Libiio detect the FPGA but not ad936x chip
I have pluto SDR it was working fine in all applications. After installing libiio oscilloscope on Linux Ubuntu 20 LTS the pluto stop working on all applications. I am able to log to the device terminal and run commands also the storage is working fine. I tried old firmware without success and it updated to the new firmware with same problem so I installed the latest 33 firmware but the same problem.
When I run iio_info it detect the device in usb and eathernet no problem, but it list only the FPGA model. Sometimes it list the ad936x, but only the phy not the adc or dds or lpc.
I think the problem is in the ad936x firmware, because I was testing the loopback function from the debug in the oscilloscope software. I could changed some register and broke the device. Is there any way to reset the ad936x or update its firmware, because updating the firmware for Linux fpga does not seem to help. Or if you other solutions.
Thank you and best regards
Parents
    on Jul 12, 2021 6:38 AM
    The AD936x "firmware" is updated when you update Pluto Firmware. You don't have to execute extra steps.
    You said that network interface with Pluto is working fine so can you please check if you log-in through SSH on Pluto if on target the IIO ADC and DDS are available when you run the "iio_info" command?
  • It looks like the damage is persistent, regardless of loading new firmware or old ones. Is there any way to hard reset the device to factory settings? For example ssh settings don't change after having new firmware. I want something stronger to make the device like new and eliminate the possibility of damaged transceiver. Because if the ad936x is damaged I will need to buy new chip or buy new pluto.
  • I did this, but it still the same. Only detecting the phy, dds, xdc. Not detecting the ad936x adc. Also not responsive to softwares on Linux or windows. Only able to login and access some limit information like temperature in iio-oscilloscope
    on Jul 12, 2021 11:05 PM in reply to Hunlx
    Can you login to Pluto and provide the output of dmesg?
    -Travis
  • Hi Travis,
    Thank you. This the output of dmesg and iio_info and iio_attr -d
    Booting Linux on physical CPU 0x0
    Linux version 5.4.0-212055-gb05d16429dac (michael@mhenneri-D06) (gcc version 8.2.0 (GCC)) #403 SMP PREEMPT Tue Mar 30 12:57:31 CEST 2021
    CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
    CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    OF: fdt: Machine model: Analog Devices PlutoSDR Rev.B (Z7010/AD9363)
    Memory policy: Data cache writealloc
    cma: Reserved 256 MiB at 0x0e400000
    On node 0 totalpages: 131072
      Normal zone: 1024 pages used for memmap
      Normal zone: 0 pages reserved
      Normal zone: 131072 pages, LIFO batch:31
    percpu: Embedded 15 pages/cpu s29196 r8192 d24052 u61440
    pcpu-alloc: s29196 r8192 d24052 u61440 alloc=15*4096
    pcpu-alloc: [0] 0 [0] 1
    Built 1 zonelists, mobility grouping on.  Total pages: 130048
    Kernel command line: console=ttyPS0,115200 maxcpus=1 rootfstype=ramfs root=/dev/ram0 rw quiet loglevel=4 uboot=U-Boot PlutoSDR v0.20-PlutoSDR-00053-g89d0754 (May 28 2019 - 19:24:22 -0700)
    Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
    mem auto-init: stack:off, heap alloc:off, heap free:off
    Memory: 241016K/524288K available (6144K kernel code, 605K rwdata, 1624K rodata, 1024K init, 138K bss, 21128K reserved, 262144K cma-reserved, 0K highmem)
    rcu: Preemptible hierarchical RCU implementation.
    rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    	Tasks RCU enabled.
    rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    efuse mapped to (ptrval)
    slcr mapped to (ptrval)
    L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C-310 erratum 769419 enabled
    L2C-310 enabling early BRESP for Cortex-A9
    L2C-310 full line of zeros enabled for Cortex-A9
    L2C-310 ID prefetch enabled, offset 1 lines
    L2C-310 dynamic clock gating enabled, standby mode enabled
    L2C-310 cache controller enabled, 8 ways, 512 kB
    L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
    random: get_random_bytes called from start_kernel+0x270/0x450 with crng_init=0
    zynq_clock_init: clkc starts at (ptrval)
    Zynq clock init
    sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
    clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
    Switching to timer-based delay loop, resolution 3ns
    clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
    timer #0 at (ptrval), irq=17
    Console: colour dummy device 80x30
    Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    CPU: Testing write buffer coherency: ok
    CPU0: Spectre v2: using BPIALL workaround
    CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Setting up static identity map for 0x100000 - 0x100060
    rcu: Hierarchical SRCU implementation.
    smp: Bringing up secondary CPUs ...
    smp: Brought up 1 node, 1 CPU
    SMP: Total of 1 processors activated (666.66 BogoMIPS).
    CPU: All CPU(s) started in SVC mode.
    devtmpfs: initialized
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    pinctrl core: initialized pinctrl subsystem
    NET: Registered protocol family 16
    DMA: preallocated 256 KiB pool for atomic coherent allocations
    cpuidle: using governor ladder
    hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    hw-breakpoint: maximum watchpoint size is 4 bytes.
    zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x(ptrval)
    e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 6249999) is a xuartps
    printk: console [ttyPS0] enabled
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    FPGA manager framework
    clocksource: Switched to clocksource arm_global_timer
    thermal_sys: Registered thermal governor 'step_wise'
    NET: Registered protocol family 2
    tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
    TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
    TCP: Hash tables configured (established 4096 bind 4096)
    UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    Trying to unpack rootfs image as initramfs...
    Freeing initrd memory: 5436K
    hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
    hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
    Initialise system trusted keyrings
    workingset: timestamp_bits=30 max_order=17 bucket_order=0
    jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    Key type asymmetric registered
    Asymmetric key parser 'x509' registered
    io scheduler mq-deadline registered
    io scheduler kyber registered
    zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
    brd: module loaded
    loop: module loaded
    spi-nor spi1.0: SPI-NOR-UniqueID 104000b2db9500020c001e00a2d61a94f0
    spi-nor spi1.0: found n25q256ax1, expected n25q256a
    spi-nor spi1.0: n25q256ax1 (32768 Kbytes)
    4 fixed-partitions partitions found on MTD device spi1.0
    Creating 4 MTD partitions on "spi1.0":
    0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    0x000000100000-0x000000120000 : "qspi-uboot-env"
    0x000000120000-0x000000200000 : "qspi-nvmfs"
    0x000000200000-0x000002000000 : "qspi-linux"
    libphy: Fixed MDIO Bus: probed
    usbcore: registered new interface driver rt2500usb
    usbcore: registered new interface driver rt73usb
    usbcore: registered new interface driver rt2800usb
    usbcore: registered new interface driver rtl8187
    usbcore: registered new interface driver rtl8192cu
    usbcore: registered new interface driver rtl8xxxu
    usbcore: registered new interface driver r8152
    usbcore: registered new interface driver lan78xx
    usbcore: registered new interface driver asix
    usbcore: registered new interface driver ax88179_178a
    usbcore: registered new interface driver cdc_ether
    usbcore: registered new interface driver dm9601
    usbcore: registered new interface driver smsc75xx
    usbcore: registered new interface driver smsc95xx
    usbcore: registered new interface driver rndis_host
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    usbcore: registered new interface driver usb-storage
    usbcore: registered new interface driver usbserial_generic
    usbserial: USB Serial support registered for generic
    usbcore: registered new interface driver ftdi_sio
    usbserial: USB Serial support registered for FTDI USB Serial Device
    chipidea-usb2 e0002000.usb: e0002000.usb supply vbus not found, using dummy regulator
    ULPI transceiver vendor/product ID 0x0424/0x0007
    Found SMSC USB3320 ULPI transceiver.
    ULPI integrity check: passed.
    i2c /dev entries driver
    cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
    Xilinx Zynq CpuIdle Driver started
    ledtrig-cpu: registered to indicate activity on CPUs
    hidraw: raw HID events driver (C) Jiri Kosina
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    usbcore: registered new interface driver r8712u
    usbcore: registered new interface driver r8188eu
    ad9361 spi0.0: ad9361_probe : enter (ad9363a)
    random: fast init done
    ad9361 spi0.0: ad9361_probe : AD936x Rev 2 successfully initialized
    cf_axi_dds 79024000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x79024000 mapped to 0x(ptrval), probed DDS AD9364
    fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
    lib80211: common routines for IEEE802.11 drivers
    lib80211_crypt: registered algorithm 'NULL'
    lib80211_crypt: registered algorithm 'WEP'
    lib80211_crypt: registered algorithm 'CCMP'
    Registering SWP/SWPB emulation handler
    Loading compiled-in X.509 certificates
    ad9361 spi0.0: Calibration TIMEOUT (0x5E, 0x80)
    random: crng init done
    SAMPL CLK: 61440000 tuning: RX
      0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
    0:# # # # # # # # # # # # # # # #
    1:# # # # # # # # # # # # # # # #
    ad9361 spi0.0: ad9361_dig_tune_delay: Tuning RX FAILED!
    cf_axi_adc: probe of 79020000.cf-ad9361-lpc failed with error -5
    input: gpio_keys as /devices/soc0/gpio_keys/input/input0
    cfg80211: Loading compiled-in X.509 certificates for regulatory database
    cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    cfg80211: failed to load regulatory.db
    Freeing unused kernel memory: 1024K
    Run /init as init process
    file system registered
    using random self ethernet address
    using random host ethernet address
    Mass Storage Function, version: 2009/09/11
    LUN: removable file: (no medium)
    read descriptors
    read strings
    usb0: HOST MAC 00:e0:22:f2:e8:9a
    usb0: MAC 00:05:f7:98:ac:1d
    configfs-gadget gadget: high-speed config #1: c
    Library version: 0.21 (git tag: v0.21)
    Compiled with backends: local xml ip usb serial
    Available contexts:
    	0: (xadc, cf-ad9361-dds-core-lpc, ad9361-phy on Analog Devices PlutoSDR Rev.B (Z7010/AD9363)) [local:]
    	1: 192.168.2.1 (Analog Devices PlutoSDR Rev.B (Z7010-AD9363A)), serial=104000b2db9500020c001e00a2d61a94f0 [ip:pluto.local]
    IIO context has 3 devices:
    	iio:device0, ad9361-phy: found 18 device attributes
    	iio:device1, xadc: found 1 device attributes
    	iio:device2, cf-ad9361-dds-core-lpc: found 0 device attributes
    on Jul 13, 2021 2:37 PM in reply to Hunlx
    Hmm - this is odd
    So initially everything worked.
    However later on when we do the interface tuning - the BBPLL doesn't lock.
    And it finally fails when tuning for 61.44 MSPS.
    Can you try to power the device from a different source?
    -Michael
  • Hi Michael.
    I think you pin it out. I used external USB power and I loss communication with ad936x. then I tried with only usb3 to data port (no extra power from the 5v USB) and it seem to work. later I connect both USB ports to new ports in my PC, but the problem return. so one port USB could be fine.
    ##################with usb external charger#################
    loop: module loaded
    ad9361 spi0.0: Calibration TIMEOUT (0x16, 0x10)
    clk_unregister: unregistering prepared clock: spi0.0-tx_rfpll
    clk_unregister: unregistering prepared clock: spi0.0-rx_rfpll
    clk_unregister: unregistering prepared clock: spi0.0-tx_rfpll_int
    clk_unregister: unregistering prepared clock: spi0.0-rx_rfpll_int
    clk_unregister: unregistering prepared clock: spi0.0-rx_refclk
    clk_unregister: unregistering prepared clock: spi0.0-tx_refclk
    ad9361: probe of spi0.0 failed with error -110
    read descriptors
    read strings
    # iio_info -s
    Available contexts:
    	0: (xadc on Analog Devices PlutoSDR Rev.B (Z7010/AD9363)) [local:]
    	1: 192.168.2.1 (Analog Devices PlutoSDR Rev.B (Z7010-)), serial=104000b2db9500020c001e00a2d61a94f0 [ip:pluto.local]
    # iio_attr -u ip:192.168.2.1 -d
    IIO context has 1 devices:
    	iio:device0, xadc: found 1 device attributes
    # reboot
    # client_loop: send disconnect: Broken pipe
    ################with one port only usb3 on data####################
    tango@tango-2837:~$ ssh -l root 192.168.2.1
    root@192.168.2.1's password:
    Welcome to:
    ______ _       _        _________________
    | ___ \ |     | |      /  ___|  _  \ ___ \
    | |_/ / |_   _| |_ ___ \ `--.| | | | |_/ /
    |  __/| | | | | __/ _ \ `--. \ | | |    /
    | |   | | |_| | || (_) /\__/ / |/ /| |\ \
    \_|   |_|\__,_|\__\___/\____/|___/ \_| \_|
    v0.33
    https://wiki.analog.com/university/tools/pluto
    # dmesg
    	Tasks RCU enabled.
    Zynq clock init
    brd: module loaded
    loop: module loaded
    cf_axi_adc 79020000.cf-ad9361-lpc: ADI AIM (10.01.b) at 0x79020000 mapped to 0x(ptrval), probed ADC AD9364 as MASTER
    read descriptors
    read strings
    random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
    random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
    random: dbus-daemon: uninitialized urandom read (12 bytes read)
    random: 1 urandom warning(s) missed due to ratelimiting
    # iio_info -s
    Available contexts:
    	0: (cf-ad9361-lpc, xadc, cf-ad9361-dds-core-lpc, ad9361-phy on Analog Devices PlutoSDR Rev.B (Z7010/AD9363)) [local:]
    IIO context has 4 devices:
    	iio:device3, cf-ad9361-lpc: found 0 device attributes
    # reboot
    ################with two ports usb3 data and 5v#################
    Welcome to:
    v0.33
    # dmesg
    	Tasks RCU enabled.
    Zynq clock init
    brd: module loaded
    loop: module loaded
    read descriptors
    read strings
    # iio_info -s
    Available contexts:
Reply
  • Hi Michael.
    loop: module loaded
    read descriptors
    read strings
    # iio_info -s
    Available contexts:
    # reboot
    Welcome to:
    v0.33
    # dmesg
    	Tasks RCU enabled.
    Zynq clock init
    brd: module loaded
    loop: module loaded
    read descriptors
    read strings
    # iio_info -s
    Available contexts:
    # reboot
    Welcome to:
    v0.33
    # dmesg
    	Tasks RCU enabled.
    Zynq clock init
    brd: module loaded
    loop: module loaded
    read descriptors
    read strings
    # iio_info -s
    Available contexts:
Children
