The IIO oscilloscope does not have a list of plot channels.
I want to check the output spectrum waveform of the ADRV9008-1 using an IIO oscilloscope.
My test environment is the ZC706 + ADRV9008-1.
When I boot zc706 I have adrv9009-phy in /dev, and IIO oscilloscopes also load the adrv9009-phy plugin properly.
When I change the signal strength input to Rx1 and Rx2, the RSSI changes in the receive chain of the IIO oscilloscope.
There is no problem at the status of JESD204.
ADRV9008-1 is operating normally, why is there nothing in the Plot Channel list?
and When running under Linux, it attaches the log of the terminal.
jelee@jelee-ubuntu:/extrahdd/libiio_build/iio-oscilloscope-master/build$ ./osc
Found plugin: Motor Control
Found plugin: AD9371 Advanced
Found plugin: FMCOMMS11
Found plugin: AD936X
Found plugin: AD6676
Found plugin: LIDAR
Found plugin: AD5628-1
Found plugin: ADRV9009
Found plugin: AD936X Advanced
Found plugin: CN0508
Found plugin: AD7303
Found plugin: SCPI
Found plugin: CN0357
Found plugin: Spectrum Analyzer
Found plugin: FMComms1
Found plugin: CN0540
Could not find expected iio devices
Found plugin: FMCADC3
Found plugin: ADRV9009 Advanced
Found plugin: FMComms5
Found plugin: Partial Reconfiguration
Found plugin: DAC Data Manager
Found plugin: DMM
Found plugin: FMComms6
Found plugin: DAQ1/2/3
Found plugin: ad9739a
Found plugin: CN0511
Found plugin: Debug
Updating widgets...
Updating FIR filter...
Loaded plugin: ADRV9009
Loaded plugin: ADRV9009 Advanced
Loaded plugin: DMM
Loaded plugin: Debug
Profile loaded: /usr/local/lib/osc/filters/adrv9009/Tx_BW200_IR245p76_Rx_BW100_OR122p88_ORx_BW200_OR245p76_DC245p76.txt (ret = 3847)
(osc:3135): Gdk-CRITICAL **: gdk_window_move_resize_internal: assertion 'GDK_IS_WINDOW (window)' failed
(osc:3135): Gdk-CRITICAL **: _gdk_pixmap_new: assertion '(drawable != NULL) || (depth != -1)' failed
curl_easy_perform() failed: Couldn't resolve host name
git_request from https://api.github.com/repos/analogdevicesinc/iio-oscilloscope/releases failed
Could not decode data about git releases
Thanks for help.
Edit Notes
add image.
[edited by: JehoLee at 11:41 AM (GMT -5) on 10 Dec 2020]
    Attach "result iio_info"
    root@peta-adi:~# iio_info
    Library version: 0.18 (git tag: v0.18)
    Compiled with backends: local xml ip usb
    IIO context created with local backend.
    Backend version: 0.18 (git tag: v0.18)
    Backend description string: Linux peta-adi 4.14.0-xilinx- #1 SMP PREEMPT Wed Dec 9 06:37:56 UTC 2020 armv7l
    IIO context has 1 attributes:
            local,kernel: 4.14.0-xilinx-
    IIO context has 4 devices:
            iio:device0: xadc
                    9 channels found:
                            voltage5: vccoddr (input)
                            2 channel-specific attributes found:
                                    attr  0: raw value: 2055
                                    attr  1: scale value: 0.732421875
                            voltage0: vccint (input)
                                    attr  0: raw value: 1372
                            voltage4: vccpaux (input)
                                    attr  0: raw value: 2455
                            temp0:  (input)
                            3 channel-specific attributes found:
                                    attr  0: offset value: -2219
                                    attr  1: raw value: 2590
                                    attr  2: scale value: 123.040771484
                            voltage7: vrefn (input)
                                    attr  0: raw value: 7
                            voltage1: vccaux (input)
                            voltage2: vccbram (input)
                                    attr  0: raw value: 1373
                            voltage3: vccpint (input)
                                    attr  0: raw value: 1368
                            voltage6: vrefp (input)
                                    attr  0: raw value: 1708
                    1 device-specific attributes found:
                                    attr  0: sampling_frequency value: 961538
            iio:device1: ad9528-1
                    4 channels found:
                            altvoltage12: DEV_SYSREF (output)
                                    attr  0: frequency value: 120000
                                    attr  1: phase value: 0.000000
                                    attr  2: raw value: 1
                            altvoltage1: FMC_CLK (output)
                                    attr  0: frequency value: 122880000
                            altvoltage13: DEV_CLK (output)
                            altvoltage3: FMC_SYSREF (output)
                    9 device-specific attributes found:
                                    attr  0: pll1_feedback_clk_present value: 1
                                    attr  1: pll1_locked value: 1
                                    attr  2: pll1_reference_clk_a_present value: 1
                                    attr  3: pll1_reference_clk_ab_missing value: 0
                                    attr  4: pll1_reference_clk_b_present value: 0
                                    attr  5: pll2_feedback_clk_present value: 1
                                    attr  6: pll2_locked value: 1
                                    attr  7: sync_dividers ERROR: Permission denied (-13)
                                    attr  8: vcxo_clk_present value: 1
                    1 debug attributes found:
                                    debug attr  0: direct_reg_access value: 0x18
            iio:device2: adrv9009-phy
                    20 channels found:
                            voltage1:  (input)
                            10 channel-specific attributes found:
                                    attr  0: gain_control_mode value: manual
                                    attr  1: gain_control_mode_available value: manual slow_attack
                                    attr  2: gain_control_pin_mode_en value: 0
                                    attr  3: hardwaregain value: 30.000000 dB
                                    attr  4: hd2_tracking_en value: 0
                                    attr  5: powerdown value: 0
                                    attr  6: quadrature_tracking_en value: 0
                                    attr  7: rf_bandwidth value: 100000000
                                    attr  8: rssi value: 44.250 dB
                                    attr  9: sampling_frequency value: 122880000
                            voltage6:  (input)
                                    attr  0: offset value: 45
                                    attr  1: raw value: 1605
                                    attr  2: scale value: 0.775194
                            voltage8:  (output)
                                    attr  0: offset value: 2726
                                    attr  1: raw value: 0
                                    attr  2: scale value: 0.782954
                            voltage5:  (output)
                            voltage0:  (input)
                            altvoltage0: RX_LO (output)
                                    attr  0: frequency value: 2400000000
                                    attr  1: frequency_hopping_mode value: 2400000000
                                    attr  2: frequency_hopping_mode_enable value: 0
                            voltage9:  (output)
                            voltage4:  (input)
                                    attr  1: raw value: 50
                            voltage12:  (output)
                                    attr  0: raw value: 0
                                    attr  1: scale value: 0.805861
                            voltage4:  (output)
                            voltage10:  (output)
                            voltage13:  (output)
                            voltage3:  (output)
                            voltage7:  (input)
                                    attr  1: raw value: 1640
                            voltage2:  (output)
                            voltage6:  (output)
                            temp0:  (input)
                            1 channel-specific attributes found:
                                    attr  0: input value: 47000
                            voltage11:  (output)
                            voltage7:  (output)
                            voltage5:  (input)
                                    attr  1: raw value: 1835
                                    attr  0: calibrate ERROR: Input/output error (-5)
                                    attr  1: calibrate_frm_en value: 0
                                    attr  2: calibrate_rx_phase_correction_en value: 0
                                    attr  3: calibrate_rx_qec_en value: 0
                                    attr  4: ensm_mode value: radio_on
                                    attr  5: ensm_mode_available value: radio_on radio_off
                                    attr  6: gain_table_config ERROR: Permission denied (-13)
                                    attr  7: multichip_sync ERROR: Permission denied (-13)
                                    attr  8: profile_config value: TB
                    306 debug attributes found:
                                    debug attr  0: gpio3v3 value: 0
                                    debug attr  1: bist_tone value: 0
                                    debug attr  2: bist_framer_b_loopback value: 0
                                    debug attr  3: bist_framer_a_loopback value: 0
                                    debug attr  4: bist_framer_b_prbs value: 0
                                    debug attr  5: bist_framer_a_prbs value: 0
                                    debug attr  6: initialize value: 0
                                    debug attr  7: adi,aux-pll-lo-frequency_hz value: 2500000000
                                    debug attr  8: adi,trx-pll-lo-frequency_hz value: 2400000000
                                    debug attr  9: adi,dig-clocks-rf-pll-phase-sync-mode value: 0
                                    debug attr 10: adi,dig-clocks-rf-pll-use-external-lo value: 0
                                    debug attr 11: adi,dig-clocks-clk-pll-hs-div value: 1
                                    debug attr 12: adi,dig-clocks-clk-pll-vco-freq_khz value: 9830400
                                    debug attr 13: adi,dig-clocks-device-clock_khz value: 122880
                                    debug attr 14: adi,tx-settings-dis-tx-data-if-pll-unlock value: 0
                                    debug attr 15: adi,tx-settings-tx2-atten_md-b value: 10000
                                    debug attr 16: adi,tx-settings-tx1-atten_md-b value: 10000
                                    debug attr 17: adi,tx-settings-tx-atten-step-size value: 0
                                    debug attr 18: adi,tx-settings-tx-channels value: 0
                                    debug attr 19: adi,tx-settings-deframer-sel value: 0
                                    debug attr 20: adi,tx-profile-tx-bbf3d-bcorner_khz value: 56000
                                    debug attr 21: adi,tx-profile-tx-dac3d-bcorner_khz value: 187000
                                    debug attr 22: adi,tx-profile-rf-bandwidth_hz value: 100000000
                                    debug attr 23: adi,tx-profile-primary-sig-bandwidth_hz value: 50000000
                                    debug attr 24: adi,tx-profile-tx-input-rate_khz value: 122880
                                    debug attr 25: adi,tx-profile-tx-int5-interpolation value: 1
                                    debug attr 26: adi,tx-profile-thb3-interpolation value: 2
                                    debug attr 27: adi,tx-profile-thb2-interpolation value: 2
                                    debug attr 28: adi,tx-profile-thb1-interpolation value: 2
                                    debug attr 29: adi,tx-profile-tx-fir-interpolation value: 2
                                    debug attr 30: adi,tx-profile-dac-div value: 1
                                    debug attr 31: adi,tx-profile-tx-fir-num-fir-coefs value: 80
                                    debug attr 32: adi,tx-profile-tx-fir-gain_db value: 6
                                    debug attr 33: adi,obs-settings-obs-rx-lo-source value: 0
                                    debug attr 34: adi,obs-settings-obs-rx-channels-enable value: 3
                                    debug attr 35: adi,obs-settings-framer-sel value: 1
                                    debug attr 36: adi,orx-gain-control-orx2-min-gain-index value: 195
                                    debug attr 37: adi,orx-gain-control-orx2-max-gain-index value: 255
                                    debug attr 38: adi,orx-gain-control-orx1-min-gain-index value: 195
                                    debug attr 39: adi,orx-gain-control-orx1-max-gain-index value: 255
                                    debug attr 40: adi,orx-gain-control-orx2-gain-index value: 255
                                    debug attr 41: adi,orx-gain-control-orx1-gain-index value: 255
                                    debug attr 42: adi,orx-gain-control-gain-mode value: 0
                                    debug attr 43: adi,orx-profile-orx-ddc-mode value: 0
                                    debug attr 44: adi,orx-profile-rx-bbf3d-bcorner_khz value: 225000
                                    debug attr 45: adi,orx-profile-rf-bandwidth_hz value: 100000000
                                    debug attr 46: adi,orx-profile-orx-output-rate_khz value: 122880
                                    debug attr 47: adi,orx-profile-rhb1-decimation value: 2
                                    debug attr 48: adi,orx-profile-rx-dec5-decimation value: 4
                                    debug attr 49: adi,orx-profile-rx-fir-decimation value: 2
                                    debug attr 50: adi,orx-profile-rx-fir-num-fir-coefs value: 48
                                    debug attr 51: adi,orx-profile-rx-fir-gain_db value: 250
                                    debug attr 52: adi,rx-settings-rx-channels value: 3
                                    debug attr 53: adi,rx-settings-framer-sel value: 0
                                    debug attr 54: adi,rx-gain-control-rx2-min-gain-index value: 195
                                    debug attr 55: adi,rx-gain-control-rx2-max-gain-index value: 255
                                    debug attr 56: adi,rx-gain-control-rx1-min-gain-index value: 195
                                    debug attr 57: adi,rx-gain-control-rx1-max-gain-index value: 255
                                    debug attr 58: adi,rx-gain-control-rx2-gain-index value: 255
                                    debug attr 59: adi,rx-gain-control-rx1-gain-index value: 255
                                    debug attr 60: adi,rx-gain-control-gain-mode value: 0
                                    debug attr 61: adi,rx-nco-shifter-band-bnco2-freq_khz value: 0
                                    debug attr 62: adi,rx-nco-shifter-band-bnco1-freq_khz value: 0
                                    debug attr 63: adi,rx-nco-shifter-band-binput-center-freq_khz value: 0
                                    debug attr 64: adi,rx-nco-shifter-band-binput-band-width_khz value: 0
                                    debug attr 65: adi,rx-nco-shifter-band-a-nco2-freq_khz value: 0
                                    debug attr 66: adi,rx-nco-shifter-band-a-nco1-freq_khz value: 0
                                    debug attr 67: adi,rx-nco-shifter-band-a-input-center-freq_khz value: 0
                                    debug attr 68: adi,rx-nco-shifter-band-a-input-band-width_khz value: 0
                                    debug attr 69: adi,rx-profile-rx-ddc-mode value: 0
                                    debug attr 70: adi,rx-profile-rx-bbf3d-bcorner_khz value: 100000
                                    debug attr 71: adi,rx-profile-rf-bandwidth_hz value: 100000000
                                    debug attr 72: adi,rx-profile-rx-output-rate_khz value: 122880
                                    debug attr 73: adi,rx-profile-rhb1-decimation value: 2
                                    debug attr 74: adi,rx-profile-rx-dec5-decimation value: 4
                                    debug attr 75: adi,rx-profile-rx-fir-decimation value: 2
                                    debug attr 76: adi,rx-profile-rx-fir-num-fir-coefs value: 48
                                    debug attr 77: adi,rx-profile-rx-fir-gain_db value: 250
                                    debug attr 78: adi,tx-pa-protection-tx2-peak-threshold value: 130
                                    debug attr 79: adi,tx-pa-protection-tx1-peak-threshold value: 130
                                    debug attr 80: adi,tx-pa-protection-peak-count value: 4
                                    debug attr 81: adi,tx-pa-protection-tx2-power-threshold value: 4096
                                    debug attr 82: adi,tx-pa-protection-tx1-power-threshold value: 4096
                                    debug attr 83: adi,tx-pa-protection-tx-atten-step value: 2
                                    debug attr 84: adi,tx-pa-protection-avg-duration value: 3
                                    debug attr 85: adi,tx2-atten-ctrl-pin-enable value: 0
                                    debug attr 86: adi,tx2-atten-ctrl-pin-tx-atten-dec-pin value: 7
                                    debug attr 87: adi,tx2-atten-ctrl-pin-tx-atten-inc-pin value: 6
                                    debug attr 88: adi,tx2-atten-ctrl-pin-step-size value: 0
                                    debug attr 89: adi,tx1-atten-ctrl-pin-enable value: 0
                                    debug attr 90: adi,tx1-atten-ctrl-pin-tx-atten-dec-pin value: 5
                                    debug attr 91: adi,tx1-atten-ctrl-pin-tx-atten-inc-pin value: 4
                                    debug attr 92: adi,tx1-atten-ctrl-pin-step-size value: 0
                                    debug attr 93: adi,rx2-gain-ctrl-pin-enable value: 0
                                    debug attr 94: adi,rx2-gain-ctrl-pin-rx-gain-dec-pin value: 4
                                    debug attr 95: adi,rx2-gain-ctrl-pin-rx-gain-inc-pin value: 3
                                    debug attr 96: adi,rx2-gain-ctrl-pin-dec-step value: 1
                                    debug attr 97: adi,rx2-gain-ctrl-pin-inc-step value: 1
                                    debug attr 98: adi,rx1-gain-ctrl-pin-enable value: 0
                                    debug attr 99: adi,rx1-gain-ctrl-pin-rx-gain-dec-pin value: 1
                                    debug attr 100: adi,rx1-gain-ctrl-pin-rx-gain-inc-pin value: 0
                                    debug attr 101: adi,rx1-gain-ctrl-pin-dec-step value: 1
                                    debug attr 102: adi,rx1-gain-ctrl-pin-inc-step value: 1
                                    debug attr 103: adi,fhm-mode-fhm-init-frequency_hz value: 2450000000
                                    debug attr 104: adi,fhm-mode-fhm-exit-mode value: 0
                                    debug attr 105: adi,fhm-mode-fhm-trigger-mode value: 0
                                    debug attr 106: adi,fhm-mode-enable-mcs-sync value: 0
                                    debug attr 107: adi,fhm-mode-fhm-enable value: 0
                                    debug attr 108: adi,fhm-config-fhm-max-freq_mhz value: 100
                                    debug attr 109: adi,fhm-config-fhm-min-freq_mhz value: 100
                                    debug attr 110: adi,fhm-config-fhm-gpio-pin value: 0
                                    debug attr 111: adi,orx-lo-cfg-gpio-select value: 19
                                    debug attr 112: adi,orx-lo-cfg-disable-aux-pll-relocking value: 0
                                    debug attr 113: adi,gpio3v3-output-level-mask value: 0
                                    debug attr 114: adi,gpio3v3-output-enable-mask value: 0
                                    debug attr 115: adi,gpio3v3-source-control value: 0
                                    debug attr 116: adi,arm-gpio-config-en-tx-tracking-cals-enable value: 0
                                    debug attr 117: adi,arm-gpio-config-en-tx-tracking-cals-polarity value: 0
                                    debug attr 118: adi,arm-gpio-config-en-tx-tracking-cals-gpio-pin-sel value: 0
                                    debug attr 119: adi,arm-gpio-config-orx2-tx-sel1-pin-enable value: 0
                                    debug attr 120: adi,arm-gpio-config-orx2-tx-sel1-pin-polarity value: 0
                                    debug attr 121: adi,arm-gpio-config-orx2-tx-sel1-pin-gpio-pin-sel value: 0
                                    debug attr 122: adi,arm-gpio-config-orx2-tx-sel0-pin-enable value: 0
                                    debug attr 123: adi,arm-gpio-config-orx2-tx-sel0-pin-polarity value: 0
                                    debug attr 124: adi,arm-gpio-config-orx2-tx-sel0-pin-gpio-pin-sel value: 0
                                    debug attr 125: adi,arm-gpio-config-orx1-tx-sel1-pin-enable value: 0
                                    debug attr 126: adi,arm-gpio-config-orx1-tx-sel1-pin-polarity value: 0
                                    debug attr 127: adi,arm-gpio-config-orx1-tx-sel1-pin-gpio-pin-sel value: 0
                                    debug attr 128: adi,arm-gpio-config-orx1-tx-sel0-pin-enable value: 0
                                    debug attr 129: adi,arm-gpio-config-orx1-tx-sel0-pin-polarity value: 0
                                    debug attr 130: adi,arm-gpio-config-orx1-tx-sel0-pin-gpio-pin-sel value: 0
                                    debug attr 131: adi,jesd204-sysref-lvds-pn-invert value: 0
                                    debug attr 132: adi,jesd204-sysref-lvds-mode value: 1
                                    debug attr 133: adi,jesd204-des-eq-setting value: 1
                                    debug attr 134: adi,jesd204-des-invert-lane-polarity value: 0
                                    debug attr 135: adi,jesd204-ser-invert-lane-polarity value: 0
                                    debug attr 136: adi,jesd204-ser-pre-emphasis value: 1
                                    debug attr 137: adi,jesd204-ser-amplitude value: 15
                                    debug attr 138: adi,jesd204-deframer-b-enable-manual-lane-xbar value: 0
                                    debug attr 139: adi,jesd204-deframer-b-syncb-out-cmos-drive-level value: 0
                                    debug attr 140: adi,jesd204-deframer-b-syncb-out-cmos-slew-rate value: 0
                                    debug attr 141: adi,jesd204-deframer-b-syncb-out-lvds-pn-invert value: 0
                                    debug attr 142: adi,jesd204-deframer-b-syncb-out-lvds-mode value: 1
                                    debug attr 143: adi,jesd204-deframer-b-np value: 16
                                    debug attr 144: adi,jesd204-deframer-b-syncb-out-select value: 0
                                    debug attr 145: adi,jesd204-deframer-b-new-sysref-on-relink value: 0
                                    debug attr 146: adi,jesd204-deframer-b-lmfc-offset value: 0
                                    debug attr 147: adi,jesd204-deframer-b-deserializer-lane-crossbar value: 228
                                    debug attr 148: adi,jesd204-deframer-b-deserializer-lanes-enabled value: 0
                                    debug attr 149: adi,jesd204-deframer-b-external-sysref value: 1
                                    debug attr 150: adi,jesd204-deframer-b-scramble value: 1
                                    debug attr 151: adi,jesd204-deframer-b-k value: 32
                                    debug attr 152: adi,jesd204-deframer-b-m value: 0
                                    debug attr 153: adi,jesd204-deframer-b-lane0-id value: 0
                                    debug attr 154: adi,jesd204-deframer-b-device-id value: 0
                                    debug attr 155: adi,jesd204-deframer-b-bank-id value: 0
                                    debug attr 156: adi,jesd204-deframer-a-enable-manual-lane-xbar value: 0
                                    debug attr 157: adi,jesd204-deframer-a-syncb-out-cmos-drive-level value: 0
                                    debug attr 158: adi,jesd204-deframer-a-syncb-out-cmos-slew-rate value: 0
                                    debug attr 159: adi,jesd204-deframer-a-syncb-out-lvds-pn-invert value: 0
                                    debug attr 160: adi,jesd204-deframer-a-syncb-out-lvds-mode value: 1
                                    debug attr 161: adi,jesd204-deframer-a-np value: 16
                                    debug attr 162: adi,jesd204-deframer-a-syncb-out-select value: 0
                                    debug attr 163: adi,jesd204-deframer-a-new-sysref-on-relink value: 0
                                    debug attr 164: adi,jesd204-deframer-a-lmfc-offset value: 17
                                    debug attr 165: adi,jesd204-deframer-a-deserializer-lane-crossbar value: 228
                                    debug attr 166: adi,jesd204-deframer-a-deserializer-lanes-enabled value: 15
                                    debug attr 167: adi,jesd204-deframer-a-external-sysref value: 1
                                    debug attr 168: adi,jesd204-deframer-a-scramble value: 1
                                    debug attr 169: adi,jesd204-deframer-a-k value: 32
                                    debug attr 170: adi,jesd204-deframer-a-m value: 0
                                    debug attr 171: adi,jesd204-deframer-a-lane0-id value: 0
                                    debug attr 172: adi,jesd204-deframer-a-device-id value: 0
                                    debug attr 173: adi,jesd204-deframer-a-bank-id value: 0
                                    debug attr 174: adi,jesd204-framer-b-enable-manual-lane-xbar value: 0
                                    debug attr 175: adi,jesd204-framer-b-syncb-in-lvds-pn-invert value: 0
                                    debug attr 176: adi,jesd204-framer-b-syncb-in-lvds-mode value: 1
                                    debug attr 177: adi,jesd204-framer-b-over-sample value: 0
                                    debug attr 178: adi,jesd204-framer-b-syncb-in-select value: 1
                                    debug attr 179: adi,jesd204-framer-b-new-sysref-on-relink value: 0
                                    debug attr 180: adi,jesd204-framer-b-lmfc-offset value: 31
                                    debug attr 181: adi,jesd204-framer-b-serializer-lane-crossbar value: 228
                                    debug attr 182: adi,jesd204-framer-b-serializer-lanes-enabled value: 12
                                    debug attr 183: adi,jesd204-framer-b-external-sysref value: 1
                                    debug attr 184: adi,jesd204-framer-b-scramble value: 1
                                    debug attr 185: adi,jesd204-framer-b-np value: 16
                                    debug attr 186: adi,jesd204-framer-b-f value: 4
                                    debug attr 187: adi,jesd204-framer-b-k value: 32
                                    debug attr 188: adi,jesd204-framer-b-m value: 4
                                    debug attr 189: adi,jesd204-framer-b-lane0-id value: 0
                                    debug attr 190: adi,jesd204-framer-b-device-id value: 0
                                    debug attr 191: adi,jesd204-framer-b-bank-id value: 0
                                    debug attr 192: adi,jesd204-framer-a-enable-manual-lane-xbar value: 0
                                    debug attr 193: adi,jesd204-framer-a-syncb-in-lvds-pn-invert value: 0
                                    debug attr 194: adi,jesd204-framer-a-syncb-in-lvds-mode value: 1
                                    debug attr 195: adi,jesd204-framer-a-over-sample value: 0
                                    debug attr 196: adi,jesd204-framer-a-syncb-in-select value: 0
                                    debug attr 197: adi,jesd204-framer-a-new-sysref-on-relink value: 0
                                    debug attr 198: adi,jesd204-framer-a-lmfc-offset value: 31
                                    debug attr 199: adi,jesd204-framer-a-serializer-lane-crossbar value: 228
                                    debug attr 200: adi,jesd204-framer-a-serializer-lanes-enabled value: 3
                                    debug attr 201: adi,jesd204-framer-a-external-sysref value: 1
                                    debug attr 202: adi,jesd204-framer-a-scramble value: 1
                                    debug attr 203: adi,jesd204-framer-a-np value: 16
                                    debug attr 204: adi,jesd204-framer-a-f value: 4
                                    debug attr 205: adi,jesd204-framer-a-k value: 32
                                    debug attr 206: adi,jesd204-framer-a-m value: 4
                                    debug attr 207: adi,jesd204-framer-a-lane0-id value: 0
                                    debug attr 208: adi,jesd204-framer-a-device-id value: 0
                                    debug attr 209: adi,jesd204-framer-a-bank-id value: 1
                                    debug attr 210: adi,aux-dac-values11 value: 0
                                    debug attr 211: adi,aux-dac-values10 value: 0
                                    debug attr 212: adi,aux-dac-values9 value: 0
                                    debug attr 213: adi,aux-dac-resolution9 value: 0
                                    debug attr 214: adi,aux-dac-vref9 value: 3
                                    debug attr 215: adi,aux-dac-values8 value: 0
                                    debug attr 216: adi,aux-dac-resolution8 value: 0
                                    debug attr 217: adi,aux-dac-vref8 value: 3
                                    debug attr 218: adi,aux-dac-values7 value: 0
                                    debug attr 219: adi,aux-dac-resolution7 value: 0
                                    debug attr 220: adi,aux-dac-vref7 value: 3
                                    debug attr 221: adi,aux-dac-values6 value: 0
                                    debug attr 222: adi,aux-dac-resolution6 value: 0
                                    debug attr 223: adi,aux-dac-vref6 value: 3
                                    debug attr 224: adi,aux-dac-values5 value: 0
                                    debug attr 225: adi,aux-dac-resolution5 value: 0
                                    debug attr 226: adi,aux-dac-vref5 value: 3
                                    debug attr 227: adi,aux-dac-values4 value: 0
                                    debug attr 228: adi,aux-dac-resolution4 value: 0
                                    debug attr 229: adi,aux-dac-vref4 value: 3
                                    debug attr 230: adi,aux-dac-values3 value: 0
                                    debug attr 231: adi,aux-dac-resolution3 value: 0
                                    debug attr 232: adi,aux-dac-vref3 value: 3
                                    debug attr 233: adi,aux-dac-values2 value: 0
                                    debug attr 234: adi,aux-dac-resolution2 value: 0
                                    debug attr 235: adi,aux-dac-vref2 value: 3
                                    debug attr 236: adi,aux-dac-values1 value: 0
                                    debug attr 237: adi,aux-dac-resolution1 value: 0
                                    debug attr 238: adi,aux-dac-vref1 value: 3
                                    debug attr 239: adi,aux-dac-values0 value: 0
                                    debug attr 240: adi,aux-dac-resolution0 value: 0
                                    debug attr 241: adi,aux-dac-vref0 value: 3
                                    debug attr 242: adi,aux-dac-enables value: 0
                                    debug attr 243: adi,rxagc-agc-enable-fast-recovery-loop value: 0
                                    debug attr 244: adi,rxagc-ip3-peak-exceeded-cnt value: 4
                                    debug attr 245: adi,rxagc-ip3-over-range-thresh-index value: 246
                                    debug attr 246: adi,rxagc-ip3-over-range-thresh value: 31
                                    debug attr 247: adi,rxagc-agc-enable-ip3-optimization-thresh value: 0
                                    debug attr 248: adi,rxagc-agc-enable-sync-pulse-for-gain-counter value: 0
                                    debug attr 249: adi,rxagc-agc-reset-on-rxon value: 0
                                    debug attr 250: adi,rxagc-agc-peak-thresh-gain-control-mode value: 1
                                    debug attr 251: adi,rxagc-agc-change-gain-if-thresh-high value: 1
                                    debug attr 252: adi,rxagc-agc-low-thresh-prevent-gain value: 0
                                    debug attr 253: adi,rxagc-agc-slow-loop-settling-delay value: 16
                                    debug attr 254: adi,rxagc-agc-rx2-attack-delay value: 10
                                    debug attr 255: adi,rxagc-agc-rx1-attack-delay value: 10
                                    debug attr 256: adi,rxagc-agc-gain-update-counter_us value: 250
                                    debug attr 257: adi,rxagc-agc-rx2-min-gain-index value: 195
                                    debug attr 258: adi,rxagc-agc-rx2-max-gain-index value: 255
                                    debug attr 259: adi,rxagc-agc-rx1-min-gain-index value: 195
                                    debug attr 260: adi,rxagc-agc-rx1-max-gain-index value: 255
                                    debug attr 261: adi,rxagc-agc-peak-wait-time value: 4
                                    debug attr 262: adi,rxagc-power-power-log-shift value: 0
                                    debug attr 263: adi,rxagc-power-upper1-power-thresh value: 0
                                    debug attr 264: adi,rxagc-power-upper0-power-thresh value: 2
                                    debug attr 265: adi,rxagc-power-rx2-tdd-power-meas-delay value: 1
                                    debug attr 266: adi,rxagc-power-rx2-tdd-power-meas-duration value: 5
                                    debug attr 267: adi,rxagc-power-rx1-tdd-power-meas-delay value: 1
                                    debug attr 268: adi,rxagc-power-rx1-tdd-power-meas-duration value: 5
                                    debug attr 269: adi,rxagc-power-power-measurement-duration value: 5
                                    debug attr 270: adi,rxagc-power-under-range-low-power-gain-step-recovery value: 4
                                    debug attr 271: adi,rxagc-power-under-range-high-power-gain-step-recovery value: 4
                                    debug attr 272: adi,rxagc-power-under-range-low-power-thresh value: 2
                                    debug attr 273: adi,rxagc-power-under-range-high-power-thresh value: 9
                                    debug attr 274: adi,rxagc-power-power-use-bbdc2 value: 0
                                    debug attr 275: adi,rxagc-power-power-use-rfir-out value: 1
                                    debug attr 276: adi,rxagc-power-power-enable-measurement value: 1
                                    debug attr 277: adi,rxagc-peak-hb2-thresh-config value: 3
                                    debug attr 278: adi,rxagc-peak-hb2-ovrg-sel value: 0
                                    debug attr 279: adi,rxagc-peak-hb2-overload-power-mode value: 1
                                    debug attr 280: adi,rxagc-peak-hb2-gain-step-attack value: 4
                                    debug attr 281: adi,rxagc-peak-hb2-gain-step-mid-recovery value: 8
                                    debug attr 282: adi,rxagc-peak-hb2-gain-step-low-recovery value: 4
                                    debug attr 283: adi,rxagc-peak-hb2-gain-step-high-recovery value: 2
                                    debug attr 284: adi,rxagc-peak-hb2-lower-thresh-peak-exceeded-cnt value: 3
                                    debug attr 285: adi,rxagc-peak-hb2-upper-thresh-peak-exceeded-cnt value: 6
                                    debug attr 286: adi,rxagc-peak-hb2-under-range-high-thresh value: 128
                                    debug attr 287: adi,rxagc-peak-hb2-under-range-mid-thresh value: 90
                                    debug attr 288: adi,rxagc-peak-hb2-under-range-low-thresh value: 45
                                    debug attr 289: adi,rxagc-peak-hb2-high-thresh value: 181
                                    debug attr 290: adi,rxagc-peak-hb2-overload-thresh-cnt value: 4
                                    debug attr 291: adi,rxagc-peak-hb2-overload-duration-cnt value: 1
                                    debug attr 292: adi,rxagc-peak-enable-hb2-overload value: 1
                                    debug attr 293: adi,rxagc-peak-apd-gain-step-recovery value: 2
                                    debug attr 294: adi,rxagc-peak-apd-gain-step-attack value: 4
                                    debug attr 295: adi,rxagc-peak-apd-lower-thresh-peak-exceeded-cnt value: 3
                                    debug attr 296: adi,rxagc-peak-apd-upper-thresh-peak-exceeded-cnt value: 6
                                    debug attr 297: adi,rxagc-peak-apd-low-gain-mode-low-thresh value: 19
                                    debug attr 298: adi,rxagc-peak-apd-low-thresh value: 23
                                    debug attr 299: adi,rxagc-peak-apd-low-gain-mode-high-thresh value: 36
                                    debug attr 300: adi,rxagc-peak-apd-high-thresh value: 39
                                    debug attr 301: adi,rxagc-peak-agc-under-range-high-interval value: 4
                                    debug attr 302: adi,rxagc-peak-agc-under-range-mid-interval value: 2
                                    debug attr 303: adi,rxagc-peak-agc-under-range-low-interval_ns value: 205
                                    debug attr 304: adi,default-initial-calibrations-mask value: 9362927
                                    debug attr 305: direct_reg_access value: 0x3C
            iio_sysfs_trigger:
                    0 channels found:
                    2 device-specific attributes found:
                                    attr  0: add_trigger ERROR: Permission denied (-13)
                                    attr  1: remove_trigger ERROR: Permission denied (-13)
    root@peta-adi:~#
    Thanks.
  • The transport layer core devices are missing.
    That's why you don't see channels.
