A problem with AD-FMCDAQ2-EBZ FMC Board
Hello.
I have some confusion when follow AD-FMCDAQ2-EBZ Microblaze Quick Start Guide at the address https://wiki.analog.com/resources/eval/user-guides/ad-fmcdaq2-ebz/quickstart/microblaze  . My FPGA carrier borad is KC705. I use the Xilinx XMD command console to loading the design in Linux. And my computer shows that as follows,it is same with the user-guide .
then ,the IP address printed on the KC705 LCD display. Before that, I connected OUT_A to IN_A, OUT_B to IN_B of AD-FMCDAQ2-EBZ FMC Board.
then I use the software  IIO Oscilloscope to connect the device by entering the IP address.
But it can only identify AD9523 and AD9144 , not AD9680. Then I load profile of AD-FMCDAQ2-EBZ in the software .It prompts the same problem about AD9680
My question is that ,Has AD-FMCDAQ2-EBZ FMC Board been damaged or did I have a problem during operation?
Thank you !
Parents
  • The revision numbers of AD-FMCDAQ2 is shown as the picture,
    I'm not good at Linux, so I don't know whether what post here is your need.If it is not ,please tell me .Thanks!
    root@xkw-HP-ProBook-4421s:/home/xkw# dmesg | more
    [ 1835.804929] usb 2-1.2: USB disconnect, device number 4
    [ 1836.257737] usb 2-1.2: new high-speed USB device number 6 using ehci-pci
    [ 1836.351391] usb 2-1.2: New USB device found, idVendor=8644, idProduct=8003
    [ 1836.351396] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber
    =3
    [ 1836.351399] usb 2-1.2: Product: USB Flash Disk
    [ 1836.351402] usb 2-1.2: Manufacturer: General
    [ 1836.351405] usb 2-1.2: SerialNumber: 03363000000321D9
    [ 1836.351778] usb-storage 2-1.2:1.0: USB Mass Storage device detected
    [ 1836.351868] scsi host5: usb-storage 2-1.2:1.0
    [ 1836.572919] usb 2-1.2: USB disconnect, device number 6
    [ 1837.281772] usb 2-1.2: new high-speed USB device number 9 using ehci-pci
    [ 1837.375446] usb 2-1.2: New USB device found, idVendor=8644, idProduct=8003
    [ 1837.375454] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber
    =3
    [ 1837.375460] usb 2-1.2: Product: USB Flash Disk
    [ 1837.375464] usb 2-1.2: Manufacturer: General
    [ 1837.375468] usb 2-1.2: SerialNumber: 03363000000321D9
    [ 1837.375864] usb-storage 2-1.2:1.0: USB Mass Storage device detected
    [ 1837.376040] scsi host6: usb-storage 2-1.2:1.0
    [ 1838.374696] scsi 6:0:0:0: Direct-Access     General  USB Flash Disk   1.00 PQ
    : 0 ANSI: 2
    [ 1838.375378] sd 6:0:0:0: Attached scsi generic sg2 type 0
    [ 1838.375959] sd 6:0:0:0: [sdb] 31299584 512-byte logical blocks: (16.0 GB/14.9
    GiB)
    [ 1838.376636] sd 6:0:0:0: [sdb] Write Protect is off
    [ 1838.376643] sd 6:0:0:0: [sdb] Mode Sense: 03 00 00 00
    [ 1838.377333] sd 6:0:0:0: [sdb] No Caching mode page found
    [ 1838.377342] sd 6:0:0:0: [sdb] Assuming drive cache: write through
    [ 1838.388379]  sdb: sdb1
    [ 1838.391760] sd 6:0:0:0: [sdb] Attached SCSI removable disk
    [ 1838.605774] FAT-fs (sdb1): Volume was not properly unmounted. Some data may b
    e corrupt. Please run fsck.
    [ 1838.698735] systemd-hostnamed[5016]: Warning: nss-myhostname is not installed
    . Changing the local hostname might make it unresolveable. Please install nss-my
    hostname!
    [ 5289.111524] usb 2-1.2: USB disconnect, device number 9
    [ 5693.773970] perf interrupt took too long (2523 > 2500), lowering kernel.perf_
    event_max_sample_rate to 50000
    [ 5835.887499] usb 2-1.2: new high-speed USB device number 10 using ehci-pci
    [ 5835.981072] usb 2-1.2: New USB device found, idVendor=8644, idProduct=8003
    [ 5835.981078] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber
    =3
    [ 5835.981082] usb 2-1.2: Product: USB Flash Disk
    [ 5835.981085] usb 2-1.2: Manufacturer: General
    [ 5835.981087] usb 2-1.2: SerialNumber: 03363000000321D9
    [ 5835.981441] usb-storage 2-1.2:1.0: USB Mass Storage device detected
    [ 5835.981591] scsi host7: usb-storage 2-1.2:1.0
    [ 5836.980268] scsi 7:0:0:0: Direct-Access     General  USB Flash Disk   1.00 PQ
    : 0 ANSI: 2
    [ 5836.980630] sd 7:0:0:0: Attached scsi generic sg2 type 0
    [ 5836.985767] sd 7:0:0:0: [sdb] 31299584 512-byte logical blocks: (16.0 GB/14.9
    GiB)
    [ 5836.986436] sd 7:0:0:0: [sdb] Write Protect is off
    [ 5836.986443] sd 7:0:0:0: [sdb] Mode Sense: 03 00 00 00
    [ 5836.987055] sd 7:0:0:0: [sdb] No Caching mode page found
    [ 5836.987060] sd 7:0:0:0: [sdb] Assuming drive cache: write through
    [ 5836.992814]  sdb: sdb1
    [ 5836.996055] sd 7:0:0:0: [sdb] Attached SCSI removable disk
    [ 5837.205070] FAT-fs (sdb1): Volume was not properly unmounted. Some data may b
    [ 5837.313680] systemd-hostnamed[5324]: Warning: nss-myhostname is not installed
    hostname!
    [ 5872.044364] usb 2-1.2: USB disconnect, device number 10
    [ 6045.618391] usb 2-1.3: USB disconnect, device number 3
    [ 6051.427179] usb 2-1.3: new low-speed USB device number 11 using ehci-pci
    [ 6051.524247] usb 2-1.3: New USB device found, idVendor=1bcf, idProduct=0007
    [ 6051.524255] usb 2-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber
    =0
    [ 6051.524260] usb 2-1.3: Product: USB Optical Mouse
    [ 6051.531477] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2
    /2-1/2-1.3/2-1.3:1.0/0003:1BCF:0007.0002/input/input20
    [ 6051.587698] hid-generic 0003:1BCF:0007.0002: input,hiddev0,hidraw0: USB HID v
    1.10 Mouse [USB Optical Mouse] on usb-0000:00:1d.0-1.3/input0
    [ 6508.563342] usb 1-1.4: new high-speed USB device number 4 using ehci-pci
    [ 6508.665606] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6010
    [ 6508.665614] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber
    =3
    [ 6508.665620] usb 1-1.4: Product: Digilent Adept USB Device
    [ 6508.665624] usb 1-1.4: Manufacturer: Digilent
    [ 6508.665628] usb 1-1.4: SerialNumber: 210203A02D73
    [ 6508.695338] usb 2-1.2: new full-speed USB device number 12 using ehci-pci
    [ 6508.707145] usbcore: registered new interface driver usbserial
    [ 6508.707156] usbcore: registered new interface driver usbserial_generic
    [ 6508.707166] usbserial: USB Serial support registered for generic
    [ 6508.725784] usbcore: registered new interface driver ftdi_sio
    [ 6508.725802] usbserial: USB Serial support registered for FTDI USB Serial Devi
    ce
    [ 6508.725867] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
    [ 6508.725914] usb 1-1.4: Detected FT2232H
    [ 6508.726565] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUS
    B0
    [ 6508.726600] ftdi_sio 1-1.4:1.1: FTDI USB Serial Device converter detected
    [ 6508.726648] usb 1-1.4: Detected FT2232H
    [ 6508.727005] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUS
    B1
    [ 6508.789850] usb 2-1.2: New USB device found, idVendor=10c4, idProduct=ea60
    [ 6508.789859] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber
    =3
    [ 6508.789865] usb 2-1.2: Product: CP2103 USB to UART Bridge Controller
    [ 6508.789869] usb 2-1.2: Manufacturer: Silicon Labs
    [ 6508.789873] usb 2-1.2: SerialNumber: 0001
    [ 6508.815001] usbcore: registered new interface driver cp210x
    [ 6508.815017] usbserial: USB Serial support registered for cp210x
    [ 6508.815043] cp210x 2-1.2:1.0: cp210x converter detected
    [ 6508.815154] usb 2-1.2: cp210x converter now attached to ttyUSB2
    [ 6568.152116] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnect
    ed from ttyUSB0
    [ 6568.152155] ftdi_sio 1-1.4:1.0: device disconnected
    [ 6568.152311] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnect
    ed from ttyUSB1
    [ 6568.152343] ftdi_sio 1-1.4:1.1: device disconnected
Reply
    =3
    =3
    : 0 ANSI: 2
    GiB)
    hostname!
    =3
    : 0 ANSI: 2
    GiB)
    hostname!
    =0
    =3
    ce
    B0
    B1
    =3
    ed from ttyUSB0
    ed from ttyUSB1
Children
No Data
