Porting ADRV9002 to Cyclone V SoC
Hi
I am porting the ADRV9002 hdl reference design to the DataStorm DAQ carrier card.
ADI has been working on a port on the design to the Arria 10 SoC development card but it is not complete. ADI gave me a reference to the repository. I took that and ported it to Cyclone V SoC.
I am now in the process of building the bootable Linux image.
I have been using the 2019_R2 branch of the ADI repo. Is this the one that I should use or is there a better one that you would recommend?
I updated the defconfig and device tree files with references to the ADRV9002. I have attached these files to the request.
The probe for the ADRV9002 driver is successfully executed.
I am currently at a standstill because the system is not seeing any iio devices. I have looked in /sys/bus/iio/devices and no devices are listed.
I have used the internal logic analyzer in the FPGA to look at a few signals.
I do not see any activity on the spi interface or the reset signal. The reset signal is continually in the asserted state.
Any thoughts would be greatly appreciated.
Steven
Parents
    on Mar 15, 2021 4:33 PM
    Hi Steven,
    The corresponding Linux branch for the Arria 10 project is: https://github.com/analogdevicesinc/linux/tree/dev_adrv9001_a10soc
    Everything is working, we only need to do some cleanup on both HDL and Linux before doing the merge to master.
    Dragos
  • Hi Dragos
    I have made some progress with your assistance. Now using the branch of Linux listed above.
    Failing during boot with the following message
    adrv9002 spi0.0: adrv9002_setup, 2512: failed with "Failed to reset the device and set SPI Config"
    I have the SPI controller set up as 8 bits wide and a spi clock rate of 10M. Is this correct? I do see the reset line asserting and deasserting during boot. The spi master does have some activity during boot but it does not look very interesting.
    I get a kernel panic due to a divide by zero in the dds driver. It is dividing a frequency. I think this is because the spi config failed.
    I do now see some of the IIO devices listed under /sys/bus/iio/devices.
    Thanks
    Steven
  • Thanks.
    Do you have a recommended set of steps for using Iio scope with the a10soc for the adrv9001 in loopback? There are a lot of options.
    Do I need to download a profile and / or a stream file or is this done by The Linux driver when it boots?
    I do not get any data showing in the iio scope time or frequency views. Probably still have to do some debug.
    Regards
    Steven
  • +1
    on Mar 23, 2021 5:20 PM in reply to skravats
    No, you shouldn't do anything special to get data.
    These are some details captured from my setup:
    [   11.586035] adrv9002 spi0.0: adrv9002-phy Rev 12.0, Firmware 0.14.5.6,  Stream 0.5.18.0,  API version: 39.0.7 successfully initialized
    [   11.599273] cf_axi_adc ff220000.axi-adrv9002-rx-lpc: ADI AIM (10.01.b) at 0xFF220000 mapped to 0xc515b125, probed ADC ADRV9002 as MASTER
    [   11.639475] cf_axi_dds ff22a000.axi-adrv9002-tx-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0xFF22A000 mapped to 0x6aef2554, probed DDS ADRV9002
    root@analog:/sys/bus/iio/devices# ls -l
    total 0
    lrwxrwxrwx 1 root root 0 Mar 23 17:05 iio:device0 -> ../../../devices/platform/soc/ff200000.bridge/ff200040.spi/spi_master/spi0/spi0.0/iio:device0
    lrwxrwxrwx 1 root root 0 Mar 23 17:05 iio:device1 -> ../../../devices/platform/soc/ff200000.bridge/ff220000.axi-adrv9002-rx-lpc/iio:device1
    lrwxrwxrwx 1 root root 0 Mar 23 17:05 iio:device2 -> ../../../devices/platform/soc/ff200000.bridge/ff22a000.axi-adrv9002-tx-lpc/iio:device2
    lrwxrwxrwx 1 root root 0 Mar 23 17:05 iio_sysfs_trigger -> ../../../devices/iio_sysfs_trigger
    root@analog:/sys/bus/iio/devices# cat */name
    adrv9002-phy
    axi-adrv9002-rx-lpc
    axi-adrv9002-tx-lpc
    By the way, for capturing this, I've used:
     - ronagyl/hdl at dev_adrv9001_a10soc_zc706 (github.com) - Quartus Pro 20.1 since it was rebased on top of our current master (I've only removed hdl/system_qsys.tcl at dev_adrv9001_a10soc_zc706 · ronagyl/hdl (github.com))
     - analogdevicesinc/linux at dev_adrv9001_a10soc (github.com)
    Dragos
  • Hi Dragos
    This is what i see. The same except for adrv9002-phy Rev 11.0. Is this because i have rev B silicon?
    root@analog:~# dmesg | grep 'adrv'
    [ 13.027866] adrv9002 spi0.0: adrv9002-phy Rev 11.0, Firmware 0.13.6.7, Stream 0.5.18.0, API version: 39.0.7 successfully initialized
    [ 13.041799] cf_axi_adc ff230000.axi-adrv9002-rx-lpc: ADI AIM (10.01.b) at 0xFF230000 mapped to 0x188716af, probed ADC ADRV9002 as MASTER
    [ 13.076993] cf_axi_dds ff23a000.axi-adrv9002-tx-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0xFF23A000 mapped to 0x1fb61dd6, probed DDS ADRV9002
    root@analog:~# cd /sys/bus/iio/devices
    total 0
    lrwxrwxrwx 1 root root 0 Jan 1 1970 iio:device0 -> ../../../devices/platform/soc/ff200000.bridge/ff220060.spi/spi_master/spi0/spi0.0/iio:device0
    lrwxrwxrwx 1 root root 0 Jan 1 1970 iio:device1 -> ../../../devices/platform/soc/ff200000.bridge/ff230000.axi-adrv9002-rx-lpc/iio:device1
    lrwxrwxrwx 1 root root 0 Jan 1 1970 iio:device2 -> ../../../devices/platform/soc/ff200000.bridge/ff23a000.axi-adrv9002-tx-lpc/iio:device2
    lrwxrwxrwx 1 root root 0 Jan 1 1970 iio_sysfs_trigger -> ../../../devices/iio_sysfs_trigger
    adrv9002-phy
    axi-adrv9002-rx-lpc
    axi-adrv9002-tx-lpc
    I did not include the axi_sys_id & rom in the my Cyclone V version of the design. Could this be an issue?
    Thanks
    on Mar 23, 2021 7:03 PM in reply to skravats
    Steven,
    No, that shouldn't mater.
    I would generate a .dts from the .sopcinfo using sopc2dts (can be called from Embedded Command Shell) and I would compare all the addresses and the interrupts with the ones specified in the devicetree.
    Dragos
  • Hi Dragos
    I do not see any reference to the following signals in the devicetree.
    gpio_tx2_enable_in
    gpio_tx1_enable_in
    gpio_rx2_enable_in
    gpio_rx1_enable_in
    They are connected from the gpio peripheral (bits [18:15]) to the adrv9001_tdd_if inputs. Should I see these signals assert at any point or are they unused?
    Thanks
Reply Children
