How to configure device tree to use more than one ADRV9009
Hello
I have custom hardware that has three ADRV9009 devices on it. These devices are clocked by an HMC7044. I have confirmed that the HMC7044 is outputting the correct clocks. I am using Vivado 2018.2 to generate the firmware, Petalinux 2018.2 to generate the Linux image and I am using the corresponding version of the ADI kernel.
Up until now I have been testing with the ADRV9009 evaluation platform which only has a single ADRV9009 device on it. I am now trying to get my custom hardware going with two ADRV9009 devices included in the device tree.
If I only have one ADRV9009 included at a time (other two ADRV9009 devices commented out), then I can see that it initialises correctly. This applies to the second ADRV9009 device as well.
However, when I want to include two ADRV9009 devices in the device tree, I can se that the following happens:
1) The first ADRV9009 initialises correctly.
2) The second fails in the probe function at the first devm_clk_get when trying to get the jesd_tx_clk/jesd_rx_clk.
It is almost like the first ADRV9009 grabbed the 'handle' to the jesd_tx_clk/jesd_rx_clk and so the second ADRV9009 can't get access to it.
I thought the solution would be to give each ADRV9009 unique clock names (such as "jesd_rx_clk0" and "jesd_rx_clk1") but then the ADRV9009 IIO device driver can't find any clocks, so clearly this is not the answer.
Please can you tell me how I must modify my device tree so that both ADRV9009 devices can complete their clock intialisation successfully?
Please help! Without this functionality our hardware won't be able to use the two remaining ADRV9009 devices.
Below is a copy of my device tree relating to the two ADRV9009 devices:
        spi@ff040000 {
            compatible = "cdns,spi-r1p6";
            status = "okay";
            is-decoded-cs = <0x0>;
            num-cs = <0x3>;
            trx0_adrv9009: adrv9009-phy@0 {
                compatible = "adrv9009";
                reg = <0>;
                #address-cells = <1>;
                #size-cells = <0>;
                // SPI Setup
                spi-max-frequency = <25000000>;
                reset-gpios = <&gpio 110 0>;
                sysref-req-gpios = <&gpio 111 0>;
                // Clocks
                clocks = <&axi_adrv9009_rx_jesd_0>, <&axi_adrv9009_tx_jesd_0>,
                    <&axi_adrv9009_rx_os_jesd_0>, <&hmc7044 6>, <&hmc7044 0>, <&hmc7044 7>, <&hmc7044 1>;
                clock-names = "jesd_rx_clk", "jesd_tx_clk", "jesd_rx_os_clk", "dev_clk", "fmc_clk", "sysref_dev_clk", "sysref_fmc_clk";
                clock-output-names = "rx_sampl_clk_0", "rx_os_sampl_clk_0", "tx_sampl_clk_0";
                #clock-cells = <1>;
                // JESD204
                // JESD204 RX
                adi,jesd204-framer-a-bank-id = <1>;
                adi,jesd204-framer-a-device-id = <0>;
                adi,jesd204-framer-a-lane0-id = <0>;
                adi,jesd204-framer-a-m = <4>;
                adi,jesd204-framer-a-k = <32>;
                adi,jesd204-framer-a-f = <4>;
                adi,jesd204-framer-a-np = <16>;
                adi,jesd204-framer-a-scramble = <1>;
                adi,jesd204-framer-a-external-sysref = <1>;
                adi,jesd204-framer-a-serializer-lanes-enabled = <0x03>;
                adi,jesd204-framer-a-serializer-lane-crossbar = <0xE4>;
                adi,jesd204-framer-a-lmfc-offset = <31>;
                adi,jesd204-framer-a-new-sysref-on-relink = <0>;
                adi,jesd204-framer-a-syncb-in-select = <0>;
                adi,jesd204-framer-a-over-sample = <0>;
                adi,jesd204-framer-a-syncb-in-lvds-mode = <1>;
                adi,jesd204-framer-a-syncb-in-lvds-pn-invert = <0>;
                adi,jesd204-framer-a-enable-manual-lane-xbar = <0>;
                // JESD204 OBS
                adi,jesd204-framer-b-bank-id = <0>;
                adi,jesd204-framer-b-device-id = <0>;
                adi,jesd204-framer-b-lane0-id = <0>;
                adi,jesd204-framer-b-m = <4>;
                adi,jesd204-framer-b-k = <32>;
                adi,jesd204-framer-b-f = <4>;
                adi,jesd204-framer-b-np = <16>;
                adi,jesd204-framer-b-scramble = <1>;
                adi,jesd204-framer-b-external-sysref = <1>;
                adi,jesd204-framer-b-serializer-lanes-enabled = <0x0C>;
                adi,jesd204-framer-b-serializer-lane-crossbar = <0xE4>;
                adi,jesd204-framer-b-lmfc-offset = <31>;
                adi,jesd204-framer-b-new-sysref-on-relink = <0>;
                adi,jesd204-framer-b-syncb-in-select = <1>;
                adi,jesd204-framer-b-over-sample = <0>;
                adi,jesd204-framer-b-syncb-in-lvds-mode = <1>;
                adi,jesd204-framer-b-syncb-in-lvds-pn-invert = <0>;
                adi,jesd204-framer-b-enable-manual-lane-xbar = <0>;
                // JESD204 TX
                adi,jesd204-deframer-a-bank-id = <0>;
                adi,jesd204-deframer-a-device-id = <0>;
                adi,jesd204-deframer-a-lane0-id = <0>;
                adi,jesd204-deframer-a-m = <4>;
                adi,jesd204-deframer-a-k = <32>;
                adi,jesd204-deframer-a-scramble = <1>;
                adi,jesd204-deframer-a-external-sysref = <1>;
                adi,jesd204-deframer-a-deserializer-lanes-enabled = <0x0F>;
                adi,jesd204-deframer-a-deserializer-lane-crossbar = <0xE4>;
                adi,jesd204-deframer-a-lmfc-offset = <17>;
                adi,jesd204-deframer-a-new-sysref-on-relink = <0>;
                adi,jesd204-deframer-a-syncb-out-select = <0>;
                adi,jesd204-deframer-a-np = <16>;
                adi,jesd204-deframer-a-syncb-out-lvds-mode = <1>;
                adi,jesd204-deframer-a-syncb-out-lvds-pn-invert = <0>;
                adi,jesd204-deframer-a-syncb-out-cmos-slew-rate = <0>;
                adi,jesd204-deframer-a-syncb-out-cmos-drive-level = <0>;
                adi,jesd204-deframer-a-enable-manual-lane-xbar = <0>;
                adi,jesd204-ser-amplitude = <15>;
                adi,jesd204-ser-pre-emphasis = <1>;
                adi,jesd204-ser-invert-lane-polarity = <0>;
                adi,jesd204-des-invert-lane-polarity = <0>;
                adi,jesd204-des-eq-setting = <1>;
                adi,jesd204-sysref-lvds-mode = <1>;
                adi,jesd204-sysref-lvds-pn-invert = <0>;
                // RX
                adi,rx-profile-rx-fir-gain_db = <(-6)>;
                adi,rx-profile-rx-fir-num-fir-coefs = <48>;
                // 245M76Hz adi,rx-profile-rx-fir-coefs = /bits/ 16 <(-2) (23) (46) (-17) (-104) (10) (208) (23) (-370) (-97) (607) (240) (-942) (-489) (1407) (910) (-2065) (-1637) (3058) (2995) (-4912) (-6526) (9941) (30489) (30489) (9941) (-6526) (-4912) (2995) (3058) (-1637) (-2065) (910) (1407) (-489) (-942) (240) (607) (-97) (-370) (23) (208) (10) (-104) (-17) (46) (23) (-2)>;
                adi,rx-profile-rx-fir-coefs = /bits/ 16 <(-6) (-22) (31) (48) (-68) (-107) (141) (201) (-254) (-351) (431) (576) (-691) (-910) (1075) (1410) (-1649) (-2205) (2562) (3613) (-4348) (-7172) (9326) (31134) (31134) (9326) (-7172) (-4348) (3613) (2562) (-2205) (-1649) (1410) (1075) (-910) (-691) (576) (431) (-351) (-254) (201) (141) (-107) (-68) (48) (31) (-22) (-6)>;
                adi,rx-profile-rx-fir-decimation = <2>;
                adi,rx-profile-rx-dec5-decimation = <4>;
                adi,rx-profile-rhb1-decimation = <1>;
                // 245M76Hz adi,rx-profile-rx-output-rate_khz = <245760>;
                adi,rx-profile-rx-output-rate_khz = <208000>;
                // 245M76Hz adi,rx-profile-rf-bandwidth_hz = <200000000>;
                adi,rx-profile-rf-bandwidth_hz = <169000000>;
                // 245M76Hz adi,rx-profile-rx-bbf3d-bcorner_khz = <200000>;
                adi,rx-profile-rx-bbf3d-bcorner_khz = <169000>;
                // 245M76Hz adi,rx-profile-rx-adc-profile = /bits/ 16 <182 142 173 90 1280 982 1335 96 1369 48 1012 18 48 48 37 208 0 0 0 0 52 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                adi,rx-profile-rx-adc-profile = /bits/ 16 <219 166 181 90 1280 940 1322 89 1216 41 857 19 48 42 31 212 0 0 0 0 53 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                adi,rx-profile-rx-ddc-mode = <0>;
                adi,rx-nco-shifter-band-a-input-band-width_khz = <0>;
                adi,rx-nco-shifter-band-a-input-center-freq_khz = <0>;
                adi,rx-nco-shifter-band-a-nco1-freq_khz = <0>;
                adi,rx-nco-shifter-band-a-nco2-freq_khz = <0>;
                adi,rx-nco-shifter-band-binput-band-width_khz = <0>;
                adi,rx-nco-shifter-band-binput-center-freq_khz = <0>;
                adi,rx-nco-shifter-band-bnco1-freq_khz = <0>;
                adi,rx-nco-shifter-band-bnco2-freq_khz = <0>;
                adi,rx-gain-control-gain-mode = <0>;
                adi,rx-gain-control-rx1-gain-index = <255>;
                adi,rx-gain-control-rx2-gain-index = <255>;
                adi,rx-gain-control-rx1-max-gain-index = <255>;
                adi,rx-gain-control-rx1-min-gain-index = <195>;
                adi,rx-gain-control-rx2-max-gain-index = <255>;
                adi,rx-gain-control-rx2-min-gain-index = <195>;
                adi,rx-settings-framer-sel = <0>;
                adi,rx-settings-rx-channels = <3>;
                // ORX
                // 245M76Hz adi,orx-profile-rx-fir-gain_db = <6>;
                adi,orx-profile-rx-fir-gain_db = <(-6)>;
                // 245M76Hz adi,orx-profile-rx-fir-num-fir-coefs = <24>;
                adi,orx-profile-rx-fir-num-fir-coefs = <48>;
                // 245M76Hz adi,orx-profile-rx-fir-coefs = /bits/ 16  <(-10) (7) (-10) (-12) (6) (-12) (16) (-16) (1) (63) (-431) (17235) (-431) (63) (1) (-16) (16) (-12) (6) (-12) (-10) (7) (-10) (0)>;
                adi,orx-profile-rx-fir-coefs = /bits/ 16  <(-7) (-19) (29) (44) (-64) (-98) (118) (152) (-265) (-315) (425) (523) (-672) (-830) (1037) (1289) (-1588) (-2018) (2477) (3327) (-4207) (-6558) (9518) (30464) (30464) (9518) (-6558) (-4207) (3327) (2477) (-2018) (-1588) (1289) (1037) (-830) (-672) (523) (425) (-315) (-265) (152) (118) (-98) (-64) (44) (29) (-19) (-7)>;
                // 245M76Hz adi,orx-profile-rx-fir-decimation = <1>;
                adi,orx-profile-rx-fir-decimation = <2>;
                adi,orx-profile-rx-dec5-decimation = <4>;
                // 245M76Hz adi,orx-profile-rhb1-decimation = <2>;
                adi,orx-profile-rhb1-decimation = <1>;
                // 245M76Hz adi,orx-profile-orx-output-rate_khz = <245760>;
                adi,orx-profile-orx-output-rate_khz = <208000>;
                // 245M76Hz adi,orx-profile-rf-bandwidth_hz = <200000000>;
                adi,orx-profile-rf-bandwidth_hz = <169000000>;
                adi,orx-profile-rx-bbf3d-bcorner_khz = <225000>;
                // 245M76Hz adi,orx-profile-orx-low-pass-adc-profile = /bits/ 16  <185 141 172 90 1280 942 1332 90 1368 46 1016 19 48 48 37 208 0 0 0 0 52 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                adi,orx-profile-orx-low-pass-adc-profile = /bits/ 16  <219 166 181 90 1280 940 1322 89 1216 41 857 19 48 42 31 212 0 0 0 0 53 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                // 245M76Hz adi,orx-profile-orx-band-pass-adc-profile = /bits/ 16  <0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0>;
                adi,orx-profile-orx-band-pass-adc-profile = /bits/ 16  <219 166 181 90 1280 940 1322 89 1216 41 857 19 48 42 31 212 0 0 0 0 53 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                adi,orx-profile-orx-ddc-mode = <0>;
                adi,orx-profile-orx-merge-filter = /bits/ 16  <0 0 0 0 0 0 0 0 0 0 0 0>;
                adi,orx-gain-control-gain-mode = <0>;
                adi,orx-gain-control-orx1-gain-index = <255>;
                adi,orx-gain-control-orx2-gain-index = <255>;
                adi,orx-gain-control-orx1-max-gain-index = <255>;
                adi,orx-gain-control-orx1-min-gain-index = <195>;
                adi,orx-gain-control-orx2-max-gain-index = <255>;
                adi,orx-gain-control-orx2-min-gain-index = <195>;
                adi,obs-settings-framer-sel = <1>;
                adi,obs-settings-obs-rx-channels-enable = <3>;
                adi,obs-settings-obs-rx-lo-source = <0>;
                // TX
                // 245M76Hz adi,tx-profile-tx-fir-gain_db = <6>;
                adi,tx-profile-tx-fir-gain_db = <0>;
                // 245M76Hz adi,tx-profile-tx-fir-num-fir-coefs = <40>;
                adi,tx-profile-tx-fir-num-fir-coefs = <20>;
                // 245M76Hz adi,tx-profile-tx-fir-coefs = /bits/ 16  <(-14) (5) (-9) (6) (-4) (19) (-29) (27) (-30) (46) (-63) (77) (-103) (150) (-218) (337) (-599) (1266) (-2718) (19537) (-2718) (1266) (-599) (337) (-218) (150) (-103) (77) (-63) (46) (-30) (27) (-29) (19) (-4) (6) (-9) (5) (-14) (0)>;
                adi,tx-profile-tx-fir-coefs = /bits/ 16  <(31) (-73) (118) (-151) (164) (-108) (-147) (1002) (-2864) (19887) (-2864) (1002) (-147) (-108) (164) (-151) (118) (-73) (31) (0)>;
                adi,tx-profile-dac-div = <1>;
                adi,tx-profile-tx-fir-interpolation = <1>;
                adi,tx-profile-thb1-interpolation = <2>;
                adi,tx-profile-thb2-interpolation = <2>;
                adi,tx-profile-thb3-interpolation = <2>;
                adi,tx-profile-tx-int5-interpolation = <1>;
                // 245M76Hz adi,tx-profile-tx-input-rate_khz = <245760>;
                adi,tx-profile-tx-input-rate_khz = <208000>;
                // 245M76Hz adi,tx-profile-primary-sig-bandwidth_hz = <100000000>;
                adi,tx-profile-primary-sig-bandwidth_hz = <63000000>;
                // 245M76Hz adi,tx-profile-rf-bandwidth_hz = <225000000>;
                adi,tx-profile-rf-bandwidth_hz = <169000000>;
                // 245M76Hz adi,tx-profile-tx-dac3d-bcorner_khz = <225000>;
                adi,tx-profile-tx-dac3d-bcorner_khz = <187000>;
                // 245M76Hz adi,tx-profile-tx-bbf3d-bcorner_khz = <113000>;
                adi,tx-profile-tx-bbf3d-bcorner_khz = <84500>;
                adi,tx-profile-loop-back-adc-profile = /bits/ 16 <206 132 168 90 1280 641 1307 53 1359 28 1039 30 48 48 37 210 0 0 0 0 53 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                adi,tx-settings-deframer-sel = <0>;
                adi,tx-settings-tx-channels = <3>;
                adi,tx-settings-tx-atten-step-size = <0>;
                adi,tx-settings-tx1-atten_md-b = <10000>;
                adi,tx-settings-tx2-atten_md-b = <10000>;
                adi,tx-settings-dis-tx-data-if-pll-unlock = <0>;
                // Clocks
                // 245M76Hz adi,dig-clocks-device-clock_khz = <245760>;
                adi,dig-clocks-device-clock_khz = <208000>;
                // 245M76Hz adi,dig-clocks-clk-pll-vco-freq_khz = <9830400>;
                adi,dig-clocks-clk-pll-vco-freq_khz = <8320000>;
                adi,dig-clocks-clk-pll-hs-div = <1>;
                adi,dig-clocks-rf-pll-use-external-lo = <0>;
                adi,dig-clocks-rf-pll-phase-sync-mode = <0>;
                // AGC
                adi,rxagc-peak-agc-under-range-low-interval_ns = <205>;
                adi,rxagc-peak-agc-under-range-mid-interval = <2>;
                adi,rxagc-peak-agc-under-range-high-interval = <4>;
                adi,rxagc-peak-apd-high-thresh = <39>;
                adi,rxagc-peak-apd-low-gain-mode-high-thresh = <36>;
                adi,rxagc-peak-apd-low-thresh = <23>;
                adi,rxagc-peak-apd-low-gain-mode-low-thresh = <19>;
                adi,rxagc-peak-apd-upper-thresh-peak-exceeded-cnt = <6>;
                adi,rxagc-peak-apd-lower-thresh-peak-exceeded-cnt = <3>;
                adi,rxagc-peak-apd-gain-step-attack = <4>;
                adi,rxagc-peak-apd-gain-step-recovery = <2>;
                adi,rxagc-peak-enable-hb2-overload = <1>;
                adi,rxagc-peak-hb2-overload-duration-cnt = <1>;
                adi,rxagc-peak-hb2-overload-thresh-cnt = <4>;
                adi,rxagc-peak-hb2-high-thresh = <181>;
                adi,rxagc-peak-hb2-under-range-low-thresh = <45>;
                adi,rxagc-peak-hb2-under-range-mid-thresh = <90>;
                adi,rxagc-peak-hb2-under-range-high-thresh = <128>;
                adi,rxagc-peak-hb2-upper-thresh-peak-exceeded-cnt = <6>;
                adi,rxagc-peak-hb2-lower-thresh-peak-exceeded-cnt = <3>;
                adi,rxagc-peak-hb2-gain-step-high-recovery = <2>;
                adi,rxagc-peak-hb2-gain-step-low-recovery = <4>;
                adi,rxagc-peak-hb2-gain-step-mid-recovery = <8>;
                adi,rxagc-peak-hb2-gain-step-attack = <4>;
                adi,rxagc-peak-hb2-overload-power-mode = <1>;
                adi,rxagc-peak-hb2-ovrg-sel = <0>;
                adi,rxagc-peak-hb2-thresh-config = <3>;
                adi,rxagc-power-power-enable-measurement = <1>;
                adi,rxagc-power-power-use-rfir-out = <1>;
                adi,rxagc-power-power-use-bbdc2 = <0>;
                adi,rxagc-power-under-range-high-power-thresh = <9>;
                adi,rxagc-power-under-range-low-power-thresh = <2>;
                adi,rxagc-power-under-range-high-power-gain-step-recovery = <4>;
                adi,rxagc-power-under-range-low-power-gain-step-recovery = <4>;
                adi,rxagc-power-power-measurement-duration = <5>;
                adi,rxagc-power-rx1-tdd-power-meas-duration = <5>;
                adi,rxagc-power-rx1-tdd-power-meas-delay = <1>;
                adi,rxagc-power-rx2-tdd-power-meas-duration = <5>;
                adi,rxagc-power-rx2-tdd-power-meas-delay = <1>;
                adi,rxagc-power-upper0-power-thresh = <2>;
                adi,rxagc-power-upper1-power-thresh = <0>;
                adi,rxagc-power-power-log-shift = <0>;
                adi,rxagc-agc-peak-wait-time = <4>;
                adi,rxagc-agc-rx1-max-gain-index = <255>;
                adi,rxagc-agc-rx1-min-gain-index = <195>;
                adi,rxagc-agc-rx2-max-gain-index = <255>;
                adi,rxagc-agc-rx2-min-gain-index = <195>;
                adi,rxagc-agc-gain-update-counter_us = <250>;
                adi,rxagc-agc-rx1-attack-delay = <10>;
                adi,rxagc-agc-rx2-attack-delay = <10>;
                adi,rxagc-agc-slow-loop-settling-delay = <16>;
                adi,rxagc-agc-low-thresh-prevent-gain = <0>;
                adi,rxagc-agc-change-gain-if-thresh-high = <1>;
                adi,rxagc-agc-peak-thresh-gain-control-mode = <1>;
                adi,rxagc-agc-reset-on-rxon = <0>;
                adi,rxagc-agc-enable-sync-pulse-for-gain-counter = <0>;
                adi,rxagc-agc-enable-ip3-optimization-thresh = <0>;
                adi,rxagc-ip3-over-range-thresh = <31>;
                adi,rxagc-ip3-over-range-thresh-index = <246>;
                adi,rxagc-ip3-peak-exceeded-cnt = <4>;
                adi,rxagc-agc-enable-fast-recovery-loop = <0>;
                // Misc
                adi,aux-dac-enables = <0x00>; // Mask
                adi,aux-dac-vref0 = <3>;
                adi,aux-dac-resolution0 = <0>;
                adi,aux-dac-values0 = <0>;
                adi,aux-dac-vref1 = <3>;
                adi,aux-dac-resolution1 = <0>;
                adi,aux-dac-values1 = <0>;
                adi,aux-dac-vref2 = <3>;
                adi,aux-dac-resolution2 = <0>;
                adi,aux-dac-values2 = <0>;
                adi,aux-dac-vref3 = <3>;
                adi,aux-dac-resolution3 = <0>;
                adi,aux-dac-values3 = <0>;
                adi,aux-dac-vref4 = <3>;
                adi,aux-dac-resolution4 = <0>;
                adi,aux-dac-values4 = <0>;
                adi,aux-dac-vref5 = <3>;
                adi,aux-dac-resolution5 = <0>;
                adi,aux-dac-values5 = <0>;
                adi,aux-dac-vref6 = <3>;
                adi,aux-dac-resolution6 = <0>;
                adi,aux-dac-values6 = <0>;
                adi,aux-dac-vref7 = <3>;
                adi,aux-dac-resolution7 = <0>;
                adi,aux-dac-values7 = <0>;
                adi,aux-dac-vref8 = <3>;
                adi,aux-dac-resolution8 = <0>;
                adi,aux-dac-values8 = <0>;
                adi,aux-dac-vref9 = <3>;
                adi,aux-dac-resolution9 = <0>;
                adi,aux-dac-values9 = <0>;
                adi,aux-dac-vref10 = <3>;
                adi,aux-dac-resolution10 = <0>;
                adi,aux-dac-values10 = <0>;
                adi,aux-dac-vref11 = <3>;
                adi,aux-dac-resolution11 = <0>;
                adi,aux-dac-values11 = <0>;
                adi,arm-gpio-config-orx1-tx-sel0-pin-gpio-pin-sel = <0>;
                adi,arm-gpio-config-orx1-tx-sel0-pin-polarity = <0>;
                adi,arm-gpio-config-orx1-tx-sel0-pin-enable = <0>;
                adi,arm-gpio-config-orx1-tx-sel1-pin-gpio-pin-sel = <0>;
                adi,arm-gpio-config-orx1-tx-sel1-pin-polarity = <0>;
                adi,arm-gpio-config-orx1-tx-sel1-pin-enable = <0>;
                adi,arm-gpio-config-orx2-tx-sel0-pin-gpio-pin-sel = <0>;
                adi,arm-gpio-config-orx2-tx-sel0-pin-polarity = <0>;
                adi,arm-gpio-config-orx2-tx-sel0-pin-enable = <0>;
                adi,arm-gpio-config-orx2-tx-sel1-pin-gpio-pin-sel = <0>;
                adi,arm-gpio-config-orx2-tx-sel1-pin-polarity = <0>;
                adi,arm-gpio-config-orx2-tx-sel1-pin-enable = <0>;
                adi,arm-gpio-config-en-tx-tracking-cals-gpio-pin-sel = <0>;
                adi,arm-gpio-config-en-tx-tracking-cals-polarity = <0>;
                adi,arm-gpio-config-en-tx-tracking-cals-enable = <0>;
                adi,orx-lo-cfg-disable-aux-pll-relocking = <0>;
                adi,orx-lo-cfg-gpio-select = <19>;
                adi,fhm-config-fhm-gpio-pin = <0>;
                adi,fhm-config-fhm-min-freq_mhz = <2400>;
                adi,fhm-config-fhm-max-freq_mhz = <2500>;
                adi,fhm-mode-fhm-enable = <0>;
                adi,fhm-mode-enable-mcs-sync = <0>;
                adi,fhm-mode-fhm-trigger-mode = <0>;
                adi,fhm-mode-fhm-exit-mode = <1>;
                adi,fhm-mode-fhm-init-frequency_hz = <2450000000>;
                adi,rx1-gain-ctrl-pin-inc-step = <1>;
                adi,rx1-gain-ctrl-pin-dec-step = <1>;
                adi,rx1-gain-ctrl-pin-rx-gain-inc-pin = <0>;
                adi,rx1-gain-ctrl-pin-rx-gain-dec-pin = <1>;
                adi,rx1-gain-ctrl-pin-enable = <0>;
                adi,rx2-gain-ctrl-pin-inc-step = <1>;
                adi,rx2-gain-ctrl-pin-dec-step = <1>;
                adi,rx2-gain-ctrl-pin-rx-gain-inc-pin = <3>;
                adi,rx2-gain-ctrl-pin-rx-gain-dec-pin = <4>;
                adi,rx2-gain-ctrl-pin-enable = <0>;
                adi,tx1-atten-ctrl-pin-step-size = <0>;
                adi,tx1-atten-ctrl-pin-tx-atten-inc-pin = <4>;
                adi,tx1-atten-ctrl-pin-tx-atten-dec-pin = <5>;
                adi,tx1-atten-ctrl-pin-enable = <0>;
                adi,tx2-atten-ctrl-pin-step-size = <0>;
                adi,tx2-atten-ctrl-pin-tx-atten-inc-pin = <6>;
                adi,tx2-atten-ctrl-pin-tx-atten-dec-pin = <7>;
                adi,tx2-atten-ctrl-pin-enable = <0>;
                adi,tx-pa-protection-avg-duration = <3>;
                adi,tx-pa-protection-tx-atten-step = <2>;
                adi,tx-pa-protection-tx1-power-threshold = <4096>;
                adi,tx-pa-protection-tx2-power-threshold = <4096>;
                adi,tx-pa-protection-peak-count = <4>;
                adi,tx-pa-protection-tx1-peak-threshold = <140>;
                adi,tx-pa-protection-tx2-peak-threshold = <140>;
            trx1_adrv9009: adrv9009-phy-b@1 {
                reg = <1>;
                #size-cells = <0>;
                // SPI Setup
                // Clocks
                clocks = <&axi_adrv9009_rx_jesd_1>, <&axi_adrv9009_tx_jesd_1>,
                    <&axi_adrv9009_rx_os_jesd_1>, <&hmc7044 4>, <&hmc7044 8>, <&hmc7044 5>, <&hmc7044 1>;
                clock-output-names = "rx_sampl_clk_1", "rx_os_sampl_clk_1", "tx_sampl_clk_1";
                #clock-cells = <1>;
                // JESD204
                // JESD204 RX
                // JESD204 OBS
                // JESD204 TX
                // RX
                // ORX
                // TX
                // Clocks
                // AGC
                // Misc
            trx2_adrv9009: adrv9009-phy-c@2 {
                reg = <2>;
                #size-cells = <0>;
                // SPI Setup
                // Clocks
                clocks = <&axi_adrv9009_rx_jesd_2>, <&axi_adrv9009_tx_jesd_2>,
                    <&axi_adrv9009_rx_os_jesd_2>, <&hmc7044 2>, <&hmc7044 10>, <&hmc7044 3>, <&hmc7044 1>;
                clock-output-names = "rx_sampl_clk_2", "rx_os_sampl_clk_2", "tx_sampl_clk_2";
                #clock-cells = <1>;
                // JESD204
                // JESD204 RX
                // JESD204 OBS
                // JESD204 TX
                // RX
                // ORX
                // TX
                // Clocks
                // AGC
                // Misc
        spi@ff050000 {
            status = "okay";
            num-cs = <0x1>;
            hmc7044: hmc7044@0 {
                #size-cells = <0>;
                #clock-cells = <1>;
                compatible = "adi,hmc7044";
                reg = <0>;
                spi-max-frequency = <10000000>;
                // 245M76Hz adi,pll1-clkin-frequencies = <0 0 0 122880000>;
                adi,pll1-clkin-frequencies = <0 0 0 10000000>;
                adi,pll1-ref-prio-ctrl = <0xFF>; // prefer CLKIN3
                adi,clkin0-buffer-mode  = <0x07>;
                adi,clkin1-buffer-mode  = <0x07>;
                adi,clkin2-buffer-mode  = <0x10>;
                adi,clkin3-buffer-mode  = <0x07>;
                adi,sync-pin-mode = <2>; // PULSE GENERATOR MODE
                // 245M76Hz adi,pll1-loop-bandwidth-hz = <30>;
                adi,pll1-loop-bandwidth-hz = <36>;
                // 245M76Hz adi,vcxo-frequency = <122880000>;
                adi,vcxo-frequency = <100000000>;
                // 245M76Hz adi,pll2-output-frequency = <2949120000>;
                adi,pll2-output-frequency = <2496000000>;
                adi,sysref-timer-divider = <3840>;
                adi,pulse-generator-mode = <0>; // LEVEL SENSITIVE
                adi,oscin-buffer-mode = <0x07>;
                adi,gpi-controls = <0x00 0x00 0x00 0x00>;
                adi,gpo-controls = <0x20 0x20 0x20 0x20>;
                adi,high-performance-mode-clock-dist-enable; // NOT USED
                adi,high-performance-mode-pll-vco-enable; // NOT USED
                    "hmc7044_out0_JESD204B0_GBTCLK", "hmc7044_out1_SOM_SYSREF",
                    "hmc7044_out2_ADRV9009_2_SYSCLK", "hmc7044_out3_ADRV9009_2_SYSREF",
                    "hmc7044_out4_ADRV9009_1_SYSCLK", "hmc7044_out5_ADRV9009_1_SYSREF",
                    "hmc7044_out6_ADRV9009_0_SYSCLK", "hmc7044_out7_ADRV9009_0_SYSREF",
                    "hmc7044_out8_JESD204B1_GBTCLK","hmc7044_out9",
                    "hmc7044_out10_JESD204B2_GBTCLK2", "hmc7044_out11",
                    "hmc7044_out12_SCO", "hmc7044_out13_SRO";
                hmc7044_c0: channel@0 {
                    reg = <0>;
                    adi,extended-name = "JESD204B0_GBTCLK";
                    // 245M76Hz adi,divider = <12>;    // 245760000
                    adi,divider = <12>;    // 208000000
                    adi,driver-mode = <2>;    // LVDS
                hmc7044_c1: channel@1 {
                    reg = <1>;
                    adi,extended-name = "SOM_SYSREF";
                    // 245M76Hz adi,divider = <3840>;    // 768000
                    adi,divider = <3840>;    // 650000
                    adi,high-performance-mode-disable;
                hmc7044_c2: channel@2 {
                    reg = <2>;
                    adi,extended-name = "ADRV9009_2_SYSCLK";
                    adi,driver-mode = <1>;    // LVPECL
                hmc7044_c3: channel@3 {
                    reg = <3>;
                    adi,extended-name = "ADRV9009_2_SYSREF";
                    adi,startup-mode-dynamic-enable;
                hmc7044_c4: channel@4 {
                    reg = <4>;
                    adi,extended-name = "ADRV9009_1_SYSCLK";
                hmc7044_c5: channel@5 {
                    reg = <5>;
                    adi,extended-name = "ADRV9009_1_SYSREF";
                hmc7044_c6: channel@6 {
                    reg = <6>;
                    adi,extended-name = "ADRV9009_0_SYSCLK";
                hmc7044_c7: channel@7 {
                    reg = <7>;
                    adi,extended-name = "ADRV9009_0_SYSREF";
                hmc7044_c8: channel@8 {
                    reg = <8>;
                    adi,extended-name = "JESD204B1_GBTCLK";
                hmc7044_c10: channel@10 {
                    reg = <10>;
                    adi,extended-name = "JESD204B2_GBTCLK2";
                hmc7044_c12: channel@12 {
                    reg = <12>;
                    adi,extended-name = "SCO";
                hmc7044_c13: channel@13 {
                    reg = <13>;
                    adi,extended-name = "SRO";
                    // 245M76Hz adi,divider = <3840>;    // 650000
Top Replies
    May 4, 2021 in reply to gavint +1 verified
    Is there a way to disable the ADRV9009 SYSREF internal 100R termination via the device tree? I can only see a "adi,jesd204-sysref-lvds-mode" which controls whether it is an LVDS or CMOS input…
Parents
    on Apr 16, 2021 11:33 AM
    Can you paste here the contents of:
    /sys/kernel/debug/clk/clk_summary
    Alexandru
  •    clock                         enable_cnt  prepare_cnt        rate   accuracy   phase
     spi1.0-tx_sampl_clk                      1            1   208000000          0 0
     spi1.0-obs_sampl_clk                     1            1   208000000          0 0
     spi1.0-rx_sampl_clk                      0            0   208000000          0 0
     hmc7044_out13_SRO                        0            0      650000          0 0
     hmc7044_out12_SCO                        0            0   208000000          0 0
     hmc7044_out10_JESD204B2_GBTCLK2           3            3   208000000          0 0
     hmc7044_out8_JESD204B1_GBTCLK            3            3   208000000          0 0
     hmc7044_out7_ADRV9009_0_SYSREF           0            0      650000          0 0
     hmc7044_out6_ADRV9009_0_SYSCLK           1            1   208000000          0 0
     hmc7044_out5_ADRV9009_1_SYSREF           0            0      650000          0 0
     hmc7044_out4_ADRV9009_1_SYSCLK           0            0   208000000          0 0
     hmc7044_out3_ADRV9009_2_SYSREF           0            0      650000          0 0
     hmc7044_out2_ADRV9009_2_SYSCLK           0            0   208000000          0 0
     hmc7044_out1_SOM_SYSREF                  0            0      650000          0 0
     hmc7044_out0_JESD204B0_GBTCLK            7            7   208000000          0 0
        tx_out_clk                            0            0   208000000          0 0
        tx_gt_clk                             1            1     4160000          0 0
           jesd_tx_lane_clk                   1            1     4160000          0 0
        rx_out_clk                            0            0   208000000          0 0
        rx_gt_clk                             1            1     8320000          0 0
           jesd_rx_lane_clk                   1            1     8320000          0 0
        rx_os_out_clk                         0            0   208000000          0 0
        rx_os_gt_clk                          1            1     8320000          0 0
           jesd_rx_os_lane_clk                1            1     8320000          0 0
     dp_aclk                                  1            1   100000000        100 0
     aux_ref_clk                              0            0    27000000          0 0
     gt_crx_ref_clk                           0            0   108000000          0 0
     pss_alt_ref_clk                          0            0           0          0 0
     video_clk                                0            0    27000000          0 0
     pss_ref_clk                              4            4    33333333          0 0
        vpll_post_src                         0            0    33333333          0 0
        vpll_pre_src                          0            0    33333333          0 0
           vpll_int                           0            0  2999999970          0 0
              vpll_half                       0            0  1499999985          0 0
                 vpll_int_mux                 0            0  1499999985          0 0
                    vpll                      0            0  1499999985          0 0
                       dp_video_ref_mux           0            0  1499999985          0 0
                          dp_video_ref_div1           0            0   299999997          0 0
                             dp_video_ref_div2           0            0   299999997          0 0
                                dp_video_ref           0            0   299999997          0 0
                       vpll_to_lpd            0            0   499999995          0 0
        dpll_post_src                         0            0    33333333          0 0
        dpll_pre_src                          1            1    33333333          0 0
           dpll_int                           1            1  2399999976          0 0
              dpll_half                       1            1  1199999988          0 0
                 dpll_int_mux                 1            1  1199999988          0 0
                    dpll                      1            1  1199999988          0 0
                       topsw_main_mux           0            0  1199999988          0 0
                          topsw_main_div1           0            0   399999996          0 0
                             topsw_main           0            0   399999996          0 0
                       gpu_ref_mux            0            0  1199999988          0 0
                          gpu_ref_div1           0            0   599999994          0 0
                             gpu_ref           0            0   599999994          0 0
                                gpu_pp1_ref           0            0   599999994          0 0
                                gpu_pp0_ref           0            0   599999994          0 0
                       sata_ref_mux           0            0  1199999988          0 0
                          sata_ref_div1           0            0    99999999          0 0
                             sata_ref           0            0    99999999          0 0
                       ddr_ref_mux            1            1  1199999988          0 0
                          ddr_ref             1            1   599999994          0 0
                       dpll_to_lpd            0            0   399999996          0 0
        apll_post_src                         0            0    33333333          0 0
        apll_pre_src                          1            1    33333333          0 0
           apll_int                           1            1  2399999976          0 0
              apll_half                       1            1  1199999988          0 0
                 apll_int_mux                 1            1  1199999988          0 0
                    apll                      2            2  1199999988          0 0
                       dpdma_ref_mux           1            1  1199999988          0 0
                          dpdma_ref_div1           1            1   599999994          0 0
                             dpdma_ref           1            1   599999994          0 0
                       gdma_ref_mux           0            0  1199999988          0 0
                          gdma_ref_div1           0            0   599999994          0 0
                             gdma_ref           0            0   599999994          0 0
                       acpu_mux               1            1  1199999988          0 0
                          acpu_div1           1            1  1199999988          0 0
                             acpu             1            1  1199999988          0 0
                                acpu_half_ff           0            0   599999994          0 0
                                   acpu_half           0            0   599999994          0 0
                       apll_to_lpd            0            0   399999996          0 0
        rpll_post_src                         0            0    33333333          0 0
        rpll_pre_src                          1            1    33333333          0 0
           rpll_int                           1            1  1523711634          0 0
              rpll_half                       1            1   761855817          0 0
                 rpll_int_mux                 1            1   761855817          0 0
                    rpll                      1            1   761855817          0 0
                       rpll_to_fpd            1            1    24575995          0 0
                          dp_stc_ref_mux           0            0    24575995          0 0
                             dp_stc_ref_div1           0            0     1755429          0 0
                                dp_stc_ref_div2           0            0     1755429          0 0
                                   dp_stc_ref           0            0     1755429          0 0
                          dp_audio_ref_mux           1            1    24575995          0 0
                             dp_audio_ref_div1           1            1    24575995          0 0
                                dp_audio_ref_div2           1            1    24575995          0 0
                                   dp_audio_ref           1            1    24575995          0 0
        iopll_post_src                        0            0    33333333          0 0
        iopll_pre_src                         1            1    33333333          0 0
           iopll_int                          1            1  2999999970          0 0
              iopll_half                      1            1  1499999985          0 0
                 iopll_int_mux                1            1  1499999985          0 0
                    iopll                    13           14  1499999985          0 0
                       pl3_ref_mux            0            0  1499999985          0 0
                          pl3_ref_div1           0            0    46875000          0 0
                             pl3_ref_div2           0            0     9375000          0 0
                                pl3_ref           0            0     9375000          0 0
                       pl2_ref_mux            0            0  1499999985          0 0
                          pl2_ref_div1           0            0    46875000          0 0
                             pl2_ref_div2           0            0     9375000          0 0
                                pl2_ref           0            0     9375000          0 0
                       pl1_ref_mux            1            1  1499999985          0 0
                          pl1_ref_div1           1            1   299999997          0 0
                             pl1_ref_div2           1            1   299999997          0 0
                                pl1_ref           9            9   299999997          0 0
                       pl0_ref_mux            1            1  1499999985          0 0
                          pl0_ref_div1           1            1   149999999          0 0
                             pl0_ref_div2           1            1   149999999          0 0
                                pl0_ref           3            3   149999999          0 0
                       ams_ref_mux            1            1  1499999985          0 0
                          ams_ref_div1           1            1    50000000          0 0
                             ams_ref_div2           1            1    50000000          0 0
                                ams_ref           1            1    50000000          0 0
                       timestamp_ref_mux           0            0  1499999985          0 0
                          timestamp_ref_div1           0            0    99999999          0 0
                             timestamp_ref           0            0    99999999          0 0
                       adma_ref_mux           0            0  1499999985          0 0
                          adma_ref_div1           0            0   499999995          0 0
                             adma_ref           0            0   499999995          0 0
                       dll_ref                0            0  1499999985          0 0
                       can1_ref_mux           0            0  1499999985          0 0
                          can1_ref_div1           0            0    46875000          0 0
                             can1_ref_div2           0            0    46875000          0 0
                                can1_ref           0            0    46875000          0 0
                                   can1           0            0    46875000          0 0
                       can0_ref_mux           0            0  1499999985          0 0
                          can0_ref_div1           0            0    46875000          0 0
                             can0_ref_div2           0            0    46875000          0 0
                                can0_ref           0            0    46875000          0 0
                                   can0           0            0    46875000          0 0
                       i2c1_ref_mux           0            0  1499999985          0 0
                          i2c1_ref_div1           0            0    99999999          0 0
                             i2c1_ref_div2           0            0    99999999          0 0
                                i2c1_ref           0            0    99999999          0 0
                       i2c0_ref_mux           0            1  1499999985          0 0
                          i2c0_ref_div1           0            1    99999999          0 0
                             i2c0_ref_div2           0            1    99999999          0 0
                                i2c0_ref           0            1    99999999          0 0
                       nand_ref_mux           0            0  1499999985          0 0
                          nand_ref_div1           0            0    46875000          0 0
                             nand_ref_div2           0            0     9375000          0 0
                                nand_ref           0            0     9375000          0 0
                       spi1_ref_mux           0            0  1499999985          0 0
                          spi1_ref_div1           0            0   187499999          0 0
                             spi1_ref_div2           0            0   187499999          0 0
                                spi1_ref           0            0   187499999          0 0
                       spi0_ref_mux           0            0  1499999985          0 0
                          spi0_ref_div1           0            0   187499999          0 0
                             spi0_ref_div2           0            0   187499999          0 0
                                spi0_ref           0            0   187499999          0 0
                       uart1_ref_mux           0            0  1499999985          0 0
                          uart1_ref_div1           0            0    99999999          0 0
                             uart1_ref_div2           0            0    99999999          0 0
                                uart1_ref           0            0    99999999          0 0
                       uart0_ref_mux           1            1  1499999985          0 0
                          uart0_ref_div1           1            1    99999999          0 0
                             uart0_ref_div2           1            1    99999999          0 0
                                uart0_ref           1            1    99999999          0 0
                       sdio1_ref_mux           1            1  1499999985          0 0
                          sdio1_ref_div1           1            1    50000000          0 0
                             sdio1_ref_div2           1            1    50000000          0 0
                                sdio1_ref           1            1    50000000          0 0
                       sdio0_ref_mux           1            1  1499999985          0 0
                          sdio0_ref_div1           1            1   187499999          0 0
                             sdio0_ref_div2           1            1   187499999          0 0
                                sdio0_ref           1            1   187499999          0 0
                       qspi_ref_mux           0            0  1499999985          0 0
                          qspi_ref_div1           0            0    50000000          0 0
                             qspi_ref_div2           0            0    50000000          0 0
                                qspi_ref           0            0    50000000          0 0
                       gem3_ref_mux           0            0  1499999985          0 0
                          gem3_ref_div1           0            0    62500000          0 0
                             gem3_ref_div2           0            0    62500000          0 0
                                gem3_ref           0            0    62500000          0 0
                                   gem3_tx_mux           0            0    62500000          0 0
                                      gem3_tx           0            0    62500000          0 0
                       gem2_ref_mux           0            0  1499999985          0 0
                          gem2_ref_div1           0            0    62500000          0 0
                             gem2_ref_div2           0            0    62500000          0 0
                                gem2_ref           0            0    62500000          0 0
                                   gem2_tx_mux           0            0    62500000          0 0
                                      gem2_tx           0            0    62500000          0 0
                       gem1_ref_mux           0            0  1499999985          0 0
                          gem1_ref_div1           0            0    62500000          0 0
                             gem1_ref_div2           0            0    62500000          0 0
                                gem1_ref           0            0    62500000          0 0
                                   gem1_tx_mux           0            0    62500000          0 0
                                      gem1_tx           0            0    62500000          0 0
                       gem0_ref_mux           1            1  1499999985          0 0
                          gem0_ref_div1           1            1   124999999          0 0
                             gem0_ref_div2           1            1   124999999          0 0
                                gem0_ref           2            2   124999999          0 0
                                   gem0_tx_mux           1            1   124999999          0 0
                                      gem0_tx           2            2   124999999          0 0
                       gem_tsu_ref_mux           1            1  1499999985          0 0
                          gem_tsu_ref_div1           1            1   249999998          0 0
                             gem_tsu_ref_div2           1            1   249999998          0 0
                                gem_tsu_ref           1            1   249999998          0 0
                                   gem_tsu           1            1   249999998          0 0
                       iou_switch_mux           0            0  1499999985          0 0
                          iou_switch_div1           0            0   249999998          0 0
                             iou_switch           0            0   249999998          0 0
                       pcap_mux               0            0  1499999985          0 0
                          pcap_div1           0            0   187499999          0 0
                             pcap             0            0   187499999          0 0
                       csu_pll_mux            0            0  1499999985          0 0
                          csu_pll_div1           0            0   187499999          0 0
                             csu_pll           0            0   187499999          0 0
                       cpu_r5_mux             0            0  1499999985          0 0
                          cpu_r5_div1           0            0   499999995          0 0
                             cpu_r5           0            0   499999995          0 0
                                cpu_r5_core           0            0   499999995          0 0
                       usb3_dual_ref_mux           1            1  1499999985          0 0
                          usb3_dual_ref_div1           1            1    60000000          0 0
                             usb3_dual_ref_div2           1            1    20000000          0 0
                                usb3_dual_ref           2            2    20000000          0 0
                       usb1_bus_ref_mux           1            1  1499999985          0 0
                          usb1_bus_ref_div1           1            1   249999998          0 0
                             usb1_bus_ref_div2           1            1   249999998          0 0
                                usb1_bus_ref           1            1   249999998          0 0
                       usb0_bus_ref_mux           1            1  1499999985          0 0
                          usb0_bus_ref_div1           1            1   249999998          0 0
                             usb0_bus_ref_div2           1            1   249999998          0 0
                                usb0_bus_ref           1            1   249999998          0 0
                       lpd_lsbus_mux           1            1  1499999985          0 0
                          lpd_lsbus_div1           1            1    99999999          0 0
                             lpd_lsbus           5            5    99999999          0 0
                       lpd_switch_mux           0            0  1499999985          0 0
                          lpd_switch_div1           0            0   499999995          0 0
                             lpd_switch           0            0   499999995          0 0
                       dbg_lpd_mux            0            0  1499999985          0 0
                          dbg_lpd_div1           0            0   249999998          0 0
                             dbg_lpd           0            0   249999998          0 0
                       iopll_to_fpd           1            1   499999995          0 0
                          gtgref0_ref_mux           0            0   499999995          0 0
                             gtgref0_ref_div1           0            0    62500000          0 0
                                gtgref0_ref           0            0    62500000          0 0
                          topsw_lsbus_mux           0            0   499999995          0 0
                             topsw_lsbus_div1           0            0    99999999          0 0
                                topsw_lsbus           0            0    99999999          0 0
                                   wdt           0            0    99999999          0 0
                          pcie_ref_mux           1            1   499999995          0 0
                             pcie_ref_div1           1            1   249999998          0 0
                                pcie_ref           1            1   249999998          0 0
                          dbg_tstmp_mux           0            0   499999995          0 0
                             dbg_tstmp           0            0   249999998          0 0
                          dbg_trace_mux           0            0   499999995          0 0
                             dbg_trace_div1           0            0    13513514          0 0
                                dbg_trace           0            0    13513514          0 0
                          dbg_fpd_mux           0            0   499999995          0 0
                             dbg_fpd_div1           0            0   249999998          0 0
                                dbg_fpd           0            0   249999998          0 0
     can1_mio                                 0            0           0          0 0
     can0_mio                                 0            0           0          0 0
  • Update: When I run iio_info, I am not seeing an axi-adrv9009-rx-hpc entry for the observation receiver. This explains why I am not getting the option to plot the OS RX data.
    This is the original device tree:
    #include <dt-bindings/iio/frequency/hmc7044.h>
    #include <dt-bindings/iio/adc/adi,adrv9009.h>
    #include <dt-bindings/clock/xlnx-zynqmp-clk.h>
    /include/ "system-conf.dtsi"
    // hmc7044_sync,         // 33
    // adrv9009_reset_b,     // 32 + 78
        amba {
            spi@ff040000 {
                status = "okay";
                num-cs = <0x3>;
                    reg = <0>;
                    #size-cells = <0>;
                    // SPI Setup
                    // GT 21042021 THIS IS ACTUALLY NEEDED spi-max-frequency = <25000000>;
                    // Clocks
                    //clock-names = "jesd_rx_clk_0", "jesd_tx_clk_0", "jesd_rx_os_clk_0", "adrv9009_0_sysclk", "jesd204b0_gbtclk", "adrv9009_0_sysref", "som_sysref";
                    #clock-cells = <1>;
                    // JESD204
                    // JESD204 RX
                    // JESD204 OBS
                    // JESD204 TX
                    // RX
                    // 208MHz adi,rx-profile-rx-fir-coefs = /bits/ 16 <(-6) (-22) (31) (48) (-68) (-107) (141) (201) (-254) (-351) (431) (576) (-691) (-910) (1075) (1410) (-1649) (-2205) (2562) (3613) (-4348) (-7172) (9326) (31134) (31134) (9326) (-7172) (-4348) (3613) (2562) (-2205) (-1649) (1410) (1075) (-910) (-691) (576) (431) (-351) (-254) (201) (141) (-107) (-68) (48) (31) (-22) (-6)>;
                    // 208MHz adi,rx-profile-rx-output-rate_khz = <208000>;
                    // 208MHz adi,rx-profile-rf-bandwidth_hz = <169000000>;
                    // 208MHz adi,rx-profile-rx-bbf3d-bcorner_khz = <169000>;
                    // 208MHz adi,rx-profile-rx-adc-profile = /bits/ 16 <219 166 181 90 1280 940 1322 89 1216 41 857 19 48 42 31 212 0 0 0 0 53 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                    // ORX
                    // 208MHz adi,orx-profile-rx-fir-gain_db = <(-6)>;
                    // 208MHz adi,orx-profile-rx-fir-num-fir-coefs = <48>;
                    // 208MHz adi,orx-profile-rx-fir-coefs = /bits/ 16  <(-7) (-19) (29) (44) (-64) (-98) (118) (152) (-265) (-315) (425) (523) (-672) (-830) (1037) (1289) (-1588) (-2018) (2477) (3327) (-4207) (-6558) (9518) (30464) (30464) (9518) (-6558) (-4207) (3327) (2477) (-2018) (-1588) (1289) (1037) (-830) (-672) (523) (425) (-315) (-265) (152) (118) (-98) (-64) (44) (29) (-19) (-7)>;
                    // 208MHz adi,orx-profile-rx-fir-decimation = <2>;
                    // 208MHz adi,orx-profile-rhb1-decimation = <1>;
                    // 208MHz adi,orx-profile-orx-output-rate_khz = <208000>;
                    // 208MHz adi,orx-profile-rf-bandwidth_hz = <169000000>;
                    // 208MHz adi,orx-profile-orx-low-pass-adc-profile = /bits/ 16  <219 166 181 90 1280 940 1322 89 1216 41 857 19 48 42 31 212 0 0 0 0 53 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                    // 208MHz adi,orx-profile-orx-band-pass-adc-profile = /bits/ 16  <219 166 181 90 1280 940 1322 89 1216 41 857 19 48 42 31 212 0 0 0 0 53 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
                    // TX
                    adi,tx-profile-tx-fir-coefs = /bits/ 16  <(32) (-76) (124) (-160) (176) (-121) (-145) (1031) (-3015) (20138) (-3015) (1031) (-145) (-121) (176) (-160) (124) (-76) (32) (0)>;
                    adi,tx-profile-thb3-interpolation = <1>;
                    adi,tx-profile-tx-input-rate_khz = <491520>;
                    adi,tx-profile-primary-sig-bandwidth_hz = <150000000>;
                    adi,tx-profile-rf-bandwidth_hz = <400000000>;
                    adi,tx-profile-tx-dac3d-bcorner_khz = <400000>;
                    adi,tx-profile-tx-bbf3d-bcorner_khz = <200000>;
                    adi,tx-profile-loop-back-adc-profile = /bits/ 16 <186 148 176 90 1280 901 1479 225 1401 85 995 21 48 48 36 207 0 0 0 0 52 0 0 6 24 0 0 6 24 0 25 27 0 0 25 27 0 0 165 44 15 905>;
                    // Clocks
                    // 208MHz adi,dig-clocks-device-clock_khz = <208000>;
                    // 208MHz adi,dig-clocks-clk-pll-vco-freq_khz = <8320000>;
                    // AGC
                    // Misc
                    jesd204-device;
                    #jesd204-cells = <2>;
                    jesd204-top-device = <0>; // This is the TOP device
                    jesd204-link-ids = <DEFRAMER_LINK_TX FRAMER_LINK_RX FRAMER_LINK_ORX>;
                    jesd204-inputs =
                        <&axi_adrv9009_rx_jesd_0 0 FRAMER_LINK_RX>,
                        <&axi_adrv9009_rx_os_jesd_0 0 FRAMER_LINK_ORX>,
                        <&axi_adrv9009_tx_jesd_0 0 DEFRAMER_LINK_TX>;
                    /delete-property/ interrupts;
            spi@ff050000 {
                status = "okay";
                num-cs = <0x1>;
                    #size-cells = <0>;
                    #clock-cells = <1>;
                    reg = <0>;
                    adi,pll1-loop-bandwidth-hz = <29>;
                    adi,pll1-charge-pump-current-ua = <1920>;
                    jesd204-device;
                    jesd204-sysref-provider;
                    adi,pulse-generator-mode = <HMC7044_PULSE_GEN_16_PULSE>;
                    adi,sync-pin-mode = <0>;
                    /delete-property/ adi,pll2-autocal-bypass-manual-cap-bank-sel;
                        reg = <0>;
                        reg = <1>;
                        reg = <2>;
                        reg = <3>;
                        reg = <4>;
                        reg = <5>;
                        reg = <6>;
                        reg = <7>;
                        reg = <8>;
                        reg = <10>;
                        reg = <12>;
                        reg = <13>;
        amba_pl@0 {
            interrupt-parent = <&gic>;
            #address-cells = <0x2>;
            #size-cells = <0x2>;
            compatible = "simple-bus";
            ranges;
            /delete-node/ axi_adrv9009@a00c0000;
            /delete-node/ axi_dmac@a0100000;
            /delete-node/ axi_dmac@a0120000;
            /delete-node/ axi_dmac@a0140000;
            rx_dma_0: dma@a0140000 {
                compatible = "adi,axi-dmac-1.00.a";
                reg = <0x0 0xa0140000 0x0 0x10000>;
                #dma-cells = <1>;
                #clock-cells = <0>;
                interrupt-parent = <&axi_intc>;
                interrupts = <0x5 0x2>;
                clocks = <&zynqmp_clk PL1_REF>;
                adi,channels {
                    #size-cells = <0>;
                    dma-channel@0 {
                        reg = <0>;
                        adi,source-bus-width = <64>;
                        adi,source-bus-type = <2>;
                        adi,destination-bus-width = <64>;
                        adi,destination-bus-type = <0>;
            rx_obs_dma_0: dma@a0120000 {
                reg = <0x0 0xa0120000 0x0 0x10000>;
                #dma-cells = <1>;
                #clock-cells = <0>;
                interrupts = <0x3 0x2>;
                adi,channels {
                    #size-cells = <0>;
                    dma-channel@0 {
                        reg = <0>;
                        adi,source-bus-width = <128>;
            tx_dma_0: dma@a0100000  {
                reg = <0x0 0xa0100000 0x0 0x10000>;
                #dma-cells = <1>;
                #clock-cells = <0>;
                interrupts = <0x4 0x2>;
                adi,channels {
                    #size-cells = <0>;
                    dma-channel@0 {
                        reg = <0>;
                        adi,source-bus-type = <0>;
                        adi,destination-bus-width = <128>;
                        adi,destination-bus-type = <2>;
            axi_adrv9009_core_rx_0: axi-adrv9009-rx-hpc@a00c0000 {
                compatible = "adi,axi-adrv9009-rx-1.0";
                reg = <0x0 0xa00c0000 0x0 0x8000>;
                dmas = <&rx_dma_0 0>;
                dma-names = "rx";
                spibus-connected = <&trx0_adrv9009>;
            axi_adrv9009_core_rx_obs_0: axi-adrv9009-rx-obs-hpc@a00c8000 {
                compatible = "adi,axi-adrv9009-obs-1.0";
                reg = <0x0 0xa00c8000 0x0 0x1000>;
                dmas = <&rx_obs_dma_0 0>;
                dma-names = "rx";
                clocks = <&trx0_adrv9009 1>;
                clock-names = "sampl_clk";
            axi_adrv9009_core_tx_0: axi-adrv9009-tx-hpc@a00c4000 {
                compatible = "adi,axi-adrv9009-tx-1.0";
                reg = <0x0 0xa00c4000 0x0 0x4000>;
                dmas = <&tx_dma_0 0>;
                dma-names = "tx";
                clocks = <&trx0_adrv9009 2>;
                //adi,axi-pl-fifo-enable;
                plddrbypass-gpios = <&gpio 113 0>;
            axi_adrv9009_rx_jesd_0: axi_jesd204_rx@a0014000 {
                compatible = "adi,axi-jesd204-rx-1.0";
                reg = <0x0 0xa0014000 0x0 0x4000>;
                //clocks = <&zynqmp_clk PL0_REF>, <&axi_adrv9009_adxcvr_rx_0 1>, <&axi_adrv9009_adxcvr_rx_0 0>;
                clocks = <&zynqmp_clk PL0_REF>, <&hmc7044 6>, <&axi_adrv9009_adxcvr_rx_0 0>;
                clock-names = "s_axi_aclk", "device_clk", "lane_clk";
                #clock-cells = <0>;
                clock-output-names = "jesd_rx_lane_clk";
                adi,octets-per-frame = <4>;
                adi,frames-per-multiframe = <32>;
                jesd204-device;
                jesd204-inputs = <&axi_adrv9009_adxcvr_rx_0 0 FRAMER_LINK_RX>;
            axi_adrv9009_tx_jesd_0: axi_jesd204_tx@a001c000 {
                compatible = "adi,axi-jesd204-tx-1.0";
                reg = <0x0 0xa001c000 0x0 0x4000>;
                //clocks = <&zynqmp_clk PL0_REF>, <&axi_adrv9009_adxcvr_tx_0 1>, <&axi_adrv9009_adxcvr_tx_0 0>;
                clocks = <&zynqmp_clk PL0_REF>, <&hmc7044 6>, <&axi_adrv9009_adxcvr_tx_0 0>;
                #clock-cells = <0>;
                clock-output-names = "jesd_tx_lane_clk";
                adi,octets-per-frame = <2>;
                adi,converter-resolution = <14>;
                adi,bits-per-sample = <16>;
                adi,converters-per-device = <4>;
                adi,control-bits-per-sample = <2>;
                jesd204-device;
                jesd204-inputs = <&axi_adrv9009_adxcvr_tx_0 0 DEFRAMER_LINK_TX>;
            axi_adrv9009_rx_os_jesd_0: axi_jesd204_rx@a0018000 {
                reg = <0x0 0xa0018000 0x0 0x4000>;
                //clocks = <&zynqmp_clk PL0_REF>, <&axi_adrv9009_adxcvr_rx_os_0 1>, <&axi_adrv9009_adxcvr_rx_os_0 0>;
                clocks = <&zynqmp_clk PL0_REF>, <&hmc7044 6>, <&axi_adrv9009_adxcvr_rx_os_0 0>;
                #clock-cells = <0>;
                clock-output-names = "jesd_rx_os_lane_clk";
                jesd204-device;
                jesd204-inputs = <&axi_adrv9009_adxcvr_rx_os_0 0 FRAMER_LINK_ORX>;
            axi_adrv9009_adxcvr_rx_0: axi_adxcvr@a0090000 {
                #size-cells = <0>;
                compatible = "adi,axi-adxcvr-1.0";
                reg = <0x0 0xa0090000 0x0 0x10000>;
                clocks = <&hmc7044 0>;
                clock-names = "conv";
                #clock-cells = <1>;
                clock-output-names = "rx_gt_clk", "rx_out_clk";
                adi,sys-clk-select = <0>;
                adi,out-clk-select = <3>;
                adi,use-lpm-enable;
                adi,use-cpll-enable;
                jesd204-device;
                jesd204-inputs =  <&hmc7044 0 FRAMER_LINK_RX>;
            axi_adrv9009_adxcvr_rx_os_0: axi_adxcvr@a0080000 {
                #size-cells = <0>;
                reg = <0x0 0xa0080000 0x0 0x10000>;
                #clock-cells = <1>;
                clock-output-names = "rx_os_gt_clk", "rx_os_out_clk";
                adi,use-lpm-enable;
                    jesd204-device;
                jesd204-inputs =  <&hmc7044 0 FRAMER_LINK_ORX>;
            axi_adrv9009_adxcvr_tx_0: axi_adxcvr@a00b0000 {
                #size-cells = <0>;
                reg = <0x0 0xa00b0000 0x0 0x10000>;
                #clock-cells = <1>;
                clock-output-names = "tx_gt_clk", "tx_out_clk";
                adi,sys-clk-select = <3>;
                    jesd204-device;
                jesd204-inputs =  <&hmc7044 0 DEFRAMER_LINK_TX>;
        chosen {
            bootargs = "earlycon clk_ignore_unused cpuidle.off=1 uio_pdrv_genirq.of_id=\"generic-uio\"";
    on Apr 29, 2021 11:49 AM in reply to gavint
    Should this "device_clk" in axi_jesd204_rx be the same clock as the clock connected to "dev_clk" in trx0_adrv9009? In my case, that would be <&hmc7044 6>.
    Well it depends - this device_clk is typically Lane_Rate/40 and clocks the link layer. In case axi_adrv9009_adxcvr_rx_os_0 1 controlled by out-clk-sel satisfies this it's ok.
    Here, I don't see the option to plot the OS RX data. Is that expected behaviour?
    Check why this devices doesn't get probed. It's a different driver - maybe not enabled in Kconfig?
    -Michael
  • That was it! I need to include the CONFIG_ADMC in the kernel configuration to get the observation receiver.
    So now I am pretty much at the same state I had in the 2018_R2 case of a single working ADRV9009 device.
    Now it starts getting interesting. How should I proceed to add the remaining two devices? Remember that I have duplicated everything in firmware three times so there are effectively three independent ADRV9009 devices.
    Should all three ADRV9009 devices get the following:
    Or should they all be assigned a unique number?
    on Apr 29, 2021 12:33 PM in reply to gavint
    No - there can only be one top device per topology.
    However simply add the two other TRX in the chain just without:
    Do the same for your jesd and adxcvr cores.
    One thing to mention here - you're using the HMC7044 to generate SYSREF, and you configure the outputs to be LVDS. The HMC7044 doesn't properly inactivate the buffers, so they appear to be floating.
    You need to use LVPECL and use a voltage level translation circuit, similar to what we use on the FMCOMMS8 take a look there....
    -Michael
    on Apr 29, 2021 12:38 PM in reply to mhennerich
    Please see here:
    https://ez.analog.com/clock_and_timing/f/q-a/167096/hmc7043-sysref-output-in-lvds-mode
    This one is about the 7043 but same applies for the 7044
    -Michael
Reply Children
  • So I have now added two and this is the dmesg output:
    root@frm127101u1r1:~# dmesg | grep adrv9009
    [    1.303583] jesd204: created con: id=12, topo=0, link=1, /amba_pl@0/axi_jesd204_rx@a0020000 <-> /amba/spi@ff040000/adrv9009-phy@1
    [    1.303608] jesd204: created con: id=13, topo=0, link=2, /amba_pl@0/axi_jesd204_rx@a0024000 <-> /amba/spi@ff040000/adrv9009-phy@1
    [    1.303633] jesd204: created con: id=14, topo=0, link=0, /amba_pl@0/axi_jesd204_tx@a0028000 <-> /amba/spi@ff040000/adrv9009-phy@1
    [    1.303669] jesd204: created con: id=15, topo=0, link=1, /amba_pl@0/axi_jesd204_rx@a0014000 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.303695] jesd204: created con: id=16, topo=0, link=2, /amba_pl@0/axi_jesd204_rx@a0018000 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.303721] jesd204: created con: id=17, topo=0, link=0, /amba_pl@0/axi_jesd204_tx@a001c000 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.303749] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[0] transition uninitialized -> initialized
    [    1.303762] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[1] transition uninitialized -> initialized
    [    1.303774] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[2] transition uninitialized -> initialized
    [    5.894968] adrv9009 spi1.0: adrv9009_probe : enter
    [    5.900627] adrv9009 spi1.1: adrv9009_probe : enter
    [    6.428197] adrv9009 spi1.0: adrv9009_probe : enter
    [    6.438111] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition initialized -> probed
    [    6.449260] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition initialized -> probed
    [    6.460395] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
    [    6.471530] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
    [    6.482052] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition probed -> idle
    [    6.492572] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
    [    6.503098] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [    6.514055] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [    6.525009] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [    6.535969] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [    6.547361] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [    6.558749] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [    6.570145] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [    6.581795] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [    6.593443] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [    6.605462] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [    6.617560] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [    6.629650] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [    6.641737] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [    6.653910] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [    6.666079] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [    6.678253] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [    6.690513] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [    6.702769] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [    6.715030] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [    6.727291] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [    6.739547] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [    6.752899] adrv9009 spi1.0: ADIHAL_resetHw
    [    7.123324] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [    7.135156] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [    7.146984] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [    7.158947] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [    7.170865] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [    7.182783] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [    9.586180] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [    9.598617] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [    9.611053] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [    9.623614] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [    9.636053] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [    9.648489] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [    9.661102] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [    9.673534] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [    9.685969] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [   13.800418] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    [   13.812852] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage5
    [   13.825287] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    [   13.840002] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
    [   13.852181] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> clocks_enable
    [   13.864358] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
    [   13.876804] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
    [   13.888549] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clocks_enable -> link_enable
    [   13.900291] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
    [   13.912403] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
    [   13.924060] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_enable -> link_running
    [   13.935715] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
    [   13.950016] adrv9009 spi1.0: adrv9009_info: adrv9009 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   13.962453] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> opt_post_running_stage
    [   13.975062] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_running -> opt_post_running_stage
    [   13.987667] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> opt_post_running_stage
    [   14.000426] adrv9009 spi1.1: adrv9009_probe : enter
    [   14.010093] jesd204: /amba/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1: Device isn't a top-device, nor does it belong to topology with top-device
    [   14.025072] adrv9009: probe of spi1.1 failed with error -14
    [   14.051364] cf_axi_adc a00c0000.axi-adrv9009-rx-hpc: ADI AIM (10.00.b) at 0xA00C0000 mapped to 0x000000004a9ee787, probed ADC ADRV9009 as MASTER
    [   14.085090] cf_axi_dds a00c4000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.00.b) at 0xA00C4000 mapped to 0x00000000cabac236, probed DDS AD9371
    I think the critical message for the second ADRV9009 is the following:
    Any suggestions please? I didn't set the second ADRV9009 to be a top device.
    on Apr 29, 2021 12:59 PM in reply to gavint
    Did you add:
    jesd204-device;
    jesd204-link-ids property and jesd204-inputs ?
    -Michael
  • I did yes. Here are the parts of the device tree for the second ADRV9009:
                trx1_adrv9009: adrv9009-phy@1 {
                    reg = <1>;
                    #size-cells = <0>;
                    // SPI Setup
                    //reset-gpios = <&gpio 110 0>;
                    //sysref-req-gpios = <&gpio 111 0>;
                    // Clocks
                    //clock-names = "jesd_rx_clk_1", "jesd_tx_clk_1", "jesd_rx_os_clk_1", "adrv9009_1_sysclk", "jesd204b1_gbtclk", "adrv9009_1_sysref", "som_sysref";
                    #clock-cells = <1>;
                    // JESD204
                    // JESD204 RX
                    // JESD204 OBS
                    // JESD204 TX
                    // RX
                    // ORX
                    // TX
                    // Clocks
                    // AGC
                    // Misc
                    jesd204-device;
                    jesd204-inputs =
                        <&axi_adrv9009_rx_jesd_1 0 FRAMER_LINK_RX>,
                        <&axi_adrv9009_rx_os_jesd_1 0 FRAMER_LINK_ORX>,
                        <&axi_adrv9009_tx_jesd_1 0 DEFRAMER_LINK_TX>;
    And for the PL firmware of the second ADRV9009:
            rx_dma_1: dma@a01a0000 {
                reg = <0x0 0xa01a0000 0x0 0x10000>;
                #dma-cells = <1>;
                #clock-cells = <0>;
                interrupts = <0xb 0x2>;
                adi,channels {
                    #size-cells = <0>;
                    dma-channel@0 {
                        reg = <0>;
            rx_obs_dma_1: dma@a0180000 {
                reg = <0x0 0xa0180000 0x0 0x10000>;
                #dma-cells = <1>;
                #clock-cells = <0>;
                interrupts = <0x9 0x2>;
                adi,channels {
                    #size-cells = <0>;
                    dma-channel@0 {
                        reg = <0>;
            tx_dma_1: dma@a0160000  {
                reg = <0x0 0xa0160000 0x0 0x10000>;
                #dma-cells = <1>;
                #clock-cells = <0>;
                interrupts = <0xa 0x2>;
                adi,channels {
                    #size-cells = <0>;
                    dma-channel@0 {
                        reg = <0>;
            axi_adrv9009_core_rx_1: axi-adrv9009-rx-hpc-b@a00e0000 {
                reg = <0x0 0xa00e0000 0x0 0x8000>;
                dmas = <&rx_dma_1 0>;
                dma-names = "rx";
                spibus-connected = <&trx1_adrv9009>;
            axi_adrv9009_core_rx_obs_1: axi-adrv9009-rx-obs-hpc-b@a00e8000 {
                reg = <0x0 0xa00e8000 0x0 0x1000>;
                dmas = <&rx_obs_dma_1 0>;
                dma-names = "rx";
                clocks = <&trx1_adrv9009 1>;
            axi_adrv9009_core_tx_1: axi-adrv9009-tx-hpc-b@a00e4000 {
                reg = <0x0 0xa00e4000 0x0 0x4000>;
                dmas = <&tx_dma_1 0>;
                dma-names = "tx";
                clocks = <&trx1_adrv9009 2>;
            axi_adrv9009_rx_jesd_1: axi_jesd204_rx@a0020000 {
                reg = <0x0 0xa0020000 0x0 0x4000>;
                clocks = <&zynqmp_clk PL0_REF>, <&axi_adrv9009_adxcvr_rx_1 1>, <&axi_adrv9009_adxcvr_rx_1 0>;
                #clock-cells = <0>;
                jesd204-device;
                jesd204-inputs = <&axi_adrv9009_adxcvr_rx_1 0 FRAMER_LINK_RX>;
            axi_adrv9009_tx_jesd_1: axi_jesd204_tx@a0028000 {
                reg = <0x0 0xa0028000 0x0 0x4000>;
                clocks = <&zynqmp_clk PL0_REF>, <&axi_adrv9009_adxcvr_tx_1 1>, <&axi_adrv9009_adxcvr_tx_1 0>;
                #clock-cells = <0>;
                jesd204-device;
                jesd204-inputs = <&axi_adrv9009_adxcvr_tx_1 0 DEFRAMER_LINK_TX>;
            axi_adrv9009_rx_os_jesd_1: axi_jesd204_rx@a0024000 {
                reg = <0x0 0xa0024000 0x0 0x4000>;
                clocks = <&zynqmp_clk PL0_REF>, <&axi_adrv9009_adxcvr_rx_os_1 1>, <&axi_adrv9009_adxcvr_rx_os_1 0>;
                #clock-cells = <0>;
                jesd204-device;
                jesd204-inputs = <&axi_adrv9009_adxcvr_rx_os_1 0 FRAMER_LINK_ORX>;
            axi_adrv9009_adxcvr_rx_1: axi_adxcvr@a00a0000 {
                #size-cells = <0>;
                reg = <0x0 0xa00a0000 0x0 0x10000>;
                clocks = <&hmc7044 8>;
                #clock-cells = <1>;
                adi,use-lpm-enable;
                jesd204-device;
                jesd204-inputs =  <&hmc7044 8 FRAMER_LINK_RX>;
            axi_adrv9009_adxcvr_rx_os_1: axi_adxcvr@a0030000 {
                #size-cells = <0>;
                reg = <0x0 0xa0030000 0x0 0x10000>;
                #clock-cells = <1>;
                adi,use-lpm-enable;
                    jesd204-device;
                jesd204-inputs =  <&hmc7044 8 FRAMER_LINK_ORX>;
            axi_adrv9009_adxcvr_tx_1: axi_adxcvr@a00d0000 {
                #size-cells = <0>;
                reg = <0x0 0xa00d0000 0x0 0x10000>;
                #clock-cells = <1>;
                    jesd204-device;
                jesd204-inputs =  <&hmc7044 8 DEFRAMER_LINK_TX>;
    on Apr 29, 2021 1:55 PM in reply to gavint
    I guess you don't link them correctly by their inputs.
    You need to build a straight connection for each link
    trx0_adrv9009 -> trx1_adrv9009 -> trx1_adrv9009 -> axi_adrv9009_rx_jesd_0 -> axi_adrv9009_rx_jesd_1 -> axi_adrv9009_rx_jesd_2 ->  axi_adrv9009_adxcvr_tx_0 -> axi_adrv9009_adxcvr_tx_1 ->axi_adrv9009_adxcvr_tx_2 ->  hmc7044
    -Michael
  • So I have followed the connection instructions of the following link:
    wiki.analog.com/.../jesd204-fsm-framework
    I have a question about the Multi-Chip Multi-Link example.
    In this device tree, the final ADRV9009 in the chain (trx3_adrv9009) connects it's DEFRAMER_LINK_TX to axi_adrv9009_core_tx. This axi_adrv9009_core_tx then connects to axi_adrv9009_tx_jesd. Both the FRAMER_LINK_RX and FRAMER_LINK_ORX both connect directly to their corresponding JESD components.
    Is this intentional?
    In my case where I have three axi_adrv9009_core_tx components, must the DEFRAMER_LINK_TX connection be:
    trx0_adrv9009 -> trx1_adrv9009 -> trx2_adrv9009 -> axi_adrv9009_core_tx0 -> axi_adrv9009_core_tx1 -> axi_adrv9009_core_tx2 -> axi_adrv9009_tx_jesd_0 -> axi_adrv9009_tx_jesd_1 -> axi_adrv9009_tx_jesd_2 -> axi_adrv9009_adxcvr_tx_0 -> axi_adrv9009_adxcvr_tx_1 -> axi_adrv9009_adxcvr_tx_2 -> hmc7044
