ad9375-z706
Good afternoon, I replaced the external 100 MHz oscillator, generated a profile, loaded it through the GUI, everything works.
When I try to tune the AD9375 via DTS, an error occurs and I don't know what I'm doing wrong.
8176.system_dts.txt
/dts-v1/;
	#address-cells = <0x1>;
	#size-cells = <0x1>;
	compatible = "xlnx,zynq-7000";
	interrupt-parent = <0x1>;
	model = "Xilinx Zynq ZC706";
	cpus {
		#size-cells = <0x0>;
		cpu@0 {
			compatible = "arm,cortex-a9";
			device_type = "cpu";
			reg = <0x0>;
			clocks = <0x2 0x3>;
			clock-latency = <0x3e8>;
			cpu0-supply = <0x3>;
			operating-points = <0xa2c2b 0xf4240 0x51616 0xf4240>;
		cpu@1 {
			reg = <0x1>;
			clocks = <0x2 0x3>;
	fpga-full {
		compatible = "fpga-region";
		fpga-mgr = <0x4>;
		ranges;
	pmu@f8891000 {
		compatible = "arm,cortex-a9-pmu";
		interrupts = <0x0 0x5 0x4 0x0 0x6 0x4>;
		reg = <0xf8891000 0x1000 0xf8893000 0x1000>;
	fixedregulator {
		compatible = "regulator-fixed";
		regulator-name = "VCCPINT";
		regulator-min-microvolt = <0xf4240>;
		regulator-max-microvolt = <0xf4240>;
		regulator-boot-on;
		regulator-always-on;
		linux,phandle = <0x3>;
		phandle = <0x3>;
	amba {
		u-boot,dm-pre-reloc;
		compatible = "simple-bus";
		ranges;
		adc@f8007100 {
			compatible = "xlnx,zynq-xadc-1.00.a";
			reg = <0xf8007100 0x20>;
			interrupts = <0x0 0x7 0x4>;
			clocks = <0x2 0xc>;
		can@e0008000 {
			compatible = "xlnx,zynq-can-1.0";
			status = "disabled";
			clocks = <0x2 0x13 0x2 0x24>;
			clock-names = "can_clk", "pclk";
			reg = <0xe0008000 0x1000>;
			interrupts = <0x0 0x1c 0x4>;
			tx-fifo-depth = <0x40>;
			rx-fifo-depth = <0x40>;
		can@e0009000 {
			clocks = <0x2 0x14 0x2 0x25>;
			reg = <0xe0009000 0x1000>;
			interrupts = <0x0 0x33 0x4>;
		gpio@e000a000 {
			compatible = "xlnx,zynq-gpio-1.0";
			#gpio-cells = <0x2>;
			clocks = <0x2 0x2a>;
			gpio-controller;
			interrupt-controller;
			#interrupt-cells = <0x2>;
			interrupts = <0x0 0x14 0x4>;
			reg = <0xe000a000 0x1000>;
			linux,phandle = <0x5>;
			phandle = <0x5>;
		i2c@e0004000 {
			compatible = "cdns,i2c-r1p10";
			clocks = <0x2 0x26>;
			interrupts = <0x0 0x19 0x4>;
			reg = <0xe0004000 0x1000>;
		i2c@e0005000 {
			clocks = <0x2 0x27>;
			interrupts = <0x0 0x30 0x4>;
			reg = <0xe0005000 0x1000>;
		interrupt-controller@f8f01000 {
			compatible = "arm,cortex-a9-gic";
			#interrupt-cells = <0x3>;
			reg = <0xf8f01000 0x1000 0xf8f00100 0x100>;
			linux,phandle = <0x1>;
			phandle = <0x1>;
		cache-controller@f8f02000 {
			compatible = "arm,pl310-cache";
			reg = <0xf8f02000 0x1000>;
			interrupts = <0x0 0x2 0x4>;
			arm,data-latency = <0x3 0x2 0x2>;
			arm,tag-latency = <0x2 0x2 0x2>;
			cache-unified;
			cache-level = <0x2>;
		memory-controller@f8006000 {
			compatible = "xlnx,zynq-ddrc-a05";
			reg = <0xf8006000 0x1000>;
		ocmc@f800c000 {
			compatible = "xlnx,zynq-ocmc-1.0";
			interrupts = <0x0 0x3 0x4>;
			reg = <0xf800c000 0x1000>;
		serial@e0000000 {
			compatible = "xlnx,xuartps", "cdns,uart-r1p8";
			clocks = <0x2 0x17 0x2 0x28>;
			clock-names = "uart_clk", "pclk";
			reg = <0xe0000000 0x1000>;
			interrupts = <0x0 0x1b 0x4>;
		serial@e0001000 {
			status = "okay";
			clocks = <0x2 0x18 0x2 0x29>;
			reg = <0xe0001000 0x1000>;
			interrupts = <0x0 0x32 0x4>;
		spi@e0006000 {
			compatible = "xlnx,zynq-spi-r1p6";
			reg = <0xe0006000 0x1000>;
			status = "okay";
			interrupts = <0x0 0x1a 0x4>;
			clocks = <0x2 0x19 0x2 0x22>;
			clock-names = "ref_clk", "pclk";
			ad9528-1@0 {
				compatible = "adi,ad9528";
				reg = <0x0>;
				spi-max-frequency = <0x989680>;
				clock-output-names = "ad9528-1_out0", "ad9528-1_out1", "ad9528-1_out2", "ad9528-1_out3", "ad9528-1_out4", "ad9528-1_out5", "ad9528-1_out6", "ad9528-1_out7", "ad9528-1_out8", "ad9528-1_out9", "ad9528-1_out10", "ad9528-1_out11", "ad9528-1_out12", "ad9528-1_out13";
				#clock-cells = <0x1>;
				adi,vcxo-freq = <100000000>;
				adi,pll1-bypass-enable;
				adi,osc-in-diff-enable;
				adi,pll2-vco-div-m1 = <4>;
				adi,pll2-n2-div = <30>;
				adi,pll2-r1-div = <3>;
				adi,pll2-charge-pump-current-nA = <0xc4888>;
				adi,status-mon-pin0-function-select = <0x1>;
				adi,status-mon-pin1-function-select = <0x7>;
				reset-gpios = <0x5 0x71 0x0>;
				linux,phandle = <0x9>;
				phandle = <0x9>;
				channel@13 {
					reg = <0xd>;
					adi,extended-name = "DEV_CLK";
					adi,driver-mode = <0x0>;
					adi,divider-phase = <0x0>;
					adi,channel-divider = <0xA>;
					adi,signal-source = <0x0>;
				channel@1 {
					reg = <0x1>;
					adi,extended-name = "FMC_CLK";
				channel@12 {
					reg = <0xc>;
					adi,extended-name = "DEV_SYSREF";
					adi,signal-source = <0x2>;
				channel@3 {
					reg = <0x3>;
					adi,extended-name = "FMC_SYSREF";
			ad9371-phy@1 {
				compatible = "adi,ad9375";
				reg = <0x1>;
				spi-max-frequency = <0x17d7840>;
				clocks = <0x6 0x7 0x8 0x9 0xd 0x9 0x1 0x9 0xc 0x9 0x3>;
				clock-names = "jesd_rx_clk", "jesd_tx_clk", "jesd_rx_os_clk", "dev_clk", "fmc_clk", "sysref_dev_clk", "sysref_fmc_clk";
				clock-output-names = "rx_sampl_clk", "rx_os_sampl_clk", "tx_sampl_clk";
				adi,clocks-clk-pll-vco-freq_khz = <12000000>;
				adi,clocks-device-clock_khz = <100000>;
				adi,clocks-clk-pll-hs-div = <4>;
				adi,clocks-clk-pll-vco-div = <3>;
				#adi,jesd204-obs-framer-over-sample = <>;
				adi,rx-profile-adc-div = <1>;
				adi,rx-profile-en-high-rej-dec5 = <1>;
				adi,rx-profile-iq-rate_khz = <100000>;
				adi,rx-profile-rf-bandwidth_hz = <80000000>;
				adi,rx-profile-rhb1-decimation = <1>;
				adi,rx-profile-rx-bbf-3db-corner_khz = <80000>;
				adi,rx-profile-rx-dec5-decimation = <5>;
				adi,rx-profile-rx-fir-decimation = <2>;
				adi,rx-profile-rx-fir-gain_db = <(-6)>;
				adi,rx-profile-rx-fir-num-fir-coefs = <48>;
				adi,rx-profile-rx-fir-coefs = /bits/ 16 <(-4) (-17) (23) (41) (-53) (-95) (117) (184) (-221) (-331) (389) (553) (-644) (-888) (1026) (1387) (-1608) (-2158) (2580) (3485) (-4786) (-7622) (9629) (32372) (32372) (9629) (-7622) (-4786) (3485) (2580) (-2158) (-1608) (1387) (1026) (-888) (-644) (553) (389) (-331) (-221) (184) (117) (-95) (-53) (41) (23) (-17) (-4)>;
				adi,rx-profile-custom-adc-profile =/bits/ 16 <660 473 201 98 1280 477 1587 269 1062 82 645 28 48 32 19 190>;
				adi,obs-profile-adc-div = <1>;
				adi,obs-profile-en-high-rej-dec5 = <1>;
				adi,obs-profile-iq-rate_khz = <100000>;
				adi,obs-profile-rf-bandwidth_hz = <80000000>;
				adi,obs-profile-rhb1-decimation = <1>;
				adi,obs-profile-rx-bbf-3db-corner_khz = <40000>;
				adi,obs-profile-rx-dec5-decimation = <5>;
				adi,obs-profile-rx-fir-decimation = <2>;
				adi,obs-profile-rx-fir-gain_db = <0>;
				adi,obs-profile-rx-fir-num-fir-coefs = <48>;
				adi,obs-profile-rx-fir-coefs = /bits/ 16 <(0) (-14) (12) (31) (-28) (-72) (67) (138) (-130) (-245) (235) (406) (-396) (-646) (640) (1003) (-1013) (-1559) (1636) (2557) (-2975) (-5752) (4332) (18454) (18454) (4332) (-5752) (-2975) (2557) (1636) (-1559) (-1013) (1003) (640) (-646) (-396) (406) (235) (-245) (-130) (138) (67) (-72) (-28) (31) (12) (-14) (0)>;
				adi,obs-profile-custom-adc-profile = /bits/ 16 <660 473 201 98 1280 477 1587 269 1062 82 645 28 48 32 19 190>;
				adi,obs-settings-custom-loopback-adc-profile = /bits/ 16 <737 439 201 98 1280 112 1505 53 1081 17 667 40 48 33 19 194>;
				adi,tx-profile-dac-div = <1>;/*2.5 = 1*/
				adi,tx-profile-iq-rate_khz = <100000>;
				adi,tx-profile-primary-sig-bandwidth_hz = <20000000>;
				adi,tx-profile-rf-bandwidth_hz = <80000000>;
				adi,tx-profile-thb1-interpolation = <1>;
				adi,tx-profile-thb2-interpolation = <2>;
				adi,tx-profile-tx-bbf-3db-corner_khz = <40000>;
				adi,tx-profile-tx-dac-3db-corner_khz = <92000>;
				adi,tx-profile-tx-fir-interpolation = <1>;
				adi,tx-profile-tx-input-hb-interpolation = <1>;
				adi,tx-profile-tx-fir-gain_db = <6>;
				adi,tx-profile-tx-fir-num-fir-coefs = <16>;
				adi,tx-profile-tx-fir-coefs = /bits/ 16 <(-37) (-192) (197) (-190) (-7) (816) (-2646) (20216) (-2646) (816) (-7) (-190) (197) (-192) (-37) (0)>;
				adi,sniffer-profile-adc-div = <1>;
				adi,sniffer-profile-en-high-rej-dec5 = <1>;
				adi,sniffer-profile-iq-rate_khz = <50000>;
				adi,sniffer-profile-rf-bandwidth_hz = <20000000>;
				adi,sniffer-profile-rhb1-decimation = <2>;
				adi,sniffer-profile-rx-bbf-3db-corner_khz = <20000>;
				adi,sniffer-profile-rx-dec5-decimation = <5>;
				adi,sniffer-profile-rx-fir-decimation = <2>;
				reset-gpios = <0x5 0x6a 0x0>;
				test-gpios = <0x5 0x6b 0x0>;
				sysref_req-gpios = <0x5 0x70 0x0>;
				rx2_enable-gpios = <0x5 0x6c 0x0>;
				rx1_enable-gpios = <0x5 0x6d 0x0>;
				tx2_enable-gpios = <0x5 0x6e 0x0>;
				tx1_enable-gpios = <0x5 0x6f 0x0>;
				linux,phandle = <0x13>;
				phandle = <0x13>;
		spi@e0007000 {
			reg = <0xe0007000 0x1000>;
			interrupts = <0x0 0x31 0x4>;
			clocks = <0x2 0x1a 0x2 0x23>;
		spi@e000d000 {
			clocks = <0x2 0xa 0x2 0x2b>;
			compatible = "xlnx,zynq-qspi-1.0";
			status = "okay";
			interrupts = <0x0 0x13 0x4>;
			reg = <0xe000d000 0x1000>;
			is-dual = <0x1>;
			num-cs = <0x1>;
			ps7-qspi@0 {
				spi-tx-bus-width = <0x1>;
				spi-rx-bus-width = <0x4>;
				compatible = "n25q128a11";
				reg = <0x0>;
				spi-max-frequency = <0x2faf080>;
				partition@0 {
					label = "boot";
					reg = <0x0 0x500000>;
				partition@500000 {
					label = "bootenv";
					reg = <0x500000 0x20000>;
				partition@520000 {
					label = "config";
					reg = <0x520000 0x20000>;
				partition@540000 {
					label = "image";
					reg = <0x540000 0xa80000>;
				partition@fc0000 {
					label = "spare";
					reg = <0xfc0000 0x0>;
		memory-controller@e000e000 {
			clock-names = "memclk", "aclk";
			clocks = <0x2 0xb 0x2 0x2c>;
			compatible = "arm,pl353-smc-r2p1";
			interrupts = <0x0 0x12 0x4>;
			ranges;
			reg = <0xe000e000 0x1000>;
			flash@e1000000 {
				compatible = "arm,pl353-nand-r2p1";
				reg = <0xe1000000 0x1000000>;
			flash@e2000000 {
				compatible = "cfi-flash";
				reg = <0xe2000000 0x2000000>;
		ethernet@e000b000 {
			compatible = "cdns,zynq-gem", "cdns,gem";
			reg = <0xe000b000 0x1000>;
			status = "okay";
			interrupts = <0x0 0x16 0x4>;
			clocks = <0x2 0x1e 0x2 0x1e 0x2 0xd>;
			clock-names = "pclk", "hclk", "tx_clk";
			phy-handle = <0xa>;
			phy-mode = "rgmii-id";
			phy@7 {
				device_type = "ethernet-phy";
				reg = <0x7>;
				linux,phandle = <0xa>;
				phandle = <0xa>;
		ethernet@e000c000 {
			reg = <0xe000c000 0x1000>;
			interrupts = <0x0 0x2d 0x4>;
			clocks = <0x2 0x1f 0x2 0x1f 0x2 0xe>;
		mmc@e0100000 {
			compatible = "arasan,sdhci-8.9a";
			status = "okay";
			clock-names = "clk_xin", "clk_ahb";
			clocks = <0x2 0x15 0x2 0x20>;
			interrupts = <0x0 0x18 0x4>;
			reg = <0xe0100000 0x1000>;
		mmc@e0101000 {
			clocks = <0x2 0x16 0x2 0x21>;
			interrupts = <0x0 0x2f 0x4>;
			reg = <0xe0101000 0x1000>;
		slcr@f8000000 {
			compatible = "xlnx,zynq-slcr", "syscon", "simple-mfd";
			reg = <0xf8000000 0x1000>;
			ranges;
			linux,phandle = <0xb>;
			phandle = <0xb>;
			clkc@100 {
				compatible = "xlnx,ps7-clkc";
				fclk-enable = <0xf>;
				clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x", "cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x", "dci", "lqspi", "smc", "pcap", "gem0", "gem1", "fclk0", "fclk1", "fclk2", "fclk3", "can0", "can1", "sdio0", "sdio1", "uart0", "uart1", "spi0", "spi1", "dma", "usb0_aper", "usb1_aper", "gem0_aper", "gem1_aper", "sdio0_aper", "sdio1_aper", "spi0_aper", "spi1_aper", "can0_aper", "can1_aper", "i2c0_aper", "i2c1_aper", "uart0_aper", "uart1_aper", "gpio_aper", "lqspi_aper", "smc_aper", "swdt", "dbg_trc", "dbg_apb";
				reg = <0x100 0x100>;
				ps-clk-frequency = <0x1fca055>;
				linux,phandle = <0x2>;
				phandle = <0x2>;
			rstc@200 {
				compatible = "xlnx,zynq-reset";
				reg = <0x200 0x48>;
				#reset-cells = <0x1>;
				syscon = <0xb>;
			pinctrl@700 {
				compatible = "xlnx,pinctrl-zynq";
				reg = <0x700 0x200>;
				syscon = <0xb>;
		dmac@f8003000 {
			compatible = "arm,pl330", "arm,primecell";
			reg = <0xf8003000 0x1000>;
			interrupt-names = "abort", "dma0", "dma1", "dma2", "dma3", "dma4", "dma5", "dma6", "dma7";
			interrupts = <0x0 0xd 0x4 0x0 0xe 0x4 0x0 0xf 0x4 0x0 0x10 0x4 0x0 0x11 0x4 0x0 0x28 0x4 0x0 0x29 0x4 0x0 0x2a 0x4 0x0 0x2b 0x4>;
			#dma-cells = <0x1>;
			#dma-channels = <0x8>;
			#dma-requests = <0x4>;
			clocks = <0x2 0x1b>;
			clock-names = "apb_pclk";
			linux,phandle = <0x10>;
			phandle = <0x10>;
		devcfg@f8007000 {
			compatible = "xlnx,zynq-devcfg-1.0";
			interrupts = <0x0 0x8 0x4>;
			reg = <0xf8007000 0x100>;
			clocks = <0x2 0xc 0x2 0xf 0x2 0x10 0x2 0x11 0x2 0x12>;
			clock-names = "ref_clk", "fclk0", "fclk1", "fclk2", "fclk3";
			syscon = <0xb>;
			linux,phandle = <0x4>;
			phandle = <0x4>;
		efuse@f800d000 {
			compatible = "xlnx,zynq-efuse";
			reg = <0xf800d000 0x20>;
		timer@f8f00200 {
			compatible = "arm,cortex-a9-global-timer";
			reg = <0xf8f00200 0x20>;
			interrupts = <0x1 0xb 0x301>;
			clocks = <0x2 0x4>;
		timer@f8001000 {
			interrupts = <0x0 0xa 0x4 0x0 0xb 0x4 0x0 0xc 0x4>;
			compatible = "cdns,ttc";
			clocks = <0x2 0x6>;
			reg = <0xf8001000 0x1000>;
		timer@f8002000 {
			interrupts = <0x0 0x25 0x4 0x0 0x26 0x4 0x0 0x27 0x4>;
			clocks = <0x2 0x6>;
			reg = <0xf8002000 0x1000>;
		timer@f8f00600 {
			interrupts = <0x1 0xd 0x301>;
			compatible = "arm,cortex-a9-twd-timer";
			reg = <0xf8f00600 0x20>;
			clocks = <0x2 0x4>;
		usb@e0002000 {
			compatible = "xlnx,zynq-usb-2.20a", "chipidea,usb2";
			status = "okay";
			clocks = <0x2 0x1c>;
			interrupts = <0x0 0x15 0x4>;
			reg = <0xe0002000 0x1000>;
			phy_type = "ulpi";
			dr_mode = "host";
			xlnx,phy-reset-gpio = <0x5 0x7 0x0>;
		usb@e0003000 {
			clocks = <0x2 0x1d>;
			interrupts = <0x0 0x2c 0x4>;
			reg = <0xe0003000 0x1000>;
			phy_type = "ulpi";
		watchdog@f8005000 {
			clocks = <0x2 0x2d>;
			compatible = "cdns,wdt-r1p2";
			interrupts = <0x0 0x9 0x1>;
			reg = <0xf8005000 0x1000>;
			timeout-sec = <0xa>;
	aliases {
		ethernet0 = "/amba/ethernet@e000b000";
		serial0 = "/amba/serial@e0001000";
	memory {
		device_type = "memory";
		reg = <0x0 0x40000000>;
	chosen {
		bootargs = "console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait";
		linux,stdout-path = "/amba@0/uart@E0001000";
	leds {
		compatible = "gpio-leds";
		ds8 {
			label = "ds12:green";
			gpios = <0x5 0x3d 0x0>;
		ds9 {
			label = "ds15:green";
			gpios = <0x5 0x3e 0x0>;
		ds10 {
			label = "ds16:green";
			gpios = <0x5 0x3f 0x0>;
		ds35 {
			label = "ds17:green";
			gpios = <0x5 0x40 0x0>;
	gpio_keys {
		compatible = "gpio-keys";
		autorepeat;
		sw7 {
			label = "Left";
			linux,code = <0x69>;
			gpios = <0x5 0x3a 0x0>;
		sw8 {
			label = "Right";
			linux,code = <0x6a>;
			gpios = <0x5 0x3c 0x0>;
		sw9 {
			label = "Select";
			linux,code = <0x1c>;
			gpios = <0x5 0x3b 0x0>;
	fpga-axi@0 {
		ranges;
		i2c@41600000 {
			compatible = "xlnx,axi-iic-1.02.a", "xlnx,xps-iic-2.00.a";
			reg = <0x41600000 0x10000>;
			interrupts = <0x0 0x3a 0x4>;
			clocks = <0x2 0xf>;
			clock-names = "pclk";
			i2cswitch@74 {
				compatible = "nxp,pca9548";
				reg = <0x74>;
				i2c@0 {
					reg = <0x0>;
					osc@5d {
						compatible = "si570";
						temperature-stability = <0x32>;
						reg = <0x5d>;
						factory-fout = <0x9502f90>;
						initial-fout = <0x8d9ee20>;
				i2c@1 {
					reg = <0x1>;
					adv7511 {
						compatible = "adi,adv7511";
						reg = <0x39 0x3f>;
						reg-names = "primary", "edid";
						adi,input-depth = <0x8>;
						adi,input-colorspace = "rgb";
						adi,input-clock = "1x";
						adi,clock-delay = <0x0>;
						#sound-dai-cells = <0x0>;
						linux,phandle = <0x1d>;
						phandle = <0x1d>;
						ports {
							port@0 {
								reg = <0x0>;
								endpoint {
									remote-endpoint = <0xc>;
									linux,phandle = <0xf>;
									phandle = <0xf>;
							port@1 {
								reg = <0x1>;
				i2c@2 {
					reg = <0x2>;
					eeprom@54 {
						compatible = "at,24c08";
						reg = <0x54>;
				i2c@3 {
					reg = <0x3>;
					gpio@21 {
						compatible = "ti,tca6416";
						reg = <0x21>;
						gpio-controller;
				i2c@4 {
					reg = <0x4>;
					rtc@54 {
						compatible = "nxp,pcf8563";
						reg = <0x51>;
				i2c@5 {
					reg = <0x5>;
					eeprom@50 {
						compatible = "at24,24c02";
						reg = <0x50>;
					eeprom@54 {
						reg = <0x54>;
					ad7291@2f {
						compatible = "adi,ad7291";
						reg = <0x2f>;
		dma@43000000 {
			compatible = "adi,axi-dmac-1.00.a";
			reg = <0x43000000 0x10000>;
			#dma-cells = <0x1>;
			interrupts = <0x0 0x3b 0x0>;
			clocks = <0x2 0x10>;
			linux,phandle = <0xd>;
			phandle = <0xd>;
			adi,channels {
				dma-channel@0 {
					reg = <0x0>;
					adi,source-bus-width = <0x40>;
					adi,source-bus-type = <0x0>;
					adi,destination-bus-width = <0x40>;
					adi,destination-bus-type = <0x1>;
		axi-clkgen@79000000 {
			compatible = "adi,axi-clkgen-2.00.a";
			reg = <0x79000000 0x10000>;
			#clock-cells = <0x0>;
			linux,phandle = <0xe>;
			phandle = <0xe>;
		axi_hdmi@70e00000 {
			compatible = "adi,axi-hdmi-tx-1.00.a";
			reg = <0x70e00000 0x10000>;
			dmas = <0xd 0x0>;
			dma-names = "video";
			clocks = <0xe>;
			adi,is-rgb;
			port {
				endpoint {
					remote-endpoint = <0xf>;
					linux,phandle = <0xc>;
					phandle = <0xc>;
		axi-spdif-tx@75c00000 {
			compatible = "adi,axi-spdif-tx-1.00.a";
			reg = <0x75c00000 0x1000>;
			dmas = <0x10 0x0>;
			dma-names = "tx";
			clocks = <0x2 0xf 0x11>;
			clock-names = "axi", "ref";
			linux,phandle = <0x1c>;
			phandle = <0x1c>;
		axi-sysid-0@45000000 {
			compatible = "adi,axi-sysid-1.00.a";
			reg = <0x45000000 0x10000>;
		rx-dmac@7c400000 {
			reg = <0x7c400000 0x10000>;
			#dma-cells = <0x1>;
			interrupts = <0x0 0x39 0x0>;
			linux,phandle = <0x12>;
			phandle = <0x12>;
			adi,channels {
				dma-channel@0 {
					reg = <0x0>;
					adi,source-bus-type = <0x2>;
					adi,destination-bus-type = <0x0>;
		rx-obs-dmac@7c440000 {
			reg = <0x7c440000 0x10000>;
			#dma-cells = <0x1>;
			interrupts = <0x0 0x37 0x0>;
			linux,phandle = <0x14>;
			phandle = <0x14>;
			adi,channels {
				dma-channel@0 {
					reg = <0x0>;
		tx-dmac@7c420000 {
			reg = <0x7c420000 0x10000>;
			#dma-cells = <0x1>;
			interrupts = <0x0 0x38 0x0>;
			linux,phandle = <0x15>;
			phandle = <0x15>;
			adi,channels {
				dma-channel@0 {
					reg = <0x0>;
					adi,destination-bus-width = <0x80>;
		axi-ad9371-rx-hpc@44a00000 {
			compatible = "adi,axi-ad9371-rx-1.0";
			reg = <0x44a00000 0x8000>;
			dmas = <0x12 0x0>;
			dma-names = "rx";
			spibus-connected = <0x13>;
			adi,axi-decimation-core-available;
			decimation-gpios = <0x5 0x73 0x0>;
		axi-ad9371-rx-obs-hpc@44a08000 {
			compatible = "adi,axi-ad9371-obs-1.0";
			reg = <0x44a08000 0x1000>;
			dmas = <0x14 0x0>;
			dma-names = "rx";
			clocks = <0x13 0x1>;
			clock-names = "sampl_clk";
		axi-ad9371-tx-hpc@44a04000 {
			compatible = "adi,axi-ad9371-tx-1.0";
			reg = <0x44a04000 0x4000>;
			dmas = <0x15 0x0>;
			dma-names = "tx";
			clocks = <0x13 0x2>;
			adi,axi-pl-fifo-enable;
			adi,axi-interpolation-core-available;
			interpolation-gpios = <0x5 0x74 0x0>;
			plddrbypass-gpios = <0x5 0x72 0x0>;
		axi-jesd204-rx@44aa0000 {
			compatible = "adi,axi-jesd204-rx-1.0";
			reg = <0x44aa0000 0x1000>;
			interrupts = <0x0 0x36 0x0>;
			clocks = <0x2 0x10 0x16 0x17 0x0>;
			clock-names = "s_axi_aclk", "device_clk", "lane_clk";
			clock-output-names = "jesd_rx_lane_clk";
			adi,octets-per-frame = <0x4>;
			adi,frames-per-multiframe = <0x20>;
			linux,phandle = <0x6>;
			phandle = <0x6>;
		axi-jesd204-tx@44a90000 {
			compatible = "adi,axi-jesd204-tx-1.0";
			reg = <0x44a90000 0x1000>;
			interrupts = <0x0 0x35 0x0>;
			clocks = <0x2 0x10 0x18 0x19 0x0>;
			clock-output-names = "jesd_tx_lane_clk";
			adi,octets-per-frame = <0x2>;
			adi,converter-resolution = <0xe>;
			adi,bits-per-sample = <0x10>;
			adi,converters-per-device = <0x4>;
			adi,control-bits-per-sample = <0x2>;
			linux,phandle = <0x7>;
			phandle = <0x7>;
		axi-jesd204-rx@44ab0000 {
			reg = <0x44ab0000 0x1000>;
			interrupts = <0x0 0x34 0x0>;
			clocks = <0x2 0x10 0x1a 0x1b 0x0>;
			clock-output-names = "jesd_rx_os_lane_clk";
			linux,phandle = <0x8>;
			phandle = <0x8>;
		axi-clkgen@43c00000 {
			reg = <0x43c00000 0x10000>;
			clocks = <0x9 0x1>;
			clock-output-names = "axi_tx_clkgen";
			linux,phandle = <0x18>;
			phandle = <0x18>;
		axi-clkgen@43c10000 {
			reg = <0x43c10000 0x10000>;
			clocks = <0x9 0x1>;
			clock-output-names = "axi_rx_clkgen";
			linux,phandle = <0x16>;
			phandle = <0x16>;
		axi-clkgen@43c20000 {
			reg = <0x43c20000 0x10000>;
			clocks = <0x9 0x1>;
			clock-output-names = "axi_rx_os_clkgen";
			linux,phandle = <0x1a>;
			phandle = <0x1a>;
		axi-adxcvr-rx@44a60000 {
			compatible = "adi,axi-adxcvr-1.0";
			reg = <0x44a60000 0x1000>;
			clocks = <0x9 0x1 0x16 0x0>;
			clock-names = "conv", "div40";
			clock-output-names = "rx_gt_clk", "rx_out_clk";
			adi,sys-clk-select = <0x0>;
			adi,out-clk-select = <0x3>;
			adi,use-lpm-enable;
			adi,use-cpll-enable;
			linux,phandle = <0x17>;
			phandle = <0x17>;
		axi-adxcvr-rx-os@44a50000 {
			reg = <0x44a50000 0x1000>;
			clocks = <0x9 0x1 0x1a>;
			clock-output-names = "rx_os_gt_clk", "rx_os_out_clk";
			adi,use-lpm-enable;
			linux,phandle = <0x1b>;
			phandle = <0x1b>;
		axi-adxcvr-tx@44a80000 {
			reg = <0x44a80000 0x1000>;
			clocks = <0x9 0x1 0x18>;
			clock-output-names = "tx_gt_clk", "tx_out_clk";
			adi,sys-clk-select = <0x3>;
			linux,phandle = <0x19>;
			phandle = <0x19>;
	audio_clock {
		compatible = "fixed-clock";
		clock-frequency = <0xbb8000>;
		linux,phandle = <0x11>;
		phandle = <0x11>;
	adv7511_hdmi_snd {
		compatible = "simple-audio-card";
		simple-audio-card,name = "HDMI monitor";
		simple-audio-card,widgets = "Speaker", "Speaker";
		simple-audio-card,routing = "Speaker", "TX";
		simple-audio-card,dai-link@0 {
			format = "spdif";
			cpu {
				sound-dai = <0x1c>;
				frame-master;
				bitclock-master;
			codec {
				sound-dai = <0x1d>;
38044.profile.txt
<profile AD9371 version=0 name=Rx 80, IQrate 100.000>
 <clocks>
  <deviceClock_kHz=100000>
  <clkPllVcoFreq_kHz=12000000>
  <clkPllVcoDiv=3>
  <clkPllHsDiv=4>
 </clocks>
 <rx>
  <adcDiv=1>
  <rxFirDecimation=2>
  <rxDec5Decimation=5>
  <enHighRejDec5=1>
  <rhb1Decimation=1>
  <iqRate_kHz=100000>
  <rfBandwidth_Hz=80000000>
  <rxBbf3dBCorner_kHz=80000>
  <filter FIR gain=-6 num=48>
  -4
  -17
  23
  41
  -53
  -95
  117
  184
  -221
  -331
  389
  553
  -644
  -888
  1026
  1387
  -1608
  -2158
  2580
  3485
  -4786
  -7622
  9629
  32372
  32372
  9629
  -7622
  -4786
  3485
  2580
  -2158
  -1608
  1387
  1026
  -888
  -644
  553
  389
  -331
  -221
  184
  117
  -95
  -53
  41
  23
  -17
  -4
  </filter>
  <adc-profile num=16>
  660
  473
  201
  98
  1280
  477
  1587
  269
  1062
  82
  645
  28
  48
  32
  19
  190
  </adc-profile>
 </rx>
 <obs>
  <adcDiv=1>
  <rxFirDecimation=2>
  <enHighRejDec5=1>
  <rhb1Decimation=1>
  <iqRate_kHz=100000>
  <rxBbf3dBCorner_kHz=40000>
  <filter FIR gain=0 num=48>
  0
  -14
  12
  31
  -28
  -72
  67
  138
  -130
  -245
  235
  406
  -396
  -646
  640
  1003
  -1013
  -1559
  1636
  2557
  -2975
  -5752
  4332
  18454
  18454
  4332
  -5752
  -2975
  2557
  1636
  -1559
  -1013
  1003
  640
  -646
  -396
  406
  235
  -245
  -130
  138
  67
  -72
  -28
  31
  12
  -14
  0
  </filter>
  660
  473
  201
  98
  1280
  477
  1587
  269
  1062
  82
  645
  28
  48
  32
  19
  190
  </adc-profile>
  <lpbk-adc-profile num=16>
  737
  439
  201
  98
  1280
  112
  1505
  53
  1081
  17
  667
  40
  48
  33
  19
  194
  </lpbk-adc-profile>
 </obs>
 <sniffer>
  <adcDiv=1>
  <rxFirDecimation=2>
  <enHighRejDec5=1>
  <rhb1Decimation=2>
  <iqRate_kHz=50000>
  <rfBandwidth_Hz=20000000>
  <rxBbf3dBCorner_kHz=20000>
  <filter FIR gain=-6 num=72>
  -13
  65
  29
  29
  -42
  -86
  -111
  -42
  75
  199
  217
  95
  -149
  -367
  -407
  -172
  253
  639
  702
  308
  -413
  -1062
  -1182
  -539
  657
  1769
  2030
  996
  -1079
  -3197
  -3981
  -2335
  1935
  7853
  13561
  17059
  17059
  13561
  7853
  1935
  -2335
  -3981
  -3197
  -1079
  996
  2030
  1769
  657
  -539
  -1182
  -1062
  -413
  308
  702
  639
  253
  -172
  -407
  -367
  -149
  95
  217
  199
  75
  -42
  -111
  -86
  -42
  29
  29
  65
  -13
  </filter>
  737
  439
  201
  98
  1280
  112
  1505
  53
  1081
  17
  667
  40
  48
  33
  19
  194
  </adc-profile>
 </sniffer>
 <tx>
  <dacDiv=2.5>
  <txFirInterpolation=1>
  <thb1Interpolation=2>
  <thb2Interpolation=2>
  <txInputHbInterpolation=1>
  <iqRate_kHz=100000>
  <primarySigBandwidth_Hz=20000000>
  <txDac3dBCorner_kHz=92000>
  <txBbf3dBCorner_kHz=40000>
  <filter FIR gain=6 num=16>
  -37
  -192
  197
  -190
  -7
  816
  -2646
  20216
  -2646
  816
  -7
  -190
  197
  -192
  -37
  0
  </filter>
 </tx>
</profile>
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ad9371 spi0.1: ad9371_probe : enter
ad9528 spi0.0: spi0.0 supply vcc not found, using dummy regulator
mmc0: new high speed SDHC card at address 59b4
mmcblk0: mmc0:59b4 SMI 7.36 GiB
mmcblk0: p1 p2
axi_adxcvr 44a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using GTX2 at 0x44A6.
axi_adxcvr 44a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using GTX2 at 0x4.
axi_adxcvr 44a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using GTX2 at 0x44A8.
axi_sysid 45000000.axi-sysid-0: [adrv9371x] on [zc706] git <0> dirty [2021-03-1C
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
Registering SWP/SWPB emulation handler
[drm] Cannot find any crtc or sizes
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 for 70e00000.axi_hdmi on minor 0
ERROR: 266: Custom SNRX ADC Profile required
ad9371 spi0.1: Custom SNRX ADC Profile required
(266)
(266)
ad9371: probe of spi0.1 failed with error -14
asoc-simple-card adv7511_hdmi_snd: spdif-hifi <-> 75c00000.axi-spdif-tx mappingk
input: gpio_keys as /devices/soc0/gpio_keys/input/input0
rtc-pcf8563 5-0051: setting system clock to 2021-04-29 09:55:16 UTC (1619690116)
ALSA device list:
[edited by: dfdfdfd at 1:22 PM (GMT -4) on 9 May 2021]
    on May 10, 2021 6:19 AM
    You are likely missing:
    1. adi,sniffer-profile-custom-adc-profile
    2. adi,sniffer-profile-rx-fir
    https://github.com/analogdevicesinc/linux/blob/master/drivers/iio/adc/ad9371.c#L3288
    -Michael
  • Thanks, I made these fixes, but I ran into the following problem:
    mmcblk0: p1 p2
    axi_adxcvr 44a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using GTX2 at 0x44A60000 mapped to 0xf092a000. Number of lanes: 2.
    axi_adxcvr 44a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using GTX2 at 0x44A50000 mapped to 0xf092c000. Number of lanes: 2.
    axi_adxcvr 44a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using GTX2 at 0x44A80000 mapped to 0xf092e000. Number of lanes: 4.
    axi_sysid 45000000.axi-sysid-0: [adrv9371x] on [zc706] git <0> dirty [2021-03-16 07:31:06] UTC
    ad9371 spi0.1: Requesting device clock 3410065408 failed got 1000000000
    ad9371: probe of spi0.1 failed with error -22
    2018.system_dts.txt
    /dts-v1/;
    	cpus {
    		cpu@0 {
    			reg = <0x0>;
    			clocks = <0x2 0x3>;
    		cpu@1 {
    			reg = <0x1>;
    			clocks = <0x2 0x3>;
    	fpga-full {
    		fpga-mgr = <0x4>;
    		ranges;
    	pmu@f8891000 {
    	fixedregulator {
    		regulator-boot-on;
    		phandle = <0x3>;
    	amba {
    		ranges;
    		adc@f8007100 {
    			clocks = <0x2 0xc>;
    		can@e0008000 {
    		can@e0009000 {
    		gpio@e000a000 {
    			gpio-controller;
    			phandle = <0x5>;
    		i2c@e0004000 {
    		i2c@e0005000 {
    			phandle = <0x1>;
    			cache-unified;
    		ocmc@f800c000 {
    		serial@e0000000 {
    		serial@e0001000 {
    			status = "okay";
    		spi@e0006000 {
    			status = "okay";
    		ad9528-1@0 {
    				reg = <0x0>;
    				phandle = <0x9>;
    				channel@13 {
    					reg = <0xd>;
    				channel@1 {
    					reg = <0x1>;
    				channel@12 {
    					reg = <0xc>;
    				channel@3 {
    					reg = <0x3>;
    			ad9371-phy@1 {
    				reg = <0x1>;
    				adi,clocks-clk-pll-vco-freq_khz = <100000>;
    				adi,clocks-device-clock_khz = <12000000>;
    				#adi,jesd204-obs-framer-over-sample = <0x0>;
    				adi,sniffer-profile-custom-adc-profile = /bits/ 16 <(-13) (65) (29) (29) (-42) (-86) (-111) (-42) (75) (199) (217) (95) (-149) (-367) (-407) (-172) (253) (639) (702) (308) (-413) (-1062) (-1182) (-539) (657) (1769) (2030) (996) (-1079) (-3197) (-3981) (-2335) (1935) (7853) (13561) (17059) (17059) (13561) (7853) (1935) (-2335) (-3981) (-3197) (-1079) (996) (2030) (1769) (657) (-539) (-1182) (-1062) (-413) (308) (702) (639) (253) (-172) (-407) (-367) (-149) (95) (217) (199) (75) (-42) (-111) (-86) (-42) (29) (29) (65) (-13)>;
    				/*#adi,sniffer-profile-rx-fir = <>*/
    			     /* adi,dpd-damping = <0x5>;
    				adi,dpd-num-weights = <0x1>;
    				adi,dpd-model-version = <0x2>;
    				adi,dpd-high-power-model-update = <0x1>;
    				adi,dpd-model-prior-weight = <0x14>;
    				adi,dpd-robust-modeling = <0x0>;
    				adi,dpd-samples = <0x200>;
    				adi,dpd-outlier-threshold = <0x1000>;
    				adi,dpd-additional-delay-offset = <0x0>;
    				adi,dpd-path-delay-pn-seq-level = <0xff>;
    				adi,dpd-weights0-real = <0x40>;
    				adi,dpd-weights0-imag = <0x0>;
    				adi,dpd-weights1-real = <0x0>;
    				adi,dpd-weights1-imag = <0x0>;
    				adi,dpd-weights2-real = <0x0>;
    				adi,dpd-weights2-imag = <0x0>;
    				adi,clgc-tx1-desired-gain = <0xfffff830>;
    				adi,clgc-tx2-desired-gain = <0xfffff830>;
    				adi,clgc-tx1-atten-limit = <0x0>;
    				adi,clgc-tx2-atten-limit = <0x0>;
    				adi,clgc-tx1-control-ratio = <0x4b>;
    				adi,clgc-tx2-control-ratio = <0x4b>;
    				adi,clgc-allow-tx1-atten-updates = <0x1>;
    				adi,clgc-allow-tx2-atten-updates = <0x1>;
    				adi,clgc-additional-delay-offset = <0x0>;
    				adi,clgc-path-delay-pn-seq-level = <0xff>;
    				adi,clgc-tx1-rel-threshold = <0x258>;
    				adi,clgc-tx2-rel-threshold = <0x258>;
    				adi,clgc-tx1-rel-threshold-en = <0x0>;
    				adi,clgc-tx2-rel-threshold-en = <0x0>;
    				adi,vswr-additional-delay-offset = <0x0>;
    				adi,vswr-path-delay-pn-seq-level = <0xff>;
    				adi,vswr-tx1-vswr-switch-gpio3p3-pin = <0x0>;
    				adi,vswr-tx2-vswr-switch-gpio3p3-pin = <0x1>;
    				adi,vswr-tx1-vswr-switch-polarity = <0x0>;
    				adi,vswr-tx2-vswr-switch-polarity = <0x0>;
    				adi,vswr-tx1-vswr-switch-delay_us = <0x32>;
    				adi,vswr-tx2-vswr-switch-delay_us = <0x32>;
    				phandle = <0x13>;
    		spi@e0007000 {
    		spi@e000d000 {
    			status = "okay";
    			is-dual = <0x1>;
    			num-cs = <0x1>;
    			ps7-qspi@0 {
    				reg = <0x0>;
    				partition@0 {
    					label = "boot";
    				partition@500000 {
    					label = "bootenv";
    				partition@520000 {
    					label = "config";
    				partition@540000 {
    					label = "image";
    				partition@fc0000 {
    					label = "spare";
    			ranges;
    			flash@e1000000 {
    			flash@e2000000 {
    		ethernet@e000b000 {
    			status = "okay";
    			phy-handle = <0xa>;
    			phy@7 {
    				reg = <0x7>;
    				phandle = <0xa>;
    		ethernet@e000c000 {
    		mmc@e0100000 {
    			status = "okay";
    		mmc@e0101000 {
    		slcr@f8000000 {
    			ranges;
    			phandle = <0xb>;
    			clkc@100 {
    				phandle = <0x2>;
    			rstc@200 {
    				reg = <0x200 0x48>;
    				syscon = <0xb>;
    			pinctrl@700 {
    				syscon = <0xb>;
    		dmac@f8003000 {
    			#dma-cells = <0x1>;
    			phandle = <0x10>;
    		devcfg@f8007000 {
    			syscon = <0xb>;
    			phandle = <0x4>;
    		efuse@f800d000 {
    		timer@f8f00200 {
    			clocks = <0x2 0x4>;
    		timer@f8001000 {
    			clocks = <0x2 0x6>;
    		timer@f8002000 {
    			clocks = <0x2 0x6>;
    		timer@f8f00600 {
    			clocks = <0x2 0x4>;
    		usb@e0002000 {
    			status = "okay";
    			phy_type = "ulpi";
    			dr_mode = "host";
    		usb@e0003000 {
    			phy_type = "ulpi";
    		watchdog@f8005000 {
    	aliases {
    	memory {
    	chosen {
    	leds {
    		ds8 {
    		ds9 {
    		ds10 {
    		ds35 {
    	gpio_keys {
    		autorepeat;
    		sw7 {
    			label = "Left";
    		sw8 {
    			label = "Right";
    		sw9 {
    			label = "Select";
    	fpga-axi@0 {
    		ranges;
    		i2c@41600000 {
    			clocks = <0x2 0xf>;
    			i2cswitch@74 {
    				reg = <0x74>;
    				i2c@0 {
    					reg = <0x0>;
    					osc@5d {
    						reg = <0x5d>;
    				i2c@1 {
    					reg = <0x1>;
    					adv7511 {
    						reg = <0x39 0x3f>;
    						phandle = <0x1d>;
    						ports {
    							port@0 {
    								reg = <0x0>;
    								endpoint {
    									phandle = <0xf>;
    							port@1 {
    								reg = <0x1>;
    				i2c@2 {
    					reg = <0x2>;
    					eeprom@54 {
    						reg = <0x54>;
    				i2c@3 {
    					reg = <0x3>;
    					gpio@21 {
    						reg = <0x21>;
    						gpio-controller;
    				i2c@4 {
    					reg = <0x4>;
    					rtc@54 {
    						reg = <0x51>;
    				i2c@5 {
    					reg = <0x5>;
    					eeprom@50 {
    						reg = <0x50>;
    					eeprom@54 {
    						reg = <0x54>;
    					ad7291@2f {
    						reg = <0x2f>;
    		dma@43000000 {
    			#dma-cells = <0x1>;
    			phandle = <0xd>;
    			adi,channels {
    				dma-channel@0 {
    					reg = <0x0>;
    			phandle = <0xe>;
    		axi_hdmi@70e00000 {
    			dmas = <0xd 0x0>;
    			clocks = <0xe>;
    			adi,is-rgb;
    			port {
    				endpoint {
    					phandle = <0xc>;
    			dmas = <0x10 0x0>;
    			dma-names = "tx";
    			phandle = <0x1c>;
    		rx-dmac@7c400000 {
    			#dma-cells = <0x1>;
    			phandle = <0x12>;
    			adi,channels {
    				dma-channel@0 {
    					reg = <0x0>;
    			#dma-cells = <0x1>;
    			phandle = <0x14>;
    			adi,channels {
    				dma-channel@0 {
    					reg = <0x0>;
    		tx-dmac@7c420000 {
    			#dma-cells = <0x1>;
    			phandle = <0x15>;
    			adi,channels {
    				dma-channel@0 {
    					reg = <0x0>;
    			dmas = <0x12 0x0>;
    			dma-names = "rx";
    			dmas = <0x14 0x0>;
    			dma-names = "rx";
    			dmas = <0x15 0x0>;
    			dma-names = "tx";
    			phandle = <0x6>;
    			phandle = <0x7>;
    			phandle = <0x8>;
    			clocks = <0x9 0x1>;
    			phandle = <0x18>;
    			clocks = <0x9 0x1>;
    			phandle = <0x16>;
    			clocks = <0x9 0x1>;
    			phandle = <0x1a>;
    			adi,use-lpm-enable;
    			phandle = <0x17>;
    			adi,use-lpm-enable;
    			phandle = <0x1b>;
    			phandle = <0x19>;
    	audio_clock {
    		phandle = <0x11>;
    	adv7511_hdmi_snd {
    			format = "spdif";
    			cpu {
    				sound-dai = <0x1c>;
    				frame-master;
    				bitclock-master;
    			codec {
    				sound-dai = <0x1d>;
  • +1
    on May 11, 2021 2:09 PM in reply to dfdfdfd
    You reversed:
    adi,clocks-device-clock_khz should be 100000 ...
    -Michael
