Hi all,
We're update the AD9371 HDL to vivado 2018.3 version on Zynq-7000(ZC706) platform
After clone the latest version from HDL https://github.com/analogdevicesinc/hdl and noOS driver https://github.com/analogdevicesinc/no-OS, there are several issues.
the HDL project we are tested in Linux driver and it work normally.
first,
there is primary error shows the platform_xilinx/jesd_core.h has an error of no definition for "mykonosDevice_t"
https://github.com/analogdevicesinc/no-OS/blob/master/ad9371/sw/platform_xilinx/jesd_core.h#L105
int32_t xcvr_setup(mykonosDevice_t *myk_dev); int32_t jesd_setup(mykonosDevice_t *myk_dev); int32_t jesd_tx_enable(mykonosDevice_t *myk_dev); int32_t jesd_rx_enable(mykonosDevice_t *myk_dev);
Second, there is no no address in hdl-master mapped to AXI_AD9371_CORE_BASEADDR as described in
https://github.com/analogdevicesinc/no-OS/issues/256
Third, the JESD report is mismatched to the device.
the device in use is Zynq-7000(GTX2) but the initial shows the different results and framer and deframer are abnormal.
Please wait... RX_XCVR (GTH4) initialization OK TX_XCVR (GTH4) initialization OK RX_OS_XCVR (GTH4) initialization OK MCS successful CLKPLL locked AD9371 ARM version 5.1.1 PLLs locked Calibrations completed successfully RxFramerStatus = 0x20 OrxFramerStatus = 0x20 DeframerStatus = 0x21 (null)
Thanks in advance
H.A. Hou
Can you please use these sources instead: https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371 ?The TPL addresses are defined in this version (https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/devices/adi_hal/parameters.h#L137).
Thanks,Dragos
Hi Dragos,
I found the link, but compile failed since some file are missing.
https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/README#L46,
cp ../../drivers/xilinx_platform/platform_drivers.c devices/adi_hal/
and there are no reference definition in
https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/README#L46-L50.
#include "delay.h" #include "error.h" #include "gpio.h" #include "i2c.h" #include "spi.h"
and finally, there is no definition for "SUCCESS" in drivers.c such as (axi_adc_core.c, axi_dac_core.c, and etc,)
thanks
Can you please try using the README file from this temporary branch to see if the issues are solved?
https://github.com/analogdevicesinc/no-OS/tree/update_readme/projects/ad9371/src
Thank you,
Antoniu
Hi Antoniu,
A. compiler issue
1. there is no corresponding member defined for spi structure
spi.id in
https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/devices/adi_hal/common.c#L40
spi.flag in
https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/devices/adi_hal/common.c#L44
2. the definition is missing in clk_axi_clkgen.c
https://github.com/analogdevicesinc/no-OS/blob/master/projects/drivers/clk_axi_clkgen/clk_axi_clkgen.c#L162
https://github.com/analogdevicesinc/no-OS/blob/master/projects/drivers/clk_axi_clkgen/clk_axi_clkgen.c#L174
after fix the above error, the binary file is generated.
B. when running the binary file on the ZYNQ platform, it hands on the following messages
Please wait...
1. after more investigation, the SPI structure are quite different between
https://github.com/analogdevicesinc/no-OS/blob/master/projects/drivers/xilinx_platform/xilinx_platform_drivers.h
and
https://github.com/analogdevicesinc/no-OS/blob/master/include/spi.h
1.1. spi_init_param
typedef struct spi_init_param { uint32_t max_speed_hz; uint8_t chip_select; enum spi_mode mode; void *extra; } spi_init_param; typedef struct xil_spi_init_param { enum spi_type type; uint32_t id; uint32_t flags; } xil_spi_init_param;
1.2. spi_desc
typedef struct spi_desc { uint32_t max_speed_hz; uint8_t chip_select; enum spi_mode mode; void *extra; } spi_desc; typedef struct xil_spi_desc { enum spi_type type; uint32_t id; uint32_t flags; #ifdef _XPARAMETERS_PS_H_ XSpiPs_Config *config; XSpiPs instance; #else XSpi instance; #endif } xil_spi_desc;
2. access the member without initialization
https://github.com/analogdevicesinc/no-OS/blob/master/projects/drivers/xilinx_platform/spi.c#L82
try to access the xli_param->flag but param->extra does not be initialized in
https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/devices/adi_hal/common.c#L30-L49
int32_t platform_init(void) { struct spi_init_param spi_param; int32_t status = 0; status = gpio_get(&gpio_ad9371_resetb, AD9371_RESET_B); status = gpio_get(&gpio_ad9528_resetb, AD9528_RESET_B); status = gpio_get(&gpio_ad9528_sysref_req, AD9528_SYSREF_REQ); spi_param.id = SPI_DEVICE_ID; spi_param.mode = SPI_MODE_0; spi_param.chip_select = AD9371_CS; #ifndef ALTERA_PLATFORM spi_param.flags = SPI_CS_DECODE; #endif status |= spi_init(&spi_ad_desc, &spi_param); return status; }
in addition, spi_init_param has no members of id and flag as mentioned in the above.
If possible, would you mind testing the code roughly before commit ?
H. A. Hou
Hello Hou,
We are currently in the process of updating some of the no-OS projects.
Please check the latest commits on master branch. These issues should be fixed now.
github.com/.../no-Os
Let me know if you encounter any other difficulties in doing the setup.
which branch should I follow? master or something else ?
Thanks
Yes, you should follow the master branch.
If you need any assistance or find any issues, let us know and we will try to respond asap.
Since our schedule is tight, I'm afraid to have much time to check the source code frequently.
Would you mind letting me if there is an official release or checkpoint for soruce ?
Therefore I would check if it works.
Can you try the current master branch? It should work.
Hi Dragos and Antoniu
I tried it. It worked partially.
first, the SPI address needs to modify to work correctly or failed. I'm not sure if the difference of the hardware.
in github.com/.../spi.chttps://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/devices/adi_hal/common.c#L49 SS_DECODE attribute is set.
so the SPI configuration for AD9528 and AD9371 should be modified
https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/app/myk_ad9528init.c#L6
static spiSettings_t clockSpiSettings = { // 1, //chip select Index 7, //chip select Index 0, //Write bit polarity 1, //16bit instruction word 1, //MSB first 0, //Clock phase 0, //Clock polarity 0,//uint8_t enSpiStreaming; 1,//uint8_t autoIncAddrUp; 1 //uint8_t fourWireMode; };
and https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/app/myk.c#L486static spiSettings_t mykSpiSettings = { // 2, /* chip select index - valid 1~8 */ 6, /* chip select index - valid 1~8 */ 0, /* the level of the write bit of a SPI write instruction word, value is inverted for SPI read operation */ 1, /* 1 = 16-bit instruction word, 0 = 8-bit instruction word */ 1, /* 1 = MSBFirst, 0 = LSBFirst */ 0, /* clock phase, sets which clock edge the data updates (valid 0 or 1) */ 0, /* clock polarity 0 = clock starts low, 1 = clock starts high */ 0, /* Not implemented in ADIs platform layer. SW feature to improve SPI throughput */ 1, /* Not implemented in ADIs platform layer. For SPI Streaming, set address increment direction. 1= next addr = addr+1, 0:addr=addr-1 */ 1 /* 1: Use 4-wire SPI, 0: 3-wire SPI (SDIO pin is bidirectional). NOTE: ADI's FPGA platform always uses 4-wire mode */ };
to make noOS driver works. Tx transmits signal, Rx need to be check.
Second, the output logs shows the ORx still failed to work
Please wait... rx_clkgen: MMCM-PLL locked (122880000 Hz) tx_clkgen: MMCM-PLL locked (122880000 Hz) rx_os_clkgen: MMCM-PLL locked (122880000 Hz) MCS successful CLKPLL locked AD9371 ARM version 5.2.2 PLLs locked Calibrations completed successfully tx_adxcvr: OK (4915200 kHz) rx_adxcvr: OK (4915200 kHz) rx_os_adxcvr: OK (4915200 kHz) rx_jesd status: Link is enabled Measured Link Clock: 122.882 MHz Reported Link Clock: 122.880 MHz Lane rate: 4915.200 MHz Lane rate / 40: 122.880 MHz Link status: DATA SYSREF captured: Yes SYSREF alignment error: No rx_jesd lane 0 status: Errors: 0 CGS state: DATA Initial Frame Synchronization: Yes Lane Latency: 1 Multi-frames and 75 Octets Initial Lane Alignment Sequence: Yes DID: 0, BID: 0, LID: 0, L: 2, SCR: 1, F: 4 K: 32, M: 4, N: 16, CS: 0, N': 16, S: 1, HD: 0 FCHK: 0x47, CF: 0 ADJCNT: 0, PHADJ: 0, ADJDIR: 0, JESDV: 1, SUBCLASS: 1 FC: 4915200 kHz rx_jesd lane 1 status: Errors: 0 CGS state: DATA Initial Frame Synchronization: Yes Lane Latency: 1 Multi-frames and 73 Octets Initial Lane Alignment Sequence: Yes DID: 0, BID: 0, LID: 1, L: 2, SCR: 1, F: 4 K: 32, M: 4, N: 16, CS: 0, N': 16, S: 1, HD: 0 FCHK: 0x48, CF: 0 ADJCNT: 0, PHADJ: 0, ADJDIR: 0, JESDV: 1, SUBCLASS: 1 FC: 4915200 kHz tx_jesd status: Link is enabled Measured Link Clock: 122.882 MHz Reported Link Clock: 122.880 MHz Lane rate: 4915.200 MHz Lane rate / 40: 122.880 MHz SYNC~: deasserted Link status: DATA SYSREF captured: Yes SYSREF alignment error: No rx_os_jesd status: Link is enabled Measured Link Clock: 122.882 MHz Reported Link Clock: 122.880 MHz Lane rate: 4915.200 MHz Lane rate / 40: 122.880 MHz Link status: DATA SYSREF captured: Yes SYSREF alignment error: No rx_os_jesd lane 0 status: Errors: 1 CGS state: DATA Initial Frame Synchronization: Yes Lane Latency: 2 Multi-frames and 9 Octets Initial Lane Alignment Sequence: Yes DID: 0, BID: 0, LID: 0, L: 2, SCR: 1, F: 2 K: 32, M: 2, N: 16, CS: 0, N': 16, S: 1, HD: 0 FCHK: 0x43, CF: 0 ADJCNT: 0, PHADJ: 0, ADJDIR: 0, JESDV: 1, SUBCLASS: 1 FC: 4915200 kHz rx_os_jesd lane 1 status: Errors: 1 CGS state: DATA Initial Frame Synchronization: Yes Lane Latency: 2 Multi-frames and 10 Octets Initial Lane Alignment Sequence: Yes DID: 0, BID: 0, LID: 1, L: 2, SCR: 1, F: 2 K: 32, M: 2, N: 16, CS: 0, N': 16, S: 1, HD: 0 FCHK: 0x44, CF: 0 ADJCNT: 0, PHADJ: 0, ADJDIR: 0, JESDV: 1, SUBCLASS: 1 FC: 4915200 kHz tx_dac: Successfully initialized (245764160 Hz) rx_adc: Successfully initialized (122882080 Hz) Done
please help to solve ORx issue.
Having the chip selects set to 6 and 7 is incorrect. Have a look at the HDL project (https://github.com/analogdevicesinc/hdl/blob/master/projects/adrv9371x/zc706/system_top.v#L306-L307): .spi0_csn_0_o (spi_csn_ad9528), .spi0_csn_1_o (spi_csn_ad9371),For the AD9371 Transceiver Evaluation Software, the valid values for the generated profiles are 1~8, so our software must subtract 1 from those values. This is done in the CMB_SPIWriteByte() (https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/devices/adi_hal/common.c#L123) and CMB_SPIReadByte() (https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9371/src/devices/adi_hal/common.c#L152) functions.
Why do you say that ORx doesn't work? Some errors may be detected during the initialization phase (Errors: 1 - in your log), but that's not an issue as long as that number doesn't increase during the run time.
I've done a quick test using the current version of the no-OS and hdl master branches, but I didn't see issues.
set AD9528 CS = 1
set AD9528 CS = 7
set AD9371 CS = 6
Obviously, the AD9528 with CS configured to 1 work abnormal, and result meets the XILINX ZYNQ-7000 TRM.
H.A.
