ad9361 devicetree
I'm trying to get a custom FMCOMMS3 like daughterboard to work with a ZynqMP.
Our Vivado project was updated to include all the IP cores from the ZCU102 + FMCOMMS2 project (here)
Most of the project seems to be working, the AD9361 spi node, the DMAs and the cf-ad9361-dds-core-lpc are probed with no apparent error but Linux fails to initialize the cf-ad9361-lpc core.
here is a sample of our bootlog showing the error:
[root@zynqmp ~]$ dmesg | grep -i ad9361
[    1.708884] ad9361 spi2.0: ad9361_probe : enter (ad9361)
[    1.934319] ad9361 spi2.0: ad9361_probe : AD936x Rev 2 successfully initialized
[    1.958005] cf_axi_dds 80004000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.00.b) at 0x80004000 mapped to 0xffffff8008ff5000, probed DDS
 AD9361
[    2.479485] ad9361 spi2.0: Failed to set BB ref clock rate (-22)
[    3.428878] ad9361 spi2.0: Calibration TIMEOUT (0x5E, 0x80)
[    3.455354] ad9361 spi2.0: Failed to set BB ref clock rate (-22)
[    3.607736] ad9361 spi2.0: ad9361_dig_tune_delay: Tuning RX FAILED!
[    3.614246] cf_axi_adc: probe of 80000000.cf-ad9361-lpc failed with error -5
here is a section of our devicetree based on this file.
cf_ad9361_adc_core_0: cf-ad9361-lpc@80000000 {
        compatible = "adi,axi-ad9361-6.00.a";
        reg = < 0x00 0x80000000 0x00 0x6000 >;
        dmas = <&rx_dma 0>;
        dma-names = "rx";
        spibus-connected = <&adc0_ad9361>;
cf_ad9361_dac_core_0: cf-ad9361-dds-core-lpc@80004000 {
        compatible = "adi,axi-ad9361-dds-6.00.a";
        reg = < 0x00 0x80004000 0x00 0x1000 >;
        clocks = <&adc0_ad9361 13>;
        clock-names = "sampl_clk";
        dmas = <&tx_dma 0>;
        dma-names = "tx";
the base address of the axi_ad9361 core is 0x80000000.
I couldn't find information on how to deduce the reg parameters for these two nodes. Am I missing something in the dts?
Where is this BB ref clock setup, is it a parameter in Vivado?
Thanks for your help,
Liam
    I didn't make any changes to those values.
    How can I find the information needed to set these frequencies?
    Liam
  • You must not alter these frequencies.
    Can you provide your entire dmesg?
    and please read /sys/kernel/debug/clk/clk summary as well.
    Also provide your complete device tree.
    -Michael
  • I just leaned that we are using the external oscillator on our board. I set the 'adi,xo-disable-use-ext-refclk-enable' but I'm still having the same issues with the BB ref clock.
    here is our complete dmesg:
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.14.0 (lvb@pepper.xiphos.ca) (gcc version 8.1.1 20180626 (Red Hat Cross 8.1.1-3) (GCC)) #8 SMP Tue Mar 26 14:09:22 EDT 2019
    [    0.000000] Boot CPU: AArch64 Processor [410fd034]
    [    0.000000] Machine model: Xiphos Q8 RevA
    [    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
    [    0.000000] bootconsole [cdns0] enabled
    [    0.000000] cma: Reserved 256 MiB at 0x000000006dc00000
    [    0.000000] On node 0 totalpages: 524288
    [    0.000000]   DMA zone: 7168 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 524288 pages, LIFO batch:31
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] random: fast init done
    [    0.000000] percpu: Embedded 20 pages/cpu @ffffffc07ff6d000 s44440 r8192 d29288 u81920
    [    0.000000] pcpu-alloc: s44440 r8192 d29288 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: enabling workaround for ARM erratum 845719
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 517120
    [    0.000000] Kernel command line: console=ttyPS0,115200 earlycon clk_ignore_unused serial=1013 rootwait=1 rw rootfstype=ubifs ubi.mtd=qspi0-nom-rootfs root=ubi0:q8-reva-rootfs
    [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
    [    0.000000] Memory: 1787948K/2097152K available (7422K kernel code, 560K rwdata, 4120K rodata, 384K init, 2100K bss, 47060K reserved, 262144K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
    [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
    [    0.000000]       .text : 0xffffff8008080000 - 0xffffff80087c0000   (  7424 KB)
    [    0.000000]     .rodata : 0xffffff80087c0000 - 0xffffff8008bd0000   (  4160 KB)
    [    0.000000]       .init : 0xffffff8008bd0000 - 0xffffff8008c30000   (   384 KB)
    [    0.000000]       .data : 0xffffff8008c30000 - 0xffffff8008cbc008   (   561 KB)
    [    0.000000]        .bss : 0xffffff8008cbc008 - 0xffffff8008ec9030   (  2101 KB)
    [    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
    [    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
    [    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
    [    0.000000]               0xffffffbf00000000 - 0xffffffbf01c00000   (    28 MB actual)
    [    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000] 	RCU event tracing is enabled.
    [    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x7b0074340, max_idle_ns: 440795202884 ns
    [    0.000004] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255543ns
    [    0.008225] Console: colour dummy device 80x25
    [    0.012495] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332)
    [    0.022771] pid_max: default: 32768 minimum: 301
    [    0.027468] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.034025] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.041850] ASID allocator initialised with 65536 entries
    [    0.047111] Hierarchical SRCU implementation.
    [    0.051790] zynqmp_plat_init Platform Management API v1.0
    [    0.057002] zynqmp_plat_init Trustzone version v1.0
    [    0.061948] smp: Bringing up secondary CPUs ...
    [    0.066625] Detected VIPT I-cache on CPU1
    [    0.066666] CPU1: Booted secondary processor [410fd034]
    [    0.066970] Detected VIPT I-cache on CPU2
    [    0.066988] CPU2: Booted secondary processor [410fd034]
    [    0.067271] Detected VIPT I-cache on CPU3
    [    0.067289] CPU3: Booted secondary processor [410fd034]
    [    0.067330] smp: Brought up 1 node, 4 CPUs
    [    0.098743] SMP: Total of 4 processors activated.
    [    0.103417] CPU features: detected feature: 32-bit EL0 Support
    [    0.109215] CPU: All CPU(s) started at EL2
    [    0.113288] alternatives: patching kernel code
    [    0.118758] devtmpfs: initialized
    [    0.127252] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.136804] futex hash table entries: 1024 (order: 5, 131072 bytes)
    [    0.149536] pinctrl core: initialized pinctrl subsystem
    [    0.155273] NET: Registered protocol family 16
    [    0.160326] cpuidle: using governor menu
    [    0.164799] vdso: 2 pages (1 code @ ffffff80087c6000, 1 data @ ffffff8008c34000)
    [    0.172003] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.179356] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.215912] ARM CCI_400_r1 PMU driver probed
    [    0.220427] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
    [    0.235152] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
    [    0.247970] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.255505] GPIO IRQ not connected
    [    0.258730] XGpio: /amba_pl@0/gpio@80012000: registered, base is 508, ngpio is 4
    [    0.266356] XGpio: /amba_pl@0/gpio@80013000: registered, base is 506, ngpio is 2
    [    0.273638] xilinx-gpio a0001000.gpio: names 14 do not match number of GPIOs 5
    [    0.280938] GPIO IRQ not connected
    [    0.284153] XGpio: /amba_pl@0/gpio@a0001000: registered, base is 501, ngpio is 5
    [    0.291715] GPIO IRQ not connected
    [    0.294925] XGpio: /amba_pl@0/gpio@a0002000: registered, base is 499, ngpio is 2
    [    0.302459] GPIO IRQ not connected
    [    0.305675] XGpio: /amba_pl@0/gpio@a0005000: registered, base is 497, ngpio is 2
    [    0.313216] GPIO IRQ not connected
    [    0.316427] XGpio: /amba_pl@0/gpio@a0006000: registered, base is 496, ngpio is 1
    [    0.323962] GPIO IRQ not connected
    [    0.327170] XGpio: /amba_pl@0/gpio@a0007000: registered, base is 495, ngpio is 1
    [    0.334763] GPIO IRQ not connected
    [    0.337975] XGpio: /amba_pl@0/xsc_q8_zynq_pa3_bridge_axi@a2000000/pa3_crp@a2000000: registered, base is 486, ngpio is 9
    [    0.348722] GPIO IRQ not connected
    [    0.352199] PLL: shutdown
    [    0.354741] PLL: enable
    [    0.357229] XGpio: setting gpio2-line-names
    [    0.361255] XGpio: /amba_pl@0/xsc_q8_zynq_pa3_bridge_axi@a2000000/pa3_crp@a2000000: dual channel registered, base is 477
    [    0.373332] SCSI subsystem initialized
    [    0.376940] libata version 3.00 loaded.
    [    0.377110] usbcore: registered new interface driver usbfs
    [    0.382430] usbcore: registered new interface driver hub
    [    0.387722] usbcore: registered new device driver usb
    [    0.392767] pps_core: LinuxPPS API ver. 1 registered
    [    0.397623] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.406717] PTP clock support registered
    [    0.410616] EDAC MC: Ver: 3.0.0
    [    0.413878] PLL: shutdown
    [    0.416676] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
    [    0.423464] FPGA manager framework
    [    0.426898] fpga-region fpga-full: FPGA Region probed
    [    0.432510] clocksource: Switched to clocksource arch_sys_counter
    [    0.438514] VFS: Disk quotas dquot_6.6.0
    [    0.442349] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.453716] NET: Registered protocol family 2
    [    0.458258] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
    [    0.465388] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
    [    0.472212] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.478644] UDP hash table entries: 1024 (order: 3, 32768 bytes)
    [    0.484549] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
    [    0.491049] NET: Registered protocol family 1
    [    0.495467] RPC: Registered named UNIX socket transport module.
    [    0.501196] RPC: Registered udp transport module.
    [    0.505862] RPC: Registered tcp transport module.
    [    0.510532] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.516940] PCI: CLS 0 bytes, default 128
    [    0.517952] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    0.525271] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    0.533417] audit: initializing netlink subsys (disabled)
    [    0.538702] audit: type=2000 audit(0.371:1): state=initialized audit_enabled=0 res=1
    [    0.539043] workingset: timestamp_bits=62 max_order=19 bucket_order=0
    [    0.553219] NFS: Registering the id_resolver key type
    [    0.558111] Key type id_resolver registered
    [    0.562234] Key type id_legacy registered
    [    0.566220] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.599351] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    0.606566] io scheduler noop registered
    [    0.610442] io scheduler deadline registered
    [    0.614696] io scheduler cfq registered (default)
    [    0.619351] io scheduler mq-deadline registered
    [    0.623848] io scheduler kyber registered
    [    0.629218] PLL: enable
    [    0.632349] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
    [    0.639284] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
    [    0.646195] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
    [    0.653116] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
    [    0.660031] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
    [    0.666956] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
    [    0.673871] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
    [    0.680797] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
    [    0.687787] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
    [    0.694703] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
    [    0.701623] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
    [    0.708546] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
    [    0.715466] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
    [    0.722386] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
    [    0.729303] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
    [    0.736224] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
    [    0.773416] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    0.782169] 80030000.serial: ttyS2 at MMIO 0x80031000 (irq = 46, base_baud = 6249937) is a 16550A
    [    0.791924] 80040000.serial: ttyS3 at MMIO 0x80041000 (irq = 47, base_baud = 6249937) is a 16550A
    [    0.801339] a0010000.serial: ttyS0 at MMIO 0xa0011000 (irq = 48, base_baud = 6249937) is a 16550A
    [    0.813481] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    0.824233] brd: module loaded
    [    0.831313] loop: module loaded
    [    0.835484] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    0.843928] m25p80 spi0.0: SPI-NOR-UniqueID 104400fa2b94000af6ff1d0049bf644a12
    [    0.851352] m25p80 spi0.0: n25q00a (262144 Kbytes)
    [    0.856003] 18 ofpart partitions found on MTD device spi0.0
    [    0.861492] Creating 18 MTD partitions on "spi0.0":
    [    0.866339] 0x000004000000-0x000004a00000 : "qspi0-gold-fw"
    [    0.872402] 0x000004a20000-0x000008000000 : "qspi0-gold-rootfs"
    [    0.878560] 0x000004a00000-0x000004a20000 : "qspi0-gold-xscinfo"
    [    0.884786] 0x000004000000-0x000008000000 : "qspi0-gold"
    [    0.890320] 0x000000000000-0x000000a00000 : "qspi0-nom-fw"
    [    0.896033] 0x000000a20000-0x000004000000 : "qspi0-nom-rootfs"
    [    0.902075] 0x000000a00000-0x000000a20000 : "qspi0-nom-xscinfo"
    [    0.908223] 0x000000000000-0x000004000000 : "qspi0-nom"
    [    0.913667] 0x000000000000-0x000008000000 : "qspi0"
    [    0.918778] 0x00000c000000-0x00000ca00000 : "qspi1-gold-fw"
    [    0.924585] 0x00000ca20000-0x000010000000 : "qspi1-gold-rootfs"
    [    0.930727] 0x00000ca00000-0x00000ca20000 : "qspi1-gold-xscinfo"
    [    0.936961] 0x00000c000000-0x000010000000 : "qspi1-gold"
    [    0.942482] 0x000008000000-0x000008a00000 : "qspi1-nom-fw"
    [    0.948201] 0x000008a20000-0x00000c000000 : "qspi1-nom-rootfs"
    [    0.954242] 0x000008a00000-0x000008a20000 : "qspi1-nom-xscinfo"
    [    0.960387] 0x000008000000-0x00000c000000 : "qspi1-nom"
    [    0.965841] 0x000008000000-0x000010000000 : "qspi1"
    [    0.972166] libphy: Fixed MDIO Bus: probed
    [    0.977193] tun: Universal TUN/TAP device driver, 1.6
    [    0.982214] CAN device driver interface
    [    0.987833] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    0.994953] libphy: MACB_mii_bus: probed
    [    1.068743] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 26 (00:1b:c5:03:c1:33)
    [    1.078366] Marvell 88E1510 ff0e0000.ethernet-ffffffff:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:01, irq=POLL)
    [    1.093141] usbcore: registered new interface driver asix
    [    1.098400] usbcore: registered new interface driver ax88179_178a
    [    1.104426] usbcore: registered new interface driver cdc_ether
    [    1.110221] usbcore: registered new interface driver net1080
    [    1.115843] usbcore: registered new interface driver cdc_subset
    [    1.121726] usbcore: registered new interface driver zaurus
    [    1.127276] usbcore: registered new interface driver cdc_ncm
    [    1.133175] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    1.140112] usbcore: registered new interface driver uas
    [    1.145265] usbcore: registered new interface driver usb-storage
    [    1.151877] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
    [    1.158977] i2c /dev entries driver
    [    1.164038] rtc-pcf2127-i2c 0-0051: oscillator stop detected, date/time is not reliable
    [    1.171924] rtc-pcf2127-i2c 0-0051: rtc core: registered rtc-pcf2127-i2c as rtc1
    [    1.179222] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 29
    [    1.185736] at24 1-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
    [    1.192178] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 30
    [    1.198278] Driver for 1-wire Dallas network protocol.
    [    1.233771] w1_master_driver w1_bus_master1: Attaching one wire slave 28.000000b54d1f crc 74
    [    1.243399] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT)
    [    1.253634] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    1.266757] sdhci: Secure Digital Host Controller Interface driver
    [    1.272744] sdhci: Copyright(c) Pierre Ossman
    [    1.277067] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.328523] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
    [    1.384517] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
    [    1.398583] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.404566] usbcore: registered new interface driver usbhid
    [    1.409942] usbhid: USB HID core driver
    [    1.417634] ad9361 spi2.0: ad9361_probe : enter (ad9361)
    [    1.423979] mmc0: new HS200 MMC card at address 0001
    [    1.425543] ad9361 spi2.0: ad9361_reset: by GPIO
    [    1.427615] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [    1.427767] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [    1.427901] ad9361 spi2.0: ad9361_clk_mux_get_parent: index 0
    [    1.428004] ad9361 spi2.0: ad9361_clk_mux_get_parent: index 0
    [    1.428117] ad9361 spi2.0: ad9361_setup
    [    1.428120] ad9361 spi2.0: ad9361_auxdac_setup
    [    1.428124] ad9361 spi2.0: ad9361_auxdac_set DAC1 = 0 mV
    [    1.428190] ad9361 spi2.0: ad9361_auxdac_set DAC2 = 0 mV
    [    1.428372] ad9361 spi2.0: ad9361_gpo_setup
    [    1.428589] ad9361 spi2.0: ad9361_set_dcxo_tune : coarse 8 fine 5920
    [    1.428769] ad9361 spi2.0: ad9361_set_trx_clock_chain
    [    1.428775] ad9361 spi2.0: ad9361_set_trx_clock_chain: 983040000 245760000 122880000 61440000 30720000 30720000
    [    1.428780] ad9361 spi2.0: ad9361_set_trx_clock_chain: 983040000 122880000 122880000 61440000 30720000 30720000
    [    1.429003] ad9361 spi2.0: ad9361_bbpll_set_rate: Rate 983040000 Hz Parent Rate 40000000 Hz
    [    1.429007] mmcblk0: mmc0:0001 R1J57L 29.1 GiB
    [    1.429542] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 122880000 Hz Parent Rate 983040000 Hz
    [    1.429605] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 122880000 Hz Parent Rate 122880000 Hz
    [    1.429667] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 61440000 Hz Parent Rate 122880000 Hz
    [    1.429729] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 61440000 Hz
    [    1.429791] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 15360000 Hz Parent Rate 30720000 Hz
    [    1.429852] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 3840000 Hz Parent Rate 15360000 Hz
    [    1.429914] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 61440000 Hz Parent Rate 122880000 Hz
    [    1.429976] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 61440000 Hz
    [    1.430037] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 15360000 Hz Parent Rate 30720000 Hz
    [    1.430098] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 3840000 Hz Parent Rate 15360000 Hz
    [    1.430347] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 245760000 Hz Parent Rate 983040000 Hz
    [    1.430409] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 245760000 Hz Parent Rate 245760000 Hz
    [    1.430470] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 122880000 Hz Parent Rate 245760000 Hz
    [    1.430532] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 61440000 Hz Parent Rate 122880000 Hz
    [    1.430593] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 61440000 Hz
    [    1.430655] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 30720000 Hz
    [    1.430716] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 122880000 Hz Parent Rate 245760000 Hz
    [    1.430777] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 61440000 Hz Parent Rate 122880000 Hz
    [    1.430839] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 61440000 Hz
    [    1.430900] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 30720000 Hz
    [    1.431045] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 122880000 Hz Parent Rate 245760000 Hz
    [    1.431106] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 61440000 Hz Parent Rate 122880000 Hz
    [    1.431168] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 61440000 Hz
    [    1.431229] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 15360000 Hz Parent Rate 30720000 Hz
    [    1.431290] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 15360000 Hz Parent Rate 15360000 Hz
    [    1.431415] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 122880000 Hz Parent Rate 122880000 Hz
    [    1.431476] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 61440000 Hz Parent Rate 122880000 Hz
    [    1.431537] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 61440000 Hz
    [    1.431598] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 30720000 Hz Parent Rate 30720000 Hz
    [    1.432035] ad9361 spi2.0: ad9361_rssi_setup
    [    1.432423] ad9361 spi2.0: ad9361_auxadc_setup
    [    1.432595] ad9361 spi2.0: ad9361_rf_port_setup : INPUT_SELECT 0x3
    [    1.432614] ad9361 spi2.0: ad9361_pp_port_setup
    [    1.432967] ad9361 spi2.0: ad9361_auxadc_setup
    [    1.433058] ad9361 spi2.0: ad9361_ctrl_outs_setup
    [    1.433093] ad9361 spi2.0: ad9361_set_ref_clk_cycles : ref_clk_hz 40000000
    [    1.433214] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 80000000 Hz
    [    1.433267] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 40000000 Hz
    [    1.433388] ad9361 spi2.0: ad9361_rfpll_set_rate: RX Rate 0 Hz Parent Rate 80000000 Hz
    [    1.433394] ad9361 spi2.0: ad9361_fastlock_prepare: RX Profile 0: Un-Prepare
    [    1.433398] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 80000000 Hz
    [    1.433446] mmcblk0boot0: mmc0:0001 R1J57L partition 1 8.00 MiB
    [    1.433453] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 80000000 Hz
    [    1.433507] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 40000000 Hz
    [    1.433568] ad9361 spi2.0: ad9361_rfpll_set_rate: TX Rate 0 Hz Parent Rate 80000000 Hz
    [    1.433572] ad9361 spi2.0: ad9361_fastlock_prepare: TX Profile 0: Un-Prepare
    [    1.433576] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 80000000 Hz
    [    1.433630] ad9361 spi2.0: ad9361_txrx_synth_cp_calib : ref_clk_hz 80000000 : is_tx 0
    [    1.434159] ad9361 spi2.0: ad9361_txrx_synth_cp_calib : ref_clk_hz 80000000 : is_tx 1
    [    1.434652] ad9361 spi2.0: ad9361_rfpll_determine_rate: Rate 1200000000 Hz
    [    1.434656] ad9361 spi2.0: ad9361_rfpll_determine_rate: Rate 1200000000 Hz
    [    1.434663] ad9361 spi2.0: ad9361_rfpll_set_rate: RX Rate 1200000000 Hz Parent Rate 80000000 Hz
    [    1.434667] ad9361 spi2.0: ad9361_fastlock_prepare: RX Profile 0: Un-Prepare
    [    1.434672] ad9361 spi2.0: ad9361_rfpll_vco_init : vco_freq 9600000000 : ref_clk 80000000 : range 2
    [    1.434677] ad9361 spi2.0: ad9361_rfpll_vco_init : freq 9445 MHz : index 12
    [    1.435127] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 80000000 Hz
    [    1.435181] ad9361 spi2.0: ad9361_rx_rfpll_rate_change: rate 2400000000 Hz
    [    1.435185] ad9361 spi2.0: ad9361_load_gt: frequency 2400000000
    [    1.435190] ad9361 spi2.0: ad9361_load_gt: frequency 2400000000 (band 1)
    [    1.439342] mmcblk0boot1: mmc0:0001 R1J57L partition 2 8.00 MiB
    [    1.443247] ad9361 spi2.0: ad9361_rfpll_determine_rate: Rate 1225000000 Hz
    [    1.443251] ad9361 spi2.0: ad9361_rfpll_determine_rate: Rate 1225000000 Hz
    [    1.443257] ad9361 spi2.0: ad9361_rfpll_set_rate: TX Rate 1225000000 Hz Parent Rate 80000000 Hz
    [    1.443260] ad9361 spi2.0: ad9361_fastlock_prepare: TX Profile 0: Un-Prepare
    [    1.443264] ad9361 spi2.0: ad9361_rfpll_vco_init : vco_freq 9800000000 : ref_clk 80000000 : range 2
    [    1.443267] ad9361 spi2.0: ad9361_rfpll_vco_init : freq 9631 MHz : index 11
    [    1.443716] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 80000000 Hz
    [    1.443770] ad9361 spi2.0: ad9361_tx_rfpll_rate_change: rate 2450000000 Hz
    [    1.443775] ad9361 spi2.0: ad9361_load_mixer_gm_subtable
    [    1.445204] mmcblk0rpmb: mmc0:0001 R1J57L partition 3 4.00 MiB
    [    1.445476] ad9361 spi2.0: ad9361_gc_setup
    [    1.447276] ad9361 spi2.0: ad9361_rx_bb_analog_filter_calib : rx_bb_bw 9000000 bbpll_freq 983040000
    [    1.447432] ad9361 spi2.0: ad9361_run_calibration: CAL Mask 0x80
    [    1.447488] ad9361 spi2.0: ad9361_tx_bb_analog_filter_calib : tx_bb_bw 9000000 bbpll_freq 983040000
    [    1.447571] ad9361 spi2.0: ad9361_run_calibration: CAL Mask 0x40
    [    1.447674] ad9361 spi2.0: ad9361_rx_tia_calib : bb_bw_Hz 9000000
    [    1.447752] ad9361 spi2.0: ad9361_tx_bb_second_filter_calib : tx_bb_bw 9000000
    [    1.448070] ad9361 spi2.0: ad9361_rx_adc_setup : BBBW 8606895 : ADCfreq 245760000
    [    1.448075] ad9361 spi2.0: c3_msb 0x0 : c3_lsb 0x36 : r2346 0x1 :
    [    1.448081] ad9361 spi2.0: invrc_tconst_1e6 942136, sqrt_inv_rc_tconst_1e3 970
    [    1.448084] ad9361 spi2.0: scaled_adc_clk_1e6 384000, inv_scaled_adc_clk_1e3 2604
    [    1.448088] ad9361 spi2.0: tmp_1e3 1000, sqrt_term_1e3 619, min_sqrt_term_1e3 1000
    [    1.448689] ad9361 spi2.0: ad9361_bb_dc_offset_calib
    [    1.448752] ad9361 spi2.0: ad9361_run_calibration: CAL Mask 0x1
    [    1.452839]  mmcblk0: p1
    [    1.462276] ad9361 spi2.0: ad9361_rf_dc_offset_calib : rx_freq 2400000000
    [    1.462383] ad9361 spi2.0: ad9361_run_calibration: CAL Mask 0x2
    [    1.502626] mmc1: new HS200 MMC card at address 0001
    [    1.507600] mmcblk1: mmc1:0001 R1J57L 29.1 GiB
    [    1.512039] mmcblk1boot0: mmc1:0001 R1J57L partition 1 8.00 MiB
    [    1.517914] mmcblk1boot1: mmc1:0001 R1J57L partition 2 8.00 MiB
    [    1.523789] mmcblk1rpmb: mmc1:0001 R1J57L partition 3 4.00 MiB
    [    1.530270]  mmcblk1: p1
    [    1.633112] ad9361 spi2.0: ad9361_tx_quad_calib : bw_tx 9000000 clkrf 30720000 clktf 30720000
    [    1.633117] ad9361 spi2.0: Tx NCO frequency: 1920000 (BW/4: 2250000) txnco_word 1
    [    1.633360] ad9361 spi2.0: ad9361_run_calibration: CAL Mask 0x10
    [    1.639548] ad9361 spi2.0: LO leakage: 1 Quadrature Calibration: 1 : rx_phase 26
    [    1.639554] ad9361 spi2.0: ad9361_tracking_control : bbdc_track=1, rfdc_track=1, rxquad_track=1
    [    1.639662] ad9361 spi2.0: ad9361_pp_port_setup
    [    1.639772] ad9361 spi2.0: ad9361_set_tx_atten : attenuation 10000 mdB tx1=1 tx2=1
    [    1.639883] ad9361 spi2.0: ad9361_rssi_setup
    [    1.640093] ad9361 spi2.0: ad9361_txmon_setup
    [    1.640268] ad9361 spi2.0: Device is in 5 state, moving to a
    [    1.641451] ad9361 spi2.0: ad9361_probe : AD936x Rev 2 successfully initialized
    [    1.665788] cf_axi_dds 99024000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.00.b) at 0x99024000 mapped to 0xffffff8008ff5000, probed DDS AD9361
    [    1.680698] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    1.687215] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    1.694784] Netfilter messages via NETLINK v0.30.
    [    1.699437] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.704707] Initializing XFRM netlink socket
    [    1.708888] NET: Registered protocol family 10
    [    1.713731] Segment Routing with IPv6
    [    1.717259] ip6_tables: (C) 2000-2006 Netfilter Core Team
    [    1.722689] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.728827] NET: Registered protocol family 17
    [    1.733094] NET: Registered protocol family 15
    [    1.737509] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    1.750384] Ebtables v2.0 registered
    [    1.754020] can: controller area network core (rev 20170425 abi 9)
    [    1.760106] NET: Registered protocol family 29
    [    1.764511] can: raw protocol (rev 20170425)
    [    1.768721] can: broadcast manager protocol (rev 20170425 t)
    [    1.774347] can: netlink gateway (rev 20170425) max_hops=1
    [    1.779935] 9pnet: Installing 9P2000 support
    [    1.784050] Key type dns_resolver registered
    [    1.789030] registered taskstats version 1
    [    1.800840] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 38, base_baud = 6249999) is a xuartps
    [    1.809786] console [ttyPS0] enabled
    [    1.816748] bootconsole [cdns0] disabled
    [    1.825405] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 39, base_baud = 6249999) is a xuartps
    [    1.836855] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
    [    1.846834] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.852251] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.860098] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
    [    1.868743] xhci-hcd xhci-hcd.0.auto: irq 56, io mem 0xfe200000
    [    1.874739] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    1.881446] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.888646] usb usb1: Product: xHCI Host Controller
    [    1.893506] usb usb1: Manufacturer: Linux 4.14.0 xhci-hcd
    [    1.898887] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    1.904068] hub 1-0:1.0: USB hub found
    [    1.907755] hub 1-0:1.0: 1 port detected
    [    1.911826] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.917238] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    1.924929] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    1.933011] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [    1.939712] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.946915] usb usb2: Product: xHCI Host Controller
    [    1.951775] usb usb2: Manufacturer: Linux 4.14.0 xhci-hcd
    [    1.957156] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    1.962259] hub 2-0:1.0: USB hub found
    [    1.965940] hub 2-0:1.0: 1 port detected
    [    1.992022] ad9361 spi2.0: ad9361_set_tx_atten : attenuation 89750 mdB tx1=1 tx2=1
    [    1.992195] ad9361 spi2.0: ad9361_bist_loopback: mode 0
    [    1.992249] ad9361 spi2.0: ad9361_bist_prbs: mode 2
    [    1.992277] ad9361 spi2.0: ad9361_calculate_rf_clock_chain: requested rate 25000000 TXFIR int 1 RXFIR dec 1 mode Nominal
    [    1.992283] ad9361 spi2.0: ad9361_set_trx_clock_chain
    [    1.992288] ad9361 spi2.0: ad9361_set_trx_clock_chain: 800000000 200000000 100000000 50000000 25000000 25000000
    [    1.992293] ad9361 spi2.0: ad9361_set_trx_clock_chain: 800000000 200000000 100000000 50000000 25000000 25000000
    [    1.992587] ad9361 spi2.0: ad9361_bbpll_set_rate: Rate 800000000 Hz Parent Rate 40000000 Hz
    [    1.993201] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 200000000 Hz Parent Rate 800000000 Hz
    [    1.993278] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 100000000 Hz Parent Rate 200000000 Hz
    [    1.993353] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 100000000 Hz Parent Rate 100000000 Hz
    [    1.993429] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 50000000 Hz Parent Rate 100000000 Hz
    [    1.993506] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 25000000 Hz Parent Rate 50000000 Hz
    [    1.993581] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 25000000 Hz Parent Rate 25000000 Hz
    [    2.003665] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 100000000 Hz Parent Rate 200000000 Hz
    [    2.003736] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 50000000 Hz Parent Rate 100000000 Hz
    [    2.003805] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 25000000 Hz Parent Rate 50000000 Hz
    [    2.003874] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 25000000 Hz Parent Rate 25000000 Hz
    [    2.004035] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 200000000 Hz Parent Rate 200000000 Hz
    [    2.004104] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 200000000 Hz Parent Rate 200000000 Hz
    [    2.004172] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 100000000 Hz Parent Rate 200000000 Hz
    [    2.004240] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 50000000 Hz Parent Rate 100000000 Hz
    [    2.004308] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 50000000 Hz Parent Rate 50000000 Hz
    [    2.014498] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 100000000 Hz Parent Rate 200000000 Hz
    [    2.014574] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 50000000 Hz Parent Rate 100000000 Hz
    [    2.014649] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 25000000 Hz Parent Rate 50000000 Hz
    [    2.014723] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 25000000 Hz Parent Rate 25000000 Hz
    [    2.025273] ad9361 spi2.0: ad9361_rssi_setup
    [    2.025754] ad9361 spi2.0: ad9361_auxadc_setup
    [    2.025897] ad9361 spi2.0: Device is in f state, forcing to 5
    [    2.026011] ad9361 spi2.0: Device is in f state, forcing to a
    [    2.090491] ad9361 spi2.0: Device is in 0 state, forcing to 5
    [    2.090603] ad9361 spi2.0: Device is in 0 state, forcing to a
    [    2.155233] ad9361 spi2.0: ad9361_calculate_rf_clock_chain: requested rate 40000000 TXFIR int 1 RXFIR dec 1 mode Nominal
    [    2.155237] ad9361 spi2.0: ad9361_set_trx_clock_chain
    [    2.155242] ad9361 spi2.0: ad9361_set_trx_clock_chain: 1280000000 320000000 160000000 80000000 40000000 40000000
    [    2.155247] ad9361 spi2.0: ad9361_set_trx_clock_chain: 1280000000 320000000 160000000 80000000 40000000 40000000
    [    2.155509] ad9361 spi2.0: ad9361_bbpll_set_rate: Rate 1280000000 Hz Parent Rate 40000000 Hz
    [    2.162024] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 10521254882 Hz
    [    2.162056] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 82197303 Hz
    [    2.162132] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 41098651 Hz
    [    2.162164] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 10274662 Hz
    [    2.162195] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 5137331 Hz
    [    2.162226] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 2568665 Hz
    [    2.162258] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 82197303 Hz
    [    2.162333] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 20549325 Hz
    [    2.162364] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 10274662 Hz
    [    2.162395] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 40000000 Hz Parent Rate 5137331 Hz
    [    2.162655] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 318825905 Hz Parent Rate 10521254882 Hz
    [    2.162731] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 159412952 Hz Parent Rate 82197303 Hz
    [    2.162762] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 39853238 Hz Parent Rate 41098651 Hz
    [    2.162837] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 19926619 Hz Parent Rate 10274662 Hz
    [    2.162869] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 9963309 Hz Parent Rate 5137331 Hz
    [    2.162900] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 2490827 Hz Parent Rate 2568665 Hz
    [    2.162974] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 79706476 Hz Parent Rate 82197303 Hz
    [    2.163050] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 39853238 Hz Parent Rate 20549325 Hz
    [    2.163081] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 19926619 Hz Parent Rate 10274662 Hz
    [    2.163112] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 4981654 Hz Parent Rate 5137331 Hz
    [    2.163188] ad9361 spi2.0: Failed to set BB ref clock rate (-22)
    [    2.169141] ad9361 spi2.0: Device is in 0 state, forcing to 5
    [    2.169253] ad9361 spi2.0: Device is in 0 state, forcing to a
    [    2.233697] ad9361 spi2.0: Device is in f state, forcing to 5
    [    2.233809] ad9361 spi2.0: Device is in f state, forcing to a
    [    2.253981] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    2.304705] ad9361 spi2.0: ad9361_calculate_rf_clock_chain: requested rate 61440000 TXFIR int 1 RXFIR dec 1 mode Nominal
    [    2.304709] ad9361 spi2.0: ad9361_set_trx_clock_chain
    [    2.304714] ad9361 spi2.0: ad9361_set_trx_clock_chain: 983040000 491520000 245760000 122880000 61440000 61440000
    [    2.304719] ad9361 spi2.0: ad9361_set_trx_clock_chain: 983040000 245760000 122880000 61440000 61440000 61440000
    [    2.304982] ad9361 spi2.0: ad9361_bbpll_set_rate: Rate 983040000 Hz Parent Rate 40000000 Hz
    [    2.305290] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 7680000 Hz Parent Rate 10521254882 Hz
    [    2.305366] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 3840000 Hz Parent Rate 82197303 Hz
    [    2.305398] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 960000 Hz Parent Rate 41098651 Hz
    [    2.305429] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 480000 Hz Parent Rate 10274662 Hz
    [    2.305460] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 240000 Hz Parent Rate 5137331 Hz
    [    2.305491] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 60000 Hz Parent Rate 2568665 Hz
    [    2.305523] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 1920000 Hz Parent Rate 82197303 Hz
    [    2.305554] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 960000 Hz Parent Rate 20549325 Hz
    [    2.305586] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 480000 Hz Parent Rate 10274662 Hz
    [    2.305617] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 120000 Hz Parent Rate 5137331 Hz
    [    2.305877] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 10521254882 Hz
    [    2.305953] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 10521254882 Hz
    [    2.305984] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 10521254882 Hz
    [    2.306015] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 10521254882 Hz
    [    2.306046] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 10521254882 Hz
    [    2.306078] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 10521254882 Hz
    [    2.316117] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 10521254882 Hz
    [    2.316150] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 2630313720 Hz
    [    2.316182] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 1315156860 Hz
    [    2.316213] ad9361 spi2.0: ad9361_clk_factor_set_rate: Rate 501012137 Hz Parent Rate 657578430 Hz
    [    2.316290] ad9361 spi2.0: Failed to set BB ref clock rate (-22)
    [    2.322235] ad9361 spi2.0: Device is in 0 state, forcing to 5
    [    2.322337] ad9361 spi2.0: Device is in 0 state, forcing to a
    [    2.386774] ad9361 spi2.0: Device is in 0 state, forcing to 5
    [    2.386878] ad9361 spi2.0: Device is in 0 state, forcing to a
    [    2.451381] SAMPL CLK: 657578430 tuning: RX
    [    2.455492]   0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
    [    2.459907] 0:# # # # # # # # # # # # # # # #
    [    2.464333] 1:# # # # # # # # # # # # # # # #
    [    2.468762] ad9361 spi2.0: ad9361_dig_tune_delay: Tuning RX FAILED!
    [    2.475012] ad9361 spi2.0: ad9361_bist_loopback: mode 0
    [    2.475106] usb 1-1: New USB device found, idVendor=13b1, idProduct=0041
    [    2.481725] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
    [    2.488839] usb 1-1: Product: Linksys USB3GIGV1
    [    2.493352] usb 1-1: Manufacturer: Linksys
    [    2.497432] usb 1-1: SerialNumber: 000001000000
    [    2.502071] ad9361 spi2.0: Device is in f state, forcing to 5
    [    2.502306] ad9361 spi2.0: ad9361_set_tx_atten : attenuation 10000 mdB tx1=1 tx2=1
    [    2.502468] cf_axi_adc: probe of 99020000.cf-ad9361-lpc failed with error -5
    [    2.510574] ubi0: attaching mtd5
    [    2.518867] cdc_ether 1-1:2.0 eth1: register 'cdc_ether' at usb-xhci-hcd.0.auto-1, CDC Ethernet Device, 58:ef:68:b5:34:29
    [    2.730137] random: crng init done
    [    2.856209] ubi0: scanning is finished
    [    2.865312] ubi0: attached mtd5 (name "qspi0-nom-rootfs", size 53 MiB)
    [    2.871755] ubi0: PEB size: 65536 bytes (64 KiB), LEB size: 65408 bytes
    [    2.878348] ubi0: min./max. I/O unit sizes: 1/256, sub-page size 1
    [    2.884511] ubi0: VID header offset: 64 (aligned 64), data offset: 128
    [    2.891020] ubi0: good PEBs: 862, bad PEBs: 0, corrupted PEBs: 0
    [    2.897010] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
    [    2.904215] ubi0: max/mean erase counter: 16/10, WL threshold: 4096, image sequence number: 1108712413
    [    2.913502] ubi0: available PEBs: 0, total reserved PEBs: 862, PEBs reserved for bad PEB handling: 0
    [    2.922681] ubi0: background thread "ubi_bgt0d" started, PID 1754
    [    2.928697] rtc_zynqmp ffa60000.rtc: setting system clock to 2103-10-23 18:12:02 UTC (4222606322)
    [    2.937688] clk: Not disabling unused clocks
    [    2.943366] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 1757
    [    3.107083] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "q8-reva-rootfs"
    [    3.115093] UBIFS (ubi0:0): LEB size: 65408 bytes (63 KiB), min./max. I/O unit sizes: 8 bytes/256 bytes
    [    3.124464] UBIFS (ubi0:0): FS size: 54027008 bytes (51 MiB, 826 LEBs), journal size 8650240 bytes (8 MiB, 133 LEBs)
    [    3.134964] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
    [    3.140783] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID 3F4F8761-6F49-44C9-86BE-43C8F10D9AF8, big LPT model
    [    3.223485] VFS: Mounted root (ubifs filesystem) on device 0:15.
    [    3.230025] devtmpfs: mounted
    [    3.233070] Freeing unused kernel memory: 384K
    [    3.498252] systemd[1]: systemd 237 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    3.520560] systemd[1]: Detected architecture arm64.
    [    3.546124] systemd[1]: No hostname configured.
    [    3.550592] systemd[1]: Set hostname to <localhost>.
    [    3.723309] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
    [    3.740275] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
    [    3.857558] systemd[1]: Reached target Swap.
    [    3.872638] systemd[1]: Reached target Paths.
    [    3.889777] systemd[1]: Created slice User and Session Slice.
    [    3.904580] systemd[1]: Reached target Remote File Systems.
    [    4.068072] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" stops
    [    4.582283] systemd-journald[1778]: Received request to flush runtime journal from PID 1
    [    6.119852] cdc_ether 1-1:2.0 eth1: kevent 12 may have been dropped
    [    6.131908] pps pps0: new PPS source ptp0
    [    6.135928] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [    6.142597] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    6.150865] cdc_ether 1-1:2.0 eth1: kevent 12 may have been dropped
    [  832.678426] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
    [  832.678486] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
    [  832.678561] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [  832.678615] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [  832.680202] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
    [  832.680254] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
    [  832.680325] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [  832.680377] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [  832.682092] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
    [  832.682143] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
    [  832.682213] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [  832.682264] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [  832.684113] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
    [  832.684180] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
    [  832.684263] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    [  832.684320] ad9361 spi2.0: ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
    here is our devicetree (the axi_ad9361 core was moved to the same base address as the reference project: 0x99020000):
    /dts-v1/;
    	#address-cells = < 0x02 >;
    	#size-cells = < 0x02 >;
    	compatible = "xiphos,q8", "xlnx,zynqmp";
    	model = "Xiphos Q8 RevA";
    	aliases {
    		ethernet0 = "/amba/ethernet@ff0e0000";
    		i2c0 = "/amba/i2c@ff020000";
    		i2c1 = "/amba/i2c@ff030000";
    		serial0 = "/amba/serial@ff000000";
    		serial1 = "/amba/serial@ff010000";
    		serial2 = "/amba_pl@0/serial@80030000";
    		serial3 = "/amba_pl@0/serial@80040000";
    		serial4 = "/amba_pl@0/serial@a0010000";
    		spi0 = "/amba/spi@ff0f0000";
    		spi1 = "/amba/spi@ff040000";
    		spi2 = "/amba/spi@ff050000";
    	amba: amba {
    		compatible = "simple-bus";
    		ranges;
    		u-boot,dm-pre-reloc;
    		sata: ahci@fd0c0000 {
    			#stream-id-cells = < 0x04 >;
    			clocks = < 0x03 0x16 >;
    			compatible = "ceva,ahci-1v84";
    			interrupt-parent = < 0x04 >;
    			interrupts = < 0x00 0x85 0x04 >;
    			iommus = < 0x09 0x4c0 >, < 0x09 0x4c1 >, < 0x09 0x4c2 >, < 0x09 0x4c3 >;
    			power-domains = < 0x1d >;
    			reg = < 0x00 0xfd0c0000 0x00 0x2000 >;
    			status = "disabled";
    		xilinx_ams: ams@ffa50000 {
    			#io-channel-cells = < 0x01 >;
    			clocks = < 0x03 0x46 >;
    			compatible = "xlnx,zynqmp-ams";
    			interrupt-names = "ams-irq";
    			interrupts = < 0x00 0x38 0x04 >;
    			phandle = < 0x3e >;
    			ranges;
    			reg = < 0x00 0xffa50000 0x00 0x800 >;
    			reg-names = "ams-base";
    			status = "okay";
    			ams_pl: ams_pl@ffa50c00 {
    				compatible = "xlnx,zynqmp-ams-pl";
    				reg = < 0x00 0xffa50c00 0x00 0x400 >;
    				status = "okay";
    			ams_ps: ams_ps@ffa50800 {
    				compatible = "xlnx,zynqmp-ams-ps";
    				reg = < 0x00 0xffa50800 0x00 0x400 >;
    				status = "okay";
    		can0: can@ff060000 {
    			clock-names = "can_clk", "pclk";
    			clocks = < 0x03 0x3f >, < 0x03 0x1f >;
    			compatible = "xlnx,zynq-can-1.0";
    			interrupts = < 0x00 0x17 0x04 >;
    			power-domains = < 0x07 >;
    			reg = < 0x00 0xff060000 0x00 0x1000 >;
    			rx-fifo-depth = < 0x40 >;
    			status = "okay";
    			tx-fifo-depth = < 0x40 >;
    		can1: can@ff070000 {
    			clocks = < 0x03 0x40 >, < 0x03 0x1f >;
    			interrupts = < 0x00 0x18 0x04 >;
    			power-domains = < 0x08 >;
    			reg = < 0x00 0xff070000 0x00 0x1000 >;
    			status = "okay";
    		cci: cci@fd6e0000 {
    			#address-cells = < 0x01 >;
    			#size-cells = < 0x01 >;
    			compatible = "arm,cci-400";
    			ranges = < 0x00 0x00 0xfd6e0000 0x10000 >;
    			reg = < 0x00 0xfd6e0000 0x00 0x9000 >;
    			pmu@9000 {
    				compatible = "arm,cci-400-pmu,r1";
    				interrupts = < 0x00 0x7b 0x04 >, < 0x00 0x7b 0x04 >, < 0x00 0x7b 0x04 >, < 0x00 0x7b 0x04 >, < 0x00 0x7b 0x04 >;
    				reg = < 0x9000 0x5000 >;
    		xlnx_dpdma: dma@fd4c0000 {
    			#dma-cells = < 0x01 >;
    			clock-names = "axi_clk";
    			clocks = < 0x03 0x14 >;
    			compatible = "xlnx,dpdma";
    			dma-channels = < 0x06 >;
    			interrupts = < 0x00 0x7a 0x04 >;
    			phandle = < 0x31 >;
    			power-domains = < 0x2f >;
    			reg = < 0x00 0xfd4c0000 0x00 0x1000 >;
    			dma-audio0channel {
    				compatible = "xlnx,audio0";
    			dma-audio1channel {
    				compatible = "xlnx,audio1";
    			dma-graphicschannel {
    				compatible = "xlnx,graphics";
    			dma-video0channel {
    				compatible = "xlnx,video0";
    			dma-video1channel {
    				compatible = "xlnx,video1";
    			dma-video2channel {
    				compatible = "xlnx,video2";
    		fpd_dma_chan1: dma@fd500000 {
    			#stream-id-cells = < 0x01 >;
    			clock-names = "clk_main", "clk_apb";
    			clocks = < 0x03 0x13 >, < 0x03 0x1f >;
    			compatible = "xlnx,zynqmp-dma-1.0";
    			interrupts = < 0x00 0x7c 0x04 >;
    			iommus = < 0x09 0x14e8 >;
    			power-domains = < 0x0a >;
    			reg = < 0x00 0xfd500000 0x00 0x1000 >;
    			status = "okay";
    			xlnx,bus-width = < 0x80 >;
    		fpd_dma_chan2: dma@fd510000 {
    			interrupts = < 0x00 0x7d 0x04 >;
    			iommus = < 0x09 0x14e9 >;
    			reg = < 0x00 0xfd510000 0x00 0x1000 >;
    			status = "okay";
    		fpd_dma_chan3: dma@fd520000 {
    			interrupts = < 0x00 0x7e 0x04 >;
    			iommus = < 0x09 0x14ea >;
    			reg = < 0x00 0xfd520000 0x00 0x1000 >;
    			status = "okay";
    		fpd_dma_chan4: dma@fd530000 {
    			interrupts = < 0x00 0x7f 0x04 >;
    			iommus = < 0x09 0x14eb >;
    			reg = < 0x00 0xfd530000 0x00 0x1000 >;
    			status = "okay";
    		fpd_dma_chan5: dma@fd540000 {
    			interrupts = < 0x00 0x80 0x04 >;
    			iommus = < 0x09 0x14ec >;
    			reg = < 0x00 0xfd540000 0x00 0x1000 >;
    			status = "okay";
    		fpd_dma_chan6: dma@fd550000 {
    			interrupts = < 0x00 0x81 0x04 >;
    			iommus = < 0x09 0x14ed >;
    			reg = < 0x00 0xfd550000 0x00 0x1000 >;
    			status = "okay";
    		fpd_dma_chan7: dma@fd560000 {
    			interrupts = < 0x00 0x82 0x04 >;
    			iommus = < 0x09 0x14ee >;
    			reg = < 0x00 0xfd560000 0x00 0x1000 >;
    			status = "okay";
    		fpd_dma_chan8: dma@fd570000 {
    			interrupts = < 0x00 0x83 0x04 >;
    			iommus = < 0x09 0x14ef >;
    			reg = < 0x00 0xfd570000 0x00 0x1000 >;
    			status = "okay";
    		lpd_dma_chan1: dma@ffa80000 {
    			clocks = < 0x03 0x44 >, < 0x03 0x1f >;
    			interrupts = < 0x00 0x4d 0x04 >;
    			power-domains = < 0x0c >;
    			reg = < 0x00 0xffa80000 0x00 0x1000 >;
    			status = "okay";
    			xlnx,bus-width = < 0x40 >;
    		lpd_dma_chan2: dma@ffa90000 {
    			interrupts = < 0x00 0x4e 0x04 >;
    			reg = < 0x00 0xffa90000 0x00 0x1000 >;
    			status = "okay";
    		lpd_dma_chan3: dma@ffaa0000 {
    			interrupts = < 0x00 0x4f 0x04 >;
    			reg = < 0x00 0xffaa0000 0x00 0x1000 >;
    			status = "okay";
    		lpd_dma_chan4: dma@ffab0000 {
    			interrupts = < 0x00 0x50 0x04 >;
    			reg = < 0x00 0xffab0000 0x00 0x1000 >;
    			status = "okay";
    		lpd_dma_chan5: dma@ffac0000 {
    			interrupts = < 0x00 0x51 0x04 >;
    			reg = < 0x00 0xffac0000 0x00 0x1000 >;
    			status = "okay";
    		lpd_dma_chan6: dma@ffad0000 {
    			interrupts = < 0x00 0x52 0x04 >;
    			reg = < 0x00 0xffad0000 0x00 0x1000 >;
    			status = "okay";
    		lpd_dma_chan7: dma@ffae0000 {
    			interrupts = < 0x00 0x53 0x04 >;
    			reg = < 0x00 0xffae0000 0x00 0x1000 >;
    			status = "okay";
    		lpd_dma_chan8: dma@ffaf0000 {
    			interrupts = < 0x00 0x54 0x04 >;
    			reg = < 0x00 0xffaf0000 0x00 0x1000 >;
    			status = "okay";
    		gem0: ethernet@ff0b0000 {
    			#size-cells = < 0x00 >;
    			clock-names = "pclk", "hclk", "tx_clk", "rx_clk", "tsu_clk";
    			clocks = < 0x03 0x1f >, < 0x03 0x31 >, < 0x03 0x2d >, < 0x03 0x31 >, < 0x03 0x2c >;
    			compatible = "cdns,zynqmp-gem", "cdns,gem";
    			interrupts = < 0x00 0x39 0x04 >, < 0x00 0x39 0x04 >;
    			iommus = < 0x09 0x874 >;
    			power-domains = < 0x0e >;
    			reg = < 0x00 0xff0b0000 0x00 0x1000 >;
    		gem1: ethernet@ff0c0000 {
    			clocks = < 0x03 0x1f >, < 0x03 0x32 >, < 0x03 0x2e >, < 0x03 0x32 >, < 0x03 0x2c >;
    			interrupts = < 0x00 0x3b 0x04 >, < 0x00 0x3b 0x04 >;
    			iommus = < 0x09 0x875 >;
    			power-domains = < 0x0f >;
    			reg = < 0x00 0xff0c0000 0x00 0x1000 >;
    		gem2: ethernet@ff0d0000 {
    			clocks = < 0x03 0x1f >, < 0x03 0x33 >, < 0x03 0x2f >, < 0x03 0x33 >, < 0x03 0x2c >;
    			interrupts = < 0x00 0x3d 0x04 >, < 0x00 0x3d 0x04 >;
    			iommus = < 0x09 0x876 >;
    			power-domains = < 0x10 >;
    			reg = < 0x00 0xff0d0000 0x00 0x1000 >;
    		gem3: ethernet@ff0e0000 {
    			clocks = < 0x03 0x1f >, < 0x03 0x34 >, < 0x03 0x30 >, < 0x03 0x34 >, < 0x03 0x2c >;
    			interrupts = < 0x00 0x3f 0x04 >, < 0x00 0x3f 0x04 >;
    			iommus = < 0x09 0x877 >;
    			phy-handle = < 0x12 >;
    			phy-mode = "rgmii-id";
    			power-domains = < 0x11 >;
    			reg = < 0x00 0xff0e0000 0x00 0x1000 >;
    			status = "okay";
    			xlnx,ptp-enet-clock = < 0x00 >;
    			phy1: phy@1 {
    				phandle = < 0x12 >;
    				reg = < 0x01 >;
    				reset-gpios = < 0x13 0x2c 0x01 >;
    		gpio: gpio@ff0a0000 {
    			#gpio-cells = < 0x02 >;
    			#interrupt-cells = < 0x02 >;
    			clocks = < 0x03 0x1f >;
    			compatible = "xlnx,zynqmp-gpio-1.0";
    			emio-gpio-width = < 0x20 >;
    			gpio-controller;
    			gpio-line-names = "MIO0", "MIO1", "MIO2", "MIO3", "MIO4", "MIO5", "MIO6", "MIO7", "MIO8", "MIO9", "MIO10", "MIO11", "ps_pa3_done", "MIO13", "MIO14", "MIO15", "MIO16", "MIO17", "MIO18", "MIO19", "MIO20", "MIO21", "MIO22", "ps_emmc0_rst_n", "MIO24", "MIO25", "MIO26", "MIO27", "MIO28", "MIO29", "MIO30", "MIO31", "MIO32", "MIO33", "MIO34", "MIO35", "MIO36", "MIO37", "ps_pa3_misc1", "MIO39", "MIO40", "MIO41", "MIO42", "ps_emmc1_rst_n", "ps_eth_rst_n", "ps_usb2_rst_n", "MIO46", "MIO47", "MIO48", "MIO49", "MIO50", "MIO51", "MIO26", "MIO27", "MIO28", "MIO29", "MIO30", "MIO31", "MIO32", "MIO33", "MIO34", "MIO35", "MIO36", "MIO37", "MIO38", "MIO39", "MIO40", "MIO41", "MIO42", "MIO43", "MIO44", "MIO45", "MIO46", "MIO47", "MIO48", "MIO49", "MIO50", "MIO51", "EMIO0", "EMIO1", "EMIO2", "EMIO3", "EMIO4", "EMIO5", "EMIO6", "EMIO7", "EMIO8", "EMIO9", "EMIO10", "EMIO11", "EMIO12", "EMIO13", "EMIO14", "EMIO15", "EMIO16", "EMIO17", "EMIO18", "EMIO19", "EMIO20", "EMIO21", "EMIO22", "EMIO23", "EMIO24", "EMIO25", "EMIO26", "EMIO27", "EMIO28", "EMIO29", "EMIO30", "EMIO31", "EMIO32", "EMIO33", "EMIO34", "EMIO35", "EMIO36", "EMIO37", "EMIO38", "EMIO39", "EMIO40", "EMIO41", "EMIO42", "EMIO43", "EMIO44", "EMIO45", "EMIO46", "EMIO47", "EMIO48", "EMIO49", "EMIO50", "EMIO51", "EMIO52", "EMIO53", "EMIO54", "EMIO55", "EMIO56", "EMIO57", "EMIO58", "EMIO59", "EMIO60", "EMIO61", "EMIO62", "EMIO63", "EMIO64", "EMIO65", "EMIO66", "EMIO67", "EMIO68", "EMIO69", "EMIO70", "EMIO71", "EMIO72", "EMIO73", "EMIO74", "EMIO75", "EMIO76", "EMIO77", "EMIO78", "EMIO79", "EMIO80", "EMIO81", "EMIO82", "EMIO83", "EMIO84", "EMIO85", "EMIO86", "EMIO87", "EMIO88", "EMIO89", "EMIO90", "EMIO91", "EMIO92", "EMIO93", "EMIO94", "EMIO95";
    			gpio-mask-high = < 0x00 >;
    			gpio-mask-low = < 0x5600 >;
    			interrupt-controller;
    			interrupts = < 0x00 0x10 0x04 >;
    			phandle = < 0x13 >;
    			power-domains = < 0x14 >;
    			reg = < 0x00 0xff0a0000 0x00 0x1000 >;
    			status = "okay";
    		gpu: gpu@fd4b0000 {
    			clock-names = "gpu", "gpu_pp0", "gpu_pp1";
    			clocks = < 0x03 0x18 >, < 0x03 0x19 >, < 0x03 0x1a >;
    			compatible = "arm,mali-400", "arm,mali-utgard";
    			interrupt-names = "IRQGP", "IRQGPMMU", "IRQPP0", "IRQPPMMU0", "IRQPP1", "IRQPPMMU1";
    			interrupts = < 0x00 0x84 0x04 >, < 0x00 0x84 0x04 >, < 0x00 0x84 0x04 >, < 0x00 0x84 0x04 >, < 0x00 0x84 0x04 >, < 0x00 0x84 0x04 >;
    			power-domains = < 0x0b >;
    			reg = < 0x00 0xfd4b0000 0x00 0x10000 >;
    			status = "okay";
    		i2c0: i2c@ff020000 {
    			clock-frequency = < 0x61a80 >;
    			clocks = < 0x03 0x3d >;
    			compatible = "cdns,i2c-r1p14", "cdns,i2c-r1p10";
    			interrupts = < 0x00 0x11 0x04 >;
    			power-domains = < 0x15 >;
    			reg = < 0x00 0xff020000 0x00 0x1000 >;
    			status = "okay";
    			adc0: adc@48 {
    				compatible = "ti,ads1015";
    				phandle = < 0x3f >;
    				reg = < 0x48 >;
    				adc0_channel0@0 {
    					reg = < 0x04 >;
    					ti,datarate = < 0x04 >;
    					ti,gain = < 0x02 >;
    				adc0_channel1@1 {
    					reg = < 0x05 >;
    					ti,gain = < 0x02 >;
    				adc0_channel2@2 {
    					reg = < 0x06 >;
    					ti,gain = < 0x02 >;
    				adc0_channel3@3 {
    					reg = < 0x07 >;
    					ti,gain = < 0x02 >;
    			adc1: adc@49 {
    				phandle = < 0x40 >;
    				reg = < 0x49 >;
    				adc1_channel0@0 {
    					reg = < 0x04 >;
    					ti,gain = < 0x02 >;
    				adc1_channel1@1 {
    					reg = < 0x05 >;
    					ti,gain = < 0x02 >;
    				adc1_channel2@2 {
    					reg = < 0x06 >;
    					ti,gain = < 0x02 >;
    				adc1_channel3@3 {
    					reg = < 0x07 >;
    					ti,gain = < 0x02 >;
    			adc2: adc@4b {
    				phandle = < 0x41 >;
    				reg = < 0x4b >;
    				adc2_channel0@0 {
    					reg = < 0x04 >;
    					ti,gain = < 0x02 >;
    				adc2_channel1@1 {
    					reg = < 0x05 >;
    					ti,gain = < 0x02 >;
    				adc2_channel2@2 {
    					reg = < 0x06 >;
    					ti,gain = < 0x02 >;
    				adc2_channel3@3 {
    					reg = < 0x07 >;
    					ti,gain = < 0x02 >;
    			w1_bridge: ds2482@18 {
    				compatible = "maxim,ds2482";
    				reg = < 0x18 >;
    			rtc0: rtc@51 {
    				compatible = "nxp,pca2129";
    				reg = < 0x51 >;
    		i2c1: i2c@ff030000 {
    			clocks = < 0x03 0x3e >;
    			interrupts = < 0x00 0x12 0x04 >;
    			power-domains = < 0x16 >;
    			reg = < 0x00 0xff030000 0x00 0x1000 >;
    			status = "okay";
    			ad7291@2f {
    				compatible = "adi,ad7291";
    				reg = < 0x2f >;
    			eeprom@50 {
    				compatible = "at24,24c02";
    				reg = < 0x50 >;
    		mc: memory-controller@fd070000 {
    			compatible = "xlnx,zynqmp-ddrc-2.40a";
    			interrupts = < 0x00 0x70 0x04 >;
    			reg = < 0x00 0xfd070000 0x00 0x30000 >;
    		ocm: memory-controller@ff960000 {
    			compatible = "xlnx,zynqmp-ocmc-1.0";
    			interrupts = < 0x00 0x0a 0x04 >;
    			reg = < 0x00 0xff960000 0x00 0x1000 >;
    		nand0: nand@ff100000 {
    			clock-names = "clk_sys", "clk_flash";
    			clocks = < 0x03 0x3c >, < 0x03 0x1f >;
    			compatible = "arasan,nfc-v3p10";
    			interrupts = < 0x00 0x0e 0x04 >;
    			iommus = < 0x09 0x872 >;
    			power-domains = < 0x0d >;
    			reg = < 0x00 0xff100000 0x00 0x1000 >;
    		pcie: pcie@fd0e0000 {
    			#address-cells = < 0x03 >;
    			#interrupt-cells = < 0x01 >;
    			bus-range = < 0x00 0xff >;
    			clocks = < 0x03 0x17 >;
    			compatible = "xlnx,nwl-pcie-2.11";
    			device_type = "pci";
    			interrupt-map = < 0x00 0x00 0x00 0x01 0x18 0x01 >, < 0x00 0x00 0x00 0x02 0x18 0x02 >, < 0x00 0x00 0x00 0x03 0x18 0x03 >, < 0x00 0x00 0x00 0x04 0x18 0x04 >;
    			interrupt-map-mask = < 0x00 0x00 0x00 0x07 >;
    			interrupt-names = "misc", "dummy", "intx", "msi1", "msi0";
    			interrupts = < 0x00 0x76 0x04 >, < 0x00 0x75 0x04 >, < 0x00 0x74 0x04 >, < 0x00 0x73 0x04 >, < 0x00 0x72 0x04 >;
    			msi-controller;
    			msi-parent = < 0x17 >;
    			phandle = < 0x17 >;
    			power-domains = < 0x19 >;
    			ranges = < 0x2000000 0x00 0xe0000000 0x00 0xe0000000 0x00 0x10000000 0x43000000 0x06 0x00 0x06 0x00 0x02 0x00 >;
    			reg = < 0x00 0xfd0e0000 0x00 0x1000 >, < 0x00 0xfd480000 0x00 0x1000 >, < 0x80 0x00 0x00 0x1000000 >;
    			reg-names = "breg", "pcireg", "cfg";
    			pcie_intc: legacy-interrupt-controller {
    				#address-cells = < 0x00 >;
    				phandle = < 0x18 >;
    		perf_monitor_ocm: perf-monitor@ffa00000 {
    			compatible = "xlnx,axi-perf-monitor";
    			interrupts = < 0x00 0x19 0x04 >;
    			reg = < 0x00 0xffa00000 0x00 0x10000 >;
    			xlnx,enable-32bit-filter-id = < 0x01 >;
    			xlnx,enable-advanced = < 0x01 >;
    			xlnx,enable-event-count = < 0x01 >;
    			xlnx,enable-event-log = < 0x00 >;
    			xlnx,enable-profile = < 0x00 >;
    			xlnx,enable-trace = < 0x00 >;
    			xlnx,fifo-axis-depth = < 0x20 >;
    			xlnx,fifo-axis-tdata-width = < 0x38 >;
    			xlnx,fifo-axis-tid-width = < 0x01 >;
    			xlnx,global-count-width = < 0x20 >;
    			xlnx,have-sampled-metric-cnt = < 0x01 >;
    			xlnx,metric-count-scale = < 0x01 >;
    			xlnx,metric-count-width = < 0x20 >;
    			xlnx,metrics-sample-count-width = < 0x20 >;
    			xlnx,num-monitor-slots = < 0x01 >;
    			xlnx,num-of-counters = < 0x03 >;
    		pinctrl0: pinctrl@ff180000 {
    			compatible = "xlnx,zynqmp-pinctrl";
    			reg = < 0x00 0xff180000 0x00 0x1000 >;
    			status = "okay";
    		rtc: rtc@ffa60000 {
    			calibration = < 0x8000 >;
    			compatible = "xlnx,zynqmp-rtc";
    			interrupt-names = "alarm", "sec";
    			interrupts = < 0x00 0x1a 0x04 >, < 0x00 0x1b 0x04 >;
    			reg = < 0x00 0xffa60000 0x00 0x100 >;
    			status = "okay";
    		sdhci0: sdhci@ff160000 {
    			clock-frequency = < 0xbebba30 >;
    			clock-names = "clk_xin", "clk_ahb";
    			clocks = < 0x03 0x36 >, < 0x03 0x1f >;
    			compatible = "xlnx,zynqmp-8.9a", "arasan,sdhci-8.9a";
    			interrupts = < 0x00 0x30 0x04 >;
    			iommus = < 0x09 0x870 >;
    			power-domains = < 0x1e >;
    			reg = < 0x00 0xff160000 0x00 0x1000 >;
    			status = "okay";
    			xlnx,device_id = < 0x00 >;
    			xlnx,mio_bank = < 0x00 >;
    		sdhci1: sdhci@ff170000 {
    			clocks = < 0x03 0x37 >, < 0x03 0x1f >;
    			interrupts = < 0x00 0x31 0x04 >;
    			iommus = < 0x09 0x871 >;
    			power-domains = < 0x1f >;
    			reg = < 0x00 0xff170000 0x00 0x1000 >;
    			status = "okay";
    			xlnx,device_id = < 0x01 >;
    			xlnx,mio_bank = < 0x01 >;
    		uart0: serial@ff000000 {
    			clock-names = "uart_clk", "pclk";
    			clocks = < 0x03 0x38 >, < 0x03 0x1f >;
    			compatible = "cdns,uart-r1p12", "xlnx,xuartps";
    			device_type = "serial";
    			interrupts = < 0x00 0x15 0x04 >;
    			port-number = < 0x04 >;
    			power-domains = < 0x2a >;
    			reg = < 0x00 0xff000000 0x00 0x1000 >;
    			status = "okay";
    		uart1: serial@ff010000 {
    			clocks = < 0x03 0x39 >, < 0x03 0x1f >;
    			interrupts = < 0x00 0x16 0x04 >;
    			port-number = < 0x05 >;
    			power-domains = < 0x2b >;
    			reg = < 0x00 0xff010000 0x00 0x1000 >;
    			status = "okay";
    		smmu: smmu@fd800000 {
    			#global-interrupts = < 0x01 >;
    			#iommu-cells = < 0x01 >;
    			compatible = "arm,mmu-500";
    			interrupts = < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >, < 0x00 0x9b 0x04 >;
    			phandle = < 0x09 >;
    			reg = < 0x00 0xfd800000 0x00 0x20000 >;
    		spi0: spi@ff040000 {
    			clock-names = "ref_clk", "pclk";
    			clocks = < 0x03 0x3a >, < 0x03 0x1f >;
    			compatible = "cdns,spi-r1p6";
    			interrupts = < 0x00 0x13 0x04 >;
    			is-decoded-cs = < 0x00 >;
    			num-cs = < 0x01 >;
    			power-domains = < 0x20 >;
    			reg = < 0x00 0xff040000 0x00 0x1000 >;
    			status = "okay";
    			pim_adc: pim_adc@0 {
    				compatible = "ti,ads7951";
    				phandle = < 0x42 >;
    				reg = < 0x00 >;
    				spi-max-frequency = < 0x989680 >;
    				vref-supply = < 0x21 >;
    		spi1: spi@ff050000 {
    			clocks = < 0x03 0x3b >, < 0x03 0x1f >;
    			interrupts = < 0x00 0x14 0x04 >;
    			num-cs = < 0x01 >;
    			power-domains = < 0x22 >;
    			reg = < 0x00 0xff050000 0x00 0x1000 >;
    			status = "okay";
    			adc0_ad9361: ad9361-phy@0 {
    				#clock-cells = < 0x01 >;
    				adi,2rx-2tx-mode-enable;
    				adi,agc-adc-large-overload-exceed-counter = < 0x0a >;
    				adi,agc-adc-large-overload-inc-steps = < 0x02 >;
    				adi,agc-adc-small-overload-exceed-counter = < 0x0a >;
    				adi,agc-attack-delay-extra-margin-us = < 0x01 >;
    				adi,agc-gain-update-interval-us = < 0x3e8 >;
    				adi,agc-inner-thresh-high = < 0x0a >;
    				adi,agc-inner-thresh-high-dec-steps = < 0x01 >;
    				adi,agc-inner-thresh-low = < 0x0c >;
    				adi,agc-inner-thresh-low-inc-steps = < 0x01 >;
    				adi,agc-lmt-overload-large-exceed-counter = < 0x0a >;
    				adi,agc-lmt-overload-large-inc-steps = < 0x02 >;
    				adi,agc-lmt-overload-small-exceed-counter = < 0x0a >;
    				adi,agc-outer-thresh-high = < 0x05 >;
    				adi,agc-outer-thresh-high-dec-steps = < 0x02 >;
    				adi,agc-outer-thresh-low = < 0x12 >;
    				adi,agc-outer-thresh-low-inc-steps = < 0x02 >;
    				adi,aux-dac-manual-mode-enable;
    				adi,aux-dac1-default-value-mV = < 0x00 >;
    				adi,aux-dac1-rx-delay-us = < 0x00 >;
    				adi,aux-dac1-tx-delay-us = < 0x00 >;
    				adi,aux-dac2-default-value-mV = < 0x00 >;
    				adi,aux-dac2-rx-delay-us = < 0x00 >;
    				adi,aux-dac2-tx-delay-us = < 0x00 >;
    				adi,ctrl-outs-enable-mask = < 0xff >;
    				adi,ctrl-outs-index = < 0x00 >;
    				adi,dcxo-coarse-and-fine-tune = < 0x08 0x1720 >;
    				adi,digital-interface-tune-skip-mode = < 0x00 >;
    				adi,fagc-dec-pow-measurement-duration = < 0x40 >;
    				adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt = < 0x08 >;
    				adi,fagc-final-overrange-count = < 0x03 >;
    				adi,fagc-gain-index-type-after-exit-rx-mode = < 0x00 >;
    				adi,fagc-lmt-final-settling-steps = < 0x01 >;
    				adi,fagc-lock-level = < 0x0a >;
    				adi,fagc-lock-level-gain-increase-upper-limit = < 0x05 >;
    				adi,fagc-lock-level-lmt-gain-increase-enable;
    				adi,fagc-lp-thresh-increment-steps = < 0x01 >;
    				adi,fagc-lp-thresh-increment-time = < 0x05 >;
    				adi,fagc-lpf-final-settling-steps = < 0x01 >;
    				adi,fagc-optimized-gain-offset = < 0x05 >;
    				adi,fagc-power-measurement-duration-in-state5 = < 0x40 >;
    				adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable;
    				adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll = < 0x0a >;
    				adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable;
    				adi,fagc-rst-gla-if-en-agc-pulled-high-mode = < 0x00 >;
    				adi,fagc-rst-gla-large-adc-overload-enable;
    				adi,fagc-rst-gla-large-lmt-overload-enable;
    				adi,fagc-rst-gla-stronger-sig-thresh-above-ll = < 0x0a >;
    				adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable;
    				adi,fagc-state-wait-time-ns = < 0x104 >;
    				adi,fagc-use-last-lock-level-for-set-gain-enable;
    				adi,frequency-division-duplex-mode-enable;
    				adi,gc-adc-large-overload-thresh = < 0x3a >;
    				adi,gc-adc-ovr-sample-size = < 0x04 >;
    				adi,gc-adc-small-overload-thresh = < 0x2f >;
    				adi,gc-dec-pow-measurement-duration = < 0x2000 >;
    				adi,gc-lmt-overload-high-thresh = < 0x320 >;
    				adi,gc-lmt-overload-low-thresh = < 0x2c0 >;
    				adi,gc-low-power-thresh = < 0x18 >;
    				adi,gc-rx1-mode = < 0x02 >;
    				adi,gc-rx2-mode = < 0x02 >;
    				adi,lvds-bias-mV = < 0x96 >;
    				adi,lvds-mode-enable;
    				adi,lvds-rx-onchip-termination-enable;
    				adi,mgc-dec-gain-step = < 0x02 >;
    				adi,mgc-inc-gain-step = < 0x02 >;
    				adi,mgc-split-table-ctrl-inp-gain-mode = < 0x00 >;
    				adi,pp-rx-swap-enable;
    				adi,pp-tx-swap-enable;
    				adi,rf-rx-bandwidth-hz = < 0x112a880 >;
    				adi,rf-tx-bandwidth-hz = < 0x112a880 >;
    				adi,rssi-delay = < 0x01 >;
    				adi,rssi-duration = < 0x3e8 >;
    				adi,rssi-restart-mode = < 0x03 >;
    				adi,rssi-wait = < 0x01 >;
    				adi,rx-data-delay = < 0x04 >;
    				adi,rx-frame-pulse-mode-enable;
    				adi,rx-path-clock-frequencies = < 0x3a980000 0xea60000 0x7530000 0x3a98000 0x1d4c000 0x1d4c000 >;
    				adi,rx-rf-port-input-select = < 0x00 >;
    				adi,rx-synthesizer-frequency-hz = /bits/ 64 < 0x8f0d1800 >;
    				adi,temp-sense-measurement-interval-ms = < 0x3e8 >;
    				adi,temp-sense-offset-signed = < 0xce >;
    				adi,temp-sense-periodic-measurement-enable;
    				adi,tx-attenuation-mdB = < 0x2710 >;
    				adi,tx-fb-clock-delay = < 0x07 >;
    				adi,tx-lo-powerdown-managed-enable;
    				adi,tx-path-clock-frequencies = < 0x3a980000 0x7530000 0x7530000 0x3a98000 0x1d4c000 0x1d4c000 >;
    				adi,tx-rf-port-input-select = < 0x00 >;
    				adi,tx-synthesizer-frequency-hz = /bits/ 64 < 0x92080880 >;
    				adi,xo-disable-use-ext-refclk-enable;
    				clock-names = "ad9361_ext_refclk";
    				clock-output-names = "rx_sampl_clk", "tx_sampl_clk";
    				clocks = < 0x23 >;
    				compatible = "adi,ad9361";
    				en_agc-gpios = < 0x24 0x01 0x00 0x00 >;
    				enable-gpios = < 0x25 0x00 0x00 0x00 >;
    				phandle = < 0x3b >;
    				reg = < 0x00 >;
    				reset-gpios = < 0x24 0x00 0x00 0x00 >;
    				spi-cpha;
    				txnrx-gpios = < 0x25 0x01 0x00 0x00 >;
    		qspi: spi@ff0f0000 {
    			clocks = < 0x03 0x35 >, < 0x03 0x1f >;
    			compatible = "xlnx,zynqmp-qspi-1.0";
    			has-io-mode = < 0x01 >;
    			interrupts = < 0x00 0x0f 0x04 >;
    			iommus = < 0x09 0x873 >;
    			is-dual = < 0x00 >;
    			is-stacked = < 0x01 >;
    			num-cs = < 0x01 >;
    			power-domains = < 0x1a >;
    			reg = < 0x00 0xff0f0000 0x00 0x1000 >, < 0x00 0xc0000000 0x00 0x8000000 >;
    			spi-rx-bus-width = < 0x04 >;
    			spi-tx-bus-width = < 0x04 >;
    			status = "okay";
    			flash: flash@0 {
    				compatible = "micron,n25q00a", "jedec,spi-nor";
    				reg = < 0x00 >;
    				spi-max-frequency = < 0x2faf080 >;
    				spi-tx-bus-width = < 0x01 >;
    				use-advanced-sector-protection;
    				qspi0-gold-fw@6 {
    					reg = < 0x4000000 0xa00000 >;
    				qspi0-gold-rootfs@8 {
    					reg = < 0x4a20000 0x35e0000 >;
    				qspi0-gold-xscinfo@7 {
    					reg = < 0x4a00000 0x20000 >;
    				qspi0-gold@5 {
    					reg = < 0x4000000 0x4000000 >;
    				qspi0-nom-fw@2 {
    					reg = < 0x00 0xa00000 >;
    				qspi0-nom-rootfs@4 {
    					reg = < 0xa20000 0x35e0000 >;
    				qspi0-nom-xscinfo@3 {
    					reg = < 0xa00000 0x20000 >;
    				qspi0-nom@1 {
    					reg = < 0x00 0x4000000 >;
    				qspi0@0 {
    					reg = < 0x00 0x8000000 >;
    				qspi1-gold-fw@15 {
    					reg = < 0xc000000 0xa00000 >;
    				qspi1-gold-rootfs@17 {
    					reg = < 0xca20000 0x35e0000 >;
    				qspi1-gold-xscinfo@16 {
    					reg = < 0xca00000 0x20000 >;
    				qspi1-gold@14 {
    					reg = < 0xc000000 0x4000000 >;
    				qspi1-nom-fw@11 {
    					reg = < 0x8000000 0xa00000 >;
    				qspi1-nom-rootfs@13 {
    					reg = < 0x8a20000 0x35e0000 >;
    				qspi1-nom-xscinfo@12 {
    					reg = < 0x8a00000 0x20000 >;
    				qspi1-nom@10 {
    					reg = < 0x8000000 0x4000000 >;
    				qspi1@9 {
    					reg = < 0x8000000 0x8000000 >;
    		ttc0: timer@ff110000 {
    			compatible = "cdns,ttc";
    			interrupts = < 0x00 0x24 0x04 >, < 0x00 0x25 0x04 >, < 0x00 0x26 0x04 >;
    			power-domains = < 0x26 >;
    			reg = < 0x00 0xff110000 0x00 0x1000 >;
    			timer-width = < 0x20 >;
    		ttc1: timer@ff120000 {
    			interrupts = < 0x00 0x27 0x04 >, < 0x00 0x28 0x04 >, < 0x00 0x29 0x04 >;
    			power-domains = < 0x27 >;
    			reg = < 0x00 0xff120000 0x00 0x1000 >;
    		ttc2: timer@ff130000 {
    			interrupts = < 0x00 0x2a 0x04 >, < 0x00 0x2b 0x04 >, < 0x00 0x2c 0x04 >;
    			power-domains = < 0x28 >;
    			reg = < 0x00 0xff130000 0x00 0x1000 >;
    		ttc3: timer@ff140000 {
    			interrupts = < 0x00 0x2d 0x04 >, < 0x00 0x2e 0x04 >, < 0x00 0x2f 0x04 >;
    			power-domains = < 0x29 >;
    			reg = < 0x00 0xff140000 0x00 0x1000 >;
    		usb0: usb0@ff9d0000 {
    			clock-names = "bus_clk", "ref_clk";
    			clocks = < 0x03 0x20 >, < 0x03 0x22 >;
    			compatible = "xlnx,zynqmp-dwc3";
    			nvmem-cell-names = "soc_revision";
    			nvmem-cells = < 0x1b >;
    			power-domains = < 0x2c >;
    			ranges;
    			reg = < 0x00 0xff9d0000 0x00 0x100 >;
    			status = "okay";
    			xlnx,usb-reset = < 0x2faf080 >;
    			dwc3_0: dwc3@fe200000 {
    				compatible = "snps,dwc3";
    				dr_mode = "host";
    				interrupts = < 0x00 0x41 0x04 >, < 0x00 0x45 0x04 >, < 0x00 0x4b 0x04 >;
    				iommus = < 0x09 0x860 >;
    				phy-names = "usb3-phy";
    				phys = < 0x2d 0x04 0x00 0x02 0x5f5e100 >;
    				reg = < 0x00 0xfe200000 0x00 0x40000 >;
    				snps,enable_guctl1_ipd_quirk;
    				snps,enable_guctl1_resume_quirk;
    				snps,quirk-frame-length-adjustment = < 0x20 >;
    				snps,refclk_fladj;
    				snps,xhci-stream-quirk;
    				status = "okay";
    		usb1: usb1@ff9e0000 {
    			clocks = < 0x03 0x21 >, < 0x03 0x22 >;
    			power-domains = < 0x2e >;
    			ranges;
    			reg = < 0x00 0xff9e0000 0x00 0x100 >;
    			dwc3_1: dwc3@fe300000 {
    				interrupts = < 0x00 0x46 0x04 >, < 0x00 0x4a 0x04 >, < 0x00 0x4c 0x04 >;
    				iommus = < 0x09 0x861 >;
    				reg = < 0x00 0xfe300000 0x00 0x40000 >;
    				snps,refclk_fladj;
    		watchdog0: watchdog@fd4d0000 {
    			clocks = < 0x03 0x4b >;
    			compatible = "cdns,wdt-r1p2";
    			interrupts = < 0x00 0x71 0x01 >;
    			reg = < 0x00 0xfd4d0000 0x00 0x1000 >;
    			timeout-sec = < 0x0a >;
    		zynqmp_dpsub: zynqmp-display@fd4a0000 {
    			clock-names = "dp_apb_clk", "dp_aud_clk", "dp_vtc_pixel_clk_in";
    			clocks = < 0x30 >, < 0x03 0x11 >, < 0x03 0x10 >;
    			compatible = "xlnx,zynqmp-dpsub-1.7";
    			interrupts = < 0x00 0x77 0x04 >;
    			reg = < 0x00 0xfd4a0000 0x00 0x1000 >, < 0x00 0xfd4aa000 0x00 0x1000 >, < 0x00 0xfd4ab000 0x00 0x1000 >, < 0x00 0xfd4ac000 0x00 0x1000 >;
    			reg-names = "dp", "blend", "av_buf", "aud";
    			gfx-layer {
    				dma-names = "gfx0";
    				dmas = < 0x31 0x03 >;
    			i2c-bus {
    			vid-layer {
    				dma-names = "vid0", "vid1", "vid2";
    				dmas = < 0x31 0x00 >, < 0x31 0x01 >, < 0x31 0x02 >;
    			zynqmp_dp_snd_card0: zynqmp_dp_snd_card {
    				compatible = "xlnx,dp-snd-card";
    				xlnx,dp-snd-codec = < 0x34 >;
    				xlnx,dp-snd-pcm = < 0x32 >, < 0x33 >;
    			zynqmp_dp_snd_codec0: zynqmp_dp_snd_codec0 {
    				clock-names = "aud_clk";
    				clocks = < 0x03 0x11 >;
    				compatible = "xlnx,dp-snd-codec";
    				phandle = < 0x34 >;
    			zynqmp_dp_snd_pcm0: zynqmp_dp_snd_pcm0 {
    				compatible = "xlnx,dp-snd-pcm";
    				dma-names = "tx";
    				dmas = < 0x31 0x04 >;
    				phandle = < 0x32 >;
    			zynqmp_dp_snd_pcm1: zynqmp_dp_snd_pcm1 {
    				dma-names = "tx";
    				dmas = < 0x31 0x05 >;
    				phandle = < 0x33 >;
    		serdes: zynqmp_phy@fd400000 {
    			compatible = "xlnx,zynqmp-psgtr-v1.1";
    			reg = < 0x00 0xfd400000 0x00 0x40000 >, < 0x00 0xfd3d0000 0x00 0x1000 >;
    			reg-names = "serdes", "siou";
    			reset-names = "sata_rst", "usb0_crst", "usb1_crst", "usb0_hibrst", "usb1_hibrst", "usb0_apbrst", "usb1_apbrst", "dp_rst", "gem0_rst", "gem1_rst", "gem2_rst", "gem3_rst";
    			resets = < 0x1c 0x10 >, < 0x1c 0x3b >, < 0x1c 0x3c >, < 0x1c 0x3d >, < 0x1c 0x3e >, < 0x1c 0x3f >, < 0x1c 0x40 >, < 0x1c 0x03 >, < 0x1c 0x1d >, < 0x1c 0x1e >, < 0x1c 0x1f >, < 0x1c 0x20 >;
    			status = "okay";
    			lane0: lane0 {
    				#phy-cells = < 0x04 >;
    			lane1: lane1 {
    			lane2: lane2 {
    				phandle = < 0x2d >;
    			lane3: lane3 {
    	amba_apu: amba_apu@0 {
    		ranges = < 0x00 0x00 0x00 0x00 0xffffffff >;
    		gic: interrupt-controller@f9010000 {
    			#interrupt-cells = < 0x03 >;
    			compatible = "arm,gic-400", "arm,cortex-a15-gic";
    			interrupts = < 0x01 0x09 0xf04 >;
    			phandle = < 0x04 >;
    			reg = < 0x00 0xf9010000 0x10000 >, < 0x00 0xf9020000 0x20000 >, < 0x00 0xf9040000 0x20000 >, < 0x00 0xf9060000 0x20000 >;
    	amba_pl: amba_pl@0 {
    		ranges;
    		psu_ctrl_ipi: PERIPHERAL@ff380000 {
    			compatible = "xlnx,PERIPHERAL-1.0";
    			reg = < 0x00 0xff380000 0x00 0x80000 >;
    		psu_message_buffers: PERIPHERAL@ff990000 {
    			reg = < 0x00 0xff990000 0x00 0x10000 >;
    		cf_ad9361_dac_core_0: cf-ad9361-dds-core-lpc@99024000 {
    			clock-names = "sampl_clk";
    			clocks = < 0x3b 0x0d >;
    			compatible = "adi,axi-ad9361-dds-6.00.a";
    			dma-names = "tx";
    			dmas = < 0x3c 0x00 >;
    			reg = < 0x00 0x99024000 0x00 0x1000 >;
    		cf_ad9361_adc_core_0: cf-ad9361-lpc@99020000 {
    			compatible = "adi,axi-ad9361-6.00.a";
    			dma-names = "rx";
    			dmas = < 0x3a 0x00 >;
    			reg = < 0x00 0x99020000 0x00 0x6000 >;
    			spibus-connected = < 0x3b >;
    		rx_dma: dma@80010000 {
    			#clock-cells = < 0x00 >;
    			clocks = < 0x03 0x47 >;
    			compatible = "adi,axi-dmac-1.00.a";
    			interrupts = < 0x00 0x6e 0x00 >;
    			phandle = < 0x3a >;
    			reg = < 0x00 0x80010000 0x00 0x1000 >;
    			adi,channels {
    				dma-channel@0 {
    					adi,destination-bus-type = < 0x00 >;
    					adi,destination-bus-width = < 0x40 >;
    					adi,source-bus-type = < 0x02 >;
    					adi,source-bus-width = < 0x40 >;
    					reg = < 0x00 >;
    		tx_dma: dma@80011000 {
    			interrupts = < 0x00 0x6d 0x00 >;
    			phandle = < 0x3c >;
    			reg = < 0x00 0x80011000 0x00 0x1000 >;
    			adi,channels {
    				dma-channel@0 {
    					adi,destination-bus-type = < 0x02 >;
    					adi,source-bus-type = < 0x00 >;
    					reg = < 0x00 >;
    		axi_gpio_tr600_misc: gpio@80012000 {
    			#gpio-cells = < 0x03 >;
    			clock-names = "s_axi_aclk";
    			compatible = "xlnx,xps-gpio-1.00.a";
    			gpio-controller;
    			gpio-line-names = "resetb", "en_agc", "pg_fmc", "adc_pd";
    			phandle = < 0x24 >;
    			reg = < 0x00 0x80012000 0x00 0x1000 >;
    			xlnx,all-inputs = < 0x00 >;
    			xlnx,all-inputs-2 = < 0x00 >;
    			xlnx,all-outputs = < 0x00 >;
    			xlnx,all-outputs-2 = < 0x00 >;
    			xlnx,dout-default = < 0x0f >;
    			xlnx,dout-default-2 = < 0x00 >;
    			xlnx,gpio-width = < 0x04 >;
    			xlnx,gpio2-width = < 0x20 >;
    			xlnx,interrupt-present = < 0x00 >;
    			xlnx,is-dual = < 0x00 >;
    			xlnx,tri-default = < 0x00 >;
    			xlnx,tri-default-2 = < 0xffffffff >;
    		axi_gpio_0: gpio@80013000 {
    			gpio-controller;
    			gpio-line-names = "pps", "adc_irq";
    			interrupt-names = "ip2intc_irpt";
    			interrupts = < 0x00 0x5a 0x04 >;
    			phandle = < 0x43 >;
    			reg = < 0x00 0x80013000 0x00 0x1000 >;
    			xlnx,all-inputs = < 0x01 >;
    			xlnx,dout-default = < 0x00 >;
    			xlnx,gpio-width = < 0x02 >;
    			xlnx,interrupt-present = < 0x01 >;
    			xlnx,tri-default = < 0xffffffff >;
    		axi_gpio_1v8: gpio@a0001000 {
    			gpio-controller;
    			gpio-line-names = "zynq_gpio_1v8_0_se", "zynq_gpio_1v8_1_se", "zynq_gpio_1v8_2_se", "zynq_gpio_1v8_3_se", "zynq_gpio_1v8_4_se", "zynq_gpio_1v8_5_se", "zynq_gpio_1v8_6_se", "zynq_gpio_1v8_7_se", "zynq_gpio_1v8_8_se", "zynq_gpio_1v8_9_se", "zynq_gpio_1v8_10_se", "zynq_gpio_1v8_11_se", "zynq_gpio_1v8_12_se", "zynq_gpio_1v8_13_se";
    			gpio2-line-names = "zynq_pa3_gpio_1v8_0", "pa3_zynq_emmc0_pwr_en_n", "pa3_zynq_emmc1_pwr_en_n", "pa3_zynq_usb_fault", "zynq_pa3_usb_en";
    			reg = < 0x00 0xa0001000 0x00 0x1000 >;
    			xlnx,gpio-width = < 0x05 >;
    			xlnx,gpio2-width = < 0x05 >;
    		axi_gpio_ad9361_misc: gpio@a0002000 {
    			gpio-controller;
    			gpio-line-names = "up_enable", "up_txnrx";
    			phandle = < 0x25 >;
    			reg = < 0x00 0xa0002000 0x00 0x1000 >;
    			xlnx,all-outputs = < 0x01 >;
    		axi_gpio_LEDs_3v3: gpio@a0005000 {
    			gpio-controller;
    			gpio-line-names = "zynq_pim_led0_3v3", "zynq_pim_led1_3v3";
    			reg = < 0x00 0xa0005000 0x00 0x1000 >;
    		axi_gpio_can_term: gpio@a0006000 {
    			gpio-controller;
    			gpio-line-names = "can_term";
    			reg = < 0x00 0xa0006000 0x00 0x1000 >;
    			xlnx,gpio-width = < 0x01 >;
    		axi_gpio_gtrefclk_usb_en: gpio@a0007000 {
    			gpio-controller;
    			gpio-line-names = "ps_gtrefclk_usb_1v8_en";
    			reg = < 0x00 0xa0007000 0x00 0x1000 >;
    			xlnx,dout-default = < 0x01 >;
    	aux_ref_clk: aux_ref_clk {
    		clock-frequency = < 0x19bfcc0 >;
    		compatible = "fixed-clock";
    		phandle = < 0x38 >;
    	chosen {
    		bootargs = "earlycon clk_ignore_unused";
    		stdout-path = "serial0:115200n8";
    	clk: clk {
    		clock-names = "pss_ref_clk", "video_clk", "pss_alt_ref_clk", "aux_ref_clk", "gt_crx_ref_clk";
    		clocks = < 0x35 >, < 0x36 >, < 0x37 >, < 0x38 >, < 0x39 >;
    		compatible = "xlnx,zynqmp-clk";
    		phandle = < 0x03 >;
    	clocks {
    		ad9361_clkin: clock@0 {
    			clock-frequency = < 0x2625a00 >;
    			clock-output-names = "ad9361_ext_refclk";
    			phandle = < 0x23 >;
    	cpu_opp_table: cpu_opp_table {
    		compatible = "operating-points-v2";
    		opp-shared;
    		phandle = < 0x01 >;
    		opp00 {
    			clock-latency-ns = < 0x7a120 >;
    			opp-hz = /bits/ 64 < 0x47868bf4 >;
    			opp-microvolt = < 0xf4240 >;
    		opp01 {
    			opp-hz = /bits/ 64 < 0x23c345fa >;
    		opp02 {
    			opp-hz = /bits/ 64 < 0x17d783fc >;
    		opp03 {
    			opp-hz = /bits/ 64 < 0x11e1a2fd >;
    	cpus {
    		cpu0: cpu@0 {
    			clocks = < 0x03 0x0a >;
    			compatible = "arm,cortex-a53", "arm,armv8";
    			cpu-idle-states = < 0x02 >;
    			device_type = "cpu";
    			enable-method = "psci";
    			operating-points-v2 = < 0x01 >;
    			reg = < 0x00 >;
    		cpu1: cpu@1 {
    			reg = < 0x01 >;
    		cpu2: cpu@2 {
    			reg = < 0x02 >;
    		cpu3: cpu@3 {
    			reg = < 0x03 >;
    		idle-states {
    			entry-method = "arm,psci";
    			CPU_SLEEP_0: cpu-sleep-0 {
    				arm,psci-suspend-param = < 0x40000000 >;
    				compatible = "arm,idle-state";
    				entry-latency-us = < 0x12c >;
    				exit-latency-us = < 0x258 >;
    				local-timer-stop;
    				min-residency-us = < 0x2710 >;
    				phandle = < 0x02 >;
    	dcc: dcc {
    		compatible = "arm,dcc";
    	dp_aclk: dp_aclk {
    		clock-accuracy = < 0x64 >;
    		clock-frequency = < 0x5f5e100 >;
    		phandle = < 0x30 >;
    	edac {
    		compatible = "arm,cortex-a53-edac";
    	fclk0: fclk0 {
    		compatible = "xlnx,fclk";
    	fclk1: fclk1 {
    		clocks = < 0x03 0x48 >;
    	fclk2: fclk2 {
    		clocks = < 0x03 0x49 >;
    	fclk3: fclk3 {
    		clocks = < 0x03 0x4a >;
    	firmware {
    		zynqmp_firmware: zynqmp-firmware {
    			compatible = "xlnx,zynqmp-firmware";
    			method = "smc";
    	vref_pim_adc: fixed-regulator@0 {
    		compatible = "regulator-fixed";
    		phandle = < 0x21 >;
    		regulator-always-on;
    		regulator-max-microvolt = < 0x2625a0 >;
    		regulator-min-microvolt = < 0x2625a0 >;
    		regulator-name = "vref_pim_adc";
    	fpga_full: fpga-full {
    		compatible = "fpga-region";
    		fpga-mgr = < 0x06 >;
    	gpio-poweroff {
    		compatible = "gpio-poweroff";
    		gpios = < 0x3d 0x00 0x00 >;
    	gpio-restart {
    		active-delay = < 0x64 >;
    		compatible = "gpio-restart";
    		gpios = < 0x3d 0x08 0x00 >;
    		inactive-delay = < 0x64 >;
    		priority = < 0xff >;
    		wait-delay = < 0x3e8 >;
    	gt_crx_ref_clk: gt_crx_ref_clk {
    		clock-frequency = < 0x66ff300 >;
    		phandle = < 0x39 >;
    	iio_hwmon_adc0 {
    		compatible = "iio-hwmon";
    		io-channel-names = "cur_vcc_in", "vcc_in", "vcc_3v3", "vcc_5v0";
    		io-channels = < 0x3f 0x04 >, < 0x3f 0x05 >, < 0x3f 0x06 >, < 0x3f 0x07 >;
    	iio_hwmon_adc1 {
    		io-channel-names = "emmc0_icc", "emmc0_iccq", "emmc1_icc", "emmc1_iccq";
    		io-channels = < 0x40 0x04 >, < 0x40 0x05 >, < 0x40 0x06 >, < 0x40 0x07 >;
    	iio_hwmon_adc2 {
    		io-channel-names = "cur_vcc_1v8", "vcc_0v85", "vcc_1v1", "vcc_1v8";
    		io-channels = < 0x41 0x04 >, < 0x41 0x05 >, < 0x41 0x06 >, < 0x41 0x07 >;
    	iio_hwmon_ams_ctrl {
    		io-channel-names = "vcc_pspll0", "vcc_psbatt", "vccint", "vccbram", "vccaux", "vcc_psddrpll", "vccpsintfpddr", "ps_temp", "remote_temp", "vccpsintlp", "vccpsintfp", "vccpsaux", "vccpsddr", "vccpsio3", "vccpsio0", "vccpsio1", "vccpsio2", "psmgtravcc", "psmgtravtt", "vccams", "pl_temp", "vccint", "vccaux", "vccvrefp", "vccvrefn", "vccbram", "vccplintlp", "vccplintfp", "vccplaux", "vccams";
    		io-channels = < 0x3e 0x00 >, < 0x3e 0x01 >, < 0x3e 0x02 >, < 0x3e 0x03 >, < 0x3e 0x04 >, < 0x3e 0x05 >, < 0x3e 0x06 >, < 0x3e 0x07 >, < 0x3e 0x08 >, < 0x3e 0x09 >, < 0x3e 0x0a >, < 0x3e 0x0b >, < 0x3e 0x0c >, < 0x3e 0x0d >, < 0x3e 0x0e >, < 0x3e 0x0f >, < 0x3e 0x10 >, < 0x3e 0x11 >, < 0x3e 0x12 >, < 0x3e 0x13 >, < 0x3e 0x14 >, < 0x3e 0x15 >, < 0x3e 0x16 >, < 0x3e 0x17 >, < 0x3e 0x18 >, < 0x3e 0x19 >, < 0x3e 0x1a >, < 0x3e 0x1b >, < 0x3e 0x1c >, < 0x3e 0x1d >;
    	iio_hwmon_pim_adc {
    		io-channels = < 0x42 0x00 >, < 0x42 0x01 >, < 0x42 0x02 >, < 0x42 0x03 >, < 0x42 0x04 >, < 0x42 0x05 >, < 0x42 0x06 >, < 0x42 0x07 >;
    	ipi_mailbox_pmu1: mailbox@ff990400 {
    		#mbox-cells = < 0x01 >;
    		compatible = "xlnx,zynqmp-ipi-mailbox";
    		interrupts = < 0x00 0x23 0x04 >;
    		phandle = < 0x05 >;
    		reg = < 0x00 0xff9905c0 0x00 0x20 >, < 0x00 0xff9905e0 0x00 0x20 >, < 0x00 0xff990e80 0x00 0x20 >, < 0x00 0xff990ea0 0x00 0x20 >;
    		reg-names = "local_request_region", "local_response_region", "remote_request_region", "remote_response_region";
    		xlnx,ipi-ids = < 0x00 0x04 >;
    	memory@0 {
    		device_type = "memory";
    		reg = < 0x00 0x00 0x00 0x80000000 >;
    	nvmem_firmware {
    		compatible = "xlnx,zynqmp-nvmem-fw";
    		soc_revision: soc_revision@0 {
    			phandle = < 0x1b >;
    			reg = < 0x00 0x04 >;
    	pcap: pcap {
    		compatible = "xlnx,zynqmp-pcap-fpga";
    		phandle = < 0x06 >;
    	pmu {
    		compatible = "arm,armv8-pmuv3";
    		interrupts = < 0x00 0x8f 0x04 >, < 0x00 0x90 0x04 >, < 0x00 0x91 0x04 >, < 0x00 0x92 0x04 >;
    	power-domains {
    		compatible = "xlnx,zynqmp-genpd";
    		pd_adma: pd-adma {
    			#power-domain-cells = < 0x00 >;
    			pd-id = < 0x2b >;
    			phandle = < 0x0c >;
    		pd_can0: pd-can0 {
    			pd-id = < 0x2f >;
    			phandle = < 0x07 >;
    		pd_can1: pd-can1 {
    			pd-id = < 0x30 >;
    			phandle = < 0x08 >;
    		pd_dp: pd-dp {
    			pd-id = < 0x29 >;
    			phandle = < 0x2f >;
    		pd_eth0: pd-eth0 {
    			pd-id = < 0x1d >;
    			phandle = < 0x0e >;
    		pd_eth1: pd-eth1 {
    			pd-id = < 0x1e >;
    			phandle = < 0x0f >;
    		pd_eth2: pd-eth2 {
    			pd-id = < 0x1f >;
    			phandle = < 0x10 >;
    		pd_eth3: pd-eth3 {
    			pd-id = < 0x20 >;
    			phandle = < 0x11 >;
    		pd_gdma: pd-gdma {
    			pd-id = < 0x2a >;
    			phandle = < 0x0a >;
    		pd_gpio: pd-gpio {
    			pd-id = < 0x2e >;
    			phandle = < 0x14 >;
    		pd_gpu: pd-gpu {
    			pd-id = < 0x3a 0x14 0x15 >;
    			phandle = < 0x0b >;
    		pd_i2c0: pd-i2c0 {
    			pd-id = < 0x25 >;
    			phandle = < 0x15 >;
    		pd_i2c1: pd-i2c1 {
    			pd-id = < 0x26 >;
    			phandle = < 0x16 >;
    		pd_nand: pd-nand {
    			pd-id = < 0x2c >;
    			phandle = < 0x0d >;
    		pd_pcie: pd-pcie {
    			pd-id = < 0x3b >;
    			phandle = < 0x19 >;
    		pd_qspi: pd-qspi {
    			pd-id = < 0x2d >;
    			phandle = < 0x1a >;
    		pd_sata: pd-sata {
    			pd-id = < 0x1c >;
    			phandle = < 0x1d >;
    		pd_sd0: pd-sd0 {
    			pd-id = < 0x27 >;
    			phandle = < 0x1e >;
    		pd_sd1: pd-sd1 {
    			pd-id = < 0x28 >;
    			phandle = < 0x1f >;
    		pd_spi0: pd-spi0 {
    			pd-id = < 0x23 >;
    			phandle = < 0x20 >;
    		pd_spi1: pd-spi1 {
    			pd-id = < 0x24 >;
    			phandle = < 0x22 >;
    		pd_ttc0: pd-ttc0 {
    			pd-id = < 0x18 >;
    			phandle = < 0x26 >;
    		pd_ttc1: pd-ttc1 {
    			pd-id = < 0x19 >;
    			phandle = < 0x27 >;
    		pd_ttc2: pd-ttc2 {
    			pd-id = < 0x1a >;
    			phandle = < 0x28 >;
    		pd_ttc3: pd-ttc3 {
    			pd-id = < 0x1b >;
    			phandle = < 0x29 >;
    		pd_uart0: pd-uart0 {
    			pd-id = < 0x21 >;
    			phandle = < 0x2a >;
    		pd_uart1: pd-uart1 {
    			pd-id = < 0x22 >;
    			phandle = < 0x2b >;
    		pd_usb0: pd-usb0 {
    			pd-id = < 0x16 >;
    			phandle = < 0x2c >;
    		pd_usb1: pd-usb1 {
    			pd-id = < 0x17 >;
    			phandle = < 0x2e >;
    	pps {
    		compatible = "pps-gpio";
    		gpios = < 0x43 0x00 0x00 0x00 >;
    		status = "okay";
    	psci {
    		compatible = "arm,psci-0.2";
    		method = "smc";
    	pss_alt_ref_clk: pss_alt_ref_clk {
    		clock-frequency = < 0x00 >;
    		phandle = < 0x37 >;
    	pss_ref_clk: pss_ref_clk {
    		clock-frequency = < 0x1fca055 >;
    		phandle = < 0x35 >;
    	rst: reset-controller {
    		#reset-cells = < 0x01 >;
    		compatible = "xlnx,zynqmp-reset";
    		phandle = < 0x1c >;
    	xlnx_keccak_384: sha384 {
    		compatible = "xlnx,zynqmp-keccak-384";
    	timer {
    		compatible = "arm,armv8-timer";
    		interrupts = < 0x01 0x0d 0xf08 >, < 0x01 0x0e 0xf08 >, < 0x01 0x0b 0xf08 >, < 0x01 0x0a 0xf08 >;
    	video_clk: video_clk {
    		phandle = < 0x36 >;
    	zynqmp_power: zynqmp-power {
    		compatible = "xlnx,zynqmp-power";
    		mbox-names = "tx", "rx";
    		mboxes = < 0x05 0x00 >, < 0x05 0x01 >;
    	xlnx_rsa: zynqmp_rsa {
    		compatible = "xlnx,zynqmp-rsa";
    clock summary:
       clock                         enable_cnt  prepare_cnt        rate   accuracy   phase
     spi2.0-tx_lo_dummy                       0            0  1225000000          0 0
     spi2.0-rx_lo_dummy                       0            0  1200000000          0 0
     video_clk                                0            0    27000000          0 0
     pss_ref_clk                              4            4    33333333          0 0
        vpll_post_src                         0            0    33333333          0 0
        vpll_pre_src                          0            0    33333333          0 0
           vpll_int                           0            0  2133333312          0 0
              vpll_half                       0            0  1066666656          0 0
                 vpll_int_mux                 0            0  1066666656          0 0
                    vpll                      0            0  1066666656          0 0
                       topsw_main_mux           0            0  1066666656          0 0
                          topsw_main_div1           0            0   533333328          0 0
                             topsw_main           0            0   533333328          0 0
                       dp_stc_ref_mux           0            0  1066666656          0 0
                          dp_stc_ref_div1           0            0    21333334          0 0
                             dp_stc_ref_div2           0            0      666667          0 0
                                dp_stc_ref           0            0      666667          0 0
                       dp_audio_ref_mux           0            0  1066666656          0 0
                          dp_audio_ref_div1           0            0    30476191          0 0
                             dp_audio_ref_div2           0            0    10158731          0 0
                                dp_audio_ref           0            0    10158731          0 0
                       vpll_to_lpd            0            0   533333328          0 0
        dpll_post_src                         0            0    33333333          0 0
        dpll_pre_src                          1            1    33333333          0 0
           dpll_int                           1            1  2399999976          0 0
              dpll_half                       1            1  1199999988          0 0
                 dpll_int_mux                 1            1  1199999988          0 0
                    dpll                      1            1  1199999988          0 0
                       gpu_ref_mux            0            0  1199999988          0 0
                          gpu_ref_div1           0            0   599999994          0 0
                             gpu_ref           0            0   599999994          0 0
                                gpu_pp1_ref           0            0   599999994          0 0
                                gpu_pp0_ref           0            0   599999994          0 0
                       pcie_ref_mux           0            0  1199999988          0 0
                          pcie_ref_div1           0            0    99999999          0 0
                             pcie_ref           0            0    99999999          0 0
                       sata_ref_mux           0            0  1199999988          0 0
                          sata_ref_div1           0            0    99999999          0 0
                             sata_ref           0            0    99999999          0 0
                       ddr_ref_mux            1            1  1199999988          0 0
                          ddr_ref             1            1   239999998          0 0
                       dpdma_ref_mux           0            0  1199999988          0 0
                          dpdma_ref_div1           0            0   599999994          0 0
                             dpdma_ref           0            0   599999994          0 0
                       gdma_ref_mux           0            0  1199999988          0 0
                          gdma_ref_div1           0            0   599999994          0 0
                             gdma_ref           0            0   599999994          0 0
                       dp_video_ref_mux           0            0  1199999988          0 0
                          dp_video_ref_div1           0            0   119999999          0 0
                             dp_video_ref_div2           0            0   119999999          0 0
                                dp_video_ref           0            0   119999999          0 0
                       dpll_to_lpd            0            0   399999996          0 0
        apll_post_src                         0            0    33333333          0 0
        apll_pre_src                          1            1    33333333          0 0
           apll_int                           1            1  2399999976          0 0
              apll_half                       1            1  1199999988          0 0
                 apll_int_mux                 1            1  1199999988          0 0
                    apll                      1            1  1199999988          0 0
                       acpu_mux               1            1  1199999988          0 0
                          acpu_div1           1            1  1199999988          0 0
                             acpu             1            1  1199999988          0 0
                                acpu_half_ff           0            0   599999994          0 0
                                   acpu_half           0            0   599999994          0 0
                       apll_to_lpd            0            0   399999996          0 0
        rpll_post_src                         0            0    33333333          0 0
        rpll_pre_src                          1            1    33333333          0 0
           rpll_int                           1            1  1599999984          0 0
              rpll_half                       1            1   799999992          0 0
                 rpll_int_mux                 1            1   799999992          0 0
                    rpll                      4            4   799999992          0 0
                       pl2_ref_mux            0            0   799999992          0 0
                          pl2_ref_div1           0            0    16000000          0 0
                             pl2_ref_div2           0            0     1000000          0 0
                                pl2_ref           0            0     1000000          0 0
                       pl1_ref_mux            0            0   799999992          0 0
                          pl1_ref_div1           0            0   199999998          0 0
                             pl1_ref_div2           0            0   199999998          0 0
                                pl1_ref           0            0   199999998          0 0
                       pl0_ref_mux            1            1   799999992          0 0
                          pl0_ref_div1           1            1    99999999          0 0
                             pl0_ref_div2           1            1    99999999          0 0
                                pl0_ref           3           10    99999999          0 0
                       spi1_ref_mux           1            1   799999992          0 0
                          spi1_ref_div1           1            1   199999998          0 0
                             spi1_ref_div2           1            1   199999998          0 0
                                spi1_ref           1            1   199999998          0 0
                       spi0_ref_mux           0            0   799999992          0 0
                          spi0_ref_div1           0            0   199999998          0 0
                             spi0_ref_div2           0            0   199999998          0 0
                                spi0_ref           0            0   199999998          0 0
                       sdio1_ref_mux           1            1   799999992          0 0
                          sdio1_ref_div1           1            1   199999998          0 0
                             sdio1_ref_div2           1            1   199999998          0 0
                                sdio1_ref           1            1   199999998          0 0
                       sdio0_ref_mux           1            1   799999992          0 0
                          sdio0_ref_div1           1            1   199999998          0 0
                             sdio0_ref_div2           1            1   199999998          0 0
                                sdio0_ref           1            1   199999998          0 0
                       iou_switch_mux           0            0   799999992          0 0
                          iou_switch_div1           0            0   266666664          0 0
                             iou_switch           0            0   266666664          0 0
                       rpll_to_fpd            0            0   399999996          0 0
        iopll_post_src                        0            0    33333333          0 0
        iopll_pre_src                         1            1    33333333          0 0
           iopll_int                          1            1  2999999970          0 0
              iopll_half                      1            1  1499999985          0 0
                 iopll_int_mux                1            1  1499999985          0 0
                    iopll                     9           11  1499999985          0 0
                       pl3_ref_mux            0            0  1499999985          0 0
                          pl3_ref_div1           0            0    46875000          0 0
                             pl3_ref_div2           0            0     9375000          0 0
                                pl3_ref           0            0     9375000          0 0
                       ams_ref_mux            1            1  1499999985          0 0
                          ams_ref_div1           1            1    50000000          0 0
                             ams_ref_div2           1            1    50000000          0 0
                                ams_ref           1            1    50000000          0 0
                       adma_ref_mux           0            0  1499999985          0 0
                          adma_ref_div1           0            0   499999995          0 0
                             adma_ref           0            0   499999995          0 0
                       dll_ref                0            0  1499999985          0 0
                       can1_ref_mux           0            0  1499999985          0 0
                          can1_ref_div1           0            0    99999999          0 0
                             can1_ref_div2           0            0    99999999          0 0
                                can1_ref           0            0    99999999          0 0
                                   can1           0            0    99999999          0 0
                       can0_ref_mux           0            0  1499999985          0 0
                          can0_ref_div1           0            0    99999999          0 0
                             can0_ref_div2           0            0    99999999          0 0
                                can0_ref           0            0    99999999          0 0
                                   can0           0            0    99999999          0 0
                       i2c1_ref_mux           0            1  1499999985          0 0
                          i2c1_ref_div1           0            1    99999999          0 0
                             i2c1_ref_div2           0            1    99999999          0 0
                                i2c1_ref           0            1    99999999          0 0
                       i2c0_ref_mux           0            1  1499999985          0 0
                          i2c0_ref_div1           0            1    99999999          0 0
                             i2c0_ref_div2           0            1    99999999          0 0
                                i2c0_ref           0            1    99999999          0 0
                       nand_ref_mux           0            0  1499999985          0 0
                          nand_ref_div1           0            0    46875000          0 0
                             nand_ref_div2           0            0     9375000          0 0
                                nand_ref           0            0     9375000          0 0
                       uart1_ref_mux           1            1  1499999985          0 0
                          uart1_ref_div1           1            1    99999999          0 0
                             uart1_ref_div2           1            1    99999999          0 0
                                uart1_ref           1            1    99999999          0 0
                       uart0_ref_mux           1            1  1499999985          0 0
                          uart0_ref_div1           1            1    99999999          0 0
                             uart0_ref_div2           1            1    99999999          0 0
                                uart0_ref           1            1    99999999          0 0
                       qspi_ref_mux           1            1  1499999985          0 0
                          qspi_ref_div1           1            1   299999997          0 0
                             qspi_ref_div2           1            1   299999997          0 0
                                qspi_ref           1            1   299999997          0 0
                       gem3_ref_mux           1            1  1499999985          0 0
                          gem3_ref_div1           1            1   124999999          0 0
                             gem3_ref_div2           1            1   124999999          0 0
                                gem3_ref           2            2   124999999          0 0
                                   gem3_tx_mux           1            1   124999999          0 0
                                      gem3_tx           2            2   124999999          0 0
                       gem2_ref_mux           0            0  1499999985          0 0
                          gem2_ref_div1           0            0    62500000          0 0
                             gem2_ref_div2           0            0    62500000          0 0
                                gem2_ref           0            0    62500000          0 0
                                   gem2_tx_mux           0            0    62500000          0 0
                                      gem2_tx           0            0    62500000          0 0
                       gem1_ref_mux           0            0  1499999985          0 0
                          gem1_ref_div1           0            0    62500000          0 0
                             gem1_ref_div2           0            0    62500000          0 0
                                gem1_ref           0            0    62500000          0 0
                                   gem1_tx_mux           0            0    62500000          0 0
                                      gem1_tx           0            0    62500000          0 0
                       gem0_ref_mux           0            0  1499999985          0 0
                          gem0_ref_div1           0            0    62500000          0 0
                             gem0_ref_div2           0            0    62500000          0 0
                                gem0_ref           0            0    62500000          0 0
                                   gem0_tx_mux           0            0    62500000          0 0
                                      gem0_tx           0            0    62500000          0 0
                       gem_tsu_ref_mux           1            1  1499999985          0 0
                          gem_tsu_ref_div1           1            1   249999998          0 0
                             gem_tsu_ref_div2           1            1   249999998          0 0
                                gem_tsu_ref           1            1   249999998          0 0
                                   gem_tsu           1            1   249999998          0 0
                       pcap_mux               0            0  1499999985          0 0
                          pcap_div1           0            0   187499999          0 0
                             pcap             0            0   187499999          0 0
                       csu_pll_mux            0            0  1499999985          0 0
                          csu_pll_div1           0            0   187499999          0 0
                             csu_pll           0            0   187499999          0 0
                       cpu_r5_mux             0            0  1499999985          0 0
                          cpu_r5_div1           0            0   499999995          0 0
                             cpu_r5           0            0   499999995          0 0
                                cpu_r5_core           0            0   499999995          0 0
                       usb3_dual_ref_mux           1            1  1499999985          0 0
                          usb3_dual_ref_div1           1            1    60000000          0 0
                             usb3_dual_ref_div2           1            1    20000000          0 0
                                usb3_dual_ref           1            1    20000000          0 0
                       usb1_bus_ref_mux           0            0  1499999985          0 0
                          usb1_bus_ref_div1           0            0   124999999          0 0
                             usb1_bus_ref_div2           0            0   124999999          0 0
                                usb1_bus_ref           0            0   124999999          0 0
                       usb0_bus_ref_mux           1            1  1499999985          0 0
                          usb0_bus_ref_div1           1            1   249999998          0 0
                             usb0_bus_ref_div2           1            1   249999998          0 0
                                usb0_bus_ref           1            1   249999998          0 0
                       lpd_lsbus_mux           1            1  1499999985          0 0
                          lpd_lsbus_div1           1            1    99999999          0 0
                             lpd_lsbus           8            8    99999999          0 0
                       lpd_switch_mux           0            0  1499999985          0 0
                          lpd_switch_div1           0            0   499999995          0 0
                             lpd_switch           0            0   499999995          0 0
                       dbg_lpd_mux            0            0  1499999985          0 0
                          dbg_lpd_div1           0            0   249999998          0 0
                             dbg_lpd           0            0   249999998          0 0
                       iopll_to_fpd           0            0   499999995          0 0
                          gtgref0_ref_mux           0            0   499999995          0 0
                             gtgref0_ref_div1           0            0    62500000          0 0
                                gtgref0_ref           0            0    62500000          0 0
                          topsw_lsbus_mux           0            0   499999995          0 0
                             topsw_lsbus_div1           0            0    99999999          0 0
                                topsw_lsbus           0            0    99999999          0 0
                                   wdt           0            0    99999999          0 0
                          dbg_tstmp_mux           0            0   499999995          0 0
                             dbg_tstmp           0            0   249999998          0 0
                          dbg_trace_mux           0            0   499999995          0 0
                             dbg_trace_div1           0            0    13513514          0 0
                                dbg_trace           0            0    13513514          0 0
                          dbg_fpd_mux           0            0   499999995          0 0
                             dbg_fpd_div1           0            0   249999998          0 0
                                dbg_fpd           0            0   249999998          0 0
        timestamp_ref_mux                     0            0    33333333          0 0
           timestamp_ref_div1                 0            0    33333333          0 0
              timestamp_ref                   0            0    33333333          0 0
     pss_alt_ref_clk                          0            0           0          0 0
     gt_crx_ref_clk                           0            0   108000000          0 0
     dp_aclk                                  0            0   100000000        100 0
     ad9361_ext_refclk                        4            4    40000000          0 0
        spi2.0-bb_refclk                      1            1    40000000          0 0
           spi2.0-bbpll_clk                   1            1           0          0 0
              spi2.0-adc_clk                  1            1           0          0 0
                 spi2.0-dac_clk               1            1           0          0 0
                    spi2.0-t2_clk             1            1           0          0 0
                       spi2.0-t1_clk           1            1           0          0 0
                          spi2.0-clktf_clk           1            1           0          0 0
                             spi2.0-tx_sampl_clk           1            1           0          0 0
                 spi2.0-r2_clk                0            0           0          0 0
                    spi2.0-r1_clk             0            0           0          0 0
                       spi2.0-clkrf_clk           0            0           0          0 0
                          spi2.0-rx_sampl_clk           0            0           0          0 0
        spi2.0-rx_refclk                      1            1    20000000          0 0
           spi2.0-rx_rfpll_int                1            1           0          0 0
              spi2.0-rx_rfpll                 1            1           0          0 0
        spi2.0-tx_refclk                      1            1    40000000          0 0
           spi2.0-tx_rfpll_int                1            1           0          0 0
              spi2.0-tx_rfpll                 1            1           0          0 0
     aux_ref_clk                              0            0    27000000          0 0
     can1_mio                                 0            0           0          0 0
     can0_mio                                 0            0           0          0 0
    Liam
  • Hmm - this is really strange -
    On boot everything works:
    [    1.641451] ad9361 spi2.0: ad9361_probe : AD936x Rev 2 successfu
    however later on (I guess when you userspace starts) it fails badly -
    Can it be that OSC starts and has a bad profile?
    Can you try to delete /home/analog/.osc_profile and /root/.osc_profile ?
    -Michael
    I couldn't find the files you mentioned on my board (or the zcu102+FMCOMMS3 I'm using for reference). If your talking about the IIO Oscilloscope application, it's not installed on the unit.
    Investigating further yesterday, I found out that the issue seems to come from the cf_axi_adc_core.c driver initialisation.
    the ad9361_dig_tune_delay function fails and return EIO. If I set the adi,xo-disable-use-ext-refclk-enable parameter in the devicetree, the board seems to boot and I can connect remotely using the IIO scope but I can't edit any frequency and the active ENSM field shows an error.
    Can this information help narrow down the issue? Could this be caused by a bad configuration in Vivado?
    Thanks for your time,
    Liam
  • For me the first issue that appears seem to be some memory corruption.
    Why does parent rate become 10521254882? I never seen such a failure before.
    I attached the FMCOMMS2 ZCU102 boot files, can you try to use our kernel image with your setup?
    pack.zip
  • I will try those files but our board requires changes to BOOT.BIN so I might not get a change to do it today.
    In the meantime, we have noticed a hardware issue with the external ref clock feed to the AD9361. Could this explain the failure you mentioned above?
    I don't think that the hardware issue of your external reference clock can explain the strange 10521254882 parent rate.
    Dragos
    Thank you so much for your time.
    It turns out we were hitting the current limit on one of our power sources during initialization.
    After fixing that everything went back to normal.
    Thanks again,
    Liam
