Hi
Is there a TESTED device tree that support MULTIPLE HMC7044/HMC7043 devices (master and slave) that we can use as a reference?
Thanks
IK
HMC7043
Recommended for New Designs
The HMC7043 is designed to meet the requirements of multicarrier GSM and LTE base station designs, and offers a wide range of clock management and distribution...
Datasheet
HMC7043 on Analog.com
HMC7044
The HMC7044 is a high performance, dual-loop, integer-N jitter attenuator capable of performing reference selection and generation of ultralow phase noise...
Datasheet
HMC7044 on Analog.com
Hi
Thanks
IK
Question moved to Linux Software Drivers forum.
Andrei
I would look at https://github.com/analogdevicesinc/linux/blob/fmcomms8_zu11eg_master/arch/arm64/boot/dts/xilinx/zynqmp-adrv9009-zu11eg-revb-adrv2crr-fmc-revb-sync-fmcomms8.dts .
That setup is composed by a carrier (that contains an HMC7044) + SOM (HMC7044 + 2 x ADRV9009) + FMCOMMS8 (HMC7044 + 2 x ADRV9009) - the HMC7044 from the carrier provides the reference clock and the sync signal for the HMC7044 from the SOM and for the HMC7044 from the FMCOMMS8.
Dragos
