ostoto@ostoto:~/linux$ git apply --reject --whitespace=fix hopper.patch Checking patch arch/arm/configs/zynq_xcomm_adv7511_defconfig... error: while searching for: CONFIG_ADIS16400=y CONFIG_ADIS16460=y CONFIG_ADIS16480=y CONFIG_JESD204=y CONFIG_AXI_ADXCVR=y CONFIG_AXI_JESD204B=y error: patch failed: arch/arm/configs/zynq_xcomm_adv7511_defconfig:359 Checking patch drivers/iio/Kconfig... error: while searching for: source "drivers/iio/health/Kconfig" source "drivers/iio/humidity/Kconfig" source "drivers/iio/imu/Kconfig" source "drivers/iio/jesd204/Kconfig" source "drivers/iio/light/Kconfig" source "drivers/iio/logic/Kconfig" error: patch failed: drivers/iio/Kconfig:80 Checking patch drivers/iio/Makefile... error: while searching for: obj-y += health/ obj-y += humidity/ obj-y += imu/ obj-y += jesd204/ obj-y += light/ obj-y += logic/ error: patch failed: drivers/iio/Makefile:25 Checking patch drivers/iio/ip/Kconfig... error: drivers/iio/ip/Kconfig: already exists in working directory Checking patch drivers/iio/ip/Makefile... error: drivers/iio/ip/Makefile: already exists in working directory Checking patch drivers/iio/ip/hopper.c... error: drivers/iio/ip/hopper.c: already exists in working directory Applying patch arch/arm/configs/zynq_xcomm_adv7511_defconfig with 1 reject... Rejected hunk #1. Applying patch drivers/iio/Kconfig with 1 reject... Rejected hunk #1. Applying patch drivers/iio/Makefile with 1 reject... Rejected hunk #1.
I tried to run frequency hopping example on ADRv9361-z7035 board. While building kernel and applying patch as described here gives following error. the terminal log is attaced above.
