ADRV9361 and Petalinux 2019.2
Hi ,
I would like to build linux image for ADRV9361-z7035 using petalinux 2019.2 (I would like to use Xilinx VITIS).
I've followed this link:
https://wiki.analog.com/resources/tools-software/linux-build/generic/petalinux
But the meta-adi repository does not support Petalinux 2019.2 (i've tried it - it failes since the petalinux kernel version is 4.19 instead 4.14).
Any advice how to overcome this issue ?
Thank you ,
Nimrod
  • +1
    on Jan 6, 2020 1:56 PM 10 months ago
    At this point, only Petalinux-v2018.3 is supported, but since our Linux master branch version is 4.19, we might do an upgrade. However, we don't have an exact timeline for this.
    We are accepting patches from outside, so if you decide to do it yourself, we would be happy to merge a pull-request from you.
    Dragos
  • Hai. I am using petalinux 2018.3, while following the documentation after getting the hardware description what all changes has to be made in the configuration box other than yocto settings. I am using adrv9361 z7035 . What should i give as the "MACHINE_NAME" and the "u-boot configuration target ". I am confused . By default it is zc706 board. Should i change it or leave it alone?
