How to create an AD9361 and ZC7035 project?
Hi all!
I want to create a project with ZC7035 part and AD9361 in the enviroment of Vivado 2016.2. I downloaded the HDL source code from https://wiki.analog.com/resources/fpga/docs/releases and the version is hdl_2016_r2.
But I found that it does not support ZC7035 natively. So I tried to modify the part to ZC7035ffg676-2 and upgrade all the IP cores using other development board versions(e.g. Zed, ZC706),  then I got so many critical warnings about pin configuration, importantly there are some xdc configuration conflicts. It‘s difficult to correct them one by one.
So Is my operation correct? Please suggest me If I am wrong. And is there any other method to solve this problem?
thank you all so much!
regards.
