ADI kernel build issue (Can't find master linux branch?)
I am building ADI kernel from buildroot using 2019.1 toolchain from Xilinx SDK (per recommendation from the Wiki page). The toolchain version in microblaze_adi_defconfig is set o 4.14 (BR2_TOOLCHAIN_HEADERS_AT_LEAST="4.14"), I had to modify the .config to change that to 4.19 to match. I built rootfs separately and was able to build fine. But kernel build fails because it cant find the master branch (log below)? I think it was looking for master branch of linux and failed and then it tried to download "linux-master.tar.gz" from other repos and couldn't find it aparently and failed. Question : Is its because something I did ? I went into the clone location it tried to fetch and saw its pointed to github.com/.../linux
which does have a master branch
ratin@ratin-ubuntu:~/work/kintex/buildroot/dl/linux/git/.git$ gitrepo
origin github.com/.../linux (fetch)
origin github.com/.../linux (push)
ratin@ratin-ubuntu:~/work/kintex/buildroot/dl/linux/git/.git$ git branch -a | grep master
remotes/origin/altera_adxcvr_master
remotes/origin/master
So I am not sure whats the issue, can anybody shed some light?
Thanks!
Ratin
Build log:
CCLD libkmod/libkmod-internal.la
/usr/bin/ar: `u' modifier ignored since `D' is the default (see `U')
CCLD tools/kmod
GEN tools/rmmod
GEN tools/lsmod
GEN tools/modprobe
GEN tools/insmod
GEN tools/modinfo
GEN tools/depmod
Making all in libkmod/docs
make[4]: Nothing to be done for 'all'.
>>> host-kmod 26 Installing to host directory
PATH="/home/ratin/work/kintex/buildroot/output/host/bin:/home/ratin/work/kintex/buildroot/output/host/sbin:/mnt/tools/Xilinx/SDK/2019.1/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/microblaze/lin/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/arm/lin/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/microblaze/linux_toolchain/lin64_le/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/aarch64/lin/aarch64-linux/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/aarch64/lin/aarch64-none/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/armr5/lin/gcc-arm-none-eabi/bin:/mnt/tools/Xilinx/SDK/2019.1/tps/lnx64/cmake-3.3.2/bin:/mnt/tools/Xilinx/Vivado/2019.1/bin:/mnt/tools/Xilinx/DocNav:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin/bin:/sbin:/usr/bin:/usr/sbin/:/usr/local/bin:/home/mjohnson/software/ds5/bin/:/home/ratin/work/fabric/nsr23-masterbuild/repos/buildroot/out/build/uboot-mathworks_zynq_R20.2.0/tools:/home/ratin/work/fabric/nsr23-masterbuild/repos/buildroot/out/build/host-dtc-1.4.4:/mnt/tools/Xilinx/SDK/2019.1/gnu/microblaze/linux_toolchain/lin64_le/bin" PKG_CONFIG="/home/ratin/work/kintex/buildroot/output/host/bin/pkg-config" PKG_CONFIG_SYSROOT_DIR="/" PKG_CONFIG_ALLOW_SYSTEM_CFLAGS=1 PKG_CONFIG_ALLOW_SYSTEM_LIBS=1 PKG_CONFIG_LIBDIR="/home/ratin/work/kintex/buildroot/output/host/lib/pkgconfig:/home/ratin/work/kintex/buildroot/output/host/share/pkgconfig" /usr/bin/make -j5 install -C /home/ratin/work/kintex/buildroot/output/build/host-kmod-26/
Making install in .
/bin/mkdir -p '/home/ratin/work/kintex/buildroot/output/host/lib'
/bin/mkdir -p '/home/ratin/work/kintex/buildroot/output/host/share/bash-completion/completions'
/bin/mkdir -p '/home/ratin/work/kintex/buildroot/output/host/include'
/bin/mkdir -p '/home/ratin/work/kintex/buildroot/output/host/lib/pkgconfig'
./doltlibtool --mode=install /usr/bin/install -c libkmod/libkmod.la '/home/ratin/work/kintex/buildroot/output/host/lib'
/usr/bin/install -c -m 644 shell-completion/bash/kmod '/home/ratin/work/kintex/buildroot/output/host/share/bash-completion/completions'
/usr/bin/install -c -m 644 libkmod/libkmod.h '/home/ratin/work/kintex/buildroot/output/host/include'
/usr/bin/install -c -m 644 libkmod/libkmod.pc '/home/ratin/work/kintex/buildroot/output/host/lib/pkgconfig'
libtool: install: /usr/bin/install -c libkmod/.libs/libkmod.so.2.3.4 /home/ratin/work/kintex/buildroot/output/host/lib/libkmod.so.2.3.4
libtool: install: (cd /home/ratin/work/kintex/buildroot/output/host/lib && { ln -s -f libkmod.so.2.3.4 libkmod.so.2 || { rm -f libkmod.so.2 && ln -s libkmod.so.2.3.4 libkmod.so.2; }; })
libtool: install: (cd /home/ratin/work/kintex/buildroot/output/host/lib && { ln -s -f libkmod.so.2.3.4 libkmod.so || { rm -f libkmod.so && ln -s libkmod.so.2.3.4 libkmod.so; }; })
libtool: install: /usr/bin/install -c libkmod/.libs/libkmod.lai /home/ratin/work/kintex/buildroot/output/host/lib/libkmod.la
libtool: finish: PATH="/home/ratin/work/kintex/buildroot/output/host/bin:/home/ratin/work/kintex/buildroot/output/host/sbin:/mnt/tools/Xilinx/SDK/2019.1/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/microblaze/lin/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/arm/lin/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/microblaze/linux_toolchain/lin64_le/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/aarch64/lin/aarch64-linux/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/aarch64/lin/aarch64-none/bin:/mnt/tools/Xilinx/SDK/2019.1/gnu/armr5/lin/gcc-arm-none-eabi/bin:/mnt/tools/Xilinx/SDK/2019.1/tps/lnx64/cmake-3.3.2/bin:/mnt/tools/Xilinx/Vivado/2019.1/bin:/mnt/tools/Xilinx/DocNav:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin/bin:/sbin:/usr/bin:/usr/sbin/:/usr/local/bin:/home/mjohnson/software/ds5/bin/:/home/ratin/work/fabric/nsr23-masterbuild/repos/buildroot/out/build/uboot-mathworks_zynq_R20.2.0/tools:/home/ratin/work/fabric/nsr23-masterbuild/repos/buildroot/out/build/host-dtc-1.4.4:/mnt/tools/Xilinx/SDK/2019.1/gnu/microblaze/linux_toolchain/lin64_le/bin:/sbin" ldconfig -n /home/ratin/work/kintex/buildroot/output/host/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the '-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the 'LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the 'LD_RUN_PATH' environment variable
during linking
- use the '-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to '/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/bin/mkdir -p '/home/ratin/work/kintex/buildroot/output/host/bin'
./doltlibtool --mode=install /usr/bin/install -c tools/kmod '/home/ratin/work/kintex/buildroot/output/host/bin'
libtool: install: /usr/bin/install -c tools/kmod /home/ratin/work/kintex/buildroot/output/host/bin/kmod
/usr/bin/make --no-print-directory install-exec-hook
if test "/home/ratin/work/kintex/buildroot/output/host/lib" != "/home/ratin/work/kintex/buildroot/output/host/lib"; then \
/bin/mkdir -p /home/ratin/work/kintex/buildroot/output/host/lib && \
so_img_name=$(readlink /home/ratin/work/kintex/buildroot/output/host/lib/libkmod.so) && \
so_img_rel_target_prefix=$(echo /home/ratin/work/kintex/buildroot/output/host/lib | sed 's,\(^/\|\)[^/][^/]*,..,g') && \
ln -sf $so_img_rel_target_prefix/home/ratin/work/kintex/buildroot/output/host/lib/$so_img_name /home/ratin/work/kintex/buildroot/output/host/lib/libkmod.so && \
mv /home/ratin/work/kintex/buildroot/output/host/lib/libkmod.so.* /home/ratin/work/kintex/buildroot/output/host/lib; \
fi
Making install in libkmod/docs
make[4]: Nothing to be done for 'install-exec-am'.
make[4]: Nothing to be done for 'install-data-am'.
mkdir -p /home/ratin/work/kintex/buildroot/output/host/sbin/
ln -sf ../bin/kmod /home/ratin/work/kintex/buildroot/output/host/sbin/depmod
>>> linux master Downloading
Initialized empty Git repository in /home/ratin/work/kintex/buildroot/dl/linux/git/.git/
Fetching all references
warning: redirecting to github.com/.../
remote: Enumerating objects: 8452428, done.
remote: Counting objects: 100% (829/829), done.
remote: Compressing objects: 100% (507/507), done.
Receiving objects: 100% (8452428/8452428), 2.33 GiB | 3.13 MiB/s, done.
remote: Total 8452428 (delta 597), reused 440 (delta 322), pack-reused 8451599
Resolving deltas: 100% (7095154/7095154), done.
From github.com/.../linux
* [new branch] 2014_R1 -> origin/2014_R1
* [new branch] 2014_R2 -> origin/2014_R2
* [new branch] 2014_R2_altera -> origin/2014_R2_altera
* [new branch] 2015_R1 -> origin/2015_R1
* [new branch] 2015_R2 -> origin/2015_R2
* [new branch] 2016_R1 -> origin/2016_R1
* [new branch] 2016_R2 -> origin/2016_R2
* [new branch] 2017_R1 -> origin/2017_R1
* [new branch] 2018_R1 -> origin/2018_R1
* [new branch] 2018_R2 -> origin/2018_R2
* [new branch] 2019_R1 -> origin/2019_R1
* [new branch] 2019_R1_altera -> origin/2019_R1_altera
* [new branch] 2019_R2 -> origin/2019_R2
* [new branch] ad3552r_pr -> origin/ad3552r_pr
* [new branch] ad7173-upstream-yaml -> origin/ad7173-upstream-yaml
* [new branch] ad9361-xilinx-4.14 -> origin/ad9361-xilinx-4.14
* [new branch] ad9361-xilinx-4.9 -> origin/ad9361-xilinx-4.9
* [new branch] ad9545-add-fast-acquisition -> origin/ad9545-add-fast-acquisition
* [new branch] ad9694 -> origin/ad9694
* [new branch] ad9694_2019_r1 -> origin/ad9694_2019_r1
* [new branch] ada4250 -> origin/ada4250
* [new branch] ada4250_dev -> origin/ada4250_dev
* [new branch] adar1000_dev -> origin/adar1000_dev
* [new branch] adas1000 -> origin/adas1000
* [new branch] adau1761-3.10 -> origin/adau1761-3.10
* [new branch] add_ad9695 -> origin/add_ad9695
* [new branch] adf5355 -> origin/adf5355
* [new branch] adf5610 -> origin/adf5610
* [new branch] adi-4.14.0 -> origin/adi-4.14.0
* [new branch] adi-4.19.0 -> origin/adi-4.19.0
* [new branch] adi-4.9.0 -> origin/adi-4.9.0
* [new branch] adi-5.4.0 -> origin/adi-5.4.0
* [new branch] adi-adin-1588-sop -> origin/adi-adin-1588-sop
* [new branch] adin1100-support -> origin/adin1100-support
* [new branch] adin1100-support-4.14 -> origin/adin1100-support-4.14
* [new branch] adin1100-support-5.8 -> origin/adin1100-support-5.8
* [new branch] adl5960-dev -> origin/adl5960-dev
* [new branch] admv1013_rpi_dev -> origin/admv1013_rpi_dev
* [new branch] admv1014_rpi_dev -> origin/admv1014_rpi_dev
* [new branch] admv8818_rpi_dev -> origin/admv8818_rpi_dev
* [new branch] adpd188 -> origin/adpd188
* [new branch] adpd188_iio_driver -> origin/adpd188_iio_driver
* [new branch] adrf6780_rpi_dev -> origin/adrf6780_rpi_dev
* [new branch] adrv9009_a10_test -> origin/adrv9009_a10_test
* [new branch] adrv9009_a10_test_4.14 -> origin/adrv9009_a10_test_4.14
* [new branch] adv7511-3.10 -> origin/adv7511-3.10
* [new branch] adv753x_dev -> origin/adv753x_dev
* [new branch] adxl362 -> origin/adxl362
* [new branch] altera_4.0 -> origin/altera_4.0
* [new branch] altera_4.14 -> origin/altera_4.14
* [new branch] altera_4.4 -> origin/altera_4.4
* [new branch] altera_4.6 -> origin/altera_4.6
* [new branch] altera_4.9 -> origin/altera_4.9
* [new branch] altera_ad917x_dev -> origin/altera_ad917x_dev
* [new branch] altera_adxcvr -> origin/altera_adxcvr
* [new branch] altera_adxcvr_master -> origin/altera_adxcvr_master
* [new branch] altera_iwg24d -> origin/altera_iwg24d
* [new branch] altera_iwg24d_daq2 -> origin/altera_iwg24d_daq2
* [new branch] arria10_fmcomms2 -> origin/arria10_fmcomms2
* [new branch] asoc-adau1372 -> origin/asoc-adau1372
* [new branch] asoc-ssm4329 -> origin/asoc-ssm4329
* [new branch] asoc-ssm4329-3.4 -> origin/asoc-ssm4329-3.4
* [new branch] axi-trigger -> origin/axi-trigger
* [new branch] axi_pwmgen -> origin/axi_pwmgen
* [new branch] bringup_ad9172_fmc -> origin/bringup_ad9172_fmc
* [new branch] ci-check-drivers-with-site -> origin/ci-check-drivers-with-site
* [new branch] clk-ad9517 -> origin/clk-ad9517
* [new branch] cn0501_de10 -> origin/cn0501_de10
* [new branch] daq3 -> origin/daq3
* [new branch] de10_nano -> origin/de10_nano
* [new branch] de10nano_hdmi -> origin/de10nano_hdmi
* [new branch] dev/adrv9002-fh-support -> origin/dev/adrv9002-fh-support
* [new branch] dev/adrv9002-new-axi-conv-drivers -> origin/dev/adrv9002-new-axi-conv-drivers
* [new branch] dev/gsoc2020-ltc2376 -> origin/dev/gsoc2020-ltc2376
* [new branch] dev_ad917x -> origin/dev_ad917x
* [new branch] dev_fmcadc5 -> origin/dev_fmcadc5
* [new branch] dual_lidar1 -> origin/dual_lidar1
* [new branch] fix_axi_pwm_gen_overflow -> origin/fix_axi_pwm_gen_overflow
* [new branch] fix_overflo_r2 -> origin/fix_overflo_r2
* [new branch] fmcomms7_wip -> origin/fmcomms7_wip
* [new branch] gsoc2020-adc -> origin/gsoc2020-adc
* [new branch] gsoc2020-gyro -> origin/gsoc2020-gyro
* [new branch] gsoc2021 -> origin/gsoc2021
* [new branch] hwmon-debugfs -> origin/hwmon-debugfs
* [new branch] iio-ad7888 -> origin/iio-ad7888
* [new branch] iio-ad9523 -> origin/iio-ad9523
* [new branch] iio-sign -> origin/iio-sign
* [new branch] intel_modify_interconnect_architecture -> origin/intel_modify_interconnect_architecture
* [new branch] ltc6952_clk_upstream -> origin/ltc6952_clk_upstream
* [new branch] m2k -> origin/m2k
* [new branch] master -> origin/master
* [new branch] mxfe_adp5587 -> origin/mxfe_adp5587
* [new branch] mxfe_dev -> origin/mxfe_dev
* [new branch] my-iio-work3 -> origin/my-iio-work3
* [new branch] pzsdr_pcie -> origin/pzsdr_pcie
* [new branch] rpi-4.0.y -> origin/rpi-4.0.y
* [new branch] rpi-4.14.y -> origin/rpi-4.14.y
* [new branch] rpi-4.14.y_GSOC_2019 -> origin/rpi-4.14.y_GSOC_2019
* [new branch] rpi-4.19-adxl372-iiocore-4.9 -> origin/rpi-4.19-adxl372-iiocore-4.9
* [new branch] rpi-4.19.y -> origin/rpi-4.19.y
* [new branch] rpi-4.9.y -> origin/rpi-4.9.y
* [new branch] rpi-5.4.y -> origin/rpi-5.4.y
* [new branch] rpi-5.4.y-push_artifacts -> origin/rpi-5.4.y-push_artifacts
* [new branch] rpi-audio -> origin/rpi-audio
* [new branch] rpi-azure-sh -> origin/rpi-azure-sh
* [new branch] rpi_fix -> origin/rpi_fix
* [new branch] staging/admv1014_temp -> origin/staging/admv1014_temp
* [new branch] staging/admv8818_rpi -> origin/staging/admv8818_rpi
* [new branch] stratix10soc -> origin/stratix10soc
* [new branch] v4l2-async-3.10 -> origin/v4l2-async-3.10
* [new branch] xcomm_zynq -> origin/xcomm_zynq
* [new branch] xcomm_zynq_4_0 -> origin/xcomm_zynq_4_0
* [new branch] xcomm_zynq_4_4 -> origin/xcomm_zynq_4_4
* [new branch] xcomm_zynq_4_6 -> origin/xcomm_zynq_4_6
* [new branch] xcomm_zynq_buffer_repeat -> origin/xcomm_zynq_buffer_repeat
* [new branch] xcomm_zynq_usdrx1 -> origin/xcomm_zynq_usdrx1
* [new branch] zerocopy -> origin/zerocopy
* [new branch] zu11eg_100vcxo -> origin/zu11eg_100vcxo
* [new branch] zu11eg_ext_clk -> origin/zu11eg_ext_clk
* [new branch] zu11eg_pfd1_updates -> origin/zu11eg_pfd1_updates
* [new branch] zybo_mh -> origin/zybo_mh
* [new branch] zynq-zed-adv7511-upstream -> origin/zynq-zed-adv7511-upstream
* [new tag] adi-xilinx-2020.1 -> adi-xilinx-2020.1
* [new tag] xcomm_zynq-2013-04-19 -> xcomm_zynq-2013-04-19
Could not fetch special ref 'master'; assuming it is not special.
Commit 'master' does not exist in this repository.
--2021-07-22 11:02:24-- sources.buildroot.net/.../linux-master.tar.gz
Resolving sources.buildroot.net (sources.buildroot.net)... 172.67.72.56, 104.26.0.37, 104.26.1.37, ...
Connecting to sources.buildroot.net (sources.buildroot.net)|172.67.72.56|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2021-07-22 11:02:27 ERROR 404: Not Found.
--2021-07-22 11:02:27-- sources.buildroot.net/linux-master.tar.gz
Resolving sources.buildroot.net (sources.buildroot.net)... 104.26.1.37, 104.26.0.37, 172.67.72.56, ...
Connecting to sources.buildroot.net (sources.buildroot.net)|104.26.1.37|:80... connected.
package/pkg-generic.mk:167: recipe for target '/home/ratin/work/kintex/buildroot/output/build/linux-master/.stamp_downloaded' failed
make[1]: *** [/home/ratin/work/kintex/buildroot/output/build/linux-master/.stamp_downloaded] Error 1
Makefile:84: recipe for target '_all' failed
make: *** [_all] Error 2
  • Hi Ratin,
    I would suggest to use the hash of the latest master as the kernel version that you want, instead of "master". Latest commit as of today is c6fa3d1.
    Cheers,
    -Paul
  • Hi Paul, I tried this custom kernel repo version  (c6fa3d1 and the latest version b9fe8e0) but in both cases after build I get a linux kernel (with 2019.1 toolchain) that's not understood by the xcku40, I am not even able to download. When I do a file <kernel image> I just get a data, not an ELF file.
    $file output/images/simpleImage.kcu105_fmcomms2-3
    output/images/simpleImage.kcu105_fmcomms2-3: data
    From XSCT:
    Failed to download Z:/kintex/buildroot_b9fe8e0/output/images/simpleImage.kcu105_fmcomms2-3
    invalid ELF file
    xsct% Info: MicroBlaze #0 (target 3) Stopped at 0x0 (Stop)
    xsct%
    The ub file seems to be valid but I dont want to burn an image to QSPI without validating it works.
    However if I use the 2019_R1 branch as the kernel version, then I get the ELF file and it loads but has a kernel panic. I am using the system_top.bit from http://swdownloads.analog.com/cse/microblaze/2018_r1/2018_r1_kcu105_fmcomms2-3.zip and loading my kernel that I built. Do you think there is a reference design change between 2018_r1 and 2019_r1?
    The only combination work is both kernel and bitstream from this zip file. Which was built with crosstool-ng :
    Ramdisk addr 0x00000000,
    Compiled-in FDT at 803e38e8
    Linux version 4.9.0-g87beab60b2b9 (dragos@debian) (gcc version 5.2.0 (crosstool-NG 1.20.0) ) #164 Tue May 8 12:56:46 EEST 2018
    Here is the kernel panic log message from my built of 2019_R1:
    ad9361 spi0.0: ad9361_probe : enter (ad9361)
    ad9361 spi0.0: ad9361_probe : AD936x Rev 2 successfully initialized
    cf_axi_dds 79024000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.00.b) at 0x79024000 mapped to 0xb007e000, probed DDS AD9361
    Data bus error exception in kernel mode.
    Oops: bus exception, sig: 7
    CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.0 #3
    task: ac013b60 task.stack: ac02c000
    Registers dump: mode=AC02DC2C
    r1=00010000, r2=00000000, r3=B0190000, r4=FFFFF000
    r5=8050FCC8, r6=AC1CD860, r7=000007C7, r8=AC1EFC8C
    r9=00000001, r10=B0140000, r11=B0130000, r12=8000003E
    r13=00000000, r14=AC05AE00, r15=803209AC, r16=00000000
    r17=803209CC, r18=4FE6F000, r19=8050FB40, r20=80413570
    r21=00000000, r22=805C7ADC, r23=AC1CD8CC, r24=805C7ADC
    r25=AC05AE0C, r26=AC05AE00, r27=00000000, r28=805EF33C
    r29=00000000, r30=00000000, r31=AC013B60, rPC=803209CC
    msr=000046A2, ear=AC1F2D20, esr=8050FB40, fsr=805C7ADC
    Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
    ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
  • Hi Ratin,
    I had something similar this morning with a ZCU102. Updating to the latest 2019 R2 image fixed it.
    Therefore please try to update to the 2019 R2 image.
    Cheers,
    -Paul
