ADRV9009-ZU11EG SPI error when booting with 2019_R1 release
I am updating my Linux/HDL design to the 2019_R1 release, and running into some issues. I followed the Zynq & Altera SoC Quick Start Guide to configure an SD card, and I extracted all the necessary files for the ADRV9009-ZU11EG to the root of the BOOT partition of the SD card, I also updated to Linux kernel 4.19 to deal with USB connectivity issues detailed in this post. When I boot up the SOM, I am able to get into the Linux userspace, but the ADRV9009 and related IIO devices aren't found. I then used the master branch files posted by Dragos in the above mentioned post about USB connectivity, and ran into the same issues.
The 2019_R1 dmesg output is included below. One line that stands out to me is:
[    8.414607] adrv9009: probe of spi1.1 failed with error -14
which implies to me that the ADRV9009 isn't getting communicated with by the ARM processor. Could this issue be in the device tree, or something else with my Linux build? I haven't found the location where the error codess are listed.
Any insight is appreciated!
-Samual
dmesg output:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 4.19.0-ga5f6da0 (jenkins@romlxbuild2.adlk.analog.co                     m) (gcc version 8.2.0 (GCC)) #98 SMP Wed Mar 11 14:14:15 GMT 2020
[    0.000000] Machine model: Analog Devices ADRV9009-ZU11EG Rev.B
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff010000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[    0.000000] On node 0 totalpages: 1048576
[    0.000000]   DMA32 zone: 7168 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 524288 pages, LIFO batch:63
[    0.000000]   Normal zone: 7168 pages used for memmap
[    0.000000]   Normal zone: 524288 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with                      crng_init=0
[    0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52504 r8192 d294                     16 u90112
[    0.000000] pcpu-alloc: s52504 r8192 d29416 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1034240
[    0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw                      earlycon rootfstype=ext4 rootwait cpuidle.off=1 root=/dev/mmcblk0p2 rw rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes                     )
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0x6bfff000-0x6ffff000] (64MB)
[    0.000000] Memory: 3774476K/4194304K available (12156K kernel code, 1380K rw                     data, 12456K rodata, 832K init, 315K bss, 157684K reserved, 262144K cma-reserved                     )
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:                      0x7b0074340, max_idle_ns: 440795202884 ns
[    0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 21990                     23255543ns
[    0.008223] Console: colour dummy device 80x25
[    0.012388] Calibrating delay loop (skipped), value calculated using timer fr                     equency.. 66.66 BogoMIPS (lpj=133332)
[    0.022667] pid_max: default: 32768 minimum: 301
[    0.027349] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.033921] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.041636] ASID allocator initialised with 32768 entries
[    0.046414] rcu: Hierarchical SRCU implementation.
[    0.051413] EFI services will not be available.
[    0.055725] smp: Bringing up secondary CPUs ...
[    0.060370] Detected VIPT I-cache on CPU1
[    0.060396] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.060675] Detected VIPT I-cache on CPU2
[    0.060692] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.060953] Detected VIPT I-cache on CPU3
[    0.060971] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.061010] smp: Brought up 1 node, 4 CPUs
[    0.095586] SMP: Total of 4 processors activated.
[    0.100259] CPU features: detected: 32-bit EL0 Support
[    0.106578] CPU: All CPU(s) started at EL2
[    0.109436] alternatives: patching kernel code
[    0.114662] devtmpfs: initialized
[    0.123245] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma                     x_idle_ns: 7645041785100000 ns
[    0.127332] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.138457] xor: measuring software checksum speed
[    0.177529]    8regs     :  2639.000 MB/sec
[    0.217554]    8regs_prefetch:  2280.000 MB/sec
[    0.257580]    32regs    :  3027.000 MB/sec
[    0.297606]    32regs_prefetch:  2565.000 MB/sec
[    0.297634] xor: using function: 32regs (3027.000 MB/sec)
[    0.301948] pinctrl core: initialized pinctrl subsystem
[    0.307700] NET: Registered protocol family 16
[    0.311879] audit: initializing netlink subsys (disabled)
[    0.316967] audit: type=2000 audit(0.268:1): state=initialized audit_enabled=                     0 res=1
[    0.324607] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval___                     _))
[    0.324611] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.339302] DMA: preallocated 256 KiB pool for atomic allocations
[    0.356302] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.423309] raid6: int64x1  gen()   495 MB/s
[    0.491311] raid6: int64x1  xor()   502 MB/s
[    0.559321] raid6: int64x2  gen()   755 MB/s
[    0.627400] raid6: int64x2  xor()   666 MB/s
[    0.695401] raid6: int64x4  gen()  1089 MB/s
[    0.763448] raid6: int64x4  xor()   819 MB/s
[    0.831496] raid6: int64x8  gen()  1291 MB/s
[    0.899540] raid6: int64x8  xor()   844 MB/s
[    0.967579] raid6: neonx1   gen()   817 MB/s
[    1.035620] raid6: neonx1   xor()   978 MB/s
[    1.103678] raid6: neonx2   gen()  1254 MB/s
[    1.171693] raid6: neonx2   xor()  1304 MB/s
[    1.239756] raid6: neonx4   gen()  1644 MB/s
[    1.307774] raid6: neonx4   xor()  1576 MB/s
[    1.375822] raid6: neonx8   gen()  1727 MB/s
[    1.443858] raid6: neonx8   xor()  1621 MB/s
[    1.443884] raid6: using algorithm neonx8 gen() 1727 MB/s
[    1.447854] raid6: .... xor() 1621 MB/s, rmw enabled
[    1.452784] raid6: using neon recovery algorithm
[    1.457981] SCSI subsystem initialized
[    1.461117] libata version 3.00 loaded.
[    1.461250] usbcore: registered new interface driver usbfs
[    1.466568] usbcore: registered new interface driver hub
[    1.471842] usbcore: registered new device driver usb
[    1.476890] media: Linux media interface: v0.10
[    1.481351] videodev: Linux video capture interface: v2.00
[    1.486823] pps_core: LinuxPPS API ver. 1 registered
[    1.491711] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome                     tti <giometti@linux.it>
[    1.500802] PTP clock support registered
[    1.504701] EDAC MC: Ver: 3.0.0
[    1.508147] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox drive                     r.
[    1.515492] jesd204: found 0 devices and 0 topologies
[    1.520113] FPGA manager framework
[    1.523621] Advanced Linux Sound Architecture Driver Initialized.
[    1.529764] Bluetooth: Core ver 2.22
[    1.533074] NET: Registered protocol family 31
[    1.537470] Bluetooth: HCI device and connection manager initialized
[    1.543786] Bluetooth: HCI socket layer initialized
[    1.548629] Bluetooth: L2CAP socket layer initialized
[    1.553655] Bluetooth: SCO socket layer initialized
[    1.558914] clocksource: Switched to clocksource arch_sys_counter
[    1.564621] VFS: Disk quotas dquot_6.6.0
[    1.568473] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.579164] NET: Registered protocol family 2
[    1.579900] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 3276                     8 bytes)
[    1.587420] TCP established hash table entries: 32768 (order: 6, 262144 bytes                     )
[    1.594740] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.601497] TCP: Hash tables configured (established 32768 bind 32768)
[    1.607677] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.613654] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.620141] NET: Registered protocol family 1
[    1.624508] RPC: Registered named UNIX socket transport module.
[    1.630203] RPC: Registered udp transport module.
[    1.634870] RPC: Registered tcp transport module.
[    1.639541] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.646179] PCI: CLS 0 bytes, default 64
[    1.646627] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.653167] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av                     ailable
[    1.661482] Initialise system trusted keyrings
[    1.665204] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    1.672172] NFS: Registering the id_resolver key type
[    1.676576] Key type id_resolver registered
[    1.680715] Key type id_legacy registered
[    1.684699] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.691365] jffs2: version 2.2. (NAND) (SUMMARY)  \xffffffc2\xffffffa9\xfffff                     fa9 2001-2006 Red Hat, Inc.
[    2.671991] NET: Registered protocol family 38
[    2.729257] Key type asymmetric registered
[    2.729284] Asymmetric key parser 'x509' registered
[    2.732584] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2                     46)
[    2.739913] io scheduler noop registered
[    2.743802] io scheduler deadline registered
[    2.748060] io scheduler cfq registered (default)
[    2.752713] io scheduler mq-deadline registered
[    2.757209] io scheduler kyber registered
[    2.786240] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.790099] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.797012] brd: module loaded
[    2.800528] loop: module loaded
[    2.800710] Registered mathworks_ip class
[    2.803821] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.810753] libphy: Fixed MDIO Bus: probed
[    2.814648] tun: Universal TUN/TAP device driver, 1.6
[    2.818724] CAN device driver interface
[    2.823272] usbcore: registered new interface driver asix
[    2.827817] usbcore: registered new interface driver ax88179_178a
[    2.833860] usbcore: registered new interface driver cdc_ether
[    2.839649] usbcore: registered new interface driver net1080
[    2.845272] usbcore: registered new interface driver cdc_subset
[    2.851155] usbcore: registered new interface driver zaurus
[    2.856700] usbcore: registered new interface driver cdc_ncm
[    2.862950] usbcore: registered new interface driver uas
[    2.867598] usbcore: registered new interface driver usb-storage
[    2.873590] usbcore: registered new interface driver upd78f0730
[    2.879437] usbserial: USB Serial support registered for upd78f0730
[    2.886084] i2c /dev entries driver
[    2.890811] usbcore: registered new interface driver uvcvideo
[    2.894818] USB Video Class driver (1.1.1)
[    2.899346] axi_fan_control_driver 80000000.axi-fan-control: clk_get failed w                     ith -517
[    2.907428] Bluetooth: HCI UART driver ver 2.3
[    2.911085] Bluetooth: HCI UART protocol H4 registered
[    2.916182] Bluetooth: HCI UART protocol BCSP registered
[    2.921476] Bluetooth: HCI UART protocol LL registered
[    2.926561] Bluetooth: HCI UART protocol ATH3K registered
[    2.931940] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.938189] Bluetooth: HCI UART protocol Intel registered
[    2.943531] Bluetooth: HCI UART protocol QCA registered
[    2.948737] usbcore: registered new interface driver bcm203x
[    2.954354] usbcore: registered new interface driver bpa10x
[    2.959891] usbcore: registered new interface driver bfusb
[    2.965338] usbcore: registered new interface driver btusb
[    2.970764] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.976427] usbcore: registered new interface driver ath3k
[    2.982125] EDAC MC0: Giving out device to module 1 controller synps_ddr_cont                     roller: DEV synps_edac (INTERRUPT)
[    2.992033] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac control                     ler zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    3.004247] CPUidle arm: Failed to register cpuidle driver
[    3.009581] sdhci: Secure Digital Host Controller Interface driver
[    3.015571] sdhci: Copyright(c) Pierre Ossman
[    3.019895] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.025856] ledtrig-cpu: registered to indicate activity on CPUs
[    3.031526] zynqmp_firmware_probe Platform Management API v1.1
[    3.037285] zynqmp_firmware_probe Trustzone version v1.0
[    3.045104] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl i                     nitialized
[    3.070767] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt,                      ret = -22
[    3.073460] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[    3.078658] zynqmp_aes zynqmp_aes: AES Successfully Registered
[    3.078658]
[    3.086099] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    3.092230] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    3.097786] usbcore: registered new interface driver usbhid
[    3.103138] usbhid: USB HID core driver
[    3.113223] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    3.114484] usbcore: registered new interface driver snd-usb-audio
[    3.121899] pktgen: Packet Generator for packet performance testing. Version:                      2.75
[    3.128022] Initializing XFRM netlink socket
[    3.131991] NET: Registered protocol family 10
[    3.136692] Segment Routing with IPv6
[    3.140046] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.146167] NET: Registered protocol family 17
[    3.150271] NET: Registered protocol family 15
[    3.154686] bridge: filtering via arp/ip/ip6tables is no longer available by                      default. Update your scripts to load br_netfilter if you need this.
[    3.167595] can: controller area network core (rev 20170425 abi 9)
[    3.173754] NET: Registered protocol family 29
[    3.178116] can: raw protocol (rev 20170425)
[    3.182353] can: broadcast manager protocol (rev 20170425 t)
[    3.187978] can: netlink gateway (rev 20170425) max_hops=1
[    3.193615] Bluetooth: RFCOMM TTY layer initialized
[    3.198276] Bluetooth: RFCOMM socket layer initialized
[    3.203382] Bluetooth: RFCOMM ver 1.11
[    3.207096] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.212368] Bluetooth: BNEP filters: protocol multicast
[    3.217560] Bluetooth: BNEP socket layer initialized
[    3.222489] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.228373] Bluetooth: HIDP socket layer initialized
[    3.233431] 9pnet: Installing 9P2000 support
[    3.237549] NET: Registered protocol family 36
[    3.241964] Key type dns_resolver registered
[    3.246648] registered taskstats version 1
[    3.250260] Loading compiled-in X.509 certificates
[    3.255329] Btrfs loaded, crc32c=crc32c-generic
[    3.265530] ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 22, base_baud =                      6249999) is a xuartps
[    3.274475] console [ttyPS0] enabled
[    3.278063] bootconsole [cdns0] disabled
[    3.286392] GPIO line 13 (ulpi-phy-reset) hogged as output/high
[    3.295566] of-fpga-region fpga-full: FPGA Region probed
[    3.302361] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    3.309054] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_lo                     cked:yes
[    3.318237] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0:                      Failed to get required clock freq
[    3.328346] xilinx-dp-snd-codec: probe of fd4a0000.zynqmp-display:zynqmp_dp_s                     nd_codec0 failed with error -22
[    3.338439] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PC                     M probed
[    3.346502] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PC                     M probed
[    3.354566] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: AS                     oC: CPU DAI (null) not registered
[    3.364635] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[    3.371680] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.378286] [drm] No driver support for vblank timestamp query.
[    3.384255] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8                     008d223d8)
[    4.470924] [drm] Cannot find any crtc or sizes
[    4.475665] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display                      on minor 0
[    4.483763] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsys                     tem driver probed
[    4.493725] adrv9009 spi1.0: adrv9009_probe : enter
[    4.498991] adrv9009 spi1.1: adrv9009_probe : enter
[    4.549472] macb ff0b0000.ethernet: Not enabling partial store and forward
[    4.556840] libphy: MACB_mii_bus: probed
[    4.596546] macb ff0e0000.ethernet: Not enabling partial store and forward
[    4.603898] libphy: MACB_mii_bus: probed
[    4.679356] Marvell 88E1510 ff0e0000.ethernet-ffffffff:00: attached PHY drive                     r [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:00, irq=POLL)
[    4.693262] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e                     0000 irq 13 (f6:ee:fe:03:87:05)
[    4.703397] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    4.709906] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[    4.716377] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[    4.722850] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[    4.730719] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[    4.736581] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:0 protocol:3 pll_lo                     cked:yes
[    4.746488] OF: graph: no port node found in /amba/zynqmp_phy@fd400000/lane1
[    4.754825] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.760318] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu                     mber 1
[    4.769107] at24 0-002c: 2048 byte 24c16 EEPROM, writable, 1 bytes/write
[    4.775856] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 15
[    4.782511] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100                      quirks 0x0000000202010010
[    4.791919] xhci-hcd xhci-hcd.0.auto: irq 38, io mem 0xfe200000
[    4.798603] adau1761 3-003b: Direct firmware load for adau1761.bin failed wit                     h error -2
[    4.806608] adau1761 3-003b: Could not find firmware file: -2
[    4.812409] i2c i2c-1: Added multiplexed i2c bus 3
[    4.817302] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc                     dDevice= 4.19
[    4.825567] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                     1
[    4.832782] usb usb1: Product: xHCI Host Controller
[    4.837649] usb usb1: Manufacturer: Linux 4.19.0-ga5f6da0 xhci-hcd
[    4.843824] usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.848897] i2c i2c-1: Added multiplexed i2c bus 4
[    4.853838] i2c i2c-1: Added multiplexed i2c bus 5
[    4.859009] hub 1-0:1.0: USB hub found
[    4.862773] hub 1-0:1.0: 1 port detected
[    4.866879] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.872372] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu                     mber 2
[    4.880029] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0  SuperSpeed
[    4.886771] i2c i2c-1: Added multiplexed i2c bus 6
[    4.891823] usb usb2: We don't know the algorithms for LPM for this host, dis                     abling LPM.
[    4.900189] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc                     dDevice= 4.19
[    4.908450] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=                     1
[    4.915669] usb usb2: Product: xHCI Host Controller
[    4.920536] usb usb2: Manufacturer: Linux 4.19.0-ga5f6da0 xhci-hcd
[    4.926707] usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.931774] i2c i2c-1: Added multiplexed i2c bus 7
[    4.936910] hub 2-0:1.0: USB hub found
[    4.940672] hub 2-0:1.0: 1 port detected
[    4.963274] i2c i2c-1: Added multiplexed i2c bus 8
[    4.968219] i2c i2c-1: Added multiplexed i2c bus 9
[    4.973176] i2c i2c-1: Added multiplexed i2c bus 10
[    4.978058] pca954x 1-0070: registered 8 multiplexed busses for I2C switch pc                     a9548
[    4.985659] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 16
[    4.992044] axi_fan_control_driver 80000000.axi-fan-control: Failed to initia                     lize device
[    5.000163] axi_fan_control_driver: probe of 80000000.axi-fan-control failed                      with error -22
[    5.008935] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at (____ptrval_                     ___) with timeout 60s
[    5.018158] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1333333                      KHz
[    5.025558] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for fre                     q 1333333320 (-34)
[    5.034287] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed                      to: 1199999 KHz
[    5.042817] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for fre                     q 1333333320 (-34)
[    5.083475] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA                      64-bit
[    5.099792] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: AS                     oC: CPU DAI (null) not registered
[    5.109950] adrv9009 spi1.0: adrv9009_probe : enter
[    5.115030] adrv9009 spi1.1: adrv9009_probe : enter
[    5.167233] macb ff0b0000.ethernet: Not enabling partial store and forward
[    5.174602] libphy: MACB_mii_bus: probed
[    5.207909] random: fast init done
[    5.211500] mmc0: new high speed SDHC card at address 0001
[    5.217456] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[    5.222914]  mmcblk0: p1 p2 p3
[    5.255330] Marvell 88E1510 ff0e0000.ethernet-ffffffff:01: attached PHY drive                     r [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:01, irq=POLL)
[    5.269244] macb ff0b0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0b                     0000 irq 12 (6a:15:2d:15:12:d0)
[    5.281479] axi_adxcvr 84a40000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using                      GTH4 at 0x84A40000 mapped to 0x(____ptrval____). Number of lanes: 4.
[    5.296338] axi_adxcvr 84a60000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) usi                     ng GTH4 at 0x84A60000 mapped to 0x(____ptrval____). Number of lanes: 4.
[    5.310302] axi_adxcvr 84a20000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using                      GTH4 at 0x84A20000 mapped to 0x(____ptrval____). Number of lanes: 8.
[    5.325717] asoc-simple-card talise_sound: adau-hifi <-> 82000000.axi-i2s-adi                      mapping ok
[    5.337215] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: AS                     oC: CPU DAI (null) not registered
[    5.347381] adrv9009 spi1.0: adrv9009_probe : enter
[    5.354598] adrv9009 spi1.0: ADIHAL_resetHw at index
[    5.618923] [drm] Cannot find any crtc or sizes
[    5.682324] adrv9009 spi1.0: adrv9009_do_setup:662 Unexpected MCS sync status                      (0x0)
[    5.689974] ------------[ cut here ]------------
[    5.694575] jesd_tx_lane_clk already disabled
[    5.698949] WARNING: CPU: 0 PID: 51 at drivers/clk/clk.c:856 clk_core_disable                     +0xa0/0xa8
[    5.706936] Modules linked in:
[    5.709976] CPU: 0 PID: 51 Comm: kworker/0:1 Not tainted 4.19.0-ga5f6da0 #98
[    5.717004] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
[    5.723346] Workqueue: events deferred_probe_work_func
[    5.728473] pstate: 60000085 (nZCv daIf -PAN -UAO)
[    5.733247] pc : clk_core_disable+0xa0/0xa8
[    5.737413] lr : clk_core_disable+0xa0/0xa8
[    5.741578] sp : ffffff8009c3ba30
[    5.744876] x29: ffffff8009c3ba30 x28: 00000000003a9800
[    5.750171] x27: ffffffc87aeaf848 x26: 00000000fffffff2
[    5.755466] x25: 00000000000e5def x24: ffffffc87a127380
[    5.760760] x23: 0000000000000003 x22: 0000000000000004
[    5.766055] x21: 0000000000000002 x20: ffffffc87b38b300
[    5.771350] x19: ffffffc87b38b300 x18: 0000000000000010
[    5.776645] x17: 0000000000000000 x16: 0000000000000000
[    5.781940] x15: ffffffffffffffff x14: ffffff8009968648
[    5.787235] x13: ffffff8089ac15cf x12: ffffff8009ac15d7
[    5.792529] x11: ffffff800997a000 x10: ffffff8009c3b710
[    5.797824] x9 : 00000000ffffffd0 x8 : ffffff80085589b0
[    5.803119] x7 : 656e616c5f78745f x6 : 0000000000000152
[    5.808414] x5 : 000000000000000f x4 : 0000000000000000
[    5.813709] x3 : 0000000000000000 x2 : ffffffffffffffff
[    5.819004] x1 : f496a42279913800 x0 : 0000000000000000
[    5.824299] Call trace:
[    5.826732]  clk_core_disable+0xa0/0xa8
[    5.830551]  clk_core_disable_lock+0x20/0x38
[    5.834804]  clk_disable+0x1c/0x28
[    5.838190]  adrv9009_setup+0x31c/0x1200
[    5.842094]  adrv9009_probe+0x299c/0x2f28
[    5.846088]  spi_drv_probe+0x7c/0xd8
[    5.849646]  really_probe+0x1c8/0x280
[    5.853292]  driver_probe_device+0x54/0xe8
[    5.857371]  __device_attach_driver+0xb8/0xe8
[    5.861711]  bus_for_each_drv+0x78/0xc8
[    5.865531]  __device_attach+0xd4/0x130
[    5.869350]  device_initial_probe+0x10/0x18
[    5.873516]  bus_probe_device+0x90/0x98
[    5.877335]  deferred_probe_work_func+0x6c/0xa0
[    5.881851]  process_one_work+0x1e4/0x340
[    5.885851]  worker_thread+0x248/0x488
[    5.889584]  kthread+0x124/0x128
[    5.892796]  ret_from_fork+0x10/0x18
[    5.896353] ---[ end trace da24355d694791a0 ]---
[    5.900975] ------------[ cut here ]------------
[    5.905586] jesd_tx_lane_clk already unprepared
[    5.910130] WARNING: CPU: 0 PID: 51 at drivers/clk/clk.c:715 clk_core_unprepa                     re+0xdc/0x100
[    5.918373] Modules linked in:
[    5.921414] CPU: 0 PID: 51 Comm: kworker/0:1 Tainted: G        W         4.19                     .0-ga5f6da0 #98
[    5.929831] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
[    5.936170] Workqueue: events deferred_probe_work_func
[    5.941299] pstate: 60000005 (nZCv daif -PAN -UAO)
[    5.946074] pc : clk_core_unprepare+0xdc/0x100
[    5.950501] lr : clk_core_unprepare+0xdc/0x100
[    5.954925] sp : ffffff8009c3ba40
[    5.958224] x29: ffffff8009c3ba40 x28: 00000000003a9800
[    5.963519] x27: ffffffc87aeaf848 x26: 00000000fffffff2
[    5.968813] x25: 00000000000e5def x24: ffffffc87a127380
[    5.974108] x23: 0000000000000003 x22: 0000000000000004
[    5.979403] x21: 0000000000000002 x20: ffffff8009968648
[    5.984698] x19: ffffffc87b38b300 x18: 0000000000000010
[    5.989993] x17: 0000000000000000 x16: 0000000000000000
[    5.995288] x15: ffffffffffffffff x14: ffffff8009968648
[    6.000582] x13: ffffff8089ac15cf x12: ffffff8009ac15d7
[    6.005877] x11: ffffff800997a000 x10: ffffff8009c3b720
[    6.011172] x9 : 00000000ffffffd0 x8 : ffffff80085589b0
[    6.016467] x7 : 726c61206b6c635f x6 : 0000000000000180
[    6.021762] x5 : 000000000000000f x4 : 0000000000000000
[    6.027057] x3 : 0000000000000000 x2 : ffffffffffffffff
[    6.032352] x1 : f496a42279913800 x0 : 0000000000000000
[    6.037646] Call trace:
[    6.040079]  clk_core_unprepare+0xdc/0x100
[    6.044158]  clk_unprepare+0x28/0x40
[    6.047717]  adrv9009_setup+0x324/0x1200
[    6.051623]  adrv9009_probe+0x299c/0x2f28
[    6.055616]  spi_drv_probe+0x7c/0xd8
[    6.059175]  really_probe+0x1c8/0x280
[    6.062820]  driver_probe_device+0x54/0xe8
[    6.066900]  __device_attach_driver+0xb8/0xe8
[    6.071240]  bus_for_each_drv+0x78/0xc8
[    6.075059]  __device_attach+0xd4/0x130
[    6.078879]  device_initial_probe+0x10/0x18
[    6.083045]  bus_probe_device+0x90/0x98
[    6.086864]  deferred_probe_work_func+0x6c/0xa0
[    6.091379]  process_one_work+0x1e4/0x340
[    6.095371]  worker_thread+0x248/0x488
[    6.099103]  kthread+0x124/0x128
[    6.102315]  ret_from_fork+0x10/0x18
[    6.105872] ---[ end trace da24355d694791a1 ]---
[    6.110494] adrv9009 spi1.0: ADIHAL_resetHw at index
[    6.116665] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    6.382256] usb 2-1: New USB device found, idVendor=2109, idProduct=0812, bcd                     Device=90.91
[    6.390426] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.397557] usb 2-1: Product: USB3.0 Hub
[    6.402599] usb 2-1: Manufacturer: VIA Labs, Inc.
[    6.438830] hub 2-1:1.0: USB hub found
[    6.442784] hub 2-1:1.0: 4 ports detected
[    6.453574] adrv9009 spi1.0: adrv9009_do_setup:662 Unexpected MCS sync status                      (0x0)
[    6.461225] ------------[ cut here ]------------
[    6.465827] jesd_tx_lane_clk already disabled
[    6.470193] WARNING: CPU: 0 PID: 51 at drivers/clk/clk.c:856 clk_core_disable                     +0xa0/0xa8
[    6.478178] Modules linked in:
[    6.481219] CPU: 0 PID: 51 Comm: kworker/0:1 Tainted: G        W         4.19                     .0-ga5f6da0 #98
[    6.489636] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
[    6.495976] Workqueue: events deferred_probe_work_func
[    6.501104] pstate: 60000085 (nZCv daIf -PAN -UAO)
[    6.505879] pc : clk_core_disable+0xa0/0xa8
[    6.510045] lr : clk_core_disable+0xa0/0xa8
[    6.514209] sp : ffffff8009c3ba30
[    6.517508] x29: ffffff8009c3ba30 x28: 00000000003a9800
[    6.522803] x27: ffffffc87aeaf848 x26: 00000000fffffff2
[    6.528097] x25: 00000000000e5def x24: ffffffc87a127380
[    6.533392] x23: 0000000000000003 x22: 0000000000000004
[    6.538687] x21: 0000000000000002 x20: ffffffc87b38b300
[    6.543982] x19: ffffffc87b38b300 x18: 0000000000000010
[    6.549277] x17: 0000000000000000 x16: 0000000000000000
[    6.554572] x15: ffffffffffffffff x14: ffffff8009968648
[    6.559867] x13: ffffff8089ac15cf x12: ffffff8009ac15d7
[    6.565161] x11: ffffff800997a000 x10: ffffff8009c3b710
[    6.570456] x9 : 00000000ffffffd0 x8 : ffffff80085589b0
[    6.575751] x7 : 6b6c635f656e616c x6 : 00000000000001b6
[    6.581046] x5 : 000000000000000f x4 : 0000000000000000
[    6.586341] x3 : 0000000000000000 x2 : ffffffffffffffff
[    6.591636] x1 : f496a42279913800 x0 : 0000000000000000
[    6.596930] Call trace:
[    6.599364]  clk_core_disable+0xa0/0xa8
[    6.603182]  clk_core_disable_lock+0x20/0x38
[    6.607435]  clk_disable+0x1c/0x28
[    6.610821]  adrv9009_setup+0x31c/0x1200
[    6.614726]  adrv9009_probe+0x2e70/0x2f28
[    6.618719]  spi_drv_probe+0x7c/0xd8
[    6.622278]  really_probe+0x1c8/0x280
[    6.625923]  driver_probe_device+0x54/0xe8
[    6.630003]  __device_attach_driver+0xb8/0xe8
[    6.634343]  bus_for_each_drv+0x78/0xc8
[    6.638162]  __device_attach+0xd4/0x130
[    6.641982]  device_initial_probe+0x10/0x18
[    6.646148]  bus_probe_device+0x90/0x98
[    6.649967]  deferred_probe_work_func+0x6c/0xa0
[    6.654482]  process_one_work+0x1e4/0x340
[    6.658474]  worker_thread+0x248/0x488
[    6.662207]  kthread+0x124/0x128
[    6.665418]  ret_from_fork+0x10/0x18
[    6.668976] ---[ end trace da24355d694791a2 ]---
[    6.673592] ------------[ cut here ]------------
[    6.678199] jesd_tx_lane_clk already unprepared
[    6.682744] WARNING: CPU: 0 PID: 51 at drivers/clk/clk.c:715 clk_core_unprepa                     re+0xdc/0x100
[    6.690987] Modules linked in:
[    6.694028] CPU: 0 PID: 51 Comm: kworker/0:1 Tainted: G        W         4.19                     .0-ga5f6da0 #98
[    6.702446] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
[    6.708784] Workqueue: events deferred_probe_work_func
[    6.713913] pstate: 60000005 (nZCv daif -PAN -UAO)
[    6.718689] pc : clk_core_unprepare+0xdc/0x100
[    6.723115] lr : clk_core_unprepare+0xdc/0x100
[    6.727540] sp : ffffff8009c3ba40
[    6.730838] x29: ffffff8009c3ba40 x28: 00000000003a9800
[    6.736133] x27: ffffffc87aeaf848 x26: 00000000fffffff2
[    6.741428] x25: 00000000000e5def x24: ffffffc87a127380
[    6.746723] x23: 0000000000000003 x22: 0000000000000004
[    6.752017] x21: 0000000000000002 x20: ffffff8009968648
[    6.757312] x19: ffffffc87b38b300 x18: 0000000000000010
[    6.762607] x17: 0000000000000000 x16: 0000000000000000
[    6.767902] x15: ffffffffffffffff x14: ffffff8009968648
[    6.773197] x13: ffffff8089ac15cf x12: ffffff8009ac15d7
[    6.778492] x11: ffffff800997a000 x10: ffffff8009c3b720
[    6.783787] x9 : 00000000ffffffd0 x8 : ffffff80085589b0
[    6.789081] x7 : 79646165726c6120 x6 : 00000000000001e4
[    6.794376] x5 : 000000000000000f x4 : 0000000000000000
[    6.799671] x3 : 0000000000000000 x2 : ffffffffffffffff
[    6.804966] x1 : f496a42279913800 x0 : 0000000000000000
[    6.810261] Call trace:
[    6.812694]  clk_core_unprepare+0xdc/0x100
[    6.816772]  clk_unprepare+0x28/0x40
[    6.820331]  adrv9009_setup+0x324/0x1200
[    6.824237]  adrv9009_probe+0x2e70/0x2f28
[    6.828230]  spi_drv_probe+0x7c/0xd8
[    6.831789]  really_probe+0x1c8/0x280
[    6.835435]  driver_probe_device+0x54/0xe8
[    6.839515]  __device_attach_driver+0xb8/0xe8
[    6.843854]  bus_for_each_drv+0x78/0xc8
[    6.847674]  __device_attach+0xd4/0x130
[    6.851493]  device_initial_probe+0x10/0x18
[    6.855659]  bus_probe_device+0x90/0x98
[    6.859479]  deferred_probe_work_func+0x6c/0xa0
[    6.863993]  process_one_work+0x1e4/0x340
[    6.867986]  worker_thread+0x248/0x488
[    6.871718]  kthread+0x124/0x128
[    6.874929]  ret_from_fork+0x10/0x18
[    6.878487] ---[ end trace da24355d694791a3 ]---
[    6.883118] adrv9009: probe of spi1.0 failed with error -14
[    6.888931] adrv9009 spi1.1: adrv9009_probe : enter
[    6.896005] adrv9009 spi1.1: ADIHAL_resetHw at index
[    6.902016] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    7.056376] usb 1-1: New USB device found, idVendor=2109, idProduct=2812, bcd                     Device=90.90
[    7.064546] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.071670] usb 1-1: Product: USB2.0 Hub
[    7.076714] usb 1-1: Manufacturer: VIA Labs, Inc.
[    7.126885] hub 1-1:1.0: USB hub found
[    7.130756] hub 1-1:1.0: 4 ports detected
[    7.142952] usb 2-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hc                     d
[    7.167425] usb 2-1.4: New USB device found, idVendor=2537, idProduct=1081, b                     cdDevice= 1.00
[    7.175774] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber                     =3
[    7.183070] usb 2-1.4: Product: NS1081
[    7.186805] usb 2-1.4: Manufacturer: Norelsys
[    7.191150] usb 2-1.4: SerialNumber: 0123456789ABCDE
[    7.197083] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[    7.203653] scsi host0: usb-storage 2-1.4:1.0
[    7.229093] adrv9009 spi1.1: adrv9009_do_setup:662 Unexpected MCS sync status                      (0x0)
[    7.236739] ------------[ cut here ]------------
[    7.241341] jesd_tx_lane_clk already disabled
[    7.245712] WARNING: CPU: 0 PID: 51 at drivers/clk/clk.c:856 clk_core_disable                     +0xa0/0xa8
[    7.253700] Modules linked in:
[    7.256742] CPU: 0 PID: 51 Comm: kworker/0:1 Tainted: G        W         4.19                     .0-ga5f6da0 #98
[    7.265158] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
[    7.271500] Workqueue: events deferred_probe_work_func
[    7.276627] pstate: 60000085 (nZCv daIf -PAN -UAO)
[    7.281401] pc : clk_core_disable+0xa0/0xa8
[    7.285568] lr : clk_core_disable+0xa0/0xa8
[    7.289732] sp : ffffff8009c3ba30
[    7.293030] x29: ffffff8009c3ba30 x28: 00000000003a9800
[    7.298325] x27: ffffffc87aeaf848 x26: 00000000fffffff2
[    7.303620] x25: 00000000000e5def x24: ffffffc87a127380
[    7.308914] x23: 0000000000000003 x22: 0000000000000004
[    7.314209] x21: 0000000000000002 x20: ffffffc87b38b300
[    7.319504] x19: ffffffc87b38b300 x18: 0000000000000010
[    7.324799] x17: 0000000000000000 x16: 0000000000000000
[    7.330094] x15: ffffffffffffffff x14: ffffff8009968648
[    7.335389] x13: ffffff8089ac15cf x12: ffffff8009ac15d7
[    7.340684] x11: ffffff800997a000 x10: ffffff8009c3b710
[    7.345979] x9 : 00000000ffffffd0 x8 : ffffff80085589b0
[    7.351273] x7 : 6b6c635f656e616c x6 : 0000000000000224
[    7.356568] x5 : 000000000000000f x4 : 0000000000000000
[    7.361863] x3 : 0000000000000000 x2 : ffffffffffffffff
[    7.367158] x1 : f496a42279913800 x0 : 0000000000000000
[    7.372453] Call trace:
[    7.374886]  clk_core_disable+0xa0/0xa8
[    7.378705]  clk_core_disable_lock+0x20/0x38
[    7.382958]  clk_disable+0x1c/0x28
[    7.386343]  adrv9009_setup+0x31c/0x1200
[    7.390248]  adrv9009_probe+0x299c/0x2f28
[    7.394242]  spi_drv_probe+0x7c/0xd8
[    7.397801]  really_probe+0x1c8/0x280
[    7.401446]  driver_probe_device+0x54/0xe8
[    7.405526]  __device_attach_driver+0xb8/0xe8
[    7.409865]  bus_for_each_drv+0x78/0xc8
[    7.413685]  __device_attach+0xd4/0x130
[    7.417504]  device_initial_probe+0x10/0x18
[    7.421670]  bus_probe_device+0x90/0x98
[    7.425490]  deferred_probe_work_func+0x6c/0xa0
[    7.430005]  process_one_work+0x1e4/0x340
[    7.433997]  worker_thread+0x248/0x488
[    7.437729]  kthread+0x124/0x128
[    7.440941]  ret_from_fork+0x10/0x18
[    7.444498] ---[ end trace da24355d694791a4 ]---
[    7.449113] ------------[ cut here ]------------
[    7.453721] jesd_tx_lane_clk already unprepared
[    7.458267] WARNING: CPU: 0 PID: 51 at drivers/clk/clk.c:715 clk_core_unprepa                     re+0xdc/0x100
[    7.466510] Modules linked in:
[    7.469551] CPU: 0 PID: 51 Comm: kworker/0:1 Tainted: G        W         4.19                     .0-ga5f6da0 #98
[    7.477968] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
[    7.484307] Workqueue: events deferred_probe_work_func
[    7.489436] pstate: 60000005 (nZCv daif -PAN -UAO)
[    7.494211] pc : clk_core_unprepare+0xdc/0x100
[    7.498637] lr : clk_core_unprepare+0xdc/0x100
[    7.503062] sp : ffffff8009c3ba40
[    7.506361] x29: ffffff8009c3ba40 x28: 00000000003a9800
[    7.511655] x27: ffffffc87aeaf848 x26: 00000000fffffff2
[    7.516950] x25: 00000000000e5def x24: ffffffc87a127380
[    7.522245] x23: 0000000000000003 x22: 0000000000000004
[    7.527540] x21: 0000000000000002 x20: ffffff8009968648
[    7.532835] x19: ffffffc87b38b300 x18: 0000000000000010
[    7.538130] x17: 0000000000000000 x16: 0000000000000000
[    7.543425] x15: ffffffffffffffff x14: ffffff8009968648
[    7.548719] x13: ffffff8089ac15cf x12: ffffff8009ac15d7
[    7.554014] x11: ffffff800997a000 x10: ffffff8009c3b720
[    7.559309] x9 : 00000000ffffffd0 x8 : ffffff80085589b0
[    7.564604] x7 : 79646165726c6120 x6 : 0000000000000252
[    7.569899] x5 : 000000000000000f x4 : 0000000000000000
[    7.575194] x3 : 0000000000000000 x2 : ffffffffffffffff
[    7.580488] x1 : f496a42279913800 x0 : 0000000000000000
[    7.585783] Call trace:
[    7.588216]  clk_core_unprepare+0xdc/0x100
[    7.592295]  clk_unprepare+0x28/0x40
[    7.595854]  adrv9009_setup+0x324/0x1200
[    7.599760]  adrv9009_probe+0x299c/0x2f28
[    7.603753]  spi_drv_probe+0x7c/0xd8
[    7.607312]  really_probe+0x1c8/0x280
[    7.610957]  driver_probe_device+0x54/0xe8
[    7.615037]  __device_attach_driver+0xb8/0xe8
[    7.619376]  bus_for_each_drv+0x78/0xc8
[    7.623196]  __device_attach+0xd4/0x130
[    7.627015]  device_initial_probe+0x10/0x18
[    7.631182]  bus_probe_device+0x90/0x98
[    7.635001]  deferred_probe_work_func+0x6c/0xa0
[    7.639515]  process_one_work+0x1e4/0x340
[    7.643508]  worker_thread+0x248/0x488
[    7.647240]  kthread+0x124/0x128
[    7.650452]  ret_from_fork+0x10/0x18
[    7.654009] ---[ end trace da24355d694791a5 ]---
[    7.658633] adrv9009 spi1.1: ADIHAL_resetHw at index
[    7.898922] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
[    7.985066] adrv9009 spi1.1: adrv9009_do_setup:662 Unexpected MCS sync status                      (0x0)
[    7.992713] ------------[ cut here ]------------
[    7.997315] jesd_tx_lane_clk already disabled
[    8.001678] WARNING: CPU: 0 PID: 51 at drivers/clk/clk.c:856 clk_core_disable                     +0xa0/0xa8
[    8.009666] Modules linked in:
[    8.012707] CPU: 0 PID: 51 Comm: kworker/0:1 Tainted: G        W         4.19                     .0-ga5f6da0 #98
[    8.021124] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
[    8.027463] Workqueue: events deferred_probe_work_func
[    8.032592] pstate: 60000085 (nZCv daIf -PAN -UAO)
[    8.037367] pc : clk_core_disable+0xa0/0xa8
[    8.041534] lr : clk_core_disable+0xa0/0xa8
[    8.045698] sp : ffffff8009c3ba30
[    8.048996] x29: ffffff8009c3ba30 x28: 00000000003a9800
[    8.054291] x27: ffffffc87aeaf848 x26: 00000000fffffff2
[    8.059586] x25: 00000000000e5def x24: ffffffc87a127380
[    8.064881] x23: 0000000000000003 x22: 0000000000000004
[    8.070175] x21: 0000000000000002 x20: ffffffc87b38b300
[    8.075470] x19: ffffffc87b38b300 x18: 0000000000000010
[    8.080765] x17: 0000000000000000 x16: 0000000000000000
[    8.086060] x15: ffffffffffffffff x14: ffffff8009968648
[    8.091355] x13: ffffff8089ac15cf x12: ffffff8009ac15d7
[    8.096650] x11: ffffff800997a000 x10: ffffff8009c3b710
[    8.101945] x9 : 00000000ffffffd0 x8 : ffffff80085589b0
[    8.107240] x7 : 726c61206b6c635f x6 : 0000000000000282
[    8.112534] x5 : 000000000000000f x4 : 0000000000000000
[    8.117829] x3 : 0000000000000000 x2 : ffffffffffffffff
[    8.123124] x1 : f496a42279913800 x0 : 0000000000000000
[    8.128419] Call trace:
[    8.130852]  clk_core_disable+0xa0/0xa8
[    8.134671]  clk_core_disable_lock+0x20/0x38
[    8.138924]  clk_disable+0x1c/0x28
[    8.142309]  adrv9009_setup+0x31c/0x1200
[    8.146214]  adrv9009_probe+0x2e70/0x2f28
[    8.150207]  spi_drv_probe+0x7c/0xd8
[    8.153766]  really_probe+0x1c8/0x280
[    8.157412]  driver_probe_device+0x54/0xe8
[    8.161492]  __device_attach_driver+0xb8/0xe8
[    8.165831]  bus_for_each_drv+0x78/0xc8
[    8.169651]  __device_attach+0xd4/0x130
[    8.173470]  device_initial_probe+0x10/0x18
[    8.177637]  bus_probe_device+0x90/0x98
[    8.181456]  deferred_probe_work_func+0x6c/0xa0
[    8.185970]  process_one_work+0x1e4/0x340
[    8.189963]  worker_thread+0x248/0x488
[    8.193695]  kthread+0x124/0x128
[    8.196906]  ret_from_fork+0x10/0x18
[    8.200464] ---[ end trace da24355d694791a6 ]---
[    8.205080] ------------[ cut here ]------------
[    8.209688] jesd_tx_lane_clk already unprepared
[    8.214232] WARNING: CPU: 0 PID: 51 at drivers/clk/clk.c:715 clk_core_unprepa                     re+0xdc/0x100
[    8.222476] Modules linked in:
[    8.225517] CPU: 0 PID: 51 Comm: kworker/0:1 Tainted: G        W         4.19                     .0-ga5f6da0 #98
[    8.233934] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
[    8.240273] Workqueue: events deferred_probe_work_func
[    8.245402] pstate: 60000005 (nZCv daif -PAN -UAO)
[    8.250177] pc : clk_core_unprepare+0xdc/0x100
[    8.254604] lr : clk_core_unprepare+0xdc/0x100
[    8.259028] sp : ffffff8009c3ba40
[    8.262327] x29: ffffff8009c3ba40 x28: 00000000003a9800
[    8.267621] x27: ffffffc87aeaf848 x26: 00000000fffffff2
[    8.272916] x25: 00000000000e5def x24: ffffffc87a127380
[    8.278211] x23: 0000000000000003 x22: 0000000000000004
[    8.283506] x21: 0000000000000002 x20: ffffff8009968648
[    8.288801] x19: ffffffc87b38b300 x18: 0000000000000010
[    8.294096] x17: 0000000000000000 x16: 0000000000000000
[    8.299391] x15: ffffffffffffffff x14: ffffff8009968648
[    8.304685] x13: ffffff8089ac15cf x12: ffffff8009ac15d7
[    8.309980] x11: ffffff800997a000 x10: ffffff8009c3b720
[    8.315275] x9 : 00000000ffffffd0 x8 : ffffff80085589b0
[    8.320570] x7 : 656e616c5f78745f x6 : 00000000000002b0
[    8.325865] x5 : 000000000000000f x4 : 0000000000000000
[    8.331160] x3 : 0000000000000000 x2 : ffffffffffffffff
[    8.336455] x1 : f496a42279913800 x0 : 0000000000000000
[    8.341749] Call trace:
[    8.344182]  clk_core_unprepare+0xdc/0x100
[    8.348261]  clk_unprepare+0x28/0x40
[    8.351820]  adrv9009_setup+0x324/0x1200
[    8.355726]  adrv9009_probe+0x2e70/0x2f28
[    8.359719]  spi_drv_probe+0x7c/0xd8
[    8.363278]  really_probe+0x1c8/0x280
[    8.366923]  driver_probe_device+0x54/0xe8
[    8.371003]  __device_attach_driver+0xb8/0xe8
[    8.375343]  bus_for_each_drv+0x78/0xc8
[    8.379162]  __device_attach+0xd4/0x130
[    8.382981]  device_initial_probe+0x10/0x18
[    8.387148]  bus_probe_device+0x90/0x98
[    8.390967]  deferred_probe_work_func+0x6c/0xa0
[    8.395482]  process_one_work+0x1e4/0x340
[    8.399474]  worker_thread+0x248/0x488
[    8.403206]  kthread+0x124/0x128
[    8.406418]  ret_from_fork+0x10/0x18
[    8.409975] ---[ end trace da24355d694791a7 ]---
[    8.421277] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: AS                     oC: CPU DAI (null) not registered
[    8.431987] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: AS                     oC: CPU DAI (null) not registered
[    8.444569] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[    8.451663] hctosys: unable to open rtc device (rtc0)
[    8.456710] of_cfs_init
[    8.459171] of_cfs_init: OK
[    8.462118] cfg80211: Loading compiled-in X.509 certificates for regulatory d                     atabase
[    8.470900] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: AS                     oC: CPU DAI (null) not registered
[    8.484202] usb 1-1.1: New USB device found, idVendor=413c, idProduct=301a, b                     cdDevice= 1.00
[    8.492551] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber                     =0
[    8.499847] usb 1-1.1: Product: Dell MS116 USB Optical Mouse
[    8.505497] usb 1-1.1: Manufacturer: PixArt
[    8.568820] input: PixArt Dell MS116 USB Optical Mouse as /devices/platform/a                     mba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:41                     3C:301A.0001/input/input1
[    8.585144] hid-generic 0003:413C:301A.0001: input: USB HID v1.11 Mouse [PixA                     rt Dell MS116 USB Optical Mouse] on usb-xhci-hcd.0.auto-1.1/input0
[    8.589272] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.598992] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: AS                     oC: CPU DAI (null) not registered
[    8.605296] ALSA device list:
[    8.617476]   #0: ADRV9009 ZU11EG ADAU1761
[    8.621856] platform regulatory.0: Direct firmware load for regulatory.db fai                     led with error -2
[    8.630458] cfg80211: failed to load regulatory.db
[    8.645033] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O                     pts: (null)
[    8.653134] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    8.666314] devtmpfs: mounted
[    8.669439] Freeing unused kernel memory: 832K
[    8.686958] Run /sbin/init as init process
[    8.913732] random: init: uninitialized urandom read (12 bytes read)
[    8.999958] init: hwclock main process (2263) terminated with status 1
[    9.117737] random: mountall: uninitialized urandom read (12 bytes read)
[    9.413782] systemd-udevd[2361]: starting version 204
[    9.547232] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[   10.095163] pps pps0: new PPS source ptp0
[   10.095175] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[   10.095326] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.242575] urandom_read: 2 callbacks suppressed
[   10.242578] random: avahi-daemon: uninitialized urandom read (4 bytes read)
[   10.456713] init: failsafe main process (3472) killed by TERM signal
[   10.602632] random: dd: uninitialized urandom read (512 bytes read)
[   10.724446] scsi 0:0:0:0: Direct-Access     NORELSYS 1081             0    PQ                     : 0 ANSI: 6
[   10.726297] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: AS                     oC: CPU DAI (null) not registered
[   10.727538] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   11.051084] init: udev-fallback-graphics main process (3695) terminated with                      status 1
[   11.418272] random: samba: uninitialized urandom read (1 bytes read)
[   11.424421] random: smbd: uninitialized urandom read (0 bytes read)
[   11.461893] random: sshd: uninitialized urandom read (32 bytes read)
[   11.776728] init: tty1 main process (3866) killed by TERM signal
[   11.876887] random: crng init done
[   12.000420] pps pps1: new PPS source ptp1
[   12.000432] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered.
[   12.000539] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   12.112416] init: samba-ad-dc main process (3793) terminated with status 1
[   13.231291] macb ff0e0000.ethernet eth0: link up (1000/Full)
[   13.231314] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Device tree is attached as a .txt file.
6366.system.txt
    on Mar 13, 2020 4:39 PM
    The files posted on the other thread (that fixed the USB issue) were generated using the master branches. You are mentioning something about 2019_R1. I'm not sure if this is the case, but to be sure: different version branches can't be be mixed - master HDL is compatible with master Linux, hdl_2019_r1 with 2019_R1, etc. Can you confirm you have used the BOOT.BIN from that .zip file too?
    I don't think the error comes from the SPI communication with the ADRV9009 - it's is most likely caused by a clock that fails.
    Dragos
  • Hi Dragos,
    I am using the boot.bin file that came with the download you posted.
    I have taken and make'd the hdl_2019_R1 branch for the ADRV9009-ZU11EG, but haven't yet generated a new BOOT.bin file with modifications to the reference design. I want to confirm the Linux side of things is updated to 2019__R1 and working before I add any HDL changes (I have a lot less Linux experience than FPGA design, so I am still learning a lot about the Linux side of things).
    Best,
    -Samual
  • Hi Dragos,
    If this is an error caused by a failing clock (or something else), what is a way forward from here? I have tried to build my own device tree, ZynqMP image, and BOOT.BIN files from the Quick Start Guide (all using 2019_R1 repositories), but I am running into issues with the device tree generation.
    My goal in updating from the 2018_R2 release to 2019_R1 is to be able to use a profile from the ADRV9008/ADRV9009 Profile Configuration Tool so I can use integer clock rates for the Rx/Tx device clocks via IIOScope, as per Adrian's suggestion here.
    My response in the other thread about the USB issue was prompted because the files I extracted from the 2019_R1 RC release here had the USB issue (with Linux kernel 4.14). Now that I go back to reboot with the Feb. 4th unchanged files, I notice I am also not seeing ADRV9009 related IIO devices there.
    For example, with the files from the USB thread (kernel 4.19), when I run a grep command I see:
    grep "" /sys/bus/iio/devices/iio\:device*/name
    /sys/bus/iio/devices/iio:device0/name:ams
    /sys/bus/iio/devices/iio:device1/name:hmc7044-car
    /sys/bus/iio/devices/iio:device2/name:hmc7044
    When I run a grep command for the Linux files from the Zynq & Altera SoC Quick Start Guide (kernel 4.14) I see:
    /sys/bus/iio/devices/iio:device2/name:adm1177
    /sys/bus/iio/devices/iio:device3/name:hmc7044
    Here is the dmesg output for the Zynq & Altera SoC Quick Start Guide SD card boot (Linux 4.14 with USB issues):
    root@analog:~# dmesg
    [    0.000000] Linux version 4.14.0-g8a57ede (jenkins@romlxbuild1.adlk.analog.com) (gcc version 7.3.1 20180314 (Linaro GCC 7.3-2018.04-rc3)) #653 SMP Mon Feb 3 16:44:50 GMT 2020
    [    0.000000] Boot CPU: AArch64 Processor [410fd034]
    [    0.000000]   DMA zone: 7168 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 524288 pages, LIFO batch:31
    [    0.000000]   Normal zone: 524288 pages, LIFO batch:31
    [    0.000000] random: fast init done
    [    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff56000 s45080 r8192 d32744 u86016
    [    0.000000] pcpu-alloc: s45080 r8192 d32744 u86016 alloc=21*4096
    [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
    [    0.000000] software IO TLB [mem 0x6bfff000-0x6ffff000] (64MB) mapped at [ffffffc06bfff000-ffffffc06fffefff]
    [    0.000000] Memory: 3783784K/4194304K available (10236K kernel code, 746K rwdata, 4448K rodata, 512K init, 2154K bss, 148376K reserved, 262144K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
    [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
    [    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a80000   ( 10240 KB)
    [    0.000000]     .rodata : 0xffffff8008a80000 - 0xffffff8008ee0000   (  4480 KB)
    [    0.000000]       .init : 0xffffff8008ee0000 - 0xffffff8008f60000   (   512 KB)
    [    0.000000]       .data : 0xffffff8008f60000 - 0xffffff800901aa00   (   747 KB)
    [    0.000000]        .bss : 0xffffff800901aa00 - 0xffffff8009235530   (  2155 KB)
    [    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
    [    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
    [    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
    [    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 MB actual)
    [    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 MB)
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000]  RCU event tracing is enabled.
    [    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255543ns
    [    0.008258] Console: colour dummy device 80x25
    [    0.012387] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332)
    [    0.027340] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.041516] ASID allocator initialised with 65536 entries
    [    0.046407] Hierarchical SRCU implementation.
    [    0.050995] EFI services will not be available.
    [    0.055213] zynqmp_plat_init Platform Management API v1.1
    [    0.060555] zynqmp_plat_init Trustzone version v1.0
    [    0.065478] smp: Bringing up secondary CPUs ...
    [    0.070121] Detected VIPT I-cache on CPU1
    [    0.070147] CPU1: Booted secondary processor [410fd034]
    [    0.070390] Detected VIPT I-cache on CPU2
    [    0.070406] CPU2: Booted secondary processor [410fd034]
    [    0.070638] Detected VIPT I-cache on CPU3
    [    0.070655] CPU3: Booted secondary processor [410fd034]
    [    0.070693] smp: Brought up 1 node, 4 CPUs
    [    0.101469] SMP: Total of 4 processors activated.
    [    0.106142] CPU features: detected feature: 32-bit EL0 Support
    [    0.111939] CPU: All CPU(s) started at EL2
    [    0.116010] alternatives: patching kernel code
    [    0.121081] devtmpfs: initialized
    [    0.129659] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.133751] futex hash table entries: 1024 (order: 5, 131072 bytes)
    [    0.144881] xor: measuring software checksum speed
    [    0.184035]    8regs     :  2559.000 MB/sec
    [    0.224062]    8regs_prefetch:  2281.000 MB/sec
    [    0.264089]    32regs    :  3145.000 MB/sec
    [    0.304117]    32regs_prefetch:  2729.000 MB/sec
    [    0.304145] xor: using function: 32regs (3145.000 MB/sec)
    [    0.308516] pinctrl core: initialized pinctrl subsystem
    [    0.314067] NET: Registered protocol family 16
    [    0.319114] vdso: 2 pages (1 code @ ffffff8008a86000, 1 data @ ffffff8008f64000)
    [    0.325419] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.332561] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.358699] zynqmp-pinctrl pinctrl: zynqmp pinctrl initialized
    [    0.359584] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
    [    0.366367] ARM CCI_400_r1 PMU driver probed
    [    0.374707] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.445783] raid6: int64x1  gen()   506 MB/s
    [    0.513848] raid6: int64x1  xor()   492 MB/s
    [    0.581889] raid6: int64x2  gen()   765 MB/s
    [    0.649933] raid6: int64x2  xor()   672 MB/s
    [    0.718002] raid6: int64x4  gen()  1160 MB/s
    [    0.786030] raid6: int64x4  xor()   850 MB/s
    [    0.854081] raid6: int64x8  gen()  1091 MB/s
    [    0.922112] raid6: int64x8  xor()   834 MB/s
    [    0.990195] raid6: neonx1   gen()   807 MB/s
    [    1.058221] raid6: neonx1   xor()   946 MB/s
    [    1.126287] raid6: neonx2   gen()  1299 MB/s
    [    1.194329] raid6: neonx2   xor()  1342 MB/s
    [    1.262369] raid6: neonx4   gen()  1673 MB/s
    [    1.330410] raid6: neonx4   xor()  1602 MB/s
    [    1.398456] raid6: neonx8   gen()  1849 MB/s
    [    1.466519] raid6: neonx8   xor()  1704 MB/s
    [    1.466545] raid6: using algorithm neonx8 gen() 1849 MB/s
    [    1.470509] raid6: .... xor() 1704 MB/s, rmw enabled
    [    1.475439] raid6: using neon recovery algorithm
    [    1.481156] SCSI subsystem initialized
    [    1.483771] libata version 3.00 loaded.
    [    1.483881] usbcore: registered new interface driver usbfs
    [    1.489224] usbcore: registered new interface driver hub
    [    1.494499] usbcore: registered new device driver usb
    [    1.499536] media: Linux media interface: v0.10
    [    1.504001] Linux video capture interface: v2.00
    [    1.508597] pps_core: LinuxPPS API ver. 1 registered
    [    1.513500] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.522591] PTP clock support registered
    [    1.526684] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
    [    1.533411] FPGA manager framework
    [    1.536768] fpga-region fpga-full: FPGA Region probed
    [    1.541767] Advanced Linux Sound Architecture Driver Initialized.
    [    1.547970] Bluetooth: Core ver 2.22
    [    1.551311] NET: Registered protocol family 31
    [    1.555713] Bluetooth: HCI device and connection manager initialized
    [    1.562029] Bluetooth: HCI socket layer initialized
    [    1.566872] Bluetooth: L2CAP socket layer initialized
    [    1.571901] Bluetooth: SCO socket layer initialized
    [    1.577268] clocksource: Switched to clocksource arch_sys_counter
    [    1.582866] VFS: Disk quotas dquot_6.6.0
    [    1.586715] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    1.596983] NET: Registered protocol family 2
    [    1.598094] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
    [    1.605198] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
    [    1.611962] TCP: Hash tables configured (established 32768 bind 32768)
    [    1.618137] UDP hash table entries: 2048 (order: 4, 65536 bytes)
    [    1.624110] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
    [    1.630589] NET: Registered protocol family 1
    [    1.634938] RPC: Registered named UNIX socket transport module.
    [    1.640662] RPC: Registered udp transport module.
    [    1.645328] RPC: Registered tcp transport module.
    [    1.649998] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.656402] PCI: CLS 0 bytes, default 128
    [    1.656871] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    1.663721] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    1.671751] audit: initializing netlink subsys (disabled)
    [    1.676611] audit: type=2000 audit(1.623:1): state=initialized audit_enabled=0 res=1
    [    1.676875] workingset: timestamp_bits=62 max_order=20 bucket_order=0
    [    1.691211] NFS: Registering the id_resolver key type
    [    1.695687] Key type id_resolver registered
    [    1.699824] Key type id_legacy registered
    [    1.703807] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.710473] jffs2: version 2.2. (NAND) (SUMMARY)  \xffffffc2\xffffffa9\xffffffa9 2001-2006 Red Hat, Inc.
    [    1.738943] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    1.740683] io scheduler noop registered
    [    1.744581] io scheduler deadline registered
    [    1.748829] io scheduler cfq registered (default)
    [    1.753489] io scheduler mq-deadline registered
    [    1.757986] io scheduler kyber registered
    [    1.763477] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
    [    1.790565] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    1.793333] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    1.800700] brd: module loaded
    [    1.803646] loop: module loaded
    [    1.804184] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    1.811728] libphy: Fixed MDIO Bus: probed
    [    1.814794] tun: Universal TUN/TAP device driver, 1.6
    [    1.819103] CAN device driver interface
    [    1.823262] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    1.858420] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    1.881953] usbcore: registered new interface driver asix
    [    1.882023] usbcore: registered new interface driver ax88179_178a
    [    1.887787] usbcore: registered new interface driver cdc_ether
    [    1.893580] usbcore: registered new interface driver net1080
    [    1.899200] usbcore: registered new interface driver cdc_subset
    [    1.905082] usbcore: registered new interface driver zaurus
    [    1.910626] usbcore: registered new interface driver cdc_ncm
    [    1.916426] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    1.923777] usbcore: registered new interface driver uas
    [    1.927756] usbcore: registered new interface driver usb-storage
    [    1.933935] i2c /dev entries driver
    [    1.937956] IR NEC protocol handler initialized
    [    1.941655] IR RC5(x/sz) protocol handler initialized
    [    1.946670] IR RC6 protocol handler initialized
    [    1.951170] IR JVC protocol handler initialized
    [    1.955666] IR Sony protocol handler initialized
    [    1.960250] IR SANYO protocol handler initialized
    [    1.964921] IR Sharp protocol handler initialized
    [    1.969593] IR MCE Keyboard/mouse protocol handler initialized
    [    1.975388] IR XMP protocol handler initialized
    [    1.980409] usbcore: registered new interface driver uvcvideo
    [    1.985596] USB Video Class driver (1.1.1)
    [    1.989785] axi_fan_control_driver 80000000.axi-fan-control: Re-mapped from 0x80000000 to ffffff800b650000
    [    1.999745] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff800923e000 with timeout 60s
    [    2.008319] Bluetooth: HCI UART driver ver 2.3
    [    2.012587] Bluetooth: HCI UART protocol H4 registered
    [    2.017688] Bluetooth: HCI UART protocol BCSP registered
    [    2.022964] Bluetooth: HCI UART protocol ATH3K registered
    [    2.028327] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    2.034584] Bluetooth: HCI UART protocol Intel registered
    [    2.039919] Bluetooth: HCI UART protocol QCA registered
    [    2.045133] usbcore: registered new interface driver bcm203x
    [    2.050753] usbcore: registered new interface driver bpa10x
    [    2.056291] usbcore: registered new interface driver bfusb
    [    2.061738] usbcore: registered new interface driver btusb
    [    2.067166] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
    [    2.072828] usbcore: registered new interface driver ath3k
    [    2.078616] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1333333 KHz
    [    2.085602] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    2.094277] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
    [    2.102734] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    2.111426] CPUidle arm: Failed to register cpuidle driver
    [    2.116928] sdhci: Secure Digital Host Controller Interface driver
    [    2.122959] sdhci: Copyright(c) Pierre Ossman
    [    2.127283] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.134035] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.138998] usbcore: registered new interface driver usbhid
    [    2.144412] usbhid: USB HID core driver
    [    2.196417] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    2.197825] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    2.204888] Netfilter messages via NETLINK v0.30.
    [    2.209511] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    2.214797] Initializing XFRM netlink socket
    [    2.218975] NET: Registered protocol family 10
    [    2.223650] Segment Routing with IPv6
    [    2.227005] ip6_tables: (C) 2000-2006 Netfilter Core Team
    [    2.232436] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    2.238483] NET: Registered protocol family 17
    [    2.242634] NET: Registered protocol family 15
    [    2.247048] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    2.259926] Ebtables v2.0 registered
    [    2.263538] can: controller area network core (rev 20170425 abi 9)
    [    2.269635] NET: Registered protocol family 29
    [    2.274026] can: raw protocol (rev 20170425)
    [    2.278263] can: broadcast manager protocol (rev 20170425 t)
    [    2.283888] can: netlink gateway (rev 20170425) max_hops=1
    [    2.289526] Bluetooth: RFCOMM TTY layer initialized
    [    2.294186] Bluetooth: RFCOMM socket layer initialized
    [    2.299288] Bluetooth: RFCOMM ver 1.11
    [    2.303005] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    2.308280] Bluetooth: BNEP filters: protocol multicast
    [    2.313472] Bluetooth: BNEP socket layer initialized
    [    2.318400] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    2.324284] Bluetooth: HIDP socket layer initialized
    [    2.329304] 9pnet: Installing 9P2000 support
    [    2.333462] Key type dns_resolver registered
    [    2.338091] registered taskstats version 1
    [    2.342041] Btrfs loaded, crc32c=crc32c-generic
    [    2.350285] ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 22, base_baud = 6249999) is a xuartps
    [    2.360798] console [ttyPS0] enabled
    [    2.364382] bootconsole [cdns0] disabled
    [    2.372494] GPIO line 13 (ulpi-phy-reset) hogged as output/high
    [    2.382489] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
    [    2.390612] PLL: shutdown
    [    2.394500] zynqmp_pll_set_rate() set divider failed for dpll_int, ret = -13
    [    2.401588] zynqmp_clk_divider_set_rate() set divider failed for gpu_ref_div1, ret = -13
    [    2.411135] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Failed to get required clock freq
    [    2.421230] xilinx-dp-snd-codec: probe of fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0 failed with error -22
    [    2.431240] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    2.439245] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    2.447269] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [    2.457322] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
    [    2.464316] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    2.470919] [drm] No driver support for vblank timestamp query.
    [    2.476875] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008b32030)
    [    3.561279] [drm] Cannot find any crtc or sizes
    [    3.565962] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
    [    3.574062] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
    [    3.582997] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    3.590316] libphy: MACB_mii_bus: probed
    [    3.622546] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    3.629792] libphy: MACB_mii_bus: probed
    [    3.705373] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 14 (26:c1:c5:4e:38:b5)
    [    3.715199] Marvell 88E1510 ff0e0000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:00, irq=POLL)
    [    3.730758] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:0 protocol:3 pll_locked:yes
    [    3.740703] dwc3 fe200000.dwc3: stop_host(): INFO: Host already stopped
    [    3.864718] dwc3 fe200000.dwc3: stop_peripheral(): INFO: Peripheral already stopped
    [    3.872488] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    3.877973] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    3.885803] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
    [    3.894508] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0xfe200000
    [    3.900515] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    3.907297] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.914506] usb usb1: Product: xHCI Host Controller
    [    3.919375] usb usb1: Manufacturer: Linux 4.14.0-g8a57ede xhci-hcd
    [    3.925546] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    3.930660] hub 1-0:1.0: USB hub found
    [    3.934416] hub 1-0:1.0: 1 port detected
    [    3.938488] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    3.943970] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    3.951652] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    3.959795] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [    3.966584] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.973801] usb usb2: Product: xHCI Host Controller
    [    3.978669] usb usb2: Manufacturer: Linux 4.14.0-g8a57ede xhci-hcd
    [    3.984840] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    3.989907] hub 2-0:1.0: USB hub found
    [    3.993663] hub 2-0:1.0: 1 port detected
    [    3.999571] at24 0-002c: 2048 byte 24c16 EEPROM, writable, 1 bytes/write
    [    4.006291] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 16
    [    4.013110] i2c i2c-1: Added multiplexed i2c bus 3
    [    4.018006] i2c i2c-1: Added multiplexed i2c bus 4
    [    4.022899] i2c i2c-1: Added multiplexed i2c bus 5
    [    4.054302] i2c i2c-1: Added multiplexed i2c bus 6
    [    4.085694] i2c i2c-1: Added multiplexed i2c bus 7
    [    4.105275] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [    4.110332] usb usb2: USB disconnect, device number 1
    [    4.115711] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
    [    4.121370] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [    4.122849] i2c i2c-1: Added multiplexed i2c bus 8
    [    4.122954] i2c i2c-1: Added multiplexed i2c bus 9
    [    4.123069] i2c i2c-1: Added multiplexed i2c bus 10
    [    4.123073] pca954x 1-0070: registered 8 multiplexed busses for I2C switch pca9548
    [    4.123098] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 17
    [    4.154293] usb usb1: USB disconnect, device number 1
    [    4.159715] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
    [    4.165382] dwc3 fe200000.dwc3: stop_peripheral(): INFO: Peripheral already stopped
    [    4.169278] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
    [    4.175565] adrv9009 spi1.0: adrv9009_probe : enter
    [    4.175746] adrv9009 spi1.1: adrv9009_probe : enter
    [    4.230231] axi_adxcvr 84a40000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using GTH4 at 0x84A40000 mapped to 0xffffff80093dd000. Number of lanes: 4.
    [    4.244808] axi_adxcvr 84a60000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using GTH4 at 0x84A60000 mapped to 0xffffff80093e5000. Number of lanes: 4.
    [    4.258692] axi_adxcvr 84a20000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using GTH4 at 0x84A20000 mapped to 0xffffff80093ed000. Number of lanes: 8.
    [    4.273047] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [    4.283331] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    4.290649] libphy: MACB_mii_bus: probed
    [    4.302275] mmc0: new SDHC card at address 0001
    [    4.306957] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
    [    4.307543] dwc3 fe200000.dwc3: do_b_idle(): ERROR: Failed to set peripheral mode
    [    4.320170]  mmcblk0: p1 p2 p3
    [    4.365367] macb ff0b0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 13 (6a:b0:c2:e0:8b:ba)
    [    4.375188] Marvell 88E1510 ff0e0000.ethernet-ffffffff:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:01, irq=POLL)
    [    4.389480] adrv9009 spi1.0: adrv9009_probe : enter
    [    4.396840] adrv9009 spi1.0: ADIHAL_resetHw at index
    [    4.433277] dwc3 fe200000.dwc3: stop_peripheral(): INFO: Peripheral already stopped
    [    4.440935] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    4.446423] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    4.454355] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
    [    4.463061] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0xfe200000
    [    4.469058] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    4.475840] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    4.483051] usb usb1: Product: xHCI Host Controller
    [    4.487920] usb usb1: Manufacturer: Linux 4.14.0-g8a57ede xhci-hcd
    [    4.494092] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    4.499201] hub 1-0:1.0: USB hub found
    [    4.502962] hub 1-0:1.0: 1 port detected
    [    4.507032] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    4.512517] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    4.520202] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    4.528336] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [    4.535115] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    4.542326] usb usb2: Product: xHCI Host Controller
    [    4.547196] usb usb2: Manufacturer: Linux 4.14.0-g8a57ede xhci-hcd
    [    4.553367] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    4.558436] hub 2-0:1.0: USB hub found
    [    4.562193] hub 2-0:1.0: 1 port detected
    [    4.730356] adrv9009 spi1.0: adrv9009_do_setup:662 Unexpected MCS sync status (0x0)
    [    4.738030] ------------[ cut here ]------------
    [    4.742640] WARNING: CPU: 1 PID: 175 at drivers/clk/clk.c:622 clk_core_disable+0x78/0x80
    [    4.750712] Modules linked in:
    [    4.753753] CPU: 1 PID: 175 Comm: kworker/1:1 Not tainted 4.14.0-g8a57ede #653
    [    4.760955] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
    [    4.767296] Workqueue: events deferred_probe_work_func
    [    4.772421] task: ffffffc87b94af00 task.stack: ffffff80094d0000
    [    4.778325] PC is at clk_core_disable+0x78/0x80
    [    4.782839] LR is at clk_core_disable_lock+0x20/0x38
    [    4.787785] pc : [<ffffff80084a3220>] lr : [<ffffff80084a3248>] pstate: 800000c5
    [    4.795162] sp : ffffff80094d3ab0
    [    4.798461] x29: ffffff80094d3ab0 x28: ffffffc87a4a4a86
    [    4.803756] x27: 00000000000e5def x26: 0000000000000007
    [    4.809051] x25: 0000000000000003 x24: 0000000000000004
    [    4.814345] x23: 0000000000000002 x22: ffffffc87a4a7848
    [    4.819640] x21: 00000000fffffff2 x20: ffffffc87b2ed900
    [    4.824935] x19: 0000000000000040 x18: 0000000000000010
    [    4.830230] x17: 0000000000001599 x16: 0000000000001592
    [    4.835525] x15: ffffffffffffffff x14: ffffff8089022927
    [    4.840820] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0
    [    4.846115] x11: 0000000005f5e0ff x10: 0000000000000006
    [    4.851409] x9 : 00000000ffffffd0 x8 : 79732053434d2064
    [    4.856704] x7 : 657463657078656e x6 : 000000000000016b
    [    4.861999] x5 : 0000000000000064 x4 : 0000000000000000
    [    4.867294] x3 : 0000000000000000 x2 : 00000000005d005c
    [    4.872589] x1 : 0000000000000000 x0 : ffffffc87b2ed900
    [    4.877884] Call trace:
    [    4.880315] Exception stack(0xffffff80094d3970 to 0xffffff80094d3ab0)
    [    4.886739] 3960:                                   ffffffc87b2ed900 0000000000000000
    [    4.894551] 3980: 00000000005d005c 0000000000000000 0000000000000000 0000000000000064
    [    4.902364] 39a0: 000000000000016b 657463657078656e 79732053434d2064 00000000ffffffd0
    [    4.910176] 39c0: 0000000000000006 0000000005f5e0ff ffffff80084ef8e0 ffffff8008f68aa0
    [    4.917988] 39e0: ffffff8089022927 ffffffffffffffff 0000000000001592 0000000000001599
    [    4.925800] 3a00: 0000000000000010 0000000000000040 ffffffc87b2ed900 00000000fffffff2
    [    4.933612] 3a20: ffffffc87a4a7848 0000000000000002 0000000000000004 0000000000000003
    [    4.941424] 3a40: 0000000000000007 00000000000e5def ffffffc87a4a4a86 ffffff80094d3ab0
    [    4.949236] 3a60: ffffff80084a3248 ffffff80094d3ab0 ffffff80084a3220 00000000800000c5
    [    4.957048] 3a80: ffffff80094d3a90 ffffff800854b05c ffffffffffffffff ffffff80087a214c
    [    4.964859] 3aa0: ffffff80094d3ab0 ffffff80084a3220
    [    4.969721] [<ffffff80084a3220>] clk_core_disable+0x78/0x80
    [    4.975277] [<ffffff80084a3248>] clk_core_disable_lock+0x20/0x38
    [    4.981265] [<ffffff80084a327c>] clk_disable+0x1c/0x28
    [    4.986388] [<ffffff80087a1f70>] adrv9009_setup+0x478/0x11f0
    [    4.992028] [<ffffff80087a56d4>] adrv9009_probe+0x29ec/0x2f30
    [    4.997760] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8
    [    5.003062] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8
    [    5.009051] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0
    [    5.015127] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98
    [    5.020682] [<ffffff800854f238>] __device_attach+0xc0/0x130
    [    5.026237] [<ffffff800854f840>] device_initial_probe+0x10/0x18
    [    5.032140] [<ffffff800854e720>] bus_probe_device+0x90/0x98
    [    5.037695] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148
    [    5.044033] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338
    [    5.049760] [<ffffff80080b1dc0>] worker_thread+0x248/0x488
    [    5.055229] [<ffffff80080b7754>] kthread+0x12c/0x130
    [    5.060177] [<ffffff8008084a60>] ret_from_fork+0x10/0x18
    [    5.065469] ---[ end trace 932006e6ec0cf211 ]---
    [    5.070112] ------------[ cut here ]------------
    [    5.074717] WARNING: CPU: 1 PID: 175 at drivers/clk/clk.c:504 clk_core_unprepare+0x80/0x90
    [    5.082968] Modules linked in:
    [    5.086008] CPU: 1 PID: 175 Comm: kworker/1:1 Tainted: G        W       4.14.0-g8a57ede #653
    [    5.094426] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
    [    5.100765] Workqueue: events deferred_probe_work_func
    [    5.105884] task: ffffffc87b94af00 task.stack: ffffff80094d0000
    [    5.111788] PC is at clk_core_unprepare+0x80/0x90
    [    5.116475] LR is at clk_unprepare+0x28/0x40
    [    5.120727] pc : [<ffffff80084a3108>] lr : [<ffffff80084a3a38>] pstate: 60000045
    [    5.128104] sp : ffffff80094d3ac0
    [    5.131403] x29: ffffff80094d3ac0 x28: ffffffc87a4a4a86
    [    5.136698] x27: 00000000000e5def x26: 0000000000000007
    [    5.141993] x25: 0000000000000003 x24: 0000000000000004
    [    5.147287] x23: 0000000000000002 x22: ffffffc87a4a7848
    [    5.152582] x21: 00000000fffffff2 x20: ffffffc87a804180
    [    5.157877] x19: ffffffc87b2ed900 x18: 0000000000000010
    [    5.163172] x17: 0000000000001599 x16: 0000000000001592
    [    5.168467] x15: ffffffffffffffff x14: ffffff8089022927
    [    5.173762] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0
    [    5.179057] x11: 0000000005f5e0ff x10: 0000000000000006
    [    5.184352] x9 : 00000000ffffffd0 x8 : 79732053434d2064
    [    5.189647] x7 : 657463657078656e x6 : 000000000000016b
    [    5.194941] x5 : 0000000000000000 x4 : ffffffc87b94af00
    [    5.200236] x3 : 0000000000000000 x2 : ffffffc87b94af00
    [    5.205531] x1 : 0000000000000000 x0 : ffffffc87b2ed900
    [    5.210825] Call trace:
    [    5.213257] Exception stack(0xffffff80094d3980 to 0xffffff80094d3ac0)
    [    5.219682] 3980: ffffffc87b2ed900 0000000000000000 ffffffc87b94af00 0000000000000000
    [    5.227494] 39a0: ffffffc87b94af00 0000000000000000 000000000000016b 657463657078656e
    [    5.235306] 39c0: 79732053434d2064 00000000ffffffd0 0000000000000006 0000000005f5e0ff
    [    5.243118] 39e0: ffffff80084ef8e0 ffffff8008f68aa0 ffffff8089022927 ffffffffffffffff
    [    5.250930] 3a00: 0000000000001592 0000000000001599 0000000000000010 ffffffc87b2ed900
    [    5.258742] 3a20: ffffffc87a804180 00000000fffffff2 ffffffc87a4a7848 0000000000000002
    [    5.266554] 3a40: 0000000000000004 0000000000000003 0000000000000007 00000000000e5def
    [    5.274366] 3a60: ffffffc87a4a4a86 ffffff80094d3ac0 ffffff80084a3a38 ffffff80094d3ac0
    [    5.282178] 3a80: ffffff80084a3108 0000000060000045 ffffffffffffffff ffffff80087a214c
    [    5.289990] 3aa0: ffffffffffffffff ffffff80084a3220 ffffff80094d3ac0 ffffff80084a3108
    [    5.297803] [<ffffff80084a3108>] clk_core_unprepare+0x80/0x90
    [    5.303531] [<ffffff80084a3a38>] clk_unprepare+0x28/0x40
    [    5.308826] [<ffffff80087a1f78>] adrv9009_setup+0x480/0x11f0
    [    5.314468] [<ffffff80087a56d4>] adrv9009_probe+0x29ec/0x2f30
    [    5.320198] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8
    [    5.325492] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8
    [    5.331481] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0
    [    5.337557] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98
    [    5.343113] [<ffffff800854f238>] __device_attach+0xc0/0x130
    [    5.348668] [<ffffff800854f840>] device_initial_probe+0x10/0x18
    [    5.354570] [<ffffff800854e720>] bus_probe_device+0x90/0x98
    [    5.360126] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148
    [    5.366463] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338
    [    5.372191] [<ffffff80080b1dc0>] worker_thread+0x248/0x488
    [    5.377659] [<ffffff80080b7754>] kthread+0x12c/0x130
    [    5.382607] [<ffffff8008084a60>] ret_from_fork+0x10/0x18
    [    5.387900] ---[ end trace 932006e6ec0cf212 ]---
    [    5.392520] adrv9009 spi1.0: ADIHAL_resetHw at index
    [    5.398494] [drm] Cannot find any crtc or sizes
    [    5.517421] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
    [    5.681274] dwc3 fe200000.dwc3: stop_peripheral(): INFO: Peripheral already stopped
    [    5.730503] adrv9009 spi1.0: adrv9009_do_setup:662 Unexpected MCS sync status (0x0)
    [    5.738167] ------------[ cut here ]------------
    [    5.742772] WARNING: CPU: 1 PID: 175 at drivers/clk/clk.c:622 clk_core_disable+0x78/0x80
    [    5.750848] Modules linked in:
    [    5.753889] CPU: 1 PID: 175 Comm: kworker/1:1 Tainted: G        W       4.14.0-g8a57ede #653
    [    5.762306] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
    [    5.768646] Workqueue: events deferred_probe_work_func
    [    5.773773] task: ffffffc87b94af00 task.stack: ffffff80094d0000
    [    5.779677] PC is at clk_core_disable+0x78/0x80
    [    5.780588] usb 2-1: New USB device found, idVendor=2109, idProduct=0812
    [    5.780592] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    5.780595] usb 2-1: Product: USB3.0 Hub
    [    5.780598] usb 2-1: Manufacturer: VIA Labs, Inc.
    [    5.784373] hub 2-1:1.0: USB hub found
    [    5.784513] hub 2-1:1.0: 4 ports detected
    [    5.816220] LR is at clk_core_disable_lock+0x20/0x38
    [    5.821167] pc : [<ffffff80084a3220>] lr : [<ffffff80084a3248>] pstate: 800000c5
    [    5.828544] sp : ffffff80094d3ab0
    [    5.831843] x29: ffffff80094d3ab0 x28: ffffffc87a4a4a86
    [    5.837138] x27: 00000000000e5def x26: 0000000000000007
    [    5.842432] x25: 0000000000000003 x24: 0000000000000004
    [    5.847727] x23: 0000000000000002 x22: ffffffc87a4a7848
    [    5.853022] x21: 00000000fffffff2 x20: ffffffc87b2ed900
    [    5.858317] x19: 0000000000000040 x18: 0000000000000010
    [    5.863612] x17: 0000000000001599 x16: 0000000000001592
    [    5.868907] x15: ffffffffffffffff x14: 757461747320636e
    [    5.874202] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0
    [    5.879496] x11: 55203236363a7075 x10: 0000000000000006
    [    5.884791] x9 : 3030397672646120 x8 : 3a302e3169707320
    [    5.890086] x7 : 3930303976726461 x6 : 00000000000001e0
    [    5.895381] x5 : 0000000000000064 x4 : 0000000000000000
    [    5.900676] x3 : 0000000000000000 x2 : 00000000005f005e
    [    5.905971] x1 : 0000000000000000 x0 : ffffffc87b2ed900
    [    5.911265] Call trace:
    [    5.913697] Exception stack(0xffffff80094d3970 to 0xffffff80094d3ab0)
    [    5.920121] 3960:                                   ffffffc87b2ed900 0000000000000000
    [    5.927933] 3980: 00000000005f005e 0000000000000000 0000000000000000 0000000000000064
    [    5.935745] 39a0: 00000000000001e0 3930303976726461 3a302e3169707320 3030397672646120
    [    5.943557] 39c0: 0000000000000006 55203236363a7075 ffffff80084ef8e0 ffffff8008f68aa0
    [    5.951370] 39e0: 757461747320636e ffffffffffffffff 0000000000001592 0000000000001599
    [    5.959182] 3a00: 0000000000000010 0000000000000040 ffffffc87b2ed900 00000000fffffff2
    [    5.966994] 3a20: ffffffc87a4a7848 0000000000000002 0000000000000004 0000000000000003
    [    5.974806] 3a40: 0000000000000007 00000000000e5def ffffffc87a4a4a86 ffffff80094d3ab0
    [    5.982618] 3a60: ffffff80084a3248 ffffff80094d3ab0 ffffff80084a3220 00000000800000c5
    [    5.990430] 3a80: ffffff80094d3a90 ffffff800854b05c ffffffffffffffff ffffff80087a214c
    [    5.998241] 3aa0: ffffff80094d3ab0 ffffff80084a3220
    [    6.003103] [<ffffff80084a3220>] clk_core_disable+0x78/0x80
    [    6.008658] [<ffffff80084a3248>] clk_core_disable_lock+0x20/0x38
    [    6.014647] [<ffffff80084a327c>] clk_disable+0x1c/0x28
    [    6.019769] [<ffffff80087a1f70>] adrv9009_setup+0x478/0x11f0
    [    6.025410] [<ffffff80087a596c>] adrv9009_probe+0x2c84/0x2f30
    [    6.031140] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8
    [    6.036435] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8
    [    6.042424] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0
    [    6.048500] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98
    [    6.054055] [<ffffff800854f238>] __device_attach+0xc0/0x130
    [    6.059610] [<ffffff800854f840>] device_initial_probe+0x10/0x18
    [    6.065513] [<ffffff800854e720>] bus_probe_device+0x90/0x98
    [    6.071068] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148
    [    6.077405] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338
    [    6.083133] [<ffffff80080b1dc0>] worker_thread+0x248/0x488
    [    6.088601] [<ffffff80080b7754>] kthread+0x12c/0x130
    [    6.093550] [<ffffff8008084a60>] ret_from_fork+0x10/0x18
    [    6.098842] ---[ end trace 932006e6ec0cf213 ]---
    [    6.103480] ------------[ cut here ]------------
    [    6.108081] WARNING: CPU: 1 PID: 175 at drivers/clk/clk.c:504 clk_core_unprepare+0x80/0x90
    [    6.116332] Modules linked in:
    [    6.119372] CPU: 1 PID: 175 Comm: kworker/1:1 Tainted: G        W       4.14.0-g8a57ede #653
    [    6.127790] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
    [    6.134129] Workqueue: events deferred_probe_work_func
    [    6.139248] task: ffffffc87b94af00 task.stack: ffffff80094d0000
    [    6.145152] PC is at clk_core_unprepare+0x80/0x90
    [    6.149839] LR is at clk_unprepare+0x28/0x40
    [    6.154092] pc : [<ffffff80084a3108>] lr : [<ffffff80084a3a38>] pstate: 60000045
    [    6.161469] sp : ffffff80094d3ac0
    [    6.164767] x29: ffffff80094d3ac0 x28: ffffffc87a4a4a86
    [    6.170062] x27: 00000000000e5def x26: 0000000000000007
    [    6.175357] x25: 0000000000000003 x24: 0000000000000004
    [    6.180652] x23: 0000000000000002 x22: ffffffc87a4a7848
    [    6.185947] x21: 00000000fffffff2 x20: ffffffc87a804180
    [    6.191242] x19: ffffffc87b2ed900 x18: 0000000000000010
    [    6.196536] x17: 0000000000001599 x16: 0000000000001592
    [    6.201831] x15: ffffffffffffffff x14: 757461747320636e
    [    6.207126] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0
    [    6.212421] x11: 55203236363a7075 x10: 0000000000000006
    [    6.217716] x9 : 3030397672646120 x8 : 3a302e3169707320
    [    6.223011] x7 : 3930303976726461 x6 : 00000000000001e0
    [    6.228305] x5 : 0000000000000000 x4 : ffffffc87b94af00
    [    6.233600] x3 : 0000000000000000 x2 : ffffffc87b94af00
    [    6.238895] x1 : 0000000000000000 x0 : ffffffc87b2ed900
    [    6.244190] Call trace:
    [    6.246622] Exception stack(0xffffff80094d3980 to 0xffffff80094d3ac0)
    [    6.253046] 3980: ffffffc87b2ed900 0000000000000000 ffffffc87b94af00 0000000000000000
    [    6.260858] 39a0: ffffffc87b94af00 0000000000000000 00000000000001e0 3930303976726461
    [    6.268670] 39c0: 3a302e3169707320 3030397672646120 0000000000000006 55203236363a7075
    [    6.276482] 39e0: ffffff80084ef8e0 ffffff8008f68aa0 757461747320636e ffffffffffffffff
    [    6.284294] 3a00: 0000000000001592 0000000000001599 0000000000000010 ffffffc87b2ed900
    [    6.292106] 3a20: ffffffc87a804180 00000000fffffff2 ffffffc87a4a7848 0000000000000002
    [    6.299918] 3a40: 0000000000000004 0000000000000003 0000000000000007 00000000000e5def
    [    6.307731] 3a60: ffffffc87a4a4a86 ffffff80094d3ac0 ffffff80084a3a38 ffffff80094d3ac0
    [    6.315542] 3a80: ffffff80084a3108 0000000060000045 ffffffffffffffff ffffff80087a214c
    [    6.323355] 3aa0: ffffffffffffffff ffffff80084a3220 ffffff80094d3ac0 ffffff80084a3108
    [    6.331167] [<ffffff80084a3108>] clk_core_unprepare+0x80/0x90
    [    6.336896] [<ffffff80084a3a38>] clk_unprepare+0x28/0x40
    [    6.342190] [<ffffff80087a1f78>] adrv9009_setup+0x480/0x11f0
    [    6.347832] [<ffffff80087a596c>] adrv9009_probe+0x2c84/0x2f30
    [    6.353562] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8
    [    6.358857] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8
    [    6.364846] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0
    [    6.370921] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98
    [    6.376477] [<ffffff800854f238>] __device_attach+0xc0/0x130
    [    6.382032] [<ffffff800854f840>] device_initial_probe+0x10/0x18
    [    6.387935] [<ffffff800854e720>] bus_probe_device+0x90/0x98
    [    6.393490] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148
    [    6.399826] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338
    [    6.405555] [<ffffff80080b1dc0>] worker_thread+0x248/0x488
    [    6.411023] [<ffffff80080b7754>] kthread+0x12c/0x130
    [    6.415971] [<ffffff8008084a60>] ret_from_fork+0x10/0x18
    [    6.421264] ---[ end trace 932006e6ec0cf214 ]---
    [    6.425901] adrv9009: probe of spi1.0 failed with error -14
    [    6.431664] adrv9009 spi1.1: adrv9009_probe : enter
    [    6.438885] adrv9009 spi1.1: ADIHAL_resetHw at index
    [    6.771282] adrv9009 spi1.1: adrv9009_do_setup:662 Unexpected MCS sync status (0x0)
    [    6.778944] ------------[ cut here ]------------
    [    6.783549] WARNING: CPU: 1 PID: 175 at drivers/clk/clk.c:622 clk_core_disable+0x78/0x80
    [    6.791625] Modules linked in:
    [    6.794666] CPU: 1 PID: 175 Comm: kworker/1:1 Tainted: G        W       4.14.0-g8a57ede #653
    [    6.803084] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
    [    6.809423] Workqueue: events deferred_probe_work_func
    [    6.814551] task: ffffffc87b94af00 task.stack: ffffff80094d0000
    [    6.820454] PC is at clk_core_disable+0x78/0x80
    [    6.824968] LR is at clk_core_disable_lock+0x20/0x38
    [    6.829915] pc : [<ffffff80084a3220>] lr : [<ffffff80084a3248>] pstate: 800000c5
    [    6.837292] sp : ffffff80094d3ab0
    [    6.840590] x29: ffffff80094d3ab0 x28: ffffffc87a4a4a86
    [    6.845885] x27: 00000000000e5def x26: 0000000000000007
    [    6.851180] x25: 0000000000000003 x24: 0000000000000004
    [    6.856475] x23: 0000000000000002 x22: ffffffc87a4a7848
    [    6.861770] x21: 00000000fffffff2 x20: ffffffc87b2ed900
    [    6.867065] x19: 0000000000000040 x18: 0000000000000010
    [    6.872359] x17: 0000000000001599 x16: 0000000000001592
    [    6.877654] x15: ffffffffffffffff x14: ffffff8089022927
    [    6.882949] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0
    [    6.888244] x11: 0000000005f5e0ff x10: 0000000000000006
    [    6.893539] x9 : 00000000ffffffd0 x8 : 7320636e79732053
    [    6.898833] x7 : 434d206465746365 x6 : 000000000000025a
    [    6.904128] x5 : 0000000000000064 x4 : 0000000000000000
    [    6.909423] x3 : 0000000000000000 x2 : 0000000000640063
    [    6.914718] x1 : 0000000000000000 x0 : ffffffc87b2ed900
    [    6.920013] Call trace:
    [    6.922445] Exception stack(0xffffff80094d3970 to 0xffffff80094d3ab0)
    [    6.928868] 3960:                                   ffffffc87b2ed900 0000000000000000
    [    6.936681] 3980: 0000000000640063 0000000000000000 0000000000000000 0000000000000064
    [    6.944493] 39a0: 000000000000025a 434d206465746365 7320636e79732053 00000000ffffffd0
    [    6.952305] 39c0: 0000000000000006 0000000005f5e0ff ffffff80084ef8e0 ffffff8008f68aa0
    [    6.960117] 39e0: ffffff8089022927 ffffffffffffffff 0000000000001592 0000000000001599
    [    6.967929] 3a00: 0000000000000010 0000000000000040 ffffffc87b2ed900 00000000fffffff2
    [    6.975741] 3a20: ffffffc87a4a7848 0000000000000002 0000000000000004 0000000000000003
    [    6.983553] 3a40: 0000000000000007 00000000000e5def ffffffc87a4a4a86 ffffff80094d3ab0
    [    6.991366] 3a60: ffffff80084a3248 ffffff80094d3ab0 ffffff80084a3220 00000000800000c5
    [    6.999178] 3a80: ffffff80094d3a90 ffffff800854b05c ffffffffffffffff ffffff80087a214c
    [    7.006989] 3aa0: ffffff80094d3ab0 ffffff80084a3220
    [    7.011851] [<ffffff80084a3220>] clk_core_disable+0x78/0x80
    [    7.017406] [<ffffff80084a3248>] clk_core_disable_lock+0x20/0x38
    [    7.023395] [<ffffff80084a327c>] clk_disable+0x1c/0x28
    [    7.028516] [<ffffff80087a1f70>] adrv9009_setup+0x478/0x11f0
    [    7.034158] [<ffffff80087a56d4>] adrv9009_probe+0x29ec/0x2f30
    [    7.039888] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8
    [    7.045182] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8
    [    7.051172] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0
    [    7.057247] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98
    [    7.062803] [<ffffff800854f238>] __device_attach+0xc0/0x130
    [    7.068358] [<ffffff800854f840>] device_initial_probe+0x10/0x18
    [    7.074260] [<ffffff800854e720>] bus_probe_device+0x90/0x98
    [    7.079816] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148
    [    7.086152] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338
    [    7.091881] [<ffffff80080b1dc0>] worker_thread+0x248/0x488
    [    7.097349] [<ffffff80080b7754>] kthread+0x12c/0x130
    [    7.102297] [<ffffff8008084a60>] ret_from_fork+0x10/0x18
    [    7.107590] ---[ end trace 932006e6ec0cf215 ]---
    [    7.112225] ------------[ cut here ]------------
    [    7.116829] WARNING: CPU: 1 PID: 175 at drivers/clk/clk.c:504 clk_core_unprepare+0x80/0x90
    [    7.125080] Modules linked in:
    [    7.128120] CPU: 1 PID: 175 Comm: kworker/1:1 Tainted: G        W       4.14.0-g8a57ede #653
    [    7.136538] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
    [    7.142877] Workqueue: events deferred_probe_work_func
    [    7.148005] task: ffffffc87b94af00 task.stack: ffffff80094d0000
    [    7.153908] PC is at clk_core_unprepare+0x80/0x90
    [    7.158595] LR is at clk_unprepare+0x28/0x40
    [    7.162848] pc : [<ffffff80084a3108>] lr : [<ffffff80084a3a38>] pstate: 60000045
    [    7.170225] sp : ffffff80094d3ac0
    [    7.173524] x29: ffffff80094d3ac0 x28: ffffffc87a4a4a86
    [    7.178818] x27: 00000000000e5def x26: 0000000000000007
    [    7.184113] x25: 0000000000000003 x24: 0000000000000004
    [    7.189408] x23: 0000000000000002 x22: ffffffc87a4a7848
    [    7.194703] x21: 00000000fffffff2 x20: ffffffc87b1a0080
    [    7.199998] x19: ffffffc87b2ed900 x18: 0000000000000010
    [    7.205293] x17: 0000000000001599 x16: 0000000000001592
    [    7.210588] x15: ffffffffffffffff x14: ffffff8089022927
    [    7.215882] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0
    [    7.221177] x11: 0000000005f5e0ff x10: 0000000000000006
    [    7.226472] x9 : 00000000ffffffd0 x8 : 7320636e79732053
    [    7.231767] x7 : 434d206465746365 x6 : 000000000000025a
    [    7.237062] x5 : 0000000000000000 x4 : ffffffc87b94af00
    [    7.242357] x3 : 0000000000000000 x2 : ffffffc87b94af00
    [    7.247651] x1 : 0000000000000000 x0 : ffffffc87b2ed900
    [    7.252946] Call trace:
    [    7.255378] Exception stack(0xffffff80094d3980 to 0xffffff80094d3ac0)
    [    7.261802] 3980: ffffffc87b2ed900 0000000000000000 ffffffc87b94af00 0000000000000000
    [    7.269614] 39a0: ffffffc87b94af00 0000000000000000 000000000000025a 434d206465746365
    [    7.277426] 39c0: 7320636e79732053 00000000ffffffd0 0000000000000006 0000000005f5e0ff
    [    7.285239] 39e0: ffffff80084ef8e0 ffffff8008f68aa0 ffffff8089022927 ffffffffffffffff
    [    7.293050] 3a00: 0000000000001592 0000000000001599 0000000000000010 ffffffc87b2ed900
    [    7.300863] 3a20: ffffffc87b1a0080 00000000fffffff2 ffffffc87a4a7848 0000000000000002
    [    7.308674] 3a40: 0000000000000004 0000000000000003 0000000000000007 00000000000e5def
    [    7.316487] 3a60: ffffffc87a4a4a86 ffffff80094d3ac0 ffffff80084a3a38 ffffff80094d3ac0
    [    7.324299] 3a80: ffffff80084a3108 0000000060000045 ffffffffffffffff ffffff80087a214c
    [    7.332111] 3aa0: ffffffffffffffff ffffff80084a3220 ffffff80094d3ac0 ffffff80084a3108
    [    7.339923] [<ffffff80084a3108>] clk_core_unprepare+0x80/0x90
    [    7.345652] [<ffffff80084a3a38>] clk_unprepare+0x28/0x40
    [    7.350946] [<ffffff80087a1f78>] adrv9009_setup+0x480/0x11f0
    [    7.356588] [<ffffff80087a56d4>] adrv9009_probe+0x29ec/0x2f30
    [    7.362318] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8
    [    7.367613] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8
    [    7.373602] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0
    [    7.379678] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98
    [    7.385233] [<ffffff800854f238>] __device_attach+0xc0/0x130
    [    7.390789] [<ffffff800854f840>] device_initial_probe+0x10/0x18
    [    7.396691] [<ffffff800854e720>] bus_probe_device+0x90/0x98
    [    7.402246] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148
    [    7.408583] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338
    [    7.41431▒▒▒▒2▒▒▒▒▒ႂ�▒"▒▒▒▒▒▒ɭ▒▒}ѡɕ▒▒▒▒▒ɢ▒z▒▒▒▒▒j▒▒          ғ▒SS▒▒S▒i▒2▒▒▒▒▒ႂ�ݺ▒▒▒▒Zѡɕ▒▒▒▒▒Œ▒▒▒Ś▒j▒▒                ғ▒▒ӓ▒Si▒2▒▒▒▒▒ႂ�¢
        ق▒▒▒▒▒}▒ɽ▒}▒▒ɭ▒▒▒łz▒▒▒▒j▒▒               ғ▒▒&&&LW▒KKK+HY▒▒ trace 932006e6ec0cf216 ]---
    [    7.434637] adrv9009 spi1.1: ADIHAL_resetHw at index
    [    7.766961] adrv9009 spi1.1: adrv9009_do_setup:662 Unexpected MCS sync status (0x0)
    [    7.774627] ------------[ cut here ]------------
    [    7.779233] WARNING: CPU: 1 PID: 175 at drivers/clk/clk.c:622 clk_core_disable+0x78/0x80
    [    7.787309] Modules linked in:
    [    7.790350] CPU: 1 PID: 175 Comm: kworker/1:1 Tainted: G        W       4.14.0-g8a57ede #653
    [    7.798768] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
    [    7.805107] Workqueue: events deferred_probe_work_func
    [    7.810235] task: ffffffc87b94af00 task.stack: ffffff80094d0000
    [    7.816138] PC is at clk_core_disable+0x78/0x80
    [    7.820652] LR is at clk_core_disable_lock+0x20/0x38
    [    7.825599] pc : [<ffffff80084a3220>] lr : [<ffffff80084a3248>] pstate: 800000c5
    [    7.832976] sp : ffffff80094d3ab0
    [    7.836275] x29: ffffff80094d3ab0 x28: ffffffc87a4a4a86
    [    7.841569] x27: 00000000000e5def x26: 0000000000000007
    [    7.846864] x25: 0000000000000003 x24: 0000000000000004
    [    7.852159] x23: 0000000000000002 x22: ffffffc87a4a7848
    [    7.857454] x21: 00000000fffffff2 x20: ffffffc87b2ed900
    [    7.862748] x19: 0000000000000040 x18: 0000000000000010
    [    7.868043] x17: 0000000000001599 x16: 0000000000001592
    [    7.873338] x15: ffffffffffffffff x14: ffffff8089022927
    [    7.878633] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0
    [    7.883928] x11: 0000000005f5e0ff x10: 0000000000000006
    [    7.889223] x9 : 00000000ffffffd0 x8 : 7320636e79732053
    [    7.894518] x7 : 434d206465746365 x6 : 00000000000002cc
    [    7.899813] x5 : 0000000000000064 x4 : 0000000000000000
    [    7.905107] x3 : 0000000000000000 x2 : 0000000000650064
    [    7.910402] x1 : 0000000000000000 x0 : ffffffc87b2ed900
    [    7.915697] Call trace:
    [    7.918129] Exception stack(0xffffff80094d3970 to 0xffffff80094d3ab0)
    [    7.924552] 3960:                                   ffffffc87b2ed900 0000000000000000
    [    7.932365] 3980: 0000000000650064 0000000000000000 0000000000000000 0000000000000064
    [    7.940177] 39a0: 00000000000002cc 434d206465746365 7320636e79732053 00000000ffffffd0
    [    7.947989] 39c0: 0000000000000006 0000000005f5e0ff ffffff80084ef8e0 ffffff8008f68aa0
    [    7.955801] 39e0: ffffff8089022927 ffffffffffffffff 0000000000001592 0000000000001599
    [    7.963613] 3a00: 0000000000000010 0000000000000040 ffffffc87b2ed900 00000000fffffff2
    [    7.971425] 3a20: ffffffc87a4a7848 0000000000000002 0000000000000004 0000000000000003
    [    7.979237] 3a40: 0000000000000007 00000000000e5def ffffffc87a4a4a86 ffffff80094d3ab0
    [    7.987050] 3a60: ffffff80084a3248 ffffff80094d3ab0 ffffff80084a3220 00000000800000c5
    [    7.994862] 3a80: ffffff80094d3a90 ffffff800854b05c ffffffffffffffff ffffff80087a214c
    [    8.002673] 3aa0: ffffff80094d3ab0 ffffff80084a3220
    [    8.007535] [<ffffff80084a3220>] clk_core_disable+0x78/0x80
    [    8.013090] [<ffffff80084a3248>] clk_core_disable_lock+0x20/0x38
    [    8.019079] [<ffffff80084a327c>] clk_disable+0x1c/0x28
    [    8.024200] [<ffffff80087a1f70>] adrv9009_setup+0x478/0x11f0
    [    8.029842] [<ffffff80087a596c>] adrv9009_probe+0x2c84/0x2f30
    [    8.035572] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8
    [    8.040867] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8
    [    8.046856] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0
    [    8.052931] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98
    [    8.058487] [<ffffff800854f238>] __device_attach+0xc0/0x130
    [    8.064042] [<ffffff800854f840>] device_initial_probe+0x10/0x18
    [    8.069944] [<ffffff800854e720>] bus_probe_device+0x90/0x98
    [    8.075500] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148
    [    8.081836] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338
    [    8.087565] [<ffffff80080b1dc0>] worker_thread+0x248/0x488
    [    8.093033] [<ffffff80080b7754>] kthread+0x12c/0x130
    [    8.097981] [<ffffff8008084a60>] ret_from_fork+0x10/0x18
    [    8.103274] ---[ end trace 932006e6ec0cf217 ]---
    [    8.107912] ------------[ cut here ]------------
    [    8.112513] WARNING: CPU: 1 PID: 175 at drivers/clk/clk.c:504 clk_core_unprepare+0x80/0x90
    [    8.120764] Modules linked in:
    [    8.123804] CPU: 1 PID: 175 Comm: kworker/1:1 Tainted: G        W       4.14.0-g8a57ede #653
    [    8.132222] Hardware name: Analog Devices ADRV9009-ZU11EG Rev.B (DT)
    [    8.138561] Workqueue: events deferred_probe_work_func
    [    8.143680] task: ffffffc87b94af00 task.stack: ffffff80094d0000
    [    8.149584] PC is at clk_core_unprepare+0x80/0x90
    [    8.154271] LR is at clk_unprepare+0x28/0x40
    [    8.158523] pc : [<ffffff80084a3108>] lr : [<ffffff80084a3a38>] pstate: 60000045
    [    8.165901] sp : ffffff80094d3ac0
    [    8.169199] x29: ffffff80094d3ac0 x28: ffffffc87a4a4a86
    [    8.174494] x27: 00000000000e5def x26: 0000000000000007
    [    8.179789] x25: 0000000000000003 x24: 0000000000000004
    [    8.185083] x23: 0000000000000002 x22: ffffffc87a4a7848
    [    8.190378] x21: 00000000fffffff2 x20: ffffffc87b1a0080
    [    8.195673] x19: ffffffc87b2ed900 x18: 0000000000000010
    [    8.200968] x17: 0000000000001599 x16: 0000000000001592
    [    8.206263] x15: ffffffffffffffff x14: ffffff8089022927
    [    8.211558] x13: ffffff8008f68aa0 x12: ffffff80084ef8e0
    [    8.216853] x11: 0000000005f5e0ff x10: 0000000000000006
    [    8.222148] x9 : 00000000ffffffd0 x8 : 7320636e79732053
    [    8.227442] x7 : 434d206465746365 x6 : 00000000000002cc
    [    8.232737] x5 : 0000000000000000 x4 : ffffffc87b94af00
    [    8.238032] x3 : 0000000000000000 x2 : ffffffc87b94af00
    [    8.243327] x1 : 0000000000000000 x0 : ffffffc87b2ed900
    [    8.248621] Call trace:
    [    8.251053] Exception stack(0xffffff80094d3980 to 0xffffff80094d3ac0)
    [    8.257478] 3980: ffffffc87b2ed900 0000000000000000 ffffffc87b94af00 0000000000000000
    [    8.265290] 39a0: ffffffc87b94af00 0000000000000000 00000000000002cc 434d206465746365
    [    8.273102] 39c0: 7320636e79732053 00000000ffffffd0 0000000000000006 0000000005f5e0ff
    [    8.280914] 39e0: ffffff80084ef8e0 ffffff8008f68aa0 ffffff8089022927 ffffffffffffffff
    [    8.288726] 3a00: 0000000000001592 0000000000001599 0000000000000010 ffffffc87b2ed900
    [    8.296538] 3a20: ffffffc87b1a0080 00000000fffffff2 ffffffc87a4a7848 0000000000000002
    [    8.304350] 3a40: 0000000000000004 0000000000000003 0000000000000007 00000000000e5def
    [    8.312162] 3a60: ffffffc87a4a4a86 ffffff80094d3ac0 ffffff80084a3a38 ffffff80094d3ac0
    [    8.319974] 3a80: ffffff80084a3108 0000000060000045 ffffffffffffffff ffffff80087a214c
    [    8.327786] 3aa0: ffffffffffffffff ffffff80084a3220 ffffff80094d3ac0 ffffff80084a3108
    [    8.335599] [<ffffff80084a3108>] clk_core_unprepare+0x80/0x90
    [    8.341327] [<ffffff80084a3a38>] clk_unprepare+0x28/0x40
    [    8.346622] [<ffffff80087a1f78>] adrv9009_setup+0x480/0x11f0
    [    8.352264] [<ffffff80087a596c>] adrv9009_probe+0x2c84/0x2f30
    [    8.357993] [<ffffff80085d2538>] spi_drv_probe+0x78/0xc8
    [    8.363288] [<ffffff800854f58c>] driver_probe_device+0x22c/0x2d8
    [    8.369277] [<ffffff800854f790>] __device_attach_driver+0x98/0xf0
    [    8.375353] [<ffffff800854d7f0>] bus_for_each_drv+0x48/0x98
    [    8.380909] [<ffffff800854f238>] __device_attach+0xc0/0x130
    [    8.386464] [<ffffff800854f840>] device_initial_probe+0x10/0x18
    [    8.392366] [<ffffff800854e720>] bus_probe_device+0x90/0x98
    [    8.397922] [<ffffff800854ebbc>] deferred_probe_work_func+0xa4/0x148
    [    8.404258] [<ffffff80080b1a14>] process_one_work+0x1d4/0x338
    [    8.409987] [<ffffff80080b1dc0>] worker_thread+0x248/0x488
    [    8.415455] [<ffffff80080b7754>] kthread+0x12c/0x130
    [    8.420403] [<ffffff8008084a60>] ret_from_fork+0x10/0x18
    [    8.425696] ---[ end trace 932006e6ec0cf218 ]---
    [    8.430322] adrv9009: probe of spi1.1 failed with error -14
    [    8.436602] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [    8.447747] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    8.454666] hctosys: unable to open rtc device (rtc0)
    [    8.460784] ALSA device list:
    [    8.463748]   No soundcards found.
    [    8.467953] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [    8.504583] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    8.512684] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    8.539988] devtmpfs: mounted
    [    8.543045] Freeing unused kernel memory: 512K
    [    9.247590] init: hwclock main process (1798) terminated with status 1
    [    9.865308] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [    9.949339] usb 2-1.4: new SuperSpeed USB device number 3 using xhci-hcd
    [    9.973780] usb 2-1.4: New USB device found, idVendor=2537, idProduct=1081
    [    9.973786] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    9.973789] usb 2-1.4: Product: NS1081
    [    9.973793] usb 2-1.4: Manufacturer: Norelsys
    [    9.973796] usb 2-1.4: SerialNumber: 0123456789ABCDE
    [    9.974419] usb-storage 2-1.4:1.0: USB Mass Storage device detected
    [    9.976199] scsi host0: usb-storage 2-1.4:1.0
    [    9.977336] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [   10.314394] systemd-udevd[1923]: starting version 204
    [   11.831040] pps pps0: new PPS source ptp0
    [   11.831050] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [   11.831165] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   12.137949] random: crng init done
    [   13.266360] scsi 0:0:0:0: Direct-Access     NORELSYS 1081             0    PQ: 0 ANSI: 6
    [   13.268039] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
    [   13.278600] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [   13.842609] init: failsafe main process (2904) killed by TERM signal
    [   14.065313] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [   14.961398] macb ff0e0000.ethernet eth0: link up (1000/Full)
    [   14.961429] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   16.816024] init: samba-ad-dc main process (3081) terminated with status 1
    [   17.006638] init: alsa-restore main process (3228) terminated with status 19
    [   17.449741] file system registered
    [   17.583820] pps pps1: new PPS source ptp1
    [   17.583830] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered.
    [   17.583893] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   17.638755] read descriptors
    [   17.638766] read strings
    [   18.165303] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [   18.658007] init: tty1 main process (3424) killed by TERM signal
    [   22.261288] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [   22.267861] usb usb1-port1: unable to enumerate USB device
    [   22.319610] init: udev-fallback-graphics main process (3520) terminated with status 1
    [  375.397210] ttyPS ttyPS0: 1 input overrun(s)
    I have tried using the 2018_R2 release that I have been using, and it boots up fine with no issues (ADRV9009 related IIO devices appear as expected, IIOScope can communicate, USB connected mouse.keyboard function).
    Any ideas on why the ADRV9009 isn't being recognized/how to fix it?
    Thank you,
    -Samual
