adrv9009-zu11eg-adrv2crr SFP ethernet clock
The user is trying to generate a 125MHz or 156.25MHz differential clock from the AD9545 on the ADRV9009-ZU11EG Rev.B board to support Ethernet on the PL side. The final solution involves configuring the AD9545 with the correct output driver mode (DRIVER_MODE_SINGLE_DIV_DIF) and ensuring the PLL1 is locked. The user confirmed the clock is generated successfully, but the Xilinx PCS/PMA IP does not recognize it, possibly due to PLL loop bandwidth settings.
I am trying to add ethernet to PL side of SOM system with carrier board. Both 10G or 1G Xilinx ethernet subsystems need 125MHz or 156.25MHz differential clock from FPGA pins. However, I am not sure where to get these clocks from. There are clocks in the carrier board like SFP_REFCLK, ETH_REFCLK1. SFP_REFCLK is generated from HMC7044. In the reference design of this system, HMC7044 pll2 output frequency is set as 2949.12MHz which can be divided by even numbers in the range 0-4096 to output a clock at the SFP_REFCLK as shown in https://github.com/analogdevicesinc/linux/blob/master/arch/arm64/boot/dts/xilinx/zynqmp-adrv9009-zu11eg-reva-adrv2crr-fmc-reva.dts . However, with this configuration, we cannot obtain 156.25MHz or 125MHz with any division. I could not find information regarding ETH_REFCLK1 which is the output of ad9545. I could not find dt-binding about this chip so that I can get my desired clock rate. Is it possible that this ETH_REFCLK1 in the carrier board provides 125 MHz default frequency?
Wrapping up everything, how can I get this 125MHz or 156.25MHz clock while using adrv9009-zu11eg reference design provided by ADI?
Thanks in advance,
Sermed
  • Hi Sermed,
    We have a Linux driver for ad9545 done. It is used to generate the above frequencies on this board. We will test the SFP and come back with an answer.
    Alexandru
    I have seen that you added ad9545 driver to the linux-master branch. Looking at the schematics of the adrv2crr board, I added the below device tree to system-user.dtsi in petalinux. However, I could not obtain any clock from the ETH_REFCLK1 pin. What is wrong or missing in this device tree part?
    /include/ "system-conf.dtsi"
     * I2C1
    #include <dt-bindings/clock/ad9545.h>
    &i2c1 {
    	status = "okay";
    	clock-frequency = <400000>;
    	pinctrl-names = "gpio";
    	pinctrl-0 = <&pinctrl_i2c1_gpio>;
    	scl-gpios = <&gpio 32 GPIO_ACTIVE_HIGH>;
    	sda-gpios = <&gpio 33 GPIO_ACTIVE_HIGH>;
    	i2c-mux@70 { /* u19 */
    		compatible = "nxp,pca9548"; /* TCA9548 */
    		#address-cells = <1>;
    		#size-cells = <0>;
    		reg = <0x70>;
    		i2c@0 { /* Audio ADAU1761 */
    			#size-cells = <0>;
    			reg = <0>;
    			adau1761: adau1761@3b {
    				compatible = "adi,adau1761";
    				reg = <0x3b>;
    				clocks = <&audio_clock>;
    				clock-names = "mclk";
    				#sound-dai-cells = <0>;
    		i2c@1 {
                #size-cells = <0>;
                ad9545_clock: ad9545@4A {
                        compatible = "adi,ad9545";
                        reg = <0x4A>;
                        #size-cells = <0>;
                        adi,ref-crystal;
                        adi,ref-frequency-hz = <49152000>;
                        #clock-cells = <2>;
                        clock-output-names = "OUT1B-P", "OUT1B-N";
                        ad9545_apll1: pll-clk@1 {
                            reg = <1>;
                            adi,pll-source = <4>;
                            adi,pll-loop-bandwidth-hz = <200>;
                        aux_nco0: aux-nco-clk@0 {
                        	reg = <0>;
                        	adi,freq-lock-threshold-ps = <100000>;
                        	adi,phase-lock-threshold-ps = <100000>;
                        output-clk@8 {
                            reg = <8>;
                            adi,init-freq-hz = <156250000>;
                            adi,init-phase = <0>;
                            adi,output-mode = <DRIVER_MODE_SINGLE_DIV_DIF>;
                            adi,current-source-microamp = <15000>;
                        output-clk@9 {
                            reg = <9>;
                            adi,init-phase = <180>;
    			/* 4A */
    		i2c@2 { /* PTN5150 */
    			#size-cells = <0>;
    			reg = <2>;
    			/* 1D */
    		i2c@3 { /* QSFP */
    			#size-cells = <0>;
    			reg = <3>;
    			eeprom@50 {
    				compatible = "at24,24c02";
    				reg = <0x50>;
    		i2c@4 { /* SFP+ */
    			#size-cells = <0>;
    			reg = <4>;
    			eeprom@50 {
    				reg = <0x50>;
    		i2c@5 { /* FMC HPC */
    			#size-cells = <0>;
    			reg = <5>;
    // 			ad7291@2f {
    // 				compatible = "adi,ad7291";
    // 				reg = <0x2f>;
    			eeprom@50 {
    				reg = <0x50>;
    Sermed
  • Hi Sermed,
    Can you replace the ad9545 node with this one:
        reg = <0x4A>;
        #size-cells = <0>;
        adi,ref-crystal;
        #clock-cells = <2>;
        assigned-clocks = <&ad9545_clock AD9545_CLK_NCO AD9545_NCO0>,
                  <&ad9545_clock AD9545_CLK_PLL AD9545_PLL1>,
                  <&ad9545_clock AD9545_CLK_OUT AD9545_Q1A>,
                  <&ad9545_clock AD9545_CLK_OUT AD9545_Q1B>;
        assigned-clock-rates = <10000>, <1875000000>, <156250000>, <156250000>;
        assigned-clock-phases = <0>, <0>, <0>, <180>;
        aux-nco-clk@AD9545_NCO0 {
            reg = <AD9545_NCO0>;
            adi,freq-lock-threshold-ps = <16000000>;
            adi,phase-lock-threshold-ps = <16000000>;
        ad9545_apll1: pll-clk@AD9545_PLL1 {
          reg = <AD9545_PLL1>;
        output-clk@AD9545_Q1A {
          reg = <AD9545_Q1A>;
          adi,output-mode = <DRIVER_MODE_DUAL_DIV>;
        output-clk@AD9545_Q1B {
          reg = <AD9545_Q1B>;
    Alexandru Tachici
    I have tried what you suggested. I fixed couple of my mistakes but still could not obtain the clock. Not sure if I'm making a mistake. I changed the fpga pin from  ETH_REFCLK1 to ETH_REFCLK2 as SFP is in the corresponding transceiver quad. In this device tree, both OUT1A and OUT1B is programmed as 156.25MHz, so there should not be a problem. Did you have a chance to try this?
  • Hi Sermed,
    I have updated today the driver in the Linux main branch: https://github.com/analogdevicesinc/linux/pull/1372. Please try running the latest Linux image and if nothing works run a "dmesg" and paste ithe output here. I have tested this on the eval-board and there should be no problem. I will try a test on the same board as yours too.
    Result is the same. Here is the dmesg output:
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 4.19.0-xilinx-v2019.2 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Thu Jan 7 08:17:49 UTC 2021
    [    0.000000] Machine model: Analog Devices ADRV9009-ZU11EG Rev.B
    [    0.000000] earlycon: cdns0 at MMIO 0x00000000ff010000 (options '115200n8')
    [    0.000000] bootconsole [cdns0] enabled
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] efi: UEFI not found.
    [    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
    [    0.000000] On node 0 totalpages: 1048576
    [    0.000000]   DMA32 zone: 7168 pages used for memmap
    [    0.000000]   DMA32 zone: 0 pages reserved
    [    0.000000]   DMA32 zone: 524288 pages, LIFO batch:63
    [    0.000000]   Normal zone: 7168 pages used for memmap
    [    0.000000]   Normal zone: 524288 pages, LIFO batch:63
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] psci: SMC Calling Convention v1.1
    [    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
    [    0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s53656 r8192 d32360 u94208
    [    0.000000] pcpu-alloc: s53656 r8192 d32360 u94208 alloc=23*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: enabling workaround for ARM erratum 845719
    [    0.000000] Speculative Store Bypass Disable mitigation not required
    [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1034240
    [    0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
    [    0.000000] software IO TLB: mapped [mem 0x6bfff000-0x6ffff000] (64MB)
    [    0.000000] Memory: 3772148K/4194304K available (12924K kernel code, 1548K rwdata, 13520K rodata, 896K init, 335K bss, 160012K reserved, 26214)
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x7b0074340, max_idle_ns: 440795202884 ns
    [    0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255543ns
    [    0.008231] Console: colour dummy device 80x25
    [    0.012390] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332)
    [    0.022667] pid_max: default: 32768 minimum: 301
    [    0.027349] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.033921] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.041621] ASID allocator initialised with 32768 entries
    [    0.046413] rcu: Hierarchical SRCU implementation.
    [    0.051420] EFI services will not be available.
    [    0.055725] smp: Bringing up secondary CPUs ...
    [    0.060368] Detected VIPT I-cache on CPU1
    [    0.060395] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.060672] Detected VIPT I-cache on CPU2
    [    0.060689] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.060946] Detected VIPT I-cache on CPU3
    [    0.060963] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.061002] smp: Brought up 1 node, 4 CPUs
    [    0.095586] SMP: Total of 4 processors activated.
    [    0.100259] CPU features: detected: 32-bit EL0 Support
    [    0.106582] CPU: All CPU(s) started at EL2
    [    0.109437] alternatives: patching kernel code
    [    0.114681] devtmpfs: initialized
    [    0.125468] Registered cp15_barrier emulation handler
    [    0.125518] Registered setend emulation handler
    [    0.129479] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.139071] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.150139] xor: measuring software checksum speed
    [    0.189266]    8regs     :  2639.000 MB/sec
    [    0.229293]    8regs_prefetch:  2280.000 MB/sec
    [    0.269318]    32regs    :  3027.000 MB/sec
    [    0.309345]    32regs_prefetch:  2565.000 MB/sec
    [    0.309385] xor: using function: 32regs (3027.000 MB/sec)
    [    0.313687] pinctrl core: initialized pinctrl subsystem
    [    0.319418] NET: Registered protocol family 16
    [    0.323558] audit: initializing netlink subsys (disabled)
    [    0.328743] audit: type=2000 audit(0.272:1): state=initialized audit_enabled=0 res=1
    [    0.336365] cpuidle: using governor menu
    [    0.340379] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
    [    0.347593] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.354944] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.372300] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.439031] raid6: int64x1  gen()   494 MB/s
    [    0.507065] raid6: int64x1  xor()   501 MB/s
    [    0.575093] raid6: int64x2  gen()   756 MB/s
    [    0.643155] raid6: int64x2  xor()   666 MB/s
    [    0.711187] raid6: int64x4  gen()  1089 MB/s
    [    0.779225] raid6: int64x4  xor()   819 MB/s
    [    0.847266] raid6: int64x8  gen()  1291 MB/s
    [    0.915291] raid6: int64x8  xor()   843 MB/s
    [    0.983372] raid6: neonx1   gen()   816 MB/s
    [    1.051385] raid6: neonx1   xor()   979 MB/s
    [    1.119417] raid6: neonx2   gen()  1252 MB/s
    [    1.187465] raid6: neonx2   xor()  1297 MB/s
    [    1.255515] raid6: neonx4   gen()  1640 MB/s
    [    1.323543] raid6: neonx4   xor()  1569 MB/s
    [    1.391610] raid6: neonx8   gen()  1711 MB/s
    [    1.459638] raid6: neonx8   xor()  1613 MB/s
    [    1.459675] raid6: using algorithm neonx8 gen() 1711 MB/s
    [    1.463631] raid6: .... xor() 1613 MB/s, rmw enabled
    [    1.468562] raid6: using neon recovery algorithm
    [    1.474059] SCSI subsystem initialized
    [    1.476898] libata version 3.00 loaded.
    [    1.477031] usbcore: registered new interface driver usbfs
    [    1.482358] usbcore: registered new interface driver hub
    [    1.487631] usbcore: registered new device driver usb
    [    1.492784] media: Linux media interface: v0.10
    [    1.497129] videodev: Linux video capture interface: v2.00
    [    1.502602] pps_core: LinuxPPS API ver. 1 registered
    [    1.507489] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.516582] PTP clock support registered
    [    1.520478] EDAC MC: Ver: 3.0.0
    [    1.523929] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
    [    1.531401] jesd204: created con: id=0, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@84a30000 <-> /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000
    [    1.543049] jesd204: created con: id=1, topo=0, link=0, /fpga-axi@0/axi-adxcvr-tx@84a20000 <-> /fpga-axi@0/axi-jesd204-tx@84a30000
    [    1.554725] jesd204: created con: id=2, topo=0, link=0, /amba/spi@ff040000/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-tx@84a20000
    [    1.565796] jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcvr-rx-os@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84a70000
    [    1.577735] jesd204: created con: id=4, topo=0, link=2, /amba/spi@ff040000/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-rx-os@84a60000
    [    1.589064] jesd204: created con: id=5, topo=0, link=1, /fpga-axi@0/axi-adxcvr-rx@84a40000 <-> /fpga-axi@0/axi-jesd204-rx@84a50000
    [    1.600742] jesd204: created con: id=6, topo=0, link=1, /amba/spi@ff040000/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-rx@84a40000
    [    1.611818] jesd204: created con: id=7, topo=0, link=1, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff050000/hmc7044-fmc@2
    [    1.623059] jesd204: created con: id=8, topo=0, link=2, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff050000/hmc7044-fmc@2
    [    1.634305] jesd204: created con: id=9, topo=0, link=0, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff050000/hmc7044-fmc@2
    [    1.645564] jesd204: created con: id=10, topo=0, link=1, /fpga-axi@0/axi-jesd204-rx@84a50000 <-> /amba/spi@ff050000/adrv9009-phy-d@1
    [    1.657408] jesd204: created con: id=11, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx@84a70000 <-> /amba/spi@ff050000/adrv9009-phy-d@1
    [    1.669258] jesd204: created con: id=12, topo=0, link=0, /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000 <-> /amba/spi@ff050000/adrv9009-phy-d@1
    [    1.681578] jesd204: created con: id=13, topo=0, link=1, /amba/spi@ff050000/adrv9009-phy-d@1 <-> /amba/spi@ff050000/adrv9009-phy-c@0
    [    1.693406] jesd204: created con: id=14, topo=0, link=2, /amba/spi@ff050000/adrv9009-phy-d@1 <-> /amba/spi@ff050000/adrv9009-phy-c@0
    [    1.705263] jesd204: created con: id=15, topo=0, link=0, /amba/spi@ff050000/adrv9009-phy-d@1 <-> /amba/spi@ff050000/adrv9009-phy-c@0
    [    1.717091] jesd204: created con: id=16, topo=0, link=1, /amba/spi@ff050000/hmc7044-fmc@2 <-> /amba/spi@ff040000/hmc7044@0
    [    1.728075] jesd204: created con: id=17, topo=0, link=2, /amba/spi@ff050000/hmc7044-fmc@2 <-> /amba/spi@ff040000/hmc7044@0
    [    1.739058] jesd204: created con: id=18, topo=0, link=0, /amba/spi@ff050000/hmc7044-fmc@2 <-> /amba/spi@ff040000/hmc7044@0
    [    1.750085] jesd204: created con: id=19, topo=0, link=1, /amba/spi@ff050000/adrv9009-phy-c@0 <-> /amba/spi@ff040000/adrv9009-phy-b@0
    [    1.761916] jesd204: created con: id=20, topo=0, link=2, /amba/spi@ff050000/adrv9009-phy-c@0 <-> /amba/spi@ff040000/adrv9009-phy-b@0
    [    1.773771] jesd204: created con: id=21, topo=0, link=0, /amba/spi@ff050000/adrv9009-phy-c@0 <-> /amba/spi@ff040000/adrv9009-phy-b@0
    [    1.785638] jesd204: created con: id=22, topo=0, link=1, /amba/spi@ff040000/adrv9009-phy-b@0 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.797292] jesd204: created con: id=23, topo=0, link=2, /amba/spi@ff040000/adrv9009-phy-b@0 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.808979] jesd204: created con: id=24, topo=0, link=0, /amba/spi@ff040000/adrv9009-phy-b@0 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    1.820687] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[0] transition uninitialized -> initialized
    [    1.830225] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[1] transition uninitialized -> initialized
    [    1.839825] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[2] transition uninitialized -> initialized
    [    1.849426] jesd204: found 14 devices and 1 topologies
    [    1.854562] FPGA manager framework
    [    1.858055] Advanced Linux Sound Architecture Driver Initialized.
    [    1.864228] Bluetooth: Core ver 2.22
    [    1.867521] NET: Registered protocol family 31
    [    1.871918] Bluetooth: HCI device and connection manager initialized
    [    1.878234] Bluetooth: HCI socket layer initialized
    [    1.883076] Bluetooth: L2CAP socket layer initialized
    [    1.888103] Bluetooth: SCO socket layer initialized
    [    1.893304] clocksource: Switched to clocksource arch_sys_counter
    [    1.899066] VFS: Disk quotas dquot_6.6.0
    [    1.902920] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    1.913556] NET: Registered protocol family 2
    [    1.914352] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
    [    1.921867] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
    [    1.929190] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
    [    1.935926] TCP: Hash tables configured (established 32768 bind 32768)
    [    1.942125] UDP hash table entries: 2048 (order: 4, 65536 bytes)
    [    1.948101] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
    [    1.954582] NET: Registered protocol family 1
    [    1.958966] RPC: Registered named UNIX socket transport module.
    [    1.964650] RPC: Registered udp transport module.
    [    1.969317] RPC: Registered tcp transport module.
    [    1.973989] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.980612] PCI: CLS 0 bytes, default 64
    [    1.981004] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    1.987619] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    1.995936] Initialise system trusted keyrings
    [    1.999646] workingset: timestamp_bits=62 max_order=20 bucket_order=0
    [    2.006618] NFS: Registering the id_resolver key type
    [    2.011024] Key type id_resolver registered
    [    2.015163] Key type id_legacy registered
    [    2.019146] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    2.025812] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
    [    3.006113] NET: Registered protocol family 38
    [    3.059218] Key type asymmetric registered
    [    3.059256] Asymmetric key parser 'x509' registered
    [    3.062551] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    3.069879] io scheduler noop registered
    [    3.073769] io scheduler deadline registered
    [    3.078022] io scheduler cfq registered (default)
    [    3.082679] io scheduler mq-deadline registered
    [    3.087176] io scheduler kyber registered
    [    3.116453] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    3.120119] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    3.127325] brd: module loaded
    [    3.130825] loop: module loaded
    [    3.131025] Registered mathworks_ip class
    [    3.134057] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    3.141078] libphy: Fixed MDIO Bus: probed
    [    3.144961] tun: Universal TUN/TAP device driver, 1.6
    [    3.148932] CAN device driver interface
    [    3.153466] usbcore: registered new interface driver asix
    [    3.158027] usbcore: registered new interface driver ax88179_178a
    [    3.164072] usbcore: registered new interface driver cdc_ether
    [    3.169866] usbcore: registered new interface driver net1080
    [    3.175490] usbcore: registered new interface driver cdc_subset
    [    3.181371] usbcore: registered new interface driver zaurus
    [    3.186920] usbcore: registered new interface driver cdc_ncm
    [    3.193095] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    3.198998] ehci-pci: EHCI PCI platform driver
    [    3.203629] usbcore: registered new interface driver uas
    [    3.208714] usbcore: registered new interface driver usb-storage
    [    3.214709] usbcore: registered new interface driver usbserial_generic
    [    3.221159] usbserial: USB Serial support registered for generic
    [    3.227129] usbcore: registered new interface driver ftdi_sio
    [    3.232834] usbserial: USB Serial support registered for FTDI USB Serial Device
    [    3.240103] usbcore: registered new interface driver upd78f0730
    [    3.245984] usbserial: USB Serial support registered for upd78f0730
    [    3.253198] i2c /dev entries driver
    [    3.257379] usbcore: registered new interface driver uvcvideo
    [    3.261365] USB Video Class driver (1.1.1)
    [    3.265904] axi_fan_control_driver 80000000.axi-fan-control: clk_get failed with -517
    [    3.273932] Bluetooth: HCI UART driver ver 2.3
    [    3.277633] Bluetooth: HCI UART protocol H4 registered
    [    3.282729] Bluetooth: HCI UART protocol BCSP registered
    [    3.288024] Bluetooth: HCI UART protocol LL registered
    [    3.293109] Bluetooth: HCI UART protocol ATH3K registered
    [    3.298488] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    3.304740] Bluetooth: HCI UART protocol Intel registered
    [    3.310080] Bluetooth: HCI UART protocol QCA registered
    [    3.315290] usbcore: registered new interface driver bcm203x
    [    3.320903] usbcore: registered new interface driver bpa10x
    [    3.326436] usbcore: registered new interface driver bfusb
    [    3.331886] usbcore: registered new interface driver btusb
    [    3.337312] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
    [    3.342976] usbcore: registered new interface driver ath3k
    [    3.348677] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT)
    [    3.358581] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    3.371151] sdhci: Secure Digital Host Controller Interface driver
    [    3.376670] sdhci: Copyright(c) Pierre Ossman
    [    3.380993] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.386958] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.392627] zynqmp_firmware_probe Platform Management API v1.1
    [    3.398384] zynqmp_firmware_probe Trustzone version v1.0
    [    3.406199] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
    [    3.433042] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
    [    3.435747] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
    [    3.440967] zynqmp_aes zynqmp_aes: AES Successfully Registered
    [    3.448378] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
    [    3.454547] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
    [    3.460064] usbcore: registered new interface driver usbhid
    [    3.465415] usbhid: USB HID core driver
    [    3.476368] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.00.a) found
    [    3.478742] axi_sysid 85000000.axi-sysid-0: [fmcomms8] on [adrv9009zu11eg] git <c0de649e2e656bd91b5da59523beaae7d04d0bfd> clean [2020-12-21 12C
    [    3.492529] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    3.499083] usbcore: registered new interface driver snd-usb-audio
    [    3.506571] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    3.512631] Initializing XFRM netlink socket
    [    3.516593] NET: Registered protocol family 10
    [    3.521307] Segment Routing with IPv6
    [    3.524640] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.530775] NET: Registered protocol family 17
    [    3.534871] NET: Registered protocol family 15
    [    3.539286] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need thi.
    [    3.552355] can: controller area network core (rev 20170425 abi 9)
    [    3.558335] NET: Registered protocol family 29
    [    3.562724] can: raw protocol (rev 20170425)
    [    3.566954] can: broadcast manager protocol (rev 20170425 t)
    [    3.572578] can: netlink gateway (rev 20170425) max_hops=1
    [    3.578089] Bluetooth: RFCOMM TTY layer initialized
    [    3.582875] Bluetooth: RFCOMM socket layer initialized
    [    3.587989] Bluetooth: RFCOMM ver 1.11
    [    3.591698] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    3.596969] Bluetooth: BNEP filters: protocol multicast
    [    3.602161] Bluetooth: BNEP socket layer initialized
    [    3.607089] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    3.612973] Bluetooth: HIDP socket layer initialized
    [    3.618004] 9pnet: Installing 9P2000 support
    [    3.622149] NET: Registered protocol family 36
    [    3.626565] Key type dns_resolver registered
    [    3.631201] registered taskstats version 1
    [    3.634860] Loading compiled-in X.509 certificates
    [    3.639908] Btrfs loaded, crc32c=crc32c-generic
    [    3.650020] ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 24, base_baud = 6249999) is a xuartps
    [    3.659331] console [ttyPS0] enabled
    [    3.662929] bootconsole [cdns0] disabled
    [    3.671237] GPIO line 13 (ulpi-phy-reset) hogged as output/high
    [    3.680418] of-fpga-region fpga-full: FPGA Region probed
    [    3.687213] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
    [    3.693905] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
    [    3.703278] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Failed to get required clock freq
    [    3.713391] xilinx-dp-snd-codec: probe of fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0 failed with error -22
    [    3.723460] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    3.731509] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    3.739557] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [    3.749624] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
    [    3.756715] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.763323] [drm] No driver support for vblank timestamp query.
    [    3.769289] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008de4cd8)
    [    4.857316] [drm] Cannot find any crtc or sizes
    [    4.862067] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
    [    4.870165] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
    [    4.879587] adrv9009 spi1.0: adrv9009_probe : enter
    [    4.885348] adrv9009 spi1.1: adrv9009_probe : enter
    [    4.938988] jesd204: /amba/spi@ff040000/hmc7044-car@3,jesd204:3,parent=spi1.3: Using as SYSREF provider
    [    4.997454] adrv9009 spi2.0: adrv9009_probe : enter
    [    5.002866] adrv9009 spi2.1: adrv9009_probe : enter
    [    5.029570] random: fast init done
    [    5.059873] m25p80 spi0.0: SPI-NOR-UniqueID 104000fe98960005100022007602444e4e
    [    5.068738] m25p80 spi0.0: n25q512a (131072 Kbytes)
    [    5.073624] 4 fixed-partitions partitions found on MTD device spi0.0
    [    5.079967] Creating 4 MTD partitions on "spi0.0":
    [    5.084752] 0x000000000000-0x000002000000 : "qspi-fsbl-uboot"
    [    5.090913] 0x000002000000-0x000002020000 : "qspi-uboot-env"
    [    5.096931] 0x000002020000-0x000002100000 : "qspi-nvmfs"
    [    5.102589] 0x000002100000-0x000007f00000 : "qspi-linux"
    [    5.108665] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    5.116043] libphy: MACB_mii_bus: probed
    [    5.151187] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    5.158536] libphy: MACB_mii_bus: probed
    [    5.233744] Marvell 88E1510 ff0e0000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:)
    [    5.247649] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 13 (00:0a:35:00:22:01)
    [    5.257800] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    5.264305] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
    [    5.270768] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
    [    5.277221] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
    [    5.285171] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
    [    5.291038] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:0 protocol:3 pll_locked:yes
    [    5.301124] OF: graph: no port node found in /amba/zynqmp_phy@fd400000/lane1
    [    5.416818] at24 0-002c: 2048 byte 24c16 EEPROM, writable, 1 bytes/write
    [    5.423576] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 15
    [    5.430926] i2c i2c-1: Added multiplexed i2c bus 3
    [    5.969319] [drm] Cannot find any crtc or sizes
    [    5.989776] ad9545 4-004a: PLL1 unlocked.
    [    5.993832] i2c i2c-1: Added multiplexed i2c bus 4
    [    5.998782] i2c i2c-1: Added multiplexed i2c bus 5
    [    6.030128] i2c i2c-1: Added multiplexed i2c bus 6
    [    6.035395] at24 7-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
    [    6.042046] i2c i2c-1: Added multiplexed i2c bus 7
    [    6.074709] i2c i2c-1: Added multiplexed i2c bus 8
    [    6.079639] i2c i2c-1: Added multiplexed i2c bus 9
    [    6.084571] i2c i2c-1: Added multiplexed i2c bus 10
    [    6.089441] pca954x 1-0070: registered 8 multiplexed busses for I2C switch pca9548
    [    6.097026] i2c i2c-1: of_i2c: modalias failure on /amba/i2c@ff030000/i2c@2
    [    6.103977] i2c i2c-1: Failed to create I2C device for /amba/i2c@ff030000/i2c@2
    [    6.111277] i2c i2c-1: of_i2c: modalias failure on /amba/i2c@ff030000/i2c@3
    [    6.118228] i2c i2c-1: Failed to create I2C device for /amba/i2c@ff030000/i2c@3
    [    6.125529] i2c i2c-1: of_i2c: modalias failure on /amba/i2c@ff030000/i2c@4
    [    6.132481] i2c i2c-1: Failed to create I2C device for /amba/i2c@ff030000/i2c@4
    [    6.139782] i2c i2c-1: of_i2c: modalias failure on /amba/i2c@ff030000/i2c@5
    [    6.146733] i2c i2c-1: Failed to create I2C device for /amba/i2c@ff030000/i2c@5
    [    6.154055] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 16
    [    6.160304] axi_fan_control_driver 80000000.axi-fan-control: Failed to initialize device
    [    6.168452] axi_fan_control_driver: probe of 80000000.axi-fan-control failed with error -22
    [    6.177201] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
    [    6.184695] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1333333 KHz
    [    6.192089] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    6.200821] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
    [    6.209350] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    6.249308] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
    [    6.266257] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [    6.276425] adrv9009 spi1.0: adrv9009_probe : enter
    [    6.282010] adrv9009 spi1.1: adrv9009_probe : enter
    [    6.335104] adrv9009 spi2.0: adrv9009_probe : enter
    [    6.344682] adrv9009 spi2.1: adrv9009_probe : enter
    [    6.354493] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    6.361882] libphy: MACB_mii_bus: probed
    [    6.390086] mmc0: Problem switching card into high-speed mode!
    [    6.396021] mmc0: new SDXC card at address 0001
    [    6.401013] mmcblk0: mmc0:0001 SD 58.3 GiB
    [    6.406736]  mmcblk0: p1 p2 p3
    [    6.449721] Marvell 88E1510 ff0e0000.ethernet-ffffffff:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:)
    [    6.463625] macb ff0b0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 12 (d6:ac:09:5a:17:b8)
    [    6.476353] axi_adxcvr 84a40000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using CPLL on GTH4 at 0x84A40000. Number of lanes: 8.
    [    6.489691] axi_adxcvr 84a60000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 8.
    [    6.502138] axi_adxcvr 84a20000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using QPLL on GTH4 at 0x84A20000. Number of lanes: 16.
    [    6.515753] asoc-simple-card talise_sound: adau-hifi <-> 82000000.axi-i2s-adi mapping ok
    [    6.527191] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [    6.537374] adrv9009 spi1.0: adrv9009_probe : enter
    [    6.547256] adrv9009 spi1.1: adrv9009_probe : enter
    [    6.578178] cf_axi_adc 84a00000.axi-adrv9009-rx-hpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0x(____ptrval____), probed ADC ADRV9009-X4 as MR
    [    6.614851] cf_axi_dds 84a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____),4
    [    6.629698] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition initialized -> probed
    [    6.640825] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition initialized -> probed
    [    6.651942] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
    [    6.663114] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
    [    6.673625] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition probed -> idle
    [    6.684136] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
    [    6.694702] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [    6.705647] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [    6.716591] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [    6.727593] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [    6.738977] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [    6.750357] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [    6.761794] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [    6.773438] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [    6.785077] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [    6.797372] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [    6.809454] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [    6.821525] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [    6.869370] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [    6.881534] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [    6.893701] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [    6.917362] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [    6.929613] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [    6.941866] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [    6.954840] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [    6.967094] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [    6.979347] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [    6.991600] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:8,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; 2
    [    7.006809] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:10,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips;2
    [    7.022218] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:12,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips;4
    [    7.038803] adrv9009 spi2.1: ADIHAL_resetHw
    [    7.378899] adrv9009 spi2.0: ADIHAL_resetHw
    [    7.782159] adrv9009 spi1.1: ADIHAL_resetHw
    [    8.110793] adrv9009 spi1.0: ADIHAL_resetHw
    [    8.509339] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [    8.521159] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [    8.532971] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [    8.546187] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [    8.558093] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [    8.570000] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [    8.657296] random: crng init done
    [   16.825636] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [   16.838062] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [   16.850492] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [   16.864413] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [   16.876836] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [   16.889266] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [   16.904221] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [   16.916645] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [   16.929073] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [   21.946901] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    [   21.959334] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage5
    [   21.971759] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    [   21.991738] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
    [   22.003903] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> clocks_enable
    [   22.016070] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
    [   22.029149] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
    [   22.040880] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clocks_enable -> link_enable
    [   22.052613] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
    [   22.101230] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
    [   22.112873] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_enable -> link_running
    [   22.124519] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
    [   22.238084] adrv9009 spi2.1: adrv9009_info: adrv9009 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   22.260734] adrv9009 spi2.0: adrv9009_info: adrv9009 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   22.283389] adrv9009 spi1.1: adrv9009_info: adrv9009 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   22.306134] adrv9009 spi1.0: adrv9009_info: adrv9009-x4 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   22.318818] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> opt_post_running_stage
    [   22.331418] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_running -> opt_post_running_stage
    [   22.344014] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> opt_post_running_stage
    [   22.357201] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [   22.367427] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [   22.379986] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [   22.386935] hctosys: unable to open rtc device (rtc0)
    [   22.391981] of_cfs_init
    [   22.394441] of_cfs_init: OK
    [   22.397427] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   22.405539] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [   22.523306] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   22.530588] ALSA device list:
    [   22.533549]   #0: ADRV9009 ZU11EG ADAU1761
    [   22.537914] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [   22.546523] cfg80211: failed to load regulatory.db
    [   22.574823] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [   22.582923] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [   22.590164] devtmpfs: mounted
    [   22.593285] Freeing unused kernel memory: 896K
    [   22.609326] Run /sbin/init as init process
    [   23.655992] systemd[1]: System time before build time, advancing clock.
    [   23.717457] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT)
    [   23.738975] systemd[1]: Detected architecture arm64.
    [   23.774397] systemd[1]: Set hostname to <arm>.
    [   24.409865] systemd[1]: File /lib/systemd/system/systemd-udevd.service:35 configures an IP firewall (IPAddressDeny=any), but the local system .
    [   24.426671] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
    [   24.552912] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [   24.577383] systemd[1]: Reached target Remote File Systems.
    [   24.593601] systemd[1]: Created slice User and Session Slice.
    [   24.609424] systemd[1]: Reached target Swap.
    [   24.625446] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [   25.235132] systemd-journald[2410]: Received request to flush runtime journal from PID 1
    [   25.331867] systemd-journald[2410]: File /var/log/journal/ccbd08173b4dcb8907efc0975a6df325/system.journal corrupted or uncleanly shut down, re.
    [   28.687110] pps pps0: new PPS source ptp0
    [   28.687122] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [   28.687242] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   28.710529] pps pps1: new PPS source ptp1
    [   28.710542] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered.
    [   28.710666] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   31.829900] macb ff0e0000.ethernet eth0: link up (1000/Full)
    [   31.829919] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  • Hi Sermed,
    Can you please run this cmd and paste the output here:
    cat /sys/kernel/debug/clk/clk_summary
    This should show the assigned frequencies to the auxiliary NCO1, PLL1 and the two outputs.
    Can you also paste the new device tree here?
    Alexandru
    Here is the output of clk_summary:
                                     enable  prepare  protect                      y
       clock                          count    count    count        rate   accurace
     spi1.1-tx_sampl_clk                  0        0        0   245760000          0
     spi1.1-obs_sampl_clk                 0        0        0   245760000          0
     spi1.1-rx_sampl_clk                  0        0        0   245760000          0
     spi1.0-tx_sampl_clk                  1        1        0   245760000          0
     spi1.0-obs_sampl_clk                 1        1        0   245760000          0
     spi1.0-rx_sampl_clk                  0        0        0   245760000          0
     spi2.1-tx_sampl_clk                  0        0        0   245760000          0
     spi2.1-obs_sampl_clk                 0        0        0   245760000          0
     spi2.1-rx_sampl_clk                  0        0        0   245760000          0
     spi2.0-tx_sampl_clk                  0        0        0   245760000          0
     spi2.0-obs_sampl_clk                 0        0        0   245760000          0
     spi2.0-rx_sampl_clk                  0        0        0   245760000          0
     hmc7044_e_out11_REFCLK_SFP           0        0        0   122880000          0
     hmc7044_e_out6_SYNC_OUT2             0        0        0      768000          0
     hmc7044_e_out5_SYNC_OUT1             0        0        0      768000          0
     hmc7044_e_out2_REFCLK_OUT2           0        0        0    30720000          0
     hmc7044_e_out0_REFCLK_OUT0           0        0        0    30720000          0
     hmc7044_c_out11_REFCLK_SFP           0        0        0   122880000          0
     hmc7044_c_out10_REFCLK_QSFP          0        0        0    30720000          0
     hmc7044_c_out9_REFCLK_OUT4           5        5        0    30720000          0
        hmc7044_fmc_out9_FPGA_SYSREF_RX_CD       0        0        0      768000   0
        hmc7044_fmc_out8_FPGA_SYSREF_TX_OBS_CD       0        0        0      768000
        hmc7044_fmc_out7_CORE_CLK_RX_CD       0        0        0   245760000      0
        hmc7044_fmc_out6_CORE_CLK_TX_OBS_CD       0        0        0   122880000  0
        hmc7044_fmc_out5_JESD_REFCLK_RX_CD       2        2        0   245760000   0
        hmc7044_fmc_out4_JESD_REFCLK_TX_OBS_CD       4        4        0   245760000
        hmc7044_fmc_out3_DEV_SYSREF_D       0        0        0     3840000        0
        hmc7044_fmc_out2_DEV_REFCLK_D       1        1        0   245760000        0
        hmc7044_fmc_out1_DEV_SYSREF_C       0        0        0     3840000        0
        hmc7044_fmc_out0_DEV_REFCLK_C       1        1        0   245760000        0
     hmc7044_c_out8_REFCLK_OUT3           0        0        0    30720000          0
     hmc7044_c_out6_SYNC_OUT2             0        0        0     3840000          0
     hmc7044_c_out5_SYNC_OUT1             0        0        0     3840000          0
     hmc7044_c_out2_REFCLK_OUT2           7        7        2    30720000          0
        hmc7044_out9_FPGA_SYSREF_RX_AB       0        0        0     3840000       0
        hmc7044_out8_FPGA_SYSREF_TX_OBS_AB       0        0        0     3840000   0
        hmc7044_out7_CORE_CLK_RX_AB       1        1        0   245760000          0
        hmc7044_out6_CORE_CLK_TX_OBS_AB       2        2        0   122880000      0
        hmc7044_out5_JESD_REFCLK_RX_AB       2        2        1   245760000       0
           rx_out_clk                     0        0        0   245760000          0
           rx_gt_clk                      1        1        1     9830400          0
        hmc7044_out4_JESD_REFCLK_TX_OBS_AB       4        4        2   245760000   0
           tx_out_clk                     0        0        0   245760000          0
           tx_gt_clk                      1        1        1     4915200          0
           rx_os_out_clk                  0        0        0   245760000          0
           rx_os_gt_clk                   1        1        1     4915200          0
        hmc7044_out3_DEV_SYSREF_B         0        0        0     3840000          0
        hmc7044_out2_DEV_REFCLK_B         1        1        0   245760000          0
        hmc7044_out1_DEV_SYSREF_A         0        0        0     3840000          0
        hmc7044_out0_DEV_REFCLK_A         1        1        0   245760000          0
     hmc7044_c_out0_REFCLK_OUT0           0        0        0    30720000          0
     audio_clock                          1        1        0    12288000          0
     dp_aclk                              1        1        0   100000000        100
     aux_ref_clk                          0        0        0    27000000          0
     gt_crx_ref_clk                       0        0        0   108000000          0
     pss_alt_ref_clk                      0        0        0           0          0
     video_clk                            0        0        0    27000000          0
     pss_ref_clk                          3        3        3    33333333          0
        vpll_post_src                     0        0        0    33333333          0
        vpll_pre_src                      0        0        0    33333333          0
           vpll_int                       0        0        0  2999999970          0
              vpll_half                   0        0        0  1499999985          0
                 vpll_int_mux             0        0        0  1499999985          0
                    vpll                  0        0        0  1499999985          0
                       dp_video_ref_mux       0        0        0  1499999985      0
                          dp_video_ref_div1       0        0        0   299999997  0
                             dp_video_ref_div2       0        0        0   299999990
                                dp_video_ref       0        0        0   299999997 0
                       vpll_to_lpd        0        0        0   499999995          0
        dpll_post_src                     0        0        0    33333333          0
        dpll_pre_src                      1        1        1    33333333          0
           dpll_int                       1        1        1  2399999976          0
              dpll_half                   1        1        1  1199999988          0
                 dpll_int_mux             1        1        1  1199999988          0
                    dpll                  1        1        1  1199999988          0
                       gpu_ref_mux        0        0        0  1199999988          0
                          gpu_ref_div1       0        0        0   599999994       0
                             gpu_ref       0        0        0   599999994         0
                                gpu_pp1_ref       0        0        0   599999994  0
                                gpu_pp0_ref       0        0        0   599999994  0
                       pcie_ref_mux       0        0        0  1199999988          0
                          pcie_ref_div1       0        0        0    99999999      0
                             pcie_ref       0        0        0    99999999        0
                       sata_ref_mux       0        0        0  1199999988          0
                          sata_ref_div1       0        0        0    99999999      0
                             sata_ref       0        0        0    99999999        0
                       dpdma_ref_mux       1        1        1  1199999988         0
                          dpdma_ref_div1       1        1        1   599999994     0
                             dpdma_ref       1        1        1   599999994       0
                       gdma_ref_mux       0        0        0  1199999988          0
                          gdma_ref_div1       0        0        0   599999994      0
                             gdma_ref       0        0        0   599999994        0
                       dp_stc_ref_mux       0        0        0  1199999988        0
                          dp_stc_ref_div1       0        0        0    26666667    0
                             dp_stc_ref_div2       0        0        0    26666667 0
                                dp_stc_ref       0        0        0    26666667   0
                       dp_audio_ref_mux       0        0        0  1199999988      0
                          dp_audio_ref_div1       0        0        0    22641510  0
                             dp_audio_ref_div2       0        0        0    22641510
                                dp_audio_ref       0        0        0    22641510 0
                       dpll_to_lpd        0        0        0   399999996          0
        apll_post_src                     0        0        0    33333333          0
        apll_pre_src                      0        0        0    33333333          0
           apll_int                       0        0        0  2666666640          0
              apll_half                   0        0        0  1333333320          0
                 apll_int_mux             0        0        0  1333333320          0
                    apll                  0        0        0  1333333320          0
                       acpu_mux           0        0        0  1333333320          0
                          acpu            0        0        0  1333333320          0
        rpll_post_src                     0        0        0    33333333          0
        rpll_pre_src                      1        1        1    33333333          0
           rpll_int                       1        1        1  1999999980          0
              rpll_half                   1        1        1   999999990          0
                 rpll_int_mux             1        1        1   999999990          0
                    rpll                  1        1        1   999999990          0
                       adma_ref_mux       0        0        0   999999990          0
                          adma_ref_div1       0        0        0   499999995      0
                             adma_ref       0        0        0   499999995        0
                       spi1_ref_mux       0        0        0   999999990          0
                          spi1_ref_div1       0        0        0   199999998      0
                             spi1_ref_div2       0        0        0   199999998   0
                                spi1_ref       0        0        0   199999998     0
                       spi0_ref_mux       0        0        0   999999990          0
                          spi0_ref_div1       0        0        0    99999999      0
                             spi0_ref_div2       0        0        0    99999999   0
                                spi0_ref       0        0        0    99999999     0
                       sdio1_ref_mux       1        1        1   999999990         0
                          sdio1_ref_div1       1        1        1   199999998     0
                             sdio1_ref_div2       1        1        1   199999998  0
                                sdio1_ref       1        1        1   199999998    0
                       rpll_to_fpd        0        0        0   499999995          0
        iopll_post_src                    0        0        0    33333333          0
        iopll_pre_src                     1        1        1    33333333          0
           iopll_int                      1        1        1  2999999970          0
              iopll_half                  1        1        1  1499999985          0
                 iopll_int_mux            1        1        1  1499999985          0
                    iopll                13       15        8  1499999985          0
                       gem3_ref_ung_mux       1        1        0  1499999985      0
                          gem3_ref_ung_div1       1        1        0  1499999985  0
                             gem3_ref_ung       1        1        0   124999999    0
                                gem3_ref       2        2        0   124999999     0
                                   gem3_tx       1        1        0   124999999   0
                       gem2_ref_ung_mux       0        0        0  1499999985      0
                          gem2_ref_ung_div1       0        0        0    62500000  0
                             gem2_ref_ung       0        0        0    62500000    0
                                gem2_ref       0        0        0    62500000     0
                                   gem2_tx       0        0        0    62500000   0
                       gem1_ref_ung_mux       0        0        0  1499999985      0
                          gem1_ref_ung_div1       0        0        0    62500000  0
                             gem1_ref_ung       0        0        0    62500000    0
                                gem1_ref       0        0        0    62500000     0
                                   gem1_tx       0        0        0    62500000   0
                       gem0_ref_ung_mux       0        0        0  1499999985      0
                          gem0_ref_ung_div1       0        0        0   124999999  0
                             gem0_ref_ung       0        0        0   124999999    0
                       pl3_ref_mux        1        1        0  1499999985          0
                          pl3_ref_div1       1        1        0    46875000       0
                             pl3_ref_div2       1        1        0     9375000    0
                                pl3_ref       1        1        0     9375000      0
                       pl2_ref_mux        1        1        0  1499999985          0
                          pl2_ref_div1       1        1        0    36585366       0
                             pl2_ref_div2       1        1        0    12195122    0
                                pl2_ref       7        7        0    12195122      0
                       pl1_ref_mux        1        1        0  1499999985          0
                          pl1_ref_div1       1        1        0    50000000       0
                             pl1_ref_div2       1        1        0    50000000    0
                                pl1_ref       1        1        0    50000000      0
                       pl0_ref_mux        1        1        0  1499999985          0
                          pl0_ref_div1       1        1        0    99999999       0
                             pl0_ref_div2       1        1        0    99999999    0
                                pl0_ref       4        4        0    99999999      0
                       ams_ref_mux        1        1        1  1499999985          0
                          ams_ref_div1       1        1        1    50000000       0
                             ams_ref_div2       1        1        1    50000000    0
                                ams_ref       1        1        1    50000000      0
                       can1_ref_mux       0        0        0  1499999985          0
                          can1_ref_div1       0        0        0    46875000      0
                             can1_ref_div2       0        0        0    46875000   0
                                can1_ref       0        0        0    46875000     0
                                   can1       0        0        0    46875000      0
                       can0_ref_mux       0        0        0  1499999985          0
                          can0_ref_div1       0        0        0    46875000      0
                             can0_ref_div2       0        0        0    46875000   0
                                can0_ref       0        0        0    46875000     0
                                   can0       0        0        0    46875000      0
                       i2c1_ref_mux       1        1        1  1499999985          0
                          i2c1_ref_div1       1        1        1    99999999      0
                             i2c1_ref_div2       1        1        1    99999999   0
                                i2c1_ref       1        1        1    99999999     0
                       i2c0_ref_mux       0        1        1  1499999985          0
                          i2c0_ref_div1       0        1        1    99999999      0
                             i2c0_ref_div2       0        1        1    99999999   0
                                i2c0_ref       0        1        1    99999999     0
                       nand_ref_mux       0        0        0  1499999985          0
                          nand_ref_div1       0        0        0    46875000      0
                             nand_ref_div2       0        0        0     9375000   0
                                nand_ref       0        0        0     9375000     0
                       uart1_ref_mux       1        1        1  1499999985         0
                          uart1_ref_div1       1        1        1    99999999     0
                             uart1_ref_div2       1        1        1    99999999  0
                                uart1_ref       1        1        1    99999999    0
                       uart0_ref_mux       0        0        0  1499999985         0
                          uart0_ref_div1       0        0        0    62500000     0
                             uart0_ref_div2       0        0        0    62500000  0
                                uart0_ref       0        0        0    62500000    0
                       sdio0_ref_mux       0        0        0  1499999985         0
                          sdio0_ref_div1       0        0        0    99999999     0
                             sdio0_ref_div2       0        0        0    99999999  0
                                sdio0_ref       0        0        0    99999999    0
                       qspi_ref_mux       0        1        1  1499999985          0
                          qspi_ref_div1       0        1        1   299999997      0
                             qspi_ref_div2       0        1        1   299999997   0
                                qspi_ref       0        1        1   299999997     0
                       gem_tsu_ref_mux       1        1        1  1499999985       0
                          gem_tsu_ref_div1       1        1        1   249999998   0
                             gem_tsu_ref_div2       1        1        1   2499999980
                                gem_tsu_ref       1        1        1   249999998  0
                                   gem_tsu       2        2        0   249999998   0
                       usb3_dual_ref_mux       1        1        1  1499999985     0
                          usb3_dual_ref_div1       1        1        1    60000000 0
                             usb3_dual_ref_div2       1        1        1    2000000
                                usb3_dual_ref       1        1        1    200000000
                       usb1_bus_ref_mux       0        0        0  1499999985      0
                          usb1_bus_ref_div1       0        0        0   124999999  0
                             usb1_bus_ref_div2       0        0        0   124999990
                                usb1_bus_ref       0        0        0   124999999 0
                       usb0_bus_ref_mux       1        1        1  1499999985      0
                          usb0_bus_ref_div1       1        1        1   249999998  0
                             usb0_bus_ref_div2       1        1        1   249999990
                                usb0_bus_ref       1        1        1   249999998 0
                       lpd_lsbus_mux       1        1        0  1499999985         0
                          lpd_lsbus_div1       1        1        0    99999999     0
                             lpd_lsbus       7        8        0    99999999       0
                                lpd_wdt       0        0        0    99999999      0
                       iopll_to_fpd       1        1        0   499999995          0
                          topsw_lsbus_mux       1        1        0   499999995    0
                             topsw_lsbus_div1       1        1        0    999999990
                                topsw_lsbus       3        3        0    99999999  0
                                   fpd_wdt       1        1        0    99999999   0
     PLL1                                 1        1        0           0          0
        Q1BB-div                          0        0        0           0          0
        Q1B-div                           0        0        0           0          0
     gem0_ref                             2        2        0           0          0
        gem0_tx                           1        1        0           0          0
     can1_mio                             0        0        0           0          0
     can0_mio                             0        0        0           0          0
     gem3_rx                              1        1        0           0          0
     gem2_rx                              0        0        0           0          0
     gem1_rx                              0        0        0           0          0
     gem0_rx                              1        1        0           0          0
    Here is the system-user.dtsi :
     * I2C1
    &i2c1 {
    	status = "okay";
    		#size-cells = <0>;
    		reg = <0x70>;
    			#size-cells = <0>;
    			reg = <0>;
    				reg = <0x3b>;
    		i2c@1 {
                #size-cells = <0>;
                reg = <1>;
                    reg = <0x4A>;
                    #size-cells = <0>;
                    adi,ref-crystal;
                    #clock-cells = <2>;
                      reg = <AD9545_Q1A>;
                      reg = <AD9545_Q1B>;
    			/* 4A */
    			#size-cells = <0>;
    			reg = <2>;
    			/* 1D */
    		i2c@3 { /* QSFP */
    			#size-cells = <0>;
    			reg = <3>;
    			eeprom@50 {
    				reg = <0x50>;
    		i2c@4 { /* SFP+ */
    			#size-cells = <0>;
    			reg = <4>;
    			eeprom@50 {
    				reg = <0x50>;
    			#size-cells = <0>;
    			reg = <5>;
    // 			ad7291@2f {
    // 				reg = <0x2f>;
    			eeprom@50 {
    				reg = <0x50>;
    Here is the related part of the overall dts compiled by Petalinux (could not paste it all as it'is too long):
    i2c@ff030000 {
    			compatible = "cdns,i2c-r1p14", "cdns,i2c-r1p10";
    			status = "okay";
    			interrupt-parent = <0x4>;
    			interrupts = <0x0 0x12 0x4>;
    			reg = <0x0 0xff030000 0x0 0x1000>;
    			#address-cells = <0x1>;
    			#size-cells = <0x0>;
    			power-domains = <0xc 0x26>;
    			clocks = <0x3 0x3e>;
    			clock-frequency = <0x61a80>;
    			pinctrl-0 = <0x16>;
    			scl-gpios = <0x12 0x20 0x0>;
    			sda-gpios = <0x12 0x21 0x0>;
    			i2c-mux@70 {
    				reg = <0x70>;
    				i2c@0 {
    					reg = <0x0>;
    					adau1761@3b {
    						reg = <0x3b>;
    						clocks = <0x17>;
    						#sound-dai-cells = <0x0>;
    						phandle = <0x3d>;
    				i2c@1 {
    					reg = <0x1>;
    					ad9545@4A {
    						reg = <0x4a>;
    						adi,ref-crystal;
    						adi,ref-frequency-hz = <0x2ee0000>;
    						#clock-cells = <0x2>;
    						assigned-clocks = <0x18 0x2 0x0 0x18 0x1 0x1 0x18 0x0 0x6 0x18 0x0 0x8>;
    						assigned-clock-rates = <0x2710 0x6fc23ac0 0x9502f90 0x9502f90>;
    						assigned-clock-phases = <0x0 0x0 0x0 0xb4>;
    						phandle = <0x18>;
    						aux-nco-clk@0 {
    							reg = <0x0>;
    							adi,freq-lock-threshold-ps = <0xf42400>;
    							adi,phase-lock-threshold-ps = <0xf42400>;
    						pll-clk@1 {
    							reg = <0x1>;
    							adi,pll-source = <0x4>;
    							adi,pll-loop-bandwidth-hz = <0xc8>;
    						output-clk@6 {
    							reg = <0x6>;
    							adi,output-mode = <0x2>;
    							adi,current-source-microamp = <0x3a98>;
    						output-clk@8 {
    							reg = <0x8>;
    				i2c@2 {
    					reg = <0x2>;
    				i2c@3 {
    					reg = <0x3>;
    					eeprom@50 {
    						reg = <0x50>;
    				i2c@4 {
    					reg = <0x4>;
    					eeprom@50 {
    						reg = <0x50>;
    				i2c@5 {
    					reg = <0x5>;
    					eeprom@50 {
    						reg = <0x50>;
  • Hi Sermed,
    The device tree looks good. The problem is that the auxiliary NCO clock is not registering in the common clock framework.
    I fixed this here: https://github.com/analogdevicesinc/linux/pull/1371/files
    As a bypass, just to check if this is the problem, you could try changing the aux-nco-clk@AD9545_NCO0 to:
                        adi,nco-freq-hz = <10000>;
    Alexandru Tachici
    Actually this made a change in the clock summary output:
                                     enable  prepare  protect                                duty
       clock                          count    count    count        rate   accuracy phase  cycle
     spi1.1-tx_sampl_clk                  0        0        0   245760000          0     0  50000
     spi1.1-obs_sampl_clk                 0        0        0   245760000          0     0  50000
     spi1.1-rx_sampl_clk                  0        0        0   245760000          0     0  50000
     spi1.0-tx_sampl_clk                  1        1        0   245760000          0     0  50000
     spi1.0-obs_sampl_clk                 1        1        0   245760000          0     0  50000
     spi1.0-rx_sampl_clk                  0        0        0   245760000          0     0  50000
     spi2.1-tx_sampl_clk                  0        0        0   245760000          0     0  50000
     spi2.1-obs_sampl_clk                 0        0        0   245760000          0     0  50000
     spi2.1-rx_sampl_clk                  0        0        0   245760000          0     0  50000
     spi2.0-tx_sampl_clk                  0        0        0   245760000          0     0  50000
     spi2.0-obs_sampl_clk                 0        0        0   245760000          0     0  50000
     spi2.0-rx_sampl_clk                  0        0        0   245760000          0     0  50000
     AUX_NCO0                             0        0        0       10000          0     0  50000
        PLL1                              0        0        0  1875000000          0     0  50000
           Q1B-div                        0        0        0   156250000          0     0  50000
           Q1A-div                        0        0        0   156250000          0     0  50000
     hmc7044_e_out11_REFCLK_SFP           0        0        0   122880000          0     0  50000
     hmc7044_e_out6_SYNC_OUT2             0        0        0      768000          0     0  50000
     hmc7044_e_out5_SYNC_OUT1             0        0        0      768000          0     0  50000
     hmc7044_e_out2_REFCLK_OUT2           0        0        0    30720000          0     0  50000
     hmc7044_e_out0_REFCLK_OUT0           0        0        0    30720000          0     0  50000
     hmc7044_c_out11_REFCLK_SFP           0        0        0   122880000          0     0  50000
     hmc7044_c_out10_REFCLK_QSFP          0        0        0    30720000          0     0  50000
     hmc7044_c_out9_REFCLK_OUT4           5        5        0    30720000          0     0  50000
        hmc7044_fmc_out9_FPGA_SYSREF_RX_CD       0        0        0      768000          0     0  50000
        hmc7044_fmc_out8_FPGA_SYSREF_TX_OBS_CD       0        0        0      768000          0     0  50000
        hmc7044_fmc_out7_CORE_CLK_RX_CD       0        0        0   245760000          0     0  50000
        hmc7044_fmc_out6_CORE_CLK_TX_OBS_CD       0        0        0   122880000          0     0  50000
        hmc7044_fmc_out5_JESD_REFCLK_RX_CD       2        2        0   245760000          0     0  50000
        hmc7044_fmc_out4_JESD_REFCLK_TX_OBS_CD       4        4        0   245760000          0     0  50000
        hmc7044_fmc_out3_DEV_SYSREF_D       0        0        0     3840000          0     0  50000
        hmc7044_fmc_out2_DEV_REFCLK_D       1        1        0   245760000          0     0  50000
        hmc7044_fmc_out1_DEV_SYSREF_C       0        0        0     3840000          0     0  50000
        hmc7044_fmc_out0_DEV_REFCLK_C       1        1        0   245760000          0     0  50000
     hmc7044_c_out8_REFCLK_OUT3           0        0        0    30720000          0     0  50000
     hmc7044_c_out6_SYNC_OUT2             0        0        0     3840000          0     0  50000
     hmc7044_c_out5_SYNC_OUT1             0        0        0     3840000          0     0  50000
     hmc7044_c_out2_REFCLK_OUT2           7        7        2    30720000          0     0  50000
        hmc7044_out9_FPGA_SYSREF_RX_AB       0        0        0     3840000          0     0  50000
        hmc7044_out8_FPGA_SYSREF_TX_OBS_AB       0        0        0     3840000          0     0  50000
        hmc7044_out7_CORE_CLK_RX_AB       1        1        0   245760000          0     0  50000
        hmc7044_out6_CORE_CLK_TX_OBS_AB       2        2        0   122880000          0     0  50000
        hmc7044_out5_JESD_REFCLK_RX_AB       2        2        1   245760000          0     0  50000
           rx_out_clk                     0        0        0   245760000          0     0  50000
           rx_gt_clk                      1        1        1     9830400          0     0  50000
        hmc7044_out4_JESD_REFCLK_TX_OBS_AB       4        4        2   245760000          0     0  50000
           tx_out_clk                     0        0        0   245760000          0     0  50000
           tx_gt_clk                      1        1        1     4915200          0     0  50000
           rx_os_out_clk                  0        0        0   245760000          0     0  50000
           rx_os_gt_clk                   1        1        1     4915200          0     0  50000
        hmc7044_out3_DEV_SYSREF_B         0        0        0     3840000          0     0  50000
        hmc7044_out2_DEV_REFCLK_B         1        1        0   245760000          0     0  50000
        hmc7044_out1_DEV_SYSREF_A         0        0        0     3840000          0     0  50000
        hmc7044_out0_DEV_REFCLK_A         1        1        0   245760000          0     0  50000
     hmc7044_c_out0_REFCLK_OUT0           0        0        0    30720000          0     0  50000
     audio_clock                          1        1        0    12288000          0     0  50000
     dp_aclk                              1        1        0   100000000        100     0  50000
     aux_ref_clk                          0        0        0    27000000          0     0  50000
     gt_crx_ref_clk                       0        0        0   108000000          0     0  50000
     pss_alt_ref_clk                      0        0        0           0          0     0  50000
     video_clk                            0        0        0    27000000          0     0  50000
     pss_ref_clk                          3        3        3    33333333          0     0  50000
        vpll_post_src                     0        0        0    33333333          0     0  50000
        vpll_pre_src                      0        0        0    33333333          0     0  50000
           vpll_int                       0        0        0  2999999970          0     0  50000
              vpll_half                   0        0        0  1499999985          0     0  50000
                 vpll_int_mux             0        0        0  1499999985          0     0  50000
                    vpll                  0        0        0  1499999985          0     0  50000
                       dp_video_ref_mux       0        0        0  1499999985          0     0  50000
                          dp_video_ref_div1       0        0        0   299999997          0     0  50000
                             dp_video_ref_div2       0        0        0   299999997          0     0  50000
                                dp_video_ref       0        0        0   299999997          0     0  50000
                       vpll_to_lpd        0        0        0   499999995          0     0  50000
        dpll_post_src                     0        0        0    33333333          0     0  50000
        dpll_pre_src                      1        1        1    33333333          0     0  50000
           dpll_int                       1        1        1  2399999976          0     0  50000
              dpll_half                   1        1        1  1199999988          0     0  50000
                 dpll_int_mux             1        1        1  1199999988          0     0  50000
                    dpll                  1        1        1  1199999988          0     0  50000
                       gpu_ref_mux        0        0        0  1199999988          0     0  50000
                          gpu_ref_div1       0        0        0   599999994          0     0  50000
                             gpu_ref       0        0        0   599999994          0     0  50000
                                gpu_pp1_ref       0        0        0   599999994          0     0  50000
                                gpu_pp0_ref       0        0        0   599999994          0     0  50000
                       pcie_ref_mux       0        0        0  1199999988          0     0  50000
                          pcie_ref_div1       0        0        0    99999999          0     0  50000
                             pcie_ref       0        0        0    99999999          0     0  50000
                       sata_ref_mux       0        0        0  1199999988          0     0  50000
                          sata_ref_div1       0        0        0    99999999          0     0  50000
                             sata_ref       0        0        0    99999999          0     0  50000
                       dpdma_ref_mux       1        1        1  1199999988          0     0  50000
                          dpdma_ref_div1       1        1        1   599999994          0     0  50000
                             dpdma_ref       1        1        1   599999994          0     0  50000
                       gdma_ref_mux       0        0        0  1199999988          0     0  50000
                          gdma_ref_div1       0        0        0   599999994          0     0  50000
                             gdma_ref       0        0        0   599999994          0     0  50000
                       dp_stc_ref_mux       0        0        0  1199999988          0     0  50000
                          dp_stc_ref_div1       0        0        0    26666667          0     0  50000
                             dp_stc_ref_div2       0        0        0    26666667          0     0  50000
                                dp_stc_ref       0        0        0    26666667          0     0  50000
                       dp_audio_ref_mux       0        0        0  1199999988          0     0  50000
                          dp_audio_ref_div1       0        0        0    22641510          0     0  50000
                             dp_audio_ref_div2       0        0        0    22641510          0     0  50000
                                dp_audio_ref       0        0        0    22641510          0     0  50000
                       dpll_to_lpd        0        0        0   399999996          0     0  50000
        apll_post_src                     0        0        0    33333333          0     0  50000
        apll_pre_src                      0        0        0    33333333          0     0  50000
           apll_int                       0        0        0  2666666640          0     0  50000
              apll_half                   0        0        0  1333333320          0     0  50000
                 apll_int_mux             0        0        0  1333333320          0     0  50000
                    apll                  0        0        0  1333333320          0     0  50000
                       acpu_mux           0        0        0  1333333320          0     0  50000
                          acpu            0        0        0  1333333320          0     0  50000
        rpll_post_src                     0        0        0    33333333          0     0  50000
        rpll_pre_src                      1        1        1    33333333          0     0  50000
           rpll_int                       1        1        1  1999999980          0     0  50000
              rpll_half                   1        1        1   999999990          0     0  50000
                 rpll_int_mux             1        1        1   999999990          0     0  50000
                    rpll                  1        1        1   999999990          0     0  50000
                       adma_ref_mux       0        0        0   999999990          0     0  50000
                          adma_ref_div1       0        0        0   499999995          0     0  50000
                             adma_ref       0        0        0   499999995          0     0  50000
                       spi1_ref_mux       0        0        0   999999990          0     0  50000
                          spi1_ref_div1       0        0        0   199999998          0     0  50000
                             spi1_ref_div2       0        0        0   199999998          0     0  50000
                                spi1_ref       0        0        0   199999998          0     0  50000
                       spi0_ref_mux       0        0        0   999999990          0     0  50000
                          spi0_ref_div1       0        0        0    99999999          0     0  50000
                             spi0_ref_div2       0        0        0    99999999          0     0  50000
                                spi0_ref       0        0        0    99999999          0     0  50000
                       sdio1_ref_mux       1        1        1   999999990          0     0  50000
                          sdio1_ref_div1       1        1        1   199999998          0     0  50000
                             sdio1_ref_div2       1        1        1   199999998          0     0  50000
                                sdio1_ref       1        1        1   199999998          0     0  50000
                       rpll_to_fpd        0        0        0   499999995          0     0  50000
        iopll_post_src                    0        0        0    33333333          0     0  50000
        iopll_pre_src                     1        1        1    33333333          0     0  50000
           iopll_int                      1        1        1  2999999970          0     0  50000
              iopll_half                  1        1        1  1499999985          0     0  50000
                 iopll_int_mux            1        1        1  1499999985          0     0  50000
                    iopll                13       15        8  1499999985          0     0  50000
                       gem3_ref_ung_mux       1        1        0  1499999985          0     0  50000
                          gem3_ref_ung_div1       1        1        0  1499999985          0     0  50000
                             gem3_ref_ung       1        1        0   124999999          0     0  50000
                                gem3_ref       2        2        0   124999999          0     0  50000
                                   gem3_tx       1        1        0   124999999          0     0  50000
                       gem2_ref_ung_mux       0        0        0  1499999985          0     0  50000
                          gem2_ref_ung_div1       0        0        0    62500000          0     0  50000
                             gem2_ref_ung       0        0        0    62500000          0     0  50000
                                gem2_ref       0        0        0    62500000          0     0  50000
                                   gem2_tx       0        0        0    62500000          0     0  50000
                       gem1_ref_ung_mux       0        0        0  1499999985          0     0  50000
                          gem1_ref_ung_div1       0        0        0    62500000          0     0  50000
                             gem1_ref_ung       0        0        0    62500000          0     0  50000
                                gem1_ref       0        0        0    62500000          0     0  50000
                                   gem1_tx       0        0        0    62500000          0     0  50000
                       gem0_ref_ung_mux       0        0        0  1499999985          0     0  50000
                          gem0_ref_ung_div1       0        0        0   124999999          0     0  50000
                             gem0_ref_ung       0        0        0   124999999          0     0  50000
                       pl3_ref_mux        1        1        0  1499999985          0     0  50000
                          pl3_ref_div1       1        1        0    46875000          0     0  50000
                             pl3_ref_div2       1        1        0     9375000          0     0  50000
                                pl3_ref       1        1        0     9375000          0     0  50000
                       pl2_ref_mux        1        1        0  1499999985          0     0  50000
                          pl2_ref_div1       1        1        0    36585366          0     0  50000
                             pl2_ref_div2       1        1        0    12195122          0     0  50000
                                pl2_ref       7        7        0    12195122          0     0  50000
                       pl1_ref_mux        1        1        0  1499999985          0     0  50000
                          pl1_ref_div1       1        1        0    50000000          0     0  50000
                             pl1_ref_div2       1        1        0    50000000          0     0  50000
                                pl1_ref       1        1        0    50000000          0     0  50000
                       pl0_ref_mux        1        1        0  1499999985          0     0  50000
                          pl0_ref_div1       1        1        0    99999999          0     0  50000
                             pl0_ref_div2       1        1        0    99999999          0     0  50000
                                pl0_ref       4        4        0    99999999          0     0  50000
                       ams_ref_mux        1        1        1  1499999985          0     0  50000
                          ams_ref_div1       1        1        1    50000000          0     0  50000
                             ams_ref_div2       1        1        1    50000000          0     0  50000
                                ams_ref       1        1        1    50000000          0     0  50000
                       can1_ref_mux       0        0        0  1499999985          0     0  50000
                          can1_ref_div1       0        0        0    46875000          0     0  50000
                             can1_ref_div2       0        0        0    46875000          0     0  50000
                                can1_ref       0        0        0    46875000          0     0  50000
                                   can1       0        0        0    46875000          0     0  50000
                       can0_ref_mux       0        0        0  1499999985          0     0  50000
                          can0_ref_div1       0        0        0    46875000          0     0  50000
                             can0_ref_div2       0        0        0    46875000          0     0  50000
                                can0_ref       0        0        0    46875000          0     0  50000
                                   can0       0        0        0    46875000          0     0  50000
                       i2c1_ref_mux       1        1        1  1499999985          0     0  50000
                          i2c1_ref_div1       1        1        1    99999999          0     0  50000
                             i2c1_ref_div2       1        1        1    99999999          0     0  50000
                                i2c1_ref       1        1        1    99999999          0     0  50000
                       i2c0_ref_mux       0        1        1  1499999985          0     0  50000
                          i2c0_ref_div1       0        1        1    99999999          0     0  50000
                             i2c0_ref_div2       0        1        1    99999999          0     0  50000
                                i2c0_ref       0        1        1    99999999          0     0  50000
                       nand_ref_mux       0        0        0  1499999985          0     0  50000
                          nand_ref_div1       0        0        0    46875000          0     0  50000
                             nand_ref_div2       0        0        0     9375000          0     0  50000
                                nand_ref       0        0        0     9375000          0     0  50000
                       uart1_ref_mux       1        1        1  1499999985          0     0  50000
                          uart1_ref_div1       1        1        1    99999999          0     0  50000
                             uart1_ref_div2       1        1        1    99999999          0     0  50000
                                uart1_ref       1        1        1    99999999          0     0  50000
                       uart0_ref_mux       0        0        0  1499999985          0     0  50000
                          uart0_ref_div1       0        0        0    62500000          0     0  50000
                             uart0_ref_div2       0        0        0    62500000          0     0  50000
                                uart0_ref       0        0        0    62500000          0     0  50000
                       sdio0_ref_mux       0        0        0  1499999985          0     0  50000
                          sdio0_ref_div1       0        0        0    99999999          0     0  50000
                             sdio0_ref_div2       0        0        0    99999999          0     0  50000
                                sdio0_ref       0        0        0    99999999          0     0  50000
                       qspi_ref_mux       0        1        1  1499999985          0     0  50000
                          qspi_ref_div1       0        1        1   299999997          0     0  50000
                             qspi_ref_div2       0        1        1   299999997          0     0  50000
                                qspi_ref       0        1        1   299999997          0     0  50000
                       gem_tsu_ref_mux       1        1        1  1499999985          0     0  50000
                          gem_tsu_ref_div1       1        1        1   249999998          0     0  50000
                             gem_tsu_ref_div2       1        1        1   249999998          0     0  50000
                                gem_tsu_ref       1        1        1   249999998          0     0  50000
                                   gem_tsu       2        2        0   249999998          0     0  50000
                       usb3_dual_ref_mux       1        1        1  1499999985          0     0  50000
                          usb3_dual_ref_div1       1        1        1    60000000          0     0  50000
                             usb3_dual_ref_div2       1        1        1    20000000          0     0  50000
                                usb3_dual_ref       1        1        1    20000000          0     0  50000
                       usb1_bus_ref_mux       0        0        0  1499999985          0     0  50000
                          usb1_bus_ref_div1       0        0        0   124999999          0     0  50000
                             usb1_bus_ref_div2       0        0        0   124999999          0     0  50000
                                usb1_bus_ref       0        0        0   124999999          0     0  50000
                       usb0_bus_ref_mux       1        1        1  1499999985          0     0  50000
                          usb0_bus_ref_div1       1        1        1   249999998          0     0  50000
                             usb0_bus_ref_div2       1        1        1   249999998          0     0  50000
                                usb0_bus_ref       1        1        1   249999998          0     0  50000
                       lpd_lsbus_mux       1        1        0  1499999985          0     0  50000
                          lpd_lsbus_div1       1        1        0    99999999          0     0  50000
                             lpd_lsbus       7        8        0    99999999          0     0  50000
                                lpd_wdt       0        0        0    99999999          0     0  50000
                       iopll_to_fpd       1        1        0   499999995          0     0  50000
                          topsw_lsbus_mux       1        1        0   499999995          0     0  50000
                             topsw_lsbus_div1       1        1        0    99999999          0     0  50000
                                topsw_lsbus       3        3        0    99999999          0     0  50000
                                   fpd_wdt       1        1        0    99999999          0     0  50000
     gem0_ref                             2        2        0           0          0     0  50000
        gem0_tx                           1        1        0           0          0     0  50000
     can1_mio                             0        0        0           0          0     0  50000
     can0_mio                             0        0        0           0          0     0  50000
     gem3_rx                              1        1        0           0          0     0  50000
     gem2_rx                              0        0        0           0          0     0  50000
     gem1_rx                              0        0        0           0          0     0  50000
     gem0_rx                              1        1        0           0          0     0  50000
    However, 1G core still does not output any clock. Is it possible that we did not set the output clocks to be differential in the device-tree? We set output to DRIVER_MODE_DUAL_DIV. Could changing this to DRIVER_MODE_SINGLE_DIV_DIFF help?
    If this is the case, should we add AD9545_Q1AA as output clock to the system.
