx2-gain-ctrl-pin-enable value: 0
    				debug attr 94: adi,rx2-gain-ctrl-pin-rx-gain-dec-pin value: 4
    				debug attr 95: adi,rx2-gain-ctrl-pin-rx-gain-inc-pin value: 3
    				debug attr 96: adi,rx2-gain-ctrl-pin-dec-step value: 1
    				debug attr 97: adi,rx2-gain-ctrl-pin-inc-step value: 1
    				debug attr 98: adi,rx1-gain-ctrl-pin-enable value: 0
    				debug attr 99: adi,rx1-gain-ctrl-pin-rx-gain-dec-pin value: 1
    				debug attr 100: adi,rx1-gain-ctrl-pin-rx-gain-inc-pin value: 0
    				debug attr 101: adi,rx1-gain-ctrl-pin-dec-step value: 1
    				debug attr 102: adi,rx1-gain-ctrl-pin-inc-step value: 1
    				debug attr 103: adi,fhm-mode-fhm-init-frequency_hz value: 2450000000
    				debug attr 104: adi,fhm-mode-fhm-exit-mode value: 1
    				debug attr 105: adi,fhm-mode-fhm-trigger-mode value: 0
    				debug attr 106: adi,fhm-mode-enable-mcs-sync value: 0
    				debug attr 107: adi,fhm-mode-fhm-enable value: 0
    				debug attr 108: adi,fhm-config-fhm-max-freq_mhz value: 2500
    				debug attr 109: adi,fhm-config-fhm-min-freq_mhz value: 2400
    				debug attr 110: adi,fhm-config-fhm-gpio-pin value: 0
    				debug attr 111: adi,orx-lo-cfg-gpio-select value: 19
    				debug attr 112: adi,orx-lo-cfg-disable-aux-pll-relocking value: 0
    				debug attr 113: adi,gpio3v3-output-level-mask value: 0
    				debug attr 114: adi,gpio3v3-output-enable-mask value: 0
    				debug attr 115: adi,gpio3v3-source-control value: 0
    				debug attr 116: adi,arm-gpio-config-en-tx-tracking-cals-enable value: 0
    				debug attr 117: adi,arm-gpio-config-en-tx-tracking-cals-polarity value: 0
    				debug attr 118: adi,arm-gpio-config-en-tx-tracking-cals-gpio-pin-sel value: 0
    				debug attr 119: adi,arm-gpio-config-orx2-tx-sel1-pin-enable value: 0
    				debug attr 120: adi,arm-gpio-config-orx2-tx-sel1-pin-polarity value: 0
    				debug attr 121: adi,arm-gpio-config-orx2-tx-sel1-pin-gpio-pin-sel value: 0
    				debug attr 122: adi,arm-gpio-config-orx2-tx-sel0-pin-enable value: 0
    				debug attr 123: adi,arm-gpio-config-orx2-tx-sel0-pin-polarity value: 0
    				debug attr 124: adi,arm-gpio-config-orx2-tx-sel0-pin-gpio-pin-sel value: 0
    				debug attr 125: adi,arm-gpio-config-orx1-tx-sel1-pin-enable value: 0
    				debug attr 126: adi,arm-gpio-config-orx1-tx-sel1-pin-polarity value: 0
    				debug attr 127: adi,arm-gpio-config-orx1-tx-sel1-pin-gpio-pin-sel value: 0
    				debug attr 128: adi,arm-gpio-config-orx1-tx-sel0-pin-enable value: 0
    				debug attr 129: adi,arm-gpio-config-orx1-tx-sel0-pin-polarity value: 0
    				debug attr 130: adi,arm-gpio-config-orx1-tx-sel0-pin-gpio-pin-sel value: 0
    				debug attr 131: adi,jesd204-sysref-lvds-pn-invert value: 0
    				debug attr 132: adi,jesd204-sysref-lvds-mode value: 1
    				debug attr 133: adi,jesd204-des-eq-setting value: 1
    				debug attr 134: adi,jesd204-des-invert-lane-polarity value: 0
    				debug attr 135: adi,jesd204-ser-invert-lane-polarity value: 0
    				debug attr 136: adi,jesd204-ser-pre-emphasis value: 1
    				debug attr 137: adi,jesd204-ser-amplitude value: 15
    				debug attr 138: adi,jesd204-deframer-b-enable-manual-lane-xbar value: 0
    				debug attr 139: adi,jesd204-deframer-b-syncb-out-cmos-drive-level value: 0
    				debug attr 140: adi,jesd204-deframer-b-syncb-out-cmos-slew-rate value: 0
    				debug attr 141: adi,jesd204-deframer-b-syncb-out-lvds-pn-invert value: 0
    				debug attr 142: adi,jesd204-deframer-b-syncb-out-lvds-mode value: 1
    				debug attr 143: adi,jesd204-deframer-b-np value: 16
    				debug attr 144: adi,jesd204-deframer-b-syncb-out-select value: 0
    				debug attr 145: adi,jesd204-deframer-b-new-sysref-on-relink value: 0
    				debug attr 146: adi,jesd204-deframer-b-lmfc-offset value: 0
    				debug attr 147: adi,jesd204-deframer-b-deserializer-lane-crossbar value: 228
    				debug attr 148: adi,jesd204-deframer-b-deserializer-lanes-enabled value: 0
    				debug attr 149: adi,jesd204-deframer-b-external-sysref value: 1
    				debug attr 150: adi,jesd204-deframer-b-scramble value: 1
    				debug attr 151: adi,jesd204-deframer-b-k value: 32
    				debug attr 152: adi,jesd204-deframer-b-m value: 0
    				debug attr 153: adi,jesd204-deframer-b-lane0-id value: 0
    				debug attr 154: adi,jesd204-deframer-b-device-id value: 0
    				debug attr 155: adi,jesd204-deframer-b-bank-id value: 0
    				debug attr 156: adi,jesd204-deframer-a-enable-manual-lane-xbar value: 0
    				debug attr 157: adi,jesd204-deframer-a-syncb-out-cmos-drive-level value: 0
    				debug attr 158: adi,jesd204-deframer-a-syncb-out-cmos-slew-rate value: 0
    				debug attr 159: adi,jesd204-deframer-a-syncb-out-lvds-pn-invert value: 0
    				debug attr 160: adi,jesd204-deframer-a-syncb-out-lvds-mode value: 1
    				debug attr 161: adi,jesd204-deframer-a-np value: 16
    				debug attr 162: adi,jesd204-deframer-a-syncb-out-select value: 0
    				debug attr 163: adi,jesd204-deframer-a-new-sysref-on-relink value: 0
    				debug attr 164: adi,jesd204-deframer-a-lmfc-offset value: 17
    				debug attr 165: adi,jesd204-deframer-a-deserializer-lane-crossbar value: 228
    				debug attr 166: adi,jesd204-deframer-a-deserializer-lanes-enabled value: 15
    				debug attr 167: adi,jesd204-deframer-a-external-sysref value: 1
    				debug attr 168: adi,jesd204-deframer-a-scramble value: 1
    				debug attr 169: adi,jesd204-deframer-a-k value: 32
    				debug attr 170: adi,jesd204-deframer-a-m value: 4
    				debug attr 171: adi,jesd204-deframer-a-lane0-id value: 0
    				debug attr 172: adi,jesd204-deframer-a-device-id value: 0
    				debug attr 173: adi,jesd204-deframer-a-bank-id value: 0
    				debug attr 174: adi,jesd204-framer-b-enable-manual-lane-xbar value: 0
    				debug attr 175: adi,jesd204-framer-b-syncb-in-lvds-pn-invert value: 0
    				debug attr 176: adi,jesd204-framer-b-syncb-in-lvds-mode value: 1
    				debug attr 177: adi,jesd204-framer-b-over-sample value: 0
    				debug attr 178: adi,jesd204-framer-b-syncb-in-select value: 1
    				debug attr 179: adi,jesd204-framer-b-new-sysref-on-relink value: 0
    				debug attr 180: adi,jesd204-framer-b-lmfc-offset value: 31
    				debug attr 181: adi,jesd204-framer-b-serializer-lane-crossbar value: 228
    				debug attr 182: adi,jesd204-framer-b-serializer-lanes-enabled value: 12
    				debug attr 183: adi,jesd204-framer-b-external-sysref value: 1
    				debug attr 184: adi,jesd204-framer-b-scramble value: 1
    				debug attr 185: adi,jesd204-framer-b-np value: 16
    				debug attr 186: adi,jesd204-framer-b-f value: 4
    				debug attr 187: adi,jesd204-framer-b-k value: 32
    				debug attr 188: adi,jesd204-framer-b-m value: 4
    				debug attr 189: adi,jesd204-framer-b-lane0-id value: 0
    				debug attr 190: adi,jesd204-framer-b-device-id value: 0
    				debug attr 191: adi,jesd204-framer-b-bank-id value: 0
    				debug attr 192: adi,jesd204-framer-a-enable-manual-lane-xbar value: 0
    				debug attr 193: adi,jesd204-framer-a-syncb-in-lvds-pn-invert value: 0
    				debug attr 194: adi,jesd204-framer-a-syncb-in-lvds-mode value: 1
    				debug attr 195: adi,jesd204-framer-a-over-sample value: 0
    				debug attr 196: adi,jesd204-framer-a-syncb-in-select value: 0
    				debug attr 197: adi,jesd204-framer-a-new-sysref-on-relink value: 0
    				debug attr 198: adi,jesd204-framer-a-lmfc-offset value: 31
    				debug attr 199: adi,jesd204-framer-a-serializer-lane-crossbar value: 228
    				debug attr 200: adi,jesd204-framer-a-serializer-lanes-enabled value: 3
    				debug attr 201: adi,jesd204-framer-a-external-sysref value: 1
    				debug attr 202: adi,jesd204-framer-a-scramble value: 1
    				debug attr 203: adi,jesd204-framer-a-np value: 16
    				debug attr 204: adi,jesd204-framer-a-f value: 4
    				debug attr 205: adi,jesd204-framer-a-k value: 32
    				debug attr 206: adi,jesd204-framer-a-m value: 4
    				debug attr 207: adi,jesd204-framer-a-lane0-id value: 0
    				debug attr 208: adi,jesd204-framer-a-device-id value: 0
    				debug attr 209: adi,jesd204-framer-a-bank-id value: 1
    				debug attr 210: adi,aux-dac-values11 value: 0
    				debug attr 211: adi,aux-dac-values10 value: 0
    				debug attr 212: adi,aux-dac-values9 value: 0
    				debug attr 213: adi,aux-dac-resolution9 value: 0
    				debug attr 214: adi,aux-dac-vref9 value: 3
    				debug attr 215: adi,aux-dac-values8 value: 0
    				debug attr 216: adi,aux-dac-resolution8 value: 0
    				debug attr 217: adi,aux-dac-vref8 value: 3
    				debug attr 218: adi,aux-dac-values7 value: 0
    				debug attr 219: adi,aux-dac-resolution7 value: 0
    				debug attr 220: adi,aux-dac-vref7 value: 3
    				debug attr 221: adi,aux-dac-values6 value: 0
    				debug attr 222: adi,aux-dac-resolution6 value: 0
    				debug attr 223: adi,aux-dac-vref6 value: 3
    				debug attr 224: adi,aux-dac-values5 value: 0
    				debug attr 225: adi,aux-dac-resolution5 value: 0
    				debug attr 226: adi,aux-dac-vref5 value: 3
    				debug attr 227: adi,aux-dac-values4 value: 0
    				debug attr 228: adi,aux-dac-resolution4 value: 0
    				debug attr 229: adi,aux-dac-vref4 value: 3
    				debug attr 230: adi,aux-dac-values3 value: 0
    				debug attr 231: adi,aux-dac-resolution3 value: 0
    				debug attr 232: adi,aux-dac-vref3 value: 3
    				debug attr 233: adi,aux-dac-values2 value: 0
    				debug attr 234: adi,aux-dac-resolution2 value: 0
    				debug attr 235: adi,aux-dac-vref2 value: 3
    				debug attr 236: adi,aux-dac-values1 value: 0
    				debug attr 237: adi,aux-dac-resolution1 value: 0
    				debug attr 238: adi,aux-dac-vref1 value: 3
    				debug attr 239: adi,aux-dac-values0 value: 0
    				debug attr 240: adi,aux-dac-resolution0 value: 0
    				debug attr 241: adi,aux-dac-vref0 value: 3
    				debug attr 242: adi,aux-dac-enables value: 0
    				debug attr 243: adi,rxagc-agc-enable-fast-recovery-loop value: 0
    				debug attr 244: adi,rxagc-ip3-peak-exceeded-cnt value: 4
    				debug attr 245: adi,rxagc-ip3-over-range-thresh-index value: 246
    				debug attr 246: adi,rxagc-ip3-over-range-thresh value: 31
    				debug attr 247: adi,rxagc-agc-enable-ip3-optimization-thresh value: 0
    				debug attr 248: adi,rxagc-agc-enable-sync-pulse-for-gain-counter value: 0
    				debug attr 249: adi,rxagc-agc-reset-on-rxon value: 0
    				debug attr 250: adi,rxagc-agc-peak-thresh-gain-control-mode value: 1
    				debug attr 251: adi,rxagc-agc-change-gain-if-thresh-high value: 1
    				debug attr 252: adi,rxagc-agc-low-thresh-prevent-gain value: 0
    				debug attr 253: adi,rxagc-agc-slow-loop-settling-delay value: 16
    				debug attr 254: adi,rxagc-agc-rx2-attack-delay value: 10
    				debug attr 255: adi,rxagc-agc-rx1-attack-delay value: 10
    				debug attr 256: adi,rxagc-agc-gain-update-counter_us value: 250
    				debug attr 257: adi,rxagc-agc-rx2-min-gain-index value: 195
    				debug attr 258: adi,rxagc-agc-rx2-max-gain-index value: 255
    				debug attr 259: adi,rxagc-agc-rx1-min-gain-index value: 195
    				debug attr 260: adi,rxagc-agc-rx1-max-gain-index value: 255
    				debug attr 261: adi,rxagc-agc-peak-wait-time value: 4
    				debug attr 262: adi,rxagc-power-power-log-shift value: 0
    				debug attr 263: adi,rxagc-power-upper1-power-thresh value: 0
    				debug attr 264: adi,rxagc-power-upper0-power-thresh value: 2
    				debug attr 265: adi,rxagc-power-rx2-tdd-power-meas-delay value: 1
    				debug attr 266: adi,rxagc-power-rx2-tdd-power-meas-duration value: 5
    				debug attr 267: adi,rxagc-power-rx1-tdd-power-meas-delay value: 1
    				debug attr 268: adi,rxagc-power-rx1-tdd-power-meas-duration value: 5
    				debug attr 269: adi,rxagc-power-power-measurement-duration value: 5
    				debug attr 270: adi,rxagc-power-under-range-low-power-gain-step-recovery value: 4
    				debug attr 271: adi,rxagc-power-under-range-high-power-gain-step-recovery value: 4
    				debug attr 272: adi,rxagc-power-under-range-low-power-thresh value: 2
    				debug attr 273: adi,rxagc-power-under-range-high-power-thresh value: 9
    				debug attr 274: adi,rxagc-power-power-use-bbdc2 value: 0
    				debug attr 275: adi,rxagc-power-power-use-rfir-out value: 1
    				debug attr 276: adi,rxagc-power-power-enable-measurement value: 1
    				debug attr 277: adi,rxagc-peak-hb2-thresh-config value: 3
    				debug attr 278: adi,rxagc-peak-hb2-ovrg-sel value: 0
    				debug attr 279: adi,rxagc-peak-hb2-overload-power-mode value: 1
    				debug attr 280: adi,rxagc-peak-hb2-gain-step-attack value: 4
    				debug attr 281: adi,rxagc-peak-hb2-gain-step-mid-recovery value: 8
    				debug attr 282: adi,rxagc-peak-hb2-gain-step-low-recovery value: 4
    				debug attr 283: adi,rxagc-peak-hb2-gain-step-high-recovery value: 2
    				debug attr 284: adi,rxagc-peak-hb2-lower-thresh-peak-exceeded-cnt value: 3
    				debug attr 285: adi,rxagc-peak-hb2-upper-thresh-peak-exceeded-cnt value: 6
    				debug attr 286: adi,rxagc-peak-hb2-under-range-high-thresh value: 128
    				debug attr 287: adi,rxagc-peak-hb2-under-range-mid-thresh value: 90
    				debug attr 288: adi,rxagc-peak-hb2-under-range-low-thresh value: 45
    				debug attr 289: adi,rxagc-peak-hb2-high-thresh value: 181
    				debug attr 290: adi,rxagc-peak-hb2-overload-thresh-cnt value: 4
    				debug attr 291: adi,rxagc-peak-hb2-overload-duration-cnt value: 1
    				debug attr 292: adi,rxagc-peak-enable-hb2-overload value: 1
    				debug attr 293: adi,rxagc-peak-apd-gain-step-recovery value: 2
    				debug attr 294: adi,rxagc-peak-apd-gain-step-attack value: 4
    				debug attr 295: adi,rxagc-peak-apd-lower-thresh-peak-exceeded-cnt value: 3
    				debug attr 296: adi,rxagc-peak-apd-upper-thresh-peak-exceeded-cnt value: 6
    				debug attr 297: adi,rxagc-peak-apd-low-gain-mode-low-thresh value: 19
    				debug attr 298: adi,rxagc-peak-apd-low-thresh value: 23
    				debug attr 299: adi,rxagc-peak-apd-low-gain-mode-high-thresh value: 36
    				debug attr 300: adi,rxagc-peak-apd-high-thresh value: 39
    				debug attr 301: adi,rxagc-peak-agc-under-range-high-interval value: 4
    				debug attr 302: adi,rxagc-peak-agc-under-range-mid-interval value: 2
    				debug attr 303: adi,rxagc-peak-agc-under-range-low-interval_ns value: 205
    				debug attr 304: adi,default-initial-calibrations-mask value: 9362927
    				debug attr 305: direct_reg_access value: 0x3C
    	iio:device4: axi-adrv9009-rx-obs-hpc (buffer capable)
    		4 channels found:
    			voltage0_i:  (input, index: 0, format: le:S16/16>>0)
    			voltage0_q:  (input, index: 1, format: le:S16/16>>0)
    			voltage1_i:  (input, index: 2, format: le:S16/16>>0)
    			voltage1_q:  (input, index: 3, format: le:S16/16>>0)
    				attr  0: sampling_frequency value: 245760000
    		3 buffer-specific attributes found:
    				attr  0: data_available value: 0
    				attr  1: length_align_bytes value: 16
    				attr  2: watermark value: 2048
    				debug attr  0: direct_reg_access value: 0xA0162
    	iio:device5: axi-adrv9009-tx-hpc (buffer capable)
    		12 channels found:
    			voltage0:  (output, index: 0, format: le:S16/16>>0)
    				attr  0: calibphase value: 0.000000
    				attr  1: calibscale value: 0.000000
    				attr  3: sampling_frequency_available value: 245760000 30720000
    			voltage1:  (output, index: 1, format: le:S16/16>>0)
    			voltage2:  (output, index: 2, format: le:S16/16>>0)
    			voltage3:  (output, index: 3, format: le:S16/16>>0)
    			altvoltage3: TX1_Q_F2 (output)
    			5 channel-specific attributes found:
    				attr  0: frequency value: 40001860
    				attr  3: sampling_frequency value: 245760000
    				attr  4: scale value: 0.000000
    			altvoltage1: TX1_I_F2 (output)
    				attr  1: phase value: 90000
    			altvoltage0: TX1_I_F1 (output)
    				attr  4: scale value: 0.251160
    			altvoltage7: TX2_Q_F2 (output)
    			altvoltage6: TX2_Q_F1 (output)
    			altvoltage5: TX2_I_F2 (output)
    			altvoltage2: TX1_Q_F1 (output)
    			altvoltage4: TX2_I_F1 (output)
    		2 debug attributes found:
    				debug attr  0: pl_ddr_fifo_enable value: 0
    				debug attr  1: direct_reg_access value: 0x90162
    	iio:device6: axi-adrv9009-rx-hpc (buffer capable)
    		4 channels found:
    				attr  0: calibbias value: 0
    				attr  1: calibphase value: 0.000000
    				attr  2: calibscale value: 0.000000
    				attr  4: sampling_frequency_available value: 245760000 30720000
    				attr  1: length_align_bytes value: 8
    				debug attr  0: pseudorandom_err_check value: CH0 : PN9 : Out of Sync : PN Error
    CH1 : PN9 : Out of Sync : PN Error
    CH2 : PN9 : Out of Sync : PN Error
    CH3 : PN9 : Out of Sync : PN Error
    				debug attr  1: direct_reg_access value: 0x0
    	iio_sysfs_trigger:
    		0 channels found:
    				attr  0: add_trigger ERROR: Permission denied (-13)
    				attr  1: remove_trigger ERROR: Permission denied (-13)
    plnx_iio_info.txt
    Library version: 0.18 (git tag: v0.18)
    Compiled with backends: local xml ip usb
    Backend version: 0.18 (git tag: v0.18)
    Backend description string: Linux adi_linux 4.14.0-xilinx- #1 SMP Fri Sep 10 11:44:08 UTC 2021 aarch64
    IIO context has 1 attributes:
    	local,kernel: 4.14.0-xilinx-
    IIO context has 6 devices:
    	iio:device0: ams
    		30 channels found:
    				attr  1: raw value: 40286
    				attr  0: raw value: 19515
    				attr  0: raw value: 26339
    				attr  0: raw value: 19802
    				attr  0: raw value: 30128
    				attr  0: raw value: 18530
    				attr  0: raw value: 18514
    				attr  0: raw value: 18468
    				attr  0: raw value: 18564
    				attr  1: raw value: 40420
    				attr  0: raw value: 39420
    				attr  0: raw value: 19525
    				attr  0: raw value: 18448
    				attr  0: raw value: 18495
    				attr  0: raw value: 18488
    				attr  0: raw value: 39232
    				attr  0: raw value: 39586
    				attr  0: raw value: 39736
    				attr  0: raw value: 39591
    				attr  0: raw value: 39256
    				attr  0: raw value: 18535
    				attr  0: raw value: 27314
    				attr  0: raw value: 25823
    				attr  0: raw value: 19537
    				attr [   36.161533] PLL: enable
    				attr  1: raw value: 40292
    				attr  0: raw value: 18560
    				attr  0: raw value: 18439
    				attr  0: raw value: 39572
    				attr  0: raw value: 39220
    		4 channels found:
    				attr  7: sync_dividers ERROR: Permission denied (-13)
    	iio:device2: adrv9009-phy
    		25 channels found:
    			voltage1:  (input)
    			voltage3:  (input)
    			voltage1:  (output)
    			voltage6:  (input)
    				attr  1: raw value: 755
    			voltage8:  (output)
    			voltage5:  (output)
    			voltage0:  (input)
    				attr  8: rssi value: 2.00 dB
    			voltage2:  (input)
    			voltage9:  (output)
    			voltage4:  (input)
    				attr  1: raw value: 45
    			voltage12:  (output)
    			voltage4:  (output)
    			voltage10:  (output)
    			voltage13:  (output)
    			voltage3:  (output)
    			voltage7:  (input)
    			voltage2:  (output)
    			voltage6:  (output)
    			temp0:  (input)
    				attr  0: input value: 61000
    			voltage0:  (output)
    			voltage11:  (output)
    			voltage7:  (output)
    			voltage5:  (input)
    				attr  1: raw value: 580
    				attr 10: multichip_sync ERROR: Permission denied (-13)
    	iio:device3: axi-adrv9009-tx-hpc (buffer capable)
    		12 channels found:
    				attr  4: scale value: 0.250000
    	iio:device4: axi-adrv9009-rx-hpc (buffer capable)
    		4 channels found:
    	iio_sysfs_trigger:
    		0 channels found:
    I guess that this image can work well because I don't use rx-obs datapath.So
    I want to know that I should add what drivers when I use petalinux-config command to config kernel???
    What menu check correspond this two drivers ??
    The following pic is the menu via which I could config drivers——
    I guess they should be in Industry I/O support menu?
    Could you help me ??
    Regards!
    Tse.
Reply
    ADI_r1_iio_info.txt
    	uri: local:
    	iio:device0: ams
    		30 channels found:
    		4 channels found:
    	iio:device2: ad7291
    		9 channels found:
    			voltage6:  (input)
    			temp0:  (input)
    			voltage3:  (input)
    			voltage7:  (input)
    			voltage0:  (input)
    			voltage4:  (input)
    			voltage1:  (input)
    			voltage5:  (input)
    			voltage2:  (input)
    		25 channels found:
    			voltage1:  (input)
    			voltage3:  (input)
    			voltage1:  (output)
    			voltage6:  (input)
    			voltage8:  (output)
    			voltage5:  (output)
    			voltage0:  (input)
    			voltage2:  (input)
    			voltage9:  (output)
    			voltage4:  (input)
    			voltage12:  (output)
    			voltage4:  (output)
    			voltage10:  (output)
    			voltage13:  (output)
    			voltage3:  (output)
    			voltage7:  (input)
    			voltage2:  (output)
    			voltage6:  (output)
    			temp0:  (input)
    			voltage0:  (output)
    			voltage11:  (output)
    			voltage7:  (output)
    			voltage5:  (input)
    		4 channels found:
    		12 channels found:
    		4 channels found:
    	iio_sysfs_trigger:
    		0 channels found:
    plnx_iio_info.txt
    	iio:device0: ams
    		30 channels found:
    		4 channels found:
    		25 channels found:
    			voltage1:  (input)
    			voltage3:  (input)
    			voltage1:  (output)
    			voltage6:  (input)
    			voltage8:  (output)
    			voltage5:  (output)
    			voltage0:  (input)
    			voltage2:  (input)
    			voltage9:  (output)
    			voltage4:  (input)
    			voltage12:  (output)
    			voltage4:  (output)
    			voltage10:  (output)
    			voltage13:  (output)
    			voltage3:  (output)
    			voltage7:  (input)
    			voltage2:  (output)
    			voltage6:  (output)
    			temp0:  (input)
    			voltage0:  (output)
    			voltage11:  (output)
    			voltage7:  (output)
    			voltage5:  (input)
    		12 channels found:
    		4 channels found:
    	iio_sysfs_trigger:
    		0 channels found:
    Regards!
    Tse.
Children
No Data
