Enabling FIR filter of AD9364 through LINUX commands
Hi ,
I am working on ZC706  + fmcomms setup with linux running from my SD Card.  While trying to enable FIR filter in AD9364 through fir_filter_config = 1, I got the following error messages. some register values are displayed saying kernel panic occurred and driver aborts execution. I attached the ERROR LOG for the reference. Kindly suggest us how to do it in the right way ?
But I could successfully use the filter in bare-metal version of the driver.
root@plnx_arm:/sys/bus/iio/devices/iio:device0# cd ..
root@plnx_arm:/sys/bus/iio/devices# cd /home/root
root@plnx_arm:~# tftp -r 2.txt -l 2.txt -g 192.168.2.2
root@plnx_arm:~# cat /home/root/2.txt> filter_fir_config
root@plnx_arm:~# cat filter_fir_config
TX 3 GAIN 0 INT 1
RX 3 GAIN 0 DEC 1
RTX 1056000000 264000000 132000000 66000000 33000000 33000000
RRX 1056000000 264000000 132000000 66000000 33000000 33000000
BWTX 30000000
BWRX 30000000
0, 0
1, 1
0, 0
-1, -1
0, 0
2, 2
-1, -1
-2, -2
1, 1
2, 2
-2, -2
-2, -2
2, 2
2, 2
-3, -3
-2, -2
5, 5
0, 0
-6, -6
1, 1
8, 8
-4, -4
-9, -9
8, 8
11, 11
-12, -12
-12, -12
17, 17
13, 13
-23, -23
-12, -12
28, 28
9, 9
-34, -34
-2, -2
38, 38
-9, -9
-41, -41
27, 27
41, 41
-54, -54
-39, -39
93, 93
35, 35
-147, -147
-27, -27
220, 220
17, 17
-319, -319
-5, -5
451, 451
-8, -8
-632, -632
21, 21
886, 886
-34, -34
-1268, -1268
46, 46
1922, 1922
-55, -55
-3376, -3376
60, 60
10396, 10396
16321, 16321 root@plnx_arm:~# cd /sys/bus/iio/devices/iio:device0
_confignx_arm:/sys/bus/iio/devices/iio:device0# cat /home/root/2.txt> filter_fir
root@plnx_arm:/sys/bus/iio/devices/iio:device0# cat filter_fir_config
FIR Rx: 64,1 Tx: 64,1
ir_enplnx_arm:/sys/bus/iio/devices/iio:device0# echo 1 > in_out_voltage_filter_f
Unable to handle kernel NULL pointer dereference at virtual address 00000314
pgd = c7e7c000
[00000314] *pgd=3ec8f831
Internal error: Oops - BUG: 17 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1191 Comm: sh Not tainted 4.9.0-xilinx #11
Hardware name: Xilinx Zynq Platform
task: ef32d440 task.stack: eea2a000
PC is at ad9361_hdl_loopback+0x20/0xe0
LR is at ad9361_bist_loopback+0x90/0xb8
pc : [<c04fb6b8>]    lr : [<c04f5e08>]    psr: a0080013
sp : eea2bce8  ip : 00000000  fp : 00000000
r10: ee931680  r9 : 00000000  r8 : 00000000
r7 : ee931610  r6 : ee9cfa10  r5 : 00000000  r4 : ef1da2c0
r3 : ef1d8400  r2 : 00000001  r1 : 00000000  r0 : ef1da2c0
Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
Control: 18c5387d  Table: 07e7c04a  DAC: 00000051
Process sh (pid: 1191, stack limit = 0xeea2a210)
Stack: (0xeea2bce8 to 0xeea2c000)
bce0:                   ef1da2c0 00000000 00000001 ef1da2c0 00000000 00000000
bd00: ee931610 00000000 eea2be10 ee931680 00000000 c04f5e08 00000000 ef1da2c0
bd20: 00000000 00000010 00000000 c04fc2ac 00000000 00000000 00000000 00000000
bd40: 00000000 00000000 00000000 00000000 0000000a 00000000 ef1d8400 ef1d8400
bd60: 00000000 ef1d8400 eea2be10 c04ef3a8 00000000 00000002 0000005d 5d02805c
bd80: 00000000 ef1d8400 00000002 ef1da2c0 00000000 eea2bdf8 ee931610 ef1d8400
bda0: eea2be10 ee931680 00000006 c04f16a0 00000001 00000002 eede3a40 ee931698
bdc0: ef1da304 ef1da2f0 00000000 ee931610 ef1da2c0 ef1d8400 00000001 01f78a40
bde0: ef1da1c8 00000002 00000000 c04f5504 ef17e4d0 b6f6c000 3ef14800 0fbc5200
be00: 07de2900 03ef1480 01f78a40 01f78a40 3ef14800 0fbc5200 07de2900 03ef1480
be20: 01f78a40 01f78a40 ef1da010 00000000 ee931610 ef293480 ef1da2c0 c04f6d80
be40: ef32d440 0000081f b6efbd60 3b7c77df c7e7edb8 ef17e4d0 00000055 ef32d440
be60: 0000081f b6efbd60 ef399a80 c01b5564 eed9c660 eea2a000 00000002 00000040
be80: eea2bed8 ef17e4d0 b6f6c000 00000055 c7e7edb8 ffeee5b0 effd007c 00000000
bea0: eea2bea0 01a2bfb0 b6f6c000 ffffffff 00000055 00000002 c7d1e680 ef293480
bec0: eea2bf88 c7d1e68c 00000051 00000000 00000000 c0224134 00000000 00000000
bee0: 00000002 c0223fc4 ef18b900 eea2bf88 b6f6c000 c01070c4 eea2a000 c01ce348
bf00: 000eb134 b6efbd60 beb539ec c0101284 beb53254 c01deb54 00000000 eea2bf60
bf20: 0000000a c7dfb980 ef256b00 ef256b40 00000000 c01e895c 00000001 ef18b900
bf40: eea2bf88 00000002 00000002 00000002 ef18b900 eea2bf88 b6f6c000 c01cefa8
bf60: ef18b900 b6f6c000 00000002 ef18b900 ef18b900 b6f6c000 00000002 c01070c4
bf80: eea2a000 c01cfb88 00000000 00000000 00000002 00000002 b6f6c000 b6efbd60
bfa0: 00000004 c0106f00 00000002 b6f6c000 00000001 b6f6c000 00000002 00000000
bfc0: 00000002 b6f6c000 b6efbd60 00000004 00000000 000eb134 000cf820 00000000
bfe0: 00000000 beb5399c b6e26b8c b6e808e0 600e0010 00000001 2fffd861 2fffdc61
[<c04fb6b8>] (ad9361_hdl_loopback) from [<c04f5e08>] (ad9361_bist_loopback+0x90/0xb8)
[<c04f5e08>] (ad9361_bist_loopback) from [<c04fc2ac>] (ad9361_dig_tune+0xac/0x4b8)
[<c04fc2ac>] (ad9361_dig_tune) from [<c04f16a0>] (ad9361_set_trx_clock_chain+0x2a0/0x310)
[<c04f16a0>] (ad9361_set_trx_clock_chain) from [<c04f5504>] (ad9361_validate_enable_fir+0x228/0x2ac)
[<c04f5504>] (ad9361_validate_enable_fir) from [<c04f6d80>] (ad9361_phy_store+0x2dc/0xa2c)
[<c04f6d80>] (ad9361_phy_store) from [<c0224134>] (kernfs_fop_write+0x170/0x1ac)
[<c0224134>] (kernfs_fop_write) from [<c01ce348>] (__vfs_write+0x1c/0x108)
[<c01ce348>] (__vfs_write) from [<c01cefa8>] (vfs_write+0xb8/0x144)
[<c01cefa8>] (vfs_write) from [<c01cfb88>] (SyS_write+0x40/0x80)
[<c01cfb88>] (SyS_write) from [<c0106f00>] (ret_fast_syscall+0x0/0x3c)
Code: 03e00012 0a00002f e596b0cc e1a09001 (e59b3314)
---[ end trace 94c3e70c45de6fd2 ]---
/bin/start_getty: line 5:  1191 Segmentation fault      /sbin/getty -L $1 $2
PetaLinux 2016.4 plnx_arm /dev/ttyPS0
Thank you,
raj
     Thanks for the reply. Please find the complete log from initial
    filt_log_2.txt
    U-Boot 2016.07 (Jul 28 2018 - 11:18:21 +0530)
    DRAM:  ECC disabled 1 GiB
    MMC:   sdhci@e0100000: 0
    SF: Detected N25Q128A with page size 512 Bytes, erase size 128 KiB, total 32 MiB
    *** Warning - bad CRC, using default environment
    ## Error: flags type check failure for "serverip" <= "AUTO" (type: i)
    himport_r: can't insert "serverip=AUTO" into hash table
    In:    serial
    Out:   serial
    Err:   serial
    Net:   ZYNQ GEM: e000b000, phyaddr -1, interface rgmii-id
    Warning: ethernet@e000b000 (eth1) using random MAC address - d2:2f:3b:4d:bf:b0
    eth1: ethernet@e000b000ZYNQ GEM: e000c000, phyaddr -1, interface gmii
    mdio_register: non unique device name 'gem'
    U-BOOT for
    Hit any key to stop autoboot:  0
    device 0 offset 0x5fe680, size 0x1330000
    SF: 20119552 bytes @ 0x5fe680 Read: OK
    ## Loading kernel from FIT Image at 10000000 ...
       Using 'conf@1' configuration
       Verifying Hash Integrity ... OK
       Trying 'kernel@0' kernel subimage
         Description:  Linux Kernel
         Type:         Kernel Image
         Compression:  uncompressed
         Data Start:   0x100000d4
         Data Size:    3806472 Bytes = 3.6 MiB
         Architecture: ARM
         OS:           Linux
         Load Address: 0x00008000
         Entry Point:  0x00008000
         Hash algo:    sha1
         Hash value:   13779d8ab4956c9ae58997e817030a96b633eee5
       Verifying Hash Integrity ... sha1+ OK
    ## Loading ramdisk from FIT Image at 10000000 ...
       Trying 'ramdisk@0' ramdisk subimage
         Description:  ramdisk
         Type:         RAMDisk Image
         Data Start:   0x103a73d0
         Data Size:    16256712 Bytes = 15.5 MiB
         Architecture: ARM
         OS:           Linux
         Load Address: unavailable
         Entry Point:  unavailable
         Hash algo:    sha1
         Hash value:   8fd0354cdc156917087775c2316f54fc6af97f0c
    ## Loading fdt from FIT Image at 10000000 ...
       Trying 'fdt@0' fdt subimage
         Description:  Flattened Device Tree blob
         Type:         Flat Device Tree
         Data Start:   0x103a16d0
         Data Size:    23629 Bytes = 23.1 KiB
         Architecture: ARM
         Hash algo:    sha1
         Hash value:   039a5ebb176fda080bc7fff085eef601ee8addef
       Booting using the fdt blob at 0x103a16d0
       Loading Kernel Image ... OK
       Loading Ramdisk to 0707f000, end 07fffec8 ... OK
       Loading Device Tree to 07076000, end 0707ec4c ... OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    Booting Linux on physical CPU 0x0
    Linux version 4.9.0-xilinx (crl@localhost.localdomain) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #33 SMP PREEMPT Sat Jul 28 11:07:57 IST 2018
    CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
    CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    OF: fdt:Machine model: cusv2
    bootconsole [earlycon0] enabled
    cma: Reserved 16 MiB at 0x3f000000
    Memory policy: Data cache writealloc
    percpu: Embedded 14 pages/cpu @ef7cd000 s25984 r8192 d23168 u57344
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
    Kernel command line: console=ttyPS0,115200 earlyprintk
    PID hash table entries: 4096 (order: 2, 16384 bytes)
    Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    Memory: 996956K/1048576K available (6144K kernel code, 204K rwdata, 1516K rodata, 1024K init, 230K bss, 35236K reserved, 16384K cma-reserved, 245760K highmem)
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
        vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
        lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
        pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
        modules : 0xbf000000 - 0xbfe00000   (  14 MB)
          .text : 0xc0008000 - 0xc0700000   (7136 kB)
          .init : 0xc0900000 - 0xc0a00000   (1024 kB)
          .data : 0xc0a00000 - 0xc0a33380   ( 205 kB)
           .bss : 0xc0a33380 - 0xc0a6cd98   ( 231 kB)
    Preemptible hierarchical RCU implementation.
            Build-time adjustment of leaf fanout to 32.
            RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
    NR_IRQS:16 nr_irqs:16 16
    efuse mapped to f0802000
    slcr mapped to f0804000
    L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C-310 erratum 769419 enabled
    L2C-310 enabling early BRESP for Cortex-A9
    L2C-310 full line of zeros enabled for Cortex-A9
    L2C-310 ID prefetch enabled, offset 1 lines
    L2C-310 dynamic clock gating enabled, standby mode enabled
    L2C-310 cache controller enabled, 8 ways, 512 kB
    L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
    zynq_clock_init: clkc starts at f0804100
    Zynq clock init
    sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
    clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
    Switching to timer-based delay loop, resolution 3ns
    clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
    timer #0 at f080c000, irq=17
    Console: colour dummy device 80x30
    Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    CPU: Testing write buffer coherency: ok
    CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Setting up static identity map for 0x100000 - 0x100058
    CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    Brought up 2 CPUs
    SMP: Total of 2 processors activated (1333.33 BogoMIPS).
    CPU: All CPU(s) started in SVC mode.
    devtmpfs: initialized
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    pinctrl core: initialized pinctrl subsystem
    NET: Registered protocol family 16
    DMA: preallocated 256 KiB pool for atomic coherent allocations
    cpuidle: using governor menu
    hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    hw-breakpoint: maximum watchpoint size is 4 bytes.
    zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
    zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
    vgaarb: loaded
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    media: Linux media interface: v0.10
    Linux video capture interface: v2.00
    pps_core: LinuxPPS API ver. 1 registered
    pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    PTP clock support registered
    EDAC MC: Ver: 3.0.0
    FPGA manager framework
    Advanced Linux Sound Architecture Driver Initialized.
    clocksource: Switched to clocksource arm_global_timer
    NET: Registered protocol family 2
    TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    TCP: Hash tables configured (established 8192 bind 8192)
    UDP hash table entries: 512 (order: 2, 16384 bytes)
    UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    Trying to unpack rootfs image as initramfs...
    Freeing initrd memory: 15876K (c707f000 - c8000000)
    hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
    futex hash table entries: 512 (order: 3, 32768 bytes)
    workingset: timestamp_bits=30 max_order=18 bucket_order=0
    jffs2: version 2.2. (NAND) (SUMMARY)  � 2001-2006 Red Hat, Inc.
    bounce: pool size: 64 pages
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
    dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
    xilinx-vdma 7e200000.dma: Xilinx AXI VDMA Engine Driver Probed!!
    e0000000.serial: ttyPS1 at MMIO 0xe0000000 (irq = 27, base_baud = 3125000) is a xuartps
    e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 28, base_baud = 3125000) is a xuartps
    �console [ttyPS0] enabled
    bootconsole [earlycon0] disabled
    xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f08c3000
    [drm] Initialized
    brd: module loaded
    loop: module loaded
    m25p80 spi0.0: SPI-NOR-UniqueID 104400228c93000af3ff360051e341e4b2
    m25p80 spi0.0: found n25q128a11, expected m25p80
    m25p80 spi0.0: n25q128a11 (32768 Kbytes)
    4 ofpart partitions found on MTD device spi0.0
    Creating 4 MTD partitions on "spi0.0":
    0x000000000000-0x000001940000 : "boot"
    0x000001940000-0x000001960000 : "bootenv"
    0x000001960000-0x000001fe0000 : "jffs2"
    0x000001fe0000-0x000002000000 : "spare"
    libphy: Fixed MDIO Bus: probed
    CAN device driver interface
    libphy: MACB_mii_bus: probed
    macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 32 (00:0a:35:00:1e:53)
    Marvell 88E1510 e000b000.etherne:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=e000b000.etherne:00, irq=-1)
    macb e000c000.ethernet eth1: Cadence GEM rev 0x00020118 at 0xe000c000 irq 33 (00:0a:35:00:1e:53)
    Marvell 88E1111 e000c000.etherne:07: attached PHY driver [Marvell 88E1111] (mii_bus:phy_addr=e000c000.etherne:07, irq=-1)
    e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    ehci-pci: EHCI PCI platform driver
    usbcore: registered new interface driver usb-storage
    e0002000.usb supply vbus not found, using dummy regulator
    ci_hdrc ci_hdrc.0: unable to init phy: -110
    ci_hdrc: probe of ci_hdrc.0 failed with error -110
    mousedev: PS/2 mouse device common for all mice
    i2c /dev entries driver
    cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 23
    cdns-i2c e0005000.i2c: 400 kHz mmio e0005000 irq 24
    cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at f092c000 with timeout 10s
    EDAC MC: ECC not enabled
    Xilinx Zynq CpuIdle Driver started
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    sdhci-pltfm: SDHCI platform and OF driver helper
    mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using DMA
    ledtrig-cpu: registered to indicate activity on CPUs
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    ad9361 spi32766.0: ad9361_probe : enter (ad9364)
    random: fast init done
    ad9361 spi32766.0: ad9361_probe: failed to register debugfs
    ad9361 spi32766.0: ad9361_probe : AD936x Rev 2 successfully initialized
    ad9361 spi32766.1: ad9361_probe : enter (ad9364)
    ad9361 spi32766.1: ad9361_probe: failed to register debugfs
    ad9361 spi32766.1: ad9361_probe : AD936x Rev 2 successfully initialized
    NET: Registered protocol family 10
    sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    can: controller area network core (rev 20120528 abi 9)
    NET: Registered protocol family 29
    can: raw protocol (rev 20120528)
    can: broadcast manager protocol (rev 20161123 t)
    can: netlink gateway (rev 20130117) max_hops=1
    Registering SWP/SWPB emulation handler
    hctosys: unable to open rtc device (rtc0)
    of_cfs_init
    of_cfs_init: OK
    ALSA device list:
      No soundcards found.
    Freeing unused kernel memory: 1024K (c0900000 - c0a00000)
    INIT: version 2.88 booting
    Sat Jul 28 09:03:23 UTC 2018
    Starting internet superserver: inetd.
     Starting test
    root
    waveform initialization
    fpga/
    fpga/cus8_0700.bit
    fpga/cus100.bit
    fpga bit stream configuration
    Ethrnet configuration
    IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    Kernel IP routing table
    Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
    192.168.1.0     0.0.0.0         255.255.255.0   U         0 0          0 eth1
    192.168.31.0    0.0.0.0         255.255.255.0   U         0 0          0 eth0
    snmp initialization
    snmp/share/man/man3/netsnmp_trap_api.3
    snmp/share/snmp/mib2c-data/syntax-StorageType-dependencies.m2i
    snmp/share/snmp/snmpconf-data/snmptrapd-data/snmpconf-config
    snmp/share/snmp/mib2c.container.conf
    snmp/include/net-snmp/system/solaris2.4.h
    snmp/share/snmp/mib2c-data/generic-table-indexes-varbind-setup.m2i
    snmp/share/man/man3/snmp_pdu_create.3
    snmp/share/man/man5/variables.5
    snmp/share/snmp/mibs/UCD-SNMP-MIB.txt
    snmp/share/man/man3/snmp_varlist_add_variable.3
    snmp/share/man/man3/netsnmp_read_module.3
    snmp/lib/libnetsnmpagent.so.30
    snmp/share/snmp/snmpconf-data/snmp-data/snmpconf-config
    snmp/include/net-snmp/agent/read_only.h
    snmp/share/snmp/mibs/DISMAN-SCRIPT-MIB.txt
    snmp/share/man/man3/snmp_error.3
    snmp/share/
    snmp/share/snmp/mib2c-data/details-enums.m2i
    snmp/include/net-snmp/library/snmp_api.h
    snmp/include/net-snmp/agent/set_helper.h
    snmp/share/man/man3/snmp_clone_varbind.3
    snmp/share/snmp/mib2c-data/mfd-doxygen.m2c
    snmp/include/net-snmp/library/snmpAliasDomain.h
    snmp/share/snmp/mibs/IANA-ADDRESS-FAMILY-NUMBERS-MIB.txt
    snmp/share/snmp/mibs/SNMP-TLS-TM-MIB.txt
    snmp/share/man/man1/snmpinform.1
    snmp/include/net-snmp/library/large_fd_set.h
    snmp/lib/libnetsnmp.a
    snmp/bin/snmpbulkwalk
    snmp/include/net-snmp/agent/snmp_vars.h
    snmp/include/net-snmp/agent/agent_trap.h
    snmp/share/man/man1/snmpnetstat.1
    snmp/include/net-snmp/net-snmp-config.h
    snmp/include/net-snmp/agent/mib_module_config.h
    snmp/share/man/man3/snmp_set_save_descriptions.3
    snmp/share/snmp/mibs/HOST-RESOURCES-TYPES.txt
    snmp/include/net-snmp/types.h
    snmp/share/man/man3/snmp_alarm_register_hr.3
    snmp/include/net-snmp/agent/table_data.h
    snmp/share/snmp/mibs/SNMPv2-TM.txt
    snmp/include/net-snmp/agent/agent_sysORTable.h
    snmp/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    snmp/share/snmp/mibs/SNMP-VIEW-BASED-ACM-MIB.txt
    snmp/include/net-snmp/system/solaris2.3.h
    snmp/share/man/man1/snmpget.1
    snmp/lib/libnetsnmptrapd.so.30.0.3
    snmp/bin/fixproc
    snmp/share/snmp/mib2c-data/node-storage.m2i
    snmp/share/snmp/mib2c-data/generic-table-indexes-set.m2i
    snmp/bin/snmpvacm
    snmp/share/man/man3/shutdown_mib.3
    snmp/share/snmp/mib2c-data/m2c-internal-warning.m2i
    snmp/share/snmp/mibs/HCNUM-TC.txt
    snmp/share/man/man1/snmpconf.1
    snmp/share/snmp/mib2c-data/generic-get-oid.m2i
    snmp/share/man/man1/mib2c.1
    snmp/include/net-snmp/agent/util_funcs/
    snmp/include/net-snmp/snmpv3_api.h
    snmp/sbin/snmpd
    snmp/include/net-snmp/agent/all_helpers.h
    snmp/lib/libnetsnmphelpers.so.30.0.3
    snmp/share/snmp/mib2c-data/syntax-TestAndIncr-get.m2i
    snmp/share/snmp/mib2c-data/generic-table-enums.m2c
    snmp/share/snmp/mib2c-data/syntax-InetAddress-set.m2i
    snmp/share/man/man3/snmp_sess_close.3
    snmp/include/net-snmp/agent/row_merge.h
    snmp/share/man/man1/net-snmp-config.1
    snmp/share/man/man3/snmp_alarm.3
    snmp/share/man/man1/snmpbulkget.1
    snmp/share/man/man1/tkmib.1
    snmp/include/net-snmp/library/snmpCallbackDomain.h
    snmp/share/snmp/mib2c.perl.conf
    snmp/include/net-snmp/agent/agent_read_config.h
    snmp/share/man/man3/add_module_replacement.3
    snmp/share/man/man3/register_prenetsnmp_mib_handler.3
    snmp/share/man/man3/unregister_app_config_handler.3
    snmp/share/man/man3/register_app_config_handler.3
    snmp/share/man/man3/snmp_api_errstring.3
    snmp/include/net-snmp/library/container_binary_array.h
    snmp/share/snmp/mib2c-data/generic-table-indexes-to-oid.m2i
    snmp/share/snmp/mibs/IANA-RTPROTO-MIB.txt
    snmp/share/man/man3/snmp_perror.3
    snmp/lib/libnetsnmp.so
    snmp/include/net-snmp/library/snmp_secmod.h
    snmp/share/snmp/mib2c-data/mfd-data-set.m2c
    snmp/bin/net-snmp-cert
    snmp/include/net-snmp/agent/var_struct.h
    snmp/include/net-snmp/agent/old_api.h
    snmp/include/net-snmp/definitions.h
    snmp/share/snmp/mib2c-data/generic-ctx-set.m2i
    snmp/share/snmp/mib2c.array-user.conf
    snmp/include/net-snmp/library/default_store.h
    snmp/share/snmp/mib2c-data/generic-get-decl-bot.m2i
    snmp/share/snmp/mib2c.old-api.conf
    snmp/share/man/man5/snmpd.conf.5
    snmp/include/net-snmp/library/text_utils.h
    snmp/include/net-snmp/agent/agent_registry.h
    snmp/share/snmp/mibs/SMUX-MIB.txt
    snmp/include/net-snmp/library/check_varbind.h
    snmp/share/snmp/snmpd.conf
    snmp/include/net-snmp/mib_api.h
    snmp/bin/snmpusm
    snmp/include/net-snmp/library/snmp.h
    snmp/include/net-snmp/system/openbsd.h
    snmp/include/net-snmp/agent/scalar.h
    snmp/share/snmp/mibs/IPV6-FLOW-LABEL-MIB.txt
    snmp/share/snmp/mib2c.raw-table.conf
    snmp/share/snmp/mibs/SNMP-MPD-MIB.txt
    snmp/share/snmp/mib2c-data/mfd-interactive-setup.m2c
    snmp/share/man/man3/snmp_add_null_var.3
    snmp/include/net-snmp/system/bsdi.h
    snmp/include/net-snmp/agent/bulk_to_next.h
    snmp/share/man/man3/unregister_all_config_handlers.3
    snmp/share/man/man3/register_mib_handlers.3
    snmp/share/man/man3/snprint_variable.3
    snmp/include/net-snmp/agent/cache_handler.h
    snmp/share/man/man1/snmpstatus.1
    snmp/share/man/man3/snmp_free_varbind.3
    snmp/share/snmp/mib2c-data/syntax-RowStatus-get.m2i
    snmp/share/snmp/mibs/SCTP-MIB.txt
    snmp/share/snmp/mibs/BEL-MIB.txt
    snmp/share/man/man3/snmp_alarm_unregister.3
    snmp/share/man/man3/snmp_sess_perror.3
    snmp/share/snmp/mib2c-data/syntax-DateAndTime-get.m2i
    snmp/include/net-snmp/library/snmpSocketBaseDomain.h
    snmp/share/man/man5/snmptrapd.conf.5
    snmp/share/snmp/mibs/TRANSPORT-ADDRESS-MIB.txt
    snmp/include/net-snmp/utilities.h
    snmp/include/net-snmp/library/ucd_compat.h
    snmp/share/snmp/mib2c-data/syntax-DateAndTime-get.m2d
    snmp/include/net-snmp/system/freebsd9.h
    snmp/include/net-snmp/library/snmpTCPBaseDomain.h
    snmp/include/net-snmp/library/snmpv3.h
    snmp/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
    snmp/share/man/man3/snmp_close.3
    snmp/share/snmp/mib2c.check_values.conf
    snmp/share/snmp/mib2c-data/default-mfd-top.m2c
    snmp/share/snmp/mib2c.check_values_local.conf
    snmp/include/
    snmp/include/net-snmp/library/oid.h
    snmp/include/net-snmp/library/snmpTCPDomain.h
    snmp/share/snmp/mibs/IF-INVERTED-STACK-MIB.txt
    snmp/share/snmp/mibs/BEL-HCRR-IDU-MIB.txt
    snmp/share/snmp/mibs/SNMP-COMMUNITY-MIB.txt
    snmp/share/snmp/mibs/SNMPv2-SMI.txt
    snmp/include/net-snmp/library/snmpUDPIPv4BaseDomain.h
    snmp/share/snmp/mibs/IPV6-UDP-MIB.txt
    snmp/include/net-snmp/version.h
    snmp/include/net-snmp/system/mingw32.h
    snmp/include/net-snmp/library/int64.h
    snmp/share/snmp/mib2c.notify.conf
    snmp/share/snmp/mibs/DISMAN-EVENT-MIB.txt
    snmp/share/snmp/mib2c-data/m2c_setup_node.m2i
    snmp/bin/snmpcheck
    snmp/share/man/man3/unregister_config_handler.3
    snmp/include/net-snmp/agent/agent_module_config.h
    snmp/include/net-snmp/system/dynix.h
    snmp/share/man/man3/read_all_mibs.3
    snmp/share/man/man3/snmp_clone_pdu.3
    snmp/share/snmp/mib2c.iterate_access.conf
    snmp/share/man/man3/fprint_value.3
    snmp/share/snmp/mib2c.create-dataset.conf
    snmp/include/net-snmp/library/tools.h
    snmp/share/man/man3/snmp_fix_pdu.3
    snmp/share/man/
    snmp/share/snmp/mibs/UCD-DLMOD-MIB.txt
    snmp/share/snmp/mib2c-data/syntax-InetAddress-get.m2i
    snmp/share/snmp/mib2c-data/mfd-readme.m2c
    snmp/share/man/man3/read_premib_configs.3
    snmp/include/net-snmp/system/sunos.h
    snmp/share/man/man3/send_v2trap.3
    snmp/share/snmp/mibs/INET-ADDRESS-MIB.txt
    snmp/include/net-snmp/agent/baby_steps.h
    snmp/include/net-snmp/agent/mib_modules.h
    snmp/include/net-snmp/system/freebsd8.h
    snmp/include/net-snmp/system/ultrix4.h
    snmp/share/snmp/snmpconf-data/snmp-data/debugging
    snmp/include/net-snmp/library/snmp_impl.h
    snmp/share/man/man3/snprint_objid.3
    snmp/bin/ipf-mod.pl
    snmp/include/net-snmp/agent/watcher.h
    snmp/share/man/man3/snmp_sess_init.3
    snmp/share/man/man1/encode_keychange.1
    snmp/share/snmp/snmpconf-data/snmp-data/mibs
    snmp/include/net-snmp/agent/struct.h
    snmp/share/snmp/snmpconf-data/snmptrapd-data/runtime
    snmp/share/snmp/mib2c-data/generic-ctx-get.m2i
    snmp/include/net-snmp/agent/stash_to_next.h
    snmp/share/man/man1/snmpdelta.1
    snmp/bin/snmpstatus
    snmp/include/net-snmp/library/cert_util.h
    snmp/share/man/man3/snmp_synch_response.3
    snmp/bin/snmpdelta
    snmp/share/snmp/mib2c-data/parent-dependencies.m2i
    snmp/include/net-snmp/agent/instance.h
    snmp/share/man/man3/register_const_config_handler.3
    snmp/share/man/man5/mib2c.conf.5
    snmp/share/snmp/mibs/AGENTX-MIB.txt
    snmp/include/net-snmp/library/parse.h
    snmp/share/snmp/mib2c-data/generic-source-includes.m2i
    snmp/share/man/man3/default_store.3
    snmp/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
    snmp/share/snmp/mibs/SNMPv2-MIB.txt
    snmp/share/snmp/mibs/DISMAN-SCHEDULE-MIB.txt
    snmp/include/net-snmp/system/dragonfly.h
    snmp/share/man/man3/snmp_set_var_objid.3
    snmp/share/snmp/mib2c-data/syntax-InetAddressType-set.m2i
    snmp/share/snmp/snmpconf-data/snmptrapd-data/formatting
    snmp/include/net-snmp/system/darwin10.h
    snmp/share/snmp/mib2c.table_data.conf
    snmp/include/net-snmp/system/freebsd7.h
    snmp/include/net-snmp/agent/mode_end_call.h
    snmp/include/net-snmp/library/getopt.h
    snmp/share/snmp/mibs/SNMPv2-TC.txt
    snmp/include/net-snmp/agent/table_iterator.h
    snmp/include/net-snmp/agent/sysORTable.h
    snmp/share/snmp/mibs/SNMPv2-CONF.txt
    snmp/include/net-snmp/system/osf5.h
    snmp/share/snmp/mibs/SNMP-PROXY-MIB.txt
    snmp/share/man/man1/snmpusm.1
    snmp/share/man/man1/snmpgetnext.1
    snmp/include/net-snmp/machine/
    snmp/share/snmp/mib2c-data/mfd-makefile.m2m
    snmp/share/man/man3/print_variable.3
    snmp/lib/libnetsnmp.la
    snmp/include/net-snmp/agent/auto_nlist.h
    snmp/share/snmp/snmpconf-data/snmp-data/output
    snmp/share/man/man3/get_module_node.3
    snmp/share/snmp/mib2c-data/m2c_setup_enum.m2i
    snmp/share/snmp/mib2c-data/subagent.m2c
    snmp/sbin/
    snmp/include/net-snmp/system/bsd.h
    snmp/share/snmp/snmpconf-data/snmp-data/authopts
    snmp/include/net-snmp/system/freebsd.h
    snmp/share/snmp/mib2c-data/syntax-RowStatus-dependencies.m2i
    snmp/include/net-snmp/agent/table_dataset.h
    snmp/share/snmp/mib2c-data/mfd-top.m2c
    snmp/share/snmp/mib2c-data/mfd-data-get.m2c
    snmp/include/net-snmp/agent/snmp_agent.h
    snmp/share/snmp/snmpconf-data/snmpd-data/extending
    snmp/lib/libnetsnmphelpers.a
    snmp/share/snmp/mibs/NET-SNMP-PASS-MIB.txt
    snmp/bin/snmptrap
    snmp/include/net-snmp/library/md5.h
    snmp/bin/
    snmp/include/net-snmp/system/freebsd6.h
    snmp/
    snmp/include/net-snmp/agent/scalar_group.h
    snmp/include/net-snmp/library/snmp_debug.h
    snmp/bin/snmptranslate
    snmp/share/man/man8/snmpd.8
    snmp/include/net-snmp/library/mib.h
    snmp/include/net-snmp/library/snmp-tc.h
    snmp/share/man/man3/fprint_variable.3
    snmp/include/net-snmp/system/openbsd5.h
    snmp/share/snmp/
    snmp/share/man/man5/snmp.conf.5
    snmp/include/net-snmp/pdu_api.h
    snmp/share/snmp/mibs/RFC-1215.txt
    snmp/share/snmp/mibs/IF-MIB.txt
    snmp/include/net-snmp/library/snmp_logging.h
    snmp/share/snmp/mib2c.iterate.conf
    snmp/share/man/man3/snmp_parse_oid.3
    snmp/share/man/man3/snmp_free_var.3
    snmp/include/net-snmp/system/mips.h
    snmp/include/net-snmp/agent/table.h
    snmp/share/snmp/mibs/IPV6-ICMP-MIB.txt
    snmp/share/snmp/mibs/IPV6-MIB.txt
    snmp/share/snmp/mib2c-data/details-table.m2i
    snmp/share/man/man3/netsnmp_sess_api.3
    snmp/bin/snmpinform
    snmp/include/net-snmp/system/freebsd12.h
    snmp/include/net-snmp/agent/table_array.h
    snmp/include/net-snmp/system/sysv.h
    snmp/share/snmp/mibs/IPV6-TCP-MIB.txt
    snmp/include/net-snmp/agent/util_funcs/header_simple_table.h
    snmp/share/man/man1/agentxtrap.1
    snmp/share/snmp/snmpconf-data/snmpd-data/snmpconf-config
    snmp/include/net-snmp/system/freebsd5.h
    snmp/share/snmp/mib2c-data/generic-table-indexes.m2i
    snmp/share/man/man1/snmpwalk.1
    snmp/include/net-snmp/library/README
    snmp/share/snmp/mib2c-data/node-validate.m2i
    snmp/share/man/man3/snmp_sess_async_send.3
    snmp/include/net-snmp/library/callback.h
    snmp/include/net-snmp/library/snmp_assert.h
    snmp/include/net-snmp/system/openbsd4.h
    snmp/include/net-snmp/library/container_list_ssll.h
    snmp/include/net-snmp/agent/agent_handler.h
    snmp/lib/libnetsnmpmibs.so
    snmp/share/man/man5/snmp_config.5
    snmp/share/snmp/mib2c.genhtml.conf
    snmp/share/man/man8/snmptrapd.8
    snmp/share/man/man1/snmpdf.1
    snmp/share/man/man3/print_mib.3
    snmp/bin/snmpbulkget
    snmp/share/snmp/mibs/IPV6-TC.txt
    snmp/include/net-snmp/library/snmp_enum.h
    snmp/bin/snmp-bridge-mib
    snmp/share/snmp/mibs/EtherLike-MIB.txt
    snmp/share/man/man3/snmp_timeout.3
    snmp/include/net-snmp/system/darwin9.h
    snmp/include/net-snmp/session_api.h
    snmp/share/snmp/mib2c-data/generic-data-allocate.m2i
    snmp/include/net-snmp/system/freebsd11.h
    snmp/share/man/man1/net-snmp-create-v3-user.1
    snmp/share/man/man3/snmp_sess_synch_response.3
    snmp/share/snmp/mib2c-data/generic-get-char.m2i
    snmp/share/man/man3/netsnmp_init_mib.3
    snmp/include/net-snmp/agent/util_funcs/header_generic.h
    snmp/share/snmp/snmpconf-data/snmptrapd-data/authentication
    snmp/lib/libnetsnmpagent.a
    snmp/share/man/man1/snmpbulkwalk.1
    snmp/lib/libnetsnmpmibs.a
    snmp/include/net-snmp/library/winpipe.h
    snmp/include/net-snmp/agent/multiplexer.h
    snmp/bin/snmpget
    snmp/include/net-snmp/library/fd_event_manager.h
    snmp/share/snmp/mib2c-data/generic-table-constants.m2c
    snmp/include/net-snmp/system/freebsd4.h
    snmp/share/snmp/snmpconf-data/snmpd-data/trapsinks
    snmp/include/net-snmp/system/irix.h
    snmp/share/snmp/mibs/UDP-MIB.txt
    snmp/include/net-snmp/varbind_api.h
    snmp/bin/mib2c-update
    snmp/include/net-snmp/library/lcd_time.h
    snmp/bin/snmptable
    snmp/bin/snmpconf
    snmp/include/net-snmp/library/transform_oids.h
    snmp/include/net-snmp/system/aix.h
    snmp/share/man/man3/print_objid.3
    snmp/share/snmp/mib2c-data/node-set.m2i
    snmp/bin/mib2c
    snmp/include/net-snmp/agent/agent_callbacks.h
    snmp/share/man/man3/netsnmp_session_api.3
    snmp/include/net-snmp/agent/table_container.h
    snmp/share/man/man3/netsnmp_mib_api.3
    snmp/include/net-snmp/system/svr5.h
    snmp/include/net-snmp/library/types.h
    snmp/include/net-snmp/agent/debug_handler.h
    snmp/share/man/man3/read_configs.3
    snmp/lib/libnetsnmphelpers.la
    snmp/share/man/man1/snmpvacm.1
    snmp/include/net-snmp/system/darwin.h
    snmp/share/snmp/mib2c-data/syntax-RowStatus-varbind-validate.m2i
    snmp/share/man/man3/send_easy_trap.3
    snmp/include/net-snmp/system/darwin8.h
    snmp/bin/snmpwalk
    snmp/include/net-snmp/system/freebsd10.h
    snmp/share/snmp/mib2c.column_enums.conf
    snmp/share/man/man3/snmp_sess_send.3
    snmp/share/man/man3/netsnmp_varbind_api.3
    snmp/include/net-snmp/library/read_config.h
    snmp/include/net-snmp/machine/generic.h
    snmp/lib/libnetsnmptrapd.la
    snmp/share/snmp/mib2c-data/syntax-InetAddressType-get.m2i
    snmp/share/man/man3/snmp_set_mib_warnings.3
    snmp/share/man/man3/register_config_handler.3
    snmp/include/net-snmp/library/data_list.h
    snmp/include/net-snmp/library/snmp_transport.h
    snmp/include/net-snmp/system/freebsd3.h
    snmp/share/man/man3/print_description.3
    snmp/share/man/man1/snmptranslate.1
    snmp/include/net-snmp/agent/util_funcs.h
    snmp/share/snmp/mib2c-data/generic-value-map.m2i
    snmp/share/man/man3/snmp_sess_read.3
    snmp/share/snmp/mib2c-data/generic-header-bottom.m2i
    snmp/share/snmp/mibs/BEL-HCRR-ODU-MIB.txt
    snmp/share/man/man3/snmp_sess_session.3
    snmp/share/snmp/mib2c-data/generic-value-map-func.m2i
    snmp/share/snmp/mib2c-data/generic-table-oids.m2c
    snmp/share/snmp/mibs/SNMP-USM-DH-OBJECTS-MIB.txt
    snmp/include/net-snmp/library/keytools.h
    snmp/include/net-snmp/output_api.h
    snmp/share/man/man1/fixproc.1
    snmp/share/snmp/mibs/RMON-MIB.txt
    snmp/lib/libnetsnmpmibs.so.30.0.3
    snmp/lib/libnetsnmptrapd.a
    snmp/lib/libnetsnmp.so.30.0.3
    snmp/share/snmp/mib2c-data/mfd-access-container-cached-defines.m2i
    snmp/share/snmp/mib2c.mfd.conf
    snmp/sbin/snmptrapd
    snmp/include/net-snmp/net-snmp-features.h
    snmp/share/snmp/mibs/SNMP-USER-BASED-SM-MIB.txt
    snmp/include/net-snmp/library/snmpUDPBaseDomain.h
    snmp/include/net-snmp/system/darwin7.h
    snmp/share/man/man3/snmp_sess_timeout.3
    snmp/share/man/man1/snmpcmd.1
    snmp/share/man/man3/netsnmp_config_api.3
    snmp/bin/snmpdf
    snmp/include/net-snmp/library/oid_stash.h
    snmp/share/snmp/mib2c-data/syntax-DateAndTime-readme.m2i
    snmp/include/net-snmp/agent/snmp_get_statistic.h
    snmp/include/net-snmp/library/asn1.h
    snmp/include/net-snmp/system/freebsd2.h
    snmp/share/snmp/mib2c.column_storage.conf
    snmp/share/man/man3/snmp_sess_select_info.3
    snmp/share/snmp/snmpconf-data/snmpd-data/acl
    snmp/bin/snmptest
    snmp/share/man/man1/traptoemail.1
    snmp/share/man/man3/read_mib.3
    snmp/include/net-snmp/system/hpux.h
    snmp/share/snmp/mib2c.access_functions.conf
    snmp/share/man/man3/snmp_set_mib_errors.3
    snmp/bin/agentxtrap
    snmp/share/man/man3/snmp_send.3
    snmp/include/net-snmp/library/system.h
    snmp/share/man/man1/snmptrap.1
    snmp/share/man/man3/send_trap_vars.3
    snmp/include/net-snmp/library/container_iterator.h
    snmp/share/man/man3/snprint_value.3
    snmp/share/man/man3/snmp_sess_open.3
    snmp/share/man/man3/snmp_alarm_register.3
    snmp/include/net-snmp/net-snmp-includes.h
    snmp/share/man/man3/read_objid.3
    snmp/share/man/man3/snmp_read.3
    snmp/share/man/man3/snmp_set_var_typed_integer.3
    snmp/share/snmp/mib2c-data/node-get.m2i
    snmp/share/man/man1/mib2c-update.1
    snmp/include/net-snmp/system/bsdi4.h
    snmp/include/net-snmp/library/factory.h
    snmp/share/man/man1/snmpset.1
    snmp/include/net-snmp/agent/null.h
    snmp/share/snmp/mib2c-data/node-varbind-validate.m2i
    snmp/share/man/man3/config_perror.3
    snmp/share/snmp/mibs/IP-MIB.txt
    snmp/include/net-snmp/library/snmp_parse_args.h
    snmp/include/net-snmp/system/linux.h
    snmp/bin/snmpgetnext
    snmp/lib/libnetsnmpmibs.la
    snmp/share/man/man3/fprint_description.3
    snmp/include/net-snmp/agent/agent_index.h
    snmp/share/man/man1/snmptest.1
    snmp/bin/snmpset
    snmp/share/snmp/mibs/SNMP-FRAMEWORK-MIB.txt
    snmp/share/man/man3/snmp_set_var_value.3
    snmp/share/snmp/mibs/UCD-DISKIO-MIB.txt
    snmp/include/net-snmp/library/dir_utils.h
    snmp/share/snmp/mib2c-data/generic-header-top.m2i
    snmp/include/net-snmp/library/snmp_alarm.h
    snmp/lib/
    snmp/bin/traptoemail
    snmp/include/net-snmp/library/container_null.h
    snmp/share/man/man3/snprint_description.3
    snmp/share/snmp/mib2c.scalar.conf
    snmp/share/snmp/mib2c-data/m2c_setup_table.m2i
    snmp/share/snmp/mibs/BRIDGE-MIB.txt
    snmp/share/snmp/snmpconf-data/snmpd-data/basic_setup
    snmp/share/snmp/mibs/IANA-LANGUAGE-MIB.txt
    snmp/share/man/man3/snmp_pdu_add_variable.3
    snmp/share/snmp/mib2c-data/generic-data-context.m2i
    snmp/share/man/man5/snmpd.examples.5
    snmp/include/net-snmp/system/bsdi3.h
    snmp/share/snmp/mibs/IP-FORWARD-MIB.txt
    snmp/share/man/man3/snmp_select_info.3
    snmp/include/net-snmp/agent/net-snmp-agent-includes.h
    snmp/bin/net-snmp-config
    snmp/include/net-snmp/agent/mib_module_includes.h
    snmp/share/snmp/mibs/NOTIFICATION-LOG-MIB.txt
    snmp/share/snmp/mib2c-data/generic-get-long.m2i
    snmp/include/net-snmp/library/snmp_client.h
    snmp/share/man/man3/sn�^@�
    INIT: Entering runlevel: 5
    Configuring network interfaces... udhcpc (v1.24.1) started
    Sending discover...
    Sending discover...
    Sending discover...
    No lease, forking to background
    done.
    Starting Dropbear SSH server: Generating key, this may take a while...
    Public key portion is:
    ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQD8GPK9cJLowEqwtu5WD2/6WbYM9/zzY2I6iHly0YYUJqRtSiGTb+icEYMRQB/vsHxaYYnCSr7XZabdOhqKkqe4LsYWmfZkVtMje8G+jC0mF3e3cqCMJUQMpE3tMD7DZ7j1l/2eZVuhZ8YPSKYHC/oCpx+wiEtjQJC+d8eixwSEsh+Rcvz2r69jNBGIGwBk9PT/DAh8CcLNmIiapNAzCDDhB2td0WI2Ds8r3cA6BBGbEB81lB9PXq7L0Sb52FVOXR8K24A9eeVH5jlQP4rMxM2EtgD2NqMp3SEYWnfoqlLxNmfSlUmzxBsY65IiqsUCHgZN83S645vOEplPKCwsa1Yp root@plnx_arm
    Fingerprint: md5 41:2b:6a:5d:74:9c:ae:7c:b5:60:37:27:7e:41:f6:b3
    dropbear.
    Starting syslogd/klogd: done
    Starting tcf-agent: OK
    plnx_arm login: RROOOOTT
    Password:
    Login incorrect
    plnx_arm login:
    plnx_arm login: R^H^H^H^H^H^H
    Password:
    Login incorrect
    plnx_arm login: root
    Password:
    root@plnx_arm:~# ls
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# ls
    calib_mode                                 in_voltage_rf_bandwidth                    out_voltage0_hardwaregain
    calib_mode_available                       in_voltage_rf_bandwidth_available          out_voltage0_hardwaregain_available
    dcxo_tune_coarse                           in_voltage_rf_dc_offset_tracking_en        out_voltage0_rf_port_select
    dcxo_tune_coarse_available                 in_voltage_rf_port_select_available        out_voltage0_rssi
    dcxo_tune_fine                             in_voltage_sampling_frequency              out_voltage2_raw
    dcxo_tune_fine_available                   in_voltage_sampling_frequency_available    out_voltage2_scale
    dev                                        multichip_sync                             out_voltage3_raw
    ensm_mode                                  name                                       out_voltage3_scale
    ensm_mode_available                        of_node                                    out_voltage_filter_fir_en
    filter_fir_config                          out_altvoltage0_RX_LO_external             out_voltage_rf_bandwidth
    gain_table_config                          out_altvoltage0_RX_LO_fastlock_load        out_voltage_rf_bandwidth_available
    in_out_voltage_filter_fir_en               out_altvoltage0_RX_LO_fastlock_recall      out_voltage_rf_port_select_available
    in_temp0_input                             out_altvoltage0_RX_LO_fastlock_save        out_voltage_sampling_frequency
    in_voltage0_gain_control_mode              out_altvoltage0_RX_LO_fastlock_store       out_voltage_sampling_frequency_available
    in_voltage0_hardwaregain                   out_altvoltage0_RX_LO_frequency            power
    in_voltage0_hardwaregain_available         out_altvoltage0_RX_LO_frequency_available  rssi_gain_step_error
    in_voltage0_rf_port_select                 out_altvoltage0_RX_LO_powerdown            rx_path_rates
    in_voltage0_rssi                           out_altvoltage1_TX_LO_external             subsystem
    in_voltage2_offset                         out_altvoltage1_TX_LO_fastlock_load        trx_rate_governor
    in_voltage2_raw                            out_altvoltage1_TX_LO_fastlock_recall      trx_rate_governor_available
    in_voltage2_scale                          out_altvoltage1_TX_LO_fastlock_save        tx_path_rates
    in_voltage_bb_dc_offset_tracking_en        out_altvoltage1_TX_LO_fastlock_store       uevent
    in_voltage_filter_fir_en                   out_altvoltage1_TX_LO_frequency            xo_correction
    in_voltage_gain_control_mode_available     out_altvoltage1_TX_LO_frequency_available  xo_correction_available
    in_voltage_quadrature_tracking_en          out_altvoltage1_TX_LO_powerdown
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# echo 33000000 > out_voltage_sampling_frequency
    echo 4400000000 > out_altvoltage0_RX_LO_frequency
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# echo 33000000 > in_voltage_sampling_frequency
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# echo 4400000000 > out_altvoltage1_TX_LO_frequency
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# echo 4400000000 > out_altvoltage0_RX_LO_frequency
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# echo 30000000 > out_voltage_rf_bandwidth
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# echo 30000000 > in_voltage_rf_bandwidth
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# cat out_voltage_sampling_frequency
    33000000
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# macb e000c000.ethernet eth1: unable to generate target frequency: 25000000 Hz
    macb e000c000.ethernet eth1: link up (100/Full)
    IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# cd /home/root
    root@plnx_arm:~# tftp -r fil.txt -g 192.168.1.2
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# cat /home/root/fil.txt > filter_fir_config
    root@plnx_arm:/sys/bus/iio/devices/iio:device0# echo 1 > in_voltage_filter_fir_en
    pgd = ef13c000
    [00000314] *pgd=3ec69831
    Modules linked in:
    CPU: 0 PID: 1183 Comm: sh Not tainted 4.9.0-xilinx #33
    task: ef270cc0 task.stack: ee938000
    pc : [<c04fb6b8>]    lr : [<c04f5e08>]    psr: a00e0013
    sp : ee939ce8  ip : 00000000  fp : 00000000
    r10: ee9b7c80  r9 : 00000000  r8 : 00000000
    r7 : ee9b7c10  r6 : ef0c5b10  r5 : 00000000  r4 : ef25e2c0
    r3 : ee964000  r2 : 00000001  r1 : 00000000  r0 : ef25e2c0
    Control: 18c5387d  Table: 2f13c04a  DAC: 00000051
    Process sh (pid: 1183, stack limit = 0xee938210)
    Stack: (0xee939ce8 to 0xee93a000)
    9ce0:                   ef25e2c0 00000000 00000001 ef25e2c0 00000000 00000000
    9d00: ee9b7c10 00000000 ee939e10 ee9b7c80 00000000 c04f5e08 00000000 ef25e2c0
    9d20: 00000000 00000010 00000000 c04fc2ac 00000000 00000000 00000000 00000000
    9d40: 00000000 00000000 00000000 00000000 0000000a 00000000 ee964000 ee964000
    9d60: 00000000 ee964000 ee939e10 c04ef3a8 00000000 00000002 0000005c 5c02805c
    9d80: 00000000 ee964000 00000002 ef25e2c0 00000000 ee939df8 ee9b7c10 ee964000
    9da0: ee939e10 ee9b7c80 00000006 c04f16a0 00000000 02010306 01020204 ee9b7c98
    9dc0: ef25e304 ef25e2f0 ef2e9900 ee9b7c10 ef25e2c0 ee964000 00000000 ee939e10
    9de0: ef25e1c8 00000002 00000000 c04f5504 ee939e10 b6fe7000 3ef14800 0fbc5200
    9e00: 07de2900 03ef1480 01f78a40 01f78a40 3ef14800 0fbc5200 07de2900 03ef1480
    9e20: 01f78a40 01f78a40 ef25e010 00000000 ee9b7c10 ee80e680 ef25e2c0 c04f6dc8
    9e40: ef270cc0 0000081f b6f76d60 3e2577df ef13edb8 c7d4e000 00000055 ef270cc0
    9e60: 0000081f b6f76d60 ee87e000 c01b5564 eeda56e8 ee938000 00000002 00000040
    9e80: ee939ed8 c7d4e000 b6fe7000 00000055 ef13edb8 ffeee79c effd1b1c 00000000
    9ea0: ee939ea0 01939fb0 b6fe7000 ffffffff 00000055 00000002 ee898580 ee80e680
    9ec0: ee939f88 ee89858c 00000051 00000000 00000000 c0224134 00000000 00000000
    9ee0: 00000002 c0223fc4 c7c5f240 ee939f88 b6fe7000 c01070c4 ee938000 c01ce348
    9f00: 000eb134 b6f76d60 be89e9dc c0101284 be89e244 c01deb54 c0a33d40 0000000a
    9f20: 0000000a c7e32f80 ef3c9600 ef3c9640 00000000 c01e895c 00000001 c7c5f240
    9f40: ee939f88 00000002 00000002 00000002 c7c5f240 ee939f88 b6fe7000 c01cefa8
    9f60: c7c5f240 b6fe7000 00000002 c7c5f240 c7c5f240 b6fe7000 00000002 c01070c4
    9f80: ee938000 c01cfb88 00000000 00000000 00000002 00000002 b6fe7000 b6f76d60
    9fa0: 00000004 c0106f00 00000002 b6fe7000 00000001 b6fe7000 00000002 00000000
    9fc0: 00000002 b6fe7000 b6f76d60 00000004 00000000 000eb134 000cf820 00000000
    9fe0: 00000000 be89e98c b6ea1b8c b6efb8e0 600e0010 00000001 ffffffff ffffffff
    [<c04f5504>] (ad9361_validate_enable_fir) from [<c04f6dc8>] (ad9361_phy_store+0x324/0xa2c)
    [<c04f6dc8>] (ad9361_phy_store) from [<c0224134>] (kernfs_fop_write+0x170/0x1ac)
    ---[ end trace ffdc86e27ad56842 ]---
    /bin/start_getty: line 5:  1183 Segmentation fault      /sbin/getty -L $1 $2
    plnx_arm login:
    boot.
