I'm using a windows computer with Pluto. And I have PYADI-IIO rev 0.0.5 installed and it all works great.
I saw rev 0.0.6 was recently released, so I upgraded to that. But now when I try to run my same Python script, I get
ModuleNotFoundError: No module named 'fs'
Complete error messages here:
[autoreload of adi.adrv9009 failed: Traceback (most recent call last): File "C:\Users\jkraft\Anaconda3\lib\site-packages\IPython\extensions\autoreload.py", line 245, in check superreload(m, reload, self.old_objects) File "C:\Users\jkraft\Anaconda3\lib\site-packages\IPython\extensions\autoreload.py", line 394, in superreload module = reload(module) File "C:\Users\jkraft\Anaconda3\lib\imp.py", line 314, in reload return importlib.reload(module) File "C:\Users\jkraft\Anaconda3\lib\importlib\__init__.py", line 169, in reload _bootstrap._exec(spec, module) File "<frozen importlib._bootstrap>", line 604, in _exec File "<frozen importlib._bootstrap_external>", line 783, in exec_module File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed File "C:\Users\jkraft\AppData\Local\Programs\Python\Python39\Lib\site-packages\adi\adrv9009.py", line 35, in <module> from adi.jesd import jesd as jesdadi File "C:\Users\jkraft\AppData\Local\Programs\Python\Python39\Lib\site-packages\adi\jesd.py", line 34, in <module> import fsModuleNotFoundError: No module named 'fs'][autoreload of adi failed: Traceback (most recent call last): File "C:\Users\jkraft\Anaconda3\lib\site-packages\IPython\extensions\autoreload.py", line 245, in check superreload(m, reload, self.old_objects) File "C:\Users\jkraft\Anaconda3\lib\site-packages\IPython\extensions\autoreload.py", line 394, in superreload module = reload(module) File "C:\Users\jkraft\Anaconda3\lib\imp.py", line 314, in reload return importlib.reload(module) File "C:\Users\jkraft\Anaconda3\lib\importlib\__init__.py", line 169, in reload _bootstrap._exec(spec, module) File "<frozen importlib._bootstrap>", line 604, in _exec File "<frozen importlib._bootstrap_external>", line 783, in exec_module File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed File "C:\Users\jkraft\AppData\Local\Programs\Python\Python39\Lib\site-packages\adi\__init__.py", line 72, in <module> from adi.jesd import * File "C:\Users\jkraft\AppData\Local\Programs\Python\Python39\Lib\site-packages\adi\jesd.py", line 34, in <module> import fsModuleNotFoundError: No module named 'fs']Traceback (most recent call last):
File "C:\Users\jkraft\OneDrive - Analog Devices, Inc\FAE\RF\SDR AD9361 and 71\GNUradio\FSK Radar\Pluto_FSK_rev1.py", line 21, in <module> import adi
File "C:\Users\jkraft\AppData\Local\Programs\Python\Python39\Lib\site-packages\adi\__init__.py", line 42, in <module> from adi.adrv9009 import *
During handling of the above exception, another exception occurred:
File "C:\Users\jkraft\OneDrive - Analog Devices, Inc\FAE\RF\SDR AD9361 and 71\GNUradio\FSK Radar\Pluto_FSK_rev1.py", line 24, in <module> import adi
Yes the JESD debugging is a new feature and requires fs.sshfs since it doesn't use libiio. We made a small update post release as well that will make the requirement truly optional if you don't need JESD…
I just noticed there is another optional install for pyadi-iio now:
https://analogdevicesinc.github.io/pyadi-iio/guides/quick.html
So I installed that on my windows computer ("pip.exe install pyadi-iio[jesd]"), and now it works! I guess the fs library was in there.
Yes the JESD debugging is a new feature and requires fs.sshfs since it doesn't use libiio. We made a small update post release as well that will make the requirement truly optional if you don't need JESD debugging: https://github.com/analogdevicesinc/pyadi-iio/pull/147
-Travis
Ah, thanks! It's no problem to just install both.
