How to add ad9361 drivers with using device tree?
Hi, I worked with zcu102 and analog devices kernel (https://github.com/analogdevicesinc/linux/tree/adi-4.14.0)
I want to add ad9361 drivers in kernel so I change device tree using system.dtb of adi referance design. but it failed.
system-user.dtsi
/include/ "system-conf.dtsi"
/delete-node/ amba_pl@0;
aliases {
        ethernet0 = "/amba/ethernet@ff0e0000";
        gpio0 = "/amba/gpio@ff0a0000";
        i2c0 = "/amba/i2c@ff020000";
        i2c1 = "/amba/i2c@ff030000";
        mmc0 = "/amba/sdhci@ff170000";
        rtc0 = "/amba/rtc@ffa60000";
        serial0 = "/amba/serial@ff000000";
        serial1 = "/amba/serial@ff010000";
        serial2 = "/dcc";
        spi0 = "/amba/spi@ff0f0000";
        usb0 = "/amba/usb0@ff9d0000";
    chosen {
        bootargs = "earlycon";
        stdout-path = "serial0:115200n8";
nvmem_firmware {
        compatible = "xlnx,zynqmp-nvmem-fw";
        #address-cells = <0x1>;
        #size-cells = <0x1>;
        soc_revision@0 {
            reg = <0x0 0x4>;
            linux,phandle = <0x22>;
            phandle = <0x22>;
    spi@ff040000 {
            compatible = "cdns,spi-r1p6";
            status = "okay";
            interrupt-parent = <0x4>;
            interrupts = <0x0 0x13 0x4>;
            reg = <0x0 0xff040000 0x0 0x1000>;
            clock-names = "ref_clk", "pclk";
            #size-cells = <0x0>;
            power-domains = <0x29>;
            clocks = <0x3 0x3a 0x3 0x1f>;
            ad9361-phy@0 {
                compatible = "adi,ad9361";
                reg = <0x0>;
                spi-cpha;
                spi-max-frequency = <0x989680>;
                clocks = <0x2a 0x0>;
                clock-names = "ad9361_ext_refclk";
                clock-output-names = "rx_sampl_clk", "tx_sampl_clk";
                #clock-cells = <0x1>;
                adi,digital-interface-tune-skip-mode = <0x0>;
                adi,pp-tx-swap-enable;
                adi,pp-rx-swap-enable;
                adi,rx-frame-pulse-mode-enable;
                adi,lvds-mode-enable;
                adi,lvds-bias-mV = <0x96>;
                adi,lvds-rx-onchip-termination-enable;
                adi,rx-data-delay = <0x4>;
                adi,tx-fb-clock-delay = <0x7>;
                adi,dcxo-coarse-and-fine-tune = <0x8 0x1720>;
                adi,2rx-2tx-mode-enable;
                adi,frequency-division-duplex-mode-enable;
                adi,rx-rf-port-input-select = <0x0>;
                adi,tx-rf-port-input-select = <0x0>;
                adi,tx-attenuation-mdB = <0x2710>;
                adi,tx-lo-powerdown-managed-enable;
                adi,rf-rx-bandwidth-hz = <0x112a880>;
                adi,rf-tx-bandwidth-hz = <0x112a880>;
                adi,rx-synthesizer-frequency-hz = <0x0 0x8f0d1800>;
                adi,tx-synthesizer-frequency-hz = <0x0 0x92080880>;
                adi,rx-path-clock-frequencies = <0x3a980000 0xea60000 0x7530000 0x3a98000 0x1d4c000 0x1d4c000>;
                adi,tx-path-clock-frequencies = <0x3a980000 0x7530000 0x7530000 0x3a98000 0x1d4c000 0x1d4c000>;
                adi,gc-rx1-mode = <0x2>;
                adi,gc-rx2-mode = <0x2>;
                adi,gc-adc-ovr-sample-size = <0x4>;
                adi,gc-adc-small-overload-thresh = <0x2f>;
                adi,gc-adc-large-overload-thresh = <0x3a>;
                adi,gc-lmt-overload-high-thresh = <0x320>;
                adi,gc-lmt-overload-low-thresh = <0x2c0>;
                adi,gc-dec-pow-measurement-duration = <0x2000>;
                adi,gc-low-power-thresh = <0x18>;
                adi,mgc-inc-gain-step = <0x2>;
                adi,mgc-dec-gain-step = <0x2>;
                adi,mgc-split-table-ctrl-inp-gain-mode = <0x0>;
                adi,agc-attack-delay-extra-margin-us = <0x1>;
                adi,agc-outer-thresh-high = <0x5>;
                adi,agc-outer-thresh-high-dec-steps = <0x2>;
                adi,agc-inner-thresh-high = <0xa>;
                adi,agc-inner-thresh-high-dec-steps = <0x1>;
                adi,agc-inner-thresh-low = <0xc>;
                adi,agc-inner-thresh-low-inc-steps = <0x1>;
                adi,agc-outer-thresh-low = <0x12>;
                adi,agc-outer-thresh-low-inc-steps = <0x2>;
                adi,agc-adc-small-overload-exceed-counter = <0xa>;
                adi,agc-adc-large-overload-exceed-counter = <0xa>;
                adi,agc-adc-large-overload-inc-steps = <0x2>;
                adi,agc-lmt-overload-large-exceed-counter = <0xa>;
                adi,agc-lmt-overload-small-exceed-counter = <0xa>;
                adi,agc-lmt-overload-large-inc-steps = <0x2>;
                adi,agc-gain-update-interval-us = <0x3e8>;
                adi,fagc-dec-pow-measurement-duration = <0x40>;
                adi,fagc-lp-thresh-increment-steps = <0x1>;
                adi,fagc-lp-thresh-increment-time = <0x5>;
                adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt = <0x8>;
                adi,fagc-final-overrange-count = <0x3>;
                adi,fagc-gain-index-type-after-exit-rx-mode = <0x0>;
                adi,fagc-lmt-final-settling-steps = <0x1>;
                adi,fagc-lock-level = <0xa>;
                adi,fagc-lock-level-gain-increase-upper-limit = <0x5>;
                adi,fagc-lock-level-lmt-gain-increase-enable;
                adi,fagc-lpf-final-settling-steps = <0x1>;
                adi,fagc-optimized-gain-offset = <0x5>;
                adi,fagc-power-measurement-duration-in-state5 = <0x40>;
                adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable;
                adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll = <0xa>;
                adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable;
                adi,fagc-rst-gla-if-en-agc-pulled-high-mode = <0x0>;
                adi,fagc-rst-gla-large-adc-overload-enable;
                adi,fagc-rst-gla-large-lmt-overload-enable;
                adi,fagc-rst-gla-stronger-sig-thresh-above-ll = <0xa>;
                adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable;
                adi,fagc-state-wait-time-ns = <0x104>;
                adi,fagc-use-last-lock-level-for-set-gain-enable;
                adi,rssi-restart-mode = <0x3>;
                adi,rssi-delay = <0x1>;
                adi,rssi-wait = <0x1>;
                adi,rssi-duration = <0x3e8>;
                adi,ctrl-outs-index = <0x0>;
                adi,ctrl-outs-enable-mask = <0xff>;
                adi,temp-sense-measurement-interval-ms = <0x3e8>;
                adi,temp-sense-offset-signed = <0xce>;
                adi,temp-sense-periodic-measurement-enable;
                adi,aux-dac-manual-mode-enable;
                adi,aux-dac1-default-value-mV = <0x0>;
                adi,aux-dac1-rx-delay-us = <0x0>;
                adi,aux-dac1-tx-delay-us = <0x0>;
                adi,aux-dac2-default-value-mV = <0x0>;
                adi,aux-dac2-rx-delay-us = <0x0>;
                adi,aux-dac2-tx-delay-us = <0x0>;
                en_agc-gpios = <0x1a 0x7a 0x0>;
                sync-gpios = <0x1a 0x7b 0x0>;
                reset-gpios = <0x1a 0x7c 0x0>;
                enable-gpios = <0x1a 0x7d 0x0>;
                txnrx-gpios = <0x1a 0x7e 0x0>;
                linux,phandle = <0x45>;
                phandle = <0x45>;
        i2c@ff020000 {
            compatible = "cdns,i2c-r1p14", "cdns,i2c-r1p10";
            status = "okay";
            interrupts = <0x0 0x11 0x4>;
            reg = <0x0 0xff020000 0x0 0x1000>;
            power-domains = <0x17>;
            clocks = <0x3 0x3d>;
            clock-frequency = <0x61a80>;
            pinctrl-names = "default", "gpio";
            pinctrl-0 = <0x18>;
            pinctrl-1 = <0x19>;
            scl-gpios = <0x1a 0xe 0x0>;
            sda-gpios = <0x1a 0xf 0x0>;
            gpio@20 {
                compatible = "ti,tca6416";
                reg = <0x20>;
                gpio-controller;
                #gpio-cells = <0x2>;
                gtr_sel0 {
                    gpio-hog;
                    gpios = <0x0 0x0>;
                    output-low;
                    line-name = "sel0";
                gtr_sel1 {
                    gpio-hog;
                    gpios = <0x1 0x0>;
                    output-high;
                    line-name = "sel1";
                gtr_sel2 {
                    gpio-hog;
                    gpios = <0x2 0x0>;
                    output-high;
                    line-name = "sel2";
                gtr_sel3 {
                    gpio-hog;
                    gpios = <0x3 0x0>;
                    output-high;
                    line-name = "sel3";
amba {
        compatible = "simple-bus";
        u-boot,dm-pre-reloc;
        #address-cells = <0x2>;
        #size-cells = <0x2>;
        ranges;
        dma@ffa80000 {
            status = "disabled";
            compatible = "xlnx,zynqmp-dma-1.0";
            reg = <0x0 0xffa80000 0x0 0x1000>;
            interrupts = <0x0 0x4d 0x4>;
            clock-names = "clk_main", "clk_apb";
            xlnx,bus-width = <0x40>;
            #stream-id-cells = <0x1>;
            power-domains = <0xd>;
            clocks = <0x3 0x44 0x3 0x1f>;
        dma@ffa90000 {
            reg = <0x0 0xffa90000 0x0 0x1000>;
            interrupts = <0x0 0x4e 0x4>;
        dma@ffaa0000 {
            reg = <0x0 0xffaa0000 0x0 0x1000>;
            interrupts = <0x0 0x4f 0x4>;
        dma@ffab0000 {
            reg = <0x0 0xffab0000 0x0 0x1000>;
            interrupts = <0x0 0x50 0x4>;
        dma@ffac0000 {
            reg = <0x0 0xffac0000 0x0 0x1000>;
            interrupts = <0x0 0x51 0x4>;
        dma@ffad0000 {
            reg = <0x0 0xffad0000 0x0 0x1000>;
            interrupts = <0x0 0x52 0x4>;
        dma@ffae0000 {
            reg = <0x0 0xffae0000 0x0 0x1000>;
            interrupts = <0x0 0x53 0x4>;
        dma@ffaf0000 {
            reg = <0x0 0xffaf0000 0x0 0x1000>;
            interrupts = <0x0 0x54 0x4>;
        i2c@ff020000 {
            status = "okay";
            pinctrl-0 = <0x18>;
            pinctrl-1 = <0x19>;
            gpio@20 {
                reg = <0x20>;
                gpio-controller;
                gtr_sel0 {
                    gpio-hog;
                    gpios = <0x0 0x0>;
                    output-low;
                    line-name = "sel0";
                gtr_sel1 {
                    gpio-hog;
                    gpios = <0x1 0x0>;
                    output-high;
                    line-name = "sel1";
                gtr_sel2 {
                    gpio-hog;
                    gpios = <0x2 0x0>;
                    output-high;
                    line-name = "sel2";
                gtr_sel3 {
                    gpio-hog;
                    gpios = <0x3 0x0>;
                    output-high;
                    line-name = "sel3";
            gpio@21 {
                reg = <0x21>;
                gpio-controller;
            i2c-mux@75 {
                compatible = "nxp,pca9544";
                reg = <0x75>;
                i2c@0 {
                    reg = <0x0>;
                    ina226@40 {
                        compatible = "ti,ina226";
                        reg = <0x40>;
                        shunt-resistor = <0x1388>;
                    ina226@41 {
                        reg = <0x41>;
                    ina226@42 {
                        reg = <0x42>;
                    ina226@43 {
                        reg = <0x43>;
                    ina226@44 {
                        reg = <0x44>;
                    ina226@45 {
                        reg = <0x45>;
                    ina226@46 {
                        reg = <0x46>;
                    ina226@47 {
                        reg = <0x47>;
                    ina226@4a {
                        reg = <0x4a>;
                    ina226@4b {
                        reg = <0x4b>;
                i2c@1 {
                    reg = <0x1>;
                    ina226@40 {
                        reg = <0x40>;
                        shunt-resistor = <0x7d0>;
                    ina226@41 {
                        reg = <0x41>;
                    ina226@42 {
                        reg = <0x42>;
                    ina226@43 {
                        reg = <0x43>;
                    ina226@44 {
                        reg = <0x44>;
                    ina226@45 {
                        reg = <0x45>;
                    ina226@46 {
                        reg = <0x46>;
                    ina226@47 {
                        reg = <0x47>;
                i2c@2 {
                    reg = <0x2>;
                    max15301@a {
                        compatible = "maxim,max15301";
                        reg = <0xa>;
                    max15303@b {
                        compatible = "maxim,max15303";
                        reg = <0xb>;
                    max15303@10 {
                        reg = <0x10>;
                    max15301@13 {
                        reg = <0x13>;
                    max15303@14 {
                        reg = <0x14>;
                    max15303@15 {
                        reg = <0x15>;
                    max15303@16 {
                        reg = <0x16>;
                    max15303@17 {
                        reg = <0x17>;
                    max15301@18 {
                        reg = <0x18>;
                    max15303@1a {
                        reg = <0x1a>;
                    max15303@1d {
                        reg = <0x1d>;
                    max20751@72 {
                        compatible = "maxim,max20751";
                        reg = <0x72>;
                    max20751@73 {
                        reg = <0x73>;
                    max15303@1b {
                        reg = <0x1b>;
gpio-keys {
        compatible = "gpio-keys";
        autorepeat;
        sw19 {
            label = "sw19";
            gpios = <0x1a 0x16 0x0>;
            linux,code = <0x6c>;
            gpio-key,wakeup;
            autorepeat;
    leds {
        compatible = "gpio-leds";
        heartbeat_led {
            label = "heartbeat";
            gpios = <0x1a 0x17 0x0>;
            linux,default-trigger = "heartbeat";
    fpga-axi@0 {
        ranges = <0x0 0x0 0x0 0xffffffff>;
        dma@9c400000 {
            compatible = "adi,axi-dmac-1.00.a";
            reg = <0x9c400000 0x10000>;
            #dma-cells = <0x1>;
            #clock-cells = <0x0>;
            interrupts = <0x0 0x6d 0x0>;
            clocks = <0x3 0x47>;
            linux,phandle = <0x44>;
            phandle = <0x44>;
            adi,channels {
                dma-channel@0 {
                    reg = <0x0>;
                    adi,source-bus-width = <0x40>;
                    adi,source-bus-type = <0x2>;
                    adi,destination-bus-width = <0x40>;
                    adi,destination-bus-type = <0x0>;
        dma@9c420000 {
            reg = <0x9c420000 0x10000>;
            #dma-cells = <0x1>;
            interrupts = <0x0 0x6c 0x0>;
            linux,phandle = <0x46>;
            phandle = <0x46>;
            adi,channels {
                dma-channel@0 {
                    reg = <0x0>;
                    adi,source-bus-type = <0x0>;
                    adi,destination-bus-type = <0x2>;
        cf-ad9361-lpc@99020000 {
            compatible = "adi,axi-ad9361-6.00.a";
            reg = <0x99020000 0x6000>;
            dmas = <0x44 0x0>;
            dma-names = "rx";
            spibus-connected = <0x45>;
        cf-ad9361-dds-core-lpc@99024000 {
            compatible = "adi,axi-ad9361-dds-6.00.a";
            reg = <0x99024000 0x1000>;
            clocks = <0x45 0xd>;
            clock-names = "sampl_clk";
            dmas = <0x46 0x0>;
            dma-names = "tx";
    clocks {
        clock@0 {
            compatible = "fixed-clock";
            clock-frequency = <0x2625a00>;
            clock-output-names = "ad9361_ext_refclk";
            linux,phandle = <0x2a>;
            phandle = <0x2a>;
&qspi {
    is-dual = <1>;
    flash@0 {
        compatible = "m25p80"; /* 32MB */
        #address-cells = <1>;
        #size-cells = <1>;
        reg = <0x0>;
        spi-tx-bus-width = <1>;
        spi-rx-bus-width = <4>; /* FIXME also DUAL configuration possible */
        spi-max-frequency = <108000000>; /* Based on DC1 spec */
        /delete-node/ partition@0x00000000;
        /delete-node/ partition@0x00100000;
        /delete-node/ partition@0x00140000;
        partition@qspi-fsbl-uboot { /* for testing purpose */
            label = "qspi-fsbl-uboot";
            reg = <0x0 0x100000>;
        partition@qspi-linux { /* for testing purpose */
            label = "qspi-linux";
            reg = <0x100000 0x500000>;
        partition@qspi-device-tree { /* for testing purpose */
            label = "qspi-device-tree";
            reg = <0x600000 0x20000>;
        partition@qspi-rootfs { /* for testing purpose */
            label = "qspi-rootfs";
            reg = <0x620000 0x5E0000>;
&dcc {
        compatible = "arm,dcc";
        status = "okay";
&pinctrl0 {
    status = "okay";
    pinctrl_i2c0_default: i2c0-default {
        mux {
            groups = "i2c0_3_grp";
            function = "i2c0";
        conf {
            bias-pull-up;
            slew-rate = <1>;
            io-standard = <1>;
    pinctrl_i2c0_gpio: i2c0-gpio {
        mux {
            groups = "gpio0_14_grp", "gpio0_15_grp";
            function = "gpio0";
        conf {
            slew-rate = <1>;
            io-standard = <1>;
    pinctrl_i2c1_default: i2c1-default {
        mux {
            groups = "i2c1_4_grp";
            function = "i2c1";
        conf {
            bias-pull-up;
            slew-rate = <1>;
            io-standard = <1>;
    pinctrl_i2c1_gpio: i2c1-gpio {
        mux {
            groups = "gpio0_16_grp", "gpio0_17_grp";
            function = "gpio0";
        conf {
            slew-rate = <1>;
            io-standard = <1>;
    pinctrl_uart0_default: uart0-default {
        mux {
            groups = "uart0_4_grp";
            function = "uart0";
        conf {
            slew-rate = <1>;
            io-standard = <1>;
        conf-rx {
            pins = "MIO18";
            bias-high-impedance;
        conf-tx {
            pins = "MIO19";
            bias-disable;
    pinctrl_uart1_default: uart1-default {
        mux {
            groups = "uart1_5_grp";
            function = "uart1";
        conf {
            slew-rate = <1>;
            io-standard = <1>;
        conf-rx {
            pins = "MIO21";
        conf-tx {
            pins = "MIO20";
            bias-disable;
    pinctrl_usb0_default: usb0-default {
        mux {
            groups = "usb0_0_grp";
            function = "usb0";
        conf {
            slew-rate = <1>;
            io-standard = <1>;
        conf-rx {
            pins = "MIO52", "MIO53", "MIO55";
        conf-tx {
            pins = "MIO54", "MIO56", "MIO57", "MIO58", "MIO59",
                   "MIO60", "MIO61", "MIO62", "MIO63";
            bias-disable;
    pinctrl_gem3_default: gem3-default {
        mux {
            function = "ethernet3";
            groups = "ethernet3_0_grp";
        conf {
            slew-rate = <1>;
            io-standard = <1>;
        conf-rx {
            pins = "MIO70", "MIO71", "MIO72", "MIO73", "MIO74",
                                    "MIO75";
            low-power-disable;
        conf-tx {
            pins = "MIO64", "MIO65", "MIO66", "MIO67", "MIO68",
                                    "MIO69";
            bias-disable;
            low-power-enable;
        mux-mdio {
            function = "mdio3";
            groups = "mdio3_0_grp";
        conf-mdio {
            slew-rate = <1>;
            io-standard = <1>;
            bias-disable;
    pinctrl_can1_default: can1-default {
        mux {
            function = "can1";
            groups = "can1_6_grp";
        conf {
            slew-rate = <1>;
            io-standard = <1>;
        conf-rx {
            pins = "MIO25";
        conf-tx {
            pins = "MIO24";
            bias-disable;
    pinctrl_sdhci1_default: sdhci1-default {
        mux {
            groups = "sdio1_0_grp";
            function = "sdio1";
        conf {
            slew-rate = <1>;
            io-standard = <1>;
            bias-disable;
        mux-cd {
            groups = "sdio1_cd_0_grp";
            function = "sdio1_cd";
        conf-cd {
            bias-pull-up;
            slew-rate = <1>;
            io-standard = <1>;
        mux-wp {
            groups = "sdio1_wp_0_grp";
            function = "sdio1_wp";
        conf-wp {
            bias-pull-up;
            slew-rate = <1>;
            io-standard = <1>;
    pinctrl_gpio_default: gpio-default {
        mux-sw {
            function = "gpio0";
            groups = "gpio0_22_grp", "gpio0_23_grp";
        conf-sw {
            slew-rate = <1>;
            io-standard = <1>;
        mux-msp {
            function = "gpio0";
            groups = "gpio0_13_grp", "gpio0_38_grp";
        conf-msp {
            slew-rate = <1>;
            io-standard = <1>;
        conf-pull-up {
            pins = "MIO22", "MIO23";
            bias-pull-up;
        conf-pull-none {
            pins = "MIO13", "MIO38";
            bias-disable;
Release 2018.3   Jan  2 2020  -  08:23:58
NOTICE:  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.5(release):xilinx-v2018.2-919-g08560c3
NOTICE:  BL31: Built : 08:21:56, Jan  2 2020
PMUFW:  v1.1
U-Boot 2018.01 (Jan 02 2020 - 08:22:55 +0000) Xilinx ZynqMP ZCU102 rev1.0
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu9eg
MMC:   mmc@ff170000: 0 (SD)
SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MB
*** Warning - bad CRC, using default environment
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
Bootmode: LVL_SHFT_SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for zcu102-siso
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete....... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
*** Unhandled DHCP Option in OFFER/ACK: 2
*** Unhandled DHCP Option in OFFER/ACK: 224
DHCP client bound to address 192.168.1.27 (6782 ms)
Hit any key to stop autoboot:  0
Device: mmc@ff170000
Manufacturer ID: 1b
OEM: 534d
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
7254948 bytes read in 534 ms (13 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x100000f8
     Data Size:    7204396 Bytes = 6.9 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   87b0da69bdad06021df1ba4227333f473179019d
   Verifying Hash Integrity ... sha1+ OK
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x106df028
     Data Size:    48648 Bytes = 47.5 KiB
     Hash algo:    sha1
     Hash value:   0657997fda500940c84d0cd57098fdc8f8f92fea
   Booting using the fdt blob at 0x106df028
   Uncompressing Kernel Image ... OK
   Loading Device Tree to 0000000007ff1000, end 0000000007fffe07 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0 (oe-user@oe-host) (gcc version 7.3.0 (GCC))0
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000006fc00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff5d000 s45080 r8192 d326
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1033987
[    0.000000] Kernel command line: earlycon
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0x6bc00000-0x6fc00000] (64MB) mapped at [ff]
[    0.000000] Memory: 3783972K/4193280K available (10300K kernel code, 666K rw)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 )
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 )
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a90000   ( 10304 )
[    0.000000]     .rodata : 0xffffff8008a90000 - 0xffffff8008dd0000   (  3328 )
[    0.000000]       .init : 0xffffff8008dd0000 - 0xffffff8008e50000   (   512 )
[    0.000000]       .data : 0xffffff8008e50000 - 0xffffff8008ef6a00   (   667 )
[    0.000000]        .bss : 0xffffff8008ef6a00 - 0xffffff8009113800   (  2164 )
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 )
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 )
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 )
[    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 )
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 )
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU event tracing is enabled.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398s
[    0.008342] Console: colour dummy device 80x25
[    0.012378] console [tty0] enabled
[    0.015744] bootconsole [cdns0] disabled
[    0.019654] Calibrating delay loop (skipped), value calculated using timer f)
[    0.019667] pid_max: default: 32768 minimum: 301
[    0.019772] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.019790] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.020391] ASID allocator initialised with 65536 entries
[    0.020442] Hierarchical SRCU implementation.
[    0.020800] EFI services will not be available.
[    0.020825] zynqmp_plat_init Platform Management API v1.1
[    0.020833] zynqmp_plat_init Trustzone version v1.0
[    0.020934] smp: Bringing up secondary CPUs ...
[    0.021178] Detected VIPT I-cache on CPU1
[    0.021208] CPU1: Booted secondary processor [410fd034]
[    0.021472] Detected VIPT I-cache on CPU2
[    0.021490] CPU2: Booted secondary processor [410fd034]
[    0.021745] Detected VIPT I-cache on CPU3
[    0.021763] CPU3: Booted secondary processor [410fd034]
[    0.021804] smp: Brought up 1 node, 4 CPUs
[    0.021836] SMP: Total of 4 processors activated.
[    0.021844] CPU features: detected feature: 32-bit EL0 Support
[    0.021854] CPU: All CPU(s) started at EL2
[    0.021870] alternatives: patching kernel code
[    0.022609] devtmpfs: initialized
[    0.027817] random: get_random_u32 called from bucket_table_alloc+0x108/0x260
[    0.027965] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.027987] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.033427] xor: measuring software checksum speed
[    0.071740]    8regs     :  2302.000 MB/sec
[    0.111768]    8regs_prefetch:  2052.000 MB/sec
[    0.151798]    32regs    :  2830.000 MB/sec
[    0.191829]    32regs_prefetch:  2381.000 MB/sec
[    0.191837] xor: using function: 32regs (2830.000 MB/sec)
[    0.191907] pinctrl core: initialized pinctrl subsystem
[    0.192147] random: fast init done
[    0.192427] NET: Registered protocol family 16
[    0.192976] cpuidle: using governor menu
[    0.193510] vdso: 2 pages (1 code @ ffffff8008a96000, 1 data @ ffffff8008e54)
[    0.193526] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.194000] DMA: preallocated 256 KiB pool for atomic allocations
[    0.214945] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.215593] ARM CCI_400_r1 PMU driver probed
[    0.219813] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.221469] sysfs: cannot create duplicate filename '/bus/platform/devices/f'
[    0.221494] ------------[ cut here ]------------
[    0.221511] WARNING: CPU: 2 PID: 1 at /kernel-source//fs/sysfs/dir.c:31 sysf8
[    0.221521] Modules linked in:
[    0.221533] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.14.0 #1
[    0.221541] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[    0.221548] task: ffffffc87b846d00 task.stack: ffffff8008038000
[    0.221558] PC is at sysfs_warn_dup+0x5c/0x78
[    0.221566] LR is at sysfs_warn_dup+0x5c/0x78
[    0.221573] pc : [<ffffff800821298c>] lr : [<ffffff800821298c>] pstate: 60005
[    0.221582] sp : ffffff800803bb90
[    0.221588] x29: ffffff800803bb90 x28: ffffff8008e383f8
[    0.221598] x27: 0000000000000004 x26: 0000000000000000
[    0.221608] x25: 0000000000000000 x24: ffffff80090f9000
[    0.221617] x23: 0000000000000001 x22: ffffffc87b836880
[    0.221627] x21: ffffffc87b836880 x20: ffffffc87b113200
[    0.221637] x19: ffffffc87bb1a000 x18: 0000000000000010
[    0.221646] x17: 0000000000000001 x16: 0000000000000001
[    0.221656] x15: ffffffffffffffff x14: 0720072007200720
[    0.221666] x13: 0720072007200720 x12: 0720072007200720
[    0.221676] x11: 0720072007200720 x10: 0720072007200720
[    0.221685] x9 : 0720072007200720 x8 : 0720072007200720
[    0.221695] x7 : 0720072007200720 x6 : 0000000000000063
[    0.221704] x5 : ffffff800849b9c8 x4 : 0000000000000000
[    0.221714] x3 : 0000000000000000 x2 : ffffffffffffffff
[    0.221723] x1 : ffffff8008e6c8e8 x0 : 000000000000004c
[    0.221733] Call trace:
[    0.221741] Exception stack(0xffffff800803ba50 to 0xffffff800803bb90)
[    0.221750] ba40:                                   000000000000004c ffffff88
[    0.221762] ba60: ffffffffffffffff 0000000000000000 0000000000000000 ffffff88
[    0.221774] ba80: 0000000000000063 0720072007200720 0720072007200720 07200720
[    0.221785] baa0: 0720072007200720 0720072007200720 0720072007200720 07200720
[    0.221797] bac0: 0720072007200720 ffffffffffffffff 0000000000000001 00000001
[    0.221808] bae0: 0000000000000010 ffffffc87bb1a000 ffffffc87b113200 ffffffc0
[    0.221820] bb00: ffffffc87b836880 0000000000000001 ffffff80090f9000 00000000
[    0.221831] bb20: 0000000000000000 0000000000000004 ffffff8008e383f8 ffffff80
[    0.221843] bb40: ffffff800821298c ffffff800803bb90 ffffff800821298c 00000005
[    0.221854] bb60: ffffffc87b113200 0000000000000073 ffffffffffffffff 80000000
[    0.221865] bb80: ffffff800803bb90 ffffff800821298c
[    0.221874] [<ffffff800821298c>] sysfs_warn_dup+0x5c/0x78
[    0.221883] [<ffffff8008212dec>] sysfs_do_create_link_sd.isra.0+0xec/0xf8
[    0.221893] [<ffffff8008212e18>] sysfs_create_link+0x20/0x40
[    0.221905] [<ffffff800856ee58>] bus_add_device+0x68/0x138
[    0.221916] [<ffffff800856cf4c>] device_add+0x334/0x598
[    0.221927] [<ffffff800878ce28>] of_device_add+0x38/0x48
[    0.221937] [<ffffff800878d3ec>] of_platform_device_create_pdata+0x84/0xe8
[    0.221948] [<ffffff800878d5b8>] of_platform_bus_create+0x120/0x348
[    0.221958] [<ffffff800878d964>] of_platform_populate+0x7c/0xe8
[    0.221969] [<ffffff8008dfc0f4>] of_platform_default_populate_init+0x64/0x78
[    0.221981] [<ffffff8008083980>] do_one_initcall+0x38/0x128
[    0.221992] [<ffffff8008dd0cc4>] kernel_init_freeable+0x138/0x1d8
[    0.222004] [<ffffff8008a76b48>] kernel_init+0x10/0x100
[    0.222014] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    0.222024] ---[ end trace 48230142efff2616 ]---
[    0.222113] sysfs: cannot create duplicate filename '/bus/platform/devices/f'
[    0.222133] ------------[ cut here ]------------
[    0.222143] WARNING: CPU: 2 PID: 1 at /kernel-source//fs/sysfs/dir.c:31 sysf8
[    0.222153] Modules linked in:
[    0.222162] CPU: 2 PID: 1 Comm: swapper/0 Tainted: G        W       4.14.0 #1
[    0.222170] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[    0.222178] task: ffffffc87b846d00 task.stack: ffffff8008038000
[    0.222186] PC is at sysfs_warn_dup+0x5c/0x78
[    0.222194] LR is at sysfs_warn_dup+0x5c/0x78
[    0.222202] pc : [<ffffff800821298c>] lr : [<ffffff800821298c>] pstate: 60005
[    0.222211] sp : ffffff800803bb90
[    0.222217] x29: ffffff800803bb90 x28: ffffff8008e383f8
[    0.222226] x27: 0000000000000004 x26: 0000000000000000
[    0.222236] x25: 0000000000000000 x24: ffffff80090f9000
[    0.222246] x23: 0000000000000001 x22: ffffffc87b836880
[    0.222255] x21: ffffffc87b836880 x20: ffffffc87b113300
[    0.222265] x19: ffffffc87bb18000 x18: 0000000000000010
[    0.222275] x17: 0000000000000001 x16: 0000000000000001
[    0.222284] x15: ffffffffffffffff x14: 0720072007200720
[    0.222294] x13: 0720072007200720 x12: 0720072007200720
[    0.222303] x11: 0720072007200720 x10: 0720072007200720
[    0.222313] x9 : 0720072007200720 x8 : 0720072007200720
[    0.222323] x7 : 0720072007200720 x6 : 0000000000000099
[    0.222332] x5 : ffffff800849b9c8 x4 : 0000000000000000
[    0.222341] x3 : 0000000000000000 x2 : ffffffffffffffff
[    0.222351] x1 : ffffff8008e6c8e8 x0 : 000000000000004c
[    0.222360] Call trace:
[    0.222367] Exception stack(0xffffff800803ba50 to 0xffffff800803bb90)
[    0.222376] ba40:                                   000000000000004c ffffff88
[    0.222387] ba60: ffffffffffffffff 0000000000000000 0000000000000000 ffffff88
[    0.222399] ba80: 0000000000000099 0720072007200720 0720072007200720 07200720
[    0.222411] baa0: 0720072007200720 0720072007200720 0720072007200720 07200720
[    0.222422] bac0: 0720072007200720 ffffffffffffffff 0000000000000001 00000001
[    0.222434] bae0: 0000000000000010 ffffffc87bb18000 ffffffc87b113300 ffffffc0
[    0.222445] bb00: ffffffc87b836880 0000000000000001 ffffff80090f9000 00000000
[    0.222457] bb20: 0000000000000000 0000000000000004 ffffff8008e383f8 ffffff80
[    0.222469] bb40: ffffff800821298c ffffff800803bb90 ffffff800821298c 00000005
[    0.222480] bb60: ffffffc87b113300 0000000000000073 ffffffffffffffff 80000000
[    0.222491] bb80: ffffff800803bb90 ffffff800821298c
[    0.222499] [<ffffff800821298c>] sysfs_warn_dup+0x5c/0x78
[    0.222509] [<ffffff8008212dec>] sysfs_do_create_link_sd.isra.0+0xec/0xf8
[    0.222518] [<ffffff8008212e18>] sysfs_create_link+0x20/0x40
[    0.222529] [<ffffff800856ee58>] bus_add_device+0x68/0x138
[    0.222538] [<ffffff800856cf4c>] device_add+0x334/0x598
[    0.222548] [<ffffff800878ce28>] of_device_add+0x38/0x48
[    0.222558] [<ffffff800878d3ec>] of_platform_device_create_pdata+0x84/0xe8
[    0.222568] [<ffffff800878d5b8>] of_platform_bus_create+0x120/0x348
[    0.222578] [<ffffff800878d964>] of_platform_populate+0x7c/0xe8
[    0.222588] [<ffffff8008dfc0f4>] of_platform_default_populate_init+0x64/0x78
[    0.222598] [<ffffff8008083980>] do_one_initcall+0x38/0x128
[    0.222608] [<ffffff8008dd0cc4>] kernel_init_freeable+0x138/0x1d8
[    0.222619] [<ffffff8008a76b48>] kernel_init+0x10/0x100
[    0.222628] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    0.222635] ---[ end trace 48230142efff2617 ]---
[    0.229011] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.295986] raid6: int64x1  gen()   403 MB/s
[    0.364037] raid6: int64x1  xor()   446 MB/s
[    0.432067] raid6: int64x2  gen()   689 MB/s
[    0.500093] raid6: int64x2  xor()   602 MB/s
[    0.568167] raid6: int64x4  gen()  1042 MB/s
[    0.636213] raid6: int64x4  xor()   741 MB/s
[    0.704229] raid6: int64x8  gen()   979 MB/s
[    0.772299] raid6: int64x8  xor()   745 MB/s
[    0.840322] raid6: neonx1   gen()   726 MB/s
[    0.908372] raid6: neonx1   xor()   850 MB/s
[    0.976458] raid6: neonx2   gen()  1170 MB/s
[    1.044474] raid6: neonx2   xor()  1207 MB/s
[    1.112516] raid6: neonx4   gen()  1504 MB/s
[    1.180555] raid6: neonx4   xor()  1440 MB/s
[    1.248640] raid6: neonx8   gen()  1652 MB/s
[    1.316660] raid6: neonx8   xor()  1532 MB/s
[    1.316668] raid6: using algorithm neonx8 gen() 1652 MB/s
[    1.316676] raid6: .... xor() 1532 MB/s, rmw enabled
[    1.316683] raid6: using neon recovery algorithm
[    1.318008] vgaarb: loaded
[    1.318183] SCSI subsystem initialized
[    1.318352] usbcore: registered new interface driver usbfs
[    1.318391] usbcore: registered new interface driver hub
[    1.318432] usbcore: registered new device driver usb
[    1.318496] media: Linux media interface: v0.10
[    1.318522] Linux video capture interface: v2.00
[    1.318562] pps_core: LinuxPPS API ver. 1 registered
[    1.318570] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    1.318590] PTP clock support registered
[    1.318615] EDAC MC: Ver: 3.0.0
[    1.318976] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.319120] FPGA manager framework
[    1.319226] fpga-region fpga-full: FPGA Region probed
[    1.319315] Advanced Linux Sound Architecture Driver Initialized.
[    1.319562] Bluetooth: Core ver 2.22
[    1.319591] NET: Registered protocol family 31
[    1.319599] Bluetooth: HCI device and connection manager initialized
[    1.319610] Bluetooth: HCI socket layer initialized
[    1.319619] Bluetooth: L2CAP socket layer initialized
[    1.319638] Bluetooth: SCO socket layer initialized
[    1.320112] clocksource: Switched to clocksource arch_sys_counter
[    1.320188] VFS: Disk quotas dquot_6.6.0
[    1.320228] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.324246] NET: Registered protocol family 2
[    1.324540] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[    1.324751] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.325167] TCP: Hash tables configured (established 32768 bind 32768)
[    1.325237] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.325314] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.325470] NET: Registered protocol family 1
[    1.325668] RPC: Registered named UNIX socket transport module.
[    1.325678] RPC: Registered udp transport module.
[    1.325685] RPC: Registered tcp transport module.
[    1.325692] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.326063] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.326216] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[    1.326855] audit: initializing netlink subsys (disabled)
[    1.327213] audit: type=2000 audit(1.308:1): state=initialized audit_enabled1
[    1.327253] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    1.327922] NFS: Registering the id_resolver key type
[    1.327943] Key type id_resolver registered
[    1.327950] Key type id_legacy registered
[    1.327962] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.327982] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[    1.351445] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    1.351465] io scheduler noop registered
[    1.351473] io scheduler deadline registered
[    1.351494] io scheduler cfq registered (default)
[    1.351502] io scheduler mq-deadline registered
[    1.351510] io scheduler kyber registered
[    1.352729] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.353088] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.353254] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.353411] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.353570] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.353727] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.353885] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.354041] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.354200] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.379180] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.382180] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.386228] brd: module loaded
[    1.389544] loop: module loaded
[    1.390318] ahci-ceva fd0c0000.ahci: couldn't get PHY in node ahci: -517
[    1.390467] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.391884] m25p80 spi0.0: SPI-NOR-UniqueID 1044002c3496001002001c00cc4617650
[    1.391899] m25p80 spi0.0: found n25q512a, expected m25p80
[    1.392074] m25p80 spi0.0: n25q512a (131072 Kbytes)
[    1.392100] 4 ofpart partitions found on MTD device spi0.0
[    1.392134] Creating 4 MTD partitions on "spi0.0":
[    1.392147] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[    1.392612] 0x000000100000-0x000000600000 : "qspi-linux"
[    1.392997] 0x000000600000-0x000000620000 : "qspi-device-tree"
[    1.393375] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[    1.394598] libphy: Fixed MDIO Bus: probed
[    1.395584] tun: Universal TUN/TAP device driver, 1.6
[    1.395739] CAN device driver interface
[    1.397856] macb ff0e0000.ethernet: Not enabling partial store and forward
[    1.398245] libphy: MACB_mii_bus: probed
[    1.398761] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0)
[    1.398777] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [T)
[    1.399411] usbcore: registered new interface driver asix
[    1.399466] usbcore: registered new interface driver ax88179_178a
[    1.399497] usbcore: registered new interface driver cdc_ether
[    1.399529] usbcore: registered new interface driver net1080
[    1.399559] usbcore: registered new interface driver cdc_subset
[    1.399589] usbcore: registered new interface driver zaurus
[    1.399628] usbcore: registered new interface driver cdc_ncm
[    1.399880] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    1.401137] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.401148] ehci-pci: EHCI PCI platform driver
[    1.401401] usbcore: registered new interface driver uas
[    1.401441] usbcore: registered new interface driver usb-storage
[    1.401910] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rt0
[    1.401964] i2c /dev entries driver
[    1.402070] cdns-i2c ff020000.i2c: could not find pctldev for node /amba/gpie
[    1.402636] IR NEC protocol handler initialized
[    1.402645] IR RC5(x/sz) protocol handler initialized
[    1.402653] IR RC6 protocol handler initialized
[    1.402659] IR JVC protocol handler initialized
[    1.402666] IR Sony protocol handler initialized
[    1.402673] IR SANYO protocol handler initialized
[    1.402680] IR Sharp protocol handler initialized
[    1.402687] IR MCE Keyboard/mouse protocol handler initialized
[    1.402695] IR XMP protocol handler initialized
[    1.403918] usbcore: registered new interface driver uvcvideo
[    1.403927] USB Video Class driver (1.1.1)
[    1.404446] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff80091s
[    1.404616] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at ffffff80091s
[    1.404782] Bluetooth: HCI UART driver ver 2.3
[    1.404793] Bluetooth: HCI UART protocol H4 registered
[    1.404801] Bluetooth: HCI UART protocol BCSP registered
[    1.404827] Bluetooth: HCI UART protocol LL registered
[    1.404835] Bluetooth: HCI UART protocol ATH3K registered
[    1.404843] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.404885] Bluetooth: HCI UART protocol Intel registered
[    1.404893] Bluetooth: HCI UART protocol QCA registered
[    1.404932] usbcore: registered new interface driver bcm203x
[    1.404965] usbcore: registered new interface driver bpa10x
[    1.404999] usbcore: registered new interface driver bfusb
[    1.405034] usbcore: registered new interface driver btusb
[    1.405042] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    1.405090] usbcore: registered new interface driver ath3k
[    1.405207] EDAC MC: ECC not enabled
[    1.405386] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac contro)
[    1.405873] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880z
[    1.405929] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changez
[    1.406299] sdhci: Secure Digital Host Controller Interface driver
[    1.406308] sdhci: Copyright(c) Pierre Ossman
[    1.406315] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.456215] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMAt
[    1.462274] ledtrig-cpu: registered to indicate activity on CPUs
[    1.462423] usbcore: registered new interface driver usbhid
[    1.462432] usbhid: USB HID core driver
[    1.464298] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    1.465670] usbcore: registered new interface driver snd-usb-audio
[    1.466378] pktgen: Packet Generator for packet performance testing. Version5
[    1.468611] Netfilter messages via NETLINK v0.30.
[    1.468725] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.468873] Initializing XFRM netlink socket
[    1.468934] NET: Registered protocol family 10
[    1.469339] Segment Routing with IPv6
[    1.469383] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.469565] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.469878] NET: Registered protocol family 17
[    1.469894] NET: Registered protocol family 15
[    1.469915] bridge: filtering via arp/ip/ip6tables is no longer available by.
[    1.469929] Ebtables v2.0 registered
[    1.470017] can: controller area network core (rev 20170425 abi 9)
[    1.470051] NET: Registered protocol family 29
[    1.470066] can: raw protocol (rev 20170425)
[    1.470074] can: broadcast manager protocol (rev 20170425 t)
[    1.470085] can: netlink gateway (rev 20170425) max_hops=1
[    1.470299] Bluetooth: RFCOMM TTY layer initialized
[    1.470312] Bluetooth: RFCOMM socket layer initialized
[    1.470329] Bluetooth: RFCOMM ver 1.11
[    1.470340] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.470347] Bluetooth: BNEP filters: protocol multicast
[    1.470357] Bluetooth: BNEP socket layer initialized
[    1.470365] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.470375] Bluetooth: HIDP socket layer initialized
[    1.470422] sctp: Hash tables configured (bind 256/256)
[    1.470581] 9pnet: Installing 9P2000 support
[    1.470601] Key type dns_resolver registered
[    1.470916] registered taskstats version 1
[    1.471232] Btrfs loaded, crc32c=crc32c-generic
[    1.476715] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 41, base_baud s
[    1.624043] mmc0: new high speed SDHC card at address 0001
[    1.631708] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[    1.639308]  mmcblk0: p1 p2
[    3.691642] console [ttyPS0] enabled
[    3.695847] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 42, base_baud s
[    3.706507] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_ls
[    3.714758] PLL: shutdown
[    3.719435] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0d
[    3.730121] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound Pd
[    3.738164] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound Pd
[    3.746490] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xk
[    3.758927] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xk
[    3.771598] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xd
[    3.781780] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[    3.788775] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.795389] [drm] No driver support for vblank timestamp query.
[    3.801368] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff)
[    4.888124] [drm] Cannot find any crtc or sizes
[    4.892828] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-displa0
[    4.900936] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsyd
[    4.909912] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_ls
[    4.917799] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps e
[    4.926763] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp f
[    4.937116] scsi host0: ahci-ceva
[    4.940620] scsi host1: ahci-ceva
[    4.944027] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x7
[    4.951944] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x7
[    4.961609] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_ls
[    4.969661] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.975158] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n1
[    4.983024] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100
[    4.991753] xhci-hcd xhci-hcd.0.auto: irq 48, io mem 0xfe200000
[    4.997782] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    5.004575] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    5.011795] usb usb1: Product: xHCI Host Controller
[    5.016671] usb usb1: Manufacturer: Linux 4.14.0 xhci-hcd
[    5.022070] usb usb1: SerialNumber: xhci-hcd.0.auto
[    5.027212] hub 1-0:1.0: USB hub found
[    5.030983] hub 1-0:1.0: 1 port detected
[    5.035078] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    5.040573] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n2
[    5.048356] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    5.055150] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    5.062371] usb usb2: Product: xHCI Host Controller
[    5.067246] usb usb2: Manufacturer: Linux 4.14.0 xhci-hcd
[    5.072644] usb usb2: SerialNumber: xhci-hcd.0.auto
[    5.077753] hub 2-0:1.0: USB hub found
[    5.081519] hub 2-0:1.0: 1 port detected
[    5.085869] cdns-i2c ff020000.i2c: could not find pctldev for node /amba/gpie
[    5.096903] at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    5.103635] i2c i2c-1: Added multiplexed i2c bus 3
[    5.108621] i2c i2c-1: Added multiplexed i2c bus 4
[    5.115525] si570 5-005d: registered, current frequency 300000000 Hz
[    5.121909] i2c i2c-1: Added multiplexed i2c bus 5
[    5.140684] si570 6-005d: registered, current frequency 148500000 Hz
[    5.147061] i2c i2c-1: Added multiplexed i2c bus 6
[    5.152046] si5324 7-0069: si5328 probed
[    5.216076] si5324 7-0069: si5328 probe successful
[    5.220893] i2c i2c-1: Added multiplexed i2c bus 7
[    5.225800] i2c i2c-1: Added multiplexed i2c bus 8
[    5.230705] i2c i2c-1: Added multiplexed i2c bus 9
[    5.235607] i2c i2c-1: Added multiplexed i2c bus 10
[    5.240486] pca954x 1-0074: registered 8 multiplexed busses for I2C switch p8
[    5.248379] i2c i2c-1: Added multiplexed i2c bus 11
[    5.253380] i2c i2c-1: Added multiplexed i2c bus 12
[    5.258382] i2c i2c-1: Added multiplexed i2c bus 13
[    5.263701] i2c i2c-1: Added multiplexed i2c bus 14
[    5.268703] i2c i2c-1: Added multiplexed i2c bus 15
[    5.273708] i2c i2c-1: Added multiplexed i2c bus 16
[    5.274310] ata2: SATA link down (SStatus 0 SControl 330)
[    5.274333] ata1: SATA link down (SStatus 0 SControl 330)
[    5.289487] i2c i2c-1: Added multiplexed i2c bus 17
[    5.294492] i2c i2c-1: Added multiplexed i2c bus 18
[    5.299366] pca954x 1-0075: registered 8 multiplexed busses for I2C switch p8
[    5.306956] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 26
[    5.313396] cdns-i2c ff020000.i2c: could not find pctldev for node /amba/gpie
[    5.323681] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.330558] rtc_zynqmp ffa60000.rtc: setting system clock to 2020-01-02 08:3)
[    5.339432] of_cfs_init
[    5.341885] of_cfs_init: OK
[    5.344858] PLL: shutdown
[    5.347476] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13
[    5.355605] ALSA device list:
[    5.358565]   #0: DisplayPort monitor
[    5.362717] cdns-i2c ff020000.i2c: could not find pctldev for node /amba/gpie
[    5.372314] VFS: Cannot open root device "(null)" or unknown-block(0,0): err6
[    5.379809] Please append a correct "root=" boot option; here are the availa:
[    5.388164] 0100           65536 ram0
[    5.388166]  (driver?)
[    5.394259] 0101           65536 ram1
[    5.394260]  (driver?)
[    5.400360] 0102           65536 ram2
[    5.400362]  (driver?)
[    5.406445] 0103           65536 ram3
[    5.406447]  (driver?)
[    5.412539] 0104           65536 ram4
[    5.412541]  (driver?)
[    5.418629] 0105           65536 ram5
[    5.418630]  (driver?)
[    5.424727] 0106           65536 ram6
[    5.424729]  (driver?)
[    5.430817] 0107           65536 ram7
[    5.430818]  (driver?)
[    5.436917] 0108           65536 ram8
[    5.436919]  (driver?)
[    5.443013] 0109           65536 ram9
[    5.443015]  (driver?)
[    5.449112] 010a           65536 ram10
[    5.449114]  (driver?)
[    5.455288] 010b           65536 ram11
[    5.455289]  (driver?)
[    5.461473] 010c           65536 ram12
[    5.461475]  (driver?)
[    5.467650] 010d           65536 ram13
[    5.467651]  (driver?)
[    5.473835] 010e           65536 ram14
[    5.473836]  (driver?)
[    5.480011] 010f           65536 ram15
[    5.480012]  (driver?)
[    5.486200] 1f00            1024 mtdblock0
[    5.486202]  (driver?)
[    5.492733] 1f01            5120 mtdblock1
[    5.492735]  (driver?)
[    5.499257] 1f02             128 mtdblock2
[    5.499258]  (driver?)
[    5.505789] 1f03            6016 mtdblock3
[    5.505791]  (driver?)
[    5.512317] b300        31260672 mmcblk0
[    5.512319]  driver: mmcblk
[    5.519110]   b301          262144 mmcblk0p1 f65c7036-01
[    5.519112]
[    5.525898]   b302        30997504 mmcblk0p2 f65c7036-02
[    5.525900]
[    5.532691] Kernel panic - not syncing: VFS: Unable to mount root fs on unkn)
[    5.540947] CPU: 3 PID: 1 Comm: swapper/0 Tainted: G        W       4.14.0 #1
[    5.548069] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[    5.553025] Call trace:
[    5.555471] [<ffffff8008088c58>] dump_backtrace+0x0/0x368
[    5.560858] [<ffffff8008088fd4>] show_stack+0x14/0x20
[    5.565903] [<ffffff8008a647f8>] dump_stack+0x9c/0xbc
[    5.570945] [<ffffff800809b308>] panic+0x11c/0x274
[    5.575728] [<ffffff8008dd1124>] mount_block_root+0x1a8/0x27c
[    5.581465] [<ffffff8008dd1430>] mount_root+0x11c/0x134
[    5.586682] [<ffffff8008dd15b4>] prepare_namespace+0x16c/0x1b4
[    5.592508] [<ffffff8008dd0d44>] kernel_init_freeable+0x1b8/0x1d8
[    5.598595] [<ffffff8008a76b48>] kernel_init+0x10/0x100
[    5.603810] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    5.609113] SMP: stopping secondary CPUs
[    5.613028] Kernel Offset: disabled
[    5.616508] CPU features: 0x002004
[    5.619901] Memory Limit: none
[    5.622943] ---[ end Kernel panic - not syncing: VFS: Unable to mount root f)
