Custom Board Based on ZynqMP: axi_adxcvr 84a50000.axi_ad9371_rx_os_xcvr: RX Error: 0
Hi All,
We are working on custom board which is based on zynqMP. We are using latest 2018.R3 repos.
I have seen that ad9371 is not probed well because of some issues which are mentioned below:
[    9.132030] axi_adxcvr 84a50000.axi_ad9371_rx_os_xcvr: RX Error: 0
[    9.138209] ad9371 spi1.0: jesd_rx_os_clk enable failed (-5)
[    9.927736] random: crng init done
[   10.871431] WARNING: 239: Clock PLL Lock event timed out in MYKONOS_waitForEvent()
[   10.878994] ad9371 spi1.0: Clock PLL Lock event timed out in MYKONOS_waitForEvent()
[   10.878994]  (239)
[   10.888658] ad9371: probe of spi1.0 failed with error -14.
Inside the driver code (ad9371.c),  have caught the code snippet which is throwing this error:
    if (has_obs_and_en(phy)) {
        ret = clk_prepare_enable(phy->jesd_rx_os_clk);
        if (ret < 0) {
            dev_err(&phy->spi->dev, "jesd_rx_os_clk enable failed (%d)", ret);
            goto out_disable_rx_clk;
pl..dtsi
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Wed Jul 31 06:06:43 2019
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		compatible = "simple-bus";
		ranges ;
		AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_rx_jesd_axi_ad9371_rx_os_jesd_rx_axi: axi_jesd204_rx_os_jesd@84ab0000 {
			clock-names = "s_axi_aclk", "core_clk";
			clocks = <&clk 71>, <&misc_clk_0>;
			compatible = "xlnx,axi-jesd204-rx-1.0";
			interrupt-names = "irq";
			interrupt-parent = <&gic>;
			interrupts = <0 104 4>;
			reg = <0x0 0x84ab0000 0x0 0x4000>;
		misc_clk_0: misc_clk_0 {
			#clock-cells = <0>;
			clock-frequency = <100000000>;
			compatible = "fixed-clock";
		AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_rx_jesd_rx_axi: axi_jesd204_rx@84aa0000 {
			interrupts = <0 106 4>;
			reg = <0x0 0x84aa0000 0x0 0x4000>;
		AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_tx_jesd_tx_axi: axi_jesd204_tx@84a90000 {
			compatible = "xlnx,axi-jesd204-tx-1.0";
			interrupts = <0 105 4>;
			reg = <0x0 0x84a90000 0x0 0x4000>;
		AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_rx_os_xcvr: axi_ad9371_rx_os_xcvr@84a50000 {
			clock-names = "s_axi_aclk";
			clocks = <&clk 71>;
			compatible = "xlnx,axi-adxcvr-1.0";
			reg = <0x0 0x84a50000 0x0 0x10000>;
		AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_rx_xcvr: axi_ad9371_rx_xcvr@84a60000 {
			clocks = <&clk 71>;
			reg = <0x0 0x84a60000 0x0 0x10000>;
		AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_tx_xcvr: axi_ad9371_tx_xcvr@84a80000 {
			clocks = <&clk 71>;
			reg = <0x0 0x84a80000 0x0 0x10000>;
		AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_rx_clkgen: axi_ad9371_rx_clkgen@83c10000 {
			clock-names = "clk", "s_axi_aclk";
			clocks = <&misc_clk_1>, <&clk 71>;
			compatible = "xlnx,axi-clkgen-1.0";
			reg = <0x0 0x83c10000 0x0 0x10000>;
		misc_clk_1: misc_clk_1 {
			#clock-cells = <0>;
		AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_rx_os_clkgen: axi_ad9371_rx_os_clkgen@83c20000 {
			reg = <0x0 0x83c20000 0x0 0x10000>;
		AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_tx_clkgen: axi_ad9371_tx_clkgen@83c00000 {
			reg = <0x0 0x83c00000 0x0 0x10000>;
		AD9371_TOP_ad9371_tpl_core_rx_ad9371_tpl_core_tpl_core: ad_ip_jesd204_tpl_adc@84a00000 {
			clock-names = "link_clk", "s_axi_aclk";
			clocks = <&misc_clk_0>, <&clk 71>;
			compatible = "xlnx,ad-ip-jesd204-tpl-adc-1.0";
			reg = <0x0 0x84a00000 0x0 0x1000>;
		AD9371_TOP_ad9371_tpl_core_rx_os_ad9371_tpl_core_tpl_core: ad_ip_jesd204_tpl_adc_rx_os@84a08000 {
			reg = <0x0 0x84a08000 0x0 0x1000>;
		AD9371_TOP_ad9371_tpl_core_tx_ad9371_tpl_core_tpl_core: ad_ip_jesd204_tpl_dac_tx@84a04000 {
			compatible = "xlnx,ad-ip-jesd204-tpl-dac-1.0";
			reg = <0x0 0x84a04000 0x0 0x1000>;
		AXI_AD_DMA_TOP_axi_ad9371_rx_dma: axi_ad9371_rx_dma@9c400000 {
			clock-names = "s_axi_aclk", "m_dest_axi_aclk", "fifo_wr_clk";
			clocks = <&clk 71>, <&clk 72>, <&misc_clk_0>;
			compatible = "xlnx,axi-dmac-1.0";
			interrupts = <0 109 4>;
			reg = <0x0 0x9c400000 0x0 0x1000>;
		AXI_AD_DMA_TOP_axi_ad9371_rx_os_dma: axi_ad9371_rx_os_dma@9c440000 {
			interrupts = <0 107 4>;
			reg = <0x0 0x9c440000 0x0 0x1000>;
		AXI_AD_DMA_TOP_axi_ad9371_tx_dma: axi_ad9371_tx_dma@9c420000 {
			clock-names = "s_axi_aclk", "m_src_axi_aclk", "m_axis_aclk";
			clocks = <&clk 71>, <&clk 72>, <&clk 72>;
			interrupts = <0 108 4>;
			reg = <0x0 0x9c420000 0x0 0x1000>;
		psu_ctrl_ipi: PERIPHERAL@ff380000 {
			compatible = "xlnx,PERIPHERAL-1.0";
			reg = <0x0 0xff380000 0x0 0x80000>;
		psu_message_buffers: PERIPHERAL@ff990000 {
			reg = <0x0 0xff990000 0x0 0x10000>;
system-user.dtsi
/include/ "system-conf.dtsi"
    chosen {
        bootargs = "earlycon clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait uio_pdrv_genirq.of_id=generic-uio loglevel=7";
        stdout-path = "serial0:115200n8";
&dwc3_0 {
	status = "okay";
	dr_mode = "host";
	maximum-speed = "super-speed";
	snps,usb3_lpm_capable;
	phy-names = "usb3-phy";
	phys = <&lane2 0x4 0x0 0x3 0x18CBA80>;
&pinctrl0 {
			pini2c0def:i2c0-default {
				mux {
					groups = "i2c0_9_grp";
					function = "i2c0";
				conf {
					bias-pull-up;
					slew-rate = <0x1>;
					io-standard = <0x0>;
			pini2c0gp:i2c0-gpio {
				mux {
					groups = "gpio0_38_grp", "gpio0_39_grp";
					function = "gpio0";
				conf {
					slew-rate = <0x1>;
			pini2c1def:i2c1-default {
				mux {
					groups = "i2c1_10_grp";
					function = "i2c1";
				conf {
					bias-pull-up;
					slew-rate = <0x1>;
			pini2c1gp:i2c1-gpio {
				mux {
					groups = "gpio0_40_grp", "gpio0_41_grp";
					function = "gpio0";
				conf {
					slew-rate = <0x1>;
			pinuart0def:uart0-default {
				mux {
					groups = "uart0_10_grp";
					function = "uart0";
				conf {
					slew-rate = <0x1>;
				conf-rx {
					pins = "MIO42";
					bias-high-impedance;
				conf-tx {
					pins = "MIO43";
					bias-disable;
			pinuart1def:uart1-default {
				mux {
					groups = "uart1_11_grp";
					function = "uart1";
				conf {
					slew-rate = <0x1>;
				conf-rx {
					pins = "MIO45";
				conf-tx {
					pins = "MIO44";
					bias-disable;
			pingem1def:gem1-default {
				mux-mdio {
					function = "mdio1";
					groups = "mdio1_0_grp";
				conf-mdio {
					slew-rate = <0x1>;
					bias-disable;
			pingem2def:gem2-default {
				mux-mdio {
					function = "mdio2";
					groups = "mdio1_1_grp";
				conf-mdio {
					slew-rate = <0x1>;
					bias-disable;
			pinsdhci:sdhci0-default {
				mux {
					groups = "sdio0_0_grp";
					function = "sdio0";
				conf {
					slew-rate = <0x1>;
					bias-disable;
			pingpio:gpio-default {
				mux-sw {
					function = "gpio0";
					groups = "gpio0_74_grp", "gpio0_75_grp";
				conf-sw {
					slew-rate = <0x1>;
					io-standard = <0>;
				conf-pull-up {
					pins = "MIO74", "MIO75";
					bias-pull-up;
				conf-pull-none {
					pins = "MIO64", "MIO65";
					bias-disable;
		pinctrl_usb0_default: usb0-default {
		mux {
			groups = "usb0_0_grp";
			function = "usb0";
		conf {
			slew-rate = <0x1>;
			io-standard = <0>;
		conf-rx {
			pins = "MIO52", "MIO53", "MIO55";
		conf-tx {
			pins = "MIO54", "MIO56", "MIO57", "MIO58", "MIO59",
				   "MIO60", "MIO61", "MIO62", "MIO63";
			bias-disable;
	pinctrl_qspi0_default: qspi0-default {
		mux {
			function = "usb0";
		conf {
			slew-rate = <0x1>;
			io-standard = <0>;
		conf-rx {
		conf-tx {
			bias-disable;
&gpio{
	pinctrl-names = "default";
	pinctrl-0 = <&pingpio>;
&i2c0 {
	pinctrl-names = "default", "gpio";
	pinctrl-0 = <&pini2c0def>;
	pinctrl-1 = <&pini2c0gp>;
	scl-gpios = <&gpio 0x26 0x0>;
	sda-gpios = <&gpio 0x27 0x0>;
					EEPROM:eeprom@50 {
						compatible = "at,24c256";
						reg = <0x50>;
						#address-cells = <0x1>;
						#size-cells = <0x1>;
						board_sn@0 {
							reg = <0x0 0x14>;
						eth_mac@20 {
							reg = <0x20 0x6>;
						board_name@d0 {
							reg = <0xd0 0x6>;
						board_revision@e0 {
							reg = <0xe0 0x3>;
					RTC:rtc@68 {
						compatible = "dallas,ds1340";
						reg = <0x68>;
					FPGATEMP:fpgaTemp@4C {
						compatible = "adt7461";
						reg = <0x4C>;
				i2cswitch@71 {
					compatible = "nxp,pca9546";
					#size-cells = <0x0>;
					reg = <0x71>;
					RFM1@0{
						compatible = "xxx";
						reg = <0x0>;
					RFM2@1{
						compatible = "xxx";
						reg = <0x1>;
					PSB@2{
						compatible = "xxx";
						reg = <0x2>;
					hotspot:hotspot@48 {
						compatible = "ti,tmp112";
						reg = <0x48>;
&i2c1 {
	pinctrl-0 = <&pini2c1def>;
	pinctrl-1 = <&pini2c1gp>;
	scl-gpios = <&gpio 0x28 0x0>;
	sda-gpios = <&gpio 0x29 0x0>;
			ina226_1@40 {
				compatible = "ti,ina226";
				reg = <0x40>;
				shunt-resistor = <0x7d0>;
			ina226_2@41 {
				reg = <0x41>;
				shunt-resistor = <0x1388>;
			ina226_3@44 {
				reg = <0x44>;
			ina226_4@45 {
				reg = <0x45>;
			i2cswitch@70 {
				reg = <0x70>;
					SFP_1:SFP0@0{
					compatible = "xxx";
					reg = <0x0>;
					SFP_2:SFP1@1{
					compatible = "xxx";
					reg = <0x1>;
					SFP_3:SFP2@2 {
					compatible = "xxx";
					reg = <0x2>;
					SFP_4:SFP3@3 {
					compatible = "xxx";
					reg = <0x3>;
&sdhci0 {
	pinctrl-0 = <&pinsdhci>;
	/* broken-mmc-highspeed; */
	no-1-8-v;
	broken-cd;
&spi1 {
spidev1: cpld@0 {
		#clock-cells = <0x1>;
		compatible = "spidev";
		reg = <0x0>;
		spi-max-frequency = <0x989680>;
&spi0 {
clk0_ad9528: ad9528-1@2 {
				compatible = "adi,ad9528";
				reg = <0x2>;
				clock-output-names = "ad9528-1_out0", "ad9528-1_out1", "ad9528-1_out2", "ad9528-1_out3", "ad9528-1_out4",
									 "ad9528-1_out5", "ad9528-1_out6", "ad9528-1_out7", "ad9528-1_out8", "ad9528-1_out9",
									 "ad9528-1_out10", "ad9528-1_out11", "ad9528-1_out12", "ad9528-1_out13";
				adi,vcxo-freq = <0x7530000>;
				adi,refb-enable;
				adi,refb-r-div = <0x1>;
				/*adi,refa-cmos-neg-inp-enable;*/
				adi,ref-mode = <0x3>;
				/*adi,osc-in-cmos-neg-inp-enable;*/
				adi,pll1-feedback-div = <0x8>;
				/*adi,pll1-feedback-src-vcxo = <0x1>;*/
				adi,pll1-charge-pump-current-nA = <0x1388>;
				adi,pll2-vco-div-m1 = <0x3>;
				adi,pll2-n2-div = <0xa>;
				adi,pll2-r1-div = <0x1>;
				adi,pll2-charge-pump-current-nA = <0xc4888>;
				adi,sysref-src = <0x2>;
				adi,sysref-pattern-mode = <0x1>;
				adi,sysref-k-div = <2000>;
				/*adi,sysref-request-enable; see this */
				adi,sysref-nshot-mode = <0x3>;
				adi,sysref-request-trigger-mode = <0x3>;
				adi,rpole2 = <0x0>;
				adi,rzero = <0x2>;
				adi,cpole1 = <0x2>;
				adi,status-mon-pin0-function-select = <0x1>;
				adi,status-mon-pin1-function-select = <0x7>;
				reset-gpios = <&gpio 0x4a 0x0>;
				channel@0 {
					reg = <0x0>;
					adi,extended-name = "DEV_CLK";
					adi,driver-mode = <0x0>;
					adi,divider-phase = <0x0>;
					adi,channel-divider = <0x5>;
					adi,signal-source = <0x0>;
				channel@1 {
					reg = <0x1>;
					adi,extended-name = "DEV_CLK1";
				channel@5 {
					reg = <0x5>;
					adi,extended-name = "FMC_CLK";
				channel@6 {
					reg = <0x6>;
					adi,extended-name = "FMC_CLK1";
				channel@2 {
					reg = <0x2>;
					adi,extended-name = "DEV_SYSREF";
					adi,signal-source = <0x3>;
				channel@3 {
					reg = <0x3>;
					adi,extended-name = "DEV_SYSREF1";
				channel@4 {
					reg = <0x4>;
					adi,extended-name = "FMC_SYSREF";
					adi,signal-source = <0x2>;
				channel@13 {
					reg = <0xd>;
					adi,extended-name = "TEST_OUT";
					adi,channel-divider = <0xa>;
					adi,signal-source = <0x1>;
trx0_ad9371: ad9371-phy@0 {
		compatible = "adi,ad9371";
		reg = <0>;
		clocks = <&AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_rx_jesd_rx_axi>,
				 <&AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_tx_jesd_tx_axi>,
				 <&AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_rx_jesd_axi_ad9371_rx_os_jesd_rx_axi>,
                 <&clk0_ad9528 0>,<&clk0_ad9528 5>, <&clk0_ad9528 2>, <&clk0_ad9528 4>;
		clock-names = "jesd_rx_clk", "jesd_tx_clk", "jesd_rx_os_clk", "dev_clk", "fmc_clk","sysref_dev_clk","sysref_fmc_clk";
		clock-output-names = "rx_sampl_clk", "rx_os_sampl_clk", "tx_sampl_clk";
		adi,clocks-clk-pll-vco-freq_khz = <9830400>;
		adi,clocks-device-clock_khz = <122880>;
		adi,clocks-clk-pll-hs-div = <4>;
		adi,clocks-clk-pll-vco-div = <2>;
		adi,jesd204-obs-framer-over-sample = <0>;
		adi,rx-profile-adc-div = <1>;
		adi,rx-profile-en-high-rej-dec5 = <1>;
		adi,rx-profile-iq-rate_khz = <122880>;
		adi,rx-profile-rf-bandwidth_hz = <100000000>;
		adi,rx-profile-rhb1-decimation = <1>;
		adi,rx-profile-rx-bbf-3db-corner_khz = <100000>;
		adi,rx-profile-rx-dec5-decimation = <5>;
		adi,rx-profile-rx-fir-decimation = <2>;
		adi,rx-profile-rx-fir-gain_db = <(-6)>;
		adi,rx-profile-rx-fir-num-fir-coefs = <48>;
		adi,rx-profile-rx-fir-coefs = /bits/ 16 <(-5) (-26) (32) (51) (-67) (-116) (140) (212) (-252) (-367) (429) (595) (-688) (-931) (1072) (1427) (-1650) (-2188) (2612) (3496) (-4802) (-7591) (9656) (32317) (32317) (9656) (-7591) (-4802) (3496) (2612) (-2188) (-1650) (1427) (1072) (-931) (-688) (595) (429) (-367) (-252) (212) (140) (-116) (-67) (51) (32) (-26) (-5)>;
		adi,rx-profile-custom-adc-profile = /bits/ 16  <534 386 201 98 1280 491 1591 279 1306 104 792 28 48 39 23 187>;
		adi,obs-profile-adc-div = <1>;
		adi,obs-profile-en-high-rej-dec5 = <1>;
		adi,obs-profile-iq-rate_khz = <245760>;
		adi,obs-profile-rf-bandwidth_hz = <200000000>;
		adi,obs-profile-rhb1-decimation = <1>;
		adi,obs-profile-rx-bbf-3db-corner_khz = <100000>;
		adi,obs-profile-rx-dec5-decimation = <5>;
		adi,obs-profile-rx-fir-decimation = <1>;
		adi,obs-profile-rx-fir-gain_db = <6>;
		adi,obs-profile-rx-fir-num-fir-coefs = <24>;
		adi,obs-profile-rx-fir-coefs = /bits/ 16 <(-289) (81) (-23) (-86) (229) (-354) (397) (-233) (-657) (1699) (-4172) (23010) (-4172) (1699) (-657) (-233) (397) (-354) (229) (-86) (-23) (81) (-289) (0)>;
		adi,obs-profile-custom-adc-profile = /bits/ 16  <450 349 201 98 1280 730 1626 818 1476 732 834 20 41 36 24 200>;
		adi,obs-settings-custom-loopback-adc-profile = /bits/ 16  <569 369 201 98 1280 291 1541 149 1320 58 807 34 48 40 23 189>;
		adi,tx-profile-dac-div = <1>;
		adi,tx-profile-iq-rate_khz = <245760>;
		adi,tx-profile-primary-sig-bandwidth_hz = <75000000>;
		adi,tx-profile-rf-bandwidth_hz = <200000000>;
		adi,tx-profile-thb1-interpolation = <2>;
		adi,tx-profile-thb2-interpolation = <1>;
		adi,tx-profile-tx-bbf-3db-corner_khz = <100000>;
		adi,tx-profile-tx-dac-3db-corner_khz = <187000>;
		adi,tx-profile-tx-fir-interpolation = <1>;
		adi,tx-profile-tx-input-hb-interpolation = <1>;
		adi,tx-profile-tx-fir-gain_db = <6>;
		adi,tx-profile-tx-fir-num-fir-coefs = <16>;
		adi,tx-profile-tx-fir-coefs = /bits/ 16 <(6) (-270) (203) (-168) (-84) (983) (-3222) (21143) (-3222) (983) (-84) (-168) (203) (-270) (6) (0)>;
		adi,sniffer-profile-adc-div = <1>;
		adi,sniffer-profile-en-high-rej-dec5 = <0>;
		adi,sniffer-profile-iq-rate_khz = <30720>;
		adi,sniffer-profile-rf-bandwidth_hz = <20000000>;
		adi,sniffer-profile-rhb1-decimation = <2>;
		adi,sniffer-profile-rx-bbf-3db-corner_khz = <100000>;
		adi,sniffer-profile-rx-dec5-decimation = <5>;
		adi,sniffer-profile-rx-fir-decimation = <4>;
		reset-gpios = <&gpio 130 0>;
		test-gpios = <&gpio 131 0>;
		sysref_req-gpios = <&gpio 136 0>;
		rx2_enable-gpios = <&gpio 132 0>;
		rx1_enable-gpios = <&gpio 133 0>;
		tx2_enable-gpios = <&gpio 134 0>;
		tx1_enable-gpios = <&gpio 135 0>;
		adi,jesd204-deframer-eq-setting = <3>;
&amba_pl {
	ranges = <0 0 0 0xffffffff>;
/* TBD */
&axi_dma_0{
reg = <0x80001000 0x1000>;
&axi_ethernet_0{
reg = <0x80000000 0x1000>;
//2018.v2: axi_ad9371_core: axi_ad9371@84a00000
//2018v3: This "AD9371_TOP_ad9371_tpl_core_rx_ad9371_tpl_core_tpl_core" has same address like old one axi_ad9371_core:
//	      This "AD9371_TOP_ad9371_tpl_core_rx_os_ad9371_tpl_core_tpl_core" is a new block
//		  This "AD9371_TOP_ad9371_tpl_core_tx_ad9371_tpl_core_tpl_core" is a new block
&AD9371_TOP_ad9371_tpl_core_rx_ad9371_tpl_core_tpl_core {
	compatible = "adi,axi-ad9371-rx-1.0";
	reg = <0x84a00000 0x10000>;
    //clock-names = "link_clk", "s_axi_aclk";
    //clocks = <&misc_clk_0>, <&clk 71>;
	dmas = <&AXI_AD_DMA_TOP_axi_ad9371_rx_dma 0>;
	dma-names = "rx";
	spibus-connected = <&trx0_ad9371>;
&AD9371_TOP_ad9371_tpl_core_rx_os_ad9371_tpl_core_tpl_core {
	reg = <0x84a08000 0x10000>;
	dma-names = "rx";
&AD9371_TOP_ad9371_tpl_core_tx_ad9371_tpl_core_tpl_core {
	reg = <0x84a04000 0x10000>;
	dma-names = "rx";
&misc_clk_0 {
	#clock-cells = <0>;
&misc_clk_1 {
	#clock-cells = <0>;
&axi_ddc_rx_dma {
		compatible = "adi,axi-dmac-1.00.a";
		reg = <0x9c400000 0x1000>;
		#dma-cells = <1>;
		#clock-cells = <0>;
		clocks = <&clk 73>;
		adi,channels {
			#size-cells = <0>;
			#address-cells = <1>;
			dma-channel@0 {
				reg = <0>;
				adi,source-bus-width = <60>;
				adi,source-bus-type = <2>;
				adi,destination-bus-width = <60>;
				adi,destination-bus-type = <0>;
  //2019.v2: axi_ad9371_rx_dma
  //2018.v3: AXI_AD_DMA_TOP_axi_ad9371_rx_dma
&AXI_AD_DMA_TOP_axi_ad9371_rx_dma {
        #dma-cells = <1>;
        #clock-cells = <0>;
		//2018.v2: Input Clock Configuration
		clocks = <&clk 73>;
		//2018.v3: Input Clock Configuration
		//clock-names = "s_axi_aclk", "m_dest_axi_aclk", "fifo_wr_clk";
		//clocks = <&clk 71>, <&clk 72>, <&misc_clk_0>;
        adi,channels {
                #size-cells = <0>;
                dma-channel@0 {
                        reg = <0>;
                        adi,source-bus-width = <64>;
                        adi,destination-bus-width = <64>;
  //2018.v2: axi_ad9371_rx_jesd_rx_axi
  //2018.v3: AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_rx_jesd_rx_axi
&AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_rx_jesd_rx_axi {
	compatible = "adi,axi-jesd204-rx-1.0";
	reg = <0x84aa0000 0x4000>;
	//clocks = <&clk 71>, <&axi_ad9371_rx_clkgen>, <&axi_ad9371_rx_xcvr 0>;
	clocks = <&clk 71>, <&AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_rx_clkgen>,<&AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_rx_xcvr 0>;
	clock-names = "s_axi_aclk", "device_clk", "lane_clk";
    //clock-names = "s_axi_aclk", "core_clk";
    //clocks = <&clk 71>, <&misc_clk_0>;
	#clock-cells = <0>;
	clock-output-names = "jesd_rx_lane_clk";
	adi,octets-per-frame = <4>;
	adi,frames-per-multiframe = <32>;
  //2018.v2: axi_ad9371_rx_os_dma
  //2018.v3: AXI_AD_DMA_TOP_axi_ad9371_rx_os_dma
&AXI_AD_DMA_TOP_axi_ad9371_rx_os_dma {
			reg = <0x9c440000 0x1000>;
			#dma-cells = <1>;
			#clock-cells = <0>;
			clocks = <&clk 73>;
			adi,channels {
				#size-cells = <0>;
				dma-channel@0 {
					reg = <0>;
   //2018.v2: axi_ad9371_rx_os_jesd_rx_axi
   //2018.v3: AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_rx_jesd_axi_ad9371_rx_os_jesd_rx_axi
&AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_rx_jesd_axi_ad9371_rx_os_jesd_rx_axi{
	reg = <0x84ab0000 0x4000>;
    // 2018.v2: The clock configuration
    //	clocks = <&clk 71>, <&axi_ad9371_tx_clkgen>, <&axi_ad9371_rx_os_xcvr 0>;
   	clocks = <&clk 71>, <&AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_tx_clkgen>,<&AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_rx_os_xcvr 0>;
    // 2018.v3: New Clock Configuration
    //Clock Output: No Change
	#clock-cells = <0>;
	clock-output-names = "jesd_rx_os_lane_clk";
	adi,octets-per-frame = <2>;
  //2018.v2:  axi_ad9371_rx_os_xcvr
  //2018.v3:  AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_rx_os_xcvr
&AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_rx_os_xcvr {
	compatible = "adi,axi-adxcvr-1.0";
	reg = <0x84a50000 0x10000>;
	//clocks =  <&clk0_ad9528 5>, <&axi_ad9371_tx_clkgen>;
	clocks =  <&clk0_ad9528 5>, <&AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_tx_clkgen>;
	clock-names = "conv", "div40";
    //clock-names = "s_axi_aclk";
    //clocks = <&clk 71>;
	#clock-cells = <1>;
	clock-output-names = "rx_os_gt_clk", "rx_os_out_clk";
	adi,sys-clk-select = <0>;
	adi,out-clk-select = <3>;
	adi,use-lpm-enable;
	adi,use-cpll-enable;
   //2018.v2: axi_ad9371_rx_xcvr
   //2018.v3: AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_rx_xcvr
&AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_rx_xcvr {
	reg = <0x84a60000 0x10000>;
    // 2018.v2: Input clock configuration
	//clocks = <&clk0_ad9528 5>, <&axi_ad9371_rx_clkgen 0>;
	clocks = <&clk0_ad9528 5>, <&AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_rx_clkgen 0>;
    // 2018.v3: Input Clock Configuration
	#clock-cells = <1>;
	clock-output-names = "rx_gt_clk", "rx_out_clk";
	adi,use-lpm-enable;
    //2018.v2: axi_ad9371_rx_clkgen
    //2018.v3: AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_rx_clkgen
&AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_rx_clkgen {
			compatible = "adi,axi-clkgen-2.00.a";
			reg = <0x83c10000 0x10000>;
            clocks = <&clk0_ad9528 5>;
            //clock-names = "clk", "s_axi_aclk";
            //clocks = <&misc_clk_1>, <&clk 71>;
			#clock-cells = <0>;
			clock-output-names = "axi_rx_clkgen";
   //2018.v3: AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_rx_os_clkgen
   // Its a newly added block which is not present in 2018.v2
&AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_rx_os_clkgen {
	  reg = <0x83c20000 0x10000>;
	  #clock-cells = <0x0>;
      clock-output-names = "axi_rx_os_clkgen";
   //2018.v2: axi_ad9371_tx_clkgen
   //2018.v3: AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_tx_clkgen
   //Depend: ??
&AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_tx_clkgen {
	  reg = <0x83c00000 0x10000>;
	  clock-output-names = "axi_tx_clkgen";
   //2018.v2: axi_ad9371_tx_dma
   //2018.v3: AXI_AD_DMA_TOP_axi_ad9371_tx_dma
&AXI_AD_DMA_TOP_axi_ad9371_tx_dma {
			reg = <0x9c420000 0x1000>;
			#dma-cells = <1>;
			#clock-cells = <0>;
			clocks = <&clk 73>;
			//clock-names = "s_axi_aclk", "m_src_axi_aclk", "m_axis_aclk";
 		    //clocks = <&clk 71>, <&clk 72>, <&clk 72>;
			adi,channels {
				#size-cells = <0>;
				dma-channel@0 {
					reg = <0>;
					adi,source-bus-type = <0>;
					adi,destination-bus-width = <128>;
					adi,destination-bus-type = <1>;
   //2018.v2: axi_ad9371_tx_jesd_tx_axi
   //2018.v3: AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_tx_jesd_tx_axi
&AD9371_TOP_JESD_TOP_jesd_ctrl_top_axi_ad9371_tx_jesd_tx_axi {
	compatible = "adi,axi-jesd204-tx-1.0";
	reg = <0x84a90000 0x4000>;
	//clocks = <&clk 71>, <&axi_ad9371_tx_clkgen>,<&axi_ad9371_tx_xcvr 0>;
	clocks = <&clk 71>,<&AD9371_TOP_ad9371_clk_rst_gen_top_axi_ad9371_tx_clkgen>,<&AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_tx_xcvr 0>;
	#clock-cells = <0>;
	clock-output-names = "jesd_tx_lane_clk";
	adi,converter-resolution = <14>;
	adi,bits-per-sample = <16>;
	adi,converters-per-device = <4>;
	adi,control-bits-per-sample = <2>;
   //2018.v2: axi_ad9371_tx_xcvr
   //2018.v3: AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_tx_xcvr
&AD9371_TOP_JESD_TOP_xcvr_top_axi_ad9371_tx_xcvr{
	reg = <0x84a80000 0x10000>;
	#clock-cells = <1>;
	clock-output-names = "tx_gt_clk", "tx_out_clk";
	adi,sys-clk-select = <3>;
&cpri_zcu102_0{
	reg = <0x80004000 0x1000>;
	compatible = "generic-uio";
&axi_iic_0{
	reg = <0x80003000 0x1000>;
&user_reg_top_0{
	reg = <0x80002000 0x1000>;
&psu_ctrl_ipi {
	reg = <0xff380000 0x80000>;
&psu_message_buffers {
	reg = <0xff990000 0x10000>;
Kindly see the system-user.dtsi and pl.dtsi if anything which is missing.
Manish
Parents Reply Children
No Data
