Operating the ADRV9009 at 208MHz
I currently have a working solution consisting of three ADRV9009 devices clocked by an HMC7044. I have the sample rate set to 245.76MSPS. I am currently using the CPLL for the RX and OBS RX and QPLL0 for the TX. I am using ADI kernel 2019_R2 branch.
I need to change my design now to 208MSPS because this is the intended frequency of the final product.
For 208MSPS RX/OBS RX, the required lane rate is 208M x 40 = 8.32Gbps (across two lanes each). This is still OK for the CPLL.
For 416MSPS TX, the required lane rate is also 8.32Gbps (across four lanes). This is outside the range of QPLL0. But it does fall within the range of QPLL1.
1) Does the 2019_R2 branch support running the TX with CPLL too?
2) I have seen that I can select QPLL1 in the device tree by changing 'adi,sys-clk-select' to 2. When I do this, I get the following output:
root@frm127101u1r1:~# dmesg | grep adxcvr
[    1.303436] jesd204: created con: id=3, topo=0, link=0, /amba/spi@ff050000/hmc7044@0 <-> /amba_pl@0/axi_adxcvr@a01e0000
[    1.303455] jesd204: created con: id=4, topo=0, link=0, /amba_pl@0/axi_adxcvr@a00b0000 <-> /amba_pl@0/axi_jesd204_tx@a00f4000
[    1.303474] jesd204: created con: id=5, topo=0, link=1, /amba/spi@ff050000/hmc7044@0 <-> /amba_pl@0/axi_adxcvr@a01d0000
[    1.303495] jesd204: created con: id=6, topo=0, link=2, /amba/spi@ff050000/hmc7044@0 <-> /amba_pl@0/axi_adxcvr@a01c0000
[    1.303513] jesd204: created con: id=7, topo=0, link=2, /amba_pl@0/axi_adxcvr@a0080000 <-> /amba_pl@0/axi_jesd204_rx@a00f0000
[    1.303531] jesd204: created con: id=8, topo=0, link=1, /amba_pl@0/axi_adxcvr@a0090000 <-> /amba_pl@0/axi_jesd204_rx@a002c000
[    1.303549] jesd204: created con: id=9, topo=0, link=0, /amba_pl@0/axi_adxcvr@a01e0000 <-> /amba_pl@0/axi_adxcvr@a00d0000
[    1.303585] jesd204: created con: id=11, topo=0, link=1, /amba_pl@0/axi_adxcvr@a01d0000 <-> /amba_pl@0/axi_adxcvr@a00a0000
[    1.303605] jesd204: created con: id=12, topo=0, link=2, /amba_pl@0/axi_adxcvr@a01c0000 <-> /amba_pl@0/axi_adxcvr@a0030000
[    1.303658] jesd204: created con: id=15, topo=0, link=0, /amba_pl@0/axi_adxcvr@a00d0000 <-> /amba_pl@0/axi_adxcvr@a00b0000
[    1.303694] jesd204: created con: id=17, topo=0, link=1, /amba_pl@0/axi_adxcvr@a00a0000 <-> /amba_pl@0/axi_adxcvr@a0090000
[    1.303712] jesd204: created con: id=18, topo=0, link=2, /amba_pl@0/axi_adxcvr@a0030000 <-> /amba_pl@0/axi_adxcvr@a0080000
[    6.514913] axi_adxcvr a0080000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA0080000. Number of lanes: 2.
[    6.527995] axi_adxcvr a0090000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA0090000. Number of lanes: 2.
[    6.539671] axi_adxcvr a00b0000.axi_adxcvr: AXI-ADXCVR-TX (16.01.a) using QPLL1 on GTH4 at 0xA00B0000. Number of lanes: 4.
[    6.552730] axi_adxcvr a0030000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA0030000. Number of lanes: 2.
[    6.568504] axi_adxcvr a00a0000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA00A0000. Number of lanes: 2.
[    6.580260] axi_adxcvr a00d0000.axi_adxcvr: AXI-ADXCVR-TX (16.01.a) using QPLL1 on GTH4 at 0xA00D0000. Number of lanes: 4.
[    6.593066] axi_adxcvr a01c0000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA01C0000. Number of lanes: 2.
[    6.606144] axi_adxcvr a01d0000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA01D0000. Number of lanes: 2.
[    6.617849] axi_adxcvr a01e0000.axi_adxcvr: AXI-ADXCVR-TX (16.01.a) using QPLL1 on GTH4 at 0xA01E0000. Number of lanes: 4.
[    7.340007] axi_adxcvr a01e0000.axi_adxcvr: QPLL1 TX Error: 0
[    7.447795] axi_adxcvr a01e0000.axi_adxcvr: QPLL1 TX Error: 0
Is there anything else I need to change to use QPLL1? Does the HDL need to change to use QPLL1?
  • While keeping my design at 245.76MSPS (so as to minimise the number of changes), I am going to try moving the TX to the CPLL. I noticed in the HDL block design components that I probably need to make the following changes to the axi_adrv9009_tx_xcvr configuration:
    Change 'Qpll Enable' from '1' to '0'.
    Change 'Sys Clk Sel' from "11" to "00"
    I am building this firmware now and will see if it works.
  • I would still like to find out if the axi_adxcvr IIO device driver supports running the RX, OBS RX and TX from CPLL? Else I am wasting my time trying this.
    on May 5, 2021 7:44 AM in reply to gavint
    I think it should be enough to just change the sys-clk-sel in the devicetree to CPLL.
    However I'm wondering if that is really the problem here.
    Your clock chip needs to be able to provide the required reference clocks. And from the default VCXO of 122.88MHz I don't think you can generate the required clocks. So I guess the framework asks for a certain rate the clock chip sets to something close but not exact and the PLL doesn't lock. I don't think this will be different when using CPLL.
    I'm sure your kernel log includes more errors besides the lock error?
    How did you set the AD9528 devicetree settings?
    Can you check clk_summary ?
    root@analog:~# cat /sys/kernel/debug/clk/clk_summary
                                     enable  prepare  protect                                duty
       clock                          count    count    count        rate   accuracy phase  cycle  nshot
     spi1.1-tx_sampl_clk                  0        0        0   245760000          0     0  50000        0
     spi1.1-obs_sampl_clk                 0        0        0   245760000          0     0  50000        0
     spi1.1-rx_sampl_clk                  0        0        0   245760000          0     0  50000        0
     spi1.0-tx_sampl_clk                  1        1        0   245760000          0     0  50000        0
     spi1.0-obs_sampl_clk                 1        1        0   245760000          0     0  50000        0
     spi1.0-rx_sampl_clk                  0        0        0   245760000          0     0  50000        0
     hmc7044_e_out11_REFCLK_SFP           0        0        0   122880000          0     0  50000        0
     hmc7044_e_out6_SYNC_OUT2             0        0        0     3840000          0     0  50000        0
     hmc7044_e_out5_SYNC_OUT1             0        0        0     3840000          0     0  50000        0
     hmc7044_e_out2_REFCLK_OUT2           0        0        0    30720000          0     0  50000        0
     hmc7044_e_out0_REFCLK_OUT0           0        0        0    30720000          0     0  50000        0
     hmc7044_c_out11_REFCLK_SFP           0        0        0   122880000          0     0  50000        0
     hmc7044_c_out10_REFCLK_QSFP          0        0        0    30720000          0     0  50000        0
     hmc7044_c_out9_REFCLK_OUT4           0        0        0    30720000          0     0  50000        0
     hmc7044_c_out8_REFCLK_OUT3           0        0        0    30720000          0     0  50000        0
     hmc7044_c_out6_SYNC_OUT2             0        0        0     3840000          0     0  50000        0
     hmc7044_c_out5_SYNC_OUT1             0        0        0     3840000          0     0  50000        0
     hmc7044_c_out2_REFCLK_OUT2           5        5        0    30720000          0     0  50000        0
        hmc7044_out9_FPGA_SYSREF_RX_AB       0        0        0     3840000          0     0  50000        0
        hmc7044_out8_FPGA_SYSREF_TX_OBS_AB       0        0        0     3840000          0     0  50000        0
        hmc7044_out7_CORE_CLK_RX_AB       0        0        0   245760000          0     0  50000        0
        hmc7044_out6_CORE_CLK_TX_OBS_AB       0        0        0   122880000          0     0  50000        0
        hmc7044_out5_JESD_REFCLK_RX_AB       1        1        0   245760000          0     0  50000        0
           rx_out_clk                     0        0        0   245760000          0     0  50000        0
           rx_gt_clk                      0        0        0     9830400          0     0  50000        0
        hmc7044_out4_JESD_REFCLK_TX_OBS_AB       2        2        0   245760000          0     0  50000        0
           tx_out_clk                     0        0        0   245760000          0     0  50000        0
           tx_gt_clk                      0        0        0     9830400          0     0  50000        0
           rx_os_out_clk                  0        0        0   245760000          0     0  50000        0
           rx_os_gt_clk                   0        0        0     9830400          0     0  50000        0
        hmc7044_out3_DEV_SYSREF_B         0        0        0     3840000          0     0  50000        0
        hmc7044_out2_DEV_REFCLK_B         1        1        0   245760000          0     0  50000        0
        hmc7044_out1_DEV_SYSREF_A         0        0        0     3840000          0     0  50000        0
        hmc7044_out0_DEV_REFCLK_A         1        1        0   245760000          0     0  50000        0
     hmc7044_c_out0_REFCLK_OUT0           0        0        0    30720000          0     0  50000        0
     audio_clock                          1        1        0    12288000          0     0  50000        0
    -Michael
  • I have an HMC7044 generating the clocks. For now, I have kept the sample rate at 245.76MSPS so that I can try and get the TX working on the CPLL before moving to 208MHz. I know that the clocks are correct because the TX works when running QPLL0.
    I made the changes to the HDL configuration and built the firmware and the result was still the same. Here is my complete dmesg output with the change to CPLL:
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 4.19.0 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Tue May 4 14:53:13 UTC 2021
    [    0.000000] Machine model: xlnx,zynqmp
    [    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
    [    0.000000] bootconsole [cdns0] enabled
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] efi: UEFI not found.
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000003ed40000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node rproc@3ed40000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000003ef40000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node rproc@3ef40000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
    [    0.000000] On node 0 totalpages: 523648
    [    0.000000]   DMA32 zone: 7168 pages used for memmap
    [    0.000000]   DMA32 zone: 0 pages reserved
    [    0.000000]   DMA32 zone: 523648 pages, LIFO batch:63
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] psci: SMC Calling Convention v1.1
    [    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
    [    0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52504 r8192 d29416 u90112
    [    0.000000] pcpu-alloc: s52504 r8192 d29416 u90112 alloc=22*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: enabling workaround for ARM erratum 845719
    [    0.000000] Speculative Store Bypass Disable mitigation not required
    [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516480
    [    0.000000] Kernel command line: earlycon clk_ignore_unused cpuidle.off=1 uio_pdrv_genirq.of_id="generic-uio"
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
    [    0.000000] Memory: 1770432K/2094592K available (10940K kernel code, 1266K rwdata, 6104K rodata, 832K init, 306K bss, 62016K reserved, 262144K cma-reserved)
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] irq-xilinx: /amba_pl@0/interrupt-controller@a000f000: num_irq=18, edge=0x0
    [    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
    [    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
    [    0.008264] Console: colour dummy device 80x25
    [    0.012376] console [tty0] enabled
    [    0.015743] bootconsole [cdns0] disabled
    [    0.019652] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
    [    0.019665] pid_max: default: 32768 minimum: 301
    [    0.019778] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.019793] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.020502] ASID allocator initialised with 32768 entries
    [    0.020554] rcu: Hierarchical SRCU implementation.
    [    0.020874] EFI services will not be available.
    [    0.020993] smp: Bringing up secondary CPUs ...
    [    0.021269] Detected VIPT I-cache on CPU1
    [    0.021298] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.021603] Detected VIPT I-cache on CPU2
    [    0.021623] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.021909] Detected VIPT I-cache on CPU3
    [    0.021928] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.021972] smp: Brought up 1 node, 4 CPUs
    [    0.022005] SMP: Total of 4 processors activated.
    [    0.022014] CPU features: detected: 32-bit EL0 Support
    [    0.023658] CPU: All CPU(s) started at EL2
    [    0.023674] alternatives: patching kernel code
    [    0.024318] devtmpfs: initialized
    [    0.033568] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.033595] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.039307] xor: measuring software checksum speed
    [    0.075740]    8regs     :  2375.000 MB/sec
    [    0.115769]    8regs_prefetch:  2052.000 MB/sec
    [    0.155799]    32regs    :  2725.000 MB/sec
    [    0.195829]    32regs_prefetch:  2309.000 MB/sec
    [    0.195837] xor: using function: 32regs (2725.000 MB/sec)
    [    0.195850] pinctrl core: initialized pinctrl subsystem
    [    0.196434] NET: Registered protocol family 16
    [    0.196699] audit: initializing netlink subsys (disabled)
    [    0.196844] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
    [    0.197146] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
    [    0.197159] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.198056] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.214479] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.280028] raid6: int64x1  gen()   448 MB/s
    [    0.348012] raid6: int64x1  xor()   450 MB/s
    [    0.416121] raid6: int64x2  gen()   684 MB/s
    [    0.484118] raid6: int64x2  xor()   599 MB/s
    [    0.552155] raid6: int64x4  gen()   980 MB/s
    [    0.620202] raid6: int64x4  xor()   736 MB/s
    [    0.688237] raid6: int64x8  gen()  1163 MB/s
    [    0.756309] raid6: int64x8  xor()   759 MB/s
    [    0.824355] raid6: neonx1   gen()   736 MB/s
    [    0.892411] raid6: neonx1   xor()   879 MB/s
    [    0.960455] raid6: neonx2   gen()  1130 MB/s
    [    1.028496] raid6: neonx2   xor()  1171 MB/s
    [    1.096561] raid6: neonx4   gen()  1484 MB/s
    [    1.164597] raid6: neonx4   xor()  1416 MB/s
    [    1.232667] raid6: neonx8   gen()  1542 MB/s
    [    1.300716] raid6: neonx8   xor()  1459 MB/s
    [    1.300724] raid6: using algorithm neonx8 gen() 1542 MB/s
    [    1.300732] raid6: .... xor() 1459 MB/s, rmw enabled
    [    1.300739] raid6: using neon recovery algorithm
    [    1.301661] SCSI subsystem initialized
    [    1.301706] libata version 3.00 loaded.
    [    1.301848] usbcore: registered new interface driver usbfs
    [    1.301887] usbcore: registered new interface driver hub
    [    1.301931] usbcore: registered new device driver usb
    [    1.301992] media: Linux media interface: v0.10
    [    1.302018] videodev: Linux video capture interface: v2.00
    [    1.302049] pps_core: LinuxPPS API ver. 1 registered
    [    1.302057] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.302077] PTP clock support registered
    [    1.302103] EDAC MC: Ver: 3.0.0
    [    1.302559] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
    [    1.302812] zynqmp-ipi-mbox mailbox@ff90600: Probed ZynqMP IPI Mailbox driver.
    [    1.302930] zynqmp-ipi-mbox mailbox@ff3f0b00: Probed ZynqMP IPI Mailbox driver.
    [    1.303480] jesd204: created con: id=0, topo=0, link=0, /amba_pl@0/axi_jesd204_tx@a001c000 <-> /amba_pl@0/axi-adrv9009-tx-hpc@a01f4000
    [    1.303500] jesd204: created con: id=1, topo=0, link=0, /amba_pl@0/axi-adrv9009-tx-hpc@a01f4000 <-> /amba_pl@0/axi-adrv9009-tx-hpc@a00e4000
    [    1.303519] jesd204: created con: id=2, topo=0, link=0, /amba_pl@0/axi-adrv9009-tx-hpc@a00e4000 <-> /amba_pl@0/axi-adrv9009-tx-hpc@a00c4000
    [    1.303539] jesd204: created con: id=3, topo=0, link=0, /amba/spi@ff050000/hmc7044@0 <-> /amba_pl@0/axi_adxcvr@a01e0000
    [    1.303558] jesd204: created con: id=4, topo=0, link=0, /amba_pl@0/axi_adxcvr@a00b0000 <-> /amba_pl@0/axi_jesd204_tx@a00f4000
    [    1.303577] jesd204: created con: id=5, topo=0, link=1, /amba/spi@ff050000/hmc7044@0 <-> /amba_pl@0/axi_adxcvr@a01d0000
    [    1.303598] jesd204: created con: id=6, topo=0, link=2, /amba/spi@ff050000/hmc7044@0 <-> /amba_pl@0/axi_adxcvr@a01c0000
    [    1.303617] jesd204: created con: id=7, topo=0, link=2, /amba_pl@0/axi_adxcvr@a0080000 <-> /amba_pl@0/axi_jesd204_rx@a00f0000
    [    1.303635] jesd204: created con: id=8, topo=0, link=1, /amba_pl@0/axi_adxcvr@a0090000 <-> /amba_pl@0/axi_jesd204_rx@a002c000
    [    1.303652] jesd204: created con: id=9, topo=0, link=0, /amba_pl@0/axi_adxcvr@a01e0000 <-> /amba_pl@0/axi_adxcvr@a00d0000
    [    1.303671] jesd204: created con: id=10, topo=0, link=0, /amba_pl@0/axi_jesd204_tx@a00f4000 <-> /amba_pl@0/axi_jesd204_tx@a0028000
    [    1.303689] jesd204: created con: id=11, topo=0, link=1, /amba_pl@0/axi_adxcvr@a01d0000 <-> /amba_pl@0/axi_adxcvr@a00a0000
    [    1.303706] jesd204: created con: id=12, topo=0, link=2, /amba_pl@0/axi_adxcvr@a01c0000 <-> /amba_pl@0/axi_adxcvr@a0030000
    [    1.303724] jesd204: created con: id=13, topo=0, link=2, /amba_pl@0/axi_jesd204_rx@a00f0000 <-> /amba_pl@0/axi_jesd204_rx@a0024000
    [    1.303742] jesd204: created con: id=14, topo=0, link=1, /amba_pl@0/axi_jesd204_rx@a002c000 <-> /amba_pl@0/axi_jesd204_rx@a0020000
    [    1.303760] jesd204: created con: id=15, topo=0, link=0, /amba_pl@0/axi_adxcvr@a00d0000 <-> /amba_pl@0/axi_adxcvr@a00b0000
    [    1.303778] jesd204: created con: id=16, topo=0, link=0, /amba_pl@0/axi_jesd204_tx@a0028000 <-> /amba_pl@0/axi_jesd204_tx@a001c000
    [    1.303796] jesd204: created con: id=17, topo=0, link=1, /amba_pl@0/axi_adxcvr@a00a0000 <-> /amba_pl@0/axi_adxcvr@a0090000
    [    1.303814] jesd204: created con: id=18, topo=0, link=2, /amba_pl@0/axi_adxcvr@a0030000 <-> /amba_pl@0/axi_adxcvr@a0080000
    [    1.303831] jesd204: created con: id=19, topo=0, link=2, /amba_pl@0/axi_jesd204_rx@a0024000 <-> /amba_pl@0/axi_jesd204_rx@a0018000
    [    1.303849] jesd204: created con: id=20, topo=0, link=1, /amba_pl@0/axi_jesd204_rx@a0020000 <-> /amba_pl@0/axi_jesd204_rx@a0014000
    [    1.303887] jesd204: created con: id=21, topo=0, link=1, /amba_pl@0/axi_jesd204_rx@a0014000 <-> /amba/spi@ff040000/adrv9009-phy@2
    [    1.303913] jesd204: created con: id=22, topo=0, link=2, /amba_pl@0/axi_jesd204_rx@a0018000 <-> /amba/spi@ff040000/adrv9009-phy@2
    [    1.303940] jesd204: created con: id=23, topo=0, link=0, /amba_pl@0/axi-adrv9009-tx-hpc@a00c4000 <-> /amba/spi@ff040000/adrv9009-phy@2
    [    1.304007] jesd204: created con: id=24, topo=0, link=1, /amba/spi@ff040000/adrv9009-phy@2 <-> /amba/spi@ff040000/adrv9009-phy@1
    [    1.304048] jesd204: created con: id=25, topo=0, link=2, /amba/spi@ff040000/adrv9009-phy@2 <-> /amba/spi@ff040000/adrv9009-phy@1
    [    1.304097] jesd204: created con: id=26, topo=0, link=0, /amba/spi@ff040000/adrv9009-phy@2 <-> /amba/spi@ff040000/adrv9009-phy@1
    [    1.304164] jesd204: created con: id=27, topo=0, link=1, /amba/spi@ff040000/adrv9009-phy@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.304205] jesd204: created con: id=28, topo=0, link=2, /amba/spi@ff040000/adrv9009-phy@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.304253] jesd204: created con: id=29, topo=0, link=0, /amba/spi@ff040000/adrv9009-phy@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.304299] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[0] transition uninitialized -> initialized
    [    1.304312] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[1] transition uninitialized -> initialized
    [    1.304325] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[2] transition uninitialized -> initialized
    [    1.304336] jesd204: found 25 devices and 1 topologies
    [    1.304376] FPGA manager framework
    [    1.304592] Advanced Linux Sound Architecture Driver Initialized.
    [    1.304870] Bluetooth: Core ver 2.22
    [    1.304900] NET: Registered protocol family 31
    [    1.304909] Bluetooth: HCI device and connection manager initialized
    [    1.304921] Bluetooth: HCI socket layer initialized
    [    1.304931] Bluetooth: L2CAP socket layer initialized
    [    1.304957] Bluetooth: SCO socket layer initialized
    [    1.305274] clocksource: Switched to clocksource arch_sys_counter
    [    1.305358] VFS: Disk quotas dquot_6.6.0
    [    1.305409] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    1.309990] NET: Registered protocol family 2
    [    1.310331] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
    [    1.310364] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
    [    1.310475] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
    [    1.310672] TCP: Hash tables configured (established 16384 bind 16384)
    [    1.310734] UDP hash table entries: 1024 (order: 3, 32768 bytes)
    [    1.310779] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
    [    1.310901] NET: Registered protocol family 1
    [    1.311107] RPC: Registered named UNIX socket transport module.
    [    1.311117] RPC: Registered udp transport module.
    [    1.311124] RPC: Registered tcp transport module.
    [    1.311131] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.311361] PCI: CLS 0 bytes, default 64
    [    1.311451] Trying to unpack rootfs image as initramfs...
    [    1.700064] Freeing initrd memory: 9428K
    [    1.700426] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    1.700585] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    1.701657] Initialise system trusted keyrings
    [    1.701739] workingset: timestamp_bits=62 max_order=19 bucket_order=0
    [    1.702418] NFS: Registering the id_resolver key type
    [    1.702433] Key type id_resolver registered
    [    1.702441] Key type id_legacy registered
    [    1.702453] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.702475] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    [    2.789940] NET: Registered protocol family 38
    [    2.848161] Key type asymmetric registered
    [    2.848172] Asymmetric key parser 'x509' registered
    [    2.848217] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    2.848230] io scheduler noop registered
    [    2.848238] io scheduler deadline registered
    [    2.848272] io scheduler cfq registered (default)
    [    2.848281] io scheduler mq-deadline registered
    [    2.848289] io scheduler kyber registered
    [    2.876779] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    2.881799] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    2.886359] brd: module loaded
    [    2.890108] loop: module loaded
    [    2.891152] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    2.892603] libphy: Fixed MDIO Bus: probed
    [    2.893853] tun: Universal TUN/TAP device driver, 1.6
    [    2.893986] CAN device driver interface
    [    2.895316] usbcore: registered new interface driver asix
    [    2.895355] usbcore: registered new interface driver ax88179_178a
    [    2.895389] usbcore: registered new interface driver cdc_ether
    [    2.895420] usbcore: registered new interface driver net1080
    [    2.895451] usbcore: registered new interface driver cdc_subset
    [    2.895482] usbcore: registered new interface driver zaurus
    [    2.895522] usbcore: registered new interface driver cdc_ncm
    [    2.896178] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.896189] ehci-pci: EHCI PCI platform driver
    [    2.896559] usbcore: registered new interface driver uas
    [    2.896599] usbcore: registered new interface driver usb-storage
    [    2.897453] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
    [    2.897544] i2c /dev entries driver
    [    2.899784] usbcore: registered new interface driver uvcvideo
    [    2.899795] USB Video Class driver (1.1.1)
    [    2.900325] Bluetooth: HCI UART driver ver 2.3
    [    2.900337] Bluetooth: HCI UART protocol H4 registered
    [    2.900345] Bluetooth: HCI UART protocol BCSP registered
    [    2.900375] Bluetooth: HCI UART protocol LL registered
    [    2.900384] Bluetooth: HCI UART protocol ATH3K registered
    [    2.900408] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    2.900465] Bluetooth: HCI UART protocol Intel registered
    [    2.900490] Bluetooth: HCI UART protocol QCA registered
    [    2.900529] usbcore: registered new interface driver bcm203x
    [    2.900565] usbcore: registered new interface driver bpa10x
    [    2.900600] usbcore: registered new interface driver bfusb
    [    2.900635] usbcore: registered new interface driver btusb
    [    2.900644] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
    [    2.900697] usbcore: registered new interface driver ath3k
    [    2.901037] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT)
    [    2.901259] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    2.901602] CPUidle arm: Failed to register cpuidle driver
    [    2.901830] sdhci: Secure Digital Host Controller Interface driver
    [    2.901840] sdhci: Copyright(c) Pierre Ossman
    [    2.901847] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.902276] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.902325] zynqmp_firmware_probe Platform Management API v1.1
    [    2.902336] zynqmp_firmware_probe Trustzone version v1.0
    [    2.925532] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
    [    2.926044] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
    [    2.926066] zynqmp_aes zynqmp_aes: AES Successfully Registered
    [    2.926066]
    [    2.926265] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
    [    2.926450] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
    [    2.926684] usbcore: registered new interface driver usbhid
    [    2.926693] usbhid: USB HID core driver
    [    2.935576] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    2.936083] usbcore: registered new interface driver snd-usb-audio
    [    2.937208] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    2.937595] Initializing XFRM netlink socket
    [    2.937671] NET: Registered protocol family 10
    [    2.938021] Segment Routing with IPv6
    [    2.938109] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    2.938440] NET: Registered protocol family 17
    [    2.938456] NET: Registered protocol family 15
    [    2.938475] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    2.938531] can: controller area network core (rev 20170425 abi 9)
    [    2.938563] NET: Registered protocol family 29
    [    2.938572] can: raw protocol (rev 20170425)
    [    2.938580] can: broadcast manager protocol (rev 20170425 t)
    [    2.938590] can: netlink gateway (rev 20170425) max_hops=1
    [    2.938652] Bluetooth: RFCOMM TTY layer initialized
    [    2.938664] Bluetooth: RFCOMM socket layer initialized
    [    2.938679] Bluetooth: RFCOMM ver 1.11
    [    2.938690] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    2.938698] Bluetooth: BNEP filters: protocol multicast
    [    2.938708] Bluetooth: BNEP socket layer initialized
    [    2.938716] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    2.938726] Bluetooth: HIDP socket layer initialized
    [    2.938845] 9pnet: Installing 9P2000 support
    [    2.938866] Key type dns_resolver registered
    [    2.939243] registered taskstats version 1
    [    2.939252] Loading compiled-in X.509 certificates
    [    2.939577] Btrfs loaded, crc32c=crc32c-generic
    [    2.945778] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 47, base_baud = 6249999) is a xuartps
    [    4.631709] console [ttyPS0] enabled
    [    4.635930] of-fpga-region fpga-full: FPGA Region probed
    [    4.641767] nwl-pcie fd0e0000.pcie: Link is DOWN
    [    4.646420] nwl-pcie fd0e0000.pcie: host bridge /amba/pcie@fd0e0000 ranges:
    [    4.653397] nwl-pcie fd0e0000.pcie:   MEM 0xe0000000..0xefffffff -> 0xe0000000
    [    4.660624] nwl-pcie fd0e0000.pcie:   MEM 0x600000000..0x7ffffffff -> 0x600000000
    [    4.668215] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
    [    4.674397] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    4.679878] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
    [    4.686752] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
    [    4.694254] pci 0000:00:00.0: [10ee:d011] type 01 class 0x068000
    [    4.694269] pci 0000:00:00.0: ignoring class 0x068000 (doesn't match header type 01)
    [    4.702044] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
    [    4.706140] pci 0000:00:00.0: not setting up bridge for bus 0000:01
    [    4.714362] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
    [    4.720957] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
    [    4.728077] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
    [    4.735190] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
    [    4.742302] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
    [    4.749411] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
    [    4.756522] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
    [    4.763636] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
    [    4.770744] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
    [    4.777927] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
    [    4.785040] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
    [    4.792150] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
    [    4.799259] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
    [    4.806368] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
    [    4.813474] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
    [    4.820590] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
    [    4.827703] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
    [    4.834950] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
    [    4.845957] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
    [    4.856703] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    4.864770] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    4.873646] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
    [    4.886137] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
    [    4.898811] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
    [    4.909003] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
    [    4.915977] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    4.922593] [drm] No driver support for vblank timestamp query.
    [    4.928570] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008bee080)
    [    6.013278] [drm] Cannot find any crtc or sizes
    [    6.018029] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
    [    6.026137] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
    [    6.035475] adrv9009 spi1.0: adrv9009_probe : enter
    [    6.041141] adrv9009 spi1.1: adrv9009_probe : enter
    [    6.046492] adrv9009 spi1.2: adrv9009_probe : enter
    [    6.099506] jesd204: /amba/spi@ff050000/hmc7044@0,jesd204:3,parent=spi2.0: Using as SYSREF provider
    [    6.108951] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    6.116349] libphy: MACB_mii_bus: probed
    [    6.194459] Micrel KSZ9031 Gigabit PHY ff0b0000.ethernet-ffffffff:03: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=ff0b0000.ethernet-ffffffff:03, irq=POLL)
    [    6.210293] macb ff0b0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 30 (00:0a:35:01:84:be)
    [    6.220492] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    6.227042] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
    [    6.233546] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
    [    6.240039] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
    [    6.246544] dwc3-of-simple ff9d0000.usb0: dwc3_simple_set_phydata: Can't find usb3-phy
    [    6.254841] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
    [    6.261848] dwc3-of-simple ff9e0000.usb1: dwc3_simple_set_phydata: Can't find usb3-phy
    [    6.270167] dwc3 fe300000.dwc3: Failed to get clk 'ref': -2
    [    6.275862] dwc3 fe300000.dwc3: Configuration mismatch. dr_mode forced to gadget
    [    6.284640] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
    [    6.321290] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA 64-bit
    [    6.365282] mmc1: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
    [    6.382564] axi_adxcvr a0080000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA0080000. Number of lanes: 2.
    [    6.395611] axi_adxcvr a0090000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA0090000. Number of lanes: 2.
    [    6.407315] axi_adxcvr a00b0000.axi_adxcvr: AXI-ADXCVR-TX (16.01.a) using CPLL on GTH4 at 0xA00B0000. Number of lanes: 4.
    [    6.420290] axi_adxcvr a0030000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA0030000. Number of lanes: 2.
    [    6.435877] axi_adxcvr a00a0000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA00A0000. Number of lanes: 2.
    [    6.447648] axi_adxcvr a00d0000.axi_adxcvr: AXI-ADXCVR-TX (16.01.a) using CPLL on GTH4 at 0xA00D0000. Number of lanes: 4.
    [    6.460338] axi_adxcvr a01c0000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA01C0000. Number of lanes: 2.
    [    6.473456] axi_adxcvr a01d0000.axi_adxcvr: AXI-ADXCVR-RX (16.01.a) using CPLL on GTH4 at 0xA01D0000. Number of lanes: 2.
    [    6.485173] axi_adxcvr a01e0000.axi_adxcvr: AXI-ADXCVR-TX (16.01.a) using CPLL on GTH4 at 0xA01E0000. Number of lanes: 4.
    [    6.499667] adrv9009 spi1.0: adrv9009_probe : enter
    [    6.509767] adrv9009 spi1.1: adrv9009_probe : enter
    [    6.519489] adrv9009 spi1.2: adrv9009_probe : enter
    [    6.549883] cf_axi_adc a00c0000.axi-adrv9009-rx-hpc-0: ADI AIM (10.00.b) at 0xA00C0000 mapped to 0x(____ptrval____), probed ADC ADRV9009 as MASTER
    [    6.583615] cf_axi_adc a00e0000.axi-adrv9009-rx-hpc-1: ADI AIM (10.00.b) at 0xA00E0000 mapped to 0x(____ptrval____), probed ADC ADRV9009 as MASTER
    [    6.617375] cf_axi_adc a01f0000.axi-adrv9009-rx-hpc-2: ADI AIM (10.00.b) at 0xA01F0000 mapped to 0x(____ptrval____), probed ADC ADRV9009 as MASTER
    [    6.630706] ad_adc: WARNING: setting max_usr_channel to 4
    [    6.631118] ad_adc: WARNING: setting max_usr_channel to 4
    [    6.636888] ad_adc: WARNING: setting max_usr_channel to 4
    [    6.646227] mmc0: new HS200 MMC card at address 0001
    [    6.657063] mmcblk0: mmc0:0001 W52516 14.3 GiB
    [    6.661945] mmcblk0boot0: mmc0:0001 W52516 partition 1 4.00 MiB
    [    6.668208] mmcblk0boot1: mmc0:0001 W52516 partition 2 4.00 MiB
    [    6.674618] cf_axi_dds a00c4000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.00.b) at 0xA00C4000 mapped to 0x(____ptrval____), probed DDS AD9371
    [    6.689516] mmcblk0rpmb: mmc0:0001 W52516 partition 3 4.00 MiB, chardev (244:0)
    [    6.697725]  mmcblk0: p1
    [    6.709697] cf_axi_dds a00e4000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.00.b) at 0xA00E4000 mapped to 0x(____ptrval____), probed DDS AD9371
    [    6.729824] random: fast init done
    [    6.736551] mmc1: new high speed SDHC card at address 59b4
    [    6.742484] mmcblk1: mmc1:59b4 USD   14.7 GiB (ro)
    [    6.747791] cf_axi_dds a01f4000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.00.b) at 0xA01F4000 mapped to 0x(____ptrval____), probed DDS AD9371
    [    6.762178] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition initialized -> probed
    [    6.773313] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition initialized -> probed
    [    6.784441] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
    [    6.795596] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
    [    6.806121] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition probed -> idle
    [    6.816640] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
    [    6.827186] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [    6.838145] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [    6.849104] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [    6.860067] adrv9009 spi1.2: adrv9009_jesd204_link_init:5396 link_num 1 reason initialization
    [    6.860074] adrv9009 spi1.2: adrv9009_jesd204_link_init:5396 link_num 2 reason initialization
    [    6.860081] adrv9009 spi1.2: adrv9009_jesd204_link_init:5396 link_num 0 reason initialization
    [    6.860086] adrv9009 spi1.1: adrv9009_jesd204_link_init:5396 link_num 1 reason initialization
    [    6.860095] adrv9009 spi1.1: adrv9009_jesd204_link_init:5396 link_num 2 reason initialization
    [    6.860103] adrv9009 spi1.1: adrv9009_jesd204_link_init:5396 link_num 0 reason initialization
    [    6.860108] adrv9009 spi1.0: adrv9009_jesd204_link_init:5396 link_num 0 reason initialization
    [    6.860113] adrv9009 spi1.0: adrv9009_jesd204_link_init:5396 link_num 1 reason initialization
    [    6.860117] adrv9009 spi1.0: adrv9009_jesd204_link_init:5396 link_num 2 reason initialization
    [    6.860124] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [    6.871517] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [    6.882905] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [    6.894303] cf_axi_dds a01f4000.axi-adrv9009-tx-hpc: JESD param mismatch between TPL and Link configuration !
    [    6.904213] cf_axi_dds a00e4000.axi-adrv9009-tx-hpc: JESD param mismatch between TPL and Link configuration !
    [    6.914126] cf_axi_dds a00c4000.axi-adrv9009-tx-hpc: JESD param mismatch between TPL and Link configuration !
    [    6.924051] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [    6.935697] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [    6.947345] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [    6.959586] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [    6.971688] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [    6.983781] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [    6.995889] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [    7.008064] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [    7.020233] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [    7.032422] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [    7.044676] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [    7.056932] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [    7.069211] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [    7.081472] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [    7.093727] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [    7.208081] axi_adxcvr a01e0000.axi_adxcvr: CPLL TX Error: 0
    [    7.315774] axi_adxcvr a01e0000.axi_adxcvr: CPLL TX Error: 0
    [    7.321436] axi-jesd204-tx a00f4000.axi_jesd204_tx: axi_jesd204_tx_jesd204_link_setup: Link0 enable lane clock failed (-5)
    [    7.332482] jesd204: /amba_pl@0/axi_jesd204_tx@a00f4000,jesd204:20,parent=a00f4000.axi_jesd204_tx: JESD204[0] got error from cb: -5
    [    7.344304] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'clk_sync_stage3', got error -5
    [    7.355972] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [    7.367793] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [    7.379614] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [    7.391454] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
    [    7.403277] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> clk_sync_stage3
    [    7.415098] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
    [    7.426938] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
    [    7.439195] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> clk_sync_stage2
    [    7.451450] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
    [    7.463725] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [    7.475981] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [    7.488237] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [    7.500510] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [    7.512680] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [    7.524850] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [    7.537037] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [    7.549119] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [    7.561202] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [    7.573303] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [    7.584954] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [    7.596608] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [    7.608276] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [    7.619662] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [    7.631050] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [    7.642455] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [    7.653410] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [    7.664363] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [    7.675318] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: FSM completed with error -5
    [    7.685142]  mmcblk1: p1 p2 p3
    [    7.691087] rtc_zynqmp ffa60000.rtc: setting system clock to 2021-05-05 07:47:06 UTC (1620200826)
    [    7.699966] of_cfs_init
    [    7.702426] of_cfs_init: OK
    [    7.705467] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    7.849572] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    7.856112] clk: Not disabling unused clocks
    [    7.860384] ALSA device list:
    [    7.863348]   #0: DisplayPort monitor
    [    7.867388] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    7.876006] cfg80211: failed to load regulatory.db
    [    7.881284] Freeing unused kernel memory: 832K
    [    7.901283] [drm] Cannot find any crtc or sizes
    [    7.901308] Run /init as init process
    [    8.026301] udevd[2010]: starting version 3.2.5
    [    8.031121] random: udevd: uninitialized urandom read (16 bytes read)
    [    8.037610] random: udevd: uninitialized urandom read (16 bytes read)
    [    8.044116] random: udevd: uninitialized urandom read (16 bytes read)
    [    8.054643] udevd[2011]: starting eudev-3.2.5
    [    8.160502] zynqmp_r5_remoteproc zynqmp-rpu: RPU core_conf: split
    [    8.168430]  r5@0: DMA mask not set
    [    8.171991]  r5@0: assigned reserved memory node rproc@3ed40000
    [    8.178071] remoteproc remoteproc0: r5@0 is available
    [    8.183306]  r5@1: DMA mask not set
    [    8.186830]  r5@1: assigned reserved memory node rproc@3ef40000
    [    8.192874] remoteproc remoteproc1: r5@1 is available
    [    8.653832] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
    [    8.654632] EXT4-fs (mmcblk1p3): INFO: recovery required on readonly filesystem
    [    8.661276] EXT4-fs (mmcblk1p2): write access unavailable, cannot proceed (try mounting with noload)
    [    8.668539] EXT4-fs (mmcblk1p3): write access unavailable, cannot proceed (try mounting with noload)
    [    8.702287] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
    [    8.704602] EXT4-fs (mmcblk1p3): INFO: recovery required on readonly filesystem
    [    8.709628] EXT4-fs (mmcblk1p2): write access unavailable, cannot proceed (try mounting with noload)
    [    8.716928] EXT4-fs (mmcblk1p3): write access unavailable, cannot proceed (try mounting with noload)
    [    9.036171] urandom_read: 4 callbacks suppressed
    [    9.036176] random: dd: uninitialized urandom read (512 bytes read)
    [    9.177804] pps pps0: new PPS source ptp0
    [    9.181869] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered.
    [    9.188569] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   18.388499] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
    [   18.395613] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
    [   20.421902] macb ff0b0000.ethernet eth0: link up (1000/Full)
    [   20.427584] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  • Here is the output of my clk_summary:
    root@frm127101u1r1:~# cat /sys/kernel/debug/clk/clk_summary
     spi1.2-tx_sampl_clk                  1        1        0   491520000          0     0  50000
     spi1.2-obs_sampl_clk                 1        1        0   245760000          0     0  50000
     spi1.2-rx_sampl_clk                  0        0        0   245760000          0     0  50000
     spi1.1-tx_sampl_clk                  1        1        0   491520000          0     0  50000
     spi1.1-obs_sampl_clk                 1        1        0   245760000          0     0  50000
     spi1.0-tx_sampl_clk                  1        1        0   491520000          0     0  50000
     hmc7044_out13_SRO                    0        0        0      768000          0     0  50000
     hmc7044_out12_SCO                    0        0        0   245760000          0     0  50000
     hmc7044_out10_JESD204B2_GBTCLK2       3        3        0   245760000          0     0  50000
        tx2_out_clk                       0        0        0   245760000          0     0  50000
        tx2_gt_clk                        0        0        0     9830400          0     0  50000
        rx2_out_clk                       0        0        0   245760000          0     0  50000
        rx2_gt_clk                        0        0        0     9830400          0     0  50000
        rx2_os_out_clk                    0        0        0   245760000          0     0  50000
        rx2_os_gt_clk                     0        0        0     9830400          0     0  50000
     hmc7044_out8_JESD204B1_GBTCLK        3        3        0   245760000          0     0  50000
        tx1_out_clk                       0        0        0   245760000          0     0  50000
        tx1_gt_clk                        0        0        0     9830400          0     0  50000
        rx1_out_clk                       0        0        0   245760000          0     0  50000
        rx1_gt_clk                        0        0        0     9830400          0     0  50000
        rx1_os_out_clk                    0        0        0   245760000          0     0  50000
        rx1_os_gt_clk                     0        0        0     9830400          0     0  50000
     hmc7044_out7_ADRV9009_0_SYSREF       0        0        0     7680000          0     0  50000
     hmc7044_out6_ADRV9009_0_SYSCLK       1        1        0   245760000          0     0  50000
     hmc7044_out5_ADRV9009_1_SYSREF       0        0        0     7680000          0     0  50000
     hmc7044_out4_ADRV9009_1_SYSCLK       1        1        0   245760000          0     0  50000
     hmc7044_out3_ADRV9009_2_SYSREF       0        0        0     7680000          0     0  50000
     hmc7044_out2_ADRV9009_2_SYSCLK       1        1        0   245760000          0     0  50000
     hmc7044_out1_SOM_SYSREF              0        0        0      768000          0     0  50000
     hmc7044_out0_JESD204B0_GBTCLK        3        3        0   245760000          0     0  50000
        tx0_out_clk                       0        0        0   245760000          0     0  50000
        tx0_gt_clk                        0        0        0     9830400          0     0  50000
        rx0_out_clk                       0        0        0   245760000          0     0  50000
        rx0_gt_clk                        0        0        0     9830400          0     0  50000
        rx0_os_out_clk                    0        0        0   245760000          0     0  50000
        rx0_os_gt_clk                     0        0        0     9830400          0     0  50000
     misc_clk_0                           0        0        0   100000000          0     0  50000
     dp_aclk                              1        1        0   100000000        100     0  50000
     aux_ref_clk                          0        0        0    27000000          0     0  50000
     gt_crx_ref_clk                       0        0        0   108000000          0     0  50000
     pss_alt_ref_clk                      0        0        0           0          0     0  50000
     video_clk                            0        0        0    27000000          0     0  50000
     pss_ref_clk                          3        3        3    33333333          0     0  50000
        vpll_post_src                     0        0        0    33333333          0     0  50000
        vpll_pre_src                      0        0        0    33333333          0     0  50000
           vpll_int                       0        0        0  2999999970          0     0  50000
              vpll_half                   0        0        0  1499999985          0     0  50000
                 vpll_int_mux             0        0        0  1499999985          0     0  50000
                    vpll                  0        0        0  1499999985          0     0  50000
                       dp_video_ref_mux       0        0        0  1499999985          0     0  50000
                          dp_video_ref_div1       0        0        0   299999997          0     0  50000
                             dp_video_ref_div2       0        0        0   299999997          0     0  50000
                                dp_video_ref       0        0        0   299999997          0     0  50000
                       vpll_to_lpd        0        0        0   499999995          0     0  50000
        dpll_post_src                     0        0        0    33333333          0     0  50000
        dpll_pre_src                      0        0        0    33333333          0     0  50000
           dpll_int                       0        0        0  2399999976          0     0  50000
              dpll_half                   0        0        0  1199999988          0     0  50000
                 dpll_int_mux             0        0        0  1199999988          0     0  50000
                    dpll                  0        0        0  1199999988          0     0  50000
                       gpu_ref_mux        0        0        0  1199999988          0     0  50000
                          gpu_ref_div1       0        0        0   599999994          0     0  50000
                             gpu_ref       0        0        0   599999994          0     0  50000
                                gpu_pp1_ref       0        0        0   599999994          0     0  50000
                                gpu_pp0_ref       0        0        0   599999994          0     0  50000
                       sata_ref_mux       0        0        0  1199999988          0     0  50000
                          sata_ref_div1       0        0        0    99999999          0     0  50000
                             sata_ref       0        0        0    99999999          0     0  50000
                       dpll_to_lpd        0        0        0   399999996          0     0  50000
        apll_post_src                     0        0        0    33333333          0     0  50000
        apll_pre_src                      1        1        1    33333333          0     0  50000
           apll_int                       1        1        1  2399999976          0     0  50000
              apll_half                   1        1        1  1199999988          0     0  50000
                 apll_int_mux             1        1        1  1199999988          0     0  50000
                    apll                  1        1        1  1199999988          0     0  50000
                       dpdma_ref_mux       1        1        1  1199999988          0     0  50000
                          dpdma_ref_div1       1        1        1   599999994          0     0  50000
                             dpdma_ref       1        1        1   599999994          0     0  50000
                       gdma_ref_mux       0        0        0  1199999988          0     0  50000
                          gdma_ref_div1       0        0        0   599999994          0     0  50000
                             gdma_ref       0        0        0   599999994          0     0  50000
                       acpu_mux           0        0        0  1199999988          0     0  50000
                          acpu            0        0        0  1199999988          0     0  50000
        rpll_post_src                     0        0        0    33333333          0     0  50000
        rpll_pre_src                      1        1        1    33333333          0     0  50000
           rpll_int                       1        1        1  1523711634          0     0  50000
              rpll_half                   1        1        1   761855817          0     0  50000
                 rpll_int_mux             1        1        1   761855817          0     0  50000
                    rpll                  1        1        1   761855817          0     0  50000
                       rpll_to_fpd        1        1        1    24575995          0     0  50000
                          dp_stc_ref_mux       0        0        0    24575995          0     0  50000
                             dp_stc_ref_div1       0        0        0     1755429          0     0  50000
                                dp_stc_ref_div2       0        0        0     1755429          0     0  50000
                                   dp_stc_ref       0        0        0     1755429          0     0  50000
                          dp_audio_ref_mux       1        1        1    24575995          0     0  50000
                             dp_audio_ref_div1       1        1        1    24575995          0     0  50000
                                dp_audio_ref_div2       1        1        1    24575995          0     0  50000
                                   dp_audio_ref       1        1        1    24575995          0     0  50000
        iopll_post_src                    0        0        0    33333333          0     0  50000
        iopll_pre_src                     1        1        1    33333333          0     0  50000
           iopll_int                      1        1        1  2999999970          0     0  50000
              iopll_half                  1        1        1  1499999985          0     0  50000
                 iopll_int_mux            1        1        1  1499999985          0     0  50000
                    iopll                15       16       10  1499999985          0     0  50000
                       gem3_ref_ung_mux       0        0        0  1499999985          0     0  50000
                          gem3_ref_ung_div1       0        0        0    62500000          0     0  50000
                             gem3_ref_ung       0        0        0    62500000          0     0  50000
                                gem3_ref       0        0        0    62500000          0     0  50000
                                   gem3_tx       0        0        0    62500000          0     0  50000
                       gem2_ref_ung_mux       0        0        0  1499999985          0     0  50000
                          gem2_ref_ung_div1       0        0        0    62500000          0     0  50000
                             gem2_ref_ung       0        0        0    62500000          0     0  50000
                                gem2_ref       0        0        0    62500000          0     0  50000
                                   gem2_tx       0        0        0    62500000          0     0  50000
                       gem1_ref_ung_mux       0        0        0  1499999985          0     0  50000
                          gem1_ref_ung_div1       0        0        0    62500000          0     0  50000
                             gem1_ref_ung       0        0        0    62500000          0     0  50000
                                gem1_ref       0        0        0    62500000          0     0  50000
                                   gem1_tx       0        0        0    62500000          0     0  50000
                       gem0_ref_ung_mux       1        1        0  1499999985          0     0  50000
                          gem0_ref_ung_div1       1        1        0   124999999          0     0  50000
                             gem0_ref_ung       1        1        0   124999999          0     0  50000
                                gem0_ref       2        2        0   124999999          0     0  50000
                                   gem0_tx       1        1        0   124999999          0     0  50000
                       pl3_ref_mux        1        1        0  1499999985          0     0  50000
                          pl3_ref_div1       1        1        0    46875000          0     0  50000
                             pl3_ref_div2       1        1        0     9375000          0     0  50000
                                pl3_ref       1        1        0     9375000          0     0  50000
                       pl2_ref_mux        1        1        0  1499999985          0     0  50000
                          pl2_ref_div1       1        1        0    46875000          0     0  50000
                             pl2_ref_div2       1        1        0     9375000          0     0  50000
                                pl2_ref       1        1        0     9375000          0     0  50000
                       pl1_ref_mux        1        1        0  1499999985          0     0  50000
                          pl1_ref_div1       1        1        0   299999997          0     0  50000
                             pl1_ref_div2       1        1        0   299999997          0     0  50000
                                pl1_ref      10       10        0   299999997          0     0  50000
                       pl0_ref_mux        1        1        0  1499999985          0     0  50000
                          pl0_ref_div1       1        1        0   149999999          0     0  50000
                             pl0_ref_div2       1        1        0   149999999          0     0  50000
                                pl0_ref      10       10        0   149999999          0     0  50000
                       ams_ref_mux        1        1        1  1499999985          0     0  50000
                          ams_ref_div1       1        1        1    50000000          0     0  50000
                             ams_ref_div2       1        1        1    50000000          0     0  50000
                                ams_ref       1        1        1    50000000          0     0  50000
                       adma_ref_mux       0        0        0  1499999985          0     0  50000
                          adma_ref_div1       0        0        0   499999995          0     0  50000
                             adma_ref       0        0        0   499999995          0     0  50000
                       can1_ref_mux       0        0        0  1499999985          0     0  50000
                          can1_ref_div1       0        0        0    46875000          0     0  50000
                             can1_ref_div2       0        0        0    46875000          0     0  50000
                                can1_ref       0        0        0    46875000          0     0  50000
                                   can1       0        0        0    46875000          0     0  50000
                       can0_ref_mux       0        0        0  1499999985          0     0  50000
                          can0_ref_div1       0        0        0    46875000          0     0  50000
                             can0_ref_div2       0        0        0    46875000          0     0  50000
                                can0_ref       0        0        0    46875000          0     0  50000
                                   can0       0        0        0    46875000          0     0  50000
                       i2c1_ref_mux       0        0        0  1499999985          0     0  50000
                          i2c1_ref_div1       0        0        0    99999999          0     0  50000
                             i2c1_ref_div2       0        0        0    99999999          0     0  50000
                                i2c1_ref       0        0        0    99999999          0     0  50000
                       i2c0_ref_mux       0        1        1  1499999985          0     0  50000
                          i2c0_ref_div1       0        1        1    99999999          0     0  50000
                             i2c0_ref_div2       0        1        1    99999999          0     0  50000
                                i2c0_ref       0        1        1    99999999          0     0  50000
                       nand_ref_mux       0        0        0  1499999985          0     0  50000
                          nand_ref_div1       0        0        0    46875000          0     0  50000
                             nand_ref_div2       0        0        0     9375000          0     0  50000
                                nand_ref       0        0        0     9375000          0     0  50000
                       spi1_ref_mux       0        0        0  1499999985          0     0  50000
                          spi1_ref_div1       0        0        0   187499999          0     0  50000
                             spi1_ref_div2       0        0        0   187499999          0     0  50000
                                spi1_ref       0        0        0   187499999          0     0  50000
                       spi0_ref_mux       0        0        0  1499999985          0     0  50000
                          spi0_ref_div1       0        0        0   187499999          0     0  50000
                             spi0_ref_div2       0        0        0   187499999          0     0  50000
                                spi0_ref       0        0        0   187499999          0     0  50000
                       uart1_ref_mux       0        0        0  1499999985          0     0  50000
                          uart1_ref_div1       0        0        0    99999999          0     0  50000
                             uart1_ref_div2       0        0        0    99999999          0     0  50000
                                uart1_ref       0        0        0    99999999          0     0  50000
                       uart0_ref_mux       1        1        1  1499999985          0     0  50000
                          uart0_ref_div1       1        1        1    99999999          0     0  50000
                             uart0_ref_div2       1        1        1    99999999          0     0  50000
                                uart0_ref       1        1        1    99999999          0     0  50000
                       sdio1_ref_mux       1        1        1  1499999985          0     0  50000
                          sdio1_ref_div1       1        1        1    50000000          0     0  50000
                             sdio1_ref_div2       1        1        1    50000000          0     0  50000
                                sdio1_ref       1        1        1    50000000          0     0  50000
                       sdio0_ref_mux       1        1        1  1499999985          0     0  50000
                          sdio0_ref_div1       1        1        1   187499999          0     0  50000
                             sdio0_ref_div2       1        1        1   187499999          0     0  50000
                                sdio0_ref       1        1        1   187499999          0     0  50000
                       qspi_ref_mux       0        0        0  1499999985          0     0  50000
                          qspi_ref_div1       0        0        0    50000000          0     0  50000
                             qspi_ref_div2       0        0        0    50000000          0     0  50000
                                qspi_ref       0        0        0    50000000          0     0  50000
                       gem_tsu_ref_mux       1        1        1  1499999985          0     0  50000
                          gem_tsu_ref_div1       1        1        1   249999998          0     0  50000
                             gem_tsu_ref_div2       1        1        1   249999998          0     0  50000
                                gem_tsu_ref       1        1        1   249999998          0     0  50000
                                   gem_tsu       1        1        0   249999998          0     0  50000
                       usb3_dual_ref_mux       1        1        1  1499999985          0     0  50000
                          usb3_dual_ref_div1       1        1        1    60000000          0     0  50000
                             usb3_dual_ref_div2       1        1        1    20000000          0     0  50000
                                usb3_dual_ref       2        2        2    20000000          0     0  50000
                       usb1_bus_ref_mux       1        1        1  1499999985          0     0  50000
                          usb1_bus_ref_div1       1        1        1   249999998          0     0  50000
                             usb1_bus_ref_div2       1        1        1   249999998          0     0  50000
                                usb1_bus_ref       1        1        1   249999998          0     0  50000
                       usb0_bus_ref_mux       1        1        1  1499999985          0     0  50000
                          usb0_bus_ref_div1       1        1        1   249999998          0     0  50000
                             usb0_bus_ref_div2       1        1        1   249999998          0     0  50000
                                usb0_bus_ref       1        1        1   249999998          0     0  50000
                       lpd_lsbus_mux       1        1        0  1499999985          0     0  50000
                          lpd_lsbus_div1       1        1        0    99999999          0     0  50000
                             lpd_lsbus       7        7        0    99999999          0     0  50000
                                lpd_wdt       0        0        0    99999999          0     0  50000
                       iopll_to_fpd       2        2        1   499999995          0     0  50000
                          topsw_lsbus_mux       1        1        0   499999995          0     0  50000
                             topsw_lsbus_div1       1        1        0    99999999          0     0  50000
                                topsw_lsbus       2        2        0    99999999          0     0  50000
                                   fpd_wdt       0        0        0    99999999          0     0  50000
                          pcie_ref_mux       1        1        1   499999995          0     0  50000
                             pcie_ref_div1       1        1        1   249999998          0     0  50000
                                pcie_ref       1        1        1   249999998          0     0  50000
     can1_mio                             0        0        0           0          0     0  50000
     can0_mio                             0        0        0           0          0     0  50000
     gem3_rx                              0        0        0           0          0     0  50000
     gem2_rx                              0        0        0           0          0     0  50000
     gem1_rx                              0        0        0           0          0     0  50000
     gem0_rx                              1        1        0           0          0     0  50000
