This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
I use LwIP to send the data collected by ad9361 and adc_capture (2048, ADC_DDR_BASEADDR). The data captured are listed in the following instructions:
@file main.c
#include "config.h"
#include "lwip/err.h"
#include "lwip/tcp.h"
#include "lwipopts.h"
#include "netif/xadapter.h"
AD9361_InitParam default_init_param =
int main(void)
//int i;
//int rev;
int32_t i;
int32_t rdata;
int16_t sampI, sampQ;
int Status;
struct netif *netif, server_netif;
struct ip_addr ipaddr, netmask, gw;
unsigned char mac_ethernet_address[] = { 0x00, 0x0a, 0x35, 0x00, 0x01, 0x02 };
#ifdef XILINX_PLATFORM
Xil_ICacheEnable();
Xil_DCacheEnable();
#endif
System_Init();
netif = &server_netif;
IP4_ADDR(&ipaddr, 192, 168, 1, 10);
IP4_ADDR(&netmask, 255, 255, 255, 0);
IP4_ADDR(&gw, 192, 168, 1, 1);
/*lwip library init*/
lwip_init();
/* Add network interface to the netif_list, and set it as default */
if (!xemac_add(netif, &ipaddr, &netmask, &gw, mac_ethernet_address, XPAR_XEMACPS_0_BASEADDR)) {
xil_printf("Error adding N/W interface\r\n");
return -1;
netif_set_default(netif);
/* specify that the network if is up */
netif_set_up(netif);
/* initialize tcp pcb */
tcp_send_init();
while(1) {
/* call tcp timer every 250ms */
if(TcpTmrFlag)
tcp_tmr();
TcpTmrFlag = 0;
xemacif_input(netif);
if (tcp_client_connected) {
sleep(1);
send_data();
xil_printf("tran_cnt:%d\n\r", tcp_trans_cnt);
printf("Done.\n");
#include "user_tcp.h"
#include "parameters.h"
#define SEND_SIZE 1024//#define SEND_SIZE 12
static struct tcp_pcb *connected_pcb = NULL;
volatile unsigned tcp_client_connected = 0;
int tcp_trans_cnt = 0;
static err_t tcp_sent_callback(void *arg, struct tcp_pcb *tpcb, u16_t len)
tcp_trans_cnt++;
xil_printf("send int");
return ERR_OK;
static err_t tcp_connected_callback(void *arg, struct tcp_pcb *tpcb, err_t err)
xil_printf("txperf: Connected to iperf server\r\n");
connected_pcb = tpcb;
tcp_nagle_disable(connected_pcb);
tcp_arg(tpcb, NULL);
tcp_sent(tpcb, tcp_sent_callback);
tcp_client_connected = 1;
xil_printf("Connect Success.\r\n");
return ERR_OK;
int tcp_send_init()
struct tcp_pcb *pcb;
struct ip_addr ipaddr;
err_t err;
u16_t port;
pcb = tcp_new();
if (!pcb) {
xil_printf("txperf: Error creating PCB. Out of Memory\r\n");
return -1;
IP4_ADDR(&ipaddr, 192, 168, 1, 100);
port = 7;
err = tcp_connect(pcb, &ipaddr, port, tcp_connected_callback);
if (err != ERR_OK) {
xil_printf("txperf: tcp_connect returned error: %d\r\n", err);
return err;
xil_printf("%d\r\n",err);
return 0;
void send_data(void)
int32_t j;
int32_t r_data;
int16_t samp_I, samp_Q;
err_t err;
struct tcp_pcb *tpcb = connected_pcb;
if (!connected_pcb)
return;
mdelay(1000);
adc_capture(1024, ADC_DDR_BASEADDR);
Xil_DCacheInvalidateRange(ADC_DDR_BASEADDR, 1024);
if (tcp_sndbuf(tpcb) > SEND_SIZE)
err = tcp_write(tpcb, ADC_DDR_BASEADDR, SEND_SIZE, 3);
xil_printf("txperf: Error on tcp_write: %d\r\n", err);
return;
err = tcp_output(tpcb);
xil_printf("txperf: Error on tcp_output: %d\r\n",err);
return;
The SEND_SIZE in tcp_write should represent the length of the transmitted data, which can be sent normally when the length is 12 short data. When the number is set to 2048, only the first data is received at the receiving end.
Later, I changed SEND_SIZE to 128 and found that once the data exceeded 1500, whether it was a one-time or cumulative transmission of more than 1500, the receiver would make mistakes (no data was received).
This problem has been bothering me for a long time and I hope to get help.
[locked by: aardelean at 7:51 AM (GMT 0) on 15 Apr 2019]
