IIOD - how to launch "IIOD" manually , how to check IIOD running logs ?
I use  "ADRV9009-W/PCBZ + A10 SOCFPGA KIT Board".  When A10 SocFpga start into Linux OS ,IIO Daemon was launched  automatically by “ /etc/init.d/iiod ”,
1) My aim is to disable this IIOD auto-running when Linux start-up, then when needed we start IIOD manually .  How to implement  this ?
2) Another queyr :  does IIOD provide executing logs, coz I want to check its log info. For example IIOD has print as "        INFO("New client connected from %s\n",
                inet_ntoa(caddr.sin_addr)); "
      How can I check these logs ?  (maybe I want to add my own log for further debug~) .
Thanks for clarify
Parents
  • OK. I had fixed my issue in this ticket.
    for question (1) - just run "  /etc/init.d# ./iiod stop " to  stop IIOD manually.
    for question (2) - I just change " iiod script " to bring IIOD launch on front, instead of on background !!
    --               #if start-stop-daemon -S -b -q -m -p /var/run/iiod.pid -x /usr/sbin/iiod -- $IIOD_OPTS; then
    ++               if start-stop-daemon -S -m -p /var/run/iiod.pid -x /usr/sbin/iiod -- $IIOD_OPTS; then
    THEN I can check iiod 's running logs now.  This ticket can be marked as "ANSWERED".
    sorry for interrupt if any
Reply
Children
No Data
