ADM3053
As testing, ADM3053 pin7 GND1 input impedance(about 20ohm) is different than other GND1 pin(about 2ohm).
When I let pin7 floating, the single noise is less then connected GND1.
Can you let me know why pin7 is different than other GND1 pin.
if I let pin7 floating, is it OK?
thanks.
  • Hi Jackey,
    The reason for your different input impedance measurements is due to the bond out wires from the package pins to dice within the ADM3053 package.
    Pin 7 needs to be connected to ground 1 (GND 1).
    Please see the ADM3053 data sheet page 15, Figure 28 which shows a typical ground fill for Pin 7.
    Best Regards,
    Richard
