AD9361 rootfs
I have a custom board which has 2 AD9361 and ZYNQ XC7Z030. I have built my Linux files separately. I can test my TX ports with spectrum analzyer. For my RX ports I added chipscope probes in to output of AD9361 ADC's I/Q pins. I can see sinus waves when I loopback my TX ports to RX ports.
However I need to see the RX ports in frequency domain. I installed IIO Oscilloscope application in my Linux computer then want to connect remotely to my custom board. In this point I used ubuntu based linaro 12.0 rootfs and booted from SD Card. But i couldn't install necessary files into the rootfs.  Is there any ready debian based rootfs which has IIO Oscilloscpe already installed?
When I search on google "AD9361 rootfs" or "Analog Devices rootfs" or "IIO Oscilloscope rootfs" or smt similar, I couldn't find it.
Thanks in advance.
Top Replies
Parents
    on Sep 11, 2020 9:55 AM 1 month ago
    You can take a look at this. It comes with IIO Oscilloscope and LibIIO installed on it.
    https://wiki.analog.com/resources/tools-software/linux-software/zynq_images
    Mircea
  • Thank you for your response.
    I have already seen this before but there are only .img image files. I have compiled files:
    * my_borad_u-boot.elf,
    * my_board_uImage
    *my_board.dtb
    * ubuntu_linaro_12.0 rootfs which I took from :
    https://wiki.analog.com/resources/tools-software/linux-drivers/platforms/zynq#install_the_root_file_system
    I need only rootfs. I will put rootfs on my sd card partition 2. I added bootargs parameters on my device tree to connect rootfs when Linux booted in the SD Card partition 2.
    Thanks.
  • +1
    on Sep 14, 2020 10:39 AM 1 month ago in reply to ibocakir06
    You could also try the released version from here:
    github.com/.../releases
  • I am so glad to write here. It worked !
    Now I have to figure out how to plot in time and frequency domain signals.
    Thanks a lot !
  • Hi again, I am facing a new issue.
    I can see the values and parameters here. I can loopback my TX channels to RX channels, I can see the RSSI value of RX Channels increasing or decreasing.
    However, I cant plot anything. My plot screen is total empty as you see here. Also only cf-ad9361-A is shown here.
    When I press the measure button it gives this error. Connection timed out !
    (osc-2019_R1-ged0dccf:27206): Gtk-CRITICAL **: IA__gtk_button_clicked: assertion 'GTK_IS_BUTTON (button)' failed
    Error while reading data: Connection timed out
    My Linux computer is not virtual, it is physical. I dont think there is a network issue.
    Is there a DMA interrupt problem or similar ?
    I generated my device tree via Xilinx Tool to learn what is it correct pin of interrupt. I beleive its true. By the way I dont know how to test my DMA function is working.
    Thanks in advance.
    on Sep 14, 2020 2:08 PM 1 month ago in reply to ibocakir06
    Can you send a dmesg output to check the debug messages? There could be some issues with some devices.
    Mircea
  • Hi, this is my kernel startup log.
    Starting kernel ...
    Booting Linux on physical CPU 0x0
    Linux version 4.14.0-xilinx-g4fea7c5-dirty (ibrahim@ibrahim-Lenovo-Y520-15IKBM) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #11 SMP PREEMPT Wed Sep 9 14:19:06 +03 2020
    CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
    CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    OF: fdt: Machine model: KONUMBUL SDR Board
    Memory policy: Data cache writealloc
    cma: Reserved 16 MiB at 0x1f000000
    random: fast init done
    percpu: Embedded 16 pages/cpu @debc1000 s34764 r8192 d22580 u65536
    Built 1 zonelists, mobility grouping on.  Total pages: 130048
    Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait
    PID hash table entries: 2048 (order: 1, 8192 bytes)
    Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    Memory: 492984K/524288K available (6144K kernel code, 278K rwdata, 1612K rodata, 1024K init, 157K bss, 14920K reserved, 16384K cma-reserved, 0K highmem)
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
        vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
        lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
        pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
        modules : 0xbf000000 - 0xbfe00000   (  14 MB)
          .text : 0xc0008000 - 0xc0700000   (7136 kB)
          .init : 0xc0900000 - 0xc0a00000   (1024 kB)
          .data : 0xc0a00000 - 0xc0a45a80   ( 279 kB)
           .bss : 0xc0a45a80 - 0xc0a6d044   ( 158 kB)
    Preemptible hierarchical RCU implementation.
    	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    	Tasks RCU enabled.
    RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    efuse mapped to e0800000
    slcr mapped to e0802000
    L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C-310 erratum 769419 enabled
    L2C-310 enabling early BRESP for Cortex-A9
    L2C-310 full line of zeros enabled for Cortex-A9
    L2C-310 ID prefetch enabled, offset 1 lines
    L2C-310 dynamic clock gating enabled, standby mode enabled
    L2C-310 cache controller enabled, 8 ways, 512 kB
    L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
    zynq_clock_init: clkc starts at e0802100
    Zynq clock init
    sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
    clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
    Switching to timer-based delay loop, resolution 3ns
    clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
    timer #0 at e080a000, irq=17
    Console: colour dummy device 80x30
    Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    CPU: Testing write buffer coherency: ok
    CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Setting up static identity map for 0x100000 - 0x100060
    Hierarchical SRCU implementation.
    smp: Bringing up secondary CPUs ...
    CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    smp: Brought up 1 node, 2 CPUs
    SMP: Total of 2 processors activated (1333.33 BogoMIPS).
    CPU: All CPU(s) started in SVC mode.
    devtmpfs: initialized
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    futex hash table entries: 512 (order: 3, 32768 bytes)
    pinctrl core: initialized pinctrl subsystem
    NET: Registered protocol family 16
    DMA: preallocated 256 KiB pool for atomic coherent allocations
    cpuidle: using governor menu
    hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    hw-breakpoint: maximum watchpoint size is 4 bytes.
    zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xe0840000
    zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
    e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 26, base_baud = 3125000) is a xuartps
    console [ttyPS0] enabled
    vgaarb: loaded
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    usb_phy_generic phy0: phy0 supply vcc not found, using dummy regulator
    media: Linux media interface: v0.10
    Linux video capture interface: v2.00
    pps_core: LinuxPPS API ver. 1 registered
    pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    PTP clock support registered
    EDAC MC: Ver: 3.0.0
    FPGA manager framework
    fpga-region fpga-full: FPGA Region probed
    Advanced Linux Sound Architecture Driver Initialized.
    clocksource: Switched to clocksource arm_global_timer
    NET: Registered protocol family 2
    TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    TCP: Hash tables configured (established 4096 bind 4096)
    UDP hash table entries: 256 (order: 1, 8192 bytes)
    UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
    hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
    workingset: timestamp_bits=30 max_order=17 bucket_order=0
    jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    io scheduler mq-deadline registered
    io scheduler kyber registered
    dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
    dma-pl330 f8003000.dmac: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
    brd: module loaded
    loop: module loaded
    libphy: Fixed MDIO Bus: probed
    CAN device driver interface
    libphy: MACB_mii_bus: probed
    macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 28 (00:0a:35:00:00:00)
    Marvell 88E1510 e000b000.ethernet-ffffffff:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=e000b000.ethernet-ffffffff:01, irq=POLL)
    e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    ehci-pci: EHCI PCI platform driver
    usbcore: registered new interface driver usb-storage
    chipidea-usb2 e0003000.usb: e0003000.usb supply vbus not found, using dummy regulator
    ci_hdrc ci_hdrc.0: EHCI Host Controller
    ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
    ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    i2c /dev entries driver
    rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
    rtc-pcf8563 0-0051: rtc core: registered rtc-pcf8563 as rtc0
    cdns-i2c e0004000.i2c: 100 kHz mmio e0004000 irq 23
    IR NEC protocol handler initialized
    IR RC5(x/sz) protocol handler initialized
    IR RC6 protocol handler initialized
    IR JVC protocol handler initialized
    IR Sony protocol handler initialized
    IR SANYO protocol handler initialized
    IR Sharp protocol handler initialized
    IR MCE Keyboard/mouse protocol handler initialized
    IR XMP protocol handler initialized
    cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at e0954000 with timeout 10s
    EDAC MC: ECC not enabled
    Xilinx Zynq CpuIdle Driver started
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    sdhci-pltfm: SDHCI platform and OF driver helper
    mmc0: SDHCI controller on e0101000.mmc [e0101000.mmc] using ADMA
    ledtrig-cpu: registered to indicate activity on CPUs
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    ad9361 spi0.0: ad9361_probe : enter (ad9361-2x)
    ad9361 spi0.0: No GPIOs defined for ext band ctrl
    mmc0: new high speed SDHC card at address 1234
    mmcblk0: mmc0:1234 SA08G 7.41 GiB
     mmcblk0: p1 p2
    ad9361 spi0.0: ad9361_probe: failed to register debugfs
    ad9361 spi0.0: ad9361_probe : AD936x Rev 2 successfully initialized
    ad9361 spi0.1: ad9361_probe : enter (ad9361)
    ad9361 spi0.1: No GPIOs defined for ext band ctrl
    ad9361 spi0.1: ad9361_probe: failed to register debugfs
    ad9361 spi0.1: ad9361_probe : AD936x Rev 2 successfully initialized
    cf_axi_dds 79024000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x79024000 mapped to 0xe0965000, probed DDS AD9361
    cf_axi_dds 79044000.cf-ad9361-dds-core-B: Analog Devices CF_AXI_DDS_DDS SLAVE (9.01.b) at 0x79044000 mapped to 0xe0969000, probed DDS AD9361
    fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
    NET: Registered protocol family 10
    Segment Routing with IPv6
    sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    can: controller area network core (rev 20170425 abi 9)
    NET: Registered protocol family 29
    can: raw protocol (rev 20170425)
    can: broadcast manager protocol (rev 20170425 t)
    can: netlink gateway (rev 20170425) max_hops=1
    Registering SWP/SWPB emulation handler
    cf_axi_adc 79020000.cf-ad9361-A: ADI AIM (10.01.b) at 0x79020000 mapped to 0xe0978000, probed ADC AD9361-2 as MASTER
    cf_axi_adc 79040000.cf-ad9361-B: ADI AIM (10.01.b) at 0x79040000 mapped to 0xe0988000, probed ADC AD9361 as SLAVE
    rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
    of_cfs_init
    of_cfs_init: OK
    ALSA device list:
      No soundcards found.
    EXT4-fs (mmcblk0p2): recovery complete
    EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    VFS: Mounted root (ext4 filesystem) on device 179:2.
    devtmpfs: mounted
    Freeing unused kernel memory: 1024K
    Mount failed for selinuxfs on /sys/fs/selinux:  No such file or directory
    init: hwclock main process (731) terminated with status 1
    mmcblk0: r/w command failed, status = 0x80000900
     * Setting up X socket directories...                                    [ OK ]
     * STARTDISTCC is set to false in /etc/default/distcc
     * /usr/bin/distccd not starting
    /usr/sbin/kerneloops: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/libffi.so.6: file too short
     * Starting IIO Daemon iiod                                              [ OK ]
    Last login: Thu Jan  1 00:00:12 UTC 1970 on tty1
    Welcome to Linaro 14.04 (GNU/Linux 4.14.0-xilinx-g4fea7c5-dirty armv7l)
     * Documentation:  https://wiki.analog.com/ https://ez.analog.com/
    Fatal Python error: Py_Initialize: Unable to get the locale encoding
    LookupError: no codec search functions registered: can't find encoding
    Aborted
    root@analog:~#
    This is also my dmesg output.
    root@analog:~# dmesg
    ad9361 spi0.1: cdns_spi_setup_transfer, mode 1, 8 bits/w, 5208333 clock speed
    of_cfs_init
    of_cfs_init: OK
    ALSA device list:
    devtmpfs: mounted
    systemd-udevd[825]: starting version 204
    init: dbus pre-start process (820) terminated with status 1
    init: rsyslog main process (1120) terminated with status 1
    init: rsyslog main process ended, respawning
    init: udev-fallback-graphics main process (1174) terminated with status 1
    init: samba-ad-dc main process (1260) terminated with status 127
    init: failsafe main process (1201) killed by TERM signal
    init: smbd main process (1255) terminated with status 127
    init: smbd main process ended, respawning
    init: smbd main process (1324) terminated with status 127
    init: smbd main process (1334) terminated with status 127
    init: smbd main process (1346) terminated with status 127
    init: smbd main process (1379) terminated with status 127
    init: ssh main process (1385) terminated with status 127
    init: ssh main process ended, respawning
    init: whoopsie main process (1392) terminated with status 127
    init: whoopsie main process ended, respawning
    init: alsa-restore main process (1396) terminated with status 19
    init: smbd main process (1448) terminated with status 127
    init: smbd main process (1461) terminated with status 127
    init: smbd main process (1483) terminated with status 127
    init: smbd main process (1491) terminated with status 127
    init: smbd main process (1511) terminated with status 127
    init: smbd main process (1520) terminated with status 127
    init: smbd respawning too fast, stopped
    init: tty1 main process (1502) killed by TERM signal
    ad9361 spi0.0: cdns_spi_setup_transfer, mode 1, 8 bits/w, 5208333 clock speed
    Thanks.
Reply
    Starting kernel ...
    	Tasks RCU enabled.
    Zynq clock init
    vgaarb: loaded
    EDAC MC: Ver: 3.0.0
    brd: module loaded
    loop: module loaded
     mmcblk0: p1 p2
    of_cfs_init
    of_cfs_init: OK
    ALSA device list:
    devtmpfs: mounted
    Aborted
    root@analog:~#
    of_cfs_init
    of_cfs_init: OK
    ALSA device list:
    devtmpfs: mounted
    Thanks.
Children
