ADUM2251 Side2 Slave don't respond
I have a design (see Appendix), that makes some communication problems.
I have double-checked logic low level thershold and it is more than 0,9V since
Vcc and Vcc-p is 5V.
I have read this thread
https://ez.analog.com/message/75240#75240
and  I have also watched the Video from MSCantrell "How I2C Isolators work"
Video which is super helpfull.
When I use the digital Isolator for some reasons the MAX1238, don't pull down the data-line when
it should transmit the data-pattern. With no digital isolator everything works fine.
Has anybody an idea or hint ?
Thanks for your support.
  • Hi Maximilian,
    There are a couple of questions I would like to ask before I can give a proper response.
    You have stated that the logic low level threshold is more than 0,9V this is occurring only on side 1 or side 2 of the ADuM2251? My initial guess is side 1 but I just wanted to make sure.
    The second question is do you have any scope screenshots of what you are seeing? A with and without isolator
    comparison would be nice. As well as a Side 1 and Side 2 snapshot as well.
    The last question is there some sort of communication going on at all? You mention that the MAX1238 doesn’t pull the data-line down but the details seem vague.
    Joseph Shim
    Thank you,
    EZ Admin
