ad9361 RX data rate
I'm using this design  example to find the frequency present at RX path using FFT.I'm using default HB filter configuration with no FIR filter.
What i noticed is that maximum data rate that i could have in HDL RX path is 61.44Mhz which is also confirmed by UG-570 guide. This also limits the maximum real-time frequency that can be calculated in RX path.  If i want to use 1RXTX mode of ad9361, is it possible to have more than 61.4Mhz data rate? Like bypassing HB filters? Because RX path after the adc_axis_fifo is running at 100Mhz. Just wanted to confirm these facts before moving forward in my project.
Regards
