setting the sampling frequency of fmcdaq2/kcu1105 in linux ELF image
I am trying to set the sampling frequency to 300MSPS on fmcdaq2 using linux 2019_R1(vivado 2018.3)  image by changing the clock settings (channel dividers) from adi-daq2.dtsi
then build the kernel. I did the following steps :
  1. set adi,pll2-m1-freq = <600000000>; which means out master clock is 5.
  2. change ADC and DAC clock channel dividers :
    • "DAC_CLK_FMC" = 4.
    • "DAC_CLK" = 2.
    • "CLKD_DAC_SYSREF"=256.
    • "DAC_SYSREF"=256.
    • "ADC_CLK_FMC" = 4.
    • "ADC_CLK" = 2.
    • "CLKD_ADC_SYSREF"=256.
    • "ADC_SYSREF"=256.
  3. enable cpll in axi_ad9144_adxcvr by adding adi,use-cpll-enable;
  4. set adi,sys-clk-select = <0> in axi_ad9144_adxcvr.
the settings did not work . ad9680 sp0 and ad9144 sp0 are out of range also I did the same settings before on no-OS software after emoving the FIFO and it worked do you have any advice.
settings the sampling frequency in no-OS to 300MSPS are disscussed here :
https://ez.analog.com/microcontroller-no-os-drivers/f/q-a/536803/adc-dac-sampling-frequency-kcu105-and-daq2
thanks
Ahmed
Parents
    on Mar 6, 2021 8:33 AM
    Can you show us the entire dmesg log? By the way, I would better use the 2019_R2 branch for both Linux and HDL.
    Dragos
  • Hi Dragos
    I can not use vivado 2019.1 because my pc performance is not that good.
    this the dmesg output:
    Ramdisk addr 0x00000000,
    Compiled-in FDT at 80416a8c
    Linux version 4.14.0-gb6e379910a11-dirty (ahmed@ahmed-virtual-machine) (gcc ver1
    setup_cpuinfo: initialising
    setup_cpuinfo: Using full CPU PVR support
    wt_msr_noirq
    setup_memory: max_mapnr: 0x30000
    setup_memory: min_low_pfn: 0x80000
    setup_memory: max_low_pfn: 0xb0000
    setup_memory: max_pfn: 0xb0000
    Zone ranges:
      DMA      [mem 0x0000000080000000-0x00000000afffffff]
      Normal   empty
    Movable zone start for each node
    Early memory node ranges
      node   0: [mem 0x0000000080000000-0x00000000ffffefff]
    Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffefff]
    On node 0 totalpages: 196608
    free_area_init_node: node 0, pgdat 805c8584, node_mem_map 808bc000
      DMA zone: 1536 pages used for memmap
      DMA zone: 0 pages reserved
      DMA zone: 196608 pages, LIFO batch:31
    pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
    pcpu-alloc: [0] 0
    Built 1 zonelists, mobility grouping on.  Total pages: 195072
    Kernel command line: console=ttyUL0,115200
    PID hash table entries: 4096 (order: 2, 16384 bytes)
    Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    Memory: 769732K/786432K available (4186K kernel code, 160K rwdata, 1504K rodata)
    Kernel virtual memory layout:
      * 0xffffe000..0xfffff000  : fixmap
      * 0xffffe000..0xffffe000  : early ioremap
      * 0xb0000000..0xffffe000  : vmalloc & ioremap
    NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    irq-xilinx: /amba_pl/interrupt-controller@41200000: num_irq=16, edge=0x410
    /amba_pl/timer@41c00000: irq=1
    clocksource: xilinx_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_is
    xilinx_timer_shutdown
    xilinx_timer_set_periodic
    sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
    Calibrating delay loop... 49.35 BogoMIPS (lpj=246784)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    devtmpfs: initialized
    random: get_random_u32 called from bucket_table_alloc+0x248/0x29c with crng_ini0
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 191s
    futex hash table entries: 256 (order: -1, 3072 bytes)
    NET: Registered protocol family 16
    clocksource: Switched to clocksource xilinx_clocksource
    NET: Registered protocol family 2
    TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    TCP: Hash tables configured (established 8192 bind 8192)
    UDP hash table entries: 512 (order: 1, 8192 bytes)
    UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    random: fast init done
    Skipping unavailable RESET gpio -2 (reset)
    workingset: timestamp_bits=30 max_order=18 bucket_order=0
    jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
    Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    io scheduler mq-deadline registered
    io scheduler kyber registered
    Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    40600000.serial: ttyUL0 at MMIO 0x40600000 (irq = 5, base_baud = 0) is a uartlie
    console [ttyUL0] enabled
    brd: module loaded
    Xilinx SystemACE device driver, major=254
    libphy: Fixed MDIO Bus: probed
    xilinx_axienet 40e00000.ethernet: TX_CSUM 2
    xilinx_axienet 40e00000.ethernet: RX_CSUM 2
    libphy: Xilinx Axi Ethernet MDIO: probed
    i2c /dev entries driver
    i2c i2c-0: Added multiplexed i2c bus 1
    at24 2-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
    i2c i2c-0: Added multiplexed i2c bus 2
    i2c i2c-0: Added multiplexed i2c bus 3
    i2c i2c-0: Added multiplexed i2c bus 4
    pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
    ad9523 spi0.0: spi0.0 supply vcc not found, using dummy regulator
    ad9523 spi0.0: probed ad9523-1
    axi_adxcvr 44a50000.axi-ad9680-adxcvr: AXI-ADXCVR-RX (17.01.a) using GTH3 at 0x.
    axi_adxcvr 44a60000.axi-ad9144-adxcvr: AXI-ADXCVR-TX (17.01.a) using GTH3 at 0x.
    axi_sysid 45000000.axi-sysid-0: [daq2] on [kcu105] git <7c86b9f84f75d6eaad0ef29C
    ad9680 spi0.2: Lane rate 3000 Mbps out of bounds. Must be between 3125 and 1250s
    ad9680 spi0.2: Failed to initialize: -22
    ad9680: probe of spi0.2 failed with error -22
    cf_axi_dds 44a04000.axi-ad9144-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.4
    Freeing unused kernel memory: 2884K
    This architecture does not have kernel memory protection.
    net eth0: Promiscuous mode disabled.
    xilinx_axienet 40e00000.ethernet eth0: Link is Down
    xilinx_axienet 40e00000.ethernet eth0: Link is Up - 1Gbps/Full - flow control of
Reply
  • Hi Dragos
    wt_msr_noirq
    Zone ranges:
      Normal   empty
    pcpu-alloc: [0] 0
    brd: module loaded
Children
No Data
