cannot find iio device "adrv9009-phy" (zc706+adrv9008-1)
The user encountered issues with the ADRV9008-1 device not appearing in /dev after booting on a ZC706 EVB with Petalinux 2018.3 and the meta-adi 2019_R1 project. The problem was resolved by modifying the device tree to use 'zynq-zc706-adv7511-adrv9008-1.dts' and adding a 'pl-delete-nodes-~~~.dtsi' file to resolve label conflicts. The ADRV9008-1 initialization succeeded after these changes.
I am running the test by referring to this document. ( https://wiki.analog.com/resources/tools-software/linux-drivers/iio-transceiver/adrv9009 )
But after booting I can't find iio:device (adrv9008-1) in "/dev". There are only xadc and ad9528.
My test environment.
1. Vivado 2018.3 / Petalinux 2018.3
2. HDL project ( hdl_2019_r1 ) : https://github.com/analogdevicesinc/hdl/tree/hdl_2019_r1
3. meta-adi project ( 2019_R1 ) : https://github.com/analogdevicesinc/meta-adi/tree/2019_R1
4. zc706 EVB + ADRV9008-1 EVB
5. Ubuntu 16.04
I enabled an adrv9009 driver in "petalinux-config -c kernel" ( adrv9009 , ad9528 , jesd204 drivers )
In this documents (https://wiki.analog.com/resources/tools-software/linux-drivers/iio-transceiver/adrv9009) Example Linux Device-Tree Initialization section.
I used zc706 + adrv9008-1. so, Is there any part where I need to modify the device tree file?
I want to see the adrv9008-1 device in /dev after booting.
attached my BootLog file. please help.
thanks.
U-Boot 2018.01 (Dec 03 2020 - 04:31:22 +0000) Xilinx Zynq ZC702
Model: Xilinx Zynq ZC706
Board: Xilinx Zynq
Silicon: v3.1
I2C:   ready
DRAM:  ECC disabled 1 GiB
MMC:   mmc@e0100000: 0 (SD)
Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial@e0001000
Out:   serial@e0001000
Err:   serial@e0001000
Board: Xilinx Zynq
Silicon: v3.1
Net:   ZYNQ GEM: e000b000, phyaddr 7, interface rgmii-id
eth0: ethernet@e000b000
U-BOOT for peta-adi
ethernet@e000b000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Hit any key to stop autoboot:  0
Device: mmc@e0100000
Manufacturer ID: 74
OEM: 4a60
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
12542616 bytes read in 698 ms (17.1 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf@system-top.dtb' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000100
     Data Size:    4486142 Bytes = 4.3 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    sha1
     Hash value:   ff7274081f2bceebbfaab916ab57639fa8476b8d
   Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  petalinux-user-image
     Type:         RAMDisk Image
     Data Start:   0x1045164c
     Data Size:    8013501 Bytes = 7.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   b8f7a069922faf581ec35445e4a45db3568c22ab
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x10447600
     Data Size:    40844 Bytes = 39.9 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   e0975f4340bf221cf96150263d5b17620dcca87e
   Booting using the fdt blob at 0x10447600
   Uncompressing Kernel Image ... OK
   Loading Ramdisk to 0785b000, end 07fff6bd ... OK
   Loading Device Tree to 0784e000, end 0785af8b ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.14.0-xilinx- (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Thu Dec 3 04:42:18 UTC 2020
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: Xilinx Zynq ZC706
bootconsole [earlycon0] enabled
Memory policy: Data cache writealloc
cma: Reserved 128 MiB at 0x38000000
random: fast init done
percpu: Embedded 16 pages/cpu @ef7c2000 s32972 r8192 d24372 u65536
Built 1 zonelists, mobility grouping on.  Total pages: 260608
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 889172K/1048576K available (6144K kernel code, 316K rwdata, 2248K rodata, 1024K init, 153K bss, 28332K reserved, 131072K cma-reserved, 131072K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0700000   (7136 kB)
      .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
      .data : 0xc0b00000 - 0xc0b4f0c0   ( 317 kB)
       .bss : 0xc0b54610 - 0xc0b7ac94   ( 154 kB)
Preemptible hierarchical RCU implementation.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
        Tasks RCU enabled.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to f0802000
slcr mapped to f0804000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0804100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at f080c000, irq=17
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100060
Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 26, base_baud = 3125000) is a xuartps
▒console [ttyPS0] enabled
bootconsole [earlycon0] disabled
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
FPGA manager framework
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 7828K
hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=18 bucket_order=0
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
io scheduler mq-deadline registered
io scheduler kyber registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
brd: module loaded
loop: module loaded
m25p80 spi2.0: found s25fl128s, expected n25q128a11
m25p80 spi2.0: s25fl128s (32768 Kbytes)
5 ofpart partitions found on MTD device spi2.0
Creating 5 MTD partitions on "spi2.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000540000 : "config"
0x000000540000-0x000000fc0000 : "image"
0x000000fc0000-0x000002000000 : "spare"
MACsec IEEE 802.1AE
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 30 (00:0a:35:00:1e:53)
Marvell 88E1116R e000b000.ethernet-ffffffff:07: attached PHY driver [Marvell 88E1116R] (mii_bus:phy_addr=e000b000.ethernet-ffffffff:07, irq=POLL)
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
chipidea-usb2 e0002000.usb: e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 23
si570: probe of 2-005d failed with error -5
i2c i2c-1: Added multiplexed i2c bus 2
adv7511 3-0039: 3-0039 supply avdd not found, using dummy regulator
adv7511 3-0039: 3-0039 supply dvdd not found, using dummy regulator
adv7511 3-0039: 3-0039 supply pvdd not found, using dummy regulator
adv7511 3-0039: 3-0039 supply bgvdd not found, using dummy regulator
adv7511 3-0039: 3-0039 supply dvdd-3v not found, using dummy regulator
i2c i2c-1: Added multiplexed i2c bus 3
at24 4-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-1: Added multiplexed i2c bus 4
pca953x 5-0021: 5-0021 supply vcc not found, using dummy regulator
pca953x 5-0021: interrupt support not compiled in
i2c i2c-1: Added multiplexed i2c bus 5
rtc-pcf8563 6-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-1: Added multiplexed i2c bus 6
at24 7-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
i2c i2c-1: Added multiplexed i2c bus 7
i2c i2c-1: Added multiplexed i2c bus 8
i2c i2c-1: Added multiplexed i2c bus 9
pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at f090c000 with timeout 10s
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
adrv9009 spi0.1: adrv9009_probe : enter
ad9528 spi0.0: spi0.0 supply vcc not found, using dummy regulator
mmc0: new high speed SDHC card at address 59b4
mmcblk0: mmc0:59b4 USD   7.51 GiB
 mmcblk0: p1
axi_adxcvr 44a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using GTX2 at 0x44A60000 mapped to 0xf092e000. Number of lanes: 2.
axi_adxcvr 44a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using GTX2 at 0x44A50000 mapped to 0xf094a000. Number of lanes: 2.
axi_adxcvr 44a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using GTX2 at 0x44A80000 mapped to 0xf094c000. Number of lanes: 4.
axi_sysid 45000000.axi-sysid-0: [adrv9009] on [zc706] git <0> dirty [2020-12-02 08:09:37] UTC
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
Registering SWP/SWPB emulation handler
[drm] Cannot find any crtc or sizes
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 for 70e00000.axi_hdmi on minor 0
adrv9009 spi0.1: ADIHAL_resetHw at index
random: crng init done
adrv9009 spi0.1: ERROR: 247: TALISE_waitArmCmdStatus() failed due to thrown ARM error. ARM time out
adrv9009 spi0.1: adrv9009_do_setup:759 (ret 5)
------------[ cut here ]------------
WARNING: CPU: 0 PID: 42 at /kernel-source//drivers/clk/clk.c:622 clk_core_disable_lock+0x18/0x24
Modules linked in:
CPU: 0 PID: 42 Comm: kworker/0:1 Not tainted 4.14.0-xilinx- #1
Hardware name: Xilinx Zynq Platform
Workqueue: events deferred_probe_work_func
[<c010ef54>] (unwind_backtrace) from [<c010b844>] (show_stack+0x10/0x14)
[<c010b844>] (show_stack) from [<c068ad00>] (dump_stack+0x8c/0xa0)
[<c068ad00>] (dump_stack) from [<c011c988>] (__warn+0xe8/0x100)
[<c011c988>] (__warn) from [<c011ca50>] (warn_slowpath_null+0x20/0x28)
[<c011ca50>] (warn_slowpath_null) from [<c0335570>] (clk_core_disable_lock+0x18/0x24)
[<c0335570>] (clk_core_disable_lock) from [<c054e4fc>] (adrv9009_setup+0x478/0x1058)
[<c054e4fc>] (adrv9009_setup) from [<c055284c>] (adrv9009_probe+0x3770/0x3c7c)
[<c055284c>] (adrv9009_probe) from [<c04094b0>] (spi_drv_probe+0x7c/0xa8)
[<c04094b0>] (spi_drv_probe) from [<c03ae964>] (driver_probe_device+0x238/0x2e8)
[<c03ae964>] (driver_probe_device) from [<c03acf60>] (bus_for_each_drv+0x44/0x94)
[<c03acf60>] (bus_for_each_drv) from [<c03ae64c>] (__device_attach+0xb0/0x114)
[<c03ae64c>] (__device_attach) from [<c03adc38>] (bus_probe_device+0x84/0x8c)
[<c03adc38>] (bus_probe_device) from [<c03ae084>] (deferred_probe_work_func+0x50/0x14c)
[<c03ae084>] (deferred_probe_work_func) from [<c0133458>] (process_one_work+0x1d8/0x410)
[<c0133458>] (process_one_work) from [<c01343a8>] (worker_thread+0x2a0/0x598)
[<c01343a8>] (worker_thread) from [<c0138ec4>] (kthread+0x14c/0x154)
[<c0138ec4>] (kthread) from [<c0107b90>] (ret_from_fork+0x14/0x24)
---[ end trace 02cae0b98a7b14af ]---
WARNING: CPU: 0 PID: 42 at /kernel-source//drivers/clk/clk.c:504 clk_unprepare+0x24/0x2c
Modules linked in:
CPU: 0 PID: 42 Comm: kworker/0:1 Tainted: G        W       4.14.0-xilinx- #1
[<c011ca50>] (warn_slowpath_null) from [<c0335c84>] (clk_unprepare+0x24/0x2c)
[<c0335c84>] (clk_unprepare) from [<c054e504>] (adrv9009_setup+0x480/0x1058)
[<c054e504>] (adrv9009_setup) from [<c055284c>] (adrv9009_probe+0x3770/0x3c7c)
---[ end trace 02cae0b98a7b14b0 ]---
INFO: task swapper/0:1 blocked for more than 20 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
swapper/0       D    0     1      0 0x00000000
[<c069fbac>] (__schedule) from [<c069ff58>] (schedule+0x54/0xc0)
[<c069ff58>] (schedule) from [<c06a33a4>] (schedule_timeout+0x120/0x168)
[<c06a33a4>] (schedule_timeout) from [<c06a0be4>] (wait_for_common+0x94/0x144)
[<c06a0be4>] (wait_for_common) from [<c013256c>] (flush_work+0x128/0x194)
[<c013256c>] (flush_work) from [<c03ae428>] (deferred_probe_initcall+0x20/0x30)
[<c03ae428>] (deferred_probe_initcall) from [<c0101a20>] (do_one_initcall+0x44/0x168)
[<c0101a20>] (do_one_initcall) from [<c0a00db8>] (kernel_init_freeable+0x144/0x1d0)
[<c0a00db8>] (kernel_init_freeable) from [<c069e820>] (kernel_init+0x8/0x110)
[<c069e820>] (kernel_init) from [<c0107b90>] (ret_from_fork+0x14/0x24)
Modules linked in:
[<c054e4fc>] (adrv9009_setup) from [<c0552ac0>] (adrv9009_probe+0x39e4/0x3c7c)
[<c0552ac0>] (adrv9009_probe) from [<c04094b0>] (spi_drv_probe+0x7c/0xa8)
---[ end trace 02cae0b98a7b14b1 ]---
Modules linked in:
[<c054e504>] (adrv9009_setup) from [<c0552ac0>] (adrv9009_probe+0x39e4/0x3c7c)
---[ end trace 02cae0b98a7b14b2 ]---
adrv9009: probe of spi0.1 failed with error -14
asoc-simple-card adv7511_hdmi_snd: spdif-hifi <-> 75c00000.axi-spdif-tx mapping ok
input: gpio_keys as /devices/soc0/gpio_keys/input/input0
rtc-pcf8563 6-0051: setting system clock to 2020-12-03 05:25:34 UTC (1606973134)
ALSA device list:
  #0: HDMI monitor
Freeing unused kernel memory: 1024K
INIT: version 2.88 booting
Starting udev
udevd[986]: starting version 3.2.2
udevd[987]: starting eudev-3.2.2
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting internet superserver: inetd.
Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
 Removing any system startup links for run-postinsts ...
  /etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
Starting system message bus: dbus.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQC/Tt3XxcRfp4zYLzllosCJ0D2Ocyz/W3auCdmmM0m17Zhh9ouaLD0DYRwfngiMmd3xkvO4SIFOM9OboW8tFtZg/HSIoTWwz4FTTv+oomKJ6HjVm7cjjIKWDSNPWPUVYGPff+juE0lxExgUf5wenQwaSguet1Fx7hS54O1xL/+1QQoxG7pdnUp36Zv+mnH3CLrxsPuJi1HI95wm4eMh06XeAqQBDReDxw6zVEOGI+bCBq0SGYk91zJof4dUMc5XphpjaOOY1mD5Zz5rI/vEju218DvbGCCXWJHL7EWikPCRWAxK9pOVA0eStg4bL2Ubgse1UTA+eLwADtWkvYlzckVD root@peta-adi
Fingerprint: md5 03:00:c6:91:67:1c:dd:f9:56:b9:36:c1:1d:e6:57:f0
dropbear.
Starting IIO Daemon: iiod
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2018.3 peta-adi /dev/ttyPS0
peta-adi login: root
Password:
root@peta-adi:~# ls /dev
block               loop5               ram12               tty2                tty5
bus                 loop6               ram13               tty20               tty50
char                loop7               ram14               tty21               tty51
console             mem                 ram15               tty22               tty52
cpu_dma_latency     memory_bandwidth    ram2                tty23               tty53
disk                mmcblk0             ram3                tty24               tty54
dri                 mmcblk0p1           ram4                tty25               tty55
fd                  mtab                ram5                tty26               tty56
full                mtd0                ram6                tty27               tty57
gpiochip0           mtd0ro              ram7                tty28               tty58
gpiochip1           mtd1                ram8                tty29               tty59
i2c-0               mtd1ro              ram9                tty3                tty6
i2c-1               mtd2                random              tty30               tty60
i2c-2               mtd2ro              rtc                 tty31               tty61
i2c-3               mtd3                rtc0                tty32               tty62
i2c-4               mtd3ro              shm                 tty33               tty63
i2c-5               mtd4                snd                 tty34               tty7
i2c-6               mtd4ro              stderr              tty35               tty8
i2c-7               mtdblock0           stdin               tty36               tty9
i2c-8               mtdblock1           stdout              tty37               ttyPS0
i2c-9               mtdblock2           tty                 tty38               udev_network_queue
iio:device0         mtdblock3           tty0                tty39               urandom
iio:device1         mtdblock4           tty1                tty4                vcs
initctl             net                 tty10               tty40               vcs1
input               network_latency     tty11               tty41               vcsa
kmsg                network_throughput  tty12               tty42               vcsa1
log                 null                tty13               tty43               watchdog
loop-control        ptmx                tty14               tty44               watchdog0
loop0               pts                 tty15               tty45               zero
loop1               ram0                tty16               tty46
loop2               ram1                tty17               tty47
loop3               ram10               tty18               tty48
loop4               ram11               tty19               tty49
root@peta-adi:~# cat /sys/bus/iio/devices/iio\:device0/name
xadc
root@peta-adi:~# cat /sys/bus/iio/devices/iio\:device1/name
ad9528-1
root@peta-adi:~#
Edit Notes
modify a subject.
[edited by: JehoLee at 6:50 AM (GMT -5) on 11 Dec 2020]
    It seems that your driver is failing here. Did you follow the steps to setup the firmware for the Stream Processor ?
    https://wiki.analog.com/resources/tools-software/linux-drivers/iio-transceiver/adrv9009#stream_processor_configuration
    Mircea
  • I don't think the stream processor will cause this. The default stream should work.
    Can you try our 2019_R2 Linux kernel relapse branch. We improved some error reporting in the driver.
  • By the way, why did you enable the driver manually? It shouldn't be the case if you use our defconfig (meta-adi/linux-xlnx_%.bbappend at master · analogdevicesinc/meta-adi (github.com)).
    Dragos
  • Thank you for reply.
    I used the meta-adi. ( refer "building with petalinux" ).
    If I use the 2019_R2 branch's Linux kernel source, specify the external kernel source path in petalinux configuration.
    Then, how do I set the yocto layer?
    ( in meta-adi, not exist 2019_R2 branch)
  • Thank you for reply, Mircea.
    I haven't done that step.
    After build I checked location "TaliseStream.bin".
    "TaliseStream.bin" exists in the directory path"/build/tmp/work-shared/plnx-zynq7/kernel-source/firmware/"
    Are there any differences between this file and the one you talked about?
  • Hi, Dragos.
    Sorry, There was a mistake in the word.
    Drivers was enabled by default. but another drivers also enabled.
    I have disabled such a driver.
    Yes, not yet. But, in fact, the current master branch will become 2019_R2 as soon as we are ready to make that change. So, for quickly trying meta-adi with our 2019_R2 kernel branch you can go to the line and change it to 2019_R2. Give it a try and see if it work.
    Hope this helps!
    - Nuno Sá
    I tried it the way you suggested.
    Vivado 2019.1 / petalinux 2019.1 / HDL 2019_R2 / meta-adi 2019_R2 and bash shell.
    However, an error occurs during petalinux-build. The error message appears to be a device tree related error.
    I know this error is due to petalinuxbsp.conf or dash shell. I runned bash shell.
    so, please check this file. why did I get error?
    /project-spec/meta-user/conf/petalinuxbsp.conf
    #User Configuration
    #OE_TERMINAL = "tmux"
    # Add EXTRA_IMAGEDEPENDS default components
    EXTRA_IMAGEDEPENDS_append_versal = " virtual/psm-firmware virtual/plm arm-trusted-firmware u-boot-zynq-scr"
    EXTRA_IMAGEDEPENDS_append_zynqmp = " virtual/fsbl virtual/pmu-firmware arm-trusted-firmware"
    EXTRA_IMAGEDEPENDS_append_zynq = " virtual/fsbl"
    EXTRA_IMAGEDEPENDS_append_microblaze = " virtual/fsboot virtual/elfrealloc"
    # prevent U-Boot from deploying the boot.bin
    SPL_BINARY = ""
    #Remove all qemu contents
    IMAGE_CLASSES_remove = "image-types-xilinx-qemu qemuboot-xilinx"
    IMAGE_FSTYPES_remove = "wic.qemu-sd"
    EXTRA_IMAGEDEPENDS_remove = "qemu-helper-native virtual/boot-bin"
    SIGGEN_UNLOCKED_RECIPES_append_versal = " initscripts"
    KERNEL_DTB="zc706-adv7511-adrv9009"
    Thank you for help.
  • So, it looks like you are using your own devicetree (zc706-adv7511-adrv9)? zynq-zc706-adv7511-adrv9009.dts is the one supported for this project. If you need changes of your own to the devicetree, you should see how to extend a devicetree in meta-adi or how to just add a new project...
    I tried test with 2019_R2 branch. but the same errors occurred.
    So, I added the TALISE_VERBOSE flag, to see where the error occurred.
    U-Boot 2018.01 (Dec 07 2020 - 06:04:21 +0000) Xilinx Zynq ZC702
    Board: Xilinx Zynq
    Silicon: v3.1
    I2C:   ready
    In:    serial@e0001000
    Board: Xilinx Zynq
    Silicon: v3.1
    U-BOOT for peta-adi
    Manufacturer ID: 74
    OEM: 4a60
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 7.5 GiB
    Bus Width: 4-bit
    reading image.ub
    12546544 bytes read in 696 ms (17.2 MiB/s)
         Type:         Kernel Image
         Data Size:    4489963 Bytes = 4.3 MiB
         Architecture: ARM
         OS:           Linux
         Hash algo:    sha1
         Hash value:   86c7a2804f1badd99f3f8b9cfa7c46f466d05453
         Type:         RAMDisk Image
         Data Start:   0x10452538
         Data Size:    8013609 Bytes = 7.6 MiB
         Architecture: ARM
         OS:           Linux
         Hash algo:    sha1
         Hash value:   9eb33b0cda530f69dd1f0d607042a9d1ce887ec3
         Data Start:   0x104484ec
         Architecture: ARM
         Hash algo:    sha1
       Booting using the fdt blob at 0x104484ec
       Loading Ramdisk to 0785b000, end 07fff729 ... OK
    Starting kernel ...
    Linux version 4.14.0-xilinx- (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #3 SMP PREEMPT Mon Dec 7 06:00:45 UTC 2020
    Memory: 889172K/1048576K available (6144K kernel code, 316K rwdata, 2252K rodata, 1024K init, 153K bss, 28332K reserved, 131072K cma-reserved, 131072K highmem)
            Tasks RCU enabled.
    Zynq clock init
    `▒▒k▒▒▒▒[ttyPS0] enabled
    brd: module loaded
    loop: module loaded
    MACsec IEEE 802.1AE
     mmcblk0: p1
    adrv9009 spi0.1: MESSAGE: 0: TALISE_resetDevice()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_initialize()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_calculateDigitalClocks()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setSpiSettings()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_verifySpiReadWrite()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_getDeviceRev()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_initDigitalClocks()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_waitForEvent()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_programFir()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_programRxGainTable()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setRxManualGain()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_programOrxGainTable()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setObsRxManualGain()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setupJesd204bFramer()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setupAdcSampleXbar()
    adrv9009 spi0.1: MESSAGE: 0: talRecoveryActions_t()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setupDeserializers()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setupDacSampleXbar()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_enableDeframerLink()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setTxAttenuation()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_getPllsLockStatus()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_enableMultichipSync()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_SerializerReset()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_initArm()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_writeArmConfig()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_writeArmMem()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_loadAdcProfiles
    adrv9009 spi0.1: MESSAGE: 0: TALISE_loadStreamFromBinary()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_loadArmFromBinary()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_verifyArmChecksum()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_readArmMem()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_sendArmCommand()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_waitArmCmdStatus()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_readArmCmdStatusByte()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setArmGpioPins()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setGpioOe()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setRfPllLoopFilter()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_setPllLoopFilter()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_checkInitCalComplete()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_runInitCals()
    adrv9009 spi0.1: MESSAGE: 0: TALISE_waitInitCals()
    WARNING: CPU: 0 PID: 28 at /kernel-source//drivers/clk/clk.c:622 clk_core_disable_lock+0x18/0x24
    Modules linked in:
    CPU: 0 PID: 28 Comm: kworker/0:1 Not tainted 4.14.0-xilinx- #3
    [<c010b844>] (show_stack) from [<c068d560>] (dump_stack+0x8c/0xa0)
    [<c068d560>] (dump_stack) from [<c011c988>] (__warn+0xe8/0x100)
    ---[ end trace e3c893506661cb65 ]---
    WARNING: CPU: 0 PID: 28 at /kernel-source//drivers/clk/clk.c:504 clk_unprepare+0x24/0x2c
    Modules linked in:
    CPU: 0 PID: 28 Comm: kworker/0:1 Tainted: G        W       4.14.0-xilinx- #3
    ---[ end trace e3c893506661cb66 ]---
    [<c06a240c>] (__schedule) from [<c06a27b8>] (schedule+0x54/0xc0)
    [<c06a27b8>] (schedule) from [<c06a5c04>] (schedule_timeout+0x120/0x168)
    [<c06a5c04>] (schedule_timeout) from [<c06a3444>] (wait_for_common+0x94/0x144)
    [<c06a3444>] (wait_for_common) from [<c013256c>] (flush_work+0x128/0x194)
    [<c0a00db8>] (kernel_init_freeable) from [<c06a1080>] (kernel_init+0x8/0x110)
    [<c06a1080>] (kernel_init) from [<c0107b90>] (ret_from_fork+0x14/0x24)
    Modules linked in:
    ---[ end trace e3c893506661cb67 ]---
    Modules linked in:
    ---[ end trace e3c893506661cb68 ]---
    rtc-pcf8563 6-0051: setting system clock to 2020-12-07 06:07:16 UTC (1607321236)
    ALSA device list:
      #0: HDMI monitor
    Starting udev
    done.
    ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCcQY6yQzL4A1Ta2LNaSpLw5MOUMI1zUE4AeOMnHngvquNG/LJIP5E34SilYWuPK132hmjjuzwDK7CzGg0mJ3Uc7C0eA4hFs9I8oz5EAj/OnmIavNSsTh8Xq4dirtU90k3/DVP55kHJt+Hzu+DFX5K6gPiMPAKay2IHArr6ILEf7+VBO4hlrWJT+2qkMkVTUQzgrWo3D6wORpI95rE3WuMH/XA1TGF5rU+n1HzuHX+BdXOPs/rkehhWCBJMvL0K5SoTKkcxFiyOG6qiLzMHOks20RnYsr8aYFzPSmFr3bWXfZkTtt4MzHT/RcMQzE1ovX/OgYwgOsxyWkc5J6Iu686D root@peta-adi
    Fingerprint: md5 2a:10:73:ca:cb:94:04:a5:c3:4f:3c:21:c2:67:4f:1b
    dropbear.
    peta-adi login:
    (In 2019_R2, when the VERBOSE flag was added, a halError undefined error occurred and could not be used.)
    In Bootlog, an error occurs in the process of executing runInitcal and then waitInitCal.
    Can I get any hints from this?
    add..
    In this page (https://wiki.analog.com/resources/tools-software/linux-drivers/iio-transceiver/adrv9009), section "example Linux-devicetree initialization".
    I don't know how to do it. I use the ADRV9008-1. The device tree has not been changed. Please tell me how to apply the steps above.
    Thanks.
