A10SoC+AD9163-FMCC-EBZ Boot/linux problem
Hello All,
I have the following setup:
HW: A10SoC+AD9163-FMCC-EBZ (Eval-AD916x)
HDL: AD-DAC-FMC-EBZ
config.tcl: AD9163 mode:08 (set params(AD9163,08) {2 8 2 1 1 16 16})
Linux:
I have used device tree here: https://github.com/analogdevicesinc/linux/blob/master/arch/arm/boot/dts/socfpga_arria10_socdk_ad9136_fmc_ebz.dts
followed the steps from here to build the Kernel and the Device tree https://wiki.analog.com/resources/tools-software/linux-build/generic/socfpga
I have also the  EVAL-AD916X board attached to FMCA connector of the A10SoC.
I have built also the FPGA project in Quartus and generated rbf and put all in the SDcard and booted.
There are a couple of things I noticed:
1- It takes considerably long to load the rbf. Are there any options to add during rbf generation?
2- I have two warnings/errors at eh very beginning of the boot messages, in red below, Why would I have those and would this be a problem?
3- I have no device in  sys/bus/iio/devices/ I cannot find a way to communicate with Ad9163 on the eval kit.
Could you please help me to  understand am I missing something or doing something wrong here?
U-Boot 2014.10-00334-gf7a7e26-dirty (Feb 19 2021 - 17:04:19), Build: jenkins-2019_r2-hdl_jobs_for_linux-projects-daq2.a10soc-28
CPU : Altera SOCFPGA Arria 10 Platform
BOARD : Altera SOCFPGA Arria 10 Dev Kit
I2C: ready
DRAM: WARNING: Caches not enabled
SOCFPGA DWMMC: 0
FPGA: writing socfpga_arria10_socdk.rbf ...
Full Configuration Succeeded.
DDRCAL: Success
INFO : Skip relocation as SDRAM is non secure memory
Reserving 2048 Bytes for IRQ stack at: ffe386e8
DRAM : 1 GiB
MMC: *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Model: SOCFPGA Arria10 Dev Kit
Net: dwmac.ff800000
Hit any key to stop autoboot: 0
FPGA must be in Early Release mode to program core.
fpga - loadable FPGA image support
** Unable to read file u-boot.scr **
5111408 bytes read in 233 ms (20.9 MiB/s)
28862 bytes read in 4 ms (6.9 MiB/s)
FPGA BRIDGES: enable
Kernel image @ 0x010000 [ 0x000000 - 0x4dfe70 ]
## Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x000100
Loading Device Tree to 01ff5000, end 01fff0bd ... OK
Starting kernel ...
Best Regards,
Ömer.
Parents Reply Children
No Data
