AD9361 linux driver does not recognize reset-gpios setting and not listed in iio_info -s output
I'm trying to configure linux for AD9361 device. The board is zcu102 based.
So far I could make the driver to initialize successful, however I see some messages in dmesg output which makes me worry.
I do not see the device in iio_info -s output, but iio_info prints all the details about the device.
Is the fact that there is a  appropriate device tree in /sys/bus/iio/adc/ enough to think the device is correctly initialized ?
Here are the messages I see despite the fact I set all the settings needed (IMHO):
[    3.224189] ad9361 spi1.2: ad9361_probe : enter (ad9361)
[    3.230400] ad9361 spi1.2: No GPIOs defined for ext band ctrl
[    3.236244] ad9361 spi1.2: ad9361_reset: by SPI, this may cause unpredicted behavior!
[    3.483104] ad9361 spi1.2: ad9361_probe : AD936x Rev 2 successfully initialized
Below is my device-tree configuration for AD9361
/include/ "system-conf.dtsi"
clocks {
		ad9361_clkin: clock@0 {
			compatible = "fixed-clock";
			clock-frequency = <40000000>;
			clock-output-names = "ad9361_ext_refclk";
			#clock-cells = <0>;
&spi0 {
	adc0_ad9361: ad9361-phy@0 {
		#address-cells = <1>;
		#size-cells = <0>;
		#clock-cells = <1>;
		compatible = "adi,ad9361";
		/* SPI Setup */
		reg = <2>;
		spi-cpha;
		spi-max-frequency = <10000000>;
        txnrx-gpios = <&axi_gpio_0 1 0>;
        reset-gpios = <&axi_gpio_0 2 0>;
        en_agc-gpios = <&axi_gpio_0 3 0>;
        enable-gpios = <&axi_gpio_0 4 0>;
		/* Clocks */
		clocks = <&ad9361_clkin>;
		clock-names = "ad9361_ext_refclk";
		clock-output-names = "rx_sampl_clk", "tx_sampl_clk";
		/* Digital Interface Control */
		adi,pp-tx-swap-enable;
		adi,pp-rx-swap-enable;
		adi,rx-frame-pulse-mode-enable;
		adi,lvds-mode-enable;
		adi,lvds-bias-mV = <150>;
		adi,lvds-rx-onchip-termination-enable;
		adi,rx-data-clock-delay = <0>;
		adi,rx-data-delay = <9>;
		adi,tx-fb-clock-delay = <4>;
		adi,tx-data-delay = <0>;
		//adi,fdd-rx-rate-2tx-enable;
		//adi,dcxo-coarse-and-fine-tune = <8 5920>;
		adi,xo-disable-use-ext-refclk-enable;
		/* Mode Setup */
		adi,2rx-2tx-mode-enable;
		//adi,split-gain-table-mode-enable;
		/* ENSM Mode */
		adi,frequency-division-duplex-mode-enable;
		//adi,ensm-enable-pin-pulse-mode-enable;
		//adi,ensm-enable-txnrx-control-enable;
		adi,rx1-rx2-phase-inversion-enable;
		/* adi,rx-rf-port-input-select:
		 * 0 = (RX1A_N &  RX1A_P) and (RX2A_N & RX2A_P) enabled; balanced
		 * 1 = (RX1B_N &  RX1B_P) and (RX2B_N & RX2B_P) enabled; balanced
		 * 2 = (RX1C_N &  RX1C_P) and (RX2C_N & RX2C_P) enabled; balanced
		 * 3 = RX1A_N and RX2A_N enabled; unbalanced
		 * 4 = RX1A_P and RX2A_P enabled; unbalanced
		 * 5 = RX1B_N and RX2B_N enabled; unbalanced
		 * 6 = RX1B_P and RX2B_P enabled; unbalanced
		 * 7 = RX1C_N and RX2C_N enabled; unbalanced
		 * 8 = RX1C_P and RX2C_P enabled; unbalanced
		adi,rx-rf-port-input-select = <0>; /* (RX1A_N &  RX1A_P) and (RX2A_N & RX2A_P) enabled; balanced */
		/* adi,tx-rf-port-input-select:
		 * 0	TX1A, TX2A
		 * 1	TX1B, TX2B
		adi,tx-rf-port-input-select = <0>; /* TX1A, TX2A */
		//adi,update-tx-gain-in-alert-enable;
		adi,tx-attenuation-mdB = <10000>;
		adi,tx-lo-powerdown-managed-enable;
		adi,rf-rx-bandwidth-hz = <18000000>;
		adi,rf-tx-bandwidth-hz = <18000000>;
		adi,rx-synthesizer-frequency-hz = /bits/ 64 <2400000000>;
		adi,tx-synthesizer-frequency-hz = /bits/ 64 <2400000000>;
		/*				BBPLL     ADC        R2CLK     R1CLK    CLKRF    RSAMPL  */
		adi,rx-path-clock-frequencies = <983040000 245760000 122880000 61440000 30720000 30720000>;
		/*				BBPLL     DAC        T2CLK     T1CLK    CLKTF    TSAMPL  */
		adi,tx-path-clock-frequencies = <983040000 122880000 122880000 61440000 30720000 30720000>;
		/* Gain Control */
		/* adi,gc-rx[1|2]-mode:
		 * 0 = RF_GAIN_MGC
		 * 1 = RF_GAIN_FASTATTACK_AGC
		 * 2 = RF_GAIN_SLOWATTACK_AGC
		 * 3 = RF_GAIN_HYBRID_AGC
		adi,gc-rx1-mode = <2>;
		adi,gc-rx2-mode = <2>;
		adi,gc-adc-ovr-sample-size = <4>; /* sum 4 samples */
		adi,gc-adc-small-overload-thresh = <47>; /* sum of squares */
		adi,gc-adc-large-overload-thresh = <58>; /* sum of squares */
		adi,gc-lmt-overload-high-thresh = <800>; /* mV */
		adi,gc-lmt-overload-low-thresh = <704>; /* mV */
		adi,gc-dec-pow-measurement-duration = <8192>; /* 0..524288 Samples */
		adi,gc-low-power-thresh = <24>; /* 0..-64 dBFS vals are set pos */
		//adi,gc-dig-gain-enable;
		//adi,gc-max-dig-gain = <15>;
		/* Manual Gain Control Setup */
		//adi,mgc-rx1-ctrl-inp-enable; /* uncomment to use ctrl inputs */
		//adi,mgc-rx2-ctrl-inp-enable; /* uncomment to use ctrl inputs */
		adi,mgc-inc-gain-step = <2>;
		adi,mgc-dec-gain-step = <2>;
		/* adi,mgc-split-table-ctrl-inp-gain-mode:
		 * (relevant if adi,split-gain-table-mode-enable is set)
		 * 0 = AGC determine this
		 * 1 = only in LPF
		 * 2 = only in LMT
		adi,mgc-split-table-ctrl-inp-gain-mode = <0>;
		/* Automatic Gain Control Setup */
		adi,agc-attack-delay-extra-margin-us= <1>; /* us */
		adi,agc-outer-thresh-high = <5>; /* -dBFS */
		adi,agc-outer-thresh-high-dec-steps = <2>; /* 0..15 */
		adi,agc-inner-thresh-high = <10>; /* -dBFS */
		adi,agc-inner-thresh-high-dec-steps = <1>; /* 0..7 */
		adi,agc-inner-thresh-low = <12>; /* -dBFS */
		adi,agc-inner-thresh-low-inc-steps = <1>; /* 0..7 */
		adi,agc-outer-thresh-low = <18>; /* -dBFS */
		adi,agc-outer-thresh-low-inc-steps = <2>; /* 0..15 */
		adi,agc-adc-small-overload-exceed-counter = <10>; /* 0..15 */
		adi,agc-adc-large-overload-exceed-counter = <10>; /* 0..15 */
		adi,agc-adc-large-overload-inc-steps = <2>; /* 0..15 */
		//adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable;
		adi,agc-lmt-overload-large-exceed-counter = <10>; /* 0..15 */
		adi,agc-lmt-overload-small-exceed-counter = <10>; /* 0..15 */
		adi,agc-lmt-overload-large-inc-steps = <2>; /* 0..7 */
		//adi,agc-dig-saturation-exceed-counter = <3>; /* 0..15 */
		//adi,agc-dig-gain-step-size = <4>; /* 1..8 */
		//adi,agc-sync-for-gain-counter-enable;
		adi,agc-gain-update-interval-us = <1000>;  /* 1ms */
		//adi,agc-immed-gain-change-if-large-adc-overload-enable;
		//adi,agc-immed-gain-change-if-large-lmt-overload-enable;
		/* Fast AGC */
		adi,fagc-dec-pow-measurement-duration = <64>; /* 64 Samples */
                //adi,fagc-allow-agc-gain-increase-enable;
                adi,fagc-lp-thresh-increment-steps = <1>;
                adi,fagc-lp-thresh-increment-time = <5>;
                adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt = <8>;
                adi,fagc-final-overrange-count = <3>;
                //adi,fagc-gain-increase-after-gain-lock-enable;
                adi,fagc-gain-index-type-after-exit-rx-mode = <0>;
                adi,fagc-lmt-final-settling-steps = <1>;
                adi,fagc-lock-level = <10>;
                adi,fagc-lock-level-gain-increase-upper-limit = <5>;
                adi,fagc-lock-level-lmt-gain-increase-enable;
                adi,fagc-lpf-final-settling-steps = <1>;
                adi,fagc-optimized-gain-offset = <5>;
                adi,fagc-power-measurement-duration-in-state5 = <64>;
                adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable;
                adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll = <10>;
                adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable;
                adi,fagc-rst-gla-if-en-agc-pulled-high-mode = <0>;
                adi,fagc-rst-gla-large-adc-overload-enable;
                adi,fagc-rst-gla-large-lmt-overload-enable;
                adi,fagc-rst-gla-stronger-sig-thresh-above-ll = <10>;
                adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable;
                adi,fagc-state-wait-time-ns = <260>;
                adi,fagc-use-last-lock-level-for-set-gain-enable;
		/* RSSI */
		/* adi,rssi-restart-mode:
		 * 0 = AGC_IN_FAST_ATTACK_MODE_LOCKS_THE_GAIN,
		 * 1 = EN_AGC_PIN_IS_PULLED_HIGH,
		 * 2 = ENTERS_RX_MODE,
		 * 3 = GAIN_CHANGE_OCCURS,
		 * 4 = SPI_WRITE_TO_REGISTER,
		 * 5 = GAIN_CHANGE_OCCURS_OR_EN_AGC_PIN_PULLED_HIGH,
		adi,rssi-restart-mode = <3>;
		//adi,rssi-unit-is-rx-samples-enable;
		adi,rssi-delay = <1>; /* 1us */
		adi,rssi-wait = <1>; /* 1us */
		adi,rssi-duration = <1000>; /* 1ms */
		/* Control Outputs */
		adi,ctrl-outs-index = <0>;
		adi,ctrl-outs-enable-mask = <0xFF>;
		/* AuxADC Temp Sense Control */
		adi,temp-sense-measurement-interval-ms = <1000>;
		adi,temp-sense-offset-signed = <0xCE>;
		adi,temp-sense-periodic-measurement-enable;
		/* AuxDAC Control */
		adi,aux-dac-manual-mode-enable;
		adi,aux-dac1-default-value-mV = <0>;
		//adi,aux-dac1-active-in-rx-enable;
		//adi,aux-dac1-active-in-tx-enable;
		//adi,aux-dac1-active-in-alert-enable;
		adi,aux-dac1-rx-delay-us = <0>;
		adi,aux-dac1-tx-delay-us = <0>;
		adi,aux-dac2-default-value-mV = <0>;
		//adi,aux-dac2-active-in-rx-enable;
		//adi,aux-dac2-active-in-tx-enable;
		//adi,aux-dac2-active-in-alert-enable;
		adi,aux-dac2-rx-delay-us = <0>;
		adi,aux-dac2-tx-delay-us = <0>;
Do you see any wrong configuration here ?
I've adapted my config based on fscomms2 config from AD github.
Linux kernel is AD based as well.
Using petalinux 2019.1
Thanks in advance!
  • +1
    on Feb 25, 2020 11:01 AM
    Configuration looks ok.
    If the device shows up in /sys/bus/iio/devices, it is a good indicator that the driver loaded, but not behavior necessarily.
    Typically if you try a loopback cable and try to load a sine-wave and all looks good, then it should work.
    Or you could try to load the TX into an oscilloscope, or something, and test.
    It also depends on what you want to do.
    Depends on which libiio backend are you using. local backend, usb backend? network?
    Or whether libiio was built with the backend you are trying to use.
