Profile Load Error on fmcomms8, but not on ZU11EG SoM
I've used the attached profile before on the ZU11EG SoM + carrier card, but when migrating to the fmcomms8 SoM + carrier + daughtercard this month the same profile fails to load. Other profiles seem to load fine.
Could you advise on if there is a restriction on the fmcomms8 that makes this profile unworkable, or if there are recommended changes?
I've attached a dmesg log with the output from a clean boot as well as the attempted profile load. A few lines that jump out are:
[  639.944181] adrv9009 spi1.0: Request deframer lanerate 3276800 kHz failed (-22)
[  640.065797] adrv9009 spi1.1: Request deframer lanerate 3276800 kHz failed (-22)
Per equation 1 from UG1295, and experiences on the ZU11EG SOM, I think the lane rate should be chosen as
Lane Rate = IQ*M*N'*10/8/L  = 163.84*4*16*10/8/2 = 6553.6 MSPS. It appears that half of this rate is being chosen, at least for the TX (deframer) side, which is outside the usable limits.
I think this might be indicating that an L of 4 is being used on the fmcomms8, whereas on the ZU11EG an L of 2 is being used, but I'm not sure yet if this is the root-cause of the issue. I don't need the TX for this particular application, although disabling it in the filter wizard prior to exporting the profile did not appear to help.
Adam
  1. The profile in question
    1. Rx_BW120_OR163p84_ORx_BW120_OR163p84.txt
    2. Made with filter wizard 2.4, device clock divider 4 yielding device clock MHz 163.84 MSPS same as the data rates
  2. A dmesg log of when I attempt to load the profile
    1. dmesg_fmcomms8_zu11eg_profile_debug.log
    2. Up until time 200 is a normal startup sequence
    3. Time 200-600 is testing another profile, just to check that other profiles can be loaded
    4. Time 600-end is loading the attached profile.
Environment
When things are working, the 2019_R1 RC (Feb 4) release is used with the zynqmp-adrv9009-zu11eg-revb-adrv2crr-fmc-revb boot files, and a SOM + carrier.
When things are not working, the same SD card image is used, but with the BOOT.BIN, Image, and system.dtb files for the fmcomms8 from the quick start guide below and a SOM + carrier + DB.
https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms8-ebz/quick-start-guide
Tx_BW120_IR163p84_Rx_BW120_OR163p84_ORx_BW120_OR163p84.txt
<profile Talise version=1 name=Tx_BW120_IR163p84_Rx_BW120_OR163p84_ORx_BW120_OR163p84>
 <clocks>
  <deviceClock_kHz=163840>
  <clkPllVcoFreq_kHz=6553600>
  <clkPllHsDiv=2.0>
 </clocks>
 <rx name=Rx 120.00MHz, OutputRate 163.84MHz, TotalDecimation 10>
  <rxChannels=TAL_RX1RX2>
  <rxFirDecimation=2>
  <rxDec5Decimation=5>
  <rhb1Decimation=1>
  <rxOutputRate_kHz=163840>
  <rfBandwidth_Hz=120000000>
  <rxBbf3dBCorner_kHz=120000>
  <rxDdcMode=0>
  <rxNcoShifterCfg>
   <bandAInputBandWidth_kHz=0>
   <bandAInputCenterFreq_kHz=0>
   <bandANco1Freq_kHz=0>
   <bandANco2Freq_kHz=0>
   <bandBInputBandWidth_kHz=0>
   <bandBInputCenterFreq_kHz=0>
   <bandBNco1Freq_kHz=0>
   <bandBNco2Freq_kHz=0>
  </rxNcoShifterCfg>
  <filter FIR gain_dB=-6 numFirCoefs=48>
  -1
  -3
  6
  12
  -21
  -37
  58
  92
  -133
  -198
  272
  385
  -508
  -694
  898
  1197
  -1566
  -2166
  2428
  3630
  -4348
  -7510
  9213
  31762
  31762
  9213
  -7510
  -4348
  3630
  2428
  -2166
  -1566
  1197
  898
  -694
  -508
  385
  272
  -198
  -133
  92
  58
  -37
  -21
  12
  6
  -3
  -1
  </filter>
  <rxAdcProfile num=42>
  270
  168
  181
  90
  1280
  605
  1283
  49
  1132
  24
  720
  31
  48
  40
  27
  189
  0
  0
  0
  0
  47
  0
  7
  6
  42
  0
  7
  6
  42
  0
  25
  27
  0
  0
  25
  27
  0
  0
  165
  44
  31
  905
  </rxAdcProfile>
 </rx>
 <obsRx name=Rx 120.00MHz, OutputRate 163.84MHz, TotalDecimation 10>
  <obsRxChannelsEnable=TAL_ORX1ORX2>
  <enAdcStitching=0>
  <rxFirDecimation=2>
  <rhb1Decimation=1>
  <orxOutputRate_kHz=163840>
  <rxBbf3dBCorner_kHz=225000>
  <orxDdcMode=0>
  -1
  -2
  6
  10
  -21
  -31
  55
  77
  -125
  -166
  253
  324
  -468
  -586
  824
  1011
  -1438
  -1851
  2224
  3076
  -4036
  -6271
  9565
  30340
  30340
  9565
  -6271
  -4036
  3076
  2224
  -1851
  -1438
  1011
  824
  -586
  -468
  324
  253
  -166
  -125
  77
  55
  -31
  -21
  10
  6
  -2
  -1
  </filter>
  <orxLowPassAdcProfile num=42>
  270
  168
  181
  90
  1280
  605
  1283
  49
  1132
  24
  720
  31
  48
  40
  27
  189
  0
  0
  0
  0
  47
  0
  7
  6
  42
  0
  7
  6
  42
  0
  25
  27
  0
  0
  25
  27
  0
  0
  165
  44
  31
  905
  </orxLowPassAdcProfile>
  <orxBandPassAdcProfile num=42>
  270
  168
  181
  90
  1280
  605
  1283
  49
  1132
  24
  720
  31
  48
  40
  27
  189
  0
  0
  0
  0
  47
  0
  7
  6
  42
  0
  7
  6
  42
  0
  25
  27
  0
  0
  25
  27
  0
  0
  165
  44
  31
  905
  </orxBandPassAdcProfile>
 </obsRx>
 <lpbk>
  <rxFirDecimation=2>
  <rhb1Decimation=1>
  <outputRate_kHz=163840>
  <rfBandwidth_Hz=75000000>
  <filter FIR gain_dB=-6 num=48>
  -1
  -2
  6
  10
  -21
  -31
  55
  77
  -125
  -166
  253
  324
  -468
  -586
  824
  1011
  -1438
  -1851
  2224
  3076
  -4036
  -6271
  9565
  30340
  30340
  9565
  -6271
  -4036
  3076
  2224
  -1851
  -1438
  1011
  824
  -586
  -468
  324
  253
  -166
  -125
  77
  55
  -31
  -21
  10
  6
  -2
  -1
  </filter>
  <lpbkAdcProfile num=42>
  267
  168
  181
  90
  1280
  623
  1285
  51
  1137
  25
  727
  30
  48
  41
  27
  190
  0
  0
  0
  0
  48
  0
  7
  6
  42
  0
  7
  6
  42
  0
  25
  27
  0
  0
  25
  27
  0
  0
  165
  44
  31
  905
  </lpbkAdcProfile>
 </lpbk>
 <tx name=Tx 120.00MHz, InputRate 163.84MHz, TotalInterpolation 10>
  <txChannels=TAL_TX1TX2>
  <dacDiv=1>
  <txFirInterpolation=2>
  <thb1Interpolation=1>
  <thb2Interpolation=1>
  <thb3Interpolation=1>
  <txInt5Interpolation=5>
  <txInputRate_kHz=163840>
  <primarySigBandwidth_Hz=75000000>
  <txDac3dBCorner_kHz=187000>
  <txBbf3dBCorner_kHz=60000>
  <filter FIR gain_dB=6 numFirCoefs=40>
  1
  -12
  7
  51
  -34
  -140
  103
  315
  -241
  -629
  490
  1162
  -912
  -2117
  1474
  3833
  -1923
  -6732
  2828
  18305
  18305
  2828
  -6732
  -1923
  3833
  1474
  -2117
  -912
  1162
  490
  -629
  -241
  315
  103
  -140
  -34
  51
  7
  -12
  1
  </filter>
 </tx>
</profile>
