4 AD9361s on a single board. Need device tree help
    I am trying to use the kernel driver for configuring the spi interface easily.  I don't necessarily want to use the RX and TX DMAs that are standard in the Vivado design.  I have my own custom DMA with custom blocks beforehand that filter and decimate the data.  Can I just use the SPI interface portion of the driver or do I need the TX and RX DMAs present in my device tree regardless if I don't use them.  Additionally, If I do need to use the DMAs I don't understand the relationship between the mastercore and slavecore and the 2x designation in the compatible property.  In my vivado design I have 1 RX DMA that is 256 wide and 1 TX DMA that is 256 wide.  Again, I don't plan on using them.  Can I remove them?  My device trees are attached.
	clocks {
		ad9361_clkin: clock@0 {
			#clock-cells = <0>;
			compatible = "adjustable-clock";
			clock-frequency = <80000000>;
			clock-accuracy = <200000>; /* 200 ppm (ppb) */
			clock-output-names = "ad9361_ext_refclk";
&spi0 {
    /* ad9361_0_L1Ant0_L1Ant1*/
	adc0_ad9361: ad9361-phy@0 {
		#address-cells = <1>;
		#size-cells = <0>;
		#clock-cells = <1>;
		compatible = "adi,ad9361-2x";
		/* SPI Setup */
		reg = <0>;
		spi-cpha;
		spi-max-frequency = <10000000>;
		/* Clocks */
		clocks = <&ad9361_clkin>;
		clock-names = "ad9361_ext_refclk";
		clock-output-names = "rx_sampl_clk", "tx_sampl_clk";
		//adi,debug-mode-enable;
		/* Digital Interface Control */
		adi,pp-tx-swap-enable;
		adi,pp-rx-swap-enable;
		adi,rx-frame-pulse-mode-enable;
		adi,lvds-mode-enable;
		adi,lvds-bias-mV = <150>;
		adi,lvds-rx-onchip-termination-enable;
		adi,rx-data-clock-delay = <0>;
		adi,rx-data-delay = <9>;
		adi,tx-fb-clock-delay = <4>;
		adi,tx-data-delay = <0>;
		//adi,fdd-rx-rate-2tx-enable;
		//adi,dcxo-coarse-and-fine-tune = <8 5920>;
		adi,xo-disable-use-ext-refclk-enable;
		/* Mode Setup */
		adi,2rx-2tx-mode-enable;
		//adi,split-gain-table-mode-enable;
		/* ENSM Mode */
		//adi,frequency-division-duplex-mode-enable = <0>;
		//adi,ensm-enable-pin-pulse-mode-enable;
		//adi,ensm-enable-txnrx-control-enable;
		adi,rx1-rx2-phase-inversion-enable;
		/* adi,rx-rf-port-input-select:
		 * 0 = (RX1A_N &  RX1A_P) and (RX2A_N & RX2A_P) enabled; balanced
		 * 1 = (RX1B_N &  RX1B_P) and (RX2B_N & RX2B_P) enabled; balanced
		 * 2 = (RX1C_N &  RX1C_P) and (RX2C_N & RX2C_P) enabled; balanced
		 * 3 = RX1A_N and RX2A_N enabled; unbalanced
		 * 4 = RX1A_P and RX2A_P enabled; unbalanced
		 * 5 = RX1B_N and RX2B_N enabled; unbalanced
		 * 6 = RX1B_P and RX2B_P enabled; unbalanced
		 * 7 = RX1C_N and RX2C_N enabled; unbalanced
		 * 8 = RX1C_P and RX2C_P enabled; unbalanced
		adi,rx-rf-port-input-select = <0>; /* (RX1A_N &  RX1A_P) and (RX2A_N & RX2A_P) enabled; balanced */
		/* adi,tx-rf-port-input-select:
		 * 0	TX1A, TX2A
		 * 1	TX1B, TX2B
		adi,tx-rf-port-input-select = <0>; /* TX1A, TX2A */
		//adi,update-tx-gain-in-alert-enable;
		adi,tx-attenuation-mdB = <10000>;
		adi,tx-lo-powerdown-managed-enable;
		adi,rf-rx-bandwidth-hz = <22000000>;
		adi,rf-tx-bandwidth-hz = <18000000>;
		adi,rx-synthesizer-frequency-hz = /bits/ 64 <1570420000>;
		adi,tx-synthesizer-frequency-hz = /bits/ 64 <2400000000>;
		/*				BBPLL     ADC        R2CLK     R1CLK    CLKRF    RSAMPL  */
		adi,rx-path-clock-frequencies = <960000000 480000000 240000000 120000000 60000000 60000000>;
		/*				BBPLL     DAC        T2CLK     T1CLK    CLKTF    TSAMPL  */
		adi,tx-path-clock-frequencies = <960000000 240000000 120000000 60000000 60000000 60000000>;
		/* Gain Control */
		/* adi,gc-rx[1|2]-mode:
		 * 0 = RF_GAIN_MGC
		 * 1 = RF_GAIN_FASTATTACK_AGC
		 * 2 = RF_GAIN_SLOWATTACK_AGC
		 * 3 = RF_GAIN_HYBRID_AGC
		adi,gc-rx1-mode = <0>;
		adi,gc-rx2-mode = <0>;
		adi,gc-adc-ovr-sample-size = <4>; /* sum 4 samples */
		adi,gc-adc-small-overload-thresh = <47>; /* sum of squares */
		adi,gc-adc-large-overload-thresh = <58>; /* sum of squares */
		adi,gc-lmt-overload-high-thresh = <800>; /* mV */
		adi,gc-lmt-overload-low-thresh = <704>; /* mV */
		adi,gc-dec-pow-measurement-duration = <8192>; /* 0..524288 Samples */
		adi,gc-low-power-thresh = <24>; /* 0..-64 dBFS vals are set pos */
		//adi,gc-dig-gain-enable;
		//adi,gc-max-dig-gain = <15>;
		/* Manual Gain Control Setup */
		//adi,mgc-rx1-ctrl-inp-enable; /* uncomment to use ctrl inputs */
		//adi,mgc-rx2-ctrl-inp-enable; /* uncomment to use ctrl inputs */
		adi,mgc-inc-gain-step = <2>;
		adi,mgc-dec-gain-step = <2>;
		/* adi,mgc-split-table-ctrl-inp-gain-mode:
		 * (relevant if adi,split-gain-table-mode-enable is set)
		 * 0 = AGC determine this
		 * 1 = only in LPF
		 * 2 = only in LMT
		adi,mgc-split-table-ctrl-inp-gain-mode = <0>;
		/* Automatic Gain Control Setup */
		adi,agc-attack-delay-extra-margin-us= <1>; /* us */
		adi,agc-outer-thresh-high = <5>; /* -dBFS */
		adi,agc-outer-thresh-high-dec-steps = <2>; /* 0..15 */
		adi,agc-inner-thresh-high = <10>; /* -dBFS */
		adi,agc-inner-thresh-high-dec-steps = <1>; /* 0..7 */
		adi,agc-inner-thresh-low = <12>; /* -dBFS */
		adi,agc-inner-thresh-low-inc-steps = <1>; /* 0..7 */
		adi,agc-outer-thresh-low = <18>; /* -dBFS */
		adi,agc-outer-thresh-low-inc-steps = <2>; /* 0..15 */
		adi,agc-adc-small-overload-exceed-counter = <10>; /* 0..15 */
		adi,agc-adc-large-overload-exceed-counter = <10>; /* 0..15 */
		adi,agc-adc-large-overload-inc-steps = <2>; /* 0..15 */
		//adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable;
		adi,agc-lmt-overload-large-exceed-counter = <10>; /* 0..15 */
		adi,agc-lmt-overload-small-exceed-counter = <10>; /* 0..15 */
		adi,agc-lmt-overload-large-inc-steps = <2>; /* 0..7 */
		//adi,agc-dig-saturation-exceed-counter = <3>; /* 0..15 */
		//adi,agc-dig-gain-step-size = <4>; /* 1..8 */
		//adi,agc-sync-for-gain-counter-enable;
		adi,agc-gain-update-interval-us = <1000>;  /* 1ms */
		//adi,agc-immed-gain-change-if-large-adc-overload-enable;
		//adi,agc-immed-gain-change-if-large-lmt-overload-enable;
		/* Fast AGC */
		adi,fagc-dec-pow-measurement-duration = <64>; /* 64 Samples */
		//adi,fagc-allow-agc-gain-increase-enable;
		adi,fagc-lp-thresh-increment-steps = <1>;
		adi,fagc-lp-thresh-increment-time = <5>;
		adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt = <8>;
		adi,fagc-final-overrange-count = <3>;
		//adi,fagc-gain-increase-after-gain-lock-enable;
		adi,fagc-gain-index-type-after-exit-rx-mode = <0>;
		adi,fagc-lmt-final-settling-steps = <1>;
		adi,fagc-lock-level = <10>;
		adi,fagc-lock-level-gain-increase-upper-limit = <5>;
		adi,fagc-lock-level-lmt-gain-increase-enable;
		adi,fagc-lpf-final-settling-steps = <1>;
		adi,fagc-optimized-gain-offset = <5>;
		adi,fagc-power-measurement-duration-in-state5 = <64>;
		adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable;
		adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll = <10>;
		adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable;
		adi,fagc-rst-gla-if-en-agc-pulled-high-mode = <0>;
		adi,fagc-rst-gla-large-adc-overload-enable;
		adi,fagc-rst-gla-large-lmt-overload-enable;
		adi,fagc-rst-gla-stronger-sig-thresh-above-ll = <10>;
		adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable;
		adi,fagc-state-wait-time-ns = <260>;
		adi,fagc-use-last-lock-level-for-set-gain-enable;
		/* RSSI */
		/* adi,rssi-restart-mode:
		 * 0 = AGC_IN_FAST_ATTACK_MODE_LOCKS_THE_GAIN,
		 * 1 = EN_AGC_PIN_IS_PULLED_HIGH,
		 * 2 = ENTERS_RX_MODE,
		 * 3 = GAIN_CHANGE_OCCURS,
		 * 4 = SPI_WRITE_TO_REGISTER,
		 * 5 = GAIN_CHANGE_OCCURS_OR_EN_AGC_PIN_PULLED_HIGH,
		adi,rssi-restart-mode = <3>;
		//adi,rssi-unit-is-rx-samples-enable;
		adi,rssi-delay = <1>; /* 1us */
		adi,rssi-wait = <1>; /* 1us */
		adi,rssi-duration = <1000>; /* 1ms */
		/* Control Outputs */
		adi,ctrl-outs-index = <0>;
		adi,ctrl-outs-enable-mask = <0xFF>;
		/* AuxADC Temp Sense Control */
		adi,temp-sense-measurement-interval-ms = <1000>;
		adi,temp-sense-offset-signed = <0xCE>;
		adi,temp-sense-periodic-measurement-enable;
		/* AuxDAC Control */
		adi,aux-dac-manual-mode-enable;
		adi,aux-dac1-default-value-mV = <0>;
		//adi,aux-dac1-active-in-rx-enable;
		//adi,aux-dac1-active-in-tx-enable;
		//adi,aux-dac1-active-in-alert-enable;
		adi,aux-dac1-rx-delay-us = <0>;
		adi,aux-dac1-tx-delay-us = <0>;
		adi,aux-dac2-default-value-mV = <0>;
		//adi,aux-dac2-active-in-rx-enable;
		//adi,aux-dac2-active-in-tx-enable;
		//adi,aux-dac2-active-in-alert-enable;
		adi,aux-dac2-rx-delay-us = <0>;
		adi,aux-dac2-tx-delay-us = <0>;
	/* ad9361_1_L1Ant2 */
	adc1_ad9361: ad9361-phy-B@1 {
		#size-cells = <0>;
		#clock-cells = <1>;
		compatible = "adi,ad9361";
		/* SPI Setup */
		reg = <1>;
		spi-cpha;
		/* Clocks */
		/* Mode Setup */
		/* ENSM Mode */
		 * 0	TX1A, TX2A
		 * 1	TX1B, TX2B
		/* Gain Control */
		 * 0 = RF_GAIN_MGC
		 * 1 = only in LPF
		 * 2 = only in LMT
		/* Fast AGC */
		/* RSSI */
	/* ad9361_2_L2Ant0_L2Ant1 */
	adc2_ad9361: ad9361-phy-C@2 {
		#size-cells = <0>;
		#clock-cells = <1>;
		/* SPI Setup */
		reg = <2>;
		spi-cpha;
		/* Clocks */
		/* Mode Setup */
		/* ENSM Mode */
		 * 0	TX1A, TX2A
		 * 1	TX1B, TX2B
		adi,rx-synthesizer-frequency-hz = /bits/ 64 <1222600000>;
		/* Gain Control */
		 * 0 = RF_GAIN_MGC
		 * 1 = only in LPF
		 * 2 = only in LMT
		/* Fast AGC */
		/* RSSI */
&spi1 {
	/* ad9361_3_L2Ant2 */
	adc3_ad9361: ad9361-phy-D@0 {
		#size-cells = <0>;
		#clock-cells = <1>;
		/* SPI Setup */
		reg = <0>;
		spi-cpha;
		/* Clocks */
		/* Mode Setup */
		/* ENSM Mode */
		 * 0	TX1A, TX2A
		 * 1	TX1B, TX2B
		/* Gain Control */
		 * 0 = RF_GAIN_MGC
		 * 1 = only in LPF
		 * 2 = only in LMT
		/* Fast AGC */
		/* RSSI */
/include/ "system-conf.dtsi"
    /* reducing memory available by 0xA000 * 2 = 0x14000 */
    memory {
        device_type = "memory";
        reg = <0x0 0x0 0x0 0x3FEEC000>;
    pod_dma_ctr: pod-dma-ctr@0 {
               compatible = "pod,prfi_dma";
                dmas = <&axi_dmac_0 0>;
               dma-names = "prfi_dma";
    /* these are each of the AD9361 IP blocks in Vivado DAC*/
    cf_ad9361_dac_core_0: cf-ad9361-dds-core-lpc@99024000 {
            compatible = "adi,axi-ad9361-dds-6.00.a";
            reg = <0x99024000 0x1000>;
            clocks = <&adc0_ad9361 13>;
            clock-names = "sampl_clk";
            dmas = <&axi_ad9361_dac_dma 0>;
            dma-names = "tx";
            slavecore-reg = <0x99044000 0x1000>;
    cf_ad9361_dac_core_1: cf-ad9361-dds-core-B@99044000 {
            compatible = "adi,axi-ad9361x2-dds-6.00.a";
            clocks = <&adc1_ad9361 13>;
            mastercore-reg = <0x99024000 0x1000>;
    cf_ad9361_dac_core_2: cf-ad9361-dds-core-C@99064000 {
            reg = <0x99064000 0x1000>;
            clocks = <&adc2_ad9361 13>;
    cf_ad9361_dac_core_3: cf-ad9361-dds-core-D@99084000 {
            reg = <0x99084000 0x1000>;
            clocks = <&adc3_ad9361 13>;
&tsu_ext_clk {
    clock-frequency = <250000000>;
&gem0 {
    phy-handle = <&phy9>;
    phy9: phy@9 {
        reg = <0x9>;
        xlnx,phy-type = <0x5>;
&i2c0 {
status = "okay";
clock-frequency = <400000>;
    lm87@2e {
        compatible = "ti,lm87";
        reg = <0x2e>;
        has-in6;
        has-in7;
    ad7291@20 {
        compatible = "adi,ad7291";
        reg = <0x20>;
/* PRFI DMA */
&axi_dmac_0 {
    compatible = "adi,axi-dmac-1.00.a";
    adi,channels {
        #size-cells = <0>;
        dma-channel@0 {
            reg = <0>;
            adi,source-bus-width = <128>;
            adi,source-bus-type = <1>;
            adi,destination-bus-width = <32>;
            adi,destination-bus-type = <0>;
            adi,length-width = <24>;
/* This is the ADI default RX DMA */
&axi_ad9361_adc_dma {
    adi,channels {
        #size-cells = <0>;
        dma-channel@0 {
            reg = <0>;
            adi,source-bus-width = <256>;
            adi,source-bus-type = <2>;
            adi,destination-bus-width = <64>;
/* This is the ADI default TX DMA */
&axi_ad9361_dac_dma {
    adi,channels {
            #size-cells = <0>;
        dma-channel@0 {
            reg = <0>;
            adi,source-bus-width = <64>;
            adi,source-bus-type = <0>;
            adi,destination-bus-width = <256>;
            adi,destination-bus-type = <2>;
/* these are each of the AD9361 IP blocks in Vivado A2D*/
&axi_ad9361_0_L1Ant0_L1Ant1 {
            compatible = "adi,axi-ad9361-6.00.a";
            dmas = <&axi_ad9361_adc_dma 0>;
            dma-names = "rx";
            spibus-connected = <&adc0_ad9361>;
            slavecore-reg = <0x99040000 0x6000>;
&axi_ad9361_1_L1Ant2 {
            spibus-connected = <&adc1_ad9361>;
&axi_ad9361_2_L2Ant0_L2Ant1 {
            spibus-connected = <&adc2_ad9361>;
&axi_ad9361_3_L2Ant2 {
            spibus-connected = <&adc3_ad9361>;
#include "ad9361_spi_and_clock.dtsi"
&adc0_ad9361 {
    reset-gpios = <&gpio 130 0>;
    sync-gpios = <&gpio 129 0>;
    enable-gpios = <&gpio 132 0>;
&adc1_ad9361 {
    enable-gpios = <&gpio 135 0>;
&adc2_ad9361 {
    enable-gpios = <&gpio 125 0>;
&adc3_ad9361 {
    enable-gpios = <&gpio 124 0>;
  • Here is the error I am getting on boot:
    [    2.510247] ad9361 spi1.0: ad9361_probe : enter (ad9361-2x)
    [    2.514010] ad9361 spi1.1: ad9361_probe : enter (ad9361-2x)
    [    2.519514] ad9361 spi1.2: ad9361_probe : enter (ad9361)
    [    2.524792] ad9361 spi2.0: ad9361_probe : enter (ad9361)
    [    2.535282] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    2.537731] Mem abort info:
    [    2.540499]   Exception class = DABT (current EL), IL = 32 bits
    [    2.546383]   SET = 0, FnV = 0
    [    2.549407]   EA = 0, S1PTW = 0
    [    2.552518] Data abort info:
    [    2.555381]   ISV = 0, ISS = 0x00000005
    [    2.559179]   CM = 0, WnR = 0
    [    2.562124] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc02e373000
    [    2.568609] [0000000000000000] *pgd=0000000000000000, *pud=0000000000000000
    [    2.575532] Internal error: Oops: 96000005 [#1] PREEMPT SMP
    [    2.581055] Modules linked in:
    [    2.584086] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.14.0 #1
    [    2.589964] Hardware name: xlnx,zynqmp (DT)
    [    2.594117] task: ffffffc02e850d80 task.stack: ffffff8008038000
    [    2.600004] PC is at cf_axi_dds_probe+0x7c/0x9a0
    [    2.604584] LR is at cf_axi_dds_probe+0x70/0x9a0
    [    2.609168] pc : [<ffffff800881feac>] lr : [<ffffff800881fea0>] pstate: 80000145
    [    2.616520] sp : ffffff800803bbe0
    [    2.619807] x29: ffffff800803bbf0 x28: ffffffc03fee0cc0
    [    2.625083] x27: ffffff8008c91000 x26: ffffffc02e155c10
    [    2.630360] x25: ffffffc02e155c00 x24: ffffff8008c91fe8
    [    2.635636] x23: 0000000000000000 x22: ffffffc007432000
    [    2.640913] x21: ffffff800902fa90 x20: ffffffc02e155c10
    [    2.646189] x19: ffffffc007432500 x18: 0000000000000001
    [    2.651466] x17: 0000000000000000 x16: 0000000000000008
    [    2.656742] x15: ffffffffffffffff x14: ffffffc0074c760c
    [    2.662019] x13: ffffffc0074c760b x12: 0000000000000028
    [    2.667295] x11: 0000000000000001 x10: 0101010101010101
    [    2.672572] x9 : ffffff800803bba0 x8 : 7f7f7f7f7f7f7f7f
    [    2.677848] x7 : ffffff800803bba0 x6 : ffffffc0074c760a
    [    2.683125] x5 : 0000000000000000 x4 : 0000000000000000
    [    2.688401] x3 : 0000000000000032 x2 : 0000000000000000
    [    2.693678] x1 : 0000000000000200 x0 : ffffffc02e155c10
    [    2.698955] Process swapper/0 (pid: 1, stack limit = 0xffffff8008038000)
    [    2.705615] Call trace:
    [    2.708038] Exception stack(0xffffff800803baa0 to 0xffffff800803bbe0)
    [    2.714440] baa0: ffffffc02e155c10 0000000000000200 0000000000000000 0000000000000032
    [    2.722225] bac0: 0000000000000000 0000000000000000 ffffffc0074c760a ffffff800803bba0
    [    2.730010] bae0: 7f7f7f7f7f7f7f7f ffffff800803bba0 0101010101010101 0000000000000001
    [    2.737795] bb00: 0000000000000028 ffffffc0074c760b ffffffc0074c760c ffffffffffffffff
    [    2.745580] bb20: 0000000000000008 0000000000000000 0000000000000001 ffffffc007432500
    [    2.753365] bb40: ffffffc02e155c10 ffffff800902fa90 ffffffc007432000 0000000000000000
    [    2.761150] bb60: ffffff8008c91fe8 ffffffc02e155c00 ffffffc02e155c10 ffffff8008c91000
    [    2.768935] bb80: ffffffc03fee0cc0 ffffff800803bbf0 ffffff800881fea0 ffffff800803bbe0
    [    2.776720] bba0: ffffff800881feac 0000000080000145 00000000fffffffe ffffffc02e155c10
    [    2.784505] bbc0: ffffffffffffffff ffffff800902fab8 ffffff800803bbf0 ffffff800881feac
    [    2.792290] [<ffffff800881feac>] cf_axi_dds_probe+0x7c/0x9a0
    [    2.797915] [<ffffff800857e2d8>] platform_drv_probe+0x58/0xb8
    [    2.803622] [<ffffff800857c6d4>] driver_probe_device+0x22c/0x2d8
    [    2.809590] [<ffffff800857c83c>] __driver_attach+0xbc/0xc0
    [    2.815040] [<ffffff800857a814>] bus_for_each_dev+0x4c/0x98
    [    2.820575] [<ffffff800857bfd0>] driver_attach+0x20/0x28
    [    2.825852] [<ffffff800857bb20>] bus_add_driver+0x1b8/0x228
    [    2.831389] [<ffffff800857d1d8>] driver_register+0x60/0xf8
    [    2.836838] [<ffffff800857e228>] __platform_driver_register+0x40/0x48
    [    2.843240] [<ffffff8008f5e3a0>] cf_axi_dds_driver_init+0x18/0x20
    [    2.849295] [<ffffff8008083980>] do_one_initcall+0x38/0x128
    [    2.854830] [<ffffff8008f30ccc>] kernel_init_freeable+0x138/0x1d8
    [    2.860886] [<ffffff8008ab41b8>] kernel_init+0x10/0x100
    [    2.866075] [<ffffff8008084c10>] ret_from_fork+0x10/0x18
    [    2.871352] Code: 97f5774f aa0003f7 911402d3 aa1a03e0 (a94006e2)
    [    2.877410] ---[ end trace 0026aaaea3a413a4 ]---
    [    2.882014] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
  • +1
    on Jan 13, 2021 7:44 AM in reply to astone21480
    You also don't need the TPL HDL core?
    I guess you do. Try without DMA, I thought there is also a SYNTHESIS option.
    Then forget about the ad9361-x2 stuff. And assign each TRX it's own RX & TX TPL with all required dt properties.
    -Michael
  • Sorry, not sure what you mean by "TPL".  What is that acronym refer to?
    TPL HDL core?
    on Jan 14, 2021 8:44 AM in reply to astone21480
    TPL stands for Transport Layer - the AXI_AD9361 IP core ...
    https://wiki.analog.com/resources/fpga/docs/axi_ad9361
  • Hi mhennerich,
        I had some hardware problems on my custom board that I have since tracked down and remedied.  Now, I am seeing 1 of the 4 AD9361s successfully initialize, but not all 4.  What is interesting is that it runs the ad9361_probe twice in the boot sequence.  The first time all 4 boards are attempted to be initialized, but it runs into a problem with the reset (is there a timer built in to give it enough time to reset??).
    line 9395:  if (IS_ERR(phy->pdata->reset_gpio))
    The second time only the first AD9361 fully initializes.  Some notes.  My design uses 1 reset line for all 4 chips.  If this is a major problem, I can alter this going forward.
    I am hitting a wall here.  My next step was to hook up the debugger.  Any suggestions on what/how to change device tree?
    Log of bootup messages that are pertinent:
    [    1.371716] ad9361 spi1.0: ad9361_probe : enter (ad9361)
    [    1.372657] Error line 9395
    [    1.372741] ad9361 spi1.1: ad9361_probe : enter (ad9361)
    [    1.373743] ad9361 spi1.1: ad9361_reset: by SPI, this may cause unpredicted behavior!
    [    1.373797] Error line 9446 PRODUCT ID doesn't match 0xFF
    [    1.373814] ad9361 spi1.1: ad9361_probe : Unsupported PRODUCT_ID 0xFF
    [    1.373898] ad9361 spi1.2: ad9361_probe : enter (ad9361)
    [    1.374895] ad9361 spi1.2: ad9361_reset: by SPI, this may cause unpredicted behavior!
    [    1.374946] Error line 9446 PRODUCT ID doesn't match 0xFF
    [    1.374962] ad9361 spi1.2: ad9361_probe : Unsupported PRODUCT_ID 0xFF
    [    1.375046] ad9361 spi2.0: ad9361_probe : enter (ad9361)
    [    1.376035] ad9361 spi2.0: ad9361_reset: by SPI, this may cause unpredicted behavior!
    [    1.376086] Error line 9446 PRODUCT ID doesn't match 0xFF
    [    1.376102] ad9361 spi2.0: ad9361_probe : Unsupported PRODUCT_ID 0xFF
    [    3.311085] ad9361 spi1.0: ad9361_probe : enter (ad9361)
    [    3.460268] ad9361 spi1.0: ad9361_probe : AD936x Rev 2 successfully initialized
    [    4.297600] cf_axi_adc 99020000.axi_ad9361: ADI AIM (10.00.b) at 0x99020000 mapped to 0xffffff800bd20000, probed ADC AD        9361 as MASTER
    [    4.311676] rtc_zynqmp ffa60000.rtc: setting system clock to 2021-01-20 22:58:38 UTC (1611183518)
    Here is my updated device tree files:
        memory {
        chosen {
        bootargs = "earlycon clk_ignore_unused cpuidle.off=1";
        /*cf_ad9361_dac_core_0: cf-ad9361-dds-core-lpc@99024000 {*/
        /*        compatible = "adi,axi-ad9361-dds-6.00.a";      */
        /*        reg = <0x0 0x99024000 0x0 0x1000>;             */
        /*        clocks = <&adc0_ad9361 13>;                    */
        /*        clock-names = "sampl_clk";                     */
        /*        dmas = <&axi_ad9361_dac_dma 0>;                */
        /*        dma-names = "tx";                              */
        /*        slavecore-reg = <0x99044000 0x1000>;           */
        /*cf_ad9361_dac_core_1: cf-ad9361-dds-core-B@99044000 {  */
        /*        compatible = "adi,axi-ad9361x2-dds-6.00.a";    */
        /*        reg = <0x0 0x99044000 0x0 0x1000>;             */
        /*        clocks = <&adc1_ad9361 13>;                    */
        /*        mastercore-reg = <0x99024000 0x1000>;          */
        /*cf_ad9361_dac_core_2: cf-ad9361-dds-core-C@99064000 {  */
        /*        reg = <0x0 0x99064000 0x0 0x1000>;             */
        /*        clocks = <&adc2_ad9361 13>;                    */
        /*cf_ad9361_dac_core_3: cf-ad9361-dds-core-D@99084000 {  */
        /*        reg = <0x0 0x99084000 0x0 0x1000>;             */
        /*        clocks = <&adc3_ad9361 13>;                    */
    &tsu_ext_clk {
    &gem0 {
        phy9: phy@9 {
            reg = <0x9>;
    &i2c0 {
    status = "okay";
        lm87@2e {
            reg = <0x2e>;
            has-in6;
            has-in7;
        ad7291@20 {
            reg = <0x20>;
    /* PRFI DMA */
    &axi_dmac_0 {
        adi,channels {
            #size-cells = <0>;
            dma-channel@0 {
                reg = <0>;
        adi,channels {
            #size-cells = <0>;
            dma-channel@0 {
                reg = <0>;
        adi,channels {
                #size-cells = <0>;
            dma-channel@0 {
                reg = <0>;
                /*dmas = <&axi_ad9361_adc_dma 0>;*/
                /*dma-names = "rx";*/
                /*slavecore-reg = <0x99040000 0x6000>;*/
    &adc0_ad9361 {
    &adc1_ad9361 {
    &adc2_ad9361 {
    &adc3_ad9361 {
    	clocks {
    			#clock-cells = <0>;
    &spi0 {
    		#size-cells = <0>;
    		#clock-cells = <1>;
    		/* SPI Setup */
    		reg = <0>;
    		spi-cpha;
    		/* Clocks */
    		/* Mode Setup */
    		/* ENSM Mode */
    		 * 0	TX1A, TX2A
    		 * 1	TX1B, TX2B
    		/* Gain Control */
    		 * 0 = RF_GAIN_MGC
    		 * 1 = only in LPF
    		 * 2 = only in LMT
    		/* Fast AGC */
    		/* RSSI */
    		#size-cells = <0>;
    		#clock-cells = <1>;
    		/* SPI Setup */
    		reg = <1>;
    		spi-cpha;
    		/* Clocks */
    		/* Mode Setup */
    		/* ENSM Mode */
    		 * 0	TX1A, TX2A
    		 * 1	TX1B, TX2B
    		/* Gain Control */
    		 * 0 = RF_GAIN_MGC
    		 * 1 = only in LPF
    		 * 2 = only in LMT
    		/* Fast AGC */
    		/* RSSI */
    		#size-cells = <0>;
    		#clock-cells = <1>;
    		/* SPI Setup */
    		reg = <2>;
    		spi-cpha;
    		/* Clocks */
    		/* Mode Setup */
    		/* ENSM Mode */
    		 * 0	TX1A, TX2A
    		 * 1	TX1B, TX2B
    		/* Gain Control */
    		 * 0 = RF_GAIN_MGC
    		 * 1 = only in LPF
    		 * 2 = only in LMT
    		/* Fast AGC */
    		/* RSSI */
    &spi1 {
    		#size-cells = <0>;
    		#clock-cells = <1>;
    		/* SPI Setup */
    		reg = <0>;
    		spi-cpha;
    		/* Clocks */
    		/* Mode Setup */
    		/* ENSM Mode */
    		 * 0	TX1A, TX2A
    		 * 1	TX1B, TX2B
    		/* Gain Control */
    		 * 0 = RF_GAIN_MGC
    		 * 1 = only in LPF
    		 * 2 = only in LMT
    		/* Fast AGC */
    		/* RSSI */
