I'm working on a zedboard-AD7768-1 project. I've seen that the single-shot acquisition via /sys/bus/iio/devices/iio:device0/in_voltage0_raw is working. I would like to get the buffered readings. Almost all literature I've read about buffered reading talks about triggers and how to use it. I've also seen the AD7768-1 Linux driver page (https://wiki.analog.com/resources/tools-software/linux-drivers/iio-adc/ad7768-1) having its trigger management section. The problem is, there is no trigger file inside my AD7768-1's sysfs directory:
And so I can't really follow that section. How can I access the buffer instead? Is there other ways to use the trigger? Just want to know, since AD7768-1's driver source apparently supports triggering. I'm using 2019_R2 versions for my meta-adi as well as HDL.
